FZ1A101M0506
FZ1A101M0506
    JARSON(伽盛)
    SMD,D5xL5.7mm
    100UF ±20% 10V
FZ1A101M0506 数据手册
FZ Series Features · Endurance : 105℃ 2000~5000 H · Extra Low Impedance (40% ~ 60% lower than LZ Series) · Designed for reflow soldering · Designed for surface mounting on high-density PCB Marking color:Black · RoHS 2.0 compliant · 219 SVHC & REACH compliant Specifications Category temp. range –55℃ to +105℃ Capacitance tolerance ±20% (120 Hz / +20 ℃) Leakage current I ≦ 0.01 CV or 3 μA whichever is greater (after 2 minutes) Tan δ Please see the attached characteristics list Rated voltage(V) 6.3 10 16 25 35 50 63 80 100 temperature(Impedance Z (-25 ℃) / Z (+20 ℃) 4 3 2 2 2 2 2 2 2 ratio at 120 Hz) Z (-55 ℃) / Z (+20 ℃) 8 5 4 3 3 3 3 3 3 Characteristics at low After applying rated working voltage for 2000/3000/5000 hours at +105 ℃ ± 2 ℃, and then being stabilized at +20 ℃,capacitors shall meet the following limits. ΦD x L ≦ 6.3x 5.7Lmm:2000H, Test Time 6.3φx7.7L , 8φx 6.5L,10φx7.7L:3000H , φD ≧ 8mm:5000H Endurance Capacitance change Within ±30% of the initial value Dissipation factor (tan δ) Less than 300% of the initial value Leakage current Within the initial limit After storage for 1000 h at +105 ℃ ± 2 ℃ with no voltage applied and then being stabilized at +20 ℃, Shelf life capacitors shall meet the limits specified in endurance. After reflow soldering and then being stabilized at +20 ℃, capacitors shall meet the following limits. Resistance to Capacitance change Within ±10% of the initial value soldering heat Dissipation factor (tan δ) Within the initial limit Leakage current factor for ripple current Within the initial limit Frequency 50Hz 120Hz 1kHz 10kHz≦ Correction Factor 0.6 0.7 0.85 1.0 Frequency correction Marking: Dimensions φD ≦ 10mm φD ≧ 12.5mm Dimensions: Unit:mm φD L A B C W P±0.2 4 5.7±0.3 4.3 4.3 5.1 0.5~0.8 1.0 5 5.7±0.3 5.3 5.3 6.1 0.5~0.8 1.3 6.3 5.7±0.3 6.6 6.6 7.3 0.5~0.8 2.2 6.3 7.7±0.3 6.6 6.6 7.3 0.5~0.8 2.2 8 6.5±0.5 8.3 8.3 9.2 0.7~1.2 3.1 8 10.5±0.5 8.3 8.3 9.2 0.7~1.2 3.1 10 7.7±0.3 10.3 10.3 11.2 0.7~1.2 4.4 10 10.5±0.5 10.3 10.3 11.2 0.7~1.2 4.4 10 13±0.5 10.3 10.3 11.2 0.7~1.2 4.4 12.5 13.5±0.5 13.0 13.0 14.0 1.0~1.4 4.4 12.5 16±0.5 13.0 13.0 14.0 1.0~1.4 4.4 Part Number System: FZ series 16V 220μF ±20 % 6.3φX7.7L FZ 1C 