F41MM-024XK-9
F41MM-024XK-9
    MICRONEL(微力)
    插件
F41MM-024XK-9 数据手册
Flat Axial Fan Range Features :Sizes - From 20mm to 254mm sq ● DC Voltages - 5, 12, 24, 48 & 53V ● AC Voltages - 110 & 220V ● ● Long life - Up to 160k hrs MTTF Airflow - up to 850 CFM ● Noise - as low as 13 dBA ● 3rd wire options available ● Connectors / Finger Guards available ● Specs and options are always being reviewed - please enquire for the latest information Tel: (01784) 439393 Fax : (01784) 477333 www.radiatron.com A complete capability ……….. Radiatron are pleased to be able to exclusively offer a choice of over 700 broadly complementary fans from 3 of todays leading manufacturers. Short-form details follow - full specs available upon request. (F/FM-series types) Broadest range of frame sizes including 48V types. Exceptionally high airflow versions. Super high speeds such as 40 x 20mm fans produces 11CFM/13 mm H2O & new 40 x 28mm over 15CFM /19 mmH2O. All DC fans over 50mm can be supplied as self-regulating, variable speed types with integrated thermistors. Sealing to IP55 possible. (JF/KF/JA-series types) In order to assist selection we have highlighted the highest airflow / lowest noise / best MTTF versions in each of the size & voltage sub-sections. Swiss engineered, precision miniature DC range. Over 30 yrs experience. Patented sleeve bearing proven to give over 60k hrs @ 60 degC ambient. Recent introduction of Meridian impellors makes their 40mm fan the quietest in its class. (YW/CW/WW/ST/WT/SW -series types) High quality Far Eastern produced value range. Wide range including AC types, available with NOS, Alarm & speed sensor 3-rd wire options. Fully CE / UL/ VDE approved. Tele: (01784) 439393 Fax : (01784) 477333 www.radiatron.com Alternatively if you are still unsure or don’t see exactly what you need – please let us help. Fill out as much of the following as you can and fax, phone or e-mail it to us. Enquiry / Questionnaire. Questionnaire ● ● ● ● ● ● ● ● ● Type (Flat / Axial / Blower) Size & Thickness Voltage (AC or DC) ...………….…………………. ……..….….…………………. ………………………………. Free Blowing Airflow ……......….………….………. Max Static Pressure (if known) ....……………………………. Working Point (if known) ..……….….…………………. Life Required Acceptable Noise Level Bearing Type ………………………………. ………………………………. ………………………………. (Sleeve = Low Noise / Ball = Long Life / Mic’l Sleeve = Both) ● ● ● Thermally Speed Sensitive ? Lead Length or Pins 3rd wire Function Required ? ………………………………. ………………………………. ………………………………. (non-op output, alarm signals, speed signal) ● Connector / Sub-assembly ? ………….………..…..…….... ● Application Potential per Annum Competition Part No. ………………………………. ………………………………. ………………………………. ● ● (if applicable, can usually x-ref) ● ● ● ● ● ● ● ● Radiatron Part No. (if known) Enquiry quantity Target Cost ………………………………. ………………………………. ………………………………. Name Contact Address …………………………………....……...... …………………………………….…..…... ………………………………….......……... ………………………………..……....….... Tel …………………….... Fax …..……………………… E-mail ………………………….. Tel: (01784) 439393 Fax : (01784) 477333 www.radiatron.com 1 of 15 21.03.2002 Radiatron Flat Fan Range Size (sq x thk) mm Radiatron Part V Bearing Type Speed (RPM) Airflow (CFM) Press. (mm/H2O) Noise (dBA) Power (Watts) MTTF (@25 DegC) MTTF (@40 DegC) DC Fan Range 20 X 10 20 X 10 20 X 10 JF0A08B5L JF0A08B5M JF0A08B5H 5 5 5 B B B 9000 12000 15000 0.68 1.06 1.27 1.95 4.34 6.84 19.5 25.3 30.4 0.35 0.45 0.55 75000 56000 45000 25 X 7 25 X 7 25 X 7 25 X 7 25 X 7 25 X 7 25 X 7 25 X 7 25 X 7 25 X 7 CW02507005BL CW02507005BM CW02507005BH FMA2505ABS JF0207B5LD JF0207B5MD JF0207B5HD JF0207B1LD JF0207B1MD JF0207B1HD 5 5 5 5 5 5 5 12 12 12 B B B S B+S B+S B+S B+S B+S B+S 6000 8000 10000 6000 7000 10000 13000 7000 10000 13000 0.82 1.13 1.45 0.82 0.84 1.24 1.68 0.84 1.24 1.68 1.41 2.50 3.96 1.41 1.67 3.14 5.51 1.67 3.14 5.51 20.0 24.0 28.0 20.0 12.6 18.1 26.6 12.6 18.1 26.6 0.20 0.25 0.30 0.20 0.30 0.45 0.65 0.48 0.60 0.72 80000 80000 80000 30000 55000 39000 30000 55000 39000 30000 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 25 X 10 F25LM-005XK-9 JF0210B5L JF0210B5M JF0210B5L YW02510005 BX YW02510005 BL YW02510005 BM YW02510005 BH YW02510005 BS KF0210B5L KF0210B5LD KF0210S5L KF0210B5M KF0210B5MD KF0210S5M KF0210B5H KF0210B5HD F25MM-012XK-9 YW02510012 BX YW02510012 BM YW02510012 BH JF0210B1M JF0210B1H KF0210B1L KF0210B1LD KF0210S1L KF0210B1M KF0210B1MD KF0210S1M KF0210B1H KF0210B1HD 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 12 12 12 12 12 12 12 12 12 12 12 12 12 12 B+S B B B B B B B B B B+S S B B+S S B B+S B+S B B B B B B B+S S B B+S S B B+S 8000 7000 10000 13000 6800 7700 8500 10000 12000 7000 7000 7000 10000 10000 10000 13000 13000 10000 6800 8500 10000 10000 13000 7000 7000 7000 10000 10000 10000 13000 13000 1.84 1.20 1.93 2.41 1.50 1.60 1.90 2.20 2.50 1.52 1.52 1.52 2.17 2.17 2.17 2.82 2.82 2.26 1.50 1.90 2.20 1.93 2.41 1.52 1.52 1.52 2.17 2.17 2.17 2.82 2.82 3.05 0.96 2.02 3.07 1.90 2.40 2.90 4.00 5.00 4.18 4.18 4.18 5.97 5.97 5.97 7.76 7.76 4.70 1.90 2.90 4.00 2.02 3.07 4.18 4.18 4.18 5.97 5.97 5.97 7.76 7.76 15.0 14.9 22.9 30.4 16.5 18.7 20.0 22.1 25.0 20.0 20.0 20.0 24.8 24.8 24.8 31.7 31.7 15.0 16.5 20.0 22.1 22.9 30.4 20.0 20.0 20.0 24.8 24.8 24.8 31.7 31.7 0.30 0.30 0.85 0.85 0.40 0.45 0.50 0.70 0.70 0.50 0.50 0.70 0.80 0.80 1.00 1.00 1.00 0.50 0.70 0.80 1.10 0.72 0.96 0.70 0.70 1.20 0.80 0.80 1.30 1.60 1.40 25 X 15 25 X 15 25 X 15 25 X 15 25 X 15 25 X 15 YW02515005BL YW02515005DL YW02515005BM YW02515005DM YW02515005BH YW02515005DH 5 5 5 5 5 5 B B+S B B+S B B+S 7500 7500 9000 9000 11000 11000 1.70 1.70 2.10 2.10 2.60 2.60 1.70 1.70 3.20 3.20 4.20 4.20 19.5 19.0 22.5 22.0 24.5 24.0 0.30 0.30 0.35 0.35 0.50 0.50 80000 50000 80000 50000 75000 50000 30 X 6 30 X 6 30 X 6 30 X 6 30 X 6 30 X 6 30 X 6 KF0306B5M KF0306S5M KF0306B5H KF0306S5H FMB3005AS KF0306S1M KF0306B1H 5 5 5 5 5 12 12 B+S S B+S S S S B+S 6000 6000 8000 8000 5000 6000 8000 2.32 2.32 3.09 3.09 1.67 2.32 3.09 2.15 2.15 2.87 2.87 1.47 2.15 2.87 21.0 21.0 25.8 25.8 12.0 21.0 25.8 0.60 0.60 1.00 1.00 0.25 1.20 1.20 40000 20000 30000 15000 30000 20000 30000 Radiatron Components Ltd, Egham, Surrey TW20 8RZ www.radiatron.com Tele: 0044 (0) 1784 439393 Fax: 0044 (0) 1784 477333 e-mail: sales@radiatron.com 30000 83000 58000 45000 80000 80000 80000 75000 75000 83000 55000 27000 58000 39000 19000 45000 30000 30000 80000 80000 75000 58000 45000 83000 55000 27000 58000 39000 19000 45000 30000 Approx. conv. factors:- l/min = CFM