DS5CK-KD-3RN21
DS5CK-KD-3RN21
    ARM(安谋控股)
    DNLD RENESAS VERSION NL 1YR
DS5CK-KD-3RN21 数据手册
Arm Keil MDK Microcontroller Development Kit Arm® Keil® MDK is the most comprehensive software development solution for Arm Cortex®-based microcontrollers. Every MDK edition includes IDE, C/C++ compiler, debugger, software pack management, and CMSIS. MDK-Core offers leading support for over 3,750 Cortex-M based devices including the new Arm Cortex-M23/M33 cores. The µVision debugger includes event recorder and component viewer to show run-time behavior of software components. Together with the ULINKpro™ debug adapter, it offers full instruction trace and complete code coverage information. DS-MDK contains the Eclipse-based DS-5 IDE/debugger and supports 32-bit Cortex-A processors or hybrid systems with 32-bit Cortex-A and Cortex-M. Streamline performance analyzer helps to get the best out of the system’s resources and create high performance, energy efficient products. The industry-leading Arm C/C++ Compilers with assembler, linker, and highly optimized run-time libraries are tailored for optimum code size and performance. Arm Compiler 5 is certified for functional safety applications and offers long-term maintenance and support. Arm Compiler 6 offer the best code size currently on the market. It offers various optimization levels including Link Time Optimization. This diagram shows the code size. Software packs can be added any time to MDK-Core or DSMDK making new device support and middleware updates independent from the toolchain. They contain device support, CMSIS libraries, software components, middleware, board support, code templates, and example projects. MDK middleware provides royalty-free, tightly-coupled software components that are specifically designed for communication peripherals in microcontrollers. developer.arm.com/armcompiler6 www.keil.com/mdk MDK editions and ULINK debug adapters Professional Plus Essential Lite         32 KB        32 KB                    µVision IDE with Editor, Pack Installer Debugger Fixed Virtual Platforms Simulation Models DS-MDK (Windows® host + Linux® host) Support for heterogenous systems (Linux Cortex-A, RTOS Cortex-M) Streamline system analysis Arm Compiler C/C++ Compilation Tools Extended Maintenance and Qualification Kit Arm processor support Arm Cortex-M0 .. Cortex-M7 Arm Cortex-M23/33 Non-Secure Arm Cortex-M23/33 Secure + Non-Secure Armv8-M architecture + FastModel Arm SecurCore™ (SC000, SC300) Arm7, Arm9, Arm Cortex-R4   RTOS and Middleware CMSIS-RTOS RTX with full source code Middleware (IPv4 Network, USB Device, File System, Graphics) Middleware (IPv6 Network, USB Host, IoT Connectivity) www.keil.com/editions Features Run control Memory and breakpoint Data trace Instruction trace ULINKpro ULINKplus ULINK2           50 MHz 1 MB/s 100 Mbit/s 800 Mbit/s 50 MHz 3 MB/s 50 Mbit/s 50 MHz 25 KB/s 1 Mbit/s         Performance JTAG clock speed Memory read/write Data and event trace Instruction trace Analysis tools ULINKplus is a universal debug and trace adapter that enables test automation, software optimization for ultra-low-power applications, and isolation for debugging sensitive hardware systems. The compact enclosure allows usage in harsh environments and provides standard target connectors for JTAG, power measurement, and general purpose I/O. Component viewer Event recorder Power measurement General purpose I/Os Performance analyzer Execution profiler Code coverage    www.keil.com/ulink Europe: +49 89 45 60 40 - 20 sales.intl@keil.com support.intl@keil.com United States: +1 800 348 8051 sales.us@keil.com support.us@keil.com All brand names or product names are the property of their respective holders. Neither the whole nor any part of the information contained in, or the product described in, this document may be adapted or reproduced in any material form except with the prior written permission of the copyright holder. The product described in this document is subject to continuous developments and improvements. All particulars of the product and its use contained in this document are given in good faith. All warranties implied or expressed, including but not limited to implied warranties of satisfactory quality or fitness for purpose are excluded. This document is intended only to provide information to the reader about the product. To the extent permitted by local laws ARM shall not be liable for any loss or damage arising from the use of any information in this document or any error or omission in such information. www.keil.com/mdk
DS5CK-KD-3RN21 价格&库存
很抱歉,暂时无法提供与“DS5CK-KD-3RN21”相匹配的价格&库存,您可以联系我们找货
