HGC0603G0101J500NTHJ
    CHINOCERA(华瓷)
    贴片电容(MLCC) 0603
HGC0603G0101J500NTHJ 数据手册
第 一 页 共 二十二 页 承认书 APPROVAL SHEET 产品名称:多层片式陶瓷电容器 PART NAME:MULTILAYER CERAMIC CAPACITORS 系 列:通用系列 Type of MLCC :General Purpose Series (6.3V to 63V) 规 格:0201 to 1210 Sizes SPECIFICATION: 0201 to 1210 Sizes 符合 RoHS 要求 RoHS Compliance 供应商(SUPPLIER): 发布日期(ISSUE DATE): 批准(APPROVED BY): 客户许可(CUSTOMER APPROVAL): 第 二 页 共 二十二 页 1. 概述(DESCRIPTION): 适合厂家高密度、高效表面贴装的陶瓷电容器。To manufacture a chip-type SMT and achieve miniaturization, high density and high efficiency, ceramic condensers are used. 产品采用 NP0(C0G、C0H), X7R 、X7S 和 X6S 材质制作,具有电气性能优越、精度高、稳定性高、可靠性高的 特点 MLCC is made by NP0 ( C0G 、 C0H ) , X7R 、 X7SandX6S dielectric material and which provides product with high electrical ,precision, stability and reliability. 2、产品特点(FEATURES): a、可选尺寸范围广,0201 至 1210 规格。A wide selection of sizes is available (0201 to 1210) b、给定尺寸容量高。High capacitance in given case size. 3.应用领域(APPLICATIONS): a、一般数字电路。For general digital circuit. b、电源旁路。For power supply bypass capacitors. c、消费电子。 For consumer electronics. d、通讯。For telecommunication 4.型号规格表示方法: HOW TO ORDER Type of MLCC 普通型 (Genernal ):HGC 高压型(Mid-High Vatage):HHV 0805 R7 104 K 500 N T H J Size 尺寸 Inch(mm): Dielectric 材质 R5=X5R R6=X6R S6=X6S R7=X7R S7=X7S T7=X7T R8=X8R G0=C0G H0=C0H Capacitance 电容量 R75=0.75pF 0R5=0.5pF 1R0=1pF 100=10pF 101=100pF 102=1000pF 103=10nF 104=100nF 105=1uF 106=10uF 107=100uF Tolerance 精度级别 A=±0.05pF B= ±0.1pF C=±0.25pF D= ±0.5pF F= ±1% G= ±2% J= ±5% K= ±10% L=±15% M= ±20% S=-20%~+5 0% Rated voltage 额定电压 4R0=4 Vdc 6R3=6.3 Vdc 100=10 Vdc 160=16 Vdc 250=25 Vdc 500=50 Vdc 101=100 Vdc 201=200 Vdc 251=250 Vdc 501=500 Vdc 631=630 Vdc 102=1k Vdc 152=1.5k Vdc 202=2k Vdc 252=2.5k Vdc 302=3k Vdc 402=4k Vdc 502=5k Vdc 602=6k Vdc Termination 端电极类型 N=Cu/Ni/Sn C=Cu/树脂 /Ni/Sn Packagin g 包装方式 T=纸带 B=散包装 S=塑胶带 Symbol /Thickness (mm) 高度代号 A=0.1mm B=0.2mm C=0.3mm D=0.4mm E=0.5mm F=0.6mm G=0.7mm H=0.8mm J=1.0mm L=1.2mm P=1.6mm S=1.8mm U=2.0mm V=2.5mm W=3.0mm Reel Size 卷盘尺寸 J=7Inch 普通宽度 D=13Inch K= 7Inch12 mm 宽度 1005(0402), 0201(0603), 0402(1005), 0603(1608), 0805(2012), 1206(3216), 1210(3225), 第 三 页 共 二十二 页 5、温度系数/特性 Temperature Coefficient /Characteristics 介质种类 参考温度点 标称温度系数 工作温度范围 Dielectric Reference Temperature Point Temperature Coefficient Operation Temperature Range COG 20C 030 ppm/℃ -55℃~125℃ COH 20C 060 ppm/℃ -55℃~125℃ X7R 20C 15% -55℃~125℃ X5R 20C 15% -55℃~85℃ X7S 20C 22% -55℃~125℃ X6S 20C 22% -55℃~105℃ 备注:Ⅰ类电容器标称温度系数和允许偏差是采用温度在 20C 和 85C 之间的电容量变化来确定的,而Ⅱ类电容器 标称温度系数是按照工作范围之间的电容量相对 20C 的电容量变化来确定的。 