DAS30PT
DAS30PT
    SEFRAM
    SEFRAM - DAS30PT - Data Acquisition Unit, w/ Printer /Pt100/Pt1000, 2 Channels, 1 MSPS, 440 VAC, 100...
DAS30PT 数据手册
Make sure to visit our Website http://www.sefram.fr SEFRAM DAS30 / DAS50 / DAS60 Sefram Sefram Handheld Data Acquisition Solution Capabilities • • • • • • • • • • • • • • • • • • 2 to 6 analogue channels Universal input DC, AC+DC RMS voltage measurement Frequency, counter Temperature: thermocouple, Pt100/Pt1000* Power analysis function (up to 400Hz for DAS60) 16 logical channels 14-bit resolution 10" TFT panoramic LCD touch screen 1 Ms/s sampling rate 100 kHz bandwidth 32 GB internal hard disk (64GB for DAS60) 32 Mword memory Interfaces: 2 x USB, Ethernet Lithium-ion battery Autonomy: up to 9,5 hours. 110mm Thermal printer module* IEC 1010 CAT III 600V * factory options: - printer module (all models) - Pt100 / Pt1000 (DAS30 / 50) DAS30 / 50 / 60 Multifunction recorders for all your applications The new DAS30 / 50 / 60 series recorders have been designed to meet the requirements of all applications in industry (IEC 61010, CAT. III 600V). You can view your measurements (traces, digital values) and record directly in the internal memory or into a USB memory stick. Using Sefram software, you can transfer easily your records on a computer. Universal input The new DAS30 / 50 / 60 recorders offer universal input, which are convenient for all types of signals : - voltage ranges from 1mV to 1000V DC or 425Vrms - temperature (thermocouples) and Pt100/Pt1000* - counter, frequency - current (with optional shunt) Easy-to-use Typical applications Thanks to the new user interface combined with its large touch screen LCD, the portable DAS recorders are design for ease of use for a wide range of data recording applications and easy transfer of your records. The new DAS30 / 50 / 60 recorders are general purpose and multifunction recorders and are suitable for many applications: - maintenance/failure diagnostic on electrical systems - voltage, current, temperature recording and monitoring - power analysis for single-phase and three-phase systems Selection guide 2 isolated universal channels 4 isolated universal channels 6 isolated universal channels Memory 2 Pt100/Pt1000 input 110mm thermal printer DAS30 • 32GB factory option factory option DAS50 • 32GB factory option factory option DAS60 • 64GB • factory option Data Acquisition Solution Sefram Sefram SEFRAM DAS30 / DAS50 / DAS60 Handheld Data Acquisition Solution Channels setup: one screen with colors to differentiate channels Oscilloscope mode Digital display of measurements XY mode Trigger: several type of trigger, one channel, on a level, slope, several channels or combined conditions. With the thermal printer module, you can set up your print Factory options 110mm thermal printer module It’s possible to install on Sefram DAS30 / 50 / 60 recorders a thermal printer module (110 mm width, 10 meters thermal paper roll). Pt100/Pt1000 board This board is included in the DAS60 and is a factory option for DAS30 / 50. It adds 2 channels dedicated to Pt100/Pt1000 platinium resistance measurements, with 2 wires, 3 wires or 4 wires setup. Using a 20 bit analog to digital converter, this card will provide an excellent accuracy and resolution for temperature measurement. Data Acquisition Solution Sefram Sefram SEFRAM DAS30 / DAS50 / DAS60 Handheld Data Acquisition Solution SEFRAM VIEWER This licence free software is supplied with each recorder. It allows the visualization of the recordings and the data transfer to other applications. SEFRAM Viewer makes the acquired signal analysis easier. Capabilities • • • • • • • • Curve printing Display of values (text) Cursors and zoom File concatenation 8 math calculations Up to 120 characters text notes Bitmap, Excel®, txt, csv export Easy setup of curves display FLEXPRO™: a powerful software for your data analysis. With Flexpro® : • More than 100 functions of statistical and math analysis • Powerful graphical display • Measurement report editing ENERGY / POWER ANALYSIS A very powerful analysis for single-phase or three-phase networks. Analysis is provided with Fresnel diagram or oscilloscope mode. The DAS60 can work with 400Hz networks and has a trigger selection function. Your instrument shows how to connect the inputs with a schematic and you can setup parameters and measurements on the same screen. Example of a three-phase network. Real time display of signals and harmoics (up to rank 50) Setup of parameters to measure or calculate. Data Acquisition Solution SPECIFICATIONS – UNIVERSAL INPUT Number of channels : 2 (DAS30), 4 (DAS50), 6 (DAS60) VOLTAGE Bandwidth : DC voltage ranges : Maximum input voltage : Max offset : Accuracy : TRMS AC+DC ranges : Bandwidth (- 3 dB) : Response time : Crest factor : 100 kHz 1 mV to 1000 V ± 500 VDC or 440 VAC ± 5 ranges (up to ± 500 