DAS240BAT
DAS240BAT
    SEFRAM
    SEFRAM - DAS240BAT - Data Acquisition Unit, 20 Channels, 1 kSPS, 200 V, 10 kHz, 176 mm
DAS240BAT 数据手册
Make sure to visit our Website http://www.sefram.fr Sefram Sefram SEFRAM DAS 240 Multi Channel Handheld Recorder Capabilities • 20 to 200 analogue channels • Input: voltage, thermocouple, Pt100-Pt1000, current (with optional adapter), resistance • Voltage: from 1mV to 200V (±100V) • Temperature: thermocouples (all types), Pt100-Pt1000 (2 or 3 wires) • 16 Bit vertical resolution • Max sampling rate: 1ms (1kHz) • 12 logical channels • 4 alarms (output) • 4 logical function input with counter & frequency meter capability • 10" TFT panoramic touch screen • Internal hard drive: 32 Gb • Interfaces: USB, Ethernet, Wifi (option) • Lithium-ion battery (factory option): 15h autonomy • DasLab software (licence free) • Safety: IEC 61010 CAT I 100V A multi channel handheld recorder dedicated to process The new DAS240 recorder has been designed to measure all parameters you can find in a process: voltage measurements, measurements on sensors (0-10V), temperature measurements (thermocouple, Pt100-Pt1000), current measurements (with optional shunt), resistance measurement, counter, frequency. You can view directly the results of measurements (graphs, numerical values) and memorize your results in the recorder memory or in a USB memory stick. The data transfer and data processing can be done later with a personal computer using the licence free DasLab software. DAS 240 A modular solution The DAS240 is supplied with 20 analogue channels, but you can add 180 analogue channels, by steps of 20. All modules (20 channels) are strictly identical and can perform the same measurements (voltage, temperature, resistance, current). User-friendly interface Multiple applications The DAS240 is equipped with a panoramic 10" touch screen: the user interface becomes absolutely interactive. The icons and symbols used makes the browsing very easy and will save your time. The DAS240 recorder is really a general purpose recorder for process applications: - multi channel temperature monitoring and recording - 0-10V sensors monitoring and recording - voltage measurements - pulse counting - 4-20mA measurement and monitoring (with optional shunt). Selection guide 20 analogue multiplexed channels 12 logical channels input Internal battery (15h autonomy) 20 channels module WiFi interface (USB dongle) DAS240 DAS240BAT • • • • • option option option option Sefram Sefram SEFRAM DAS 240 Multi Channel Handheld Recorder Setup: self-explanatory icons to guide the user Channels setup: all parameters can be displayed on a single screen Numerical display of measurements XY mode Trigger: multiple choice and combination of threshold, channels and conditions Math calculation between channels Measurement display with zoom and cursors File management with the DAS240 Sefram Sefram SEFRAM DAS 240 Multi Channel Handheld Recorder SEFRAM DasLab Software The new DasLab software for PC (under Windows) is suitable for: - Managing recorder setup (online & offline) - Remote setup of the DAS240 - Managing & downloading files (records, setup) from the recorder DasLab is a licence free software and can be downloaded from Sefram website. The link between your DAS240 and your computer can be set up through the Ethernet interface or the Wifi interface (option). DasLab : Remote setup DasLab: files management DasLab: channels setup DAS 240: a flexible solution with the optional 20 channels modules Your applications needs more measurement channels? The DAS240 is a flexible and scalable system! Supplied with 20 measurement channels, you can add up to 180 channels, by increment of 20, for reaching a total of 200 channels. The 20 channels modules (P/N: 902401000) are all versatile: you can measure voltage, temperature with thermocouples, Pt100-1000 and are supplied with fast connectors and a mechanical system to fix them together. 