表单编号:FGH/BD-0053.01-15A
佛山市国星 RGB 器件事业部
FOSHAN NATIONSTAR RGB DIVISION
产品规格书
S P E C I F I C AT I O N
顾客名称
产品名称
Customer
Product
顾客型号
产品型号
Customer Type
Type
顾客部品号
版本号
Customer No.
Version NO
TOP LED
FM-3510RGBA-SG
A版
地址:广东省佛山市禅城区华宝南路 18 号
Add: NO.18 South Huabao Rd, Foshan, Guangdong, China
电话(Tel)
: 0757-83985605; 83985607; 82100231; 82100230
传真(Fax): 0757-82100223;82100200
邮编(Zip)
:528000
http://www.nationstar.com
研 发 中 心
客户(加盖公章)
Research & Development Center
Customer(Stamp)
制 定
审
核
DRAW
CHECK
批
准
APPROVE
确
认
CONFIRM
发放日期 (Release Date):2020-04-24
保存期限:长期
TOP 彩色发光二极管
FM-3510RGBA-SG
TOP Full-color LED
技术数据表 Technical Data Sheet
本产品属于表面贴装全彩器件,采用白框设计、高亮度、哑光封装、无镜面反射;
拥有侧面发光功能、高可靠性、长寿命、宽视角等特点,是透明屏显示领域的理想选择。
These products are full-color SMD components with white refractor, high brightness, matte
packing and non-mirror reflection, which are featured by side view , good reliability, long lifespan and wide viewing
angle. They are suitable for perspective display applications.
特性: 管芯材料:
Material:
红色 Red
AlGaInP
绿色 Green
InGaN
蓝色 Blue
InGaN
Features:
封装材料:环氧树脂
Encapsulation: Epoxy Resin
焊接方法:无铅回流焊
Soldering methods: Pb-Free reflow soldering
光强高,功耗低,可靠性好,寿命长
High Luminous Intensity ,Low Power Dissipation, Good Reliability and Long Life
符合欧盟公布的 RoHS 指令要求
Complied With RoHS Directive
目录
Catalogue
电性参数
Electrical Characteristics.............................................................................................................................2
典型特性曲线
Typical Characteristic Curves.....................................................................................................................3
可靠性实验
Reliability Test Items and Conditions.........................................................................................................4
产品设计及操作建议
Product design and operating recommendation............................................................................5
包装
Packaging......................................................................................................................................................6
焊接指导
Guideline for Soldering................................................................................................................................8
使用注意事项
Precautions...................................................................................................................................................10
* 产品规格如因工艺改进而有所改变,恕不另行通知。
* The specifications of the product may be modified for improvement without notice.
发放日期:20200424TYBA
1 / 12
保存期限:长期
TOP 彩色发光二极管
光电参数
Electro-Optical Characteristics
极限参数(温度=25℃)
Absolute Maximum Ratings (Temperature=25°C)
参数名称
Parameter
正向电流
Forward Current
正向脉冲电流*
Pulse Forward Current*
反向电压
Reverse Voltage
工作温度
Operating Temperature
贮存温度
Storage Temperature
符号
Symbol
数值
Rating
单位
Unit
IF
25
mA
IFP
50
mA
VR
5
V
TOPR
-30~ +85
Tstg
-40~ +100
红 Red
功耗
Power Dissipation
60
绿 Green
PD
90
蓝 Blue
90
* 注:脉冲宽度≤0.1ms,占空比≤1/10
mW
* Note:
Pulse Width≤0.1ms, Duty≤1/10
光电参数(温度=25℃)
Electro-Optical Characteristics (Temperature=25°C)
参数名称
Parameter
符号
Symbol
条件
Condition
反向电流
Reverse Current
IR
VR=5 V
正向电压
Forward Voltage
主波长
Dominant Wavelength
半波宽度
Spectrum Radiation
Bandwidth
光强
Luminous Intensity
视角度
View Angle
VF
λD
Δλ
IV
颜色
Color
最小值
Min.
典型值
Typ.
最大值
Max.
红 Red
10
绿 Green
10
蓝 Blue
10
IF=15mA
红 Red
1.8
2.1
2.4
IF=8mA
绿 Green
2.4
2.7
3.6
IF=5mA
蓝 Blue
2.4
2.7
3.6
IF=15mA
红 Red
615
621
630
IF=8mA
绿 Green
520
529
540
IF=5mA
蓝 Blue
460
470
480
IF=15mA
红 Red
24
IF=8mA
绿 Green
38
IF=5mA
蓝 Blue
28
IF=15mA
红 Red
280
445
623
IF=8mA
绿 Green
544
762
1066
IF=5mA
蓝 Blue
74
104
146
2θ1/2
110
单位
Unit
μA
V
nm
nm
mcd
deg.