221 M 0607 Capacitance tolerance Case Size Series name Rated voltage Capacitance Characteristics list Case size Specification Rated Capacitance voltage (±20%) øD L (V) (μF) (mm) (mm) 22 4 5.7 4 5 220 6.3 (Ω) tan δ ③ Part Number ④ MPQ (pcs/reel) 0.26 FZ0J220M0406 2000 5.7 80 1.45 0.26 FZ0J330M0406 2000 5.7 150 0.80 0.26 FZ0J330M0506 1000 5 5.7 150 0.80 0.26 FZ0J470M0506 1000 5 5.7 150 0.80 0.26 FZ0J101M0506 1000 6.3 5.7 230 0.44 0.26 FZ0J101M0606 1000 6.3 5.7 230 0.44 0.26 FZ0J151M0606 1000 6.3 5.7 230 0.44 0.26 FZ0J221M0606 1000 6.3 7.7 280 0.36 0.26 FZ0J221M0607 1000 6.3 7.7 280 0.36 0.26 FZ0J331M0607 1000 8 6.5 280 0.36 0.26 FZ0J331M0806 1000 8 10.5 450 0.17 0.26 FZ0J331M0810 500 6.3 7.7 280 0.36 0.26 FZ0J471M0607 1000 330 470 680 1000 8 10.5 450 0.17 0.26 FZ0J471M0810 500 10 7.7 450 0.17 0.26 FZ0J471M1007 500 8 10.5 450 0.17 0.26 FZ0J681M0810 500 10 7.7 450 0.17 0.26 FZ0J681M1007 500 8 10.5 450 0.17 0.28 FZ0J102M0810 500 10 10.5 670 0.09 0.28 FZ0J152M1010 500 10 13 720 0.08 0.28 FZ0J152M1013 400 2200 12.5 13.5 820 0.07 0.34 FZ0J222M1313 200 22 4 5.7 80 1.45 0.22 FZ1A220M0406 2000 33 5 5.7 150 0.80 0.22 FZ1A330M0506 1000 47 6.3 5.7 230 0.44 0.22 FZ1A470M0606 1000 100 6.3 5.7 230 0.44 0.22 FZ1A101M0606 1000 150 6.3 5.7 230 0.44 0.22 FZ1A151M0606 1000 6.3 7.7 280 0.36 0.22 FZ1A221M0607 1000 8 6.5 280 0.36 0.22 FZ1A221M0806 1000 8 10.5 450 0.17 0.22 FZ1A331M0810 500 10 7.7 450 0.17 0.22 FZ1A331M1007 500 8 10.5 450 0.17 0.22 FZ1A471M0810 500 10 7.7 450 0.17 0.22 FZ1A471M1007 500 680 10 10.5 670 0.09 0.22 FZ1A681M1010 500 1000 10 10.5 670 0.09 0.24 FZ1A102M1010 500 10 13 720 0.08 0.24 FZ1A152M1013 400 12.5 13.5 820 0.07 0.27 FZ1A152M1313 200 12.5 13.5 820 0.07 0.29 FZ1A222M1313 200 1500 220 10 (mA rms) Imp.② 1.45 47 150 current① Taping&Reel 80 33 100 Rated ripple 330 470 1500 2200 ① Rated ripple current (100kHz / +105℃) ② Impedance (100kHz / +20℃) ③ tan δ (120Hz / +20℃) ④ For plastic reel packaging,the Part Number is appended with "PR" at the end. ※Please refer to the page of reflow conditions for reflow profile. Characteristics list Case size Specification Taping&Reel Rated Capacitance voltage (±20%) øD L (V) (μF) (mm) (mm) 10 4 5.7 80 1.45 0.18 FZ1C150M0406 2000 22 5 5.7 150 0.80 0.18 FZ1C220M0506 1000 5 5.7 150 0.80 0.18 FZ1C330M0506 1000 6.3 