CXC6X260000GHVRN00
CXC6X260000GHVRN00
    PARTRON(帕创)
    SMD3225_4P
    无源晶振 SMD3225_4P
CXC6X260000GHVRN00 数据手册
APPROVAL SHEET PRODUCT NAME SMD CRYSTAL UNIT USER NAME USER PART NO. Provider PARTRON PARTRON MODEL CXC6X260000GHVRN00 Issued by Checked by Approved by Issued by Checked by Approved by In Charge J.S.B. M.N.S. K.J.M. Division R & D Q C R & D User PARTRON MSL Halogen-Free LEAD FREE MSL LEVEL 1 Case Fab China/Yantai/Partron Assembly China/Yantai/Partron Final Test & Packing China/Yantai/Partron ※ Please return one copy with approval to PARTRON 2011. 12. 13 22-6, Seokwoo-dong, Hwaseong-si, Gyeonggi-do, Korea 445-170 TEL : 82-31-201-7750 A1-PTR 0245 - 1 /14- Contents 1. Revision History - - - 3 2. Specification - - - 4 3. Mechanical characteristics - - - 6 4. A Primary test result A1-PTR 0245 - - 7 5. Reliability test - - - 8 6. Soldering condition - - - 9 7. Construction & material - - - 10 8. Notices - - - 11 9. Packing - - - 12 - 2 /14- 1. Revision History Rev. Date Rev. page Revision Content and Reason V1.0 '11.12.13 All Page First-edition A1-PTR 0245 Remark - 3 /14- 1. Scope This specification is for SMD crystal units 2. Electrical Characteristics No. Item Symbol 2.1 Frequency fo 2.2 Frequency Tolerance 2.3 Temperature range Content 26.0000 MHz Δf/fo ± 10 ppm Storage TSTG -40 to 85℃ Operating TOPR -30 to 85℃ Δf/fo ± 10 ppm (-30℃ to +85℃, Ref. @+25℃±2℃) CTQ (@+25℃ ±2℃) 2.4 Frequency stability 2.5 Drive level DL 100 uW max. 2.6 Equivalent series resistance R1 50 Ω max. 2.7 Oscillation mode O/T Fundamental 2.8 Shunt capacitance CO 3 pF max. 2.9 Motional capacitance C1 10 fF max. 2.10 Load capacitance 2.11 Aging fa ± 3 ppm/year max. (@+25℃ ± 2℃) 2.12 Insulation resistance IR 500 MΩ min @ 100VDC CL 9.0 pF [REMARK] A1-PTR 0245 - 4 /14- 2-1 Crystal Equivalent Circuit and Application Circuit [Crystal and equivalent circuit] [Application circuit for oscillation] A1-PTR 0245 - 5 /14- 3. Mechanical characteristics 3-1 Outline Dimensions and Pin connections 1.0±0.2 0.8±0.2 #4 #3 HOT D [Top View] #1 #2 HOT E #1 #2 HOT B #4 #3 C HOT A [Bottom View] Size in mm 2- 0.8 1.20 0.70 ±0.10 ±0.10 2- 0.45 0.75 max. 4- 1.4 E 4- 1.15 D #3 3.20 2.50 ±0.10 ±0.10 C #2 B #4 A #1 HOT #2 GND #3 HOT #4 GND 3-2 Marking and #1 Pin connections [Recommanded solder pattern (Top View)] LOT No ITEM #4 #3 26 200M 00M 19 P 26 00M ① x ② MARKING ① P Partron logo ② 26 00M Frequency: 26.0000MHz ③ X CRYSTAL CL (1 digit) 24 00M YMD S ③ #1 ④ Y : the last 1 digit of year ⑤ ※Laser Marking REMARK M : 1 digit of month (Jan to Sept; 1 to 9, Oct; A,Nov B, Dec;C) #2 ④ YMD D : 1 digit of day 1 to 9, A to V (A=10, V=31) EX) 769 = 2007.06.09, 8AS = 2008.10.28 Manufacturing Site ⑤ A1-PTR 0245 S K .. Korea C .. China - 6 /14- 4. A Primary test result Electrical Characteristics Testing Data Item Result FL (ppm) C0 (pF) RR ( Ω) C1 (fF) L (mH) TS (ppm/pF) 50.0 10.0 - - High 10.0 3.0 Low -10.0 - Max Min Pass 4.9 1.5 Pass 0.2 Average Stdev Pass 3.5 Pass 1 2 3 4 5 6 7 8 9 10 Spec A1-PTR 0245 - - - 27.3 5.8 7.3 25.1 1.5 13.3 5.1 6.5 24.2 1.5 20.4 5.6 6.7 24.8 1.3 0.0 4.3 0.2 0.2 0.3 Pass 0.2 1.5 13.3 5.1 7.3 24.7 Pass 4.2 1.5 20.4 5.6 6.7 24.5 Pass 4.9 1.5 18.2 5.6 6.7 24.8 Pass 4.1 1.5 23.6 5.6 6.7 24.9 Pass 3.9 1.5 18.3 5.7 6.6 25.0 Pass 2.8 1.5 20.7 5.7 6.6 24.2 Pass 3.3 1.5 17.8 5.8 6.5 25.1 Pass 3.0 1.5 26.4 5.5 6.8 25.0 Pass 4.0 1.5 18.3 5.5 6.8 25.0 Pass 4.4 1.5 27.3 5.6 6.7 24.8 Remark - - 7 /14- 5. Reliability test 5.1 Environment Test Contents Condition ℃±5℃, 240 hr -55℃±5℃, 240 hr High temperature Storage humidity Storage *Testing is complete, leave +125 Low temperature Storage High temperature High Remark at room temperature for 24 hours, and ℃ ℃, RH=85%, 96 hr +85 ±5 ℃ ℃, RH=100%, 24hr PCT +121 ±5 ℃ ℃) Measure.