BZT52C7V5Q
BZT52C7V5Q
    JSMSEMI(杰盛微)
    SOD-123
    SMT型齐纳二极管
BZT52C7V5Q 数据手册
BZT52C2V0Q-BZT52C47Q SMT-Type Zener Diode FEATURES Large selection of zener voltages: 2.0V ~ 47V Tight voltage tolerance: ±5% for C-series Ultra low-profile package well suited for automated assembly MSL Class 1 compatible to r APPLICATIONS General voltage regulation Mobile & handheld systems Marking See Page 2 co BZT52C2V0Q - BZT52C47Q Package nd Part Number uc ORDERING INFORMATION SOD-123 MAXIMUM RATING (@ TA = 25C unless otherwise specified) Symbol Value Unit VF 0.9 V PC 500 mW Thermal Resistance (Junction-to-Ambient) RθJA 250  C/W Thermal Resistance (Junction-to-Case) RθJC 140  C/W Junction Temperature Range TJ -55 ~ +150 C Storage Temperature Range TSTG -65 ~ +150 C mi Parameter CR O Power Dissipation (Collector) Se Forward Voltage @ IF=10mA JS MI Note: These ratings are limiting values above which the serviceability of the diodes may be impaired. www.jsmsemi.com 第1/3页 BZT52C2V0Q-BZT52C47Q SMT-Type Zener Diode ELECTRICAL CHARACTERISTICS (@ TA = 25C unless otherwise specified) 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 2 2 2 2 2 2 2 600 600 600 600 600 600 600 600 600 500 480 400 150 80 80 80 100 150 150 150 170 200 200 225 225 250 250 300 300 325 350 350 700 750 Min. Max. -3.5 -3.5 -3.5 -3.5 -3.5 -3.5 -3.5 -3.5 -3.5 -3.5 -2.7 -2.0 0.4 1.2 2.5 3.2 3.8 4.5 5.4 6.0 7.0 9.2 10.4 12.4 14.4 16.4 18.4 21.4 24.4 27.4 30.4 33.4 10.0 10.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 0.0 1.2 2.5 3.7 4.5 5.3 6.2 7.0 8.0 9.0 10.0 11.0 13.0 14.0 16.0 18.0 20.0 22.0 25.3 29.4 33.4 37.4 41.2 12.0 12.0 www.jsmsemi.com Maximum Reverse Current IR (A) @ VR (V) 150.000 150.000 50.000 20.000 10.000 5.000 5.000 3.000 3.000 3.000 2.000 1.000 3.000 2.000 1.000 0.700 0.500 0.200 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 0.100 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 2.0 2.0 2.0 4.0 4.0 5.0 5.0 6.0 7.0 8.0 8.0 8.0 10.5 11.2 12.6 14.0 15.4 16.8 18.9 21.0 23.1 25.2 27.3 32.0 35.0 to r 2.10 2.31 2.52 2.84 3.15 3.47 3.78 4.10 4.52 4.94 5.36 5.88 6.51 7.14 7.88 8.61 9.56 10.50 11.55 12.60 13.65 15.75 16.80 18.90 21.00 23.10 25.20 28.35 31.50 34.65 37.80 40.95 45.15 49.35 @ IZK (mA) 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 1.0 0.5 0.5 0.5 0.5 0.5 1.0 1.0 uc 2.00 2.20 2.40 2.70 3.00 3.30 3.60 3.90 4.30 4.70 5.10 5.60 6.20 6.80 7.50 8.20 9.10 10.00 11.00 12.00 13.00 15.00 16.00 18.00 20.00 22.00 24.00 27.00 30.00 33.00 36.00 39.00 43.00 47.00 ZZK () Temperature Coefficient @ IZT TC (mV/C) nd 1.90 2.09 2.28 2.57 2.85 3.14 3.42 3.71 4.09 4.47 4.85 5.32 5.89 6.46 7.13 7.79 8.65 9.50 10.45 11.40 12.35 14.25 15.20 17.10 19.00 20.90 22.80 25.65 28.50 31.35 34.20 37.05 40.85 44.65 ZZT () @ IZT 100 100 100 100 95 95 90 90 90 80 60 40 10 15 15 15 15 20 20 25 30 30 40 45 55 55 70 80 80 80 90 130 100 100 co Max. Maximum Zener Impedance mi Typ. Se WY 22• WX W1 W2 W3 W4 W5 W6 W7 W8 W9 WA WB WC WD WE WF WG WH WI WJ WK WL WM WN WO WP WQ WR WS WT WU WV @ IZT (mA) Min. JS MI BZT52C2V0Q BZT52C2V2Q BZT52C2V4Q BZT52C2V7Q BZT52C3V0Q BZT52C3V3Q BZT52C3V6Q BZT52C3V9Q BZT52C4V3Q BZT52C4V7Q BZT52C5V1Q BZT52C5V6Q BZT52C6V2Q BZT52C6V8Q BZT52C7V5Q BZT52C8V2Q BZT52C9V1Q BZT52C10Q BZT52C11Q BZT52C12Q BZT52C13Q BZT52C15Q BZT52C16Q BZT52C18Q BZT52C20Q BZT52C22Q BZT52C24Q BZT52C27Q BZT52C30Q BZT52C33Q BZT52C36Q BZT52C39Q BZT52C43Q BZT52C47Q Marking Code CR O Part Number Zener Voltage VZ (V) 第2/3页 BZT52C2V0Q-BZT52C47Q SMT-Type Zener Diode JS MI CR O Se mi co nd uc to r TYPICAL CHARACTERISTICS (@ TA = 25C unless otherwise specified) www.jsmsemi.com 第3/3页
BZT52C7V5Q 价格&库存
很抱歉,暂时无法提供与“BZT52C7V5Q”相匹配的价格&库存,您可以联系我们找货
