ELS61-E REL2
ELS61-E REL2
    THALES(泰雷兹)
    LGA-122
    ELS61-E REL2
ELS61-E REL2 数据手册
LTE Cinterion® ELS61 Wireless Module LTE Cat 1 with 2G / 3G fallback Optimized for M2M IoT Solutions Cinterion® ELS61 Wireless Module Delivering LTE Cat 1 connectivity with 2G / 3G fallback ELS61 Five Band LTE Cat 1 JavaTM embedded Tri Band 3G HSPA Dual Band 2G GSM RLS Monitoring (Jamming Detection) USB 2.0 High Speed compatible Multi Design Capability (LGA) Embedded TCP/IP Stack Cell ID for On-Demand Positioning Incremental Firmware Update High quality voice support Thales Cinterion® ELS61 wireless module delivers highly efficient Cat 1 LTE connectivity for M2M IoT solutions offering seamless fall back to 2G and 3G networks. The best in class solution enables M2M optimized speeds of 10Mbit/s download and 5Mbit/s uplink making it ideal for the vast number of M2M and industrial IoT applications that are not dependent on speed but that requires the longevity of LTE networks, while still providing 3G and 2G connectivity to ensure complete population and geographic coverage as LTE rolls out. Applications well suited to the ELS61 solution include metering, tracking and tracing, remote surveillance, connected signs, fleet management and mHealth solutions. The Cinterion ELS61 module comes with a Java® embedded virtual machine leveraging a powerful ARM11 architecture which allows device manufacturers to utilize the massive to reduce complexity and speed application integration. The latest Java ME 3.2 client runtime platform reduces total cost of ownership (TCO) and time to market by sharing internal resources such as memory, a large existing code base and proven software building blocks. The module uses Multi MIDlet Java execution to simultaneously host and run multiple applications and protocols. An extended security concept with the latest TLS/SSL engine provides secure and reliable TCP/IP connectivity. Sophisticated sandbox modeling and layered architectures simplify device management and allow simultaneous progress of network operator approvals and application code development for a shorter time to market. A growing family of M2M-optimized LTE modules shares the same footprint as other Cinterion industrial modules enabling easy forward and backward migration from a single hardware design. Cinterion LTE Cat.1 modules deliver long product lifespans up to seven years, efficient bandwidth and power utilization plus a feature set that meets the rigorous requirements of M2M IoT solutions including extended operating temperatures from -40°C to 85°C. All Cinterion M2M modules come with global customer support, Full Type Approval (FTA) and local network operator certifications to ensure easy integration and a fast time to market for innovative solutions. The Cinterion ELS61 Cat.1 solution provides a dependable connectivity platform with the support needed for a fast time to market and a value you can trust. LTE Cat 1 Optimized for M2M IoT Solutions 27.6 mm JavaTM Java offers easy and fast application development, a broad choice of tools, high code reusability, easy maintenance, a proven security concept, on-device debugging as well as multi-threading programming and program execution. 25.4 mm BIP (Bearer Independent Protocol) Future proof and support for multi-designs Sharing a common footprint with existing Thales 2G, 3G and 4G modules, the unique form factor of ELS61 supports easy migration between existing wireless standards. In addition, the footprint matches forthcoming lower category LTE modules such as LTE Cat.M1 standards. BIP enables remote SIM provisioning according to latest GSMA’s embedded SIM specifications as well as over-the-air subscription management of eUICCs for the lifetime of M2M devices. This enables remote management of MNO subscriptions when device ownership changes or when the device is moved to another geographical location. In addition, ELS61 fully supports Thales On-Demand Connectivity solutions including On-Demand Provisioning Service for the secure remote download of MNO subscription profiles into embedded SIMs. Thales M2M Support includes:  Personal design-in consulting for hardware and software Local engineers, a competent helpdesk, a dedicated team of R&D specialists and an advanced development center are the hallmarks of our leading support offer.  