V) ± 0,1% of range ; ± 10µV / ± 0,1% offset from 200 mV to 424 V 5 Hz - 500 Hz 100 ms typical (40 ms to 50 Hz) 2,2 and 600 V peak voltage FREQUENCY Sensitivity : Duty cycle : Frequency range : Basic accuracy 100 mV rms min. 10% min. 0,1 Hz to 100 kHz 0,02% of full scale PAPER PLOT CARACTERISTICS (factory option for all models) Paper width : Paper speed : Paper speed in memory mode : Resolution & accuracy : Y axis : X axis : XY mode : Storage Setup backup : Internal hard disk : Ranges -210°C to 1200°C -250°C to 1370°C -200°C to 400°C -50°C to 1760°C 200°C to 1820°C -250°C to 1000°C -250°C to 1300°C 0°C to 2320°C -200°C to 900°C Display : Automatic measurements : Interfaces : Power supply : Battery (factory installed) : Autonomy : Charging time: Accuracy Cold junction compensation ±1,25°C POWER ANALYSIS FUNCTION Networks : Display : Measurements : Single phase, 2 phases, 3 phases Fresnel diagram, oscilloscope, data Mean value, RMS value, peak value, crest factor, THD and DF for voltages and currents, active, reactive and apparent power, power factor (cos ϕ) calculated up to rank 50, with display and record Harmonics : . SAMPLING Resolution : Sampling rate : Memory length : Triggering : 14 bit 1M sample/sec per channel max. 32Mword in segments of up to 128 Blocks Positive edge, negative edge, on logical input, delay, Go No Go -100% to +100% Pre trigger : . BANDWIDTH Bandwidth ( -3dB) Range : Range : Range : Internal analogue filters : Slope : Programmable digital filters : Slope : Input impedance (DC) : Maximum input voltage : Between 2 terminals of one channel Isolation between frame ground and channel : > 1 V : 100kHz > 50mV : 50kHz 5 mV : 20kHz 10 kHz, 1 kHz, 100 Hz, 10 Hz. 20 dB/decade 10 Hz, 1 Hz, 0,1 Hz, 0,01 Hz, 0,001 Hz 40 dB/decade >25MΩ for range 100 MΩ at 500 VDC . LOGIC INPUT Channels : TTL – Max voltage : Sampling rate : Sensor supply : Alarms 2 : 16 24V The same sampling rate as analogue inputs. 9 to 15 V A & B 0-5 V output. PT100 / PT1000* INPUT (factory option for DAS30 / 50) Number of channels : 2 Current : 1mA for Pt100 and 100µA for Pt1000 Resolution : 20 bits Temperature range: -200°C to +850°C Measurements : 2, 3, 4 wires Accuracy at 20°C : ±0,2°C unlimited on the hard disk 32 GB (solid state) for DAS30 / 50 and 64GB for DAS60 GENERAL SPECIFICATIONS TEMPERATURE Sensor Couple J Couple K Couple T Couple S Couple B Couple E Couple N Couple C Couple L 110 mm from 1 mm/min to 25mm/s 10 mm/s max. 8 dots per mm 16 dots per mm 8 dots per mm (both axis) Dimensions & weight : Operating temperature range : Max. RH. : Storage temperature range : Warranty : Safety : OPTIONNAL 10 inches TFT LCD coloured touch screen F(t)and XY functions. Zoom, cursors, dV, dT and zoom between cursors. Calculation functions y=ax+b , y=/x/+b, y=a√x+b+c, y=ax2+b, y=(log x)+b, yae(x+b)+c 20 automatic measurements ( F, T, Vpp, Tm…) 2 x USB port, Ethernet 100 to 240 VAC, ouput 15 V 5A max. Lithium ion 10,8 V, 6,5 Ah. Typically 9h30min after a complete charge 4 hours without screen saver 1 hour (recorder off) Complete charge in 4 hours. 295 x 210 x 105 mm, 2,5 Kg 0°C to 40°C 80% without condensation. -20°C to 60°C 2 years IEC 61010 - CAT III 600V ACCESSORIES Accessory clamps SP 201 - 200 AAC, 10mV/1A, ø 15 mm. SP 221 - 100 AAC, 100mV/1A, ø 15 mm. SP 230 - 1200 AAC, 10mV/1A, ø 50 mm. SP 261 - 1200 AAC+DC, 1mV/1A, ø 50 mm. SP 270 - 2000 AAC, 1 mV/1A, ø 70 mm. A 1287 - 3000 AAC, 0.333 mV/A, ø 150 mm / Flex Shunts Shunts (with banana plugs) 910007100 Shunt CA 0.01 ohm : 3 A 910007200 Shunt CA 0.1 ohm : 1 A 989007000 Shunt CA 50 ohm : 0.05 A 989006000 Shunt CC 1 ohm : 0.5 A 912008000 Shunt CA 10 ohm : 0.15 A Shunts (with wires) 207030301 Shunt 0.01 ohm : 30 A max 207030500 Shunt 0.001 ohm : 50 A max Logical channels. 984405500 16 isolated logical channels interface 902407000 16 channels logic probe. Rugged carrying case 903001000 Rugged carrying case for DAS30/50 906002000 Rugged carrying case for DAS60 FLEXPRO software 916002100 FlexPro View 916002200 FlexPro Standard 916002300 FlexPro Professional 916002400 FlexPro Developer Suite Printer module (factory option) 903002000 Thermal printer module for DAS30/50 906003000 Thermal printer module for DAS60 Consumables 837500526 Thermal paper roll (10m) Pt100/Pt1000 (factory option for DAS30 / 50) 903003000 2 channels Pt100/Pt1000 19" rackmount kit 903004000 Rackmount kit for DAS30/50 906001000 Rackmount kit for DAS60 Supplied with : a carrying case, a set of red and black cable + alligator clip + quick banana plug, main adaptor, manual (CD-ROM). FT SEFRAM DAS30/50/60 A 01 - Specifications can be updated without notice For assistance and ordering 32, rue Edouard Martel • B.P. 55 • 42009 - St Etienne cedex 2 Tel.+33 (0).4.77.59 36 81 Fax. +33 (0).4.77.57.23.23 Website : www.sefram.fr • e-mail : sales@sefram.fr
DAS30PT 价格&库存
很抱歉,暂时无法提供与“DAS30PT”相匹配的价格&库存,您可以联系我们找货
