HSE231
HSE231
    BROTHER
    BROTHER - HSE231 - Wire Marker, Heat Shrinkable Sleeve, Blank (No Legend), White, 11.7mm x 1.5m, 7 m...
HSE231 数据手册
Technical data for Brother TZe Tapes Laminated Why do Brother P-Touch laminated labels last longer? Unlike ordinary labels, our unique laminated tape technology ensures that a layer of superclear polyethylene laminate protects your text. protective coating (PET) 38µm lettering adhesive (acrylic) base film (PET) colour layer for the base film adhesive (acrylic) backing paper Brother P-touch laminated TZe tapes consist of seven layers of materials, resulting in a thin, extremely strong label. Characters are formed with a thermal transfer ink and sandwiched between two protective layers of PET (polyester film). The result is a virtually indestructible label that can withstand even the harshest conditions. In fact, we are sure about the durability of our labels because we’ve tested them to the extreme, against the effects of abrasion, temperature, chemicals and sunlight. Results prove that Brother P-touch laminated labels out perform competitor labels, staying legible and affixed, so you can be confident of a professional quality label that has been designed to last. And we can prove it. The following pages will show you exactly how our labels are tested to the extreme. Patented lamination provides an extra protective overcoat. Laminated Abrasion Resistant Abrasion Resistant Labels Brother’s patented tape lamination technology ensures that Brother P-touch laminated labels can withstand even heavy abrasion. The Abrasion Test Procedure A 1kg sanding device was passed over Brother P-touch laminated labels, and nonlaminated competitor labels. After 50 return passes the characters underneath the Brother P-touch laminated label were completely unaffected and the lamination was only slightly scratched Abrasion Test Results Brother P-Touch laminated TZe label = No effect on print quality Competitor non-laminated label = Print quality affected Brother P-Touch Laminated Label Non-Laminated Competitor Label Can withstand heavy abrasion Abrasion Resistant Temperature Resistant Temperature Resistant Labels Whether you want to use our labels in freezing conditions or alternatively in extremely warm environments, our labels have been designed to last, we know this because we’ve tested them to the extreme. In fact, results show that Brother P-touch laminated labels can withstand temperatures from -80°C to 150°C. The Temperature Test Procedure Brother P-touch laminated labels, slightly roughened with abrasive paper, were attached to stainless steel then heated and cooled. After 240 hours at -80°C no noticeable change in tape adhesive or colour had occurred. After 240 hours at 150°C, despite slight discolouration, the text on the label remained completely intact, and the heat actually increased the tapes’ adhesive strength, due to a slight softening and spreading of the adhesive.* We recommend TZe-M931/951/961 (Black on matt silver) as most resistant to high temperatures in terms of discolouration. Test Results Label performance after exposure to head and cold Temperature Hours Tape Condition = no noticeable change = text is legible but there is some tape discolouration *When tape is subject to extremely high temperatures for long periods the laminate film may be separated or discoloured, or it may shrink. Test: Temperature Temperature: 100°c Duration: 240 hours Labels: Brother P-touch Laminated Label Resistant to temperatures of -80°C to 150°C Temperature Resistant Fade Resistant Fade Resistant Labels Wherever you use P-touch laminated labels, they have been designed to stay as clear and legible as the day they were applied. The Fade Test Procedure Several Brother P-touch laminated labels, in various colours, were attached to coated metal plates and placed inside a fade-inducing chamber at 83°C. They were left for a period of 100 hours to simulate a year in sunny surroundings and then inspected for any obvious changes. The text colour remained unchanged and so all characters were still completely legible. To the naked eye, the tapes’ background colour showed no change, except for the yellow tape which showed some slight fading. Abrasion Test Results Test: Fade Meter Temperature: 83°c Duration: 100 Hours Labels: Brother P-touch Laminated Labels ABCDE ABCDE ABCDE Before Testing Resistant to ultra violet exposure Fade Resistant ABCDE ABCDE ABCDE After Testing Chemical Resistant Water Resistant Water and Chemical Resistance Water and chemical resistance tests were conducted in two stages: Stage 1 - The water and chemical submersion test Stage 2 - The water and chemical abrasion test Stage 1 Water and Chemical Submersion Test Procedure To test Brother P-touch laminated labels against the effects of water and chemicals, the tapes were firstly attached to