ECT818000500
ECT818000500
    ECT(电连)
    SMD
ECT818000500 数据手册
ECT Shenzhen Electric Connector Technology Co.,Ltd 深圳市电连精密技术有限公司 Product Specification P/ N: 818000500 DOC. No.: 651-0500-01 Approved/Date Rev.: B Page: 1/10 Check/Date Design/date ~ Kenny 08/01,12 SAM 08/01,12 1. Application(应用): This SMT type Micro coaxial RF Rec.products are designed for Mobile phones, Wireless LAN, Mini-PCI, Bluetooth, PDA, GPS, electronic measuring instruments, etc 该系列产品设计用于移动电话, 无线LAN, Mini-PCI, 蓝牙,PDA, GPS, 电子测量仪器等等. 2.Scope(范围): This specification covers the requirements for product performance, test methods and quality assurance provisions of USS RF Receptalce(IV Generation )Connectors. 本规范内容包括 USS RF 母座(第四代)射频同轴连接器的产品性能、测试方法及品质保证方 面的要求。 3. Technology Parameters(技术参数) 3.1 Voltage Rating(额定电压) 3.2 Frequency Range(频率范围) 3.3 Nominal Characteristic Impedance(特征阻抗) 3.4 Operating Temperature Range(工作温度范围) 3.5 Operating Humidity(工作湿度) 4. Ratings(额定性能要求) 4.1 Initial Insulation Resistance(绝缘电阻) 4.2 Contact Resistance(接触电阻) 4.2.1 Inner Contact (内导体) 4.2.2 Outer Contact (外导体) 4.3 Withstand Voltage(耐电压) 4.4 V .S .W. R*(电压驻波比) 5. Electrical Performance(电性性能) Items No (项目) 5.1 60VAC (R.M.S) DC~6G Hz 50±5 Ohm -40℃~+85℃ 95% R.H.MAX 500 M Ohm 20 milliohm Max. (Initial初始值) 20 milliohm Max. (After tested试验后) 20 milliohm Max. (Initial初始值) 20 milliohm Max. (After tested试验后) 200V AC 1 Min. 1.3Max.( DC~3GHz);1.4Max.(3~6GHz) Test Condition (测试条件) ( IEC512-2-1(2a) ) Solder the receptacle connector to the test board and mate the plug connector together, then measure the contact resistance as shown in figure 1 by the four terminal Contact method。 Resistance 将母座焊接在测试板上,并且将公头插合在 (接触电阻) 焊好的母座上,采用四种端接方式(如下图 1)依 次测量电阻值. Open circuit voltage/放电压: 20mV MAX Circuit current/电流: 10mA MAX Specifications (规格) Inner contact(中心导 体): Initial:20mΩ MAX After:20mΩ MAX Ground contact(外导 体) Initial:20mΩ MAX After:20mΩ MAX Product ECT Shenzhen Electric Connector Technology Co.,Ltd DOC. No.: 651-0500-01 Specification Approved/Date P/ N: 深圳市电连精密技术有限公司 Rev.: B Check/Date Design/date ~ Kenny 08/01,12 SAM 08/01,12 818000500 Page: 2/10 Inner Contact/中心导体 A - B Ground Contact/外导体 D - C Figure 1 5.2 5.3 Insulation Resistance (绝缘电阻) Mate the plug and receptacle connector together,and then, apply DC 200 V Voltage between the inner contact and the ground contact in accordance with IEC 512-4-1(3a) 按照 IEC 512-4-1(3a),将公母头配合在一起, 然后在内导体和拉地端之间施加 200V DC 的 电压,然后,进行相关的测试。 Mate the plug and receptacle connector together,and then apply AC 200 V between the inner contact and the ground contact in Dielectric accordance with IEC 512-4-1(4a) withstanding 按照 IEC 512-4-1(4a)标准,将公母头配合在一 voltage 起,然后在内导体和接地外导体之间施加 200V (耐电压) AC 的电压,并进行相关测试。 