Note:Nominal temperature coefficient and allowed tolerance of class Ⅰare decided by the changing of the capacitance between 20C and 85C. Nominal temperature coefficient of class Ⅱare decided by the temperature of 20C。 6.产品外围尺寸及内部结构 EXTERNAL DIMENSIONS AND STRUCTURE 外观 Outline Size Inch(mm) L(mm) W(mm) 0.60±0.05 0.30±0.05 0.30±0.05 1.00±0.05 0.50±0.05 1.00±0.20 0603 (1608) 0805 (2012) 0201(0603) 0402 (1005) 1206 (3216) 1210 (3225) 说明:R=Reflow Soldering 回流焊 W=Wave Soldering 波峰焊 Soldering Method* MB(mm) C R 0.15 ±0.05 0.50±0.05 E R 0.50±0.20 0.50±0.20 E R 0.25 +0.05/-0.10 1.60±0.20 0.80±0.20 0.80±0.20 H R/W 0.40±0.15 0.70±0.10 G 2.00±0.20 1.25±0.20 0.80±0.10 H 3.20±0.20 3.20±0.30 1.60±0.20 2.50±0.20 T(mm)/Symbol 1.20±0.20 L 0.70±0.10 G 0.80±0.10 H 1.0±0.10 J 1.20±0.2 L 1.60±0.20 P 1.20±0.10 L 1.60±0.20 P 2.00±0.20 U 2.50±0.30 V R/W 0.50±0.20 R R/W 0.60±0.20 R R 0.75±0.25 第 四 页 共 二十二 页 结构 STRUCTURE W 序号 NO L ① T ② ③ ① ② ③ ④ ⑤ ④ ⑤ 名称 Name 陶瓷介质 Ceramic dielectric 内电极 Inner electrode 外电极 Substrate electrode 镍层 Nickel Layer 锡层 Tin Layer 7、包装标准数量 PACKAGING STANDARD QUANTITY Size 尺寸 0201 (0603) 0402 (1005) 0603 (1608) 0805 (2012) 1206 (3216) 1210 (3225) Thickness(mm)/Symbol 厚度/符号 0.30±0.03 0.50±0.05 0.50±0.20 0.80±0.1 0.70±0.10 0.80±0.10 1.20±0.20 0.70±0.10 0.80±0.10 1.0±0.10 1.20±0.10 1.60±0.20 1.20±0.10 1.60±0.20 2.00±0.20 2.50±0.30 C E E H G H L H H J L P L P U V Paper tape 纸带 7″reel 15,000 10,000 10,000 4000 4000 4000 4000 4000 4000 Plastic Tape 胶带 7″reel 3000 3000 3000 2000 3000 2000 1000 1000 第 五 页 共 二十二 页 8-1 Capacitance Range and rating Voltage C0G、C0H Dielectric Dielectric (尺寸)Size 额定电压 Rated Voltage (VDC) 0.3pF(0R3) 0.4pF(0R4) 0.5pF(0R5) 0.6pF(0R6) 0.7pF(0R7) 0.8pF(0R8) 0.9pF(0R9) 1.0pF(1R0) 1.2pF(1R2) 1.5pF(1R5) 1.8pF(1R8) 2.0pF(2R0) 2.2pF(2R2) 2.7pF(2R7) 3.0pF(3R0) 3.3pF(3R3) 3.9pF(3R9) 4.0pF(4R0) 4.7pF(4R7) 5.0pF(5R0) 5.6pF(5R6) 6.0pF(6R0) 6.8pF(6R8) 7.0pF(7R0) 8.0pF(8R0) 8.2pF(8R2) 9.0pF(9R0) 10pF(100) 12pF(120) 15pF(150) 18pF(180) 22pF(220) 27pF(270) 33pF(330) 39pF(390) 47pF(470) 56pF(560) 68pF(680) 