x 28.3 Inch/H20 = mm/H20 x 0.04 2 Pa = mm/H 0 x 0.10 2 of 15 21.03.2002 Radiatron Flat Fan Range Size (sq x thk) mm Radiatron Part V Bearing Type Speed (RPM) Airflow (CFM) Press. (mm/H2O) Noise (dBA) Power (Watts) MTTF (@25 DegC) 30 X 7 30 X 7 30 X 7 30 X 7 30 X 7 30 X 7 JF0307B5LD JF0307B5MD JF0307B5HD JF0307B1LD JF0307B1MD JF0307B1HD 5 5 5 12 12 12 B+S B+S B+S B+S B+S B+S 5500 7500 9500 5500 7500 9500 1.78 2.39 3.12 1.78 2.39 3.12 1.21 2.10 3.02 1.21 2.10 3.02 14.9 22.1 28.1 14.9 22.1 28.1 0.30 0.45 0.65 0.48 0.72 0.96 51000 38000 30000 51000 38000 30000 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 30 X 10 JF0310B5L JF0310B5M JF0310B5H YW03010005BX YW03010005BL YW03010005BM YW03010005BH KF0310B5L KF0310B5LD KF0310S5L KF0310B5M KF0310B5MD KF0310S5M KF0310B5H KF0310B5HD JF0310B1L JF0310B1M JF0310B1H FMA3012BS YW03010012BL YW03010012BM YW03010012BH KF0310B1L KF0310B1LD KF0310S1L KF0310B1M KF0310B1MD KF0310S1M KF0310B1H KF0310B1HD 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 B B B B B B B B B+S S B B+S S B B+S B B B S B B B B B+S S B B+S S B B+S 6500 8000 9500 4800 5800 6800 7800 5500 5500 5500 8000 8000 8000 9500 9500 6500 8000 9500 5000 5800 6800 7800 5500 5500 5500 8000 8000 8000 9500 9500 1.98 2.33 3.16 2.10 2.15 2.90 3.30 2.45 2.45 2.45 3.56 3.56 3.56 4.23 4.23 1.98 2.33 3.16 2.15 2.50 2.90 3.30 2.45 2.45 2.45 3.56 3.56 3.56 4.23 4.23 1.85 2.64 3.89 1.40 1.80 2.60 3.30 2.59 2.59 2.59 3.76 3.76 3.76 4.47 4.47 1.85 2.64 3.89 1.85 1.80 2.60 3.30 2.59 2.59 2.59 3.76 3.76 3.76 4.47 4.47 23.2 27.3 31.8 15.5 19.0 20.5 22.0 19.3 19.3 19.3 23.3 23.3 23.3 28.5 28.5 23.2 27.3 31.8 15.0 19.0 20.5 22.0 19.3 19.3 19.3 23.3 23.3 23.3 28.5 28.5 0.45 0.60 0.90 0.28 0.30 0.40 0.50 0.50 0.50 0.60 0.90 0.90 1.00 1.00 1.00 0.60 0.84 1.08 0.30 0.84 0.96 1.08 0.70 0.70 0.70 1.30 1.30 1.30 1.40 1.40 65000 53000 45000 80000 80000 80000 75000 77000 51000 25000 53000 35000 17000 45000 30000 65000 53000 45000 30000 80000 80000 75000 77000 51000 25000 53000 35000 17000 45000 30000 30 X 15 30 X 15 30 X 15 30 X 15 30 X 15 30 X 15 30 X 15 30 X 15 30 X 15 30 X 15 YW03015005BX YW03015005BL YW03015005DL YW03015005BM YW03015005DM YW03015005BH YW03015005DH YW03015005BS YW03015012BH YW03015012BS 5 5 5 5 5 5 5 5 12 12 B B B+S B B+S B B+S B B B 5000 6000 6000 7000 7000 8000 8000 10000 8000 10000 2.70 3.20 3.20 3.70 3.70 4.30 4.30 5.30 4.30 5.30 1.60 2.50 2.50 3.40 3.40 4.40 4.40 6.90 4.40 6.90 17.0 20.3 19.0 21.5 20.0 24.0 22.5 28.5 24.0 28.5 0.40 0.25 0.30 0.35 0.40 0.40 0.40 0.55 0.60 0.84 80000 80000 50000 80000 50000 80000 50000 75000 80000 75000 35 X 10 35 X 10 35 X 10 35 X 10 35 X 10 35 X 10 JF0B10B5L JF0B10B5M JF0B10B5H JF0B10B1L JF0B10B1M JF0B10B1H 5 5 5 12 12 12 B B B B B B 4500 6000 7000 4500 6000 7000 3.15 4.22 4.99 3.15 4.22 4.99 1.45 2.50 3.35 1.45 2.50 3.35 18.7 23.3 26.3 18.7 23.3 26.3 0.35 0.65 0.95 0.60 0.84 1.08 70000 52000 45000 70000 52000 45000 Radiatron Components Ltd, Egham, Surrey TW20 8RZ www.radiatron.com Tele: 0044 (0) 1784 439393 Fax: 0044 (0) 1784 477333 e-mail: sales@radiatron.com MTTF (@40 DegC) Approx. conv. factors:- l/min = CFM x 28.3 Inch/H20 = mm/H20 x 0.04 2 Pa = mm/H 0 x 0.10 3 of 15 21.03.2002 Radiatron Flat Fan Range MTTF (@25 DegC) Size (sq x thk) mm Radiatron Part V Bearing Type Speed (RPM) Airflow (CFM) Press. (mm/H2O) Noise (dBA) Power (Watts) 39 Dia X 12 39 Dia X 12 39 Dia X 12 39 Dia X 12 39 Dia X 12 39 Dia X 12 39 Dia X 12 39 Dia X 12 39 Dia X 12 39 Dia X 12 39 Dia X 12 39 Dia X 12 F39LM-005KK-9 F39LM-005XK-9 F39MM-005KK-9 F39MM-005XK-9 F39LM-012KK-9 F39LM-012XK-9 F39MM-012KK-9 F39MM-012XK-9 F39LM-024KK-9 F39LM-024XK-9 F39MM-024KK-9 F39MM-024XK-9 5 5 5 5 12 12 12 12 24 24 24 24 B B+S B B+S B B+S B B+S B B+S B B+S 4100 4100 5400 5400 4200 4200 5000 5000 4300 4300 5400 5400 3.36 3.36 4.95 4.95 3.53 3.53 4.42 4.42 3.71 3.71 4.95 4.95 1.84 1.84 3.26 3.26 1.94 1.94 2.65 2.65 2.04 2.04 3.26 3.26 13.0 13.0 20.0 20.0 14.0 14.0 18.0 18.0 15.0 15.0 20.0 20.0 0.44 0.44 0.57 0.57 0.50 0.50 0.76 0.76 0.74 0.74 0.86 0.86 40 X 6 40 X 6 40 X 6 40 X 6 40 X 6 KF0406B5MD KF0406S5M KF0406B1MD KF0406S1M KF0406B1HD 5 5 12 12 12 B+S S B+S S B+S 4000 4000 4000 4000 5000 4.50 4.50 4.50 4.50 5.62 1.10 1.10 1.10 1.10 1.38 22.3 22.3 22.3 22.3 23.6 0.70 0.70 1.30 1.30 1.40 37000 18000 37000 18000 30000 40 X 7 40 X 7 40 X 7 40 X 7 40 X 7 40 X 7 40 X 7 40 X 7 40 X 7 40 X 7 JF0407B5LD JF0407B5MD JF0407B5HD YW04007005SM YW04007005SH FMB4012AS JF0407B1LD JF0407B1HD JF0407B1MD YW04007012SH 5 5 5 5 5 12 12 12 12 12 B+S B+S B+S S S S B+S B+S B+S S 4000 4900 5700 5500 5700 4000 4000 5700 4900 5700 3.90 4.68 5.38 5.20 5.90 4.02 3.90 5.38 4.68 5.90 1.18 1.54 1.99 2.20 2.50 1.21 1.18 1.99 1.54 2.50 16.8 21.5 25.8 23.0 24.3 23.5 16.8 25.8 21.5 24.3 0.30 0.55 0.75 0.65 0.75 0.24 0.48 0.84 0.60 1.08 42000 34000 30000 30000 30000 30000 42000 30000 34000 30000 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 B+S S B+S S B+S B B+S S B B+S S B B+S B B+S S B B+S S B B+S 4200 4200 5400 5400 6000 4200 4200 4200 5400 5400 5400 6000 6000 4500 4500 5300 5500 5500 6300 6500 6500 4.45 4.45 5.72 5.72 6.36 4.48 4.48 4.48 5.76 5.76 5.76 6.40 6.40 4.50 4.50 5.30 5.50 5.50 6.30 6.60 6.60 2.55 2.55 3.28 3.28 3.65 2.32 2.32 2.32 2.98 2.98 2.98 3.31 3.31 2.00 2.00 2.90 3.10 3.10 4.00 4.10 4.10 21.6 21.6 27.2 27.2 29.9 21.2 21.2 21.2 25.8 25.8 25.8 26.6 26.6 22.0 21.5 25.0 26.0 25.5 30.0 31.0 30.5 0.70 0.70 0.80 0.80 0.90 0.40 0.40 0.60 0.50 0.60 0.80 0.80 0.90 0.45 0.45 0.65 0.65 0.65 0.85 0.85 0.85 42000 28000 33000 22000 30000 71000 42000 28000 55000 33000 22000 50000 30000 80000 50000 30000 80000 50000 30000 75000 50000 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 KF0409B5LD KF0409S5L KF0409B5MD KF0409S5M KF0409B5HD KF0410B5L KF0410B5LD KF0410S5L KF0410B5M KF0410B5MD KF0410S5M KF0410B5H KF0410B5HD YW04010005BL YW04010005DL YW04010005SM YW04010005BM YW04010005DM YW04010005SH YW04010005BH YW04010005DH Radiatron Components Ltd, Egham, Surrey TW20 8RZ www.radiatron.com Tele: 0044 (0) 1784 439393 Fax: 0044 (0) 1784 477333 e-mail: sales@radiatron.com MTTF (@40 DegC) 40000 40000 40000 40000 40000 40000 Approx. conv. factors:- l/min = CFM x 28.3 Inch/H20 = mm/H20 x 0.04 2 Pa = mm/H 0 x 0.10 4 of 15 21.03.2002 Radiatron Flat Fan Range MTTF (@25 DegC) Size (sq x thk) mm Radiatron Part V Bearing Type Speed (RPM) Airflow (CFM) Press. (mm/H2O) Noise (dBA) Power (Watts) 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 40 X 10 F40MM-012GK-9 KF0409B1LD KF0409S1L KF0409B1MD KF0409S1M