CLP-03
CLP-03
    BITSCOPE
    BITSCOPE - CLP-03 - TEST WIRE, MIXED SIGNAL SCOPE & PROBE
CLP-03 数据手册
BitScope CLP-03 Test wires & probe pins (Socket terminated) te erminated)) Product Information CLP-03 is a set of 10 terminated test wires with detachable probe pins for use with LP103X, LP103W or Pocket Analzyer. They plug into standard prototype bread-boards and onto test points or they can be used to connect from BitScopePOD pins to standard header pins. When used with a LP103X or LP103W or Pocket Analzyer or they are suitable Product Summary Order Code CLP-03 Description 10 x 8" colored leads with termination for use with a logic POD or BitScope. Comment Socket terminated. Mini-Probe test wire CMOS and TTL logic and ± 12V analog signals up to100MHz. If you need surface-mount or fine-pitch component connectivity we recommend CLP- 02. They may also be used to connect directly to the POD connector on other BitScope models.
CLP-03 价格&库存
很抱歉,暂时无法提供与“CLP-03”相匹配的价格&库存,您可以联系我们找货
