ESD9X5V
ESD9X5V
1-Line, Uni-directional, Transient Voltage Suppressor
http//:www.sh-willsemi.com
Descriptions
The ESD9X5V is a Uni-directional TVS (Transient Voltage
Suppressor) designed to protect sensitive electronic
components from damage due to ESD (Electrostatic
Discharge), EFT (Electrical Fast Transients) and CDE
FBP-02C (Bottom view)
(Cable Discharge Event). The ESD9X5V has been
specifically designed to replace MLV (Multilayer Varistor) in
portable application such as cellular handsets, notebook
computers, tablets and PADs.
Pin1
Pin2
The ESD9X5V is based on solid-state silicon technology
and offer unique electrical characteristics like lower
clamping voltage and no device degrading compared to
Circuit diagram
MLV.
The ESD9X5V may be used to provide ESD protection up
to ±30kV (contact discharge) according to IEC61000-4-2,
and withstand peak pulse current up to 11A (8/20μs)
*H
Pin1
according to IEC61000-4-5.
Pin2
The ESD9X5V is available in FBP-02C package. Standard
* = Month (A~Z)
products are Pb-free and Halogen-free.
H = Device code
Marking (Top View)
Features
Stand-off voltage: 5V Max.
Transient protection for each line according to
Order information
IEC61000-4-2 (ESD): ±30kV (contact discharge)
IEC61000-4-5 (surge): 11A (8/20μs)
Capacitance: CJ = 60pF typ.
Low clamping voltage
Solid-state silicon technology
Device
Package
Shipping
ESD9X5V-2/TR
FBP-02C
10000/Tape&Reel
Applications
Cellular handsets
Tablets
Computers and peripherals
Notebooks
Digital camera
Other electronic equipment
Will Semiconductor Ltd.
1
Revision 2.5, 2016/07/06
ESD9X5V
Absolute maximum ratings
Parameter
Symbol
Rating
Unit
Peak pulse power (tp = 8/20μs)
Ppk
154
W
Peak pulse current (tp = 8/20μs)
IPP
11
A
ESD according to IEC61000-4-2 air discharge
±30
VESD
ESD according to IEC61000-4-2 contact discharge
Junction temperature
TJ
Operating temperature
TOP
Lead temperature
TL
Storage temperature
kV
±30
TSTG
125
o
-40~85
o
260
o
-55~150
o
C
C
C
C
Electronics characteristics (TA = 25oC, unless otherwise noted)
Parameter
Symbol
Reverse stand-off voltage
VRWM
Reverse leakage current
IR
Condition
Min.
Typ.
VRWM = 5V
Max.
Unit
5.0
V
1.0
μA
Reverse breakdown voltage
VBR
IT = 1mA
6.2
6.8
7.6
V
Forward voltage
VF
IF = 1mA
0.4
0.8
1.3
V
Clamping voltage
VCL
IPP = 1A, tp = 8/20μs
7.5
V
IPP = 11A, tp = 8/20μs
14
V
Junction capacitance
CJ
70
pF
VR = 0V, f = 1MHz
2
60
ESD9X5V
o
100
90
Front time: T1= 1.25 T = 8s
100
90
Time to half-value: T2= 20s
Current (%)
Peak pulse current (%)
Typical characteristics (TA = 25 C, unless otherwise noted)
50
T2
10
tr = 0.7~1ns
Time (s)
T1
CJ - Junction capacitance (pF)
VC - Clamping voltage (V)
12
10
8
4
6
Time (ns)
70
Pulse waveform: tp = 8/20s
14
6
t
Contact discharge current waveform per IEC61000-4-2
8/20μs waveform per IEC61000-4-5
16
60ns
30ns
T
8
10
f = 1MHz
VAC = 50mV
60
50
40
30
2
3
4
IPP - Peak pulse current (A)
VR - Reverse voltage (V)
Clamping voltage vs. Peak pulse current
Capacitance vs. Reverse voltage
5
1000
% of Rated power
Peak pulse power (W)
100
100
10
1
10
100
Pulse time (s)
60
40
50
75
100
125
o
TA - Ambient temperature ( C)
Non-repetitive peak pulse power vs. Pulse time
80
Power derating vs. Ambient temperature
3
150
ESD9X5V
o
ESD clamping
ESD clamping
(+8kV contact discharge per IEC61000-4-2)
(-8kV contact discharge per IEC61000-4-2)
4
ESD9X5V
Package outline dimensions
FBP-02C
L
D1
D
L2
b
b1
E
E1
L3
L1
e1
e
Top View
Bottom View
Dimensions In Millimeters
Min.
Typ.
Max.
A
0.450
0.500
0.550
A1
0.010
0.100
D
0.950
1.000
1.050
E
0.550
0.600
0.650
A
A1
Symbol
Side View
D1
0.470 Ref.
E1
0.420 Ref.
b
0.270
0.320
0.370
b1
0.250
0.300
0.350
e
0.555
0.605
0.655
e1
L
Recommend land pattern (Unit: mm)
0.250
L1
L2
0.40
L3
0.40
0.230 Ref.
0.300
0.350
0.030 Ref.
0.370
0.420
0.470
0.040 Ref.
Notes:
This recommended land pattern is for reference
purposes only. Please consult your manufacturing
0.62
0.18
0.50
group to ensure your PCB design guidelines are met.
5