KF0409B1HD KF0410B1L KF0410B1LD KF0410S1L KF0410B1M KF0410B1MD KF0410S1M KF0410B1H KF0410B1HD YW04010012BL YW04010012DL YW04010012SL YW04010012BM YW04010012DM YW04010012SM YW04010012BH YW04010012DH YW04010012SH F40MM-024GK-9 YW04010024BM YW04010024BH YW04010024DH YW04010024SH 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 24 24 24 24 24 S B+S S B+S S B+S B B+S S B B+S S B B+S B B+S S B B+S S B B+S S S B B B+S S 5500 4200 4200 5400 5400 6000 4200 4200 4200 5400 5400 5400 6000 6000 4500 4500 4300 5500 5500 5300 6500 6500 6300 5500 5500 6500 6500 6300 5.30 4.45 4.45 5.72 5.72 6.36 4.48 4.48 4.48 5.76 5.76 5.76 6.40 6.40 4.50 4.50 4.50 5.50 5.50 5.30 6.60 6.60 6.30 5.30 5.50 6.60 6.60 6.30 2.55 2.55 2.55 3.28 3.28 3.65 2.32 2.32 2.32 2.98 2.98 2.98 3.31 3.31 2.00 2.00 1.80 3.10 3.10 2.90 4.30 4.30 4.00 2.55 3.10 4.30 4.30 4.00 18.0 21.6 21.6 27.2 27.2 29.9 21.2 21.2 21.2 25.8 25.8 25.8 26.6 26.6 21.0 20.5 20.0 26.0 25.5 25.0 31.0 30.5 30.0 18.0 26.0 31.0 30.5 30.0 0.80 1.20 1.20 1.30 1.30 1.40 0.60 0.60 0.70 0.70 0.70 0.80 0.80 1.10 0.72 0.72 0.72 0.96 0.96 0.96 1.08 1.08 1.08 42000 28000 33000 22000 30000 71000 42000 28000 55000 33000 22000 50000 30000 80000 50000 30000 80000 50000 30000 75000 50000 30000 1.44 1.68 1.68 1.68 80000 75000 50000 30000 40 X 15 40 X 15 40 X 15 YW04015012BL YW04015012BM YW04015012BH 12 12 12 B B B 6000 7400 8600 6.00 7.50 9.50 3.80 5.00 8.30 26.6 32.0 36.5 1.32 1.56 1.80 80000 80000 75000 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 YW04020005SL YW04020005BL YW04020005SM YW04020005BM YW04020005SH YW04020005BH JF0420B5L JF0420B5LD JF0420S5L JF0420B5M JF0420B5MD JF0420S5M JF0420B5H JF0420B5HD JF0420S5H FMA4012DS YW04020012SL YW04020012BL YW04020012SM YW04020012BM YW04020012SH YW04020012BH YW04020012BS YW04020012BSS 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 12 12 12 12 12 12 12 12 12 S B S B S B B B+S S B B+S S B B+S S S S B S B S B B B 3600 4000 4600 5000 6000 6000 6000 6000 6000 7000 7000 7000 8000 8000 8000 8900 3600 4000 4600 5000 5600 6000 7600 9500 4.40 4.70 5.70 6.00 6.90 7.50 7.50 7.50 7.50 8.60 8.60 8.60 10.10 10.10 10.10 10.69 4.40 4.70 5.70 6.00 6.90 7.50 9.50 11.00 1.20 1.70 2.60 3.00 4.60 4.30 5.50 5.50 5.50 6.80 6.80 6.80 9.40 9.40 9.40 10.28 1.30 1.70 2.60 3.00 3.90 4.30 7.60 13.21 16.1 17.0 22.4 23.4 31.0 28.0 25.0 25.0 25.0 28.5 28.5 28.5 32.0 32.0 32.0 35.0 16.0 17.0 22.4 23.4 27.0 28.0 37.0 41.9 0.55 0.55 0.80 0.80 0.90 1.10 0.40 0.40 0.40 0.80 0.80 0.80 1.50 1.50 1.50 2.04 0.72 0.72 1.08 1.08 1.56 1.56 1.44 3.00 30000 80000 30000 80000 30000 75000 66000 40000 26000 57000 34000 22000 50000 30000 20000 30000 30000 80000 30000 80000 30000 75000 75000 60000 Radiatron Components Ltd, Egham, Surrey TW20 8RZ www.radiatron.com Tele: 0044 (0) 1784 439393 Fax: 0044 (0) 1784 477333 e-mail: sales@radiatron.com MTTF (@40 DegC) 40000 40000 Approx. conv. factors:- l/min = CFM x 28.3 Inch/H20 = mm/H20 x 0.04 2 Pa = mm/H 0 x 0.10 5 of 15 21.03.2002 Radiatron Flat Fan Range Size (sq x thk) mm Radiatron Part V Bearing Type Speed (RPM) Airflow (CFM) Press. (mm/H2O) Noise (dBA) Power (Watts) MTTF (@25 DegC) 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 40 X 20 JF0420B1L JF0420B1LD JF0420S1L JF0420B1M JF0420B1MD JF0420S1M JF0420B1H JF0420B1HD JF0420S1H YW04020024BM YW04020024SH YW04020024BH YW04020024BS JKF0420B2L JKF0420B2LD JF0420S2L JF0420B2M JF0420B2MD JF0420S2M JF0420B2H JF0420B2HD JKF0420S2H 12 12 12 12 12 12 12 12 12 24 24 24 24 24 24 24 24 24 24 24 24 24 B B+S S B B+S S B B+S S B S B B B B+S S B B+S S B B+S S 6000 6000 6000 7000 7000 7000 8000 8000 8000 5000 5600 6000 7500 6000 6000 6000 7000 7000 7000 8000 8000 8000 7.50 7.50 7.50 8.60 8.60 8.60 10.10 10.10 10.10 6.00 6.90 7.50 9.30 7.50 7.50 7.50 8.60 8.60 8.60 10.10 10.10 10.10 5.50 5.50 5.50 6.80 6.80 6.80 9.40 9.40 9.40 3.00 3.90 4.30 6.50 5.50 5.50 5.50 6.80 6.80 6.80 9.40 9.40 9.40 25.0 25.0 25.0 28.5 28.5 28.5 32.0 32.0 32.0 23.4 27.0 28.0 34.0 25.0 25.0 25.0 28.5 28.5 28.5 32.0 32.0 32.0 0.84 0.84 0.84 0.96 0.96 0.96 1.32 1.32 1.32 1.20 1.44 1.44 2.88 1.44 1.44 1.44 1.68 1.68 1.68 2.16 2.16 2.16 66000 40000 26000 57000 34000 22000 50000 30000 20000 80000 30000 75000 75000 66000 40000 26000 57000 34000 22000 50000 30000 20000 40 X 28 40 X 28 40 X 28 YW04028012BM-6 YW04028012BH-6 YW04028012BSS-6 12 12 12 B B B 8500 10000 11500 11.30 13.40 15.20 10.60 14.70 19.20 35.0 42.0 44.0 1.56 2.40 3.12 160000 160000 160000 41 X 12 41 X 12 41 X 12 41 X 12 41 X 12 41 X 12 41 X 12 41 X 12 41 X 12 41 X 12 41 X 12 41 X 12 F41LM-005KK-9 F41LM-005XK-9 F41MM-005KK-9 F41MM-005XK-9 F41LM-012KK-9 F41LM-012XK-9 F41MM-012KK-9 F41MM-012XK-9 F41LM-024KK-9 F41LM-024XK-9 F41MM-024KK-9 F41MM-024XK-9 5 5 5 5 12 12 12 12 24 24 24 24 B B+S B B+S B B+S B B+S B B+S B B+S 4100 4100 5400 5400 4200 4200 5000 5000 4300 4300 5400 5400 3.36 3.36 4.95 4.95 3.53 3.53 4.42 4.42 3.71 3.71 4.95 4.95 1.84 1.84 3.26 3.26 1.94 1.94 2.65 2.65 2.04 2.04 3.26 3.26 13.0 13.0 20.0 20.0 14.0 14.0 18.0 18.0 15.0 15.0 20.0 20.0 0.45 0.45 0.57 0.57 0.50 0.50 0.76 0.76 0.74 0.74 0.86 0.86 45 X 10 45 X 10 45 X 10 45 X 10 45 X 10 45 X 10 45 X 10 45 X 10 45 X 10 45 X 10 45 X 10 45 X 10 YW04510005BM YW04510005DM YW04510005BH YW04510012SX YW04510012SL YW04510012BL YW04510012DL YW04510012SM YW04510012BM YW04510012DM YW04510012BH YW04510012DH 5 5 5 12 12 12 12 12 12 12 12 12 B B+S B S S B B+S S B B+S B B+S 5500 5500 6300 4000 4900 5100 5100 5300 5500 5500 6500 6500 8.70 8.70 10.60 6.50 7.80 8.10 8.10 8.50 8.70 8.70 10.30 10.30 3.40 3.40 3.70 1.70 2.70 2.90 2.90 3.30 3.40 3.40 4.80 4.80 32.0 31.5 35.5 23.6 28.3 29.4 29.4 31.0 32.0 31.5 37.1 36.6 0.85 0.85 1.20 0.72 1.08 1.08 1.08 1.44 1.44 1.44 1.68 1.70 80000 50000 75000 30000 30000 80000 50000 30000 80000 50000 75000 50000 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 KF0510B5L KF0510B5LD KF0510S5L KF0510B5M KF0510B5MD KF0510S5M KF0510B5H KF0510B5HD 5 5 5 5 5 5 5 5 B B+S S B B+S S B B+S 3500 3500 3500 4500 4500 4500 5300 5300 7.30 7.30 7.30 9.38 9.38 9.38 11.00 11.00 1.77 1.77 1.77 2.27 2.27 2.27 2.67 2.67 20.9 20.9 20.9 26.1 26.1 26.1 30.2 30.2 0.60 0.60 0.70 0.90 0.90 1.10 1.10 1.10 75000 45000 30000 58000 35000 23000 50000 30000 Radiatron Components Ltd, Egham, Surrey TW20 8RZ www.radiatron.com Tele: 0044 (0) 1784 439393 Fax: 0044 (0) 1784 477333 e-mail: sales@radiatron.com MTTF (@40 DegC) 40000 40000 40000 40000 40000 40000 Approx. conv. factors:- l/min = CFM x 28.3 Inch/H20 = mm/H20 x 0.04 2 Pa = mm/H 0 x 0.10 6 of 15 21.03.2002 Radiatron