GS1011MIP
GS1011MIP
    GAINSPAN
GS1011MIP 数据手册
T BRIEF PR O D UCT B RI E F GainSpan GS1011M Low Power Wi-Fi® Module Family PRODUCT OVERVIEW The GS1011M family of fully certified modules offers a quick, easy and cost effective way for device and appliances manufacturers to add Wi-Fi capabilities to their products. The module provides multiple serial UART or SPI interfaces, enabling connection to any embedded design utilizing a 8/16/32-bit microcontroller via simple commands. The GS1011M is an ideal solution for organizations with limited or no Wi-Fi or RF expertise, as it not only dramatically reduces RF design time but also removes the burden of testing and certification, allowing customers to focus on their core application, product or expertise. The module supports data rates up to 11 Mbps, is compliant with 802.11b and meets regulatory and Wi-Fi Alliance requirements. Multiple software configurations are available for the stack running on the module. For applications utilizing a small 8 bit microcontroller host, the module supports a serial to Wi-Fi function and runs the full Wi-Fi and TCP/IP networking stacks, completely offloading the host. For applications utilizing more powerful microcontrollers, the networking stack and services can reside on the host while the module provides the IP to Wi-Fi functionality. In addition, it supports WEP/WPA/WPA2 security, Adhoc as well as Wi-Fi Protected Setup (WPS) for ease of provisioning. BENEFITS: • Brings Wi-Fi and web connectivity to any device with a microcontroller and serial HOST interface (UART or SPI) • Reduces development time, testing and certification burden, accelerating time to market • Fully contained solution minimizes host processor loading when needed • Easy device provisioning through Limited AP (embedded web pages) or Wi-Fi Protected Set-up (WPS) • Ultra low power consumption through dynamic power management o Sleep, Deep Sleep, Standby FEATURES: • Operates with standard 802.11 b/g/n access points at speed up to 11 Mbps (802.11b) − Infrastructure, Limited AP or Adhoc • Two serial UART ports − Data rates of up to 921.6kbps • Two SPI ports − Supports SPI Master/Slave modes − Data rate of up to 3Mbps GS1011M based Embedded Design • The module family consists of four different SKU’s for antenna configuration and output power. The module SKU’s are single sided, pin compatible with castellation on the edges for I/O connection so module can be soldered down on customer application base-board. . SKUs Power Amplifier Antenna Option GS1011MIP Internal PA PCB Trace Antenna GS1011MIE Internal PA External Antenna (u.FL) GS1011MEP External PA PCB Trace Antenna GS1011MEE External PA External Antenna (u.FL) • Firmware provides full Wi-Fi and networking stack services including TCP/UPD/IP, HTTP, DNS, DHCP and SSL 802.11i Security − WEP, WPA/WPA2 Personal − WPA/WPA2 Enterprise MODULE HIGHLIGHTS • Single power source of 3.3V • FCC/IC/ETSI, Wi-Fi Alliance Certified • Rich I/O interfaces : SPI, UART, GPIO, I2C, ADC, JTAG PR O D UCT B RI E F GS1011M MODULE SPECIFICATIONS Radio Protocol IEEE 802.11b (IEEE 802.11b/g/n Compatible) RF Output Power (Typical) 8 dBm (GS1011MIx) 18 dBm (GS1011MEx) RF Operating Frequency 2.4 - 2.497 GHz Supported Data Rates 11, 5.5, 2, 1 Mbps (802.11b) Antenna Options PCB Trace and u.FL connector for external antenna Operating Temperature Industrial (-40° to +85°C) Security Protocols WEP, WPA/WPA2 Personal WPA/WPA2 Enterprise (EAP-FAST, EAP-TLS, EAP-TTLS, PEAP v0/1) Networking Protocols UDP, TCP/IP (IPv4), DHCP, ARP, DNS, HTTP/HTTPS Client and Server Certifications and Compliance Wi-Fi, FCC, IC, ETSI, RoHS, Japan Pre-Scan I/O Interface UART (2), SPI (2), I2C, ADC (2), WAKE, ALARM (2), GPIOs, PWM, JTAG Dimensions GS1011MIx = 1.28 in X 0.9 in (32.51 mm x 22.86 mm) GS1011MEx = 1.45 in X 0.9 in (36.83 mm x 22.86 mm) Power Source 3.3V Standby Power (Typical) < 7uA * Lowest power state (RTC Active) GS1011M BLOCK DIAGRAM ENABLE ADC WAKE UART1 BPF/ PA UART0 GPIO 32KHz GS1011 GPIO 1.8 V SPI1 VR SPI2 I2C 3.3V GPIO 3.3V 44MHz JTAG ALARM TARGET APPLICATIONS GainSpan’s GS1011 module is easily designed into embedded systems, allowing customers to develop a broad array of devices and appliances that will connect to the Internet. In applications such as healthcare and fitness, smart energy, industrial controls, commercial/building automation and consumer electronics. © 2011. GainSpan Corporation; http://www.gainspan.com• info@gainspan.com GS1011M PB 1.0 @GainSpan
GS1011MIP 价格&库存
很抱歉,暂时无法提供与“GS1011MIP”相匹配的价格&库存,您可以联系我们找货
