CMT2117A-ESR
CMT2117A-ESR
    HOPERF(华普微)
    SOT23-6
    停产 CMT2117A-ESR
CMT2117A-ESR 数据手册
CMT2110/17A CMT2110/17A Low-Cost 240 – 960 MHz OOK Transmitter Features Applications    Low-Cost Consumer Electronics Applications  Very Easy Development with RFPDK  Home and Building Automation  All Features Programmable  Remote Fan Controllers  Infrared Transmitter Replacements  240 to 480 MHz (CMT2110A)  Industrial Monitoring and Controls  240 to 960 MHz (CMT2117A)  Remote Lighting Control Embedded EEPROM Frequency Range:  OOK Modulation  Wireless Alarm and Security Systems  Symbol Rate: 0.5 to 30 ksps  Remote Keyless Entry (RKE)  Output Power: -10 to +13 dBm  Supply Voltage: 1.8 to 3.6 V  Current Consumption: 12.4 mA @ +10 dBm  Sleep Current: < 20 nA  FCC / ETSI Compliant  RoHS Compliant  6-pin SOT23-6 Package Ordering Information Part Number Frequency Package MOQ CMT2110A-ESR 433.92 MHz SOT23-6 3,000 pcs CMT2117A-ESR 868.35 MHz SOT23-6 3,000 pcs More Ordering Info: See Page 20 Descriptions The CMT2110/17A devices are ultra low-cost, highly flexible, high performance, single-chip OOK transmitters for various 240 to 960 MHz wireless applications. The CMT2110A covers the frequency range from 240 to 480 MHz while the CMT2117A covers the 240 to 960 MHz frequency range. They are part of the CMOSTEK NextGenRFTM family, which includes a complete line of transmitters, receivers and transceivers. With very low SOT23-6 current consumption, the device modulates and transmits the data which is sent from the host MCU. An embedded EEPROM allows the frequency, output power and other features to be programmed into the chip using the CMOSTEK USB Programmer and RFPDK. Alternatively, in stock products of 433.92/868.35 MHz are available for XTAL 1 6 VDD GND 2 5 RFO DATA 3 4 CLK immediate demands without the need of EEPROM programming. The CMT2110/17A uses a 1-pin crystal oscillator circuit with the required crystal load capacitance integrated on-chip to minimize the number of external components. The CMT2110/17A transmitter together with the CMT221x receiver enables an ultra low cost RF link. Copyright © By CMOSTEK Rev 1.2 | Page 1/25 CMT2110/17A www.hoperf.com CMT2110/17A Typical Application CMT2110/17A X1 J1 1 VDD XTAL VDD VDD 6 ANT 1 2 3 VDD C0 DATA L1 CLK 2 4 U1 GND RFO L2 5 C1 Note: Connector J1 is for EEPROM Programming 3 DATA DATA CLK 4 C2 CLK Figure 1. CMT2110/17A Typical Application Schematic Table 1. BOM of 433.92/868.35 MHz Low-Cost Application Value Designator Descriptions 868.35 MHz[1] 433.92 MHz U1 CMT2110/17A, Low-Cost 240 – 960 MHz OOK Transmitter Unit Manufacturer - - CMOSTEK X1 ±20 ppm, SMD32*25 mm crystal 26 MHz EPSON C0 ±20%, 0402 X7R, 25 V 0.1 uF Murata GRM15 C1 ±5%, 0402 NP0, 50 V 82 82 pF Murata GRM15 C2 ±5%, 0402 NP0, 50 V 9 3.9 pF Murata GRM15 L1 ±5%, 0603 multi-layer chip inductor 180 100 nH Murata LQG18 L2 ±5%, 0603 multi-layer chip inductor 27 8.2 nH Murata LQG18 Note: [1]. The 868.35 MHz Application is for CMT2117A only. Table 2. Product Selection Table Product Frequency Modulation Max Output Power CMT2110A 240-480 MHz OOK +13 dBm CMT2117A 240-960 MHz OOK +13 dBm Rev 1.2 | Page 2/25 Tx Current Consumption 13.4 mA (+10 dBm @ 433.92 MHz) 15.5 mA (+10 dBm @ 868.35 MHz) Embedded EEPROM √ √ www.hoperf.com CMT2110/17A Abbreviations Abbreviations used in this data sheet are described below AN Application Notes PA Power Amplifier BOM Bill of Materials PC Personal Computer BSC Basic Spacing between Centers PCB Printed Circuit Board EEPROM Electrically Erasable Programmable Read-Only PN Phase Noise Memory RCLK Reference Clock Electro-Static Discharge RF Radio Frequency ESR Equivalent Series Resistance RFPDK RF Product Development Kit ETSI European Telecommunications Standards RoHS Restriction of Hazardous Substances Institute Rx Receiving, Receiver FCC Federal Communications Commission SOT Small-Outline Transistor Max Maximum SR Symbol Rate MCU Microcontroller Unit TWI Two-wire Interface Min Minimum Tx Transmission, Transmitter MOQ Minimum Order Quantity Typ Typical NP0 Negative-Positive-Zero USB Universal Serial Bus OBW Occupied Bandwidth XO/XOSC Crystal Oscillator OOK On-Off Keying XTAL Crystal ESD Rev 1.2 | Page 3/25 www.hoperf.com CMT2110/17A Table of Contents 1. Electrical Characteristics ............................................................................................................................................ 5 1.1 Recommended Operating Conditions ................................................................................................................... 5 1.2 Absolute Maximum Ratings................................................................................................................................... 5 1.3 Transmitter Specifications ..................................................................................................................................... 6 1.4 Crystal Oscillator ................................................................................................................................................... 7 2. Pin Descriptions .......................................................................................................................................................... 