CXC8X160000GJVRN00
CXC8X160000GJVRN00
    PARTRON(帕创)
    SMD2520_4P
    无源晶振 SMD2520_4P
CXC8X160000GJVRN00 数据手册
APPROVAL SHEET PRODUCT NAME SMD CRYSTAL UNIT USER NAME USER PART NO. Provider PARTRON PARTRON MODEL CXC8X160000GJVRN00 Issued by Checked by Approved by Issued by Checked by Approved by In Charge J.S.B M.N.S K.J.M Division R&D QC R&D CUSTOMER PARTRON MSL Halogen-Free LEAD FREE MSL LEVEL 1 Case Fab China/Yantai/Partron Assembly China/Yantai/Partron Final Test & Packing China/Yantai/Partron ※ Please return one copy with approval to PARTRON 2016. 02. 24 22-6, Seokwoo-dong, Hwaseong-si, Gyeonggi-do, Korea 445-170 TEL : 82-31-201-7750 A1-PTR A910 - 1 /15- Contents A1-PTR A910 1. Revision History - - - 2. Electrical characteristics - - - 4 3. Mechanical characteristics - - - 6 4. A Primary test result - - - 7 5. Reliability test - - - 8 6. Soldering Condition - - - 9 3 7. Construction - - - 10 8. Notices - - - 11 9. Packing - - - 12 - 2 /15- 1. Revision History Rev. Date Rev. page Revision Content and Reason V1.0 '16.02.24 All Page First-edition A1-PTR A910 Remark - 3 /15- 2. Electrical Characteristics No. Item Symbol 2.1 Frequency fo 2.2 Frequency Tolerance 2.3 Temperature range Content 16.0000 MHz Δf/fo ± 10 ppm (@+25℃ ±2℃) Storage TSTG -40 to 85℃ Operating TOPR -20 to 85℃ Δf/fo ± 10 ppm (-20 to +85℃, Ref.@+25℃±2℃) CTQ 2.4 Frequency stability 2.5 Drive level DL 100 uW max. 2.6 Equivalent series resistance R1 150 Ω max. 2.7 Oscillation mode O/T Fundamental 2.8 Shunt capacitance CO 3 pF max. 2.9 Motional capacitance C1 10 fF max. 2.10 Load capacitance 2.11 Aging fa ± 3 ppm/3year max. (@+25℃ ± 2℃) 2.12 Insulation resistance IR 500 MΩ min @ 100VDC CL 9.0 pF [REMARK] A1-PTR A910 - 4 /15- 2.1 Crystal Equivalent Circuit and Application Circuit [Crystal and equivalent circuit] [Application circuit for oscillation] A1-PTR A910 - 5 /15- 3. Mechanical characteristics 3.1 Outline Dimensions and Pin connections Pin connections #1 HOT #2 #3 #4 GND HOT GND 3.2 Marking and [Recommended solder pad layout] LOT No ITEM MARKING REMARK ① P 19 26 200M 00M P 16 00 ② 16 00 Frequency: 16.0000MHz ② ③ X CRYSTAL CL (1 digit) #4 #3 ① x 24 00M YMD X ③ ④ Y : the last 1 digit of year ⑤ #1 ※Laser Marking M : 1 digit of month (Jan to Sept; 1 to 9, Oct; A,Nov B, Dec;C) #2 ④ YMD D : 1 digit of day 1 to 9, A to V (A=10, V=31) EX) 769 = 2007.06.09, 8AS = 2008.10.28 ⑤ Internal Code X * Note 1 1 Digit S T R N B P C Q D E F G H Crystal CL 6pF 7pF 8pF 9pF 10pF 11pF 12pF 13pF 14pF 15pF 16pF 18pF 20pF A1-PTR A910 - 6 /15- 4. A Primary test result Electrical Characteristics Testing Data Item No. Spec Result FL (ppm) C0 (pF) RR ( Ω) C1 (fF) L (mH) TS (ppm/pF) High 10.0 3.0 150.0 10.0 - - Low -10.0 - - - - - Max Pass 4.9 0.8 87.2 1.7 66.7 8.8 Min Pass 3.2 0.8 58.7 1.5 58.8 7.7 Average Pass 4.1 0.8 74.7 1.6 62.2 8.4 Stdev Pass 0.6 0.0 9.7 0.1 2.3 0.3 1 Pass 76.7 1.6 62.6 8.3 Pass 4.6 3.4 0.8 2 0.8 87.2 1.6 62.4 8.3 3 Pass 4.5 0.8 81.6 1.6 62.8 8.3 4 Pass 3.7 0.8 63.9 1.7 58.8 8.8 5 Pass 4.9 0.8 64.1 1.5 66.7 7.7 6 Pass 4.3 0.8 85.3 1.5 64.6 8.0 7 Pass 3.6 0.8 58.7 1.6 61.5 8.4 8 Pass 3.2 0.8 80.5 1.6 61.1 8.5 9 Pass 4.6 0.8 72.6 1.7 59.8 8.7 10 Pass 4.5 0.8 76.1 1.6 61.6 8.4 A1-PTR A910 Remark - 7 /15- 5. Reliability test 5.1 Environment Test Contents Condition Remark High temperature Storage +125℃±5℃, 240 hr *Testing is complete, leave at room temperature for -55℃±5℃, 240 hr Low temperature Storage High temperature High humidity Storage 24 hours, and Measure.