ESD56281NXX
ESD56281NXX
http//:www.sh-willsemi.com
1-Line, Uni-directional, Transient Voltage Suppressor
Descriptions
The ESD56281NXX is a transient voltage suppressor
designed to protect power interfaces. It is suitable to replace
multiple discrete components in portable electronics.
The ESD56281NXX is specifically designed to protect USB
port and power lines.
DFN1006-2L (Bottom View)
The ESD56281NXX is available in DFN1006-2L package.
Standard products are Pb-free and Halogen-free.
Pin1
Features
Reverse stand-off voltage: 4.85V ~ 6.3V
Surge protection according to IEC61000-4-5
Circuit diagram
see Table 4
Pin2
ESD protection according to IEC61000-4-2
±30kV (contact and air discharge)
Low clamping voltage
Solid-state silicon technology
Pin1
x*
Pin2
Applications
Cell phone handsets and accessories
Power supply protection
Power management
__
X
= Device code(Y,Z ,Q)
= Month code (A~Z)
Marking (Top View)
Order information
Table 1.
Device
Package
Shipping
Marking
ESD56281N04-2/TR
DFN1006-2L
10000/Tape&Reel
Y*
ESD56281N05-2/TR
DFN1006-2L
10000/Tape&Reel
Z*
ESD56281N06-2/TR
DFN1006-2L
10000/Tape&Reel
Q*
Will Semiconductor Ltd.
1
__
Revision 1.1, 2021/01/19
ESD56281NXX
Absolute maximum ratings
Table 2.
Parameter
Peak pulse power (tp=8/20μs)
ESD according to IEC61000-4-2 air discharge
Symbol
Rating
Unit
Ppk
350
W
±30
VESD
ESD according to IEC61000-4-2 contact discharge
±30
kV
TJ
125
oC
Operating temperature
TOP
-40~85
oC
Lead temperature
TL
260
oC
TSTG
-55~150
oC
Junction temperature
Storage temperature
Electrical characteristics (TA = 25oC, unless otherwise noted)
I
VRWM Reverse stand-off voltage
IPP
IR
Reverse leakage current
VF
Forward voltage
VBR
Reverse breakdown voltage
IF
Forward current
IBR
Reverse breakdown current
VFC
Forward clamping voltage
VCL
Clamping voltage
IPP
Peak pulse current
VTRIG Reverse trigger voltage
ITRIG
IHOLD
VFC VF IBR
Reverse trigger current
VHOLD Reverse holding voltage
ITRIG
IR
IHOLD
VRWM
VBR
Reverse holding current
VTRIG
V
VCL
VHOLD
IF
IPP
Definitions of electrical characteristics
2
ESD56281NXX
Table 3.
Reverse
Stand off
Type number
Breakdown voltage
Voltage
VBR(V)
IBR = 1mA
VRWM (V)
Reverse
leakage current
IRM(nA) at VRWM
Junction
Forward voltage
capacitance
VF(V) IF = 20mA
F=1MHz,
VR=0V (pF)
Max.
Min.
Typ.
Max.
Typ.
Max.
Min.
Max.
Typ.
Max.
ESD56281N04
4.85
5.0
5.5
6.0
1
100
0.5
1.1
170
180
ESD56281N05
5.5
5.6
6.4
7.5
1
100
0.5
1.1
160
170
ESD56281N06
6.3
6.5
7.5
9.0
1
100
0.5
1.1
90
100
Table 4.
Type number
Rated peak pulse
current IPP (A)1)3)
Clamping voltage
Clamping voltage
Clamping voltage
Typ. VCL(V) at IPP(A)
Typ. VCL(V) at IPP =
Typ. VCL(V) at
2)3)
VESD = 8kV 2)3)
1)3)
16A, tp = 100ns
ESD56281N04
42
8.2
6.0
7.5
ESD56281N05
40
8.8
6.6
8.0
ESD56281N06
35
9.0
6.6
8.0
Notes:
1) Non-repetitive current pulse, according to IEC61000-4-5.(8/20μs current waveform)
2) Non-repetitive current pulse, according to IEC61000-4-2.
3) Measured from pin 1 to pin 2.
3
ESD56281NXX
100
90
Front time: T1= 1.25 T = 8s
100
90
Time to half-value: T2= 20s
Current (%)
Peak pulse current (%)
Typical characteristics (TA = 25oC, unless otherwise noted)
50
T2
10
10
T5
10
T1
15
Time (s)
30
Time (ns)
Contact discharge current waveform per IEC61000-4-2
8/20μs waveform per IEC61000-4-5
Pulse waveform:tp=8/20μS
CJ - Junction capacitance (pF)
Vc-Clamping Voltage (V)
9.5
9.0
8.5
8.0
7.5
7.0
6.5
6.0
ESD56281N04
ESD56281N05
ESD56281N06
5.5
5.0
10
15
t
60ns
30ns
tr = 0.7~1ns
30
35
40
180
f = 1MHz
VAC = 50mV
160
140
120
ESD56281N04
100
ESD56281N05
80
60
45
ESD56281N06
Ipp-Peak Pulse Current (A)
Clamping voltage vs. Peak pulse current
2
3
4
5
6
7
VR - Reverse voltage (V)
Capacitance vs. Reverse voltage
100
% of Rated power
Peak pulse power (W)
1000
100
80
60
40
10
100
Pulse time (s)
25
50
75
100
125
150
o
TA - Ambient temperature ( C)
Non-repetitive peak pulse power vs. Pulse time
Power derating vs. Ambient temperature
4
ESD56281NXX
TLP current (A)
16
12
8
Z0 = 50
tr = 2ns
tp = 100ns
4
-8
-12
ESD56281N04
ESD56281N05
ESD56281N06
-16
-20
-3 -2 -1 0
1
2
3
4
5
6
7
8
9 10
TLP voltage (V)
TLP Measurement
5
PACKAGE OUTLINE DIMENSIONS
DFN1006-2L
b
CATHODE MARKING
(Ⅰ)
L
E
(Ⅱ)
D
e
Top View
Bottom View
(Ⅲ)
(Ⅰ)
A
(Ⅱ)
A3
A1
Side View
Dimensions in Millimeters
Symbol
Min.
Typ.
Max.
A
0.340
0.450
0.530
A1
0.000
0.020
0.050
A3
0.125 Ref.
D
0.950
1.000
1.075
E
0.550
0.600
0.675
b
0.200
0.250
0.300
L
0.450
0.500
0.550
e
0.650 BSC
Recommended PCB Layout (Unit: mm)
0.55
0.60
0.30
Notes:
This recommended land pattern is for reference
0.85
1.40
purposes only. Please consult your manufacturing
group to ensure your PCB design guidelines are met.
6
TAPE AND REEL INFORMATION
Reel Dimensions
RD
Reel Dimensions
W
Tape Dimensions
P1
Quadrant Assignments For PIN1 Orientation In Tape
Q1
Q2
Q1
Q2
Q3
Q4
Q3
Q4
User Direction of Feed
RD
Reel Dimension
7inch
13inch
W
Overall width of the carrier tape
8mm
12mm
P1
Pitch between successive cavity centers
2mm
4mm
8mm
Pin1 Quadrant
Q1
Q2
Q3
Pin1
7
Q4
很抱歉,暂时无法提供与“ESD56281N06-2/TR”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+0.31350
- 500+0.20900
- 5000+0.18150
- 10000+0.16500
- 国内价格
- 20+0.26968
- 200+0.21784
- 600+0.19192
- 2000+0.17248