8 3. Typical Performance Characteristics ......................................................................................................................... 9 4. Typical Application Schematics ............................................................................................................................... 10 4.1 Low-Cost Application Schematic ......................................................................................................................... 10 4.2 FCC/ETSI Compliant Application Schematic....................................................................................................... 11 5. Functional Descriptions ............................................................................................................................................ 12 5.1 Overview ............................................................................................................................................................. 12 5.2 Modulation, Frequency and Symbol Rate ........................................................................................................... 12 5.3 Embedded EEPROM and RFPDK ...................................................................................................................... 13 5.4 Power Amplifier ................................................................................................................................................... 14 5.5 PA Ramping ........................................................................................................................................................ 14 5.6 Crystal Oscillator and RCLK................................................................................................................................ 15 6. Working States and Transmission Control Interface ............................................................................................. 16 6.1 Working States .................................................................................................................................................... 16 6.2 Transmission Control Interface ........................................................................................................................... 16 6.2.1 Tx Enabled by DATA Pin Rising Edge...................................................................................................... 17 6.2.2 Tx Enabled by DATA Pin Falling Edge ..................................................................................................... 17 6.2.3 Two-wire Interface.................................................................................................................................... 17 7. Ordering Information ................................................................................................................................................. 20 8. Package Outline......................................................................................................................................................... 21 9. Top Marking ............................................................................................................................................................... 22 9.1 CMT2110/17A Top Marking ................................................................................................................................ 22 10. Other Documentations .............................................................................................................................................. 23 11. Document Change List.............................................................................................................................................. 24 12. Contact Information .................................................................................................................................................. 25 Rev 1.2 | Page 4/25 www.hoperf.com CMT2110/17A 1. Electrical Characteristics VDD = 3.3 V, TOP = 25 ℃, FRF = 433.92 MHz, output power is +10 dBm terminated in a matched 50 Ω impedance, unless otherwise noted. 1.1 Recommended Operating Conditions Table 3. Recommended Operation Conditions Parameter Symbol Conditions Min Typ Max Unit Operation Voltage Supply VDD 1.8 3.6 V Operation Temperature TOP -40 85 ℃ Supply Voltage Slew Rate 1 mV/us 1.2 Absolute Maximum Ratings Table 4. Absolute Maximum Ratings Parameter Symbol Conditions [1] Min Max Unit Supply Voltage VDD -0.3 3.6 V Interface Voltage VIN -0.3 VDD + 0.3 V Junction Temperature TJ -40 125 ℃ Storage Temperature TSTG -50 150 ℃ Soldering Temperature TSDR 255 ℃ -2 2 kV -100 100 mA Lasts at least 30 seconds ESD Rating Human Body Model (HBM) Latch-up Current @ 85 ℃ Note: [1]. Stresses above those listed as “absolute maximum ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device under these conditions is not implied. Exposure to maximum rating conditions for extended periods may affect device reliability. Caution! ESD sensitive device. Precaution should be used when handling the device in order to prevent permanent damage. Rev 1.2 | Page 5/25 www.hoperf.com CMT2110/17A 1.3 Transmitter Specifications Table 5. Transmitter Specifications Parameter Frequency