BGS12 REL.2
BGS12 REL.2
    THALES(泰雷兹)
    BLGA-106
    BGS12 REL.2
BGS12 REL.2 数据手册
Cinterion® BGS12 IoT Wireless Module Secure Global 2G Connectivity with a Seamless Path to 5G Cinterion® BGS12 IoT Wireless Module Secure Global 2G Connectivity with a Seamless Path to 5G The Cinterion® BGS12 IoT Wireless Module delivers reliable global 2G GSM/GPRS to connect and protect applications today while supporting easy migration to 5G in the future. The latest 2G chipset enables efficient data speeds up to 86 kbps for downlink and uplink making the BGS12 IoT module ideal for long life solutions such as metering, tracking and tracing and remote maintenance and control. data. Customer manufacturing support services simplify the device test method (RF TX Wave Generation / RX Power Measurement) and provide a simplified set-up for customer manufacturing processes. Industrial Family Benefits Key Features The Cinterion BGS12 IoT module comes as Quad-Band GSM (850, 900, 1800, 1900MHz) and GPRS class 12 for global connectivity The module’s optimized power supply design and advanced power management system extends battery life and improves Total Cost of Ownership (TCO). An embedded IP stack with IPv4 support provides Internet service that is protected by an advanced security concept including TLS/DTLS support and jamming detection. A dual SIM with smart switching technology securely manages the connection to cellular networks and encrypts Secure Global 2G Connectivity with a Seamless Path to 5G The Cinterion BGS12 IoT wireless module is part of Gemalto’s Cinterion Industrial family, which offers reliability, M2M-optimized features and extreme efficiency for a range of cellular standards from 2G to 3G to LTE Cat. 1, LTE-M, NB-IoT and other 5G categories. All Industrial modules share a compatible footprint enabling seamless backward and forward migration to protect your IoT investment as technology needs change. Smart module variants with embedded systems powered by Java and Linux improve design simplicity and TCO. Complemented by Gemalto’s comprehensive suite of solutions, services and platforms, enterprises can easily Connect, Secure and Monetize™ IoT technology. Enhanced Security Concept Advanced TLS/DTLS support for IP based services and sophisticated encryption secure data shared between device and cloud service. RLS monitoring detects and defends against jamming attacks, triggering preventive actions to secure the device. Multi Design Capability 18.8 mm 27.6 mm The industry proven BGS12 IoT module footprint, based on LGA technology, ensures full compatibility within the product family, offering seamless migration from 2G to 5G with a single design. This ensures future-proofing and investment protection for the long life of IoT applications. IoT Advanced Power Saving In addition to standard 3GPP power saving capabilities, the module’s state of the art power management system reduces energy consumption and optimizes battery usage. Optimized power management helps to improve overall TCO. Cinterion® BGS12 Features GENERAL FEATURES > 3GPP R99 Compliant Protocol Stack > Quad-Band GSM (850, 900, 1800, 1900MHz) > GPRS multi-slot class 12 > C  ontrol via standardized and extended AT commands (Hayes, TS 27.007 and 27.005) > I nternet Services TCP/UDP server/client, HTTP client, FTP client, DNS, IMCP > S  IM Application Toolkit, letter classes C, E with BIP support > LGA pad soldering mount, MSL4 > Supply voltage range: 3.3 - 4.5 V > Embedded IP stack with IPv4 support > Dimension: 27.6 x 18.8 x 2.7 mm > T  CP/IP stack access via AT command and transparent TCP/ UDP services > Weight: approx. 2.29 g > Operating temperature: -40°C to +85°C SPECIFICATIONS SPECIAL FEATURES > GPRS class 12 data rates > RLS Monitoring (Jamming detection) > D  L: max.85.6 kbps, UL: max 85.6kbps Mobile Station Class B > Dual SIM with smart network switching > PPP-Stack for GPRS data transfer > Real-time clock with alarm functionality > H  igh-quality voice support for the handset and hands-free operation > Firmware update via serial interface > Supplementary services & USSD support > Informal Network Scan > Multiplexer according to 3GPP TS 27.010 > SMS text and PDU mode, Cell broadcast > C  ustomer Manufacturing Test Support (RF TX Wave Generation / RX Power Measurement) INTERFACES (LGA PADS) > UICC and U/SIM card interface 1.8V / 3V > Power Supply > F  ast- Shutdown by hardware signal and AT command > Pad for GSM Antenna > D  igital I2S and Analog Audio Interface with microphone feeding > 2 High-speed serial interfaces (ASC0, ASC1) > S  erial interface, including automatic baud rate detection(8-wire) > S  witch-on by Hardware signal ON, Switch-off by AT command; Automatic switch-off in case of critical temperature and voltage conditions. > Reset by hardware signal > Orderly shutdown and reset by AT command > 6  GPIO lines shared with an I2C interface, Network-Status- Indication, PWM functionality, Jamming-Indication DRIVERS APPROVALS > M  UX driver for Windows® 7 / Windows® 8 / Windows® 10 / Windows mobile® > RED, GCF, CE, FCC, PTCRB, UL, IC > EuP, RoHS, China RoHS and REACH compliant Connect. Secure. Monetize.™ Gemalto’s complementary offering of solutions, services and solid identity management helps enterprises unleash the power of the IoT, providing a solid foundation of Trust based on three key pillars: > Connect. The backbone of any IoT solution, Cinterion M2M Modules, SIM/MIMs, Terminals and secure services provide future-proof, reliable connectivity for all vertical market IoT solutions. > Secure. Gemalto’s end-to-end security solutions protect device s, the network and the cloud while managing the entire application lifecycle. For more information, please visit www.gemalto.com/iot, developer.gemalto.com, blog.gemalto.com, or follow @gemaltoIoT on twitter. GEMALTO.COM/IOT © Gemalto 2020. All rights reserved. Gemalto, the Gemalto logo, are trademarks and service marks of Gemalto and are registered in certain countries. February 2020 > Monetize. Our agile Sentinel monetization solutions enable innovative business models and new revenue streams through embedded licensing, while the secure device-to-cloud platform speeds time to market.
BGS12 REL.2 价格&库存
很抱歉,暂时无法提供与“BGS12 REL.2”相匹配的价格&库存,您可以联系我们找货
