CMT2180A-ESR
CMT2180A-ESR
    HOPERF(华普微)
    SOIC-14
    CMT2180A-ESR
CMT2180A-ESR 数据手册
CMT2180/89A A CMT2180/89A 240 – 960 MHz SoC OOK/(G)FSK Transmitter Features Applications   Remote Keyless Entry (RKE)  High-Performance RISC Microcontroller Core  All Single-Cycle Instructions Except Branches  Garage and gate door openers  Up to 8 MHz Clock  Home/Building Automation and Security  Multiple Interruption Supported  Industrial Monitoring and Controls  32 Bytes EEPROM / 64 Bytes SRAM / 1024 Words Flash  Remote Lighting Control  Wireless Alarm and Security Systems  Consumer Electronics Applications High-Performance OOK Transmitter  All Features Programmable on the RFPDK  CMT2180A: 240 to 480 MHz, OOK Modulation  CMT2189A: 240 to 960 MHz, OOK/(G)FSK Modulation  Symbol Rate: up to 30 ksps for OOK, 100 ksps for (G)FSK  Configurable Single-Ended or Differential PA Output  Output Power: -10 to +13 dBm  Supply Voltage: 2.3 to 3.6 V  1-pin Crystal  FCC / ETSI Compliant  RoHS Compliant  14-pin SOP Package Ordering Information Part Number Frequency Package MOQ CMT2180A-ESR 433.92 MHz SOP14 2,500 pcs CMT2189A-ESR 868.35 MHz SOP14 2,500 pcs Description The CMT2180/89A is a fully integrated, highly flexible, high performance, SoC OOK/G(FSK) transmitter with an embedded RISC microcontroller core for various 240 to 960 MHz wireless applications. It is part of the CMOSTEK NextGenRFTM family, which includes a complete line of transmitters, receivers and transceivers. The device SOP14 includes a 1024 words flash for programming the user's application, supports up to 4 push buttons to implement the user defined functions. All the device features (such as frequency, output power, WDT, Security and etc.) and programs can be burned into the device using the CMOSTEK USB Programmer and RFPDK. Alternatively, in VDD 1 14 XTAL GND 2 13 GND PAP 3 12 DATA PAN 4 11 VDD CLK 5 10 GND stock products of 433.92/868.35 MHz are available for immediate demands with no need of extra programming. The CMT2180/89A uses a 1-pin crystal oscillator circuit with the required crystal load capacitance integrated on-chip to minimize the BOM counts. The device can deliver up to +13 dBm output power and the PA output can 9 K0/DATA2 K3/VTG 6 be either single-ended or differential. The device operates from 2.3 V to 3.6 V. Its low power design enables superior 8 K1/CLK2 K2 7 operation life for battery powered application. The CMT2180/89A TM NextGenRF transmitter together with CMOSTEK CMT2180/89A receiver enables a highly flexible, low cost RF link. Copyright © By CMOSTEK Rev 0.9 | Page 1 / 4 www.hoperf.com CMT2180/89A Typical Application CMT2180/89A VDD X1 1 XTAL GND GND PAP DATA DATA C0 2 L1 13 DATA2 CLK 3 12 DATA CLK2 VTG VDD C2 4 C1 11 U1 PAN CLK 5 VTG 3 4 R1 5 6 10 GND 6 K3/VTG SW2 D1 2 7 VDD CLK SW3 VDD 1 VTG Loop Antenna J1 VDD 14 VDD 9 DATA2 SW0 8 CLK2 SW1 K0/DATA2 7 K2 K1/CLK2 Notes: 1. Connector J1 is used only for chip programming. 2. D1 is used to isolate the 15V high voltage at VTG during chip programming. If user does not need to program the chip, D1 can be removed, but pulling VTG up to VDD by R1 is always required. Figure 1. CMT2180/89A Typical Application with Differential PA Output Table 1. BOM of 433.92 MHz Application with Differential PA Output Designator Descriptions Value CMT2180/89A, 240 – 960 MHz SoC OOK/(G)FSK U1 transmitter X1 ±20 ppm, SMD32*25 mm crystal SW[3:0] Push buttons Unit - - CMOSTEK 26 MHz EPSON - - D1 MBR0520LT1, SOD123 - - R1 ±5%, 0402 10k Ω C0 ±20%, 0402 X7R, 25 V 0.1 uF Murata GRM15 C1 ±0.25 pF, 0402 NP0, 50 V 2.2 pF Murata GRM15 C2 ±0.25 pF, 0402 NP0, 50 V 2.2 pF Murata GRM15 L1 ±5%, 0603 multi-layer chip inductor 180 nH Murata LQG18 VDD X1 L3 L2 XTAL GND GND PAP DATA 2 DATA2 CLK 12 CLK2 DATA VTG VDD 4 11 U1 PAN C2 CLK VTG GND 6 K3/VTG SW2 VDD D1 3 4 R1 5 6 10 CLK SW3 2 7 VDD 5 J1 1 DATA 13 3 C1 VDD 14 VDD VTG C0 L1 ANT IR CMT2180/89A 1 C3 Manufacturer DATA2 SW0 8 CLK2 SW1 K0/DATA2 7 K2 9 K1/CLK2 Notes: 1. Connector J1 is used only for chip programming. 