Range[1] Synthesizer Frequency Resolution Symbol FRF FRES Conditions Min Typ Max Unit CMT2110A 240 480 MHz CMT2117A 240 960 MHz FRF ≤ 480 MHz 198 398 Hz Maximum Output Power POUT(Max) +13 dBm Minimum Output Power POUT(Min) -10 dBm Output Power Step Size PSTEP PA Ramping Time[2] tRAMP Current Consumption @ 433.92 MHz Current Consumption @ 868.35 MHz Sleep Current Symbol Rate Frequency Tune Time Phase Noise @ 433.92 MHz Phase Noise @ 868.35 MHz IDD433.92 IDD868.35 FRF > 480 MHz Hz 1 0 6.7 mA +10 dBm, 50% duty cycle 13.4 mA +13 dBm, 50% duty cycle 17.4 mA 0 dBm, 50% duty cycle 8.0 mA +10 dBm, 50% duty cycle 15.5 mA +13 dBm, 50% duty cycle 19.9 mA 20 nA SR 0.5 tTUNE PN868.35 us 0 dBm, 50% duty cycle ISLEEP PN433.92 dB 1024 30 ksps 370 us 100 kHz offset from FRF -81 dBc/Hz 200 kHz offset from FRF -83 dBc/Hz 400 kHz offset from FRF -92 dBc/Hz 600 kHz offset from FRF -97 dBc/Hz 1.2 MHz offset from FRF -107 dBc/Hz 100 kHz offset from FRF -75 dBc/Hz 200 kHz offset from FRF -77 dBc/Hz 400 kHz offset from FRF -86 dBc/Hz 600 kHz offset from FRF -91 dBc/Hz 1.2 MHz offset from FRF -101 dBc/Hz nd Harmonics Output for H2433.92 2 -52 dBm 433.92 MHz[3] H3433.92 3rd harm @ 1301.76 MHz, +13 dBm POUT -60 dBm Harmonics Output for H2868.35 2nd harm @ 1736.7 MHz, +13 dBm POUT -67 dBm -55 dBm 60 dB [3] 868.35 MHz H3868.35 harm @ 867.84 MHz, +13 dBm POUT rd 3 harm @ 2605.05 MHz, +13 dBm POUT OOK Extinction Ration Notes: [1]. The frequency range is continuous over the specified range. [2]. 0 and 2n us, n = 0 to 10, when set to “0”, the PA output power will ramp to its configured value in the shortest possible time. [3]. The harmonics output is measured with the application shown as Figure 10. Rev 1.2 | Page 6/25 www.hoperf.com CMT2110/17A 1.4 Crystal Oscillator Table 6. Crystal Oscillator Specifications Parameter [1] Crystal Frequency Symbol Conditions FXTAL Min Typ Max Unit 26 26 26 MHz [2] Crystal Tolerance [3] Load Capacitance Crystal ESR ±20 CLOAD 12 Rm [4] XTAL Startup Time tXTAL ppm 20 pF 60 Ω 400 us Notes: [1]. The CMT2110/17A can directly work with external 26 MHz reference clock input to XTAL pin (a coupling capacitor is required) with amplitude 0.3 to 0.7 Vpp. [2]. This is the total tolerance including (1) initial tolerance, (2) crystal loading, (3) aging, and (4) temperature dependence. The acceptable crystal tolerance depends on RF frequency and channel spacing/bandwidth. [3]. The required crystal load capacitance is integrated on-chip to minimize the number of external components. [4]. This parameter is to a large degree crystal dependent. Rev 1.2 | Page 7/25 www.hoperf.com CMT2110/17A 2. Pin Descriptions XTAL 1 6 VDD GND 2 5 RFO DATA 3 4 CLK Figure 2. CMT2110/17A Pin Assignments Table 7. CMT2110/17A Pin Descriptions Pin Number Name I/O 1 XTAL I 2 GND I Descriptions 26 MHz single-ended crystal oscillator input or External 26 MHz reference clock input Ground Data input to be transmitted or Data pin to access the embedded EEPROM 3 DATA IO Pulled down internally to GND when configured as Transmission Enabled by DATA Pin Falling Edge and used as input pin Pulled up internally to VDD when configured as Transmission Enabled by DATA Pin Rising Edge and used as input pin Clock pin to control the device Clock pin to access the embedded EEPROM 4 CLK I 5 RFO O Power amplifier output 6 VDD I Power supply input Pulled up internally to VDD Rev 1.2 | Page 8/25 www.hoperf.com CMT2110/17A 3. Typical Performance Characteristics Phase Noise @ 868.35 MHz Phase Noise 15 20 13.2 dBm @ 433.92 MHz 10 -5 0 -10 Power (dBm) Power (dBm) 13.0 dBm @ 868.35 MHz 5 -20 -30 -15 -25 -35 -55.9 dBm @ 869.55 MHz -45 -40 -55.0 dBm @ 435.12 MHz -50 -55 -65 -60 432.42 432.72 433.02 433.32 433.62 433.92 434.22 434.52 434.82 435.12 435.42 866.85 867.1 867.35 867.6 867.85 868.1 868.35 868.6 868.85 869.1 869.35 869.6 869.85 Frequency (MHz) RBW = 10 kHz Frequency (MHz) (RBW = 10 kHz) Figure 3. Phase Noise, FRF = 433.92 MHz, Figure 4. Phase Noise, FRF = 868.35 MHz, POUT = +13 dBm, Unmodulated POUT = +13 dBm, Unmodulated Spectrum of Various PA Ramping Options OOK Spectrum, SR = 9.6 ksps 10 10 -10 Power (dBm) -10 Power (dBm) 128 us 64 us 32 us 16 us 8 us 4 us 0 0 -20 -20 -30 -30 -40 -40 -50 433.18 433.37 433.55 433.74 433.92 434.11 434.29 434.48 -50 434.66 433.17 433.37 433.57 433.77 Frequency (MHz) 434.17 434.37 434.57 Figure 5. OOK Spectrum, SR = 9.6 ksps, Figure 6. Spectrum of PA Ramping, POUT = +10 dBm, tRAMP = 32 us SR = 9.6 ksps, POUT = +10 dBm Spectrum of Various PA Ramping Options POUT vs. VDD 10 14 -10 12 10 SR = 1.2 ksps Power (dBm) 1024 us 512 us 256 us 128 us 64 us 32 us 0 Power (dBm) 433.97 Frequency (MHz) -20 8 0 dBm 6 +10 dBm 4 +13 dBm -30 2 -40 0 -2 -50 433.17 433.37 433.57 433.77 433.97 434.17 Frequency (MHz) 434.37 434.57 1.6 1.8 2 2.2 2.4 2.6 2.8 3 3.2 3.4 3.6 3.8 Supply Voltage VDD (V) Figure 8. Spectrum of PA Ramping, Figure 7. Output Power vs. Supply SR = 1.2 ksps, POUT = +10 dBm Voltages, FRF = 433.92 MHz Rev 1.2 | Page 9/25 www.hoperf.com CMT2110/17A 4. Typical Application Schematics 4.1 Low-Cost Application Schematic CMT2110/17A X1 J1 1 VDD XTAL VDD VDD 6 ANT 1 2 3 VDD C0 DATA L1 CLK 2 4 GND U1 RFO L2 5 C1 Note: Connector J1 is for EEPROM Programming DATA 3 DATA CLK 4 C2 CLK Figure 9. Low-Cost Application Schematic Notes: 1. Connector J1 is a must for the CMT2110/17A EEPROM access during development or manufacture. 