* 注:以上参数仅供参考,请以实物标签为准。我司给出的参数均由国星测试系统测得。
* Note: The parameters above only for your reference. In case of any discrepancy, please adhere to
the label of our actual products. All parameters tested by the standard testing system of NationStar.
发放日期:20200424TYBA
2 / 12
保存期限:长期
TOP 彩色发光二极管
典型特性曲线
Typical Characteristics Curves
伏安特性
相对光强与正向电流特性
Volt -Ampere Characteristics
Relative Luminous Intensity VS Forward Current
Blue
1.5
1.8 2.1 2.4
2.7 3.0
正向电压 ( Forward Voltage)( V)
3.3
6
5
4
Green
2
3
Blue
Red
1
Green
TAmbient =25℃
Red
1
正 向电流 (Forward Curren t)(mA)
100
相对光强(Relative Luminous Intensity)(a.u .)
TAmbient =25℃
40
50
60
正向电流(Forward Current )(mA )
光强与环境温度曲线
正向电流降额曲线
Luminous Intensity VS Ambient Temperature
10
15
Blue
0 10 20 30 40 50 60 70 80 90 100
1.0 1.2
0.8
0.4 0.6
0.2
500
550
600
650
1.2
-40
a . u .)
Red
700
750
相 对 光 强( Re la ti ve L umino us Int ens ity ) (
a. u .)
相 对 光 强( R el at ive L umi nous Inte nsit y )(
光谱分布特性曲线
Relative Spectral Distribution
350 400
Green
-20
60
80
环境温度( Ambient Temperature )(℃)
Blue Green
1. 0
Red
Blue
0.8
30
Green
0. 6
相对 光强(Relative Lu min ous Intens ity)
Red
35
正向 电流(Forward Cu rrent)( mA)
40
1 .4
Forward Current Derating Curve
光强分布特性曲线
Typical Spatial Distribution
0°
1
10°
20°
30°
40°
50°
60°
0.5
70°
80°
90°
-90°-80°-70°-60°-50°-40°-30°-20°-10° 0
0.5
1
角 度( Angle ) ( Deg. )
波 长( Wavelength) ( nm)
发放日期:20200424TYBA
3 / 12
保存期限:长期
TOP 彩色发光二极管
可靠性试验
Reliability Test Items And Conditions
实验项目
参考标准
实验条件
时间
样品数
合格判据
Test Items
Reference
Test Conditions
Time
Quantity
Criterion
循环 100 次
冷热冲击
Thermal Shock
MIL-STD-202G
常温寿命试验
Room Temperature
Operating Life
JESD22-A108D
高温高湿寿命试验
Temperature & Humidity
Operating Life
耐焊接热
Resistance to Soldering Heat
防水试验
Water Proof Test
紫外老化
UV aging
-65℃(15min)←→150℃(15min)
100 pcs
0/100
1000h
20 pcs
见下表
See Table below
500h
20 pcs
见下表
See Table below
100 pcs
0/100
100 pcs
0/100
20 pcs
见下表
See Table below
100 cycles
Ta=25℃
IFR =15mA,IFG=15mA,IFB =15mA
JEITA ED-4701 100 103
Ta=85℃ RH=85%
JESD22-A108D
IFR =10mA,IFG=10mA,IFB =10mA
JEITA ED-4701 300 301
Tsol*=260℃ 10sec.
2次
2 times
IEC 60529:2001
ASTM-G154
寿命试验合格判断标准
Immersing in 1m water
24h
(0.89±0.1)W/m2@340nm,
循环 14 次
60℃,8h ←→50℃,4h/ cycle
14 cycles
Criteria For Passing Qualification of Lifespan Test
测试项目
符号
测试条件
判定标准
Test Items
Symbol
Test Conditions
Criteria For Judging Damage
正向电压
Forward Voltage
VF
IF= IFT
初始值±10%
Initial Data±10%
反向电流
Reverse Current
IR
VR= 5V
IR≤10μA
IF = IFT
平均 IV 衰减≤30%,单个 IV 衰减≤50%
Average IV degradation≤30%;
Single LED IV degradation≤50%
光强
Luminous Intensity
IV
* 注:Tsol-锡液温度;IFT:典型电流
* Note: Tsol-Temperature of tin liquid; IFT:Typical current.
