DS1M12
DS1M12
    MEILHAUS
    DS1M12
DS1M12 数据手册
Mobile USB Mini Scope und Waveform Generator PocketScope DS1M12 - The 2 Channel “Travel Scope” USB, Mobile Model: PocketScope DS1M12       Low cost and easy to use: Ideal solution for Platform: professionals, education, hobby etc.  PCI  Oscilloscope, data logger, spectrum analyzer,  PXI/cPCI voltmeter, frequency meter and waveform   USB generator in one device.  Other  A/D resolution 12 bit.  2 channels with BNC for x1/x10 standard Functions: probes (available as an optional accessory).  Analog I/O Third BNC as trigger output or waveform  Digital I/O generator output.  Temp./°C  Simultaneous sampling on both channels.  Interfaces  32 kB waveform buffer.   Instrument  20 MS/s sample rate (repetitive),  Logger 1 MS/s native.  Isolation  Max. input voltage ±50 V.  Accessory  AC/DC coupling.  Software  Trigger modes: Edge, min./max. pulse width and delay trigger. Analog bandwidth 250 kHz. Inbuilt 10 bit waveform generator with 3.5 V output range and 1 k buffer. Power via USB (250 mA). USB 1.1/2.0 full-speed. Size only ~116 mm (W) x 30 mm (H) x 100 mm (D), 160 g (without cable). Follow-up model of the popular DS2200C. Optional accessory: Passive probe pair, not included! >> Specification: PocketScope (DS1M12, follow-up model of the DS2200C) 2 channel DSO for USB. Included: Windows drivers and software EasyScope II and EasyLogger. USB cable and bag. ME-Probe LF pair Optional accessory, see “Accessories & Software” section Web Link: www.meilhaus.com/e_me Specifications: Functions Oscilloscope, data logger, spectrum analyzer, voltmeter, frequency meter and waveform generator Digital Oscilloscope/DSO Channels A/D resolution Sample rate Input voltage Trigger modes 2 simultaneous 12 bit each channel 20 MS/s (repetitive), 1 MS/s native. Analog bandwidth 250 kHz Max. ±50 V; AC/DC coupling (per software) Edge, min./max. puls width and delay trigger Waveform Generator Channel Specifications 1 output (third BNC selectable as external scope trigger input or waveform generator output) 10 bit, ±3.5 V output range, 1 k buffer General Data PC interface Power Display Connectors Size (mm) www.meilhaus.com USB 1.1/2.0 full-speed Via USB (250 mA) 2 LEDs (1 per channel) 2x BNC 50 Ω for x1/x10 standard probes (scope channel A and B); third BNC selectable as trigger input or waveform generator output ~116 (W) x 30 (H) x 100 (D), 160 g (without cable) Software included: DLL, drivers for Windows XP, 2000, 98SE/Me; examples for LabVIEW. EasyScope II for Windows: • Scope: Time base 2 µs/Div to 50 ms/Div in 14 steps. Y scale 10 mV/Div to 5 V/Div. On screen X and Y measurement cursors. • FFT spectrum analyzer display. • Meter displays: Min., max., mean, true RMS voltage + frequency. • Save results to csv. file (compatible with Excel), save screens to .bmp files. • Sine wave, square wave, triangle, sawtooth and user defined waveform generation. EasyLogger for Windows: • Sample rate >100,000 S/s to 100 S/s. • Flexible scaling of Y (V/mV, user defined) and X axis (sample number or time). • Save to .csv, .bmp, .txt or binary file. Data import from previously saved binary file. • Up to 3 on-screen cursors to track data, up to 4 pop-up or E-Mail alerts. • Text memos for incorporation user notes in the data. MEsurement starts with ME. 53
DS1M12 价格&库存
很抱歉,暂时无法提供与“DS1M12”相匹配的价格&库存,您可以联系我们找货