Measure the V.S.W.R as shown in figure 2 by the network analyzer Frequency:DC~11GHz 通过网络分析仪测试 V.S.W.R,频率范围为 DC~6GHz.如图 1 所示。 5.4 V.S.W.R (电压驻波 比) Figure 2 NA TEST CABLE Initial 初始值: 500 MΩ Min. After 测试后: 100 MΩ Min. No flashover, No sparkover, No excess leakage, No breakdown 无瞬断、熔闪、漏电、 击穿。 1.3 Max. (DC~3GHz); 1.4Max. (3~6GHz); Product ECT Specification Shenzhen Electric Connector Technology Co.,Ltd 深圳市电连精密技术有限公司 P/ N: 818000500 DOC. No.: 651-0500-01 Approved/Date Rev.: B Page: 3/10 Check/Date Design/date ~ Kenny 08/01,12 SAM 08/01,12 6. Mechanical Performance(机械性能) No Items (项目) Un-mating Force 6.1 (拔出力) 6.2 Durability (机械寿命) Test Condition (测试条件) IEC 512-15-4(15d) Solder the receptacle connector to the test board and mate the plug connector, then measure the un-mating force at speed 25± 3mm/minutes along by the push-push machine 将公母座完全配合到位后,将公母座分离到完 全分开位置并测试要求的拔出力, 速率:每分钟 25±3 毫米。 Mate and un-mate the receptacle connector(soldered to the test board) and plug connector 100 cycles at the speed of 25± 3mm/minutes along the mating direction by the push-push machine 将母座焊接在测试板上,然后,通过插拔力测 试仪沿配合方向以每分钟 25±3 毫米的速度插拔 公母头 30 个循环,然后测试参数。 6.3 Vibration (振动) IEC 512-6-4(6d) Apply the following vibration to the mating connector. During the testing,run 100mA DC to check electrical discontinuity. Frequency:10Hz→ 100Hz→ 10Hz/approx 20minutes. Half amplitude,Peak value of acceleration: 1.5mm or 59m/s²(6G) Directions,cycle:3 mutually perpendicular direction, 3 cycles about each direction 将公母头配合在一起,并施加如下振动条件测试。 在测试期间,施加 100mA DC 电压,并检验电 不连续性。 频率:10Hz→ 100Hz→ 10Hz/约 20minutes. 半振幅、加速度:1.5mm、59 m/s²(6G) 方向和循环次数: 每个互相垂直方向上进行 3 次测量。 Specifications (规格) 1.Initial(初值): 4N (0.4Kgf) Min. 2.After 30 Cycle (30 次插拔后): 2N(0.2Kgf) Min. Appearance: No abnormality Contact Resistance: Shall meet 5.1 外观:无损伤 接触电阻: 满足节 5.5.1 要求 Appearance: No abnormality Contact Resistance: Shall meet 5.5.1 No discontinuities of 1μs or longer duration 外观:无损伤 接触电阻:满足节 5.5.1 的要求, 电不连续性不超过 1μs。 Product ECT Specification Shenzhen Electric Connector Technology Co.,Ltd 深圳市电连精密技术有限公司 6.4 Shock (机械冲击) 7. Environmental No 7.1 DOC. No.: 651-0500-01 Approved/Date P/ N: 818000500 Rev.: B Page: 4/10 Check/Date Design/date ~ Kenny 08/01,12 SAM 08/01,12 IEC 512-6-3(6c) The object of this test procedure is to detail a standard method to assess the ability of a connector to withstand specified severity of mechanical shock. 此测试程序的目的是要作一详细标准以评估连接 器能承受特定严格机械冲击的能力。 Peak value of acceleration:735m/s²(75G) Duration :11ms Wave form : half sinusoidal Directions,cycle : 6 mutually perpendicula direction, 3cycles about each direction 振幅峰值,:735m/s²(75G) 持续时间:11 毫秒 波型:半正弦波 方向和循环次数:每 6 个相互垂直方向上各进次 3 次。 