发放日期:20200424TYBA
4 / 12
保存期限:长期
TOP 彩色发光二极管
产品设计及操作建议
Product design and operational recommendation
1、产品设计(单位:mm)
Product design(Unit: mm)
④
B-
③
G-
②
①
R-
Note:
B-
G-
A :缺口标志
A :Nick Mark
公差: X.X ±0.1 mm X.XX ±0.05mm
Tolerances:X.X ±0.1 mm
X.XX ±0.05mm
R-
2、参考焊盘(单位:mm)
0.95
B-
0.44
0.44
0.6
0.6
1.07
0.90
G-
0.5
0.75
0.5
0.75
Reference soldering pad (Unit: mm)
R-
发放日期:20200424TYBA
5 / 12
保存期限:长期
TOP 彩色发光二极管
包装(1)
Packaging (1)
载带 Carrier Tape
4.00
12.00
B-
G-
5.50±0.05
1.75
R-
2.00± 0.05mm
单位:mm,未注公差:±0.10mm
All dimensions in mm, tolerances unless mentioned is ±0.10 mm.
编带细节 Details Of Carrier Tape
前进方向Progressive Direction
A:引导,空带,500mm;B:编载产品 13000 只;C:尾部,空带,100mm
A: Leader, Empty, 500mm; B: 13000 Lamps Loaded; C: Trailer, Empty, 100mm.
带盘 Reel Dimension
二维码
Qr code
TOP LED
XXXX
TYPE: XX-XXXXX-XX
QTY: XXXX
BIN: XXX
SC: XXX
LOT: ||||||||||||||||||||||||||||||||
XXXX
IV(mcd)
λd(nm)
R:( xxx-xxx)
( xxx-xxx)
G:( xxx-xxx)
( xxx-xxx)
B:( xxx-xxx) ( xxx-xxx)
VF(V)
IF(mA)
( xx-xx) ( xx)
( xx-xx) ( xx)
( xx-xx) ( xx)
QC
QC:
PASS
FOSHAN NATIONSTAR OPTOELECTRONICS CO., LTD
佛山市国星光电股份有限公司
标签
Label
发放日期:20200424TYBA
6 / 12
保存期限:长期
TOP 彩色发光二极管
包装(2)
Packaging( 2)
防潮抗静电包装 Moisture Proof and Anti-Electrostatic Foil Bag
标签
Label
防潮抗静电包装袋
Moisture Proof and
干燥剂
密封
标签
Moisture Absorbent Material
Sealed
Label
外包装箱 Cardboard Box
二维码
Qr code
TOP LED
XXXX
TYPE: XX-XXXXX-XX
QTY: XXXX
IV(mcd)
λd(nm)
R:( xxx-xxx)
( xxx-xxx)
G:( xxx-xxx)
( xxx-xxx)
SC: XXX
B:( xxx-xxx)
LOT: XXXXXXXX
( xxx-xxx)
BIN:
XXX
20XX - XX - XX
VF(V)
IF(mA)
( xx-xx) ( xx)
( xx-xx) ( xx)
( xx-xx) ( xx)
QC
QC:
PASS
佛山市国星光电股份有限公司
佛山市国星光电股份有限公司
FOSHAN NATIONSTAR OPTOELECTRONICS CO.,LTD
地址:佛山市禅城区华宝南路18号
TEL:(86-757)83980208
邮编:528000
FAX:(86-757)82100206
标签说明 Label Explanation
TYPE:产品型号
二维码
Qr code
TOP LED
QTY:数量 Quantity
BIN:分档 Rank
XXXX
TYPE: XX-XXXXX-XX
QTY: XXXX
SC: 分档代码 Bin Code
BIN:
XXX
LOT:批号 Lot Number
SC:
λd:波长范围 Wavelength Range
LOT: XXXXXXXX
XXXX
XXX
IV(mcd)
λd(nm)
VF(V)
IF(mA)
R:( xxx-xxx)
( xxx-xxx)
( xx-xx) ( xx)
G:( xxx-xxx)
( xxx-xxx)
( xx-xx) ( xx)
B:( xxx-xxx)
( xxx-xxx)
( xx-xx) ( xx)
QC
QC:
PASS
佛山市国星光电股份有限公司
IV:光强范围 Luminous Intensity Range
VF:正向电压范围
Forward Voltage Range
IF:测试电流 Test Current
发放日期:20200424TYBA
7 / 12
保存期限:长期
TOP 彩色发光二极管
焊接指导(1)
Guideline for Soldering (1)
使用烙铁人手焊接
1.
