CDX2341-130A
CDX2341-130A
    CORDEX
CDX2341-130A 数据手册
BATTERIES AND CHARGERS 1 XP SERIES BATTERY (CDX2341-008) 1 XP SERIES REPLACEMENT BATTERY (CDX2341-008) CorDEX Instruments. Incorporates reverse charging and Technical data: 3W (Max) Safety Note – Only use CorDEX Instruments fuse part number CDX2341-120. Failure to do so will render the Weight: 135g Dimensions: 25x82x60mm 2 XP SERIES BATTERY CHARGING STATION (XP-323) 2 3 XP SERIES POWER PACK 3 4 XP SERIES FUSE Ref. ID251, Rev. A 5 XP SERIES BATTERY CHARGING STATION (XP-323) The charger can be desk or wall mounted and is supplied complete with all required fixings. N.B. – Power pack is included, and comes with a choice of UK, US, EU & AU plug types. Weight: - 95g Dimensions: 47x93x108mm XP SERIES POWER PACK (CDX2341-130) the built in LED which indicates the status of the charge cycle. N.B. – Power Pack comes with a choice of UK, US, EU & AU plug types. Weight: 265g Dimensions: 115x58x52mm 4 XP SERIES REPLACEMENT FUSE KIT (XP-326) This pack of 10, 1.25A fuses can replace the over current Supplied complete with a fuse replacement tool. Safety Note non-hazardous area. Only CorDEX Instruments replacement fuses should be used, failure to do so will void XP SERIES BATTERY FIXING 5 XP SERIES BATTERY FIXING KIT (XP-325) The stainless steel, high strength fixings can be used to instrument body. Safety Note – Only use CorDEX supplied fixings to secure 4 5
CDX2341-130A 价格&库存
很抱歉,暂时无法提供与“CDX2341-130A”相匹配的价格&库存,您可以联系我们找货
