CXC3X260000GHVRT3R
CXC3X260000GHVRT3R
    PARTRON(帕创)
    SMD3225_4P
    无源晶振 SMD3225_4P
CXC3X260000GHVRT3R 数据手册
APPROVAL SHEET PRODUCT NAME SMD CRYSTAL UNIT USER NAME USER PART NO. Provider PARTRON PARTRON MODEL CXC3X260000GHVRT3R Issued by Checked by Approved by Issued by Checked by Approved by In Charge J.S.B. L.K.G L.H.Y. Division R & D Q C R & D User PARTRON MSL Halogen-Free LEAD FREE MSL LEVEL 1 Case Fab China/Yantai/Partron Assembly China/Yantai/Partron Final Test & Packing China/Yantai/Partron ※ Please return one copy with approval to PARTRON 2017. 09. 26 22-6, Seokwoo-dong, Hwaseong-si, Gyeonggi-do, Korea 445-170 TEL : 82-31-201-7750 B1-PTR B125 - 1 /14- Contents B1-PTR B125 1. Revision History - - - 2. Electrical characteristics - - - 4 3. Mechanical characteristics - - - 6 4. A Primary test result - - - 7 5. Reliability test - - - 8 6. Construction - - - 9 7. Notices - - - 10 8. Packing - - - 11 3 - 2 /14- 1. Revision History Rev. Date Rev. page Revision Content and Reason V1.0 '17.09.26 All Page First-edition B1-PTR B125 Remark - 3 /14- 2. Electrical Characteristics No. Item Symbol 2.1 Frequency fo 2.2 Frequency Tolerance 2.3 Temperature range Content 26.0000 MHz Δf/fo ± 10 ppm (@+25℃ ±2℃) Storage TSTG -40 to 85℃ Operating TOPR -20 to 75℃ Δf/fo ± 10 ppm (-20℃ to +75℃, Ref. @+25℃±2℃) CTQ 2.4 Frequency stability 2.5 Drive level DL 100 uW max. 2.6 Equivalent series resistance R1 30Ω max. 2.7 Oscillation mode O/T Fundamental 2.8 Shunt capacitance CO 1.5 ± 0.2 pF. 2.9 Motional capacitance C1 10fF Max . 2.10 Load capacitance 2.11 Aging fa ± 2 ppm/year (@+25℃ ± 2℃) 2.12 Insulation resistance IR 500 MΩ min @ 100VDC CL 7.3 pF [REMARK] B1-PTR B125 - 4 /14- 2-1 Crystal Equivalent Circuit and Application Circuit [Crystal and equivalent circuit] [Application circuit for oscillation] B1-PTR B125 - 5 /14- 3. Mechanical characteristics 3-1 Outline Dimensions and Pin connections Size in mm A B 3.20 2.50 ±0.10 ±0.10 C D 0.75 max. E 1.20 0.70 ±0.10 ±0.10 Pin connections #1 HOT #2 GND #3 HOT #4 GND 3-2 Marking and LOT No ITEM #4 #3 19 26 200M 00M P 26 00M ① ② MARKING ① P Partron logo ② 26 00M Frequency: 26.0000MHz ③ xx CRYSTAL CL (2 digit) 24 00M xx YMD X ③ ④ Y : the last 1 digit of year 1 to 9, A to ⑤ #1 ※Laser Marking REMARK #2 ④ YMD V (A=10, H=17) M : 1 digit of month (Jan to Sept; 1 to 9, Oct; A,Nov B, Dec;C) D : 1 digit of day 1 to 9, A to V (A=10, V=31) EX) H11 = 2017.01.01, GAS = 2016.10.28 ⑤ B1-PTR B125 X Internal code - 6 /14- 4. A Primary test result 4-1 Electrical Characteristics Testing Data Item No. FL (ppm) C0 (pF) RR ( Ω) C1 (fF) L (mH) TS (ppm/pF) 30.00 10.00 - - - - - - High 10.00 Low -10.00 Max Min Pass -0.5 1.5 23.9 5.5 7.2 34.2 Pass -2.3 1.4 13.1 5.2 6.8 32.6 Average Stdev Pass -1.2 1.5 16.0 5.4 6.9 33.6 Pass 0.6 0.0 3.2 0.1 0.1 0.5 1 2 Pass -1.5 1.5 13.1 5.5 6.8 34.0 Pass -2.1 1.5 13.9 5.3 7.1 33.0 3 4 5 Pass -1.0 1.5 13.5 5.2 7.2 32.6 Pass -0.6 1.5 15.4 5.4 6.9 33.7 Pass -1.2 1.5 15.4 5.5 6.8 34.2 6 7 8 9 Pass -0.5 1.5 16.3 5.4 6.9 33.7 Pass -2.3 1.5 18.6 5.5 6.9 33.7 Pass -0.9 1.4 15.6 5.4 7.0 33.7 Pass -1.0 1.5 23.9 5.4 6.9 33.6 10 Pass -1.1 1.5 13.9 5.4 6.9 33.5 Spec B1-PTR B125 Result 1.5±0.2 pF - 7 /14- 5. Reliability test 5.1 Environment Test Contents Condition High