FZ Series
Features
· Endurance : 105℃ 2000~5000 H
· Extra Low Impedance (40% ~ 60% lower than LZ Series)
· Designed for reflow soldering
· Designed for surface mounting on high-density PCB
Marking color:Black
· RoHS 2.0 compliant
· 219 SVHC & REACH compliant
Specifications
Category temp. range
–55℃ to +105℃
Capacitance tolerance
±20% (120 Hz / +20 ℃)
Leakage current
I ≦ 0.01 CV or 3 μA whichever is greater (after 2 minutes)
Tan δ
Please see the attached characteristics list
Rated voltage(V)
6.3
10
16
25
35
50
63
80
100
temperature(Impedance
Z (-25 ℃) / Z (+20 ℃)
4
3
2
2
2
2
2
2
2
ratio at 120 Hz)
Z (-55 ℃) / Z (+20 ℃)
8
5
4
3
3
3
3
3
3
Characteristics at low
After applying rated working voltage for 2000/3000/5000 hours at +105 ℃ ± 2 ℃, and then being stabilized at
+20 ℃,capacitors shall meet the following limits.
ΦD x L ≦ 6.3x 5.7Lmm:2000H,
Test Time
6.3φx7.7L , 8φx 6.5L,10φx7.7L:3000H , φD ≧ 8mm:5000H
Endurance
Capacitance change
Within ±30% of the initial value
Dissipation factor (tan δ)
Less than 300% of the initial value
Leakage current
Within the initial limit
After storage for 1000 h at +105 ℃ ± 2 ℃ with no voltage applied and then being stabilized at +20 ℃,
Shelf life
capacitors shall meet the limits specified in endurance.
After reflow soldering and then being stabilized at +20 ℃, capacitors shall meet the following limits.
Resistance to
Capacitance change
Within ±10% of the initial value
soldering heat
Leakage current
factor for ripple current
Frequency
50Hz
120Hz
1kHz
10kHz≦
Correction Factor
0.6
0.7
0.85
1.0
Frequency correction
Marking:
Dimensions
φD ≦ 10mm
φD ≧ 12.5mm
Dimensions:
Unit:mm
φD
L
A
B
C
W
P±0.2
4
5.7±0.3
4.3
4.3
5.1
0.5~0.8
1.0
5
5.7±0.3
5.3
5.3
6.1
0.5~0.8
1.3
6.3
5.7±0.3
6.6
6.6
7.3
0.5~0.8
2.2
6.3
7.7±0.3
6.6
6.6
7.3
0.5~0.8
2.2
8
6.5±0.5
8.3
8.3
9.2
0.7~1.2
3.1
8
10.5±0.5
8.3
8.3
9.2
0.7~1.2
3.1
10
7.7±0.3
10.3
10.3
11.2
0.7~1.2
4.4
10
10.5±0.5
10.3
10.3
11.2
0.7~1.2
4.4
10
13±0.5
10.3
10.3
11.2
0.7~1.2
4.4
12.5
13.5±0.5
13.0
13.0
14.0
1.0~1.4
4.4
12.5
16±0.5
13.0
13.0
14.0
1.0~1.4
4.4
Part Number System:
FZ series
16V
220μF
±20 %
6.3φX7.7L
FZ
1C
221
M
0607
Case Size
Series name
Rated voltage
Capacitance
Characteristics list
Case size
Specification
Rated
Capacitance
voltage
(±20%)
øD
L
(V)
(μF)
(mm)
(mm)
22
4
5.7
4
5
220
6.3
(Ω)
tan δ ③
Part Number ④
MPQ
(pcs/reel)
0.26
FZ0J220M0406
2000
5.7
80
1.45
0.26
FZ0J330M0406
2000
5.7
150
0.80
0.26
FZ0J330M0506
1000
5
5.7
150
0.80
0.26
FZ0J470M0506
1000
5
5.7
150
0.80
0.26
FZ0J101M0506
1000
6.3
5.7
230
0.44
0.26
FZ0J101M0606
1000
6.3
5.7
230
0.44
0.26
FZ0J151M0606
1000
6.3
5.7
230
0.44
0.26
FZ0J221M0606
1000
6.3
7.7
280
0.36
0.26
FZ0J221M0607
1000
6.3
7.7
280
0.36
0.26
FZ0J331M0607
1000
8
6.5
280
0.36
0.26
FZ0J331M0806
1000
8
10.5
450
0.17
0.26
FZ0J331M0810
500
6.3
7.7
280
0.36
0.26
FZ0J471M0607
1000
330
470
680
1000
8
10.5
450
0.17
0.26
FZ0J471M0810
500
10
7.7