Appearance: No abnormality Contact Resistance: Shall meet 5.5.1 No discontinuities of 1μs or longer duration 外观:无损伤 接触电阻: 满足节 5.5.1 要求 电不连续性不超过 1μs Performance(环境性能) Items (项目) Humidity (湿度试验) Test Condition (测试条件) Apply the following environment to the mating connector in accordance with IEC 512-11-3(11c) Temperature : 25~65℃ Humidity : 90~95%R.H Duration: 96 hours 根据 IEC 512-11-3(11c)试验方法,对已配合的 连接器施加下列条件测试. 温度: 25~65℃ 湿度: 90~95%R.H 持续时间: 96 小时 Specifications (规格) Appearance: No abnormality Contact Resistance: Shall meet 5.5.1 Insulation Resistance: Shall meet 5.5.2 Dielectric withstanding voltage Shall meet 5.5.3 外观:无损伤 接触电阻:满足 5.5.1 绝缘电阻:满足 5.5.2 耐电压:满足 5.5.3 ECT Shenzhen Electric Connector Technology Co.,Ltd 深圳市电连精密技术有限公司 Product Specification P/ N: 818000500 DOC. No.: 651-0500-01 Approved/Date 7.2 7.3 Resistance to soldering heat (耐焊接热 试验) Page: 5/10 Check/Date Design/date ~ Kenny 08/01,12 SAM 08/01,12 Apply the following environment to the mating connector in accordance with IEC 512-11-4(11d) Temperature : -55~85℃ Transition time: : 5min. MAX Cycles: 5 Cycles Thermal Shock (冷热冲击) Rev.: B 根据 IEC 512-11-4(11d)方法,对已配合的连接 器施加下列条件测试. 温度: -55~85℃ 转换时间: 5 min Max. 循环次数: 5 次数 According to 8.8.1,Apply reflow soldering condition. Measurement after 24h+/-2h. 按 8.8.1 中曲线条件进行回流焊接,并在 24 小 时后进行相关测试. Appearance: No abnormality Contact Resistance: Shall meet 5.5.1 Insulation Resistance: Shall meet 5.5.2 Dielectric withstanding voltage Shall meet 5.5.3 外观:无损伤 接触电阻:满足节 5.5.1 中的要求 绝缘电阻:满足节 5.5.2 中的要求 耐电压:满足节 5.5.3 中的要求 Appearance: No abnormality Contact Resistance: Shall meet 5.5.1 Insulation Resistance: Shall meet 5.5.2 Dielectric withstanding voltage Shall meet 5.5.3 外观:无损伤 接触电阻:满足节 5.5.1 中的要求 绝缘电阻:满足节 5.5.2 中的要求 耐电压:满足节 5.5.3 中的要求 ECT Shenzhen Electric Connector Technology Co.,Ltd Product 7.5 Salt Spray (盐雾测试) solderability (可焊试验) Approved/Date P/ N: 深圳市电连精密技术有限公司 7.4 DOC. No.: 651-0500-01 Specification Check/Date Design/date ~ Kenny 08/01,12 SAM 08/01,12 818000500 IEC 512-11-6(11f) Apply the following environment to the mating connector Temperature : 35±2℃ Relative Humidity : 90~98%R.H Salt water density: 5±1% Duration : 48 hours 根据 IEC 512-11-6(11f)试验条件中的要求, 对已配合的连接器施加下列条件测试. 温度: 35±2℃ 相对湿度: 90~98%R.H 盐水浓度: 5±1% 持续时间: 48 hours Apply the following environment to the mating connector Temperature : 245±2℃ Duration : 3~5 second Test sample should be observed by the magnification of 10times after the test. 按下列条件对已配合的连接器进行测试. 温度: 245+/-2℃ 持续时间:3~5 秒钟. 观测:10 倍放大镜 Page: 6/10 Rev.: B Appearance: No abnormality Contact Resistance: Shall meet 5.5.1 外观:无损伤 接触电阻: 满足节 5.5.1 中的要求 At least 95% covered by a continuous new solder coating. 吃锡面积大于 95%以 上。 8、SMT Temperature Curve (SMT 温度曲线图) 8.2 Extremed Tem.&time curve of Re-flow 8.1 Recommanded Tem.&time relative curve of Re-flow. 