AK-D78/1
AK-D78/1
    MEILHAUS
    AK-D78/1
AK-D78/1 数据手册
Cables, Terminal Blocks, Expansions ME AK and ME AB Series - Reliable High Quality Accessories Standard Cable Ordering Code: Model L. Side 1 Side 2 eg. for Use with ME Series Boards1)2) ME-96 with TB ME-63Xtend to ME-1400(A) with TB; ME-95, ME-94, ME-26 with TB; DIO ports C/D of ME-FoXX, ME-Jekyll, ME-6303), MEphisto Switch, ME-61003), ME-60003) with TB ME-160, ME-81, ME-63, ME-14 with TB ME-300, ME-260 with TB ME-FoXX, ME-Jekyll with TB or ME-MultiSig; ME-8100 with TB; ME-3000, ME-2600i, ME-2000i with TB or ME-MultiSig; ME-1600 with TB; ME-1400 with TB, ME-1400(A) with ME63Xtend, ME-1000 with TB; ME-630 with TB (for current up to 0.5 A per relay/line) Cabel with special shielding for ME-FoXX, ME-Jekyll Cable with special shielding for ME-FoXX, ME-Jekyll ME-FoXX, ME-Jekyll, ME-6303), MEphisto Switch, ME-61003), ME-60003) with 1x ME-63Xtend ME-FoXX, ME-Jekyll, ME-6303), MEphisto Switch, ME-61003), ME-60003) with 2x ME-UB ME-1000 with 2x ME-63Xtend ME-63Xtend and ME-1000 with second ME-63Xtend 3x ME-UB series with ME-1400 3x ME-UB series with ME-RedJack PMD-1008 (+ power) 2x ME-UB series with LabJack U12 (+ power) ME AK-D15 ME AK-D25 2m 2m 15-pin. D-sub male 25-pin D-sub male 15-pin D-sub female 25-pin D-sub female ME AK-D37 ME AK-D50 ME AK-D78/1 ME AK-D78 2m 2m 1m 2m 37-pin D-sub male 50-pin D-sub male 78-pin D-sub male 37-pin D-sub female 50-pin D-sub female 78-pin D-sub female ME AK-D78/4000M-F ME AK-D78/4000M-OEM ME AK-D2578/4000 1m 1m 0,5 m 78-pin D-sub male 78-pin D-sub male 25-pin D-sub male 78-pin D-sub female open ends 78-pin D-sub female ME AK-D2515/4000 0,5 m 25-pin D-sub male 2x 15-pin D-sub male ME AK-D78/1000 ME AK-D2578/1000 ME AK-D7815/1400 ME AK-DUB ME AK-DUB/LJ 1m 0,5 m 0,5 m 1m 1m 78-pin D-sub male 25-pin D-sub male 25-pin D-sub male 37-pin D-sub female 25-pin D-sub male 78-pin D-sub female 78-pin D-sub female 3x 15-pin D-sub male 3x 15-pin D-sub male 2x 15-pin D-sub male Accessories Included with Certain Boards as Spare Parts Model Lngth. Side 1 ME AK-D25F/S ME AK-D78/6000 ME AK-D78/1400CD ME AK-DDual ME AK-DQuad ME AK-DOcto 1) TB = terminal block 58 1m 1m 1m 1m 1m Side 2 20-pin flat ribbon cable connector 78-pin D-sub male 78-pin D-sub male 78-pin D-sub male 78-pin D-sub male 78-pin D-sub male Ordering Code: for ME Boards 25-pin D-sub female ME-FoXX, ME-Jekyll, ME-6303), ME-61003), ME-60003) digital I/O ports C/D Open ends ME-6000, ME-6100 Open ends ME-1400C, ME-1400D 2x 9-pin D-sub male ME-9000 4x 9-pin D-sub male ME-9100i, ME-9000 8x 9-pin D-sub male ME-9100i, ME-9000 2) Many accessories can also be used with borads from other suppliers! MEasurement starts with ME. www.meilhaus.com ME AB-D78M ME AB-D50M ME AB-D37M ME AB-D15M ME AB-BNC16 ME AB-D25M, ME AK-D25 ME-MultiSig ME-63Xtend series ME AB-D9/16-V ME-UB series ME-AA4-3(i) ME-PA series Terminal Blocks with Spring Terminals4), no Additional Functions Ordering Codes: Model Side 1 Side 2 eg. for Use with ME Series Boards2) ME AB-D15M ME AB-D15F ME AB-D25M 15-pin D-sub male 15-pin D-sub female 25-pin D-sub male Spring terminals