2. The general layout guidelines are listed below. For more design details, please refer to “AN101 CMT211xA Schematic and PCB Layout Design Guideline”  Use as much continuous ground plane metallization as possible.  Use as many grounding vias (especially near to the GND pins) as possible to minimize series parasitic inductance  Avoid using long and/or thin transmission lines to connect the components.  Avoid placing the nearby inductors in the same orientation to reduce the coupling between them.  Place C0 as close to the CMT2110/17A as possible for better filtering. between the ground pour and the GND pins. 3. The table below shows the BOM of 433.92/868.35 MHz Low-Cost Application. For the BOM of 315/915 MHz application, please refer to “AN101 CMT211xA Schematic and PCB Layout Design Guideline”. Table 8. BOM of 433.92/868.35 MHz Low-Cost Application Value Designator Descriptions Unit Manufacturer - - CMOSTEK 868.35 MHz[1] 433.92 MHz U1 CMT2110/17A, Low-Cost 240 – 960 MHz OOK Transmitter X1 ±20 ppm, SMD32*25 mm crystal 26 MHz EPSON C0 ±20%, 0402 X7R, 25 V 0.1 uF Murata GRM15 C1 ±5%, 0402 NP0, 50 V 82 82 pF Murata GRM15 C2 ±5%, 0402 NP0, 50 V 9 3.9 pF Murata GRM15 L1 ±5%, 0603 multi-layer chip inductor 180 100 nH Murata LQG18 L2 ±5%, 0603 multi-layer chip inductor 27 8.2 nH Murata LQG18 Note: [1]. The 868.35 MHz Application is for CMT2117A only. Rev 1.2 | Page 10/25 www.hoperf.com CMT2110/17A 4.2 FCC/ETSI Compliant Application Schematic CMT2110/17A X1 J1 1 2 3 4 1 VDD XTAL VDD VDD VDD 6 ANT VDD C0 DATA L1 L2 CLK 2 GND U1 GND RFO 5 L3 C1 Note: Connector J1 is for EEPROM Programming 3 DATA DATA CLK 4 C2 C3 CLK Figure 10. FCC/ETSI Compliant Application Schematic Notes: 1. Connector J1 is a must for the CMT2110/17A EEPROM access during development or manufacture. 2. The general layout guidelines are listed below. For more design details, please refer to “AN101 CMT211xA Schematic and PCB Layout Design Guideline”.  Use as much continuous ground plane metallization as possible.  Use as many grounding vias (especially near to the GND pins) as possible to minimize series parasitic inductance  Avoid using long and/or thin transmission lines to connect the components.  Avoid placing the nearby inductors in the same orientation to reduce the coupling between them.  Place C0 as close to the CMT2110/17A as possible for better filtering. between the ground pour and the GND pins. 3. The table below shows the BOM of 433.92/868.35 MHz FCC/ETSI Compliant Application. For the BOM of 315/915 MHz application, please refer to “AN101 CMT211xA Schematic and PCB Layout Design Guideline”. Table 9. BOM of 433.92/868.35 MHz FCC/ETSI Compliant Application Value Designator Descriptions Unit Manufacturer - - CMOSTEK 868.35 MHz[1] 433.92 MHz U1 CMT2110/17A, Low-Cost 240 – 960 MHz OOK Transmitter X1 ±20 ppm, SMD32*25 mm crystal 26 MHz EPSON C0 ±20%, 0402 X7R, 25 V 0.1 uF Murata GRM15 C1 ±5%, 0402 NP0, 50 V 68 68 pF Murata GRM15 C2 ±5%, 0402 NP0, 50 V 15 9.1 pF Murata GRM15 C3 ±5%, 0402 NP0, 50 V 15 8.2 pF Murata GRM15 L1 ±5%, 0603 multi-layer chip inductor 180 100 nH Murata LQG18 L2 ±5%, 0603 multi-layer chip inductor 36 8.2 nH Murata LQG18 L3 ±5%, 0603 multi-layer chip inductor 18 8.2 nH Murata LQG18 Note: [1]. The 868.35 MHz Application is for CMT2117A only. Rev 1.2 | Page 11/25 www.hoperf.com CMT2110/17A 5. Functional Descriptions VDD POR LDOs Bandgap GND XOSC XTAL VCO PFD/CP Loop Filter PA RFO Fractional-N DIV OOK Modulator EEPROM CLK Ramp Control Interface and Digital Logic DATA Figure 11. CMT2110/17A Functional Block Diagram 5.1 Overview The CMT2110/17A is an ultra low-cost, highly flexible, high performance, single-chip OOK transmitter for various 240 to 960 MHz wireless applications. The CMT2110A covers the frequency range from 240 to 480 MHz while the CMT2117 covers the 240 to 960 MHz frequency range. They are part of the CMOSTEK NextGenRFTM family, which includes a complete line of transmitters, receivers and transceivers. The chip is optimized for the low system cost, low power consumption, battery powered application with its highly integrated and low power design. The functional block diagram of the CMT2110/17A is shown in the figure above. The CMT2110/17A is based on direct synthesis of the RF frequency, and the frequency is generated by a low-noise fractional-N frequency synthesizer. It uses a 1-pin crystal oscillator circuit with the required crystal load capacitance integrated on-chip to minimize the number of external components. Every analog block is calibrated on each Power-on Reset (POR) to the highly accurate reference voltage internally. The calibration can help the chip to finely work under different temperatures and supply voltages. The CMT2110/17A uses the DATA pin for the host MCU to send in the data. The input data will be modulated and sent out by a highly efficient PA which output power can be configured from -10 to +13 dBm in 1 dB step size. RF Frequency, PA output power and other product features can be programmed into the embedded EEPROM by the RFPDK and USB Programmer. This saves the cost and simplifies the product development