DS500-RD-40R2D
DS500-RD-40R2D
    ARM(安谋控股)
    RVDS TO DS-5 PE FL LIC DL CONV S
DS500-RD-40R2D 数据手册
Arm DS-5 Development Studio The most powerful Integrated Development Environment (IDE) for embedded Arm® systems. developer.arm.com/ds-5 ARM-DS-5-Flyer-2017 - resources section edited.indd 1 25/01/2017 10:22:06 Arm DS-5 Development Studio • Support for all Arm processors • Industry leading C/C++ compilation tools • Powerful OS-aware multicore debugger • Debug support for all phases of development including bootloader, kernel and user space • Streamline performance analyzer for system-wide profiling based on performance counters • Powerful C/C++ editor and project manager based on Eclipse • Fast simulator for software development on the host computer with typical speeds above 250 MHz Arm DS-5 Development Studio - An end-to-end suite of tools for embedded C/C++ software development on any Arm-based SoC • Technical support from Arm experts Arm C/C++ Compiler DS-5 Debugger The result of over 25 years’ investment in compiler technology, the Arm Compiler embedded toolchain has been used to build ultra-efficient C/C++ code shipping in billions of Arm-based devices on the market. The DS-5 Debugger builds on the most advanced Arm technologies, such as Arm CoreSight™ Debug and Trace, to equip developers with a flexible debug solution for tasks from hardware bring-up and OS porting to application development. Key advantages: Key advantages: • Developed alongside Arm architecture for most efficient code generation for Arm processors • Pre-configured support for a large range of Arm based devices • Best-in-class code size using link-time optimization and Arm C microlib library • Platform Configuration Editor (PCE) to bring-up a new SoC in a simple and flexible way • Performance tuning for real-world embedded applications, not simple benchmarks. Up to 38% faster than v5.06 • Full task-aware debug, offering individual run control and breakpoints for specific tasks or threads • Certified by TÜV SÜD for use in functional safety applications up to the highest integrity levels • Full multi-processor support, allowing you to simultaneously control all Arm devices in your system • Support for the newest language standards like C++11 and C++14. • Cycle accurate non-intrusive instruction and data trace RAM • Visibility into RTOS internal data structures such as interrupts, semaphores and task queues. Relative code size [RTX 5 project] +30% AC 6.6 GCC 5u2 ROM • Linux kernel and user space debug, including context awareness and control of individual processes and threads +48% developer.arm.com/ds-5 ARM-DS-5-Flyer-2017 - resources section edited.indd 2 25/01/2017 10:22:07 Streamline The Arm Streamline performance analyzer is a system-wide performance analysis tool to analyse Linux, Android and baremetal embedded systems. Through a lightweight agent running on the target, Streamline captures the target’s performance information from the CPU, GPU and OS. Key advantages: • Per core visualization of performance metrics and thread activity for optimal code parallelization • System wide performance counter analysis enabling developers to easily identify performance bottlenecks, multithreading issues and inefficient resource usage • Correlation between software execution and power consumption data • Analysis of hot spots down to the source and disassembly level • Flexible filtering capabilities to restrict the data set under analysis (e.g. per thread, in a particular time slice, etc). DSTREAM family Fixed Virtual Platforms The Arm DSTREAM family of high-performance debug and trace units enable powerful software debug and optimization on any Arm-based hardware target. Develop bare metal and Linux software without a hardware target using Fixed Virtual Platform (FVP). The probes allow DS-5 Debugger to connect to the SoC via JTAG (speeds up to 200MHz) or Serial-Wire Debug. It delivers high download speeds (up to 16MBytes/s) and fast stepping through code on single and multi-core devices. The DSTREAM family offers varying capabilities to provide the optimum solution for any SoC or particular use case. Trace capabilities vary from narrow-port (4 pin) parallel streaming trace captured on a host PC, to wide-port (16 pin) parallel trace stored on large built-in trace buffers. FVP is a fast simulation model of an Arm-based SoC with processor, memory, and peripherals required to run complex operating systems and user applications. FVPs run at speeds comparable to the real hardware and significantly cut your development time. For a comparison see: developer.arm.com/debug-probes DS-5 ships with sample FVPs and example projects to kickstart your development. developer.arm.com/ds-5 ARM-DS-5-Flyer-2017 - resources section edited.indd 3 25/01/2017 10:22:10 Arm DS-5 Development Studio Mali Graphics Debugger Getting started The Arm Mali™ Graphics Debugger is an API level tracer for OpenGL® ES 2.0, 3.x, Open CL™ and Vulkan®. As the Mali Graphics Debugger intercepts all calls it is in the unique position to help the user analyse their application and pinpoint areas for optimization. You can find step-by-step tutorials, product documentation and videos on developer.arm.com to get you started with DS-5 in almost no time. Key advantages: Follow the Getting Started with DS-5 online tutorial to download and install DS-5, setup a license, write your first program, compile and run it on a FVP. • Render frames drawcall by drawcall and inspect scene compositions Evaluation • Record application assets to see textures, framebuffers and shaders • Inspect shader cycle count performance statistics. Download the latest version of DS-5 Ultimate Edition from developer.arm.com/ds-5/downloads and evaluate all the features for 30 days. Sample code DS-5 comes with extensive code examples that include baremetal startup code, Linux kernel and application debug and Streamline usage amongst others. Arm technical support Arm expert technical support is available to customers with a support and maintenance contract.Visit developer.arm.com/ support for more information. Product Edition Ultimate Professional* Compiler   Arm Compiler for embedded Compiler qualification kit for functional safety Compiler extended maintenance     Debugger   Fixed Virtual Platform   Streamline   Mali Graphics Debugger   * DS-5 Professional Edition supports a subset of ARM cores. Please visit our website to see the list of cores supported. Arm Ltd. www.arm.com UK salesinfo-eu@arm.com EUROPE salesinfo-eu@arm.com JAPAN salesinfo-cn@arm.com TAIWAN salesinfo-cn@arm.com CHINA salesinfo-cn@arm.com USA salesinfo-us@arm.com ASIA PACIFIC salesinfo-cn@arm.com KOREA salesinfo-cn@arm.com ISRAEL salesinfo-eu@arm.com INDIA salesinfo-in@arm.com All brand names or product names are the property of their respective holders. Neither the whole nor any part of the information contained in, or the product described in, this document may be adapted or reproduced in any material form except with the prior written permission of the copyright holder.The product described in this document is subject to continuous developments and improvements. All particulars of the product and its use contained in this document are given in good faith. All warranties implied or expressed, including but not limited to implied warranties of satisfactory quality or fitness for purpose are excluded.This document is intended only to provide information to the reader about the product.To the extent permitted by local laws ARM shall not be liable for any loss or damage arising from the use of any information in this document or any error or omission in such information. Program examples and detailed technical information are available from your distributor and our web site (developer.arm.com). ARM-DS-5-Flyer-2017 - resources section edited.indd 4 © ARM Ltd. | 01.17 25/01/2017 10:22:10
DS500-RD-40R2D 价格&库存
很抱歉,暂时无法提供与“DS500-RD-40R2D”相匹配的价格&库存,您可以联系我们找货