temperature Storage +125℃±5℃, 240 hr Low temperature Storage -55℃±5℃, 240 hr High temperature High +85℃±5℃, RH=85%, 96 hr humidity Storage PCT Remark * 24 hour after Measure when finishes the test(25℃±5℃) +121℃±5℃, RH=100%, 24hr 5.2 Thermal shock , Reflow Test Contents Thermal shock REFLOW Condition -40℃±5℃,+85℃±5℃, 30 min, 32 cycle Pre Heating 200±5℃ , 30∼60 sec Remark * 24 hour after measure when finishes the test(25℃±5℃) Peak Heating 260℃±5℃ , 30sec Max 5.3 Mechanical Test Contents Vibration Drop test Condition Frequency : 10~500Hz, 10 ×9.8㎨(G) Sweep time 15min ,X.Y.Z each 5 times 12 times falling at a 152cm height Remark * 24 hour after measure when finishes the test(25℃±5℃) (falling with jig) 5.4 Soldering Condition ※ The maximum temperature guarantees to the 260℃±5℃ (10sec. Max.) B1-PTR B125 - 8 /14- 6. Construction I Ceramic package 2 Crystal blank 5 Electrode 3 Conductive epoxy 4 Cover B1-PTR B125 No item 1 Ceramic package 2 Crystal blank 3 Conductive Epoxy 4 Lid(Cover) 5 Electrode - 9 /14- 7. Notices 7-1 Max. two(2) times reflow is allowed. Once miss soldering is happen, hand work soldering by soldering iron is recommended. (+400℃ x within 5 sec) 7-2 Ultrasonic vibration may cause deterioration and destruction of the components. Please avoid ultrasonic cleaning 7-3 We recommend storing products at +15℃ to +35℃ and 25% R.H to 75% R.H 7-4 ESD Level : 7-5 MSL LEVEL 1 (JEDEC J-STD-020C) ITEM 1 Class2(2000V ~ 4000V) Floor Life Soak Requirements Time Conditions Time Conditions Unlimited =< 30℃/85%RH 165+5/-0 =< 85℃/85%RH 7-4 Unless adequate negative resistance is allocated in the oscillation circuit, start up time of oscillation may be increased, or no oscillation may occur. In order to avoid this, please provide enough negative resistance in the circuit design. ◎ How to check the negative resistance (1) Connect the resister (R) to the circuit in series with the crystal resonator. (2) Adjust R so that oscillation can start (or stop). (3) Measure R when oscillation just start (or stop) in above (2). (4) Get the negative resistance -R = R + CI value (5) Recommended -R [-R] > CI × 5 B1-PTR B125 - 10 /14- 8. Packing 8.1 Reel, carrier tape material Item Main Material Cover Tape PE (Polyester Film) Carrier Tape PC (Poly Carbonate +Carbon) or (Clear Poly Carbonate) Reel PS (Poly Styrene) 8.2 inner Box Reel size Quantity 13" ( 5,000 or 10,000 pcs ) x 2set 8.3 Outer Box Inner Box Quantity 3EA 60,000 pcs 5EA 100,000 pcs 8.4 Reel and Carrier tape dimensions(unit : mm) ■ Carrier tape *Heating press cover tape B1-PTR B125 - 11 /14- 8.5 Tape and Reel Leader Trailer Top Tape 200 min Empty Pockets 150 min Products Empty Pockets 150 min Top Tape 250 min Unreeling Direction B1-PTR B125 - 12 /14- Customer label Process Label Size B1-PTR B125 W W1 9.5mm 11.5mm - 13 /14- 8.6 Inner, outer box Dimensions (unit : mm) Inner Box Item Size Material Quantity B1-PTR B125 Outer Box Dimension Dimension (Type #1) (Type #2) L2 355mm 355mm 54mm W2 200mm 355mm 330mm H2 355mm 355mm Mark Dimension Mark L1 330mm W1 H1 Corrugated Cardboard 20,000 EA (Reel * 2set) Corrugated Cardboard 60,000 EA 100,000 EA (Inner Box * (Inner Box * 3set) 5set) - 14 /14-
CXC3X260000GHVRT3R 价格&库存
很抱歉,暂时无法提供与“CXC3X260000GHVRT3R”相匹配的价格&库存,您可以联系我们找货
