1000-4
1000-4
    XURON
1000-4 数据手册
Wickgun™ Braid Dispensers Help take the work out of rework. Wickgun™ desoldering braid dispensers combine the capabilities of desoldering braid with the convenience of a hand tool. Simple one handed operation dispenses, positions and cuts off braid, even the smaller, hard to control sizes. The only other tool you need is your soldering iron. Wickgun™ braid dispensers fit comfortably in your hand; rotate the thumb wheel to advance or retract the braid, squeeze the trigger to cut off used braid. There are no The desoldering system that fits in the palm of your hand. plungers to push, spring-loaded levers to cock or vacuum chambers to empty. You The simple, one-handed-operation of the XURON Wickgun™ eliminates the tool- never touch the braid. You don’t burn your swapping three-hands-required process associated with conventional desoldering fingers. You stay clean and solderability braid use. Your technicians work quickly and precisely with just a Wickgun™ is enhanced since the desoldering braid and their soldering iron. Productivity is enhanced. In tests performed by XURON, is not contaminated by finger oil or other technicians worked 3 to 5 times faster than with conventional desoldering braid on foreign matter. bobbins—a significant increase in productivity; At this rate a Wickgun™ pays for itself before lunch on its first day of use. And the increased productivity fully offsets Wickgun™ braid dispensers feature your costs for replacement cassettes, easily contributing $20,000 to $40,000 per replaceable/interchangeable cassettes, year to your company in increased productivity. factory loaded with 15 foot (4.6 meter) lengths of pure copper braid impregnated Wickgun™ use can significantly reduce the “user cost” for your desoldering braid. with water clear flux. Cassettes are Due to the inherently clumsy and time consuming nature of conventional braid use, available in braid sizes 1, 2, 3 and 4 a 30-50% waste factor is not uncommon. Additionally, braid is commonly discarded (widths - 0.035”, 0.060”, 0.076” and 0.110”). when its temperature becomes too high for the technician’s comfort and safety. Both the Wickgun™ and its replacement Wickgun™ use can eliminate these “hidden” desoldering braid costs. With all this cassettes are manufactured from static in mind, when deciding how many Wickguns you should purchase, ask yourself, dissipative plastic so they may be used “How much money do I want to save?” in conjunction with your electrostatic discharge (ESD) control program. precisiontools Increase productivity & reduce cost • Using a WickGun™ braid dispenser is 3-5 times faster than To see how the WickGun™ Desoldering Braid Dispensers can help you increase productivity and reduce cost, contact your local Xuron Sales Representative or Distributor to arrange for a demonstration. conventional braid use. Dispense, position Part Number Description 1000-1 Dispenser with #1 (0.035”) braid 1000-2 Dispenser with #2 (0.060”) braid 1000-3 Dispenser with #3 (0.076”) braid and cut exactly at the 1000-4 Dispenser with #4 (0.110”) braid point where solder ends. W4015-1 Replacement Cassette - #1 braid No waste associated W4015-2 Replacement Cassette - #2 braid W4015-3 Replacement Cassette - #3 braid W4015-4 Replacement Cassette - #4 braid and cut braid with one tool (in one hand). • No wasted braid. Braid can be retracted with heat transfer (burned fingers). • No braid contamination. Solderability is enhanced because braid is not BLUE 77C 17M 0Y 24K contaminated with finger oil or other foreign matter. US & Canadian Sales/Main Office Xuron Corp. 62 Industrial Park Road Saco, ME 04072 Tel: 207-283-1401 Fax: 207-283-0594 Email: sales@xuron.com www.xuron.com International Sales Office Zed Group PO Box 505671 Chelsea, MA 02150 Tel: 617-889-2220 Fax: 617-889-0170 Email: international.sales@verizon.net precisiontools
1000-4 价格&库存
很抱歉,暂时无法提供与“1000-4”相匹配的价格&库存,您可以联系我们找货