Flat Fan Range Size (sq x thk) mm Radiatron Part V Bearing Type Speed (RPM) Airflow (CFM) Press. (mm/H2O) Noise (dBA) Power (Watts) MTTF (@25 DegC) 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 50 X 10 KF0509B5L KF0509B5LD KF0509S5L KF0509B5M KF0509B5MD KF0509S5M KF0509B5H KF0509B5HD YW05010005BM YW05010005DM YW05010005SM YW05010005SH YW05010005BH YW05010005DH FMB5012BS KF0510B1L KF0510B1LD KF0510S1L KF0510B1M KF0510B1MD KF0510S1M KF0510B1H KF0510B1HD KF0509B1L KF0509B1LD KF0509S1L KF0509B1M KF0509B1MD KF0509S1M KF0509B1H KF0509B1HD YW05010012BX YW05010012DX YW05010012BL YW05010012DL YW05010012SL YW05010012SM YW05010012BM YW05010012DM YW05010012DH YW05010012SH YW05010012BH 5 5 5 5 5 5 5 5 5 5 5 5 5 5 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 B B+S S B B+S S B B+S B B+S S S B B+S S B B+S S B B+S S B B+S B B+S S B B+S S B B+S B B+S B B+S S S B B+S B+S S B 3500 3500 3500 4500 4500 4500 5300 5300 4600 4600 4600 5000 5200 5200 4000 3500 3500 3500 4500 4500 4500 5300 5300 3500 3500 3500 4500 4500 4500 5300 5300 3000 3000 4000 4000 3800 4400 4600 4600 4800 5000 5200 7.77 7.77 7.77 10.00 10.00 10.00 11.77 11.77 10.70 10.70 10.70 11.60 12.50 12.60 6.36 7.30 7.30 7.30 9.38 9.38 9.38 11.00 11.00 7.77 7.77 7.77 10.00 10.00 10.00 11.77 11.77 7.40 7.40 9.40 9.40 9.40 10.00 10.70 10.70 11.30 11.60 12.50 2.00 2.00 2.00 2.58 2.58 2.58 3.04 3.04 2.60 2.60 2.60 3.10 3.30 3.30 1.77 1.77 1.77 1.77 2.27 2.27 2.27 2.67 2.67 2.00 2.00 2.00 2.58 2.58 2.58 3.04 3.04 1.30 1.30 2.10 2.10 2.10 2.30 2.60 2.60 2.50 3.10 3.30 25.3 25.3 25.3 31.3 31.3 31.3 35.3 35.3 31.0 29.0 29.0 31.0 33.0 33.0 24.0 20.9 20.9 20.9 26.1 26.1 26.1 30.2 30.2 25.3 25.3 25.3 31.3 31.3 31.3 35.3 35.3 22.5 22.5 28.5 27.1 26.5 27.7 31.0 29.0 28.0 30.0 34.0 0.80 0.80 0.80 1.10 1.10 1.10 1.20 1.20 0.85 0.85 0.85 1.20 1.20 1.20 0.84 0.70 0.80 0.80 0.80 1.00 1.00 1.60 1.60 1.20 1.20 1.20 1.60 1.60 1.60 1.80 1.80 0.72 0.72 1.08 1.08 1.08 1.44 1.44 1.44 2.88 2.88 2.88 75000 45000 30000 58000 35000 23000 50000 30000 80000 50000 30000 30000 75000 50000 30000 75000 45000 30000 58000 35000 23000 50000 30000 75000 45000 30000 58000 35000 23000 50000 30000 80000 50000 80000 50000 30000 30000 80000 50000 50000 30000 80000 50 X 15 50 X 15 50 X 15 50 X 15 50 X 15 50 X 15 50 X 15 50 X 15 50 X 15 50 X 15 50 X 15 50 X 15 50 X 15 50 X 15 50 X 15 KF0515B5L KF0515B5LD KF0515B5M KF0515B5MD YW05015005DL YW05015005BM YW05015005DM YW05015005BH YW05015005DH KF0515B1L KF0515B1LD KF0515B1M KF0515B1MD KF0515B1H KF0515B1HD 5 5 5 5 5 5 5 5 5 12 12 12 12 12 12 B B+S B B+S B+S B B+S B B+S B B+S B B+S B B+S 3800 3800 4500 4500 3800 4500 4500 5000 5000 3800 3800 4500 4500 5000 5000 11.00 11.00 13.10 13.10 11.50 13.10 13.10 14.70 14.70 11.00 11.00 13.10 13.10 14.70 14.70 2.30 2.30 3.20 3.20 2.40 3.20 3.20 4.00 4.00 2.30 2.30 3.20 3.20 3.40 3.40 27.0 27.0 29.5 29.5 26.5 29.5 29.0 31.5 31.0 27.0 27.0 29.5 29.5 31.5 31.5 1.00 1.00 1.50 1.50 1.00 1.25 1.25 1.40 1.40 1.20 1.20 1.60 1.60 2.00 2.00 65000 39000 55000 33000 50000 80000 50000 75000 50000 65000 39000 55000 33000 50000 30000 Radiatron Components Ltd, Egham, Surrey TW20 8RZ www.radiatron.com Tele: 0044 (0) 1784 439393 Fax: 0044 (0) 1784 477333 e-mail: sales@radiatron.com MTTF (@40 DegC) Approx. conv. factors:- l/min = CFM x 28.3 Inch/H20 = mm/H20 x 0.04 2 Pa = mm/H 0 x 0.10 7 of 15 21.03.2002 Radiatron Flat Fan Range Size (sq x thk) mm Radiatron Part V Bearing Type Speed (RPM) Airflow (CFM) Press. (mm/H2O) Noise (dBA) Power (Watts) MTTF (@25 DegC) 50 X 15 50 X 15 50 X 15 50 X 15 50 X 15 50 X 15 50 X 15 50 X 15 50 X 15 50 X 15 50 X 15 50 X 15 YW05015012SL YW05015012BL YW05015012DL YW05015012SM YW05015012BM YW05015012DM YW05015012SH YW05015012BH YW05015012DH YW05015012SS YW05015012BS YW05015012DS 12 12 12 12 12 12 12 12 12 12 12 12 S B B+S S B B+S S B B+S S B B+S 3600 3800 3800 4300 4500 4500 4800 5000 5000 5300 5500 5500 10.50 11.00 11.00 12.50 13.10 13.10 14.00 14.70 14.70 15.70 17.10 17.10 2.10 2.30 2.30 3.00 3.20 3.20 3.70 4.00 4.00 4.30 4.40 4.40 25.5 27.0 26.5 28.0 29.5 29.0 30.0 31.5 31.0 35.7 35.5 33.0 1.20 1.20 1.20 1.56 1.56 1.56 2.04 2.04 2.04 2.88 2.88 2.88 30000 80000 50000 30000 80000 50000 30000 75000 50000 30000 75000 50000 50 X 20 50 X 20 50 X 20 50 X 20 50 X 20 50 X 20 YW05020012SL YW05020012BL YW05020012SM YW05020012BM YW05020012SH YW05020012BH 12 12 12 12 12 12 S B S B S B 3500 3800 4400 4700 5300 5600 8.80 9.60 11.20 11.60 13.20 14.00 2.50 2.90 3.40 4.10 4.70 5.50 21.4 23.1 27.2 27.7 30.6 32.1 0.96 0.96 1.20 1.20 1.44 1.44 30000 80000 30000 80000 30000 75000 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 60 X 10 KF0610B5M KF0610B5MD YW06010005BL YW06010005SM YW06010005BM YW06010005DM YW06010005BH FMB6012CS KF0610B1L KF0610B1LD KF0610B1M KF0610B1MD KF0610B1H KF0610B1HD YW06010012SL YW06010012BL YW06010012DL YW06010012SM YW06010012BM YW06010012DM YW06010012SH YW06010012BH YW06010012DH YW06010012BLN YW06010012BMN YW06010012BHN 5 5 5 5 5 5 5 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 B B+S B S B B+S B S B B+S B B+S B B+S S B B+S S B B+S S B B+S B B B 4200 4200 14.00 14.00 2.00 2.00 29.5 29.5 1.00 1.00 55000 44000 4000 4200 4200 4700 3900 3800 3800 4200 4200 4700 4700 3600 3800 3800 4000 4200 4200 4500 4700 4700 3500 4100 5000 14.50 14.60 14.60 16.50 13.48 13.30 13.30 14.50 14.50 16.50 16.50 12.60 13.30 13.30 13.80 14.60 14.60 15.70 16.50 16.50 18.40 20.60 25.10 1.90 2.00 2.00 2.40 1.98 1.70 1.70 2.00 2.00 2.40 2.40 1.50 1.70 1.70 1.80 2.00 2.00 2.30 2.40 2.40 2.15 2.80 4.10 29.0 30.0 29.5 35.0 28.0 27.0 26.5 29.4 29.4 31.5 31.5 26.0 27.0 26.5 29.0 30.0 29.5 34.5 35.5 35.0 33.0 37.1 41.5 1.00 0.85 0.85 1.15 1.44 1.10 1.10 1.40 1.40 1.70 1.70 1.08 1.08 1.08 1.44 1.44 1.44 1.68 1.68 1.68 1.44 2.80 4.10 30000 80000 50000 75000 30000 61000 37000 55000 33000 50000 30000 30000 80000 50000 30000 80000 50000 30000 75000 50000 80000 80000 80000 60 X 15 60 X 15 60 X 15 60 X 15 60 X 15 60 X 15 60 X 15 60 X 15 60 X 15 60 X 15 60 X 15 60 X 15 60 X 15 60 X 15 FMB6012BS JF0615B1L JF0615S1L JF0615B1M JF0615S1M JF0615B1H JF0615S1H YW06015012BL YW06015012SM YW06015012BM YW06015012SH YW06015012BH YW06015012BHN YW06015012BS 12 12 12 12 12 12 12 12 12 12 12 12 12 12 S B S B S B S B S B S B B B 3600 3500 3500 4000 4000 4500 4500 3600 3700 4200 3700 4800 4000 4700 14.8 11.63 11.63 13.28 13.28 15.74 15.74 14.80 15.10 16.90 19.20 19.40 21.00 24.10 2.9 3.26 3.26 4.12 4.12 5.41 5.41 2.90 1.90 3.40 3.10 3.90 3.00 3.90 26 25.1 25.1 30.1 30.1 34.0 34.0 26.0 26.3 30.5 