2. D1 is used to isolate the 15V high voltage at VTG during chip programming. If user does not need to program the chip, D1 can be removed, but pulling VTG up to VDD by R1 is always required. Figure 2. CMT2180/89A Typical Application with Single-ended PA Output Rev 0.9 | Page 2 / 4 www.hoperf.com CMT2180/89A Table 2. BOM of 433.92 MHz Application with Single-ended PA Output Designator U1 X1 SW[3:0] Descriptions CMT2180/89A, 240 – 960 MHz SoC OOK/(G)FSK transmitter ±20 ppm, SMD32*25 mm crystal Push buttons Value Unit Manufacturer - - CMOSTEK 26 MHz EPSON - - D1 MBR0520LT1, SOD123 - - R1 ±5%, 0402 10k Ω C0 ±20%, 0402 X7R, 25 V 0.1 uF IR Murata GRM15 C1 ±5%, 0402 NP0, 50 V 68 pF Murata GRM15 C2 ±5%, 0402 NP0, 50 V 15 pF Murata GRM15 C3 ±5%, 0402 NP0, 50 V 15 pF Murata GRM15 L1 ±5%, 0603 multi-layer chip inductor 180 nH Murata LQG18 L2 ±5%, 0603 multi-layer chip inductor 36 nH Murata LQG18 L3 ±5%, 0603 multi-layer chip inductor 18 nH Murata LQG18 Table 3. CMT2180/89A Pin Descriptions Pin Number Name I/O Descriptions 1 VDD I Power supply input 2 GND I Ground 3 PAP O The differential power amplifier output, when using as singled-ended output, PAN/PAP 4 PAN O should be connected together before connect to the matching network 5 CLK I Clock1 for the chip programming, internally pulled up to VDD 6 K3/VTG I Push button key 3 or voltage for the chip programming 7 K2 I Push button key 2 8 K1/CLK2 I Push button key 1 or clock2 for the chip programming 9 K0/DATA2 IO Push button key 0 or data2 for the chip programming 10 GND I Ground 11 VDD I Power supply input Data1 for the chip programming 12 DATA IO Pulled up internally to VDD when configured as Transmission Enabled by DATA Pin Rising Edge and used as input pin 13 GND I Ground 14 XTAL I 26 MHz single-ended crystal oscillator input or external 26 MHz reference clock input Rev 0.9 | Page 3 / 4 www.hoperf.com CMT2180/89A Package Outline D A3 h A2 A 0.25 c θ A1 L L1 E1 b E e Figure 3. 14-Pin SOP Package Table 4. 14-Pin SOP Package Dimensions Size (millimeters) Symbol Min Typ Max A - - 1.75 A1 0.05 - 0.225 A2 1.30 1.40 1.50 A3 0.60 0.65 0.70 b 0.39 - 0.48 C 0.21 - 0.26 D 8.45 8.65 8.85 E 5.80 6.00 6.20 E1 3.70 3.90 4.10 e 1.27 BSC h 0.25 - 0.50 L 0.30 - 0.60 L1 θ 1.05 BSC 0 - 8° Copyright. CMOSTEK Microelectronics Co., Ltd. All rights are reserved. The information furnished by CMOSTEK is believed to be accurate and reliable. However, no responsibility is assumed for inaccuracies and specifications within this document are subject to change without notice. The material contained herein is the exclusive property of CMOSTEK and shall not be distributed, reproduced, or disclosed in whole or in part without prior written permission of CMOSTEK. CMOSTEK products are not authorized for use as critical components in life support devices or systems without express written approval of CMOSTEK. The CMOSTEK logo is a registered trademark of CMOSTEK Microelectronics Co., Ltd. All other names are the property of their respective owners. Rev 0.9 | Page 4 / 4 www.hoperf.com
CMT2180A-ESR 价格&库存
很抱歉,暂时无法提供与“CMT2180A-ESR”相匹配的价格&库存,您可以联系我们找货