glass slides and immersed in a variety of liquids for 2 hours. No change in appearance or structure of the labels occurred, and the labels remained affixed to the slides. Although some labels soaked in certain chemicals showed minor changes, rubbing the labels with the same chemicals had no effect at all. So even if chemicals are spilled on your Brother P-touch laminated labels, a quick wipe should be enough to prevent any damage. Test Results for Brother P-Touch Laminated Toluene Hexane Ethanol Ethyl Acetate Acetone Mineral Spirit Water 0.1N Hydrochloric • • • • • • • • • = no print discolouration • Test: Water and Chemical Submersion Chemical: Ethanol Duration: 2 hours Labels: Brother P-touch Laminated Label Resistant to water and a wide range of industrial chemicals Chemical Resistant Water Resistant 0.1 Sodium Hydroxide Stage 2 Water and Chemical Submersion Test Procedure Brother P-touch laminated tape was affixed to several glass plates. A 500g weight with a chemical and solvent infused cloth was passed over each label 20 times. As the results below show, the print quality of Brother P-touch laminated labels was unaffected, unlike our competitor’s non-laminated labels. Toluene Hexane Ethanol Acetone Ethyl Acetate Water 0.1N Hydrochloric Mineral Spirit 0.1 Sodium Hydroxide Test Results P-Touch Laminated Label • • • • • • • • • Non-Laminated Competitor Label x • • x x • • • • • = Print quality unaffected x = Print quality affected Labels after Testing Test: Chemical Abrasion Chemical: Acetone Brother P-Touch Laminated Label Non-Laminated Competitor Label Strong Adhesion Strong Adhesion The Adhesion Test Procedure To test the adhesive strength of Brother P-touch laminated tapes, 12mm standard tape and extra strength adhesive tape were affixed to a variety of objects, all with different surfaces, and left for 30 minutes. Adhesive strength was tested by removing the tape at an angle of 180 degrees. Test Results The table explains that an adhesive strength of approximately 6 Newtons* was maintained with most materials. Our strong adhesive tape maintained an average of 50% more adhesive strength compared to our standard tape and is suitable for more demanding surfaces such as polypropylene. Stainless Steel Glass PVC Acrylic Polypropylene Polyester Coated Wood Standard TZe Tape 7.6 7.2 8.6 6.9 3.3 6.4 Extra Strong Adhesive TZe Tape 10 10.1 11.5 11.5 7.4 11.5 *Results in Newtons for 12mm width tape Strong Adhesion Strong adhesive to a wide range of surfaces Get Organised With Labels That Stick Colour Description 6mm 9mm 12mm 18mm 24mm 36mm ABC Black on Clear Laminated TZe-111 TZe-121 TZe-131 TZe-141 TZe-151 TZe-161 ABC Black on White Laminated TZe-211 TZe-221 TZe-231 TZe-241 TZe-251 TZe-261 ABC Blue on White Laminated - TZe-223 TZe-233 TZe-243 TZe-253 TZe-263 ABC Red on White Laminated - TZe-222 TZe-243 TZe-242 TZe-252 TZe-262 Products ABC White on Black Laminated ABC White on Blue Laminated ABC Black on Yellow Laminated ABC Black on Blue Laminated TZe-315 TZe-325 TZe-335 TZe-345 TZe-355 - - - TZe-535 - TZe-555 - Tze-611 Tze-621 TZe-631 Tze-641 TZe-651 Tze-661 - Tze-521 TZe-531 Tze-541 TZe-551 Tze-561 ABC Blue on White Iron on Fabric Tape - - TZe-FA3 - - - ABC Black on Red Laminated - Tze-421 TZe-431 Tze-441 TZe-451 Tze-461 ABC Black on Green Laminated - Tze-721 TZe-731 Tze-741 TZe-751 - 6mm PT-900, PT-1000, PT-1010, PT-1090, PT-H105, P1230PC, PT-1280, PT-1290, PT-D200, PT-1400, PT-1650, PT-7600, PT-1750, PT-1830, PT-1880, PT-2420PC, PT-2430PC, PT-9500PC, PT-9700PC, PT-9800PCN, PT-1950, PT-2300, PT-3600, PT-9600, PT-2100, PT-2700, PT-7100VP, PT-2030, PT-2730, PT-E100VP, PT-H300Li, PT-E300VP 9mm PT-900, PT-1000, PT-1010, PT-1090, PT-H105, PT-1230PC, PT-1280, PT-1290, PT-D200, PT-1400, PT-1650, PT-7600, PT-1750, PT-1830, PT-1880, PT-2420PC, PT-2430PC, PT-9500PC, PT-9700PC, PT-9800PCN, PT-1950, PT-2300, PT-3600, PT-9600, PT-2100, PT-2700, PT-7100VP, PT-2030, PT-2730, PT-E100VP, PT-H300Li, PT-E300VP 12mm PT-900, PT-1000, PT-1010, PT-1090, PT-H105, PT-1230PC, PT-1280, PT-1290, PT-D200, PT-1400, PT-1650, PT-7600, PT-1750, PT-1830, PT-1880, PT-2420PC, PT-2430PC, PT-9500PC, PT-9700PC, PT-9800PCN, PT-1950, PT-2300, PT-3600, PT-9600, PT-2100, PT-2700, PT-7100VP, PT-2030, PT-2730, PT-H300Li, PT-E300VP 18mm PT-1400, PT-1650, PT-7600, PT-1750, PT-1830, PT-1880, PT-2420PC, PT-2430PC, PT-9500PC, PT-9700PC, PT-9800PCN, PT-1950, PT-2300, PT-3600, PT-9600, PT-2100, PT-2700, PT-2030, PT-2730 18mm PT-1400, PT-1650, PT-7600, PT-2420PC, PT-2430PC, PT-9500PC, PT-9700PC, PT-9800PCN, PT-2300, PT-3600, PT-9600, PT-2700, PT-2730 Note: The above tapes are 8 metres in length except for the fabric tape which is 3 metres in length Heat Shrink Heat Shrink Black on White* 5.8mm 8.8mm 11.7mm 17.7mm HSE-211 HSE-221 HSE-231 HSE-241 *Compatible with PT-E300VP only For more information, visit