32.1 37.0 32.0 36.0 1.44 1.44 1.44 1.80 1.80 2.04 2.04 1.44 1.80 1.92 2.76 2.64 1.68 2.64 30000 64000 38000 56000 33000 50000 30000 80000 30000 80000 30000 80000 80000 80000 Radiatron Components Ltd, Egham, Surrey TW20 8RZ www.radiatron.com Tele: 0044 (0) 1784 439393 Fax: 0044 (0) 1784 477333 e-mail: sales@radiatron.com MTTF (@40 DegC) Approx. conv. factors:- l/min = CFM x 28.3 Inch/H20 = mm/H20 x 0.04 2 Pa = mm/H 0 x 0.10 8 of 15 21.03.2002 Radiatron Flat Fan Range Size (sq x thk) mm Radiatron Part V Bearing Type Speed (RPM) Airflow (CFM) Press. (mm/H2O) Noise (dBA) Power (Watts) MTTF (@25 DegC) 60 X 15 60 X 15 60 X 15 60 X 15 60 X 15 60 X 15 JF0615B2L JF0615S2L JF0615B2M JF0615S2M JF0615B2H JF0615S2H 24 24 24 24 24 24 B S B S B S 3500 3500 4000 4000 4500 4500 11.63 11.63 13.28 13.28 15.74 15.74 3.26 3.26 4.12 4.12 5.41 5.41 25.1 25.1 30.1 30.1 34.0 34.0 2.16 2.16 2.64 2.64 3.12 3.12 64000 38000 56000 33000 50000 30000 60 X 20 60 X 20 60 X 20 60 X 20 60 X 20 60 X 20 60 X 20 60 X 20 60 X 20 60 X 20 60 X 20 60 X 20 60 X 20 60 X 20 60 X 20 60 X 20 60 X 20 60 X 20 JF0620B1L JF0620S1L JF0620B1M JF0620S1M JF0620B1H JF0620S1H YW06020012SL YW06020012BL YW06020012SM YW06020012BM YW06020012SH YW06020012BH JF0620B2L JF0620S2L JF0620B2M JF0620S2M JF0620B2H JF0620S2H 12 12 12 12 12 12 12 12 12 12 12 12 24 24 24 24 24 24 B S B S B S S B S B S B B S B S B S 3500 3500 4000 4000 4500 4500 2600 2900 3100 3400 3900 4200 3500 3500 4000 4000 4500 4500 12.90 12.90 14.45 14.45 15.90 15.90 15.20 16.50 18.90 19.00 22.20 22.90 12.90 12.90 14.45 14.45 15.90 15.90 3.48 3.48 4.35 4.35 4.86 4.86 2.40 2.70 3.60 3.70 4.50 5.00 3.48 3.48 4.35 4.35 4.86 4.86 22.5 22.5 26.8 26.8 30.4 30.4 25.2 26.0 30.6 31.2 35.4 36.1 22.5 22.5 26.8 26.8 30.4 30.4 1.56 1.56 1.80 1.80 2.04 2.04 1.44 1.44 1.80 1.80 2.28 2.28 2.16 2.16 2.64 2.64 3.12 3.12 64000 38000 56000 33000 50000 30000 30000 80000 30000 80000 30000 75000 64000 38000 56000 33000 50000 30000 60 X 23 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 X 25 60 x 25 FMA6012BB JF0625B1L JF0625S1L JF0625B1M JF0625S1M JF0625B1H JF0625S1H YW06025012SL YW06025012BL YW06025012SM YW06025012BM YW06025012SH YW06025012BH YW06025012BHN YW06025012BSN YW06025012BS YW06025012BSS-6 JF0625B2L JF0625S2L JF0625B2M JF0625S2M JF0625B2H JF0625S2H YW06025024SL YW06025024BL YW06025024SM YW06025024BM YW06025024SH YW06025024BH YW06025024BSS-6 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 24 24 24 24 24 24 24 24 24 24 24 24 24 B B S B S B S S B S B S B B B B B B S B S B S S B S B S B B 5300 3500 3500 4000 4000 4500 4500 2400 2600 3100 3200 4100 4200 4500 5200 5000 6800 3500 3500 4000 4000 4500 4500 2400 2600 3100 3200 4100 4200 6200 24.00 15.28 15.28 17.60 17.60 20.52 20.52 15.50 16.00 19.50 20.00 25.50 26.00 24.40 29.30 31.70 40.10 15.28 15.28 17.60 17.60 20.52 20.52 15.50 16.00 18.50 20.00 25.30 26.00 37.20 8.22 3.53 3.53 4.38 4.38 5.86 5.86 1.70 1.80 2.80 2.90 4.70 5.00 5.60 6.30 6.00 14.20 3.53 3.53 4.38 4.38 5.86 5.86 1.70 1.90 2.80 2.90 4.20 5.00 9.10 37.0 27.4 27.4 31.5 31.5 33.6 33.6 22.4 23.6 27.0 28.0 33.0 36.0 34.5 40.4 41.4 48.0 27.4 27.4 31.5 31.5 33.6 33.6 22.5 23.5 26.9 28.0 35.2 36.0 46.7 2.88 2.04 2.04 2.40 2.40 2.76 2.76 0.96 0.96 1.44 1.44 2.16 2.16 2.16 2.76 3.00 7.20 2.88 2.88 3.12 3.12 4.08 4.08 1.68 1.20 1.92 1.68 2.16 2.88 9.60 50000 64000 38000 56000 33000 50000 30000 30000 80000 30000 80000 30000 75000 80000 80000 80000 80000 64000 38000 56000 33000 50000 30000 30000 80000 30000 80000 30000 75000 75000 Radiatron Components Ltd, Egham, Surrey TW20 8RZ www.radiatron.com Tele: 0044 (0) 1784 439393 Fax: 0044 (0) 1784 477333 e-mail: sales@radiatron.com MTTF (@40 DegC) Approx. conv. factors:- l/min = CFM x 28.3 Inch/H20 = mm/H20 x 0.04 2 Pa = mm/H 0 x 0.10 9 of 15 21.03.2002 Radiatron Flat Fan Range MTTF (@25 DegC) Size (sq x thk) mm Radiatron Part V Bearing Type Speed (RPM) Airflow (CFM) Press. (mm/H2O) Noise (dBA) Power (Watts) 62 X 15 62 X 15 62 X 15 62 X 15 62 X 15 62 X 15 F62LM-005GK-9 F62MM-005GK-9 F62LM-012GK-9 F62MM-012GK-9 F62LM-024GK-9 F62MM-024GK-9 5 5 12 12 24 24 S S S S S S 2800 3450 2800 3450 2900 3450 10.25 12.72 10.25 12.72 10.60 12.72 2.14 2.96 2.14 2.96 2.35 2.96 22.0 28.0 20.0 27.0 20.0 27.0 0.37 0.84 0.50 0.74 0.74 0.98 70 X 10 YW07010012BM 12 B 4300 23.20 2.70 36.0 2.64 80000 70 X 15 YW07015012BM 12 B 4500 30.60 4.10 37.0 2.28 80000 80 X 16 80 X 16 80 X 16 FMA8005AB FMA8012AS FMA8012BS 5 12 12 B S S 2100 2100 2500 21.20 21.20 25.23 1.88 1.88 2.23 29.0 29.0 31.5 1.25 1.08 1.44 50000 30000 30000 80 X 18 80 X 18 80 X 18 80 X 18 80 X 18 80 X 18 80 X 18 80 X 18 80 X 18 F70EM-005CK-0 F75EM-005CK-0 F80EM-005CK-0 F70EM-012CK-0 F75EM-012CK-0 F80EM-012CK-0 F70EM-024CK-0 F75EM-024CK-0 F80EM-024CK-0 5 5 5 12 12 12 24 24 24 S S S S S S S S S 2000 2600 3325 2050 2600 3400 2050 2600 3500 14.14 17.31 22.26 14.50 17.31 21.73 13.78 17.31 23.32 1.24 1.86 2.78 1.35 1.86 2.75 1.20 1.89 3.32 26.0 32.0 39.0 27.0 33.0 39.0 26.0 32.0 41.0 1.32 1.32 2.67 1.42 1.42 3.04 2.16 2.16 3.41 80 X 20 80 X 20 80 X 20 80 X 20 80 X 20 80 X 20 80 X 20 80 X 20 YW08020012BL YW08020012SL YW08020012SM YW08020012BM YW08020012SH YW08020012BH YW08020024SH YW08020024BH 12 12 12 12 12 12 24 24 B S S B S B S B 2100 2000 2400 2600 2900 3100 2900 3100 22.00 22.70 27.00 32.00 32.70 38.00 32.70 38.00 1.50 2.20 2.10 2.70 3.10 3.80 3.10 3.80 24.0 23.0 27.0 27.7 33.5 34.2 33.5 34.2 1.20 1.20 1.32 1.32 1.80 1.80 2.40 2.40 80000 30000 30000 80000 30000 80000 30000 80000 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 JF0825B1L JF0825S1L JF0825B1M JF0825S1M JF0825B1H JF0825S1H JF0825B1LN JF0825S1LN JF0825B1MN JF0825S1MN JF0825B1HN JF0825S1HN FMA8012DS YW08025012BX YW08025012SL YW08025012BL YW08025012SM YW08025012BM YW08025012SH YW08025012BH YW08025012BS 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 B S B S B S B S B S B S S B S B S B S B B 2000 2000 2500 2500 3000 3000 2000 2000 2500 2500 3000 3000 3600 1850 1900 2000 2400 2500 2900 3000 3300 25.07 25.07 31.73 31.73 39.20 39.20 27.86 27.86 33.69 33.69 40.96 40.96 44.13 27.00 27.00 30.00 35.00 38.30 43.70 45.20 47.00 1.53 1.53 2.54 2.54 3.56 3.56 1.83 1.83 2.63 2.63 3.90 3.90 4.00 1.30 1.50 1.60 2.50 2.60 3.50 3.60 3.90 22.9 22.9 29.3 29.3 33.2 33.2 21.8 21.8 27.1 27.1 33.6 33.6 37.0 22.0 22.5 23.2 27.4 28.7 33.5 34.2 36.9 1.20 1.20 1.80 1.80 2.28 2.28 1.20 1.20 1.80 1.80 2.28 2.28 3.60 0.96 1.20 1.20 1.92 1.92 2.76 2.76 3.12 75000 45000 60000 36000 50000 30000 75000 45000 60000 36000 50000 30000 30000 80000 