5.7 230 0.44 0.18 FZ1C330M0606 1000 47 6.3 5.7 230 0.44 0.18 FZ1C470M0606 1000 68 6.3 5.7 230 0.44 0.18 FZ1C680M0606 1000 6.3 5.7 230 0.44 0.18 FZ1C101M0606 1000 8 6.5 280 0.36 0.18 FZ1C101M0806 1000 6.3 7.7 280 0.36 0.18 FZ1C151M0607 1000 8 6.5 280 0.36 0.18 FZ1C151M0806 1000 6.3 7.7 280 0.36 0.18 FZ1C221M0607 1000 8 10.5 450 0.17 0.18 FZ1C331M0810 500 10 7.7 450 0.17 0.18 FZ1C331M1007 500 33 100 16 150 220 330 MPQ (pcs/reel) 0.17 0.18 FZ1C471M0810 500 670 0.09 0.18 FZ1C471M1010 500 10 10.5 670 0.09 0.18 FZ1C681M1010 500 10 13 720 0.08 0.20 FZ1C102M1013 500 12.5 13.5 820 0.07 0.22 FZ1C102M1313 200 10 4 5.7 80 1.45 0.16 FZ1E100M0406 2000 22 5 5.7 150 0.80 0.16 FZ1E220M0506 1000 5 5.7 150 0.80 0.16 FZ1E330M0506 1000 6.3 5.7 230 0.44 0.16 FZ1E330M0606 1000 47 6.3 5.7 230 0.44 0.16 FZ1E470M0606 1000 68 6.3 5.7 230 0.44 0.16 FZ1E680M0606 1000 6.3 7.7 280 0.36 0.16 FZ1E101M0607 1000 8 6.5 280 0.36 0.16 FZ1E101M0806 1000 8 10.5 450 0.17 0.16 FZ1E151M0810 500 8 10.5 450 0.17 0.16 FZ1E221M0810 500 10 7.7 450 0.17 0.16 FZ1E221M1007 500 330 8 10.5 450 0.17 0.16 FZ1E331M0810 500 470 10 10.5 670 0.09 0.16 FZ1E471M1010 500 10 13 720 0.08 0.16 FZ1E681M1013 400 12.5 13.5 820 0.07 0.18 FZ1E681M1313 200 1000 12.5 13.5 820 0.07 0.20 FZ1E102M1313 200 4.7 4 5.7 80 1.45 0.14 FZ1V4R7M0406 2000 4 5.7 80 1.45 0.14 FZ1V100M0406 2000 5 5.7 150 0.80 0.14 FZ1V100M0506 1000 5 5.7 150 0.80 0.14 FZ1V220M0506 1000 150 220 680 10 22 6.3 5.7 230 0.44 0.14 FZ1V220M0606 1000 33 6.3 5.7 230 0.44 0.14 FZ1V330M0606 1000 47 6.3 5.7 230 0.44 0.14 FZ1V470M0606 1000 6.3 7.7 280 0.36 0.14 FZ1V680M0607 1000 8 6.5 280 0.36 0.14 FZ1V680M0806 1000 6.3 7.7 280 0.36 0.14 FZ1V101M0607 1000 8 10.5 450 0.17 0.14 FZ1V101M0810 500 8 10.5 450 0.17 0.14 FZ1V151M0810 500 10 7.7 450 0.17 0.14 FZ1V151M1007 500 8 10.5 600 0.17 0.14 FZ1V221M0810 500 10 10.5 670 0.09 0.14 FZ1V221M1010 500 10 10.5 850 0.09 0.14 FZ1V331M1010 500 12.5 13.5 820 0.07 0.16 FZ1V331M1313 200 10 13 720 0.08 0.14 FZ1V471M1013 400 12.5 13.5 820 0.07 0.16 FZ1V471M1313 200 1 4 5.7 60 2.9 0.12 FZ1H010M0406 2000 2.2 4 5.7 60 2.9 0.12 FZ1H2R2M0406 2000 3.3 4 5.7 60 2.9 0.12 FZ1H3R3M0406 2000 4 5.7 60 2.9 0.12 FZ1H4R7M0406 2000 5 5.7 85 1.52 0.12 FZ1H4R7M0506 1000 10 6.3 5.7 165 0.88 0.12 FZ1H100M0606 1000 22 6.3 5.7 165 0.88 0.12 FZ1H220M0606 