回流焊极限温度与时间条件 温度 温度 建议回流焊温度与时间条件 时间( 时间( ECT Shenzhen Electric Connector Technology Co.,Ltd 深圳市电连精密技术有限公司 Product Specification P/ N: 818000500 DOC. No.: 651-0500-01 Approved/Date SAM 08/01,12 9. Profile Dimensions(外形规格) 10.Recommanded PCB LAYOUT(推荐的 PCB 安装焊盘规格) Rev.: B Page: 7/10 Check/Date Design/date ~ Kenny 08/01,12 ECT Shenzhen Electric Connector Technology Co.,Ltd 深圳市电连精密技术有限公司 Product Specification DOC. No.: 651-0500-01 Approved/Date P/ N: 818000500 Rev.: B Page: 8/10 Check/Date Design/date ~ Kenny 08/01,12 SAM 08/01,12 11.Packaging (包装) 11.1 上带的剥离力度:300mm/min 的速度进行剥离,力度最大应该是 1.3N Peeling off Force of Cover Tape:When cover tape is peeled off as in right figure by a speed of 300mm/minute.The peeling off force should be 1.3N maximum. 11.2 包装方式:载带包装,4000Pcs/卷(Ф178mm) The way of package :Tape packing,4000Pcs/Reel(Ф178mm) 160 160 Usage direction 50 Product ECT DOC. No.: 651-0500-01 Specification Shenzhen Electric Connector Technology Co.,Ltd Approved/Date P/ N: 深圳市电连精密技术有限公司 Page: 9/10 Check/Date Design/date ~ Kenny 08/01,12 SAM 08/01,12 818000500 Rev.: B 12. Usage Precaution(使用禁忌或注意事项) No Items (项目) Test Condition (测试条件) Specifications (规格) PCB 板设计时极性要求注意事项 (Note polarity requirements of the PCB design) PLUG Ground Contact PLUG Contact PLUG Insulator RECE Contact RECE Insulator RECE Ground Contact Crimping 12.1 配合高度较小的 USS 系列产品中 PCB 设计过程中,应避免 RECE Contact 与 Plug Ground Contact 卷边同向,以防止不小 心有按压旋转时 Plug Ground Contact 与 RECE Contact 短接. With the height of the smaller USS range of products PCB design process, you should avoid the the RECE Contact and Plug Ground Contact curling in the same direction to prevent the careless press rotating Plug Ground Contact and RECE Contact shorted. Stockpile condition 12.2 (存储条件) 1)存储温度 -10℃~+40℃ 2)工作湿度 85% R.H.MAX 3)有效期:请在产品接收后的 6 个月内使用 Product ECT DOC. No.: 651-0500-01 Specification Shenzhen Electric Connector Technology Co.,Ltd Approved/Date P/ N: 深圳市电连精密技术有限公司 Rev.: B Check/Date Design/date ~ Kenny 08/01,12 SAM 08/01,12 818000500 Page: 10/10 13. Test Sequence and Sample Quantity(测试顺序及样品数量) A B Group(测试分组) C D E F G 1, 1,6 1,5 1,5 1,6 1,6 1,6 1,4 2,7 2,4 2, 4 2,7 2,7 2,7 2,5 3,8 3,8 3,8 4,9 4,9 4,9 Test Item (测试项目) Examination of product (外观检测) Contact Resistance (接触电阻) Insulation Resistance (绝缘电阻) Dielectric Withstanding Voltage (耐电压) V.S.W.R (电压驻波比) Un-mating Force (拔出力) Durability (机械寿命) Vibration (振动) I 1,3 2, 3,5 4, 3, Shock (冲击) Humidity (湿度试验) Thermal Shock (冷热冲击) High Temperature Life (耐焊性测试) Salt Spray (盐雾测试) Solderability (可焊试验) Sample QTY(PCS) 样品数量 H 3, 5, 5, 5, 3, 2, 5 5 5 5 5 5 5 5 5
ECT818000500 价格&库存
很抱歉,暂时无法提供与“ECT818000500”相匹配的价格&库存,您可以联系我们找货
ECT818000500
    • 10+0.50501
    • 100+0.40652
    • 300+0.35727
    • 1000+0.32033
    • 5000+0.27540
    • 10000+0.26061
    库存:18193