Hand Soldering
如使用手工焊接,建议使用小于25瓦的电烙铁,烙铁温度必须控制在315℃以下,焊接时间需控制在3
秒钟之内,且每个电极只能焊接一次。
If manual soldering is used, the use of a soldering iron of less than 25W is recommended. The temperature of
the iron must be kept below 315℃,with soldering time within 3 seconds and each electrode can be only
soldered at one time.
手工焊接时电烙铁不可触及SMD LED表面。
The epoxy resin of the SMD LED should not contact the tip of the soldering iron.
焊接期间,不可以对器件施加机械压力。
No mechanical stress should be exerted on the resin portion by the tip of the soldering iron.
器件外部温度在 40℃以下时,才可以对其进行处理。避免高温时操作对 LED 造成损伤。
Handing of the SMD LED should be done when the temperature of environment is below 40℃, in case of
LED failures caused by thermal-mechanical stress in condition of high temperature .
2. 回流焊接:推荐使用以下无铅回流焊接温度图进行。
Reflow Soldering: Use the conditions shown in the under Figure of Pb-Free Reflow Soldering.
推荐温度焊接曲线
Recommended Solder Profile
温 度( Temperature )(℃)
260
250
255 ±5℃
升 温 1-5℃/ sec
Ramp -up 1-5℃/ sec
217
200
10sec .
Max .
60 sec . max
150
预 热 Preheat
( 60 -120 )sec .
降 温 7℃/ sec . max
Ramp -down 7℃/ sec . max
时间( Time )
发放日期:20200424TYBA
8 / 12
保存期限:长期
TOP 彩色发光二极管
焊接指导(2)
Guideline for Soldering (2)
· 回流焊接最多只能进行一次。
· Reflow soldering should not be done more than one time.
· 在回流焊接升温过程中,请不要对 LED 施加任何压力。
· Stress on the LEDs should be avoided during heating in the reflow soldering process.
· 在焊接完成后,待产品温度下降到室温之后,再进行其他处理。
· After soldering, do not deal with the product before its temperature drop down to room temperature.
3.
清洗:
Cleaning
· 在焊接后推荐使用酒精(无水乙醇)进行清洗,在温度不高于 30℃的条件下持续 3 分钟,不高于 50℃
的条件下持续 30 秒。使用其他类似溶剂清洗前,请先确认使用的溶剂不会对 LED 的封装和环氧树脂部
分造成损伤。
It is recommended that alcohol(Anhydrous ethanol) be used as a solvent for cleaning after soldering.
Cleaning is to go under 30℃ for 3 minutes or 50℃ for 30 seconds. When using other solvents, it should be
confirmed beforehand whether the solvents will dissolve the package and the resin or not.
· 超声波清洗也是有效的方法,一般最大功率不应超过 300W,否则可能对 LED 造成损伤。请根据具体
的情况预先测试清洗条件是否会对 LED 造成损伤。
Ultrasonic cleaning is also an effective way for cleaning. The influence of Ultrasonic cleaning on LED depends
on factors such as ultrasonic power. Generally, the ultrasonic power should not be higher than 300W, otherwise
it will cause LED damage. Before cleaning, a pre-test should be done to confirm if any damage to LEDs will
occur.
* 注意:此一般指导原则并不适用于所有 PCB 设计和焊接设备的配置。具体工艺受到诸多因素的影响,请根据特定的PCB设计和焊
接设备来确定焊接方案。
* Note: This general guideline may not apply to all PCB designs and configurations of all soldering equipment. The technique
in practice is influenced by many factors, it should be specialized base on the PCB designs and configurations
of the soldering equipment.
发放日期:20200424TYBA
9 / 12
5
保存期限:长期
TOP 彩色发光二极管
使用注意事项(1)
Precautions (1)
贮存:
1.
Storage
本产品使用密封防潮抗静电袋包装,并附有干燥剂,湿度卡。
Moisture proof, anti-electrostatic package and moisture absorbent material are used, to keep moisture to a
minimum. Humidity indicator card inside to test if the products are moisted.
贮存环境为:开封前,产品贮存在温度
很抱歉,暂时无法提供与“FM-3510RGBA-SG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.31600
- 100+0.29493
- 300+0.27387
- 500+0.25280
- 2000+0.24227
- 5000+0.23595
- 国内价格
- 40+0.20547
- 80+0.19873
- 160+0.19537
- 320+0.18526
- 国内价格
- 1+0.14920
- 13000+0.11810