82pF(820) 100pF(101) 120pF(121) 150pF(151) 180pF(181) 220pF(221) 270pF(271) 330pF(331) 390pF(391) 470pF(471) 560pF(561) 680pF(681) 820pF(821) 1,000pF(102) 1,200pF(122) 1,500pF(152) 1,800pF(182) 2,200pF(222) 2,700pF(272) 3,300pF(332) 3,900pF(392) 4,700pF(472) 5,600pF(562) 6,800pF(682) 8,200pF(822) 0.010uF(103) 0.012uF(123) 0.015uF(153) 0.018uF(183) 0.022uF(223) 0.027uF(273) 0.033uF(333) 0.039uF(393) 0.047uF(473) 0.056uF(563) 0.068uF(683) 0.082uF(823) 0.10uF(104) 0201 10 16 25 50 0402 10 16 25 50 0603 10 16 25 50 C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H 10 16 G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G H H H H L L L L 0805 C0G、C0H 25 50 G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G H H H H L L L L 10 16 G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G L L L L P P P P P P P P P P P P 1206 25 50 10 16 G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G G L L L L P P P P P P P P P P P P J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J L L U U U U U U U U U U 1210 Capacitance 8、容量范围及其电压 25 50 J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J J L L U U U U U U U U U U 第 六 页 共 二十二 页 8-2 X7R Dielectric X7R Dielectric Size 16 25 100pF(101) 120pF(121) 150pF(151) 180pF(181) 220pF(221) 270pF(271) 330pF(331) 390pF(391) 470pF(471) 560pF(561) 680pF(681) 820pF(821) 1,000pF(102) C C C C C C C C C C C C C C C C C C C C C C C C C C 1,200pF(122) 1,500pF(152) 1,800pF(182) 2,200pF(222) 2,700pF(272) 3,300pF(332) 3,900pF(392) 4,700pF(472) 5,600pF(562) 6,800pF(682) 8,200pF(822) 0.010uF(103) C C C C C C C C C C C C C C C C C C C C C C C C Rated Voltage (VLC) capacitance 0201 6.3 10 0.012uF(123) 0.015uF(153) 0.018uF(183) 0.022uF(223) 0.027uF(273) 0.033uF(333) 0.039uF(393) 0.047uF(473) 0.056uF(563) 0.068uF(683) 0.082uF(823) 0.10uF(104) 0.12uF(124) 0.15uF(154) 0.18uF(184) 0.22uF(224) 0.27uF(274) 0.33uF(334) 0.39uF(394) 0.47uF(474) 0.56uF(564) 0.68uF(684) 0.82uF(824) 1.0uF(105) 1.5uF(155) 2.2uF(225) 3.3uF(335) 4.7uF(475) 6.8uF(685) 10uF(106) 22uF(226) 47uF(476) 0402 0603 50 6.3 10 16 25 E E E E E E E E E E E E E E E E E E E E E E E E E E H H H H H H H H H H H H H E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E 50 6.3 10 16 25 C C C C C C C C C C C C C E E E E E E E E E E E E E E 0805 1206 50 6.3 10 16 25 50 