1000 33 6.3 7.7 185 0.68 0.12 FZ1H330M0607 1000 6.3 7.7 185 0.68 0.12 FZ1H470M0607 1000 8 6.5 185 0.68 0.12 FZ1H470M0806 1000 8 10.5 360 0.34 0.12 FZ1H470M0810 500 8 10.5 360 0.34 0.12 FZ1H680M0810 500 8 10.5 360 0.34 0.12 FZ1H101M0810 500 10 10.5 560 0.18 0.12 FZ1H101M1010 500 10 10.5 560 0.18 0.12 FZ1H151M1010 500 10 10.5 560 0.18 0.12 FZ1H221M1010 500 12.5 13.5 650 0.12 0.12 FZ1H221M1313 200 12.5 13.5 650 0.12 0.12 FZ1H331M1313 200 4.7 5 5.7 60 2.9 0.12 FZ1J4R7M0506 1000 10 6.3 5.7 80 1.5 0.12 FZ1J100M0606 1000 6.3 7.7 120 1.2 0.12 FZ1J220M0607 1000 8 6.5 120 1.2 0.12 FZ1J220M0806 1000 33 8 10.5 250 0.65 0.12 FZ1J330M0810 500 47 8 10.5 250 0.65 0.12 FZ1J470M0810 500 68 8 10.5 250 0.65 0.12 FZ1J680M0810 500 10 10.5 400 0.35 0.12 FZ1J101M1010 500 68 100 150 220 330 470 4.7 47 68 100 150 220 330 22 100 12.5 13.5 800 0.16 0.14 FZ1J101M1313 200 150 12.5 13.5 800 0.16 0.14 FZ1J151M1313 200 220 12.5 13.5 800 0.16 0.14 FZ1J221M1313 200 3.3 5 5.7 25 5.0 0.12 FZ1K3R3M0506 1000 4.7 6.3 5.7 40 3.0 0.12 FZ1K4R7M0606 1000 6.3 7.7 60 2.4 0.12 FZ1K100M0607 1000 8 6.5 60 2.4 0.12 FZ1K100M0806 1000 8 10.5 130 1.3 0.12 FZ1K220M0810 500 33 8 10.5 130 1.3 0.12 FZ1K330M0810 500 47 10 10.5 200 0.70 0.12 FZ1K470M1010 500 10 13 400 0.40 0.12 FZ1K680M1013 400 12.5 13.5 500 0.32 0.14 FZ1K680M1313 200 10 13 400 0.40 0.12 FZ1K101M1013 400 12.5 13.5 500 0.32 0.14 FZ1K101M1313 200 150 12.5 13.5 500 0.32 0.14 FZ1K151M1313 200 22 8 10.5 130 1.3 0.12 FZ2A220M0810 500 33 10 10.5 200 0.70 0.12 FZ2A330M1010 500 10 10.5 200 0.70 0.12 FZ2A470M1010 500 10 13 400 0.40 0.12 FZ2A470M1013 400 12.5 13.5 500 0.32 0.14 FZ2A470M1313 200 68 12.5 13.5 500 0.32 0.14 FZ2A680M1313 200 100 12.5 13.5 500 0.32 0.14 FZ2A101M1313 200 10 22 68 100 100 Part Number ④ 450 100 80 tan δ ③ 10.5 33 63 (Ω) 10.5 1000 50 (mA rms) Imp.② 8 680 35 current① 10 470 25 Rated ripple 47 ① Rated ripple current (100kHz / +105℃) ② Impedance (100kHz / +20℃) ③ tan δ (120Hz / +20℃) ④ For plastic reel packaging,the Part Number is appended with "PR" at the end. ※Please refer to the page of reflow conditions for reflow profile.
FZ1A101M0506 价格&库存
很抱歉,暂时无法提供与“FZ1A101M0506”相匹配的价格&库存,您可以联系我们找货
FZ1A101M0506
    • 10+0.29873
    • 100+0.23717
    • 300+0.20639
    • 1000+0.17842
    • 5000+0.15995
    • 10000+0.15066
    库存:950
