BGS5 REL.2
BGS5 REL.2
    THALES(泰雷兹)
    BGS5 REL.2
BGS5 REL.2 数据手册
2G Cinterion® BGS5 Wireless Module With Advanced Processing Power Cinterion® BGS5 Wireless Module With Advanced Processing Power BGS5 Quad Band 2G GPRS Class 12 Multi Design Capability (LGA) FOTA Configurable & Free of Charge Java embedded USB 2.0 High Speed Compatible Advanced Temperature Management Embedded TCP/IP Stack RLS Monitoring (Jamming Detection) Thales M2M is proud to introduce the Cinterion BGS5: the next step in advanced 2G machine-to-machine (M2M) processing and communications. BGS5 provides advanced processing and an embedded Java virtual machine to offload the application, or even remove the microprocessor, significantly reducing the device complexity and Bill of Material (BOM) cost. With a small footprint compatible with the Cinterion Industrial platform, it offers the perfect complement to 3G solutions when the application processing power is required, but the high throughput is not. At only 27.6 mm x 18.8 mm x 2.7 mm, BGS5 is the smallest module to offer advanced application processing power. It is a full Quad-Band GSM (850/900/1800/1900 MHz) module with GPRS class 12 support. Designed to deal with harsh environments, BGS5 supports M2M-grade extended temperature ranges. The application processor makes BGS5 the perfect fit for applications like track and trace or Automatic Meter Reading (AMR), remote maintenance and control, and aftermarket telematics. In such applications, the module itself can be programmed to collect specific information, process it via embedded business logic, and send the results at a scheduled time. Device makers can program and add applets to fit their needs, or use existing JSRs which are publically available. As the Java platform is open, this code can then be ported to other Java enabled devices later without requiring additional modifications. As part of our Edge-to-Enterprise concept, the embedded Java allows seamless integration between your application and the backend server – optimizing information collection and processing while ensuring you a future-proof infrastructure. In addition any infrastructure developed on this platform can easily be migrated to any other Java enabled Cinterion module. BGS5 is a key product for the Industrial platform which embeds intelligence directly in the module, saving you cost and design complexity! Perfect M2M at Minimal Footprint 27.6 mm LGA technology Land grid array, or LGA, is a surface-mount technology for fully automated manufacturing allowing to benefit from efficiency and process consistency. Cinterion’s unique type of LGA technology is designed with focus on highest reliability and flexibility and to meet the demanding requirements of M2M application manufacturers. 18.8 mm Multi Design Capability The unique BGS5 footprint, based on LGA technology, offers seamless migration from 2G to 3G within a single design footprint. Compatibility with the world’s smallest HSPA wireless module ensures future-proof design and longevity of M2M applications. Java™ Java offers easy and fast application development, a broad choice of tools, high code reusability, easy maintenance, a proven security concept, on-device debugging as well as multithreading programming and program execution. Thales M2M Support includes:  Personal design-in consulting for hardware and software Local engineers, a competent helpdesk, a dedicated team of R&D specialists and an advanced development center are the hallmarks of our leading support offer.  Extensive RF test capabilities  GCF/PTCRB conform pretests to validate approval readiness  Regular training workshops Cinterion® BGS5 Features General Features  GSM Quad-Band: 850 / 900 / 1800 / 1900 MHz 3GPP Release 6  GPRS multi-slot Class 12  Compliant to GSM phase 2/2+  Output power:  Class 4 (2W) ) for GSM850  Class 4 (2W) for GSM900  Class 1 (1W) for GSM1800  Class 1 (1W) for GSM1900  SIM Application Toolkit, Class 3  Control via standardized and extended AT commands (Hayes, TS 27.007 and 27.005)  TCP/IP stack access via AT commands and transparent TCP services  Secure Connection for client IP services  Internet Services TCP/UDP server/client, DNS, Ping, FTP client, HTTP client  Supply voltage range 3.3 - 4.5 V, highly optimized for minimal power consumption  LGA66 soldering mount, MSL4  Dimensions: 27.6 x 18.8 x 2.7 mm  Weight: 3 g  Operating temperature: -40°C to +85°C Specifications  GPRS Class 12 DL: max. 85.6 kbps, UL: max 85.6 kbps Mobile Station class B  CSD data transmission up to 9.6 kbps, V.110, non-transparent  USSD support  SMS text and PDU mode, cell broadcast  High quality digital voice support for handset, headset and handsfree operation  Speech codec: FR, HR, EFR and AMR Special Features  USB interface supports multiple composite mode and a Linux-/Mac- compliant mode   Firmware update via serial and USB interfaces   Real time clock with alarm functionality   Multiplexer according 3GPP TS 27.010   RLS Monitoring (Jamming detection)   Informal Network Scan   Customer IMEI/SIM-Lock as variant   Integrated FOTA, configurable and free of charge Java Open Platform  Java™ profile IMP-NG & CLDC 1.1 HI   Serial interface (4-wire)   UICC/SIM card interface 1.8 V and 3.0 V  4 GPIO pins (special option for PWM or Buzzer and status indication functionality)  I2C interface   ADC interface Drivers  Serial interface modem driver for Microsoft® Windows 8™, 7™, Vista™, XP™  USB and MUX Drivers for Microsoft® Windows Embedded Compact™ 7 and Embedded Handheld® 6.5   MUX Driver for Microsoft® 8™, 7™, Vista™, XP™   Secure data transmission with HTTPS/SSL Approvals  Multi-Threading programming and Multi-Application execution   CE, R&TTE, GCF, FCC, PTRCB, UL, IC   GCF Listing   5 MB RAM and 10 MB Flash File System   Other local approvals and network operator certifications Interfaces (Land Grid Array)   EuP, RoHS and REACH compliant   Power supply   Digital Audio interface, prepared for Analog Audio support   USB 2.0 Interface Thales in IoT: Driving digital transformation with the power of the IoT Thales delivers innovative IoT technology that simplifies and speeds enterprise digital transformation. For more than 20 years, our customers – in a wide range of industries - trust our IoT solutions to seamlessly connect and secure their IoT devices, maximise field insights, and accelerate their global business success. Thales solutions:  Connect assets to wireless networks and cloud platforms  Manage the long lifecycle of IoT solutions  Secure devices and their data  Analyse real-time data transforming it into business intelligence that improves decision making Our 360° approach provides the essential building blocks needed to simplify design, streamline development and accelerate timeto-market. For more information, please visit www.thalesgroup.com/IoT or follow @ThalesIoT on Twitter thalesgroup.com/iot  Thales has a policy of continuous development and improvement and consequently the equipment may vary from the description and specification in this document. This document may not be considered as a contract specification. Graphics do not indicate use or endorsement of the featured equipment or services. © Thales 2020. All rights reserved. Thales, the Thales logo, are trademarks and service marks of Thales and are registered in certain countries. 3 Jun 2020   Serial interface, including automatic baud rate detection
BGS5 REL.2 价格&库存
很抱歉,暂时无法提供与“BGS5 REL.2”相匹配的价格&库存,您可以联系我们找货