30000 80000 30000 80000 30000 75000 75000 Radiatron Components Ltd, Egham, Surrey TW20 8RZ www.radiatron.com Tele: 0044 (0) 1784 439393 Fax: 0044 (0) 1784 477333 e-mail: sales@radiatron.com MTTF (@40 DegC) 40000 40000 40000 40000 40000 40000 40000 40000 40000 40000 40000 40000 40000 40000 40000 Approx. conv. factors:- l/min = CFM x 28.3 Inch/H20 = mm/H20 x 0.04 2 Pa = mm/H 0 x 0.10 10 of 15 21.03.2002 Radiatron Flat Fan Range Size (sq x thk) mm Radiatron Part V Bearing Type Speed (RPM) Airflow (CFM) Press. (mm/H2O) Noise (dBA) Power (Watts) MTTF (@25 DegC) 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 JF0825B2L JF0825S2L JF0825B2M JF0825S2M JF0825B2H JF0825S2H JF0825B2LN JF0825S2LN JF0825B2MN JF0825S2MN JF0825B2HN JF0825S2HN YW08025024SL YW08025024SM YW08025024BM YW08025024SH YW08025024BH YW08025024BS 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 B S B S B S B S B S B S S S B S B B 2000 2000 2500 2500 3000 3000 2000 2000 2500 2500 3000 3000 1900 2400 2500 2900 3000 3300 25.07 25.07 31.73 31.73 39.20 39.20 27.86 27.86 33.69 33.69 40.96 40.96 27.00 35.00 38.30 43.70 45.20 47.00 1.53 1.53 2.54 2.54 3.56 3.56 1.83 1.83 2.63 2.63 3.90 3.90 1.50 2.50 2.60 3.50 3.60 3.90 22.9 22.9 29.3 29.3 33.2 33.2 21.8 21.8 27.1 27.1 33.6 33.6 22.5 27.9 28.7 34.4 34.2 36.0 2.40 2.40 3.12 3.12 3.60 3.60 2.40 2.40 3.12 3.12 3.60 3.60 1.44 1.92 1.92 3.60 3.12 3.60 75000 45000 60000 36000 50000 30000 75000 45000 60000 36000 50000 30000 30000 30000 80000 30000 75000 75000 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 YW08025048BL YW08025048SM YW08025048BM YW08025048SH YW08025048BH 48 48 48 48 48 B S B S B 2000 2400 2500 2900 3000 30.00 35.00 38.30 43.70 45.20 1.60 2.50 2.60 3.50 3.60 23.2 27.9 28.7 33.5 34.2 1.92 2.88 2.88 4.32 4.32 80000 30000 80000 30000 75000 80 X 32 80 X 32 80 X 32 80 X 32 80 X 32 80 X 32 80 X 32 80 X 32 80 X 32 80 X 32 YW08032012BM YW08032012BH YW08032012BS YW08032024BL YW08032024BM YW08032024BH YW08032024BS YW08032048BM YW08032048BH YW08032048BS 12 12 12 24 24 24 24 48 48 48 B B B B B B B B B B 3400 4400 5400 2400 3400 4400 5400 3400 4400 5400 37.00 46.90 56.00 27.10 37.00 46.90 49.20 39.60 44.90 49.20 6.60 9.80 13.80 3.30 6.60 10.30 13.80 6.60 10.90 14.90 39.6 44.9 49.0 34.8 39.6 44.9 49.2 39.6 44.9 49.2 2.76 4.44 7.56 1.80 3.36 4.80 7.92 5.28 8.16 12.96 80000 80000 80000 80000 80000 80000 80000 80000 80000 80000 92 X 20 92 X 20 92 X 20 92 X 20 CW09220012BX CW09220012BL CW09220012BM CW09220012BH 12 12 12 12 B B B B 2100 2500 3000 3600 31.80 38.10 47.60 54.50 1.18 2.60 3.48 4.20 24.0 28.0 32.0 38.0 1.44 1.92 3.12 3.84 80000 80000 80000 80000 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 JF0925B1L JF0925S1L JF0925B1M JF0925S1M JF0925B1H JF0925S1H YW09225012BX YW09225012SL YW09225012BL YW09225012SM YW09225012BM YW09225012SH YW09225012BH YW09225012BS 12 12 12 12 12 12 12 12 12 12 12 12 12 12 B S B S B S B S B S B S B B 2100 2100 2500 2500 2800 2800 1750 1800 1900 2300 2400 2700 2800 3100 37.70 37.70 45.43 45.43 52.09 52.09 37.10 38.00 40.10 47.00 50.30 57.00 60.00 63.40 2.06 2.06 2.97 2.97 3.60 3.60 1.50 1.60 1.70 2.50 2.70 3.50 3.70 4.00 26.6 26.6 32.2 32.2 35.3 35.3 24.5 25.8 26.3 31.1 31.9 36.3 37.4 39.5 1.92 1.92 2.40 2.40 4.20 4.20 1.08 1.20 1.20 1.92 1.92 2.76 2.76 3.12 66000 40000 56000 33000 50000 30000 80000 30000 80000 30000 80000 30000 75000 75000 Radiatron Components Ltd, Egham, Surrey TW20 8RZ www.radiatron.com Tele: 0044 (0) 1784 439393 Fax: 0044 (0) 1784 477333 e-mail: sales@radiatron.com MTTF (@40 DegC) Approx. conv. factors:- l/min = CFM x 28.3 Inch/H20 = mm/H20 x 0.04 2 Pa = mm/H 0 x 0.10 11 of 15 21.03.2002 Radiatron Flat Fan Range Size (sq x thk) mm Radiatron Part V Bearing Type Speed (RPM) Airflow (CFM) Press. (mm/H2O) Noise (dBA) Power (Watts) MTTF (@25 DegC) 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 JF0925B2L JF0925S2L JF0925B2M JF0925S2M JF0925B2H JF0925S2H YW09225024BL YW09225024SM YW09225024BM YW09225024SH YW09225024BH YW09225048BM-6 YW09225048BH-6 24 24 24 24 24 24 24 24 24 24 24 48 48 B S B S B S B S B S B B B 2100 2100 2500 2500 2800 2800 1900 2300 2400 2700 2800 2400 2800 37.70 37.70 45.43 45.43 52.09 52.09 40.10 47.00 50.30 57.00 60.00 50.30 60.00 2.06 2.06 2.97 2.97 3.60 3.60 1.70 2.50 2.70 3.50 3.70 2.70 3.70 26.6 26.6 32.2 32.2 35.3 35.3 26.3 31.1 31.9 33.5 37.4 31.9 37.4 3.12 3.12 3.60 3.60 4.56 4.56 1.44 2.16 1.92 3.12 3.12 2.88 4.32 66000 40000 56000 33000 50000 30000 80000 30000 80000 30000 75000 80000 75000 92 X 32 92 X 32 92 X 32 YW09232012BH YW09232024BH YW09232048BH 12 24 48 B B B 4000 4000 4000 73.30 73.30 73.30 10.70 10.70 10.70 47.0 47.0 47.0 5.52 6.24 10.08 80000 80000 80000 92 X 38 92 X 38 92 X 38 FMC9212CB CW09238012BH CW09238024BH 12 12 24 B B B 3000 4000 60.33 7.90 10.52 35.5 47.5 4.20 9.00 50000 80000 80000 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 JF1225B1L JF1225S1L JF1225B1M JF1225S1M JF1225B1H JF1225S1H FMB12012C YW12025012BL-6 YW12025012SL-6 YW12025012BM-6 YW12025012SM-6 YW12025012BH-6 YW12025012SH-6 JF1225B2L JF1225S2L JF1225B2M JF1225S2M JF1225B2H JF1225S2H YW12025024BL-6 YW12025024BM-6 YW12025024SM-6 YW12025024BH-6 YW12025024SH-6 JF1225B4L JF1225S4L JF1225B4M JF1225S4M JF1225B4H JF1225S4H YW12025048BL-6 YW12025048BM-6 YW12025048BH-6 12 12 12 12 12 12 12 12 12 12 12 12 12 24 24 24 24 24 24 24 24 24 24 24 48 48 48 48 48 48 48 48 48 B S B S B S B B S B S B S B S B S B S B B S B S B S B S B S B B B 1800 1800 2100 2100 2400 2400 2300 1800 1800 2200 2200 2600 2600 1800 1800 2100 2100 2400 2400 1800 2200 2200 2600 2600 1800 1800 2100 2100 2400 2400 1800 2200 2600 67.43 67.43 74.25 74.25 82.97 82.97 83.80 74.40 74.40 92.00 92.00 105.00 105.00 67.43 67.43 74.25 74.25 82.97 82.97 74.40 92.00 92.00 105.00 105.00 67.43 67.43 74.25 74.25 82.97 82.97 74.40 92.00 105.00 3.02 3.02 4.05 4.05 4.72 4.72 3.24 3.20 3.20 4.70 4.70 6.20 6.20 3.02 3.02 4.05 4.05 4.72 4.72 2.60 4.70 4.70 6.20 6.20 3.02 3.02 4.05 4.05 4.72 4.72 2.60 6.20 6.20 33.1 33.1 37.3 37.3 41.1 41.1 42.0 36.0 35.2 39.0 39.0 45.0 45.0 33.1 33.1 37.3 37.3 41.1 41.1 36.0 32.5 39.0 45.0 45.0 33.1 33.1 37.3 37.3 41.1 41.1 26.0 45.0 45.0 2.40 2.40 3.00 3.00 3.60 3.60 4.56 2.16 2.16 3.48 3.48 5.52 5.52 3.60 3.60 4.80 4.80 6.00 6.00 2.40 3.84 3.84 6.72 6.72 2.88 2.88 3.84 3.84 4.80 4.80 3.36 6.24 8.16 66000 40000 57000 34000 50000 30000 Radiatron Components Ltd, Egham, Surrey TW20 8RZ www.radiatron.com Tele: 0044 (0) 1784 439393 Fax: 0044 (0) 1784 477333 e-mail: sales@radiatron.com MTTF (@40 DegC) 80000 30000 