H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H 1210 6.3 10 16 25 50 H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H L L L L L H H H H H H H L L L L L H H H H H H H L L L L L H H H H H H H H H H H L H J J J J J L L L L L L L L L L L L L L L L L L P P P P P P P P L L P 10 16 25 50 H H H H H H H H H H H H J J J J J J J J H J J J L L P P P P P P J J J J J J J J L L L L J J J J J J J J L L L L J J J J J J J J L L L L J J J J J L L L L L L L U P P P U P P P U V V V V U U U V V V V V P P 第 七 页 共 二十二 页 8-3 X7S Dielectric Dielectric Size Capacitance Rated Voltage (VDC) 1.0uF (105) 1.5uF (155) 2.2uF (225) 3.3uF (335) 4.7uF (475) 6.8uF (685) 10uF (106) 22uF (226) 47uF (476) 100uF (107) 0402 6. 3 10 0603 16 2 5 6.3 10 0805 16 25 10 16 25 X7S 50 1206 100 E E 6.3 10 16 1210 25 50 6.3 10 16 V V 25 50 L E H H H H H H L L L P P P V 8-4 X5R Dielectric Dielectric Capacitance Size Rated Voltage (VDC) 100pF(101) 220pF(221) 470pF(471) 1,000pF(102) 2,200pF(222) 4,700pF(472) 0.010uF(103) X5R 0201 0402 6.3 10 16 25 50 C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C 0.027uF(273) 0.033uF(333) 0.039uF(393) 0.047uF(473) 0.056uF(563) 0.068uF(683) 0.082uF(823) 0.10uF(104) C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C C 0.15uF(154) 0.22uF(224) 0.27uF(274) 0.33uF(334) 0.39uF(394) 0.47uF(474) 0.68uF(684) 0.82uF(824) 1.0uF(105) C C C C C C C C C C C C C C C C C C C 1.5uF(155) 2.2uF(225) 3.3uF(335) 4.7uF(475) 6.8uF(685) 10uF(106) 22uF(226) 47uF(476) 100uF(107) 220uF(227) 6.3 0603 10 16 25 50 E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E E 6.3 H H H H 0805 10 16 25 50 H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H H 6.3 10 1206 16 25 50 L L 6.3 4 6.3 1210 10 25 16 10 16 25 50 50 L P P P P P P U U P U U V P P P U U U V P P P V V V V V V V V H H H L L L L L L L L L L L L L L L L L L L L L L L P P P P P P P P P P P P V V 第 八 页 共 二十二 页 8-5 X6S Dielectric Capacitance Dielectric Size Rated Voltage (VDC) 0.10uF(104) 0.15uF(154) 0.22uF(224) 0.33uF(334) 0.39uF(394) 0.47uF(474) 0.68uF(684) 1.0uF(105) 1.5uF(155) 2.2uF(225) 3.3uF(335) 4.7uF(475) 6.8uF(685) 10uF(106) 22uF(226) 47uF(476) 100uF(107) X6S 0402 6.3 0603 10 16 25 E E E E E E E 4 6.3 10 0805 16 25 H H H 4 6.3 10 16 1206 25 50 L L 6.3 10 16 P P 1210 25 50 6.3 P P V 10 16 25 50 V V E E E H H H H H H H L H L L L