ESDA6V1-5W6-6/TR
ESDA6V1-5W6-6/TR
    WILLSEMI(韦尔)
    SOT323-6
    单向TVS 5V截止 峰值脉冲电流:16A@8/20US
ESDA6V1-5W6-6/TR 数据手册
ESDA6V1-5W6 ESDA6V1-5W6 Transient Voltage Suppressors for ESD Protection http://www.willsemi.com Description: The ESDA6V1-5W6 array is 5-Line ESD transient voltage suppressor which provides a very high level of protection for sensitive electronic components that may be subjected to electrostatic discharge (ESD). These devices clamp the voltage just above the logic level supply for positive transient, and to a diode drop below ground for negative transients. The ESDA6V1-5W6 safely dissipates ESD strikes of ±20kV, exceeding the maximum requirement of the IEC 61000-4-2 international standard. Using the MILSTD-883 (Method 3015) specification for Human Body Model (HBM) ESD, the device provides protection for contact discharges to greater than ±20kV. The ESDA6V1-5W6 is available in a SOT-363 package with working voltages of 5 volt. SOTŦ363 PIN CONFIGURATION 1 6 2 5 3 4 MARKING DIAGRAM  Specification Features: z z z z z z Working Peak Reverse Voltage: 5 V Low Leakage current: 20kV per HBM IEC61000–4–2 Level 4 ESD Protection IEC61000–4–4 Level 4 EFT Protection Five separate unidirectional configurations WX W=Date Code X=Specific Device Code Mechanical Characteristics z z z Void Free, Transfer-Molded, Thermosetting Plastic Case Corrosion Resistant Finish, Easily Solderable Small Packaging Applications z z Order Information Part Number Package Shipping ESDA6V1-5W6- 6/TR SOT-363 http://www.willsemi.com  3000 Tape & Reel z z Page 1 Cell Phone Handsets and Accessories Personal Digital Assistants (PDAƍs) Notebooks, Desktops, and Servers Portable Instrumentation 2/15/2008 Rev2.0 ESDA6V1-5W6 Absolute Maximum Rating Rating Symbol Value Units Peak Pulse Power(TP=8/20us) PPP 300 W Maximum Peak Pulse Current(TP=8/20us) IPP 16 A ESD per IEC 61000-4-2 (Air) ESD per IEC 61000-4-2 (Contact) Maximum lead temperature for soldering during 10s Storage Temperature Range VPP KV TL +/-20 +/-20 260 TSTG -55 to+150 °C Operating Temperature Range TOP -55 to+150 °C °C Electrical Parameter Symbol Parameter IPP Maximum Reverse Peak Pulse Current VC Clamping Voltage @ IPP VRWM Working Peak Reverse Voltage IR Maximum Reverse Leakage Current @ VRWM IT Test Current VBR Breakdown Voltage @ IT IF Forward Current VF Forward Voltage @ IF I IF VF VC VBR VRWM IR V IPP http://www.willsemi.com Page 2 2/15/2008 Rev2.0 ESDA6V1-5W6 Electrical Characteristics (T=25Ɔ, Device for 5.0V Working Peak Reverse Voltage) Conditions Minimum Typical Maximum Unit 0.5 uA IR VRWM=5V VF IF= -10mA -0.4 -0.8 -1.25 V VBR IT=1mA 6.1 6.6 7.2 V VC IPP=1A, TP = 8/20us, note1 9.8 V IPP=16 A, TP = 8/20us, note1 12.5 V C 50 Pin1 to 2 VR = 0V, f = 1MHz pF Note1: Surge current waveform per Figure 1. Typical Characteristics Figure 1. Pulse Waveform Figure 2. Power Derating Curve 110 WAVEFORM PARAMETERS tr = 8 ms td = 20 ms 90 PERCENT OF IPP 80 70 110 100 % of Rated Power or I PP 100 cït 60 . td = IPP/2 50 40 30 90 80 70 60 50 40 30 20 20 10 0 0 10 5 10 15 20 25 0 30 0 25 Figure 3. Non-Repetitive Peak Pulse Power vs. Pulse Time 75 100 125 150 Figure 4. Junction Capacitance vs. Reverse Voltage 10 610 Capacitance - Cj (pF) Peak Pulse Power - P PP (kW) 50 Ambient Temperature - TA (oC) t, TIME (ms) 1 0.1 0.01 0.1 1 10 100 1000 50 40 30 20 0 Pulse Duration - tp (Ps) http://www.willsemi.com Page 3 1 2 3 Reverse Voltage - VR (V) 4 2/15/2008 Rev2.0 5 ESDA6V1-5W6 Package mechanical data SOT-363 A G 6 5 DIM A B C D G H J K N S 4 ŦBŦ S 1 2 3 D 6 PL N J INCHES MIN MAX 0.071 0.087 0.045 0.053 0.031 0.043 0.004 0.012 0.026 BSC ŦŦŦ 0.004 0.004 0.010 0.004 0.012 0.008 REF 0.079 0.087 PIN 1. 2. 3. 4. 5. 6. MILLIMETERS MIN MAX 1.80 2.20 1.15 1.35 0.80 1.10 0.10 0.30 0.65 BSC ŦŦŦ 0.10 0.10 0.25 0.10 0.30 0.20 REF 2.00 2.20 CATHODE ANODE CATHODE CATHODE CATHODE CATHODE C H http://www.willsemi.com K Page 4 2/15/2008 Rev2.0
ESDA6V1-5W6-6/TR 价格&库存
很抱歉,暂时无法提供与“ESDA6V1-5W6-6/TR”相匹配的价格&库存,您可以联系我们找货
