DAS220BAT
DAS220BAT
    SEFRAM
    SEFRAM - DAS220BAT - Data Acquisition Unit, 10 Channels, 1 kSPS, 200 V, 10 kHz, 105 mm
DAS220BAT 数据手册
Make sure to visit our Website http://www.sefram.fr Sefram Sefram SEFRAM DAS 220 Multi Channel Handheld Recorder Capabilities • 10 analogue channels • Input : voltage, thermocouple, Pt100-1000, current (with optional adapter), resistance • Voltage: from 1mV to 200V (±100V) • Temperature: thermocouples (all types), Pt100/Pt1000 (2 or 3 wires) • 16 Bit vertical resolution • Max sampling rate: 1ms (1kHz) • 12 logical channels • 4 alarms (output) • 4 logical function input with counter & frequencymeter capability • 10" TFT panoramic touch screen • Internal hard drive : 32 GB • Interfaces: USB, Ethernet, WiFi (option) • Lithium-ion battery (factory option) : 15h autonomy • DasLab software (license free) • Safety: IEC61010 CAT I 100V A multi channel handheld recorder dedicated to process The new DAS220 recorder has been designed to measure all parameters you can find in a process: voltage measurements, measurements on sensors (0-10V), temperature measurements (thermocouple, Pt100-Pt1000), current measurements (with optional shunt), resistance measurement, counter, frequency. You can view directly the results of measurements (graphs, numerical values) and memorize your results in the recorder memory or in a USB memory stick. The data transfer and data processing can be done later with a personal computer using the licence free DasLab software. DAS 220 Multiple applications The DAS220 recorder is really a general purpose recorder for process applications: - multi channel temperature monitoring and recording - 0-10V sensors monitoring and recording - voltage measurements - pulse counting - 4-20mA measurement and monitoring (with optional shunt). User-friendly interface The DAS220 is equipped with a panoramic 10" touch screen: the user interface becomes absolutely interactive. The icons and symbols used makes the browsing very easy and will save your time. Selection guide 10 analogue multiplexed channels 12 logical channels input Internal battery (8h autonomy) WiFi interface (USB dongle) DAS220 DAS220BAT • • • • • option option Sefram Sefram SEFRAM DAS 220 Multi Channel Handheld Recorder Setup: self-explanatory icons to guide the user Channels setup: all parameters can be displayed on a single screen Numerical display of measurements XY mode Trigger: multiple choice and combination of threshold, channels and conditions Math calculation between channels Measurement display with zoom and cursors File management with the DAS220 Sefram Sefram SEFRAM DAS 220 Multi Channel Handheld Recorder SEFRAM DasLab Software The new DasLab software for PC (under Windows) is suitable for: - Managing recorder setup (online & offline) - Remote setup of the DAS220 - Managing & downloading files (records, setup) from the recorder DasLab is a licence free software and can be downloaded from Sefram website. The link between your DAS220 and your computer can be set up through the Ethernet interface or the WiFi interface (option). DasLab : Remote setup DasLab: files management DasLab: channels setup Optional accessories for all uses P/N: 902406500 Shunt 50 Ohms for current measurements 4-20mA P/N: 902407000 Cord for logic channels P/N: 902407100 Connecting cord with female banana plugs P/N: 902408000 Carrying case for the device and its accessories Sefram Sefram SEFRAM DAS 220 Multi Channel Handheld Recorder TECHNICAL SPECIFICATIONS Number of channels: INTERNAL 10 channels, STORAGE Internal flash drive size: Maximum file size: INPUT SPECIFICATIONS INTERFACES DC Voltage Ranges: 1mV (±0,5mV) to 200V (±100V) Maximum input voltage: 100V DC 0,1% of the full scale ±10µV Accuracy: TEMPERATURE WITH THERMOCOUPLES Range Sensors Couple J -210°C to 1200°C -250°C to 1370°C Couple K Couple T -200°C to 400°C -50°C to 1760°c Couple S 200°C to 1820°C Couple B Couple E -250°C to 1000°C -250°C to 1300°C Couple N Couple C 0°C to 2320°C -200°C to 900°C Couple L USB: Ethernet: Wifi: Power supply: Battery: Autonomy with battery: TEMPERATURE WITH PT100 - PT1000 Current: Range: 1mA (Pt100) & 100µA (Pt1000) -200°C to 850°C ACCESSORIES AND OPTIONS Measurements: Accuracy (at 20°C): Compensated resistance with 2 wire: Compensated resistance with 3 wires: 2 and 3 wires 0,3°C ±0,1% of reading 30 ohms max. 50 ohms max RESISTANCE 1kΩ and 10kΩ 1Ω (range 1kΩ) and 10Ω (range (10kΩ) Ranges: Accuracy: ACQUISITION - SAMPLING Resolution: Acquisition system: Sampling rate: Trigger: Pre-trigger : 16 bit scanner, one sample per channel 1ms to 20mn for V >50mV 2ms to 20mn for V ≤50mV, thermocouples & Pt100-Pt1000 date, delay, threshold, combination of thresholds (and/or), word on logical channels (and, or, slope, level) variable from 0 to 100k samples 2 x USB type A 10/100base-T with RJ45 socket with optional USB dongle GENERAL SPECIFICATIONS Display: Operating temperature: Storage temperature: Dimensions: Weight: Safety: Warranty: Cold junction compensation: ±0,5°C 32GB min 2GB 10" TFT touch screen LCD, backlighted, 1024 x 600 dots 15V / 4A max with main adapter (100/240VAC) factory option, non removable, Lithium-ion 15h with standby mode, 10h without stand-by mode 0°C to 40°C, 80% RH (no condensation) -20°C to 60°C 210 x 295 x 105mm 2,5kg Cat I 100V, according to IEC61010-1 2 years Rugged carrying case: P/N: 902408000 Wifi option (USB dongle): P/N: 902402000 12 isolated logical channels : P/N: 984405500 Logical channels patch cord: P/N: 902407000 4-20mA / 50 ohms shunt: P/N: 902406500 19" rackmount kit: P/N: 902209000 Din mount kit: P/N: 902201000 ADDITIONNAL I/O Logical channels Number: Maximum permitted voltage: Input impedance: Sampling rate: 12 24V Cat I 4,7kΩ 1ms max. LOGICAL FUNCTION INPUT Number of channels: Maximum permitted voltage: Input impedance: Sampling rate: Pulse counter: Frequency measurement: 4 (K1 to K4) 24V Cat I 4,7kΩ 1ms max. 0 to 10000000 1Hz to 10kHz ALARMS (OUTPUT) Number: Output level: 4 alarms (A, B, C, D) 0-5V Supplied with: a main adaptor 100/240V, manual (CD-ROM), 1 male connector with 25 pins mâle and cover, connectors, a stylus, a soft wipe, a screwdriver. For ordering the DAS220 with internal battery: DAS220 BAT FTDAS220A00 - Specifications can be updated without notice For assistance and ordering 32, rue Edouard Martel - BP55- 42009 - St Etienne - cedex 2 Tél. +33 (0) 4.77.59.01.01 Fax. +33 (0) 4.77.57.23.23 Web : www.sefram.fr - e-mail : sales@sefram.fr
DAS220BAT 价格&库存
很抱歉,暂时无法提供与“DAS220BAT”相匹配的价格&库存,您可以联系我们找货
DAS220BAT
    库存:2
    DAS220BAT
      库存:1
      DAS220BAT