450
0.17
0.26
FZ0J471M1007
500
8
10.5
450
0.17
0.26
FZ0J681M0810
500
10
7.7
450
0.17
0.26
FZ0J681M1007
500
8
10.5
450
0.17
0.28
FZ0J102M0810
500
10
10.5
670
0.09
0.28
FZ0J152M1010
500
10
13
720
0.08
0.28
FZ0J152M1013
400
2200
12.5
13.5
820
0.07
0.34
FZ0J222M1313
200
22
4
5.7
80
1.45
0.22
FZ1A220M0406
2000
33
5
5.7
150
0.80
0.22
FZ1A330M0506
1000
47
6.3
5.7
230
0.44
0.22
FZ1A470M0606
1000
100
6.3
5.7
230
0.44
0.22
FZ1A101M0606
1000
150
6.3
5.7
230
0.44
0.22
FZ1A151M0606
1000
6.3
7.7
280
0.36
0.22
FZ1A221M0607
1000
8
6.5
280
0.36
0.22
FZ1A221M0806
1000
8
10.5
450
0.17
0.22
FZ1A331M0810
500
10
7.7
450
0.17
0.22
FZ1A331M1007
500
8
10.5
450
0.17
0.22
FZ1A471M0810
500
10
7.7
450
0.17
0.22
FZ1A471M1007
500
680
10
10.5
670
0.09
0.22
FZ1A681M1010
500
1000
10
10.5
670
0.09
0.24
FZ1A102M1010
500
10
13
720
0.08
0.24
FZ1A152M1013
400
12.5
13.5
820
0.07
0.27
FZ1A152M1313
200
12.5
13.5
820
0.07
0.29
FZ1A222M1313
200
1500
220
10
(mA rms)
Imp.②
1.45
47
150
current①
Taping&Reel
80
33
100
Rated ripple
330
470
1500
2200
① Rated ripple current (100kHz / +105℃)
② Impedance (100kHz / +20℃)
③ tan δ (120Hz / +20℃)
④ For plastic reel packaging,the Part Number is appended with "PR" at the end.
※Please refer to the page of reflow conditions for reflow profile.
Case size
Specification
Taping&Reel
Rated
Capacitance
voltage
(±20%)
øD
L
(V)
(μF)
(mm)
(mm)
10
4
5.7
80
1.45
0.18
FZ1C150M0406
2000
22
5
5.7
150
0.80
0.18
FZ1C220M0506
1000
5
5.7
150
0.80
0.18
FZ1C330M0506
1000
6.3
5.7
230
0.44
0.18
FZ1C330M0606
1000
47
6.3
5.7
230
0.44
0.18
FZ1C470M0606
1000
68
6.3
5.7
230
0.44
0.18
FZ1C680M0606
1000
6.3
5.7
230
0.44
0.18
FZ1C101M0606
1000
8
6.5
280
0.36
0.18
FZ1C101M0806
1000
6.3
7.7
280
0.36
0.18
FZ1C151M0607
1000
8
6.5
280
0.36
0.18
FZ1C151M0806
1000
6.3
7.7
280
0.36
0.18
FZ1C221M0607
1000
8
10.5
450
0.17
0.18
FZ1C331M0810
500
10
7.7
450
0.17
0.18
FZ1C331M1007
500
33
100
16
150
220
330
MPQ
(pcs/reel)
0.17
0.18
FZ1C471M0810
500
670
0.09
0.18
FZ1C471M1010
500
10
10.5
670
0.09
0.18
FZ1C681M1010
500
10
13
720
0.08
0.20
FZ1C102M1013
500
12.5
13.5
820
0.07
0.22
FZ1C102M1313
200
10
4
5.7
80
1.45
0.16
FZ1E100M0406
2000
22
5
5.7
150
0.80
0.16
FZ1E220M0506
1000
5
5.7
150
0.80
0.16
FZ1E330M0506
1000
6.3
5.7
230
0.44
0.16
FZ1E330M0606
1000
47
6.3
5.7
230
0.44
0.16
FZ1E470M0606
1000
68
6.3
5.7
230
0.44
0.16
FZ1E680M0606
1000
6.3
7.7
280
0.36
0.16
FZ1E101M0607
1000
8
6.5
280
0.36
0.16
FZ1E101M0806
1000
8
10.5
450
0.17
0.16
FZ1E151M0810
500
8
10.5
450
0.17
0.16
FZ1E221M0810
500
10
7.7
450
0.17
0.16
FZ1E221M1007
500
330
8
10.5
450
0.17
0.16
FZ1E331M0810
500
470
10
10.5
670
0.09
0.16
FZ1E471M1010
500
10
13
720
0.08
0.16
FZ1E681M1013
400
12.5
13.5
820
0.07
0.18
FZ1E681M1313
200
1000
12.5
13.5
820
0.07
0.20
FZ1E102M1313
200
4.7
4
5.7
80
1.45
0.14
FZ1V4R7M0406
2000
4
5.7
80
1.45
0.14
FZ1V100M0406
2000
5
5.7
150
0.80
0.14
FZ1V100M0506
1000
5
5.7
150
0.80
0.14
FZ1V220M0506
1000
150
220