L L L L L L P P P P V V V V V V 第 九 页 共 二十二 页 9、可靠性测试 Reliability Test 项目 技术规格 测 试 方 法 Item Technical Specification Test Method and Remarks 标称容量 Ⅰ类 ClassⅠ 应符合指定的误差级别 Should be within the specified tolerance. Capacitance 测试频率 Measuring Frequency ≤1000pF 1MHz±10% >1000 pF 1KHz±10% 测试电压 Measuring Voltage 1.0±0.2Vrms 测试温度: 25℃±3℃ Test Temprature: 25℃±3℃ C≤10µF:测试频率: 1KHz±10% 测试电压: 1.0±0.2Vrms 容量 Capacitance Test Frequency: 1KHz±10% Ⅱ类 Class Ⅱ Test Voltage: 1.0±0.2Vrms 应符合指定的误差级别 Should be within specified tolerance. the C>10µF X7R、X5R、X7S、X6S 测试频率: 120±24 Hz 测试电压:0.5±0.1Vrms Test Frequency: 120±24 Hz Test Voltage: 0.5±0.1Vrms DF 损耗角正切 (DF, tanδ) Ⅰ类 Dissipation ClassⅠ Factor 标称容量 Capacitance 测试频率 测试电压 Measuring Measuring Frequency Voltage ≤0.56% Cr<5 pF 1MHz±10% 1.5[(150/Cr)+7]×10-4 5pF≤Cr<50 pF 1MHz±10% ≤0.15% 50pF≤Cr≤1000 pF 1MHz±10% ≤0.15% >1000 pF 1KHz±10% 1.0±0.2Vrms 第 十 页 共 二十二 页 项目 Item 技术规格 Technical Specification ≥50V X7R/X5R X7S/X6S (≥ 损耗角正切 (DF, tanδ) Dissipation Factor Ⅱ类 0402) Class Ⅱ 25V (< ≤3.5% ≤5.0% 0402) Ⅰ类 Class Ⅰ 16V ≤ 2.5% ≤3.5% ≤3.5% ( C < (C < (C < 1.0µF) 0.47µF) 0.47µF) ≤ ≤5.0% ≤10.0% ( C ≥ 10.0% (C ≥ 1.0µF) ( C ≥ 0.47µF) 0.47µF) X7R/X5R X7S/X6S 测 试 方 法 Test Method and Remarks ≤5.0% (C < 0.047µF) ≤10%(C ≥ 0.047µF) 10V 6.3V ≤5.0% ≤5.0% ≤10.0% ≤10.0% ( C ≥ ( C ≥ C>10µF X7R、X5R、X7S、 0.15µF) 0.15µF) X6S、测试频率: 120±24 Hz ≤7.5% (C < 0.047µF) ≤10%(C ≥ 0.047µF) C≤10 nF, Ri≥50000MΩ C>10 nF, Ri•CR≥500S (IR) Ⅱ类 Resistance Class X7R/X5R/X7S/X6S Ⅱ 介质耐电强度 (DWV) 不应有介质被击穿或损伤 Dielectric No breakdown or damage. Withstanding Voltage 测试频率: 1KHz±10% 测试电压: 1.0±0.2Vrms ( C < ( C < Test Frequency: 1KHz±10% 0.15µF) 0.15µF) Test Voltage: 1.0±0.2Vrms 绝缘电阻 Insulation C≤10µF C≤25 nF, Ri≥10000MΩ C>25 nF, Ri•CR>100S 测试电压:0.5±0.1Vrms ≤7.5% Test Frequency: 120±24 Hz ( C < Test Voltage: 0.5±0.1Vrms 0.047µF) ≤10%(C ≥ 0.047µF) 测试电压:额定电压 测试时间: 60±5 秒 测试湿度:≤75% 测试温度: 25℃±3℃ 测试充放电电流:≤50mA Measuring Voltage: Rated Voltage Duration: 60±5s Test Humidity: ≤75% Test Temperature: 25℃±3℃ Test Current: ≤50mA 测量电压: Ⅰ类:300%额定电压 Ⅱ类:250% 额定电压 时间: 1~5 秒 充/放电电流:不应 超过 50mA Measuring Voltage: ClassⅠ:300% Rated voltage ClassⅡ:250% Rated voltage Duration: 1~5s Charge/ Discharge Current: 50mA max. 第 十一 页 共 二十二 页 项目 技术规格 测 试 方 法 Item Technical Specification Test Method and Remarks 将电容在 80~120℃的温度下预热 10~30 秒. Preheating conditions:80 to 120℃; 10~30s. 