CPM1206-B5NR000
CPM1206-B5NR000
    FORT(致强)
    Surface Mount High Current Jumper Chip Resistor
CPM1206-B5NR000 数据手册
Surface Mount High Current Jumper Chip Resistor 1. Scope: 1.1 This specification is applicable of “ZERO” milli-ohm resistor (Jumper) products. 2. Explanation of Part Numbers: CPM 1206 Type Size (inch) - B Rated Power 1206 B = 0.5 W Current 2512 2= 2.0 W Jumper Chip 2725 4= 4.0 W Resistor 2817 3= 3.0W 4527 5= 5.0W 5 N Packaging* R000 Resistance Nominal Tolerance Resistance 1=1,000pcs 2=2,000pcs 95% coverage 8. Recommend Land Pattern: a i a b Type Dimensions - in inches (millimeters) a b i CPM1206 0.040 (1.00) 0.075 (1.90) 0.055 (1.40) CPM2512 0.083 (2.11) 0.145 (3.68) 0.125 (3.18) CPM2725 0.092 (2.34) 0.270 (6.86) 0.118 (3.00) CPM2817 0.096 (2.45) 0.181 (4.60) 0.122 (3.11) CPM4527 0.134 (3.40) 0.344 (8.74) 0.292 (6.43) 9. Packaging: Model Tape Width Diameter Piece/reel CPM1206 8 mm/embossed plastic 178 mm/7” 5,000 178 mm/7” 4,000 178 mm/7” 2,000 178 mm/7” 1,000 178 mm/7” 1,000 CPM2512 CPM2725 12 mm/embossed plastic CPM2817 CPM4527 24 mm/embossed plastic Fort Technology Co., Ltd www.fort-tec.com , Document #: FT-SPEC-CPM-05R1X-R000-V1, Revision 2016/02/05 Page 3 of 3
CPM1206-B5NR000 价格&库存
很抱歉,暂时无法提供与“CPM1206-B5NR000”相匹配的价格&库存,您可以联系我们找货