20 channels module (P/N: 902401000) DAS240 equipped with 40 channels Sefram Sefram SEFRAM DAS 240 Multi Channel Handheld Recorder TECHNICAL SPECIFICATIONS Number of channels: INTERNAL 20 channels, expandable to 200 with optional 20 channels modules INPUT SPECIFICATIONS INTERFACES DC Voltage 1mV (±0,5mV) to 200V (±100V) Ranges: 100V DC Maximum input voltage: Accuracy: 0,1% of the full scale ±10µV TEMPERATURE WITH THERMOCOUPLES Sensors Range -210°C to 1200°C Couple J Couple K -250°C to 1370°C -200°C to 400°C Couple T Couple S -50°C to 1760°c 200°C to 1820°C Couple B -250°C to 1000°C Couple E Couple N -250°C to 1300°C 0°C to 2320°C Couple C Couple L -200°C to 900°C USB: Ethernet: Wifi: Cold junction compensation: ±0,5°C TEMPERATURE WITH PT100 - PT1000 STORAGE Internal flash drive size: Maximum file size: 32Gb min 2Gb 2 x USB type A 10/100base-T with RJ45 socket with optional USB dongle GENERAL SPECIFICATIONS Display: Power supply: Battery: Autonomy with battery: Operating temperature: Storage temperature: Dimensions: Weight: Safety: Warranty: 10" TFT touch screen LCD, backlighted, 1024 x 600 dots 15V / 4A max with main adapter (100/240VAC) factory option, non removable, Lithium-ion 15h with standby mode, 10h without stand-by mode 0°C to 40°C, 80% RH (no condensation) -20°C to 60°C 66 x 298 x 176mm 1,5kg Cat I 100V, according to IEC61010-1 2 years Current: Range: 1mA (Pt100) & 100µA (Pt1000) -200°C to 850°C ACCESSORIES AND OPTIONS Measurements: Accuracy (at 20°C): Compensated resistance with 2 wire: Compensated resistance with 3 wires: 2 and 3 wires 0,3°C ±0,1% of reading 30 ohms max. 50 ohms max 902401000: 20 channels module 902408000: Rugged carrying case 1kΩ and 10kΩ 1Ω (range 1kΩ) and 10Ω (range (10kΩ) 902402000: Wifi option (USB dongle) 984405500: 12 isolated logical channels board 902407000: Logical channels patch cord 902406500: 4-20mA / 50 ohms shunt 902409000: 19" rackmount kit: RESISTANCE Ranges: Accuracy: ACQUISITION - SAMPLING Resolution: Acquisition system: Sampling rate: Trigger: Pre-trigger : 16 bit scanner, one sample per channel 1ms to 20mn for V >50mV 2ms to 20mn for V ≤50mV, thermocouples & Pt100-Pt1000 date, delay, threshold, combination of thresholds (and/or), word on logical channels (and, or, slope, level) variable from 0 to 100k samples ADDITIONNAL I/O Logical channels Number: Maximum permitted voltage: Input impedance: Sampling rate: 12 24V Cat I 4,7kΩ 1ms max. LOGICAL FUNCTION INPUT Number of channels: Maximum permitted voltage: Input impedance: Sampling rate: Pulse counter: Frequency measurement: 4 (K1 to K4) 24V Cat I 4,7kΩ 1ms max. 0 to 10000000 1Hz to 10kHz ALARMS (OUTPUT) Number: Output level: 4 alarms (A, B, C, D) 0-5V Supplied with: a main adaptor 100/240V, manual (CD-ROM), 1 male connector with 25 pins male and cover, 1 cable (70cm) for measurement module connection, 1 measurement module (20 channels) with connectors, a stylus, a soft wipe, a screwdriver. FTDAS240A00 - Specifications can be updated without notice For assistance and ordering 32, rue Edouard Martel - BP55- 42009 - St Etienne - cedex 2 Tél. +33 (0) 4.77.59.01.01 Fax. +33 (0) 4.77.57.23.23 Web : www.sefram.fr - e-mail : sales@sefram.fr