可焊性 Solderability 耐焊接热 Resistanceto SolderingHeat 抗弯曲强度 上锡率应大于 95% 有铅焊料:(Sn/Pb:63/37) 无铅焊料: 外观:无可见损伤. At least 95% of the terminal electrode is 浸锡温度: 235±5℃ 浸锡温度: 245±5℃ covered by new solder. 浸锡时间: 2±0.5s 浸锡时间: 2±0.5s Visual Appearance: No visible damage. SolderTemperature:235±5℃ SolderTemperature:245±5℃ Duration:2±0.5s Duration:2±0.5s 将电容在 100~200℃的温度下预热 10±1 分钟. 项目 NPO(COG、 X7R/X5R/X7S/X6S 浸锡温度: 265±5℃ Item COH) 浸锡时间: 10±1s ΔC/C ≤±0.5% -5%~+10% 然后取出溶剂清洗干净,在10倍以上的显微镜底下观察. 同初始标准 放置时间:24±2 小时 放置条件:室温 DF Same to initial value. Preheating conditions: 100 to 200℃; 10±1min. 同初始标准 Solder Temperature: 265±5℃ IR Same to initial value. Duration: 10±1s 外观:无可见损伤 上锡率: ≥95% Clean the capacitor with solvent and examine it with Appearance : No visible damage.At least a 10X(min.) microscope. 95% of the terminal electrode is covered Recovery Time: 24±2h by new solder. Recovery condition: Room temperature 试验基板:Al2O3 或 PCB 外观: 无可见损伤. 弯曲深度:1mm Appearance: No visible damage. 施压速度:0.5mm/sec. 单位:mm 应在弯曲状态下进行测量。 20 T=10 Resistance to Flexure of Substrate (Bending 1mm ΔC/C ≤±10% Strength) 45±2 Test Board: Al2O3 or PCB Warp: 1mm Speed: 0.5mm/sec. Unit: mm 45±2 The measurement should be made with the board in the bending position. 端头结合强度 Termination Adhesion 外观无可见损伤 施加的力:5N No visible damage. Applied Force: 5N 时间:10±1S Duration: 10±1S 第 十二 页 共 二十二 页 项目 Item 技术规格 Technical Specification ΔC/C: Ⅰ类:≤±1%或±1pF , 取两者中最大者 Ⅱ类: X7R,X5R,X7S,X6S: ≤±10% 温度循环 Temperature Cycle ClassⅠ: ≤±1% or ±1pF, whichever is larger. ClassⅡ: X7R,X5R,X7S,X6S: ≤±10% 测 试 方 法 Test Method and Remarks ※ 预处理 (2 类):上限类别温度,1 小时 恢复:24±1h 初始测量 循环次数:5 次,一个循环分以下 4 步: 阶段 温度(℃) 时间(分钟) 第1步 下限温度(-55) 第2步 常温 第3步 (+20) 上限温度 (X7R、X7S:+125) (X5R:+85) (X6S:+105) 第4步 常温 (+20) 30 2~3 30 2~3 试验后放置(恢复)时间:24±2h Preheating conditions: up-category temperature, 1h Recovery time: 24±1h Initial Measurement Cycling Times: 5 times, 1 cycle, 4 steps: Step Temperature(℃) Time(min.) 1 Low-categorytemp. (-55) 30 2 Normal temp. (+20) 2~3 3 Up-categorytemp. (+125) 30 4 Normal temp. (+20) 2~3 Recovery time after test: 24±2h Ⅰ类: ≤±2%或±1pF, 取两者之中较大者 Ⅱ类: X7R,X5R,X7S,X6S: ≤±10% Δ C/C 潮湿试验 Moisture Resistance ClassⅠ: ≤±2% or ±1pF, whichever is larger. 