DC-046A-1.3
DC-046A-1.3
    CIKI(皓富)
    插件
    L9*W6*H4.7mm
DC-046A-1.3 数据手册
东莞市皓富电子科技有限公司 SPECIFICATION 規 格 書 Designation 品名: DC POWER JACK Model No. 型 號: DC-046A-1.3 1. Rating 額定值: DC 30V 2A 2. Operation temperature range 使用溫度範圍: -30℃~+70℃ 3. Preservative temperature range 保存溫度範圍: -40℃~+85℃ 4. Construction dimension 結構尺寸: Apply to the appended drawing: 符合附加圖紙 Item 项目 Test condition 測試條件 Specification 規格 5. Electrical characteristics 電氣性能 5A Contact Resistance 接觸阻抗 Being measured at 1KHz small current contact resistance meter. 在 1KHZ 小電流下測量. 30mΩ max. 30 毫歐以下. 5B Insulation Resistance 絕緣阻抗 Measurements shall be made following application of DC 250V potential across terminals and across terminals and frame for 1 minute. 在端子之間和端子與殼之間加 DC 250V 條件下,持續 1 分 鐘測量. 100MΩ min. 100 兆歐以上. 5C Withstand Voltage 耐電壓 AC 500V (50Hz or 60Hz) shall be applied across terminals and across terminals and frame for one minute. 在端子之間和端子與殼之間加 AC 500V(50HZ 或 60HZ)條件 下,持續 1 分鐘測量. There shall be no breakdown. 無擊穿現象出現. 6. Mechanical characteristics 機械性能 6A Insertion and Extraction force 插拔力 Terminal Strength 端子強度 6B Being measure at across spring piece and across matching plug for ergometer. 用測力計在插頭與彈片之間進行測量. A static force of 5N being applied in one direction on the tip of terminal for 10sec. 将 5N 之靜負荷施加於端子頂部的一個方向持續 10 秒。 Insertion and extraction force: 3~30N 插拔力: 3~30N (1). Contact resistance:30mΩmax. 接觸阻抗:30 毫歐以下. (2). Insertion and withdraw force:3~30N 插入力和拔出力:3~30N (3). Electrical characteristics and mechanical characteristics shall be satisfied. Without distinct damage. 机械,电气性能满足规定要求,无异常发生 7. Durability 耐久性 7A 7B Soldering test 可焊性試驗 The tip of the terminals shall be dipped 2mm in the solder bath at a temperature of 240 ±5℃ for 3 ± 0.5sec. 端子頂部被浸入焊錫池 2mm 深,溫度 240±5℃,時間 3± 0.5 秒。 A new uniform coating of solder shall cover a minimum of 95% of the surface being immersed. 浸入的部分 95%以上表面將被錫覆蓋. Resistance to soldering heat 耐焊接熱 The jack shall be put into at the temperature of 250 ±5℃ in 5±1sec(Automatic soldering) or 380±5℃ in 3±1sec(Manual soldering) after which measurement shall be made. 将产品端子浸入锡炉, 250±5℃,5±1 秒(自动焊); 380±5℃,3±1 秒(手工焊) (1). Contact resistance:30mΩmax. 接觸阻抗:30 毫歐以下. (2). Insertion and withdraw force:3~30N 插入力和拔出力:3~30N (3). Electrical characteristics and mechanical characteristics sall be satisfied. Without distinct damage. 机械,电气性能满足规定要求,无异常发生 Remark 備 註 SPECIFICATION 規 格 書 Model No. 型 號: Item 项目 7C Life test 壽命試驗 DC-046A-1.3 Test condition 測試條件 5,000 cycles of operation at a rate of 5~8 cycles per minute with unloading. 無負載條件下,每分鐘 5~8 次的速度操作 5,000 次。 Heat test 耐熱試驗 At 85±2℃ for 96 hours, after test keep in normal condition for 30 minutes. 在 85±2℃環境中放 96 小時,再放在正常環境中 30 分鐘 後進行測試. 7E Humidity test. 耐濕試驗 The condition of temperature 40±2℃ and humidity 90-95% for 96 hours, after test keep in normal condition for 30 minutes. 在溫度 40±2℃,濕度 90-95%環境中放 96 小時,再放在 正常環境中 30 分鐘後進行測試. 7F Cold test 耐寒試驗 At –40 ± 2 ℃ for 96 hours, after test keep in normal condition for 30 minutes. 在-40±2℃環境中放 96 小時,再置於正常環境中 30 分 鐘後進行測試. 7G Salt spray test 噴霧試驗 At 5% Nacl liquor for 24 hours, after washing, keep in normal condition for 30 minutes. 5%的 Nacl 溶液中噴霧 24 小時,用水清洗並在室溫下放 置 30 分鐘. 7D Specification 規格 (1). Contact resistance:30mΩmax. 接觸阻抗:30 毫歐以下. (2). Insertion and withdraw force:3~30N 插入力和拔出力:3~30N (3). Electrical characteristics and mechanical characteristics shall be satisfied. Without distinct damage. 机械,电气性能满足规定要求,无异常发生 (1). Contact resistance:30mΩmax. 接觸電阻:30 毫歐以下 (2). Insulation resistance: 100MΩmin. 絕緣電阻: 100 兆歐以上 (3). There shall be no sign of damage mechanically and electrically. 無任何迹象顯示機械及電器性能之損壞. Without excessive Corrosion or crack in appearance 表面無明顯腐蝕或鍍層脫落現象 8. Standard condition 試驗、測定狀態 Unless otherwise specified, the test and measurements shall be carried out as follows: Ambient temperature 溫度: 5℃~35℃ Relative humidity 相對濕度: 45~85% Air pressure 氣壓:86~106kPa(860~1060mbar) However if doubt arises on the decision based on the measured values under the above-mentioned conditions, the following condition shall be employed:但在對判定産生疑義時,按下述狀態實施: Ambient temperature 溫度: 20±2℃ Relative humidity 相對濕度: 65±5% Air pressure 氣壓:86~106kPa(860~1060mbar) Remark 備 註
DC-046A-1.3 价格&库存
很抱歉,暂时无法提供与“DC-046A-1.3”相匹配的价格&库存,您可以联系我们找货