(25℃±5℃) +85℃±5℃, RH=85%, 96 hr * Be satisfied with contents No 2. +121℃±5℃, RH=100%, 24hr PCT Specification 5.2 Thermal shock , Reflow Test Contents Condition Remark *Testing is complete, leave Thermal shock -40℃±5℃,+90℃±5℃, 15 min, 300 cycle at room temperature for 24 hours, and Measure.(25℃±5℃) REFLOW Pre Heating 200±5℃ , 30∼60 sec Peak Heating 260℃±5℃ , 30sec Max * Be satisfied with contents No 2. Specification 5.3 Mechanical Test Contents Condition Remark *Testing is complete, leave Vibration Frequency : 10~500Hz, 10 ×9.8㎨(G) Sweep time 15min ,X.Y.Z each 5 times at room temperature for 1 hours, and Measure.(25℃±5℃) 12 times falling at a 160cm height Drop test (falling with jig) * Be satisfied with contents No 2. Specification 5.4 Table Frequency change permitted A1-PTR A910 ±3ppm Max. - 8 /15- 6. Soldering Condition 6.1 Standard Reflow soldering condition Max temp 최대 온도 240 ±5 ℃ 240℃ 200℃ 160℃ pre heating 예열 130 ~ 130~180℃ 180℃ 100℃ 25℃ 0℃ 90 sec 90 ~180 ~ 180초 최대 30초 max 30sec 30~60sec 30∼60 초 6.2 The maximum temperature guarantees to the 260℃(10sec Max) 6.3 Soldering Iron Method - Pre heating : 120℃ (30 ~ 300 sec) - Max temp : 410℃ Max - Time : Max 4 sec A1-PTR A910 - 9 /15- 7. Construction I Ceramic package 2 Crystal blank 5 Electrode 3 Conductive epoxy 4 Cover A1-PTR A910 No item 1 Ceramic package 2 Crystal blank 3 Conductive Epoxy 4 Lid(Cover) 5 Electrode - 10 /15- 8. Notices 8.1 Max. two(2) times reflow is allowed. Once miss soldering is happen, hand work soldering by soldering iron is recommended. (+400℃ x within 5 sec) 8.2 Ultrasonic vibration may cause deterioration and destruction of the components. Please avoid ultrasonic cleaning 8.3 We recommend storing products at +15℃ to +35℃ and 25% R.H to 75% R.H 8.4 ESD Level : Class2(2000V ~ 4000V) 8.5 MSL LEVEL 1 (JEDEC J-STD-020C) ITEM 1 Floor Life Soak Requirements Time Conditions Time Conditions Unlimited =< 30℃/85%RH 165hr =< 85℃/85%RH 8.6 Unless adequate negative resistance is allocated in the oscillation circuit, start up time of oscillation may be increased, or no oscillation may occur. In order to avoid this, please provide enough negative resistance in the circuit design. ◎ How to check the negative resistance (1) Connect the resister (R) to the circuit in series with the crystal resonator. (2) Adjust R so that oscillation can start (or stop). (3) Measure R when oscillation just start (or stop) in above (2). (4) Get the negative resistance -R = R + CI value (5) Recommended -R [-R] > CI × 5 A1-PTR A910 - 11 /15- 9. Packing 9.1 Reel, carrier tape material item Main Material Cover Tape PE (Polyester film) Carrier Tape PC (Poly Carbonate +Carbon) or (Clear Poly Carbonate) Reel PS (Poly Styrene) 9.2 inner Box :1 reel/inner box and 2,000 pcs or 3,000 pcs /1 reel. 9.3 Outer Box : 10 inner boxes/Outer Box Max 30,000 pcs are packed in a 1 outer box 9.4 Reel and Carrier tape dimensions(unit : mm) ■ Carrier tape *Heating press cover tape A1-PTR A910 - 12 /15- 9.5 Reel Dimensions (unit : mm) Customer LABEL Process LABEL A1-PTR A910 - 13 /15- 9.6 Tape and Reel Leader Trailer Top Tape 200 min Empty Pockets 150 min Products Empty Pockets 150 min Top Tape 250 min Unreeling Direction A1-PTR A910 - 14 /15- 9.7 Inner, outer box Dimensions (unit : mm) customer label MSL LEVEL 1 Process label RoHS Pb ESD Pb-free RoHS RoHS A1-PTR A910 - 15 /15-
CXC8X160000GJVRN00 价格&库存
很抱歉,暂时无法提供与“CXC8X160000GJVRN00”相匹配的价格&库存,您可以联系我们找货