and manufacturing effort. Alternatively, in stock products of 433.92/868.35 MHz are available for immediate demands with no need of EEPROM programming. The CMT2110/17A operates from 1.8 to 3.6 V so that it can finely work with most batteries to their useful power limits. Working under 3.3 V supply voltage when transmitting signal at +10 dBm power, it only consumes 13.4 mA at 433.92 MHz and 15.5 mA at 868.35 MHz. 5.2 Modulation, Frequency and Symbol Rate The CMT2110/17A supports OOK modulation with the symbol rate up to 30 ksps. The CMT2110A covers the frequency range from 240 to 480 MHz, while the CMT2117A covers the frequency range from 240 to 960 MHz, including the license free ISM frequency band around 315 MHz, 433.92 MHz, 868.35 MHz and 915 MHz. The device contains a high spectrum purity low power fractional-N frequency synthesizer with output frequency resolution better than 198 Hz when the frequency is lower than 480 MHz, and the frequency resolution is 397 Hz when the frequency is higher than 480 MHz. See the table below for the modulation, frequency and symbol rate specifications. Rev 1.2 | Page 12/25 www.hoperf.com CMT2110/17A Table 10. Modulation, Frequency and Symbol Rate Parameter Value Unit OOK - Frequency (CMT2110A) 240 to 480 MHz Frequency (CMT2117A) 240 to 960 MHz 198 Hz Modulation Frequency Resolution (FRF ≤ 480 MHz) 397 Hz 0.5 to 30 ksps Frequency Resolution (FRF > 480 MHz) Symbol Rate 5.3 Embedded EEPROM and RFPDK The RFPDK (RF Products Development Kit) is a very user-friendly software tool delivered for the user configuring the CMT2110/17A in the most intuitional way. The user only needs to fill in/select the proper value of each parameter and click the “Burn” button to complete the chip configuration. No register access and control is required in the application program. See the figure below for the accessing of the EEPROM and Table 11 for the summary of all the configurable parameters of the CMT2110/17A in the RFPDK. CMT2110/17A RFPDK EEPROM CLK Interface DATA CMOSTEK USB Programmer Figure 12. Accessing Embedded EEPROM For more details of the CMOSTEK USB Programmer and the RFPDK, please refer to “AN103 CMT211xA-221xA One-Way RF Link Development Kits Users Guide”. For the detail of CMT2110/17A configurations with the RFPDK, please refer to “AN102 CMT2110/17A Configuration Guideline”. Table 11. Configurable Parameters in RFPDK Category RF Settings Parameters Frequency To input a desired transmitting radio frequency in the (CMT2110A) range from 240 to 480 MHz. The step size is 0.001 MHz. Frequency To input a desired transmitting radio frequency in the (CMT2117A) range from 240 to 960 MHz. The step size is 0.001 MHz. Tx Power Xtal Cload PA Ramping Start by Transmitting Settings Descriptions Stop by To select a proper transmitting output power from -10 dBm to +14 dBm, 1 dBm margin is given above +13 dBm. On-chip XOSC load capacitance options: from 10 to 22 pF. To control PA output power ramp up/down time, options are 0 and 2n us (n from 0 to 10). Start condition of a transmitting cycle, by Data Pin Rising/Falling Edge. Stop condition of a transmitting cycle, by Data Pin Holding Low for 20 to 90 ms. Rev 1.2 | Page 13/25 Default Mode 433.92 MHz 868.35 MHz Basic Advanced Basic Advanced Basic +13 dBm Advanced Basic 15 pF Advanced 0 us Advanced Data Pin Rising Edge Advanced Data Pin Holding Low Advanced for 20 ms www.hoperf.com CMT2110/17A 5.4 Power Amplifier A highly efficient single-ended Power Amplifier (PA) is integrated in the CMT2110/17A to transmit the modulated signal out. Depending on the application, the user can design a matching network for the PA to exhibit optimum efficiency at the desired output power for a wide range of antennas, such as loop or monopole antenna. Typical application schematics and the required BOM are shown in “Chapter 4 Typical Application Schematic”. For the schematic, layout guideline and the other detailed information please refer to “AN101 CMT211xA Schematic and PCB Layout Design Guideline”. The output power of the PA can be configured by the user within the range from -10 dBm to +13 dBm in 1 dB step size using the CMOSTEK USB Programmer and RFPDK. 5.5 PA Ramping When the PA is switched on or off quickly, its changing input impedance momentarily disturbs the VCO output frequency. This process is called VCO pulling, and it manifests as spectral splatter or spurs in the output spectrum around the desired carrier frequency. By gradually ramping the PA on and off, PA transient spurs are minimized. The CMT2110/17A has built-in PA ramping configurability with options of 0, 1, 2, 4, 8, 16, 32, 64, 128, 256, 512 and 1024 us, as shown in Figure 13. When the option is set to “0”, the PA output power will ramp up to its configured value in the shortest possible time. The ramp down time is identical to the ramp up time in the same configuration. CMOSTEK recommends that the maximum symbol rate should be no higher than 1/2 of the PA ramping “rate”, as shown in the formula below: SRMax ≤ 0.5 * ( 1 ) tRAMP In which the PA ramping “rate” is given by (1/tRAMP). In other words, by knowing the maximum symbol rate in the application, the PA ramping time can be calculated by: tRAMP ≤ 0.5 * ( 1 ) SRMAX The user can select one of the values of the tRAMP in the available options that meet the above requirement. If somehow the tRAMP is set to be longer than “0.5 * (1/SRMax)”, it will possibly bring additional challenges to the OOK demodulation of the Rx RFO Amplitude device. For more detail of calculating tRAMP, please refer to “AN102 CMT2110/17A Configuration Guideline”. 