www.brother.com.au/our-technology/electronic-labeller/labelling-tapes Choosing The Right Tape Choose the right tape for the job Smooth Flat Surface Textured Large Curved Surface (more than 8mm diameter) Small Curved Surface (less than 8mm diameter) Smooth Textured Smooth Textured = Recommended = Acceptable = Not Recommended Choose the right tape for the job Choosing The Right Tape Security Tapes Flexible Tapes Strong Adhesive Tapes TZe Laminated Tapes Brother P-touch laminated tapes are available in a wide range of tape colours, widths and styles. Your application and your choice of P-touch model should guide your ultimate tape selection. The table below will also help you to determine the correct tape for your applications. Frequently Asked Questions How thick are TZe tapes? TZe tapes are around 160 micro metres in thickness but this varies slightly by tape type. Which colour tape is recommended for high temperatures? We recommend TZe-M931/951/961 (Black on matt silver) as most resistant to high temperatures in terms of discolouration. When I remove the label will messy adhesive remain? How can I remove it? Tapes can be removed from most materials with relative ease leaving little or no adhesive on the material. Extreme heat, humidity and certain chemicals may result in some residual adhesive being left but this can be removed in most cases with Ethanol. What is the shelf life of an unused TZe tape? The shelf life of an unused TZe tape is 15 months from production. Do TZe tapes contain chloride? No chloride materials are used in the cassette case, tape or ink. Do TZe tapes create any outgasing? The following gases may be produced when labels are in a hot environment such as in front of an air conditioner: toluene, n-butanol, 2-ethylhexyl alcohol, butyl carbinol acetate. These levels are however very low. Can TZe tapes be submerged in alcohol? Submersion of TZe tapes in alcohol is not recommended for extended periods due to the possible deterioration of the tape adhesive. Is it safe to burn a P-touch label? Although there may be some halogen in TZe tapes, it is of a very low level making it safe to burn TZe tapes. Do TZe tapes contain silicon? Since the tape liner itself is silicon coated on both sides, there is a chance that small amounts of silicon may remain on the adhesive layer underneath the label even after the liner is peeled off. Strong Adhesion Strong adhesive to a wide range of surfaces Do TZe tapes create static electricity? When peeling off the tape liner there may be some very low levels of static electricity. Do TZe tapes contain vinyl chlorine? TZe laminated tapes contain very low levels of residual chlorine. Which colour tape fades the least? We recommend TZe-M931/951/961 (Black on matt silver) as our most fade resistant tape. Fluorescent tapes are not recommended. Do TZe tapes contain latex? TZe tape uses acryl based adhesive materials and do not include latex. Does TZe tape contain lead? There is no lead in the cassette case, tape or ink. Can TZe tapes be used on circuit boards? We do not recommend that TZe tapes are used on circuit boards due to the sensitivity of circuit boards to dust, static electricity and acid (although these are at very low levels in TZe tapes) Can TZe tapes be used on copper? As adhesive materials used in our tape are acrylic and weakly acid we do not recommend that TZe tapes are used on copper. How long should security tape be attached before peeling off? We recommend that TZe security tape is affixed for at least 24 hours in order to work effectively. UL Certification A number of our TZe tapes have been tested by Underwriters Laboratories, a renowned independent testing laboratory. Our tapes have passed their rigorous safety standards and gained UL certification and we continue to test more tapes. For latest certification details and a list of certified tapes please contact your local Brother office. Can withstand heavy abrasion Abrasion Resistant Brother offers lifetime Australian based product support. Contact your local Brother representative for full product range. For further information on Brother products or services, or to arrange a free evaluation of your printing environment, please contact the Brother Commercial Team on 1300 885 989 or email: corporatesales@brother.com.au Brother International (Aust) Pty Ltd. Microsoft, Windows, the Windows logo and/or other Microsoft products referenced herein are either registered trademarks of Microsoft Corporation in the U.S. and/or other countries. Brother and its logo are trademarks of Brother and its logo are trademarks of Brother Industries Ltd., Japan. All specifications are subject to change without notice. All registered trademarks referenced herein are the property of their respective companies. TZe_Technical_Data : 18, February, 2014
HSE231 价格&库存
很抱歉,暂时无法提供与“HSE231”相匹配的价格&库存,您可以联系我们找货