Extensive RF test capabilities  GCF/PTCRB conform pretests to validate approval readiness  Regular training workshops Cinterion® ELS61 Features General Features   LTE (FDD) 3GPP Rel.9 Compliant Protocol Stack, RX-Diversity  Regional Variants ELS61-E: Penta-Band LTE: Bands 1, 3, 8, 20, 28 (700, 800,900, 1800, 2100 MHz), Dual-Band UMTS/HSPA+: Bands 8, 1 (900, 2100 MHz), Dual-Band GSM 900 and 1800 MHz ELS61-US/USA: Quad-Band LTE: Bands 2, 4, 5, 12 (700, 850,1700/2100 (AWS) and 1900 MHz), Tri-Band UMTS: Bands 5, 4, 2 (WCDMA/FDD 850, 1700/2100 (AWS) and 1900 MHz) ELS61-AUS: Quad-Band LTE: Bands 3, 5, 8, 28 (1800, 850,900, 700 MHz), Tri-Band UMTS: Bands 1, 5, 8 (WCDMA/FDD 2100, 850, 900 MHz)  SIM Application Toolkit, letter classes b, c, e with BIP and RunAT support  Control via standardized and extended ATcommands (Hayes, TS 27.007 and 27.005)   Embedded IP stack with IPv4/IPv6 support  TCP/IP stack access via AT command and transparent TCP/UDP services   Secure Connection with TLS  Internet Services TCP/UDP server/client, DNS, Ping, HTTP, SMTP, FTP client   LGA pad soldering mount, MSL4   Supply voltage range: 3.0 - 4.5 V   Dimension: 27.6 x 25.4 x 2.2 mm   Weight: 4g   Operating temperature: -40°C to +85°C Specifications  LTE Cat. 1 DL: max. 10.2 Mbps, UL: max. 5.2 Mbps  HSPA+ Cat.8 (ELS61-US/USA) data rates DL: max. 7.2 Mbps, UL: max. 5.76 Mbps   G  PRS Class 12 (ELS61-E) DL: max. 85.6 kbps, UL: max 85.6 kbps   SMS text and PDU mode support  VoLTE4 or CSFB4,5   Integrated TTY4,5 Special Features Interfaces (LGA Pads)  USB Interface features a composite mode, compliant to Windows, Linux and Mac   Power Supply   Firmware update via USB and ASC   USB 2.0 HS interface up to 480 Mbps   Incremental firmware update over-the-air   High speed serial modem interface ASC0   High-Quality Voice for handset and handfree operation4,5   Multiplexer according 3GPP TS 27.010  16 GPIO lines shared with DSR, DTR, DCD (all ASC0), ASC1 (RXD, TXD, RTS, CTS), SPI, Fast-Shutdown, Network-Status-Indication, PWM, Pulse-Counter lines   Real time clock with alarm functionality   ADC and I2C interface   RLS Monitoring (Jamming detection)   UICC and U/SIM card interface 1.8V / 3V   Informal Network Scan   Lines for Module-On and Reset   Customer IMEI/SIM-Lock as variant   Pads for RX-Diversity Antenna Java Open Platform Drivers   Java™ ME 3.2 embedded  USB, MUX driver for Microsoft® Windows 7TM and Microsoft® Windows 10TM   Multi-Threading programming and Multi-Application execution   18 MB RAM and 31 MB Flash File System   Secure data transmission with HTTPS/SSL   RIL Driver for Android versions KitKat (V4.x) and Lollipop (V5.x)  RIL, USB driver for Microsoft® Windows Embedded Handheld™ >= 6.x Approvals   CE, R&TTE, GCF, PTCRB, IC, UL   EuP, RoHS, REACH compliant ) ELS61-US only | 4) ELS61-USA only | 5) ELS61-E 2 Thales in IoT: Driving digital transformation with the power of the IoT Thales delivers innovative IoT technology that simplifies and speeds enterprise digital transformation. For more than 20 years, our customers – in a wide range of industries - trust our IoT solutions to seamlessly connect and secure their IoT devices, maximise field insights, and accelerate their global business success. Thales solutions:  Connect assets to wireless networks and cloud platforms  Manage the long lifecycle of IoT solutions  Secure devices and their data  Analyse real-time data transforming it into business intelligence that improves decision making Our 360° approach provides the essential building blocks needed to simplify design, streamline development and accelerate timeto-market. For more information, please visit www.thalesgroup.com/IoT or follow @ThalesIoT on Twitter thalesgroup.com/iot  Thales has a policy of continuous development and improvement and consequently the equipment may vary from the description and specification in this document. This document may not be considered as a contract specification. Graphics do not indicate use or endorsement of the featured equipment or services. © Thales 2018. All rights reserved. Thales, the Thales logo, are trademarks and service marks of Thales and are registered in certain countries. May 26 2020  AT&T2,4, Telstra and other local approvals and provider certifications
ELS61-E REL2 价格&库存
很抱歉,暂时无法提供与“ELS61-E REL2”相匹配的价格&库存,您可以联系我们找货
