G401DS
G401DS
    JINGDAO(晶导微电子)
    TO-252(DPAK)
    G401DS 停产
G401DS 数据手册
山东晶导微电子股份有限公司 G401 THRU G410 Jingdao Microelectronics co.LTD GLASS PASSIVATED RECTIFIERS Reverse Voltage - 100 to 1000 V Forward Current - 4.0 A FEATURES • High current capability • Low forward voltage drop • Low power loss, high efficiency • High surge capability • High temperature soldering guaranteed • Mounting position: any ① ③ ② ④ ① ③ ② ④ MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS Ratings at 25℃ ambient temperature unless otherwise specified TO-251 G401VS G402VS G404VS G406VS G408VS G410VS TO-252 G401DS G402DS G404DS G406DS G408DS G410DS Maximum Recurrent Peak Reverse Voltage V RRM 100 200 400 600 800 1000 V Maximum RMS voltage V RMS 70 140 280 420 560 700 V Maximum DC Blocking Voltage V DC 100 200 400 600 800 1000 V Maximum Average Forward Rectified Current I F(AV) 4.0 A Peak Forward Surge Current,8.3ms Single Half Sine-wave Superimposed on Rated Load (JEDEC method) I FSM 140 A VF 1.1 V IR 5 500 uA Cj 50 pF RθJC 25 °C/W Tj -55 ~ +150 °C T stg -55 ~ +150 °C CHARACTERISTICS Units Max Instantaneous Forward Voltage at 4 A DC Maximum DC Reverse Current T a = 25°C at Rated DC Reverse Voltage T a =125°C Typical Junction Capacitance (1) Typical Thermal Resistance (2) Operating Junction Temperature Range Storage Temperature Range (1)Measured at 1 MHz and applied reverse voltage of 4 V D.C (2)P.C.B. mounted with 10cmX10cmX1mm copper pad areas. 2018.12 TO-251&TO-252-A-G401~G410-4A1KV Page 1 of 4 山东晶导微电子股份有限公司 G401 THRU G410 Average Forward Current (A) Fig.1 Forward Current Derating Curve 6.0 5.0 4.0 3.0 2.0 1.0 RESISTIVE OR INDUCTIVE LOAD 0.0 25 50 75 100 125 150 175 INSTANTANEOUS REVERSE CURRENT, (uA) Jingdao Microelectronics co.LTD Fig.2 Typical Instaneous Reverse Characteristics 1000 100 1.0 0.1 60 80 100 Percent of rated peak reverse voltage (%) Fig.4 Typical Junction Capacitance Junction Capacitance ( pF) 10 1.0 T J =25°C 100 10 T J =25°C 0.1 0.4 1 0.6 0.8 1.0 1.2 1.4 1.6 1.8 10 100 Instaneous Forward Voltage (V) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current Fig.6- Typical Transient Thermal Impedance 140 120 100 80 60 40 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 1.0 Reverse Voltage (V) 160 20 0.1 10 100 Transient Thermal Impedance( °C /W) Instaneous Forward Current (A) 40 20 0 Fig.3 Typical Forward Characteristic Peak Forward Surage Current (A) T J =25°C 0.01 Case Temperature (°C) 100 10 Number of Cycles at 60Hz 2018.12 T J =125°C 10 1 0.01 0.1 1 10 100 t, Pulse Duration(sec) www.sdjingdao.com Page 2 of 4 山东晶导微电子股份有限公司 G401 THRU G410 Jingdao Microelectronics co.LTD TO-251(D-PAK) Package Outline Dimensions A B C E L1 + D L M N b1 b G H F G TO-251(I-PAK) mechanical data UNIT A B b b1 C D E F G H L L1 M N max 6.7 5.5 0.8 0.9 2.5 6.3 0.6 1.8 0.55 4.3 1.2 min 6.3 5.1 0.3 0.76 2.1 5.9 0.4 1.3 2.29 TYPICAL 0.45 3.9 0.8 1.8 TYPICAL 1.3 TYPICAL max 264 217 31 35 98 248 24 71 22 169 47 min 248 201 12 30 83 232 16 51 18 154 31 71 TYPICAL 51 TYPICAL mm mil 90 TYPICAL Important Notice and Disclaimer Jingdao Microelectronics reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design, purchase or use. Jingdao Microelectronics makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Jingdao Microelectronics assume any liability for application assistance or customer product design. Jingdao Microelectronics does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Jingdao Microelectronics. Jingdao Microelectronics products are not authorized for use as critical components in life support devices or systems without express written approval of Jingdao Microelectronics. 2018.12 JD81225 Page 3 of 4 山东晶导微电子股份有限公司 G401 THRU G410 Jingdao Microelectronics co.LTD TO-252(D-PAK) Package Outline Dimensions A B C E L1 + D M N J K T S L2 L L3 b G H G F TO-252(D-PAK) mechanical data UNIT mm mil A B b C D E F max 6.7 5.5 0.8 2.5 6.3 0.6 1.8 min 6.3 5.1 0.3 2.1 5.9 max 264 217 31 98 min 248 201 12 83 G H L L1 L2 L3 S 1.2 1.0 1.75 0.1 0.4 0.55 3.1 2.29 TYPICAL 1.3 0.45 2.7 0.8 0.6 1.40 0.0 248 24 71 122 47 39 69 4 232 16 51 22 90 TYPICAL 18 106 31 24 55 0 M N J K T 3.16 1.80 4.83 1.8 1.3 TYPICAL TYPICAL ref. ref. ref. 124 71 190 71 51 TYPICAL TYPICAL ref. ref. ref. Jingdao Microelectronics reserves the right to make changes to this document and its products and specifications at any time without notice. Customers should obtain and confirm the latest product information and specifications before final design, purchase or use. Jingdao Microelectronics makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, not does Jingdao Microelectronics assume any liability for application assistance or customer product design. Jingdao Microelectronics does not warrant or accept any liability with products which are purchased or used for any unintended or unauthorized application. No license is granted by implication or otherwise under any intellectual property rights of Jingdao Microelectronics. Jingdao Microelectronics products are not authorized for use as critical components in life support devices or systems without express written approval of Jingdao Microelectronics. 2018.12 JD81225 Page 4 of 4
G401DS 价格&库存
很抱歉,暂时无法提供与“G401DS”相匹配的价格&库存,您可以联系我们找货
