AD115/230-12 108
AD115/230-12 108
    ALFATRONIX
    ALFATRONIX - AD115/230-12 108 - AC/DC Enclosed Power Supply (PSU), ITE, 1 Outputs, 108 W, 12 V, 9 A
AD115/230-12 108 数据手册
AD Series 115/230Vac Mains Power Supplies Mains Power Supplies in 12V, 24V and 48V Configurations Rugged and Compact The AD Series units may be used to supply mobile radios and other appliances from AC mains used in offices, portable site cabins, communication cabins, telephone exchanges, remote antennae sites, ships, oil rigs etc. The units will accept either European 230Vac or US 115Vac inputs and are available as standard in 12V, 24V and 48V dc output configurations. Input is via a standard IEC-320 C13/14 power cord with UK, European or US mains plugs – please state your requirement. These units, often referred to as ‘brick in the lead’ supplies are housed in a rugged, corrosion resistant anodized aluminium extrusion. The low mass surface mount technology components offer excellent resistance to shock and vibration, thus further increasing the reliability of these products. A red LED indicates when there is output from the converter. This gives reassurance to the installation engineer and speeds fault finding. “C L I C K” --FAST-Installation There’s nothing worse than a power supply lying around on the floor. The ‘T’ shaped mounting clip, common to many Alfatronix products, allows the power supplies to be installed quickly and simply in many out of the way locations, such as underneath desks or on walls. The 3 point ‘T’ clip can be fitted securely, even on uneven surfaces , quickly and simply, then the power supply simply ‘clips’ in place. The ever popular ‘T’ shaped bracket allows the power supply to be fitted quickly and simply making for a fast and neat installation. Battery Charging Required? A fixed voltage battery charging facility is also available with the supplementary loom; P/N AD BB loom. For dedicated battery charging units, please check out our IC Series – Intelligent Battery Chargers Full Circuit Protection The AD Series supplies have transient, overload and overheat protection for reliable operation even in the Toughest environments Alfatronix AD Series units are widely used throughout the world to provide reliable power supplies to radio repeaters for long range transmissions. AD Series power supplies can also be fitted with DIN rail clips for rack mounted applications Desktop Versions also available. While the brick power supplies offer a versatile solution, if you are powering a mobile radio, try our Desktop Versions. These are configured to attach to the radio forming one dedicated unit and are available for a variety of radios including Motorola, Icom, Kenwood, Tait, Maxon and Vertex. Product Coding The product code is developed as follows taking the AD 115/230-12 108 as an example: AD 115/230 -12 108 AC input and DC output Denotes auto select US or European AC input voltage Nominal 12V output 108W Capacity Unit PPoow weerr C Coonnvveerrssiioonn for A Auuttoom moottiivvee,, C Coom mm muunniiccaattiioonnss and M Maarriinnee A Apppplliiccaattiioonnss Choose your AD Series Product Output Voltage P R C O O D D 12Vdc 24Vdc 48Vdc Power Dimensions Weight AD 115/230-12 036 AD 115/230-24 036 AD 115/230-48 036 36W 165 x 87 x 59mm 675g AD 115/230-12 072 AD 115/230-24 072 AD 115/230-48 072 72W 165 x 87 x 59mm 675g AD 115/230-24 108 AD 115/230-48 108 U E AD 115/230-12 108 108W 165 x 87 x 59mm 675g C S AD 115/230-12 168 AD 115/230-24 168 AD 115/230-48 168 168W 215 x 87 x 59mm 900g AD 115/230-12 240 AD 115/230-24 240 AD 115/230-48 240 240W 255 x 87 x 59mm 1150g T Additional Loom for battery charging – P/N: AD BB Loom Technical Data Input voltage range Auto-Select, 85-135Vac and 170-265Vac, 47-440Hz Output voltage options 13.6Vdc, 27.2Vdc or 54.4Vdc, as ordered . Worst case limits are +/- 4% Output noise
AD115/230-12 108 价格&库存
很抱歉,暂时无法提供与“AD115/230-12 108”相匹配的价格&库存,您可以联系我们找货