(25 ±5 * Be satisfied with contents No 2. Specification 5.2 Thermal shock , Reflow Test Condition Contents Remark *Testing is complete, leave -40℃±5℃,+90℃±5℃, 15 min, Thermal shock 200 cycle at room temperature for 24 hours, and ℃ ℃) Measure.(25 ±5 Pre Heating 200±5℃ , 30∼60 sec REFLOW Peak Heating 260℃±5℃ , 30sec Max * Be satisfied with contents No 2. Specification 5.3 Mechanical Test Contents Vibration Condition Frequency : 10~500Hz, 10 ×9.8 Remark ㎨(G) Sweep time 15min ,X.Y.Z each 5 times *Testing is complete, leave at room temperature for 1 hours, and ℃ ℃) Measure.(25 ±5 12 times falling at a 160cm height Drop test (falling with jig) * Be satisfied with contents No 2. Specification 5.4 Table Frequency change permitted A1-PTR 0245 ±3ppm Max. - 8 /14- 6. Soldering Condition 6.1 Standard Reflow soldering condition 240℃ 200℃ 160℃ 100℃ Max최대temp 온도 240 ±5 ℃ pre heating 예열 130 ~ 130~180℃ 180℃ 25℃ 0℃ 90 ~ 180초 90 ~180 sec 6.2 The maximum temperature guarantees 최대 30초 max 30sec 30~60sec 30∼60 초 to the 260℃(10sec Max) 6.3 Soldering Iron Method - Pre heating : 120℃ (30 ~ 300 sec) - Max temp : 410℃ Max - Time : Max 4 sec A1-PTR 0245 - 9 /14- 7. Construction I Ceramic package 2 Crystal blank 5 Electrode 3 Conductive epoxy 4 Cover A1-PTR 0245 No item 1 Ceramic package 2 Crystal blank 3 Conductive Epoxy 4 Lid(Cover) 5 Electrode - 10 /14- 8. Notices 8-1 Max. two(2) times reflow is allowed. Once miss soldering is happen, hand work soldering by soldering iron is recommended. (+400℃ x within 5 sec) 8-2 Ultrasonic vibration may cause deterioration and destruction of the components. Please avoid ultrasonic cleaning 8-3 We recommend storing products at +15℃ to +35℃ and 25% R.H to 75% R.H 8-4 ESD Level : Class2(2000V ~ 4000V) 8-5 MSL LEVEL 1 (JEDEC J-STD-020C) ITEM 1 Floor Life Soak Requirements Time Conditions Time Conditions Unlimited =< 30℃/85%RH 165+5/-0 =< 85℃/85%RH 8-6 Unless adequate negative resistance is allocated in the oscillation circuit, start up time of oscillation may be increased, or no oscillation may occur. In order to avoid this, please provide enough negative resistance in the circuit design. ◎ How to check the negative resistance (1) Connect the resister (R) to the circuit in series with the crystal resonator. (2) Adjust R so that oscillation can start (or stop). (3) Measure R when oscillation just start (or stop) in above (2). (4) Get the negative resistance -R = R + CI value (5) Recommended -R [-R] > CI × 5 A1-PTR 0245 - 11 /14- 9. Packing 9.1 Reel, carrier tape material item Main Material Cover Tape PE (Polyester film) Carrier Tape PC (Poly Carbonate +Carbon) or (Clear Poly Carbonate) Reel PS (Poly Styrene) 9.2 inner Box :1 reel/inner box and 2000 Oscillators/1 reel. 9.3 Outer Box : 10 inner boxes/Outer Box Total 20,000 Oscillators are paked in a 1 out box 9.4 Reel and Carrier tape dimensions(unit : mm) *Heating press cover tape A1-PTR 0245 - 12 /14- 9.5 Reel size (unit : mm) ` A1-PTR 0245 - 13 /14- 9.6 inner, outer box dimensions(unit : mm) A1-PTR 0245 - 14 /14-
CXC6X260000GHVRN00 价格&库存
很抱歉,暂时无法提供与“CXC6X260000GHVRN00”相匹配的价格&库存,您可以联系我们找货
