FTB15SM
FTB15SM
    JINGDAO(晶导微电子)
    ABS
    特性:玻璃钝化芯片结-反向电压。600至1000V-正向电流。1.5A。快速反向恢复时间。专为表面贴装应用设计
FTB15SM 数据手册
山东晶导微电子有限公司 Jingdao Microelectronics FTB15SJ THRU FTB15SM 1.5A SURFACE MOUNT GLASS PASSIVATED BRIDGE RECTIFIER FEATURES: PINNING • Glass Passivated Chip Junction • Reverse Voltage - 600 to 1000 V • Forward Current - 1.5 A PIN DESCRIPTION 1 Input Pin(~) 2 Input Pin(~) • Fast reverse recovery time 3 Output Anode(+) • Designed for Surface Mount Application 4 Output Cathode(-) MECHANICAL DATA • Case: ABS/LBF • Terminals: Solderable per MIL-STD-750, Method 2026 • A pprox. Weight: 88mg / 0.0031oz 3 4 2 1 ABS/LBF Package Maximum Ratings and Electrical characteristics Ratings at 25 °C ambient temperature unless otherwise specified. Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %. Symbols FTB15SJ FTB15SK FTB15SM Units Maximum Repetitive Peak Reverse Voltage V RRM 600 800 1000 V Maximum RMS voltage V RMS 420 560 700 V Maximum DC Blocking Voltage V DC 1000 1000 1000 V Maximum Average Forward Rectified Current at T C = 125 °C I F(AV) 1.5 A Peak Forward Surge Current 8.3 ms Single Half Sine Wave Superimposed on Rated Load I FSM 50 A Maximum Instantaneous Forward Voltage at 1.5 A VF 1.3 V IR 5 50 μA Maximum Reverse Recovery Time(Note1) t rr 160 ns Typical Junction Capacitance at V R =4V, f=1MHz Cj 30 pF RθJA 65 16 °C/W T j , T stg -55 ~ +150 °C Parameter Maximum DC Reverse Current T A = 25 °C at Rated DC Blocking Voltage T A =125 °C Typical Thermal Resistance(Note2) Operating and Storage Temperature Range Note: 1. Measured at 1 MHz and applied reverse voltage of 4 V D.C 2. Mounted on glass epoxy PC board with 4×1.5"×1.5"(3.81×3.81 cm)copper pad. 2016.01 ABS-F-FTB15SJ~FTB15SM-1.5A1KV160ns Page 1 of 3 山东晶导微电子有限公司 Jingdao Microelectronics FTB15SJ THRU FTB15SM Fig.2 Typical Reverse Characteristics 1.8 1.5 1.2 0.9 0.6 0.3 0.0 25 50 75 100 125 150 175 Instaneous Reverse Current(μ A) Average Output Current (A) Fig.1 Forward Current Derating Curve 100 T J =125°C 10 1.0 T J =25°C 0.1 00 T J =25°C 1.0 0.1 pulse with 300μs 1% duty cycle 0.01 0.0 40 60 80 100 120 140 Fig.4 Typical Junction Capacitance Junction Capacitance ( pF) Instaneous Forward Current (A) Fig.3 Typical Instaneous Forward Characteristics 10 20 percent of Rated Peak Reverse Voltage (%) Case Temperature (°C) 100 T J =25°C 10 1 0.5 1.0 1.5 2.0 2.5 0.1 1.0 10 100 Reverse Voltage (V) Instaneous Forward Voltage (V) Peak Forward Surage Current (A) Fig.5 Maximum Non-Repetitive Peak Forward Surage Current 60 50 40 30 20 10 8.3 ms Single Half Sine Wave (JEDEC Method) 00 1 10 100 Number of Cycles 2016.01 www.sdjingdao.com Page 2 of 3 山东晶导微电子有限公司 Jingdao Microelectronics FTB15SJ THRU FTB15SM PACKAGE OUTLINE Plastic surface mounted package; 4 leads ABS/LBF ∠ALL ROUND ∠ALL ROUND C A a L1 d L HE e D e E ABS/LBF mechanical data A C D E HE d e max 1.5 0.22 5.2 4.5 6.4 4.2 0.7 min 1.3 0.15 4.9 4.2 6.0 3.8 0.5 max 59 8.7 205 177 252 165 28 min 51 5.9 193 166 236 150 20 UNIT mm L L1 a 0.95 0.6 0.2 ∠ 7° 37 mil The recommended mounting pad size 24 8 Marking Type number 6.2 244 Marking code FTB15SJ FT15SJ FTB15SK FT15SK FTB15SM FT15SM 4.0 157 1.0 39 FT15SM 2.0 79 2016.01 mm Unit : (mil) JD512285B6 Page 3 of 3
FTB15SM 价格&库存
很抱歉,暂时无法提供与“FTB15SM”相匹配的价格&库存,您可以联系我们找货