80000 30000 75000 30000 66000 40000 57000 34000 50000 30000 80000 80000 30000 75000 30000 66000 40000 57000 34000 50000 30000 80000 80000 75000 Approx. conv. factors:- l/min = CFM x 28.3 Inch/H20 = mm/H20 x 0.04 2 Pa = mm/H 0 x 0.10 12 of 15 21.03.2002 Radiatron Flat Fan Range Size (sq x thk) mm Radiatron Part V Bearing Type Speed (RPM) Airflow (CFM) Press. (mm/H2O) Noise (dBA) Power (Watts) MTTF (@25 DegC) 120 X 32 120 X 32 120 X 32 120 X 32 120 X 32 120 X 32 120 X 32 120 X 32 120 X 32 120 X 32 120 X 32 120 X 32 YW12032012SL-6 YW12032012SM-6 YW12032012BM-6 YW12032012BH-6 YW12032024BM-6 YW12032024SH-6 YW12032024BH-6 YW12032048SL-6 YW12032048BM-6 YW12032048SM-6 YW12032048BH-6 YW12032048SH-6 12 12 12 12 24 24 24 48 48 48 48 48 S S B B B S B S B S B S 2100 2500 2500 2900 2500 2900 2900 2100 2500 2500 2900 2900 83.00 92.00 99.00 115.00 99.00 100.00 115.00 83.00 99.00 99.00 115.00 115.00 4.20 6.00 6.00 8.00 6.00 6.00 8.00 4.20 6.00 6.00 8.00 8.00 37.4 42.5 42.5 47.6 42.5 48.2 47.6 37.4 42.5 42.5 47.6 47.6 4.08 5.52 5.40 6.96 4.80 8.40 6.96 4.32 6.24 6.24 9.12 10.08 30000 30000 80000 75000 80000 30000 75000 30000 80000 30000 75000 30000 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 JF1238B1L JF1238C1L JF1238S1L JF1238B1M JF1238C1M JF1238S1M JF1238B1H JF1238C1H JF1238S1H FMA12012CB YW12038012BL YW12038012BM YW12038012SM YW12038012BH YW12038012SH YW12038012BS 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 12 B B+S S B B+S S B B+S S B B B S B S B 2000 2000 2000 2400 2400 2400 2800 2800 2800 2300 2000 2400 2400 2800 2800 3000 77.00 77.00 77.00 93.00 93.00 93.00 111.00 111.00 111.00 120.37 89.50 107.50 107.50 125.50 125.50 135.00 4.00 4.00 4.00 6.00 6.00 6.00 8.20 8.20 8.20 5.40 3.90 5.60 5.60 7.60 7.60 8.60 41.1 41.1 41.1 45.9 45.9 45.9 48.8 48.8 48.8 43.0 36.0 40.5 40.5 45.0 40.5 46.5 4.08 4.08 4.08 5.40 5.40 5.40 9.60 9.60 9.60 9.60 3.84 5.04 5.40 7.92 8.52 11.64 70000 56000 42000 58000 46000 35000 50000 40000 30000 50000 80000 80000 30000 75000 30000 75000 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 JF1238B2L JF1238C2L JF1238S2L JF1238B2M JF1238C2M JF1238S2M JF1238B2H JF1238C2H JF1238S2H YW12038024BL YW12038024SL YW12038024BM YW12038024SM YW12038024BH YW12038024SH YW12038024BS 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 24 B B+S S B B+S S B B+S S B S B S B S B 2000 2000 2000 2400 2400 2400 2800 2800 2800 2000 2000 2400 2400 2800 2800 3000 77.00 77.00 77.00 93.00 93.00 93.00 111.00 111.00 111.00 89.50 89.50 107.50 107.50 125.50 125.50 135.00 4.00 4.00 4.00 6.00 6.00 6.00 8.20 8.20 8.20 3.90 3.90 5.60 5.60 7.60 7.60 8.60 41.1 41.1 41.1 45.9 45.9 45.9 48.8 48.8 48.8 36.0 36.0 40.5 40.5 45.0 45.0 46.5 3.84 3.84 3.84 6.00 6.00 6.00 9.36 9.36 9.36 3.60 3.84 6.00 6.00 8.64 9.36 12.48 70000 56000 42000 58000 46000 35000 50000 40000 30000 80000 30000 80000 30000 75000 30000 75000 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 JF1238B4L JF1238C4L JF1238S4L JF1238B4M JF1238C4M JF1238S4M JF1238B4H JF1238C4H JF1238S4H YW12038048BL YW12038048BM YW12038048SM YW12038048BH YW12038048SH YW12038048BS YW12038053BL 48 48 48 48 48 48 48 48 48 48 48 48 48 48 48 53 B B+S S B B+S S B B+S S B B S B S B B 2000 2000 2000 2400 2400 2400 2800 2800 2800 2000 2400 2400 2800 2800 3000 2100 77.00 77.00 77.00 93.00 93.00 93.00 111.00 111.00 111.00 89.50 107.50 107.50 125.50 125.50 135.50 92.70 4.00 4.00 4.00 6.00 6.00 6.00 8.20 8.20 8.20 3.90 5.60 5.60 7.60 7.60 8.60 4.90 41.1 41.1 41.1 45.9 45.9 45.9 48.8 48.8 48.8 36.0 40.5 40.5 45.0 45.0 46.5 38.8 5.76 5.76 5.76 7.68 7.68 7.68 10.08 10.08 10.08 5.76 7.20 7.20 10.08 10.08 12.96 6.36 70000 56000 42000 58000 46000 35000 50000 40000 30000 80000 80000 30000 75000 30000 75000 80000 Radiatron Components Ltd, Egham, Surrey TW20 8RZ www.radiatron.com Tele: 0044 (0) 1784 439393 Fax: 0044 (0) 1784 477333 e-mail: sales@radiatron.com MTTF (@40 DegC) Approx. conv. factors:- l/min = CFM x 28.3 Inch/H20 = mm/H20 x 0.04 2 Pa = mm/H 0 x 0.10 13 of 15 21.03.2002 Radiatron Flat Fan Range MTTF (@25 DegC) Size (sq x thk) mm Radiatron Part V Bearing Type Speed (RPM) Airflow (CFM) Press. (mm/H2O) Noise (dBA) Power (Watts) 127 X 38 127 X 38 127 X 38 127 X 38 127 X 38 127 X 38 127 X 38 127 X 38 127 X 38 WW12738012BL WW12738012BM WW12738012BH WW12738024BL WW12738024BM WW12738024BH WW12738048BL WW12738048BM WW12738048BH 12 12 12 24 24 24 48 48 48 B B B B B B B B B 2000 2500 3000 2000 2500 3000 2000 2800 3450 60.00 88.00 110.00 60.00 88.00 110.00 76.00 110.00 140.00 3.50 5.80 7.00 3.50 5.80 7.00 4.50 6.50 8.20 26.0 33.0 44.0 26.0 33.0 43.0 30.0 38.0 48.0 2.40 4.80 6.00 3.60 4.56 5.52 172 X 38 172 X 38 172 X 38 172 X 38 172 X 38 172 X 38 172 X 38 172 X 38 172 X 38 WW17238012BL WW17238012BM WW17238012BH WW17238024BL WW17238024BM WW17238024BH WW17238048BL WW17238048BM WW17238048BH 12 12 12 24 24 24 48 48 48 B B B B B B B B B 2000 2800 3350 2000 2800 3450 2000 2800 3450 76.00 110.00 135.00 76.00 110.00 140.00 76.00 110.00 140.00 4.50 6.50 8.20 4.50 6.50 8.20 4.50 6.20 8.20 30.0 38.0 48.0 30.0 38.0 48.0 30.0 38.0 48.0 172 X 50 172 X 50 172 X 50 172 X 50 172 X 50 172 X 50 WW17250012BL WW17250012BM WW17250012BH WW17250024BL WW17250024BM WW17250024BH 12 12 12 24 24 24 B B B B B B 1500 2000 2800 1500 2200 3000 120.00 150.00 200.00 120.00 150.00 225.00 6.40 7.60 14.20 6.40 7.60 14.20 30.0 38.0 50.0 30.0 38.0 50.0 5.40 6.60 16.80 4.80 7.20 15.60 60000 60000 60000 60000 60000 60000 172 X 50 172 X 50 172 X 50 WW17250048BL WW17250048BM WW17250048BH 48 48 48 B B B 1500 2200 3050 120.00 150.00 230.00 6.40 7.60 14.20 30.0 38.0 50.0 4.80 7.20 18.70 60000 60000 60000 172 X 51 172 X 51 172 X 51 172 X 51 172 X 51 172 X 51 172 X 51 172 X 51 172 X 51 172 X 51 WW17251012BL WW17251012BM WW17251012BH WW17251024BL WW17251024BM WW17251024BH WW17251048BL WW17251048BM WW17251048BH JF1751B4SP 12 12 12 24 24 24 48 48 48 48 B B B B B B B B B B 1500 2000 2800 1500 2200 3000 1500 2200 3050 3400 120.00 150.00 200.00 120.00 150.00 225.00 120.00 150.00 230.00 240.00 6.40 7.60 14.20 6.40 7.60 14.20 6.40 7.60 14.20 19.00 30.0 38.0 50.0 30.0 38.0 50.0 30.0 38.0 50.0 53.0 5.40 6.60 16.80 4.80 7.20 15.60 4.80 7.20 18.70 24.00 60000 60000 60000 60000 60000 60000 60000 60000 60000 100000 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 80 X 25 JA0825B11H JA0825S11H ST08025115BM ST08025115BH JA0825B22H JA0825S22H ST08025230BM ST08025230BH 115 115 115 115 230 230 230 230 B S B B B S B B 2200 2200 2400 3000 2200 2200 2400 3000 18.00 18.00 18.00 24.00 18.00 18.00 18.00 24.00 