680
10
22
6.3
5.7
230
0.44
0.14
FZ1V220M0606
1000
33
6.3
5.7
230
0.44
0.14
FZ1V330M0606
1000
47
6.3
5.7
230
0.44
0.14
FZ1V470M0606
1000
6.3
7.7
280
0.36
0.14
FZ1V680M0607
1000
8
6.5
280
0.36
0.14
FZ1V680M0806
1000
6.3
7.7
280
0.36
0.14
FZ1V101M0607
1000
8
10.5
450
0.17
0.14
FZ1V101M0810
500
8
10.5
450
0.17
0.14
FZ1V151M0810
500
10
7.7
450
0.17
0.14
FZ1V151M1007
500
8
10.5
600
0.17
0.14
FZ1V221M0810
500
10
10.5
670
0.09
0.14
FZ1V221M1010
500
10
10.5
850
0.09
0.14
FZ1V331M1010
500
12.5
13.5
820
0.07
0.16
FZ1V331M1313
200
10
13
720
0.08
0.14
FZ1V471M1013
400
12.5
13.5
820
0.07
0.16
FZ1V471M1313
200
1
4
5.7
60
2.9
0.12
FZ1H010M0406
2000
2.2
4
5.7
60
2.9
0.12
FZ1H2R2M0406
2000
3.3
4
5.7
60
2.9
0.12
FZ1H3R3M0406
2000
4
5.7
60
2.9
0.12
FZ1H4R7M0406
2000
5
5.7
85
1.52
0.12
FZ1H4R7M0506
1000
10
6.3
5.7
165
0.88
0.12
FZ1H100M0606
1000
22
6.3
5.7
165
0.88
0.12
FZ1H220M0606
1000
33
6.3
7.7
185
0.68
0.12
FZ1H330M0607
1000
6.3
7.7
185
0.68
0.12
FZ1H470M0607
1000
8
6.5
185
0.68
0.12
FZ1H470M0806
1000
8
10.5
360
0.34
0.12
FZ1H470M0810
500
8
10.5
360
0.34
0.12
FZ1H680M0810
500
8
10.5
360
0.34
0.12
FZ1H101M0810
500
10
10.5
560
0.18
0.12
FZ1H101M1010
500
10
10.5
560
0.18
0.12
FZ1H151M1010
500
10
10.5
560
0.18
0.12
FZ1H221M1010
500
12.5
13.5
650
0.12
0.12
FZ1H221M1313
200
12.5
13.5
650
0.12
0.12
FZ1H331M1313
200
4.7
5
5.7
60
2.9
0.12
FZ1J4R7M0506
1000
10
6.3
5.7
80
1.5
0.12
FZ1J100M0606
1000
6.3
7.7
120
1.2
0.12
FZ1J220M0607
1000
8
6.5
120
1.2
0.12
FZ1J220M0806
1000
33
8
10.5
250
0.65
0.12
FZ1J330M0810
500
47
8
10.5
250
0.65
0.12
FZ1J470M0810
500
68
8
10.5
250
0.65
0.12
FZ1J680M0810
500
10
10.5
400
0.35
0.12
FZ1J101M1010
500
68
100
150
220
330
470
4.7
47
68
100
150
220
330
22
100
12.5
13.5
800
0.16
0.14
FZ1J101M1313
200
150
12.5
13.5
800
0.16
0.14
FZ1J151M1313
200
220
12.5
13.5
800
0.16
0.14
FZ1J221M1313
200
3.3
5
5.7
25
5.0
0.12
FZ1K3R3M0506
1000
4.7
6.3
5.7
40
3.0
0.12
FZ1K4R7M0606
1000
6.3
7.7
60
2.4
0.12
FZ1K100M0607
1000
8
6.5
60
2.4
0.12
FZ1K100M0806
1000
8
10.5
130
1.3
0.12
FZ1K220M0810
500
33
8
10.5
130
1.3
0.12
FZ1K330M0810
500
47
10
10.5
200
0.70
0.12
FZ1K470M1010
500
10
13
400
0.40
0.12
FZ1K680M1013
400
12.5
13.5
500
0.32
0.14
FZ1K680M1313
200
10
13
400
0.40
0.12
FZ1K101M1013
400
12.5
13.5
500
0.32
0.14
FZ1K101M1313
200
150
12.5
13.5
500
0.32
0.14
FZ1K151M1313
200
22
8
10.5
130
1.3
0.12
FZ2A220M0810
500
33
10
10.5
200
0.70
0.12
FZ2A330M1010
500
10
10.5
200
0.70
0.12
FZ2A470M1010
500
10
13
400
0.40
0.12
FZ2A470M1013
400
12.5
13.5
500
0.32
0.14
FZ2A470M1313
200
68
12.5
13.5
500
0.32
0.14
FZ2A680M1313
200
100
12.5
13.5
500
0.32
0.14
FZ2A101M1313
200
10
22
68
100
100
Part Number ④
450
100
80
tan δ ③
10.5
33
63
(Ω)
10.5
1000
50
(mA rms)
Imp.②
8
680
35
current①
10
470
25
Rated ripple
47
很抱歉,暂时无法提供与“FZ1C221M0607”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 10+0.29225
- 100+0.23264
- 300+0.20283
- 1000+0.17291
- 5000+0.15509
- 10000+0.14613