0 us 1 us 2 us 4 us 8 us 512 us 1024 us Data Time Logic 1 Logic 0 Time Figure 13. PA Ramping Time Rev 1.2 | Page 14/25 www.hoperf.com CMT2110/17A 5.6 Crystal Oscillator and RCLK The CMT2110/17A uses a 1-pin crystal oscillator circuit with the required crystal load capacitance integrated on-chip. Figure 14 shows the configuration of the XTAL circuitry and the crystal model. The recommended specification for the crystal is 26 MHz with ±20 ppm, ESR (Rm) < 60 Ω, load capacitance CLOAD ranging from 12 to 20 pF. To save the external load capacitors, a set of variable load capacitors CL is built inside the CMT2110/17A to support the oscillation of the crystal. The value of load capacitors is configurable with the CMOSTEK USB Programmer and RFPDK. To achieve the best performance, the user only needs to input the desired value of the XTAL load capacitance CLOAD of the crystal (can be found in the datasheet of the crystal) to the RFPDK, then finely tune the required XO load capacitance according to the actual XO frequency. Please refer to “AN103 CMT211xA-221xA One-Way RF Link Development Kits Users Guide” for the method of choosing the right value of CL. Crystal Model CMT2110/17A CMT2110/17A Cc XTAL RCLK 26 MHz 0. 3 – 0. 7 Vpp Rm Cm XTAL C0 CL CL Lm Figure 14. XTAL Circuitry and Crystal Model Figure 15. RCLK Circuitry If a 26 MHz RCLK (reference clock) is available in the system, the user can directly use it to drive the CMT2110/17A by feeding the clock into the chip via the XTAL pin. This further saves the system cost due to the removal of the crystal. A coupling capacitor is required if the RCLK is used. The recommended amplitude of the RCLK is 0.3 to 0.7 Vpp on the XTAL pin. Also, the user should set the internal load capacitor CL to its minimum value. See Figure 15 for the RCLK circuitry. Rev 1.2 | Page 15/25 www.hoperf.com CMT2110/17A 6. Working States and Transmission Control Interface 6.1 Working States The CMT2110/17A has 4 different working states: SLEEP, XO-STARTUP, TUNE and TRANSMIT. SLEEP When the CMT2110/17A is in the SLEEP state, all the internal blocks are turned off and the current consumption is minimized to 20 nA typically. XO-STARTUP After detecting a valid control signal on DATA pin, the CMT2110/17A goes into the XO-STARTUP state, and the internal XO starts to work. The valid control signal can be a rising or falling edge on the DATA pin, which can be configured on the RFPDK. The host MCU has to wait for the tXTAL to allow the XO to get stable. The tXTAL is to a large degree crystal dependent. A typical value of tXTAL is provided in Table 12. TUNE The frequency synthesizer will tune the CMT2110/17A to the desired frequency in the time tTUNE. The PA can be turned on to transmit the incoming data only after the TUNE state is done, before that the incoming data will not be transmitted. See Figure 16 and Figure 17 for the details. TRANSMIT The CMT2110/17A starts to modulate and transmit the data coming from the DATA pin. The transmission can be ended in 2 methods: firstly, driving the DATA pin low for tSTOP time, where the tSTOP can be configured from 20 to 90 ms on the RFPDK; secondly, issuing SOFT_RST command over the two-wire interface, this will stop the transmission in 1 ms. See section 6.2.3 for details of the two-wire interface. Table 12. Timing in Different Working States Parameter XTAL Startup Time Symbol [1] Min Typ Max Unit tXTAL 400 us Time to Tune to Desired Frequency tTUNE 370 us Hold Time After Rising Edge tHOLD 10 tSTOP 20 [2] Time to Stop The Transmission ns 90 ms Notes: [1]. This parameter is to a large degree crystal dependent. [2]. Configurable from 20 to 90 ms in 10 ms step size. 6.2 Transmission Control Interface The CMT2110/17A uses the DATA pin for the host MCU to send in data for modulation and transmission. The DATA pin can be used as pin for EEPROM programming, data transmission, as well as controlling the transmission. The transmission can be started by detecting rising or falling edge on the DATA pin, and stopped by driving the DATA pin low for tSTOP as shown in the table above. Besides communicating over the DATA pin, the host MCU can also communicate with the device over the two-wire interface, so that the transmission is more robust, and consumes less current. Please note that the user is recommended to use the Tx Enabled by DATA pin Rising Edge, which is described in Section 6.2.1. Rev 1.2 | Page 16/25 www.hoperf.com CMT2110/17A 6.2.1 Tx Enabled by DATA Pin Rising Edge As shown in the Figure 16, once the CMT2110/17A detects a rising edge on the DATA pin, it goes into the XO-STARTUP state. The user has to pull the DATA pin high for at least 10 ns (tHOLD) after detecting the rising edge, as well as wait for the sum of tXTAL and tTUNE before sending any useful information (data to be transmitted) into the chip on the DATA pin. The logic state of the DATA pin is “Don't