Spring terminals Spring terminals ME AB-D25F ME AB-D37M ME AB-D37F ME AB-D50M ME AB-D50F ME AB-D78M 25-pin D-sub female 37-pin D-sub male 37-pin D-sub female 50-pin D-sub male 50-pin D-sub female 78-pin D-sub male Spring terminals Spring terminals Spring terminals Spring terminals Spring terminals Spring terminals ME-UB15 15-pin D-sub female Spring terminals ME-UB37 ME AB-BNC16 37-pin D-sub female 78-pin D-sub male Spring terminals 16 BNC-female ME AB-BNC16/MUX 2x Phoenix-male 16 BNC-femalen … ME-96 ME-1400 + ME-63Xtend; DIO ports C/D of ME-FoXX series, ME-Jekyll, ME6303), MEphisto Switch, ME-60003), ME-61003) ME-95, ME-94; ME-26 ME-160; ME-81; ME-63; ME-14 … ME-300, ME-260 … ME-FoXX series; ME-Jekyll; ME-8100; ME-3000, ME-2600i, ME-2000i; ME-1600; ME-1000; ME-1400; ME-630, MEphisto Switch; ME-MultiSig; ME63Xtend ME-FoXX Serie, ME-Jekyll, ME-6303), MEphisto Switch, ME-6x003), ME-1400, USB Mini-Messlabore LabJack U12, ME-RedJack PMD-1008 ME-RedJack PMD-1008 ME-3000, ME-2600i, ME-2000i. BNC-Box für 16 single-ended AnalogEingänge. Ca. 1 m Kabel integriert ME-MUX32, ME-SIG32 mit ME-DIFF Accessories with Additional Functions Ordering Codes Model Description eg. for Use with ME Series Boards3) ME-63Xtend series ME-UB series External expansion board with relays or opto isolation External expansion boxes with relays or opto isolation Multiplexing system for analog inputs ME-FoXX series, ME-Jekyll, ME-6303), MEphisto Switch, ME-61003), ME60003), ME-1400(A), ME-1000 ME-FoXX series, ME-Jekyll, ME-6303), MEphisto Switch, MEphisto Scope 1, ME-6x003), ME-1400, USB LabJack U12, ME-RedJack PMD-1008 ME-FoXX series (for the models “i” a ME-AA4-3i may be necessary); MEJekyll; ME-3000, ME-2600i, ME-2000i ME-FoXX series (not ME-LittleFoXX/ME-4650); ME-3000, ME-2600i ME-FoXX Serie; ME-Jekyll; ME-3000, ME-2600i, ME-2000i Connects existing ME-2x00i/ME-3000 applications to boards of the ME-FoXX series or used for opto-isolated connectivity of the “i” models to the ME-MUX32 ME-FoXX series; ME-Jekyll; ME-1400; ME-3000, ME-2600i, ME-2000i; ME-14; ME-300 ME-MUX32-M/-S ME-DEMUX32 Demultiplexing system for analog outputs ME-SIG32 Signal conditioning system for analog inputs ME-AA4-3(i) series Connectivity adaptor, isolation adaptor ME-PA series Connectivity adaptor for various boards of the ME seriese 3) For the new board versions (from 2005) with additional digital ports. 4) Incl. a tool to open the spring terminals. www.meilhaus.com MEsurement starts with ME. 59 ME AB-D9/8 ME AB-RJ45/8x8 60 ME AB-D9/8-H ME AB-D9/8-V ME AB-RJ45/8x8-P ME AB-RJ45/8x8-V MEasurement starts with ME. ME AB-D9/8-HV ME AB-RJ45/8x8-PV www.meilhaus.com  For PC boards with D-sub: ME series and boards from other suppliers.  Ideal solution for industry and labor.  Shielded 1:1 quality cable.  Terminal blocks with D-sub connectors and spring terminals.  DIN rail mountable.  BNC connectivity boxes.  Connectivity boxes for serial interface boards with 8x D-sub or RJ45. Terminal block ME AB-D78M with spring terminals www.meilhaus.com MEsurement starts with ME. 61
AK-D78/1 价格&库存
很抱歉,暂时无法提供与“AK-D78/1”相匹配的价格&库存,您可以联系我们找货