温度:40±2℃ Class Ⅱ : X7R,X5R,X7S,X6S: ≤ ± 湿度:90~95%RH 10% 时间:500 小时 ≤2 倍初始标准 DF Not more than twice of initial value. Ⅰ类:Ri≥2500MΩ或 Ri•CR≥25S 取两者之中较小者. ClassⅠ: Ri≥2500MΩ或 Ri•CR≥ 25S whichever is smaller. IR Ⅱ类:Ri≥1000MΩ或 Ri•CR≥25S 取两者之中较小者. ClassⅡ: Ri≥1000MΩ或 Ri•CR≥ 25S whichever is smaller. 外观:无损伤 Appearance: No visible damage. 放置条件:室温 放置时间:24 小时(Ⅰ类);48 小时(Ⅱ类) Temperature: 40±2℃ Humidity: 90~95%RH Duration: 500h Recovery conditions: Room temperature Recovery Time: 24h (Class1) or 48h (Class2) 第 十三 页 共 二十二 页 项目 Item 技术规格 Technical Specification Ⅰ类:≤±2%或±1pF 取两者之中较大者 Ⅱ类:X7R,X5R,X7S,X6S: ≤±20% ΔC/C 寿命试验 Life Test 测 试 方 法 Test Method and Remarks 低压产品(<100V) 电压:1.5 倍额定工作电压 ClassⅠ:≤±2% or ±1pF, 时间:1000 小时 whichever is larger. 温度:125℃(NPO(COG、COH)、X7R、X7S) 85℃ Class Ⅱ : X7R,X5R,X7S,X6S: ≤ ± (X5R)105℃(X6S) 20% 充电电流:不应超过 50mA ≤2 倍初始标准 DF Not more than twice of initial value. Ⅰ类:Ri≥4000MΩ或 Ri•CR≥40S 取两者之中较小者. ClassⅠ: Ri≥4000MΩ或 Ri•CR ≥ 40S whichever is smaller. IR Ⅱ类:Ri≥2000MΩ或 Ri•CR≥50S 取两者之中较小者. ClassⅡ: Ri≥2000MΩ或 Ri•CR ≥ 50S whichever is smaller. 外观:无损伤 Visual Appearance: No visible damage. 放置条件:室温 放置时间:24 小时(Ⅰ类),或 48 小时(Ⅱ类) , Low-voltange(<100V) Applied Voltage: 1.5 × Rated Voltage Duration: 1000h Temperature:125℃(NPO(COG、COH)、X7R、 X7S) 85℃(X5R)105℃(X6S) Charge/ Discharge Current: 50mA max. Recovery Conditions: Room Temperature Recovery Time: 24h (Class 1), or 48h (Class2) 备注(Remark): 1、预处理 (仅对 2 类电容器): ※ 将电容器放在上限类别温度或按详细规范中可能规定的更高温度(150℃)下经 1h 后,接着在试验的标准大气条 件下恢复 24±1h。 Note:Pretreatment (only for class2 capacitor) Pretreatment (only for class2 capacitor) is a method to treat the capacitor before measurement. First, place the capacitor in the up-category temperature or other specified higher temperature environment(150℃) for 1hour. Then recovery the capacitor at standard pressure conditions for 24±1hours。 第 十四 页 共 二十二 页 10、包装 PACKAGE 10-1 纸带卷盘结构 PAPER TAPING Top cover tape 面胶 Carrier tape(paper)传送带 Chip hole(Pocket) 芯片孔 Polystyrene reel 胶盘 Bottom tape 底胶 0201、0402 纸带编带尺寸大小 Dimensions of paper taping for 0201、0402 type 代号 Code 0201 0402 A0 B0 W F* E P1 P2* P0 D0 T 0.37 0.67 8.00 3.50 1.75 2.00 2.00 4.00 1.50 0.80 0.10 0.10 0.10 0.05 0.10 0.05 0.05 0.10 -0/+0.10 Below 0.65 1.15 8.00 3.50 1.75 2.00 2.00 4.00 1.50 0.80 0.10 0.10 0.10 0.05 0.10 0.05 0.05 0.10 -0/+0.10 Below 注意:*表示此处对尺寸的要求非常精确。 Note: The place with “*” means where needs exactly dimensions. 