Care” from the end of tHOLD till the end of tTUNE. In the TRANSMIT state, PA sends out the input data after they are modulated. The user has to pull the DATA pin low for tSTOP in order to end the transmission. SLEEP XO-STARTUP TUNE SLEEP TRANSMIT STATE tXTAL Rising Edge DATA pin 0 tTUNE Don’t Care 1 tSTOP Valid Transmitted Data 0 tHOLD PA out RF Signals Figure 16. Transmission Enabled by DATA Pin Rising Edge 6.2.2 Tx Enabled by DATA Pin Falling Edge As shown in the Figure 17, once the CMT2110/17A detects a falling edge on the DATA pin, it goes into XO-STARTUP state and the XO starts to work. During the XO-STARTUP state, the DATA pin needs to be pulled low. After the XO is settled, the CMT2110/17A goes to the TUNE state. The logic state of the DATA pin is “Don't Care” during the TUNE state. In the TRANSMIT state, PA sends out the input data after they are modulated. The user has to pull the DATA pin low for tSTOP in order to end the transmission. Before starting the next transmit cycle, the user has to pull the DATA pin back to high. SLEEP SLEEP TRANSMIT XO-STARTUP TUNE STATE Falling Edge DATA pin 1 PA out tXTAL tTUNE 0 Don’t Care tSTOP Valid Transmitted Data 0 1 RF Signals Figure 17. Transmission Enabled by DATA Pin Falling Edge 6.2.3 Two-wire Interface For power-saving and reliable transmission purposes, the CMT2110/17A is recommended to communicate with the host MCU over a two-wire interface (TWI): DATA and CLK. The TWI is designed to operate at a maximum of 1 MHz. The timing requirement and data transmission control through the TWI are shown in this section. Rev 1.2 | Page 17/25 www.hoperf.com CMT2110/17A Table 13. TWI Requirements Parameter Symbol Digital Input Level High Digital Input Level Low Conditions Min VIH Typ Max 0.8 Unit VDD VIL 0.2 VDD 1,000 kHz CLK Frequency FCLK 10 CLK High Time tCH 500 ns CLK Low Time tCL 500 ns CLK delay time for the first falling edge of the 20 15,000 ns 15,000 ns CLK Delay Time tCD DATA Delay Time tDD DATA Setup Time tDS From DATA change to CLK falling edge 20 ns DATA Hold Time tDH From CLK falling edge to DATA change 200 ns TWI_RST command, see Figure 20 The data delay time from the last CLK rising edge of the TWI command to the time DATA return to default state CLK tCH tCL tDS tDH DATA Figure 18. Two-wire Interface Timing Diagram Once the device is powered up, TWI_RST and SOFT_RST should be issued to make sure the device works in SLEEP state robustly. On every transmission, TWI_RST and TWI_OFF should be issued before the transmission to make sure the TWI circuit functions correctly. TWI_RST and SOFT_RST should be issued again after the transmission for the device going back to SLEEP state reliably till the next transmission. The operation flow with TWI is shown as the figure below. One Transmission Cycle Reset TWI (1) - TWI_RST (2) - SOFT_RST (1) - TWI_RST (2) - TWI_OFF TRANSMISSION One Transmission Cycle (1) - TWI_RST (2) - SOFT_RST (1) - TWI_RST (2) - TWI_OFF TRANSMISSION (1) - TWI_RST (2) - SOFT_RST Figure 19. CMT2110/17A Operation Flow with TWI Table 14. TWI Commands Descriptions Command Descriptions Implemented by pulling the DATA pin low for 32 clock cycles and clocking in 0x8D00, 48 clock cycles in total. It only resets the TWI circuit to make sure it functions correctly. The DATA pin cannot detect the Rising/Falling edge to trigger transmission after this command, until the TWI_OFF command is issued. TWI_RST Notes: 1. 2. Please ensure the DATA pin is firmly pulled low during the first 32 clock cycles. When the device is configured as Transmission Enabled by DATA Pin Falling Edge, in order to issue the TWI_RST command correctly, the first falling edge of the CLK should be sent tCD after the DATA falling edge, which should be longer than the minimum DATA setup time 20 ns, and shorter than 15 us, Rev 1.2 | Page 18/25 www.hoperf.com CMT2110/17A Command Descriptions as shown in Figure 20. 3. When the device is configured as Transmission Enabled by DATA Pin Rising Edge, the default state of the DATA is low, there is no tCD requirement, as shown in Figure 21. Implemented by clocking in 0x8D02, 16 clock cycles in total. TWI_OFF It turns off the TWI circuit, and the DATA pin is able to detect the Rising/Falling edge to trigger transmission after this command, till the TWI_RST command is issued. The command is shown as Figure 22. Implemented by clocking in 0xBD01, 16 clock cycles in total. SOFT_RST It resets all the other circuits of the chip except the TWI circuit. This command will trigger internal calibration for getting the optimal device performance. After issuing the SOFT_RST command, the host MCU should wait 1 ms before sending in any new command. After that, the device goes to SLEEP state. The command is shown as Figure 23. 