2.30 2.30 4.00 4.00 2.30 2.30 4.00 4.00 31.0 31.0 32.0 35.0 31.0 31.0 32.0 35.0 7.00 7.00 13.00 14.00 7.00 7.00 15.00 18.00 50000 30000 50000 50000 50000 30000 50000 50000 80 X 38 80 X 38 80 X 38 80 X 38 80 X 38 80 X 38 80 X 38 80 X 38 ST08038115BM ST08038115BH JA0838B11H JA0838S11H ST08038230BH ST08038230BM JA0838B22H JA0838S22H 115 115 115 115 230 230 230 230 B B B S B B B S 2800 3100 2500 2500 3100 2800 2500 2500 29.00 32.00 33.50 33.50 32.00 29.00 33.50 33.50 0.82 0.91 3.55 3.55 0.91 0.82 3.55 3.55 37.0 36.0 33.0 33.0 36.0 37.0 33.0 33.0 10.00 10.00 11.00 11.00 12.00 12.00 11.00 11.00 50000 50000 50000 30000 50000 50000 50000 30000 MTTF (@40 DegC) 60000 60000 60000 60000 60000 60000 60000 60000 60000 80000 80000 80000 80000 80000 80000 80000 80000 80000 AC Fan Range Radiatron Components Ltd, Egham, Surrey TW20 8RZ www.radiatron.com Tele: 0044 (0) 1784 439393 Fax: 0044 (0) 1784 477333 e-mail: sales@radiatron.com Approx. conv. factors:- l/min = CFM x 28.3 Inch/H20 = mm/H20 x 0.04 2 Pa = mm/H 0 x 0.10 14 of 15 21.03.2002 Radiatron Flat Fan Range Size (sq x thk) mm Radiatron Part V Bearing Type Speed (RPM) Airflow (CFM) Press. (mm/H2O) Noise (dBA) Power (Watts) MTTF (@25 DegC) 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 92 X 25 JA0925B11H JA0925S11H ST09225115BM ST09225115BH JA0925B22H JA0925S22H ST09225230BM ST09225230BH 115 115 115 115 230 230 230 230 B S B B B S B B 2200 2200 2300 2900 2200 2200 2300 2900 29.50 29.50 26.56 34.17 29.50 29.50 26.56 34.17 2.80 2.80 4.60 4.60 2.80 2.80 4.60 4.60 39.0 39.0 35.0 41.0 39.0 39.0 35.0 41.0 7.00 7.00 13.00 14.00 7.00 7.00 14.00 14.00 50000 30000 50000 50000 50000 30000 50000 50000 92 X 38 92 X 38 ST0938115BH ST0938220BH 115 220 B B 3250 3250 50.00 50.00 1.42 1.42 45.0 43.0 12.00 11.00 50000 50000 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 120 X 25 JA1225B11L JA1225S11L JA1225B11H JA1225S11H WT12025115BL WT12025115BM WT12025115BH JA1225B22L JA1225S22L JA1225B22H JA1225S22H WT12025220BL WT12025220BM WT12025220BH 115 115 115 115 115 115 115 230 230 230 230 220 220 220 B S B S B B B B S B S B B B 1800 1800 2250 2250 2000 2700 2900 1800 1800 2250 2250 2000 2700 2900 55.00 55.00 68.00 68.00 53.50 76.00 81.00 55.00 55.00 68.00 68.00 53.50 76.00 81.00 2.40 2.40 3.18 3.18 4.60 4.60 5.90 2.40 2.40 3.18 3.18 3.20 4.20 5.90 35.0 35.0 42.0 42.0 35.0 43.0 37.0 35.0 35.0 42.0 42.0 35.0 43.0 37.0 7.00 7.00 15.50 15.50 13.00 14.00 13.00 7.00 7.00 15.50 15.50 16.00 16.00 13.00 60000 36000 50000 30000 60000 60000 60000 60000 36000 50000 30000 50000 50000 50000 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 JA1238B11L JA1238S11L JA1238B11M JA1238S11M JA1238B11H JA1238S11H WT12038115BX WT12038115BL WT12038115BM WT12038115BH WT12038115BS 115 115 115 115 115 115 115 115 115 115 115 B S B S B S B B B B B 2100 2100 2400 2400 2900 2900 1600 1900 2400 3000 3200 71.50 71.50 85.00 85.00 92.00 92.00 48.00 63.00 72.00 105.00 115.00 3.56 3.56 5.33 5.33 8.13 8.13 3.20 4.20 4.70 7.60 7.90 37.5 37.5 41.0 41.0 48.0 48.0 29.0 34.0 39.0 48.0 55.0 11.50 11.50 15.50 15.50 21.00 21.00 8.00 9.00 10.00 16.00 13.00 70000 42000 62000 37000 50000 30000 80000 80000 80000 80000 80000 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 120 X 38 JA1238B22L JA1238S22L JA1238B22M JA1238S22M JA1238B22H JA1238S22H WT12038220BL WT12038220BM WT12038220BH WT12038220BS 230 230 230 230 230 230 230 230 230 230 B S B S B S B B B B 2100 2100 2400 2400 2900 2900 1900 2400 3000 3200 71.50 71.50 85.00 85.00 92.00 92.00 63.00 72.00 105.00 115.00 3.56 3.56 5.33 5.33 8.13 8.13 4.20 4.70 7.60 7.90 37.5 37.5 41.0 41.0 48.0 48.0 34.0 39.0 48.0 55.0 11.50 11.50 15.50 15.50 22.00 22.00 9.00 10.00 19.00 13.00 70000 42000 62000 37000 50000 30000 60000 60000 60000 60000 127 X 38 127 X 38 127 X 38 127 X 38 127 X 38 127 X 38 WT12738115BL WT12738115BM WT12738115BH WT12738220BL WT12738220BM WT12738220BH 115 115 115 220 220 220 B B B B B B 1400 2200 3100 1400 2200 3100 74.00 95.00 130.00 74.00 95.00 130.00 5.20 6.80 3.68 5.20 6.80 3.68 28.0 37.0 48.0 28.0 37.0 48.0 7.00 10.00 22.00 7.00 10.00 21.00 60000 60000 60000 60000 60000 60000 Radiatron Components Ltd, Egham, Surrey TW20 8RZ www.radiatron.com Tele: 0044 (0) 1784 439393 Fax: 0044 (0) 1784 477333 e-mail: sales@radiatron.com MTTF (@40 DegC) Approx. conv. factors:- l/min = CFM x 28.3 Inch/H20 = mm/H20 x 0.04 2 Pa = mm/H 0 x 0.10 15 of 15 21.03.2002 Radiatron Flat Fan Range Size (sq x thk) mm Radiatron Part V Bearing Type Speed (RPM) Airflow (CFM) Press. (mm/H2O) Noise (dBA) Power (Watts) MTTF (@25 DegC) 160 X 62 160 X 62 ST16062115BH ST16062220BH 115 220 B B 3400 3400 315.00 315.00 8.92 8.92 54.0 54.0 60.00 60.00 60000 60000 170 X 51 170 X 51 ST17051115BH ST17051220BH 115 220 B B 3350 3350 235.00 235.00 6.70 6.70 59.0 59.0 30.00 30.00 60000 60000 172 X 38 172 X 38 172 X 38 172 X 38 JA1738B11H ST17238115BH JA1738B22H ST17238220BH 115 115 230 220 B B B B 2950 3350 2950 3350 171.00 235.00 171.00 235.00 13.20 6.70 13.20 6.70 50.5 59.0 50.5 59.0 36.00 32.00 36.00 32.00 50000 50000 50000 50000 172 X 51 172 X 51 172 X 51 172 X 51 172 X 51 172 X 51 172 X 51 172 X 51 JA1751B11H ST17251115BL ST17251115BM ST17251115BH JA1751B22H ST17251220BL ST17251220BM ST17251220BH 115 115 115 115 230 220 220 220 B B B B B B B B 2950 1800 2400 3350 2950 1800 2400 3350 205.00 106.00 170.00 235.00 205.00 106.00 170.00 235.00 16.10 8.00 14.00 67.00 16.10 8.00 14.00 67.00 56.0 32.0 40.0 59.0 56.0 32.0 40.0 59.0 48.50 16.00 20.00 32.00 47.50 16.00 20.00 32.00 50000 60000 60000 60000 50000 60000 60000 60000 180 X 65 180 X 65 SW18065115BH SW18065220BH 115 220 B B 3000 3000 370.00 370.00 10.50 10.50 59.0 59.0 55.00 65.00 60000 60000 208 X 72 208 X 72 SW20872115BH SW20872220BH 115 220 B B 3000 3000 650.00 650.00 18.50 18.50 65.0 65.0 64.00 68.00 60000 60000 254 X 89 254 X 89 254 X 89 254 X 89 254 X 89 254 X 89 WT25489115BL WT25489115BM WT25489115BH WT25489220BL WT25489220BM WT25489220BH 115 115 115 220 220 220 B B B B B B 1650 2400 3200 2650 2400 3200 550.00 650.00 850.00 550.00 650.00 850.00 15.60 15.00 20.00 15.60 15.00 20.00 52.0 60.0 65.0 52.0 60.0 65.0 43.00 55.00 70.00 41.00 55.00 70.00 60000 60000 60000 60000 60000 60000 Radiatron Components Ltd, Egham, Surrey TW20 8RZ www.radiatron.com Tele: 0044 (0) 1784 439393 Fax: 0044 (0) 1784 477333 e-mail: sales@radiatron.com MTTF (@40 DegC) Approx. conv. factors:- l/min = CFM x 28.3 Inch/H20 = mm/H20 x 0.04 2 Pa = mm/H 0 x 0.10
F41MM-024XK-9 价格&库存
很抱歉,暂时无法提供与“F41MM-024XK-9”相匹配的价格&库存,您可以联系我们找货