第 十五 页 共 二十二 页 0603,0805,1206’常规尺寸产品的纸带尺寸 Dimensions of paper taping for 0603,0805,1206 types. 送带孔 Feeding hole 芯片方穴 Chip pocket J E A D B T G H Chip cap F C Tape running direction 纸带运行方向 Unit:mm 代号Code 纸带规格 papersize A B C D* E F G* H J T 0603 1.10  0.10 1.90  0.10 8.00  0.10 3.50  0.05 1.75  0.10 4.00  0.10 2.00  0.10 4.00  0.10 1.50 -0/+0.10 1.10 Max 0805 1.45  0.15 2.30  0.15 8.0  0.15 3.50  0.05 1.75  0.10 4.00  0.10 2.00  0.10 4.00  0.10 1.50 -0/+0.10 1.10 Max 1206 1.80  0.20 3.40  0.20 8.00  0.20 3.50  0.05 1.75  0.10 4.00  0.10 2.00  0.10 4.00  0.10 1.50 -0/+0.10 1.10 Max 注意:*表示此处对尺寸的要求非常精确。 Note: The place with “*” means where needs exactly dimensions. 第 十六 页 共 二十二 页 10-2 塑胶卷盘结构 EMBOSSED TAPING Top cover tape 面胶 Carrier tape(paper)传送带 Chip hole(Pocket)芯片孔 Polystyrene reel 胶盘 塑胶带尺寸结构(适合‘0805~1812’型产品) Dimensions of embossed taping for 0805~1812 type 送带孔 Feeding hole 芯片方穴 Chip pocket J E A D B T H Chip cap G F C Tape running direction 塑胶带传送方向 代号 Code 规格 Tapesize 0805 1206 1210 A B C D* E F G* H J T 1.55 2.35 8.00 3.50 1.75 4.00 2.00 4.00 1.50 1.50  0.20  0.20  0.20  0.05  0.10  0.10  0.10  0.10 -0/+0.10 Max 1.95 3.60 8.00 3.50 1.75 4.00 2.00 4.00 1.50 1.85  0.20  0.20  0.20  0.05  0.10  0.10  0.10  0.1 -0/+0.10 Max 2.70 3.42 8.00 3.50 1.75 4.00 2.00 4.00 1.55 3.2  0.10  0.10  0.10  0.05  0.10  0.10  0.05  0.10 -0/+0.10 Max 备注:*表示此处对尺寸的要求非常精确。 Note:The place with “*” means where needs exactly dimensions. 第 十七 页 共 二十二 页 Structure of leader part and end part of the carrier paper 10-3 传送带的前后结构 尾部(空带) 芯片传送 End (Vacant position) 空带 Chip carrier Vacant position 大于 150 mm over 150mm 大于 150 mm over 150mm 卷盘尺寸 Reel Dimensions 带头(面胶面) Leader part(cover) tape) 大于 150 mm /Over 150 mm 传送方向/ Moving Direction (unit: mm) 尺寸代码(CODE) 卷盘型号 A B C D 7 REEL φ178±2.0 3.0 φ13±0.5 φ21±0.8 13′REEL φ330±2.0 3.0 φ13±0.5 φ21±0.8 ′ E φ50或更大 φ50 or more φ50或更大 φ50ormore F G 10.0±1.5 12max 10.0±1.5 12max 第 十八 页 共 二十二 页 10-4 卷带的说明 Taping specification 面胶剥离强度 Top tape peeling strength (a)纸带 Paper Taping Cover tape peeling direction 面胶剥离方向 Cover tape 面胶 0~15° Carrier tape 传送带 (b) 塑料胶盘 Embossed Taping Cover tape peeling direction 面胶剥离方向 Cover tape 面胶 0~15° Carrier tape 传送带 标准:0.1N
HGC0603G0101J500NTHJ 价格&库存
很抱歉,暂时无法提供与“HGC0603G0101J500NTHJ”相匹配的价格&库存,您可以联系我们找货