32 clock cycles CLK 16 clock cycles … … tCD 1 DATA tDD 0x8D00 0 1 Figure 20. TWI_RST Command When Transmission Enabled by DATA Pin Falling Edge 32 clock cycles CLK DATA 16 clock cycles … … 0 0x8D00 0 Figure 21. TWI_RST Command When Transmission Enabled by DATA Pin Rising Edge 16 clock cycles CLK DATA 16 clock cycles … CLK tDD 0x8D02 (TWI_OFF) Default State Figure 22. TWI_OFF Command DATA … tDD 0xBD01 (SOFT_RST) Default State Figure 23. SOFT_RST Command The DATA is generated by the host MCU on the rising edge of CLK, and is sampled by the device on the falling edge. The CLK should be pulled up by the host MCU during the TRANSMISSION shown in Figure 19. The TRANSMISSION process should refer to Figure 16 or Figure 17 for its timing requirement, depending on the “Start By” setting configured on the RFPDK. The device will go to SLEEP state by driving the DATA low for tSTOP, or issuing SOFT_RST command. A helpful practice for the device to go to SLEEP is to issue TWI_RST and SOFT_RST commands right after the useful data is transmitted, instead of waiting the tSTOP, this can save power significantly. Rev 1.2 | Page 19/25 www.hoperf.com CMT2110/17A 7. Ordering Information Table 15. CMT2110/17A Ordering Information Part Number CMT2110A-ESR[1] CMT2117A-ESR[1] Descriptions Low-Cost 240-480 MHz OOK Transmitter Low-Cost 240-960 MHz OOK Transmitter Package Package Type Option SOT23-6 Tape & Reel SOT23-6 Tape & Reel Operating MOQ / Condition Multiple 1.8 to 3.6 V, 3,000 -40 to 85 ℃ 1.8 to 3.6 V, 3,000 -40 to 85 ℃ Notes: [1]. “E” stands for extended industrial product grade, which supports the temperature range from -40 to +85 ℃. “S” stands for the package type of SOT23-6. “R” stands for the tape and reel package option, the minimum order quantity (MOQ) for this option is 3,000 pieces. The default frequency for CMT2110A-ESR is 433.92 MHz, for CMT2117A-ESR is 868.35 MHz, for the other settings, please refer to the Table 11 of Page 13. Visit www.cmostek.com/products to know more about the product and product line. Contact sales@cmostek.com or your local sales representatives for more information. Rev 1.2 | Page 20/25 www.hoperf.com CMT2110/17A 8. Package Outline The 6-pin SOT23-6 illustrates the package details for the CMT2110/17A. Table 16 lists the values for the dimensions shown in the illustration. e1 e 0.25 L E1 E c b θ D A A2 A3 A1 Figure 24. 6-Pin SOT23-6 Table 16. 6-Pin SOT23-6 Package Dimensions Symbol Size (millimeters) Min Typ Max A — — 1.35 A1 0.04 — 0.15 A2 1.00 1.10 1.20 A3 0.55 0.65 0.75 b 0.38 — 0.48 C 0.08 — 0.20 D 2.72 2.92 3.12 E 2.60 2.80 3.00 E1 1.40 1.60 1.80 e 0.95 BSC e1 1.90 BSC L 0.30 — 0.60 θ 0 — 8° Rev 1.2 | Page 21/25 www.hoperf.com CMT2110/17A 9. Top Marking 9.1 CMT2110/17A Top Marking 6 5 4 6 5 4 0 A ① ② ③ 7 A ① ② ③ 1 1 2 3 2 3 Figure 25. CMT2110A (Left) and CMT2117A (Right) Top Marking Table 17. CMT2110/17A Top Marking Explanation Top Mark: 0A①②③ / 7A①②③ Mark Method: Laser Font Size: 0.6 mm, right-justified 1st letter: nd 2 letter: 3rd – 5th letter: 0, represents CMT2110A 7, represents CMT2117A A: represents revision A ①②③: Internal reference for data code tracking, assigned by the assembly house Rev 1.2 | Page 22/25 www.hoperf.com CMT2110/17A 10. Other Documentations Table 18. Other Documentations for CMT2110/17A Brief AN101 AN102 AN103 Name Descriptions CMT211xA Schematic and PCB Layout Design Guideline design rules, RF matching network and other application layout design related issues. CMT2110/17A Configuration Guideline CMT211xA-221xA One-Way RF Link Development Kits Users Guide Details of CMT2110/13/17/19A PCB schematic and layout Details of configuring CMT2110/17A features on the RFPDK. User’s Guides for CMT211xA and CMT221xA Development Kits, including Evaluation Board and Evaluation Module, CMOSTEK USB Programmer and the RFPDK. Rev 1.2 | Page 23/25 www.hoperf.com CMT2110/17A 11. Document Change List Table 19. Document Change List Rev. No. Chapter 0.7 All Initial released version 0 Add Ordering Information in first page 1 Update Table 5 3 Update the title of Figure8/9 4 Update the BOM of Typical Application Schematics 5 Update Section 5.3 Embedded EEPROM and RFPDK Add Section 0.8 Description of Changes Date 2014-03-04 2014-04-05 5.5 PA Ramping 0.85 0.9 1.0 1.1 1.2 1 Update Table 5 3 Update Figure 4 0 Update ordering Information in first page Update Description 5 Update 5.3, add Table 11 7 Update chapter 7. Ordering information - - 2014-04-08 2014-06-14 2014-06-30 All Add product CMT2117A to the datasheet 6 Add Section 6.2.3 6 Update Section 6.2.3 Rev 1.2 | Page 24/25 2015-01-16 2015-01-23 www.hoperf.com CMT2110/17A 12. Contact Information Hope Microelectronics Co., Ltd Address: 2/F,Building3,Pingshan Private Enterprise science and Technology Park,Xili Town,Nanshan District,Shenzhen,China Tel: +86-755-82973805 Fax: +86-755-82973550 Email: sales@hoperf.com hoperf@gmail.com Website: http://www.hoperf.com http://www.hoperf.cn Copyright. CMOSTEK Microelectronics Co., Ltd. All rights are reserved. The information furnished by CMOSTEK is believed to be accurate and reliable. However, no responsibility is assumed for inaccuracies and specifications within this document are subject to change without notice. The material contained herein is the exclusive property of CMOSTEK and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of CMOSTEK. CMOSTEK products are not authorized for use as critical components in life support devices or systems without express written approval of CMOSTEK. The CMOSTEK logo is a registered trademark of CMOSTEK Microelectronics Co., Ltd. All other names are the property of their respective owners. Rev 1.2 | Page 25/25 www.hoperf.com
CMT2117A-ESR 价格&库存
很抱歉,暂时无法提供与“CMT2117A-ESR”相匹配的价格&库存,您可以联系我们找货
