AR166-F-LC
AR166-F-LC
    ARM(安谋控股)
    AR166 (FLOATING) LIC
AR166-F-LC 数据手册
ARTX-166 Advanced RTOS Product Overview ARTX-166 is an advanced real-time kernel for the Infineon XC16x and C16x as well as the STMicroelectronics ST10 families of microcontrollers. It is designed to solve several problems in embedded programs:   Multitasking allows you to manage several jobs (tasks) on a single CPU. Real-time Control allows you to configure tasks so that operations execute within a defined period of time. You have control over task priorities, round-robin, preemptive context switching, and support for multiple instances of the same task function.  Flash File System allows you to create, save, read and modify files stored on a standard Flash memory device.  TCP/IP Networking is a ground-up implementation specifically designed for embedded applications. It helps you to create TCP/IP solutions that connect to standard internet browsers. While it is possible to implement an embedded program without using a real-time kernel, a proven kernel like ARTX saves time and makes software development easier.
AR166-F-LC 价格&库存
很抱歉,暂时无法提供与“AR166-F-LC”相匹配的价格&库存,您可以联系我们找货
