11720001055
11720001055
    PFANNENBERG
    PFANNENBERG - 11720001055 - Fan Filter Media, Exhaust Filter, for PFA 20.000, IP54, 145 mm
11720001055 数据手册
P R O D U C T S F I LT E R FA N S 4 . 0 PF 22.000 | PFA 20.000 εCOOL FILTERFAN | EXHAUST FILTER 56–67 m3/h • • • • • installation size 2, air flow rate up to 67 m3/h system of protection IP 54 and IP 55, NEMA type 12 UL, cUL approval UV-resistance (IP 55 version) cut-out compatible with installation size 2 from the 3rd Generation PRODUCT PF 22.000 ARTICLE NO. IP 54 11622101055 11622151055 11622851055 11622801055 11622701055 ARTICLE NO. IP 55 11622103055 11622153055 11622853055 11622803055 11622703055 Unit DATA AC 50 | 60 Hz Rated voltage ±10 % Unimpeded airflow Airflow rate in comb. with exhaust filter 230 DC 115 12 IP 54 IP 55 56 | 64 IP 54 44 | 50 IP 55 19 | 18 20 | 20 Current consumption 0.12 | 0.18 0.24 | 0.23 Noise level according to EN ISO 3741 Weight 0.7 0.44 kg cable, 2-core, length 310 mm IP 55 NEMA type 12 - fluted filter IP 54 88 IP 55 91 IP 54 G3 IP 55 G4 sleeve bearing 37500 % ball bearing 40000 62500 –40 … +55 | –40 ... +131 IP 54 made of injection-moulded thermoplastic, self-extinguishing, UL 94 VO IP 55 additional: UV-resistant RAL 7035 | different colours available on request ACCESSORIES ARTICLE NUMBER Exhaust filter gray 11720001055 Exhaust filter black 11720001050 5 pieces 18611600030 Thermostat % 100 Bearing type Spare filter mats A 6 Colour 17121000000 Hygrostat 17207000000 Rainhood in stainless steel 18102000014 For additional models, options and voltages visit www.pfannenberg.com or contact us directly. 1 A terminal strip NEMA type 12 - standard filter Temperature range 0.1 dB (A) Duty cycle Design (housing and protection against accidental contact) 0.21 IP 54 Service life L 10 (+ 40 °C) 1 W 5 0.42 44 Fuse Filter mat quality class according to EN 779 V m³/h 44 | 44 Type of connection Filtration efficiency 48 40 | 46 Power consumption System of protection according to EN 60529 / UL 50 24 61 | 67 fan failure is defined as being when the current and speed deviate or the operating noises are out of the ordinary h °C | °F 0 Temperaturdifferenz ∆ T [K] 5 Statischer Druck [Pa] PF 22.000 IP54 capacity / PFA 20.000performance IP54 Cooling curves [Pa] [W ] Static Pressure [Pa] 600 70 600 PF + 2 PFA 60 500 500 400 50 PFA 10 40 PF + PFA 2 PFA 300 PF 200 0 100 5 0 0 5 10 12 14 19 15 Luftfördermenge [m 3/h] 10 15 20 25 30 35 20 20 10 40 1200 300 1000 200 40 60 30 50 20 40 10 30 0 20 PF PF + PFA 44 61 15 20 25 30 40 50 30 60 35 7040 Temperature difference ∆T [K] Temperaturdifferenz ∆ T [K] Luftfördermenge [m 3/h] 20 10 200 10 5 10 15 20 25 30 35 40 Z1 Dimensions X Y 500 Z1 400 Z2 3001 A 200 B1 100 40 600 30 20 10 0 0 1 PF 22.000 AC 20 10 40 70 PFA 20.000 DC 145 145 145 145 145PFA 5 5 64 125 125 125 125 PF + 2 PFA 700 600 PFA PF 46 PF +56PFA 260PFA 40 50 500 400 0 300 10 20 30 Airflow rate [m 3/h] Luftfördermenge [m 3/h] 20 30 40 2 PFA 50 60 73 70 70 PF 80 90 98 5 100 110 35 40 125PF 125 B 60 50 40 98 10 20 30 40 50 60 70 80 90 100 110 0 f or material thicknesses up to 2 mm 0 5 10 15 20 25 30 35 40 + 1 mm for thickness of material[m>3/h] 2 mm ≤ 3 mm Luftfördermenge Temperaturdifferenz ∆ T [K] 800 61 Y 5 PF + PFA 262 PFA 73 PFA 70 PF + 2 PFA 145 70 PF 3 Statischer Druck [Pa] Kühlleistung 70 [W ] 700 5 10 15 20 25 30 Luftfördermenge [m 3/h] PF 32.000 IP55 / PF A 30.000 IP55 A Temperaturdifferenz ∆ T [K] Z1 PF 32.000 IP54 / PF A 30.000 IP54 Temperaturdifferenz ∆ T [K] PF 32.000 IP55 / PFA 30.000 IP55 Statischer Druck [Pa] 60 900 mm 50 800 10 900 200 0 100 0 10 0 0 0 0 0 6135 70 PF 32.000 IP55 / PFA 30.000 IP55 Statischer Druck 60 [Pa] 57 Kühlleistung 50 [W ] 70 100 10 800 0 400 PF 20 44 25 15 30 30 40 50 60 3 Airflow rate [m /h] Temperaturdifferenz ∆ T [K] Luftfördermenge [m 3/h] PF 22.000 IP55 / PF A 20.000 IP55 PFA PF + PFA PF + 2 PFA 2 PFA 0 10 5 2 PFA 100 0 PF + 2 PFA Kühlleistung [W ] 400 0 600 200 [Pa] PF Static 32.000Pressure IP54 / PF[Pa] A 30.000 IP54 70 600 PF 32.000 IP54 / PFA 30.000 IP54 60 500 20 PFA PF + PFA PF 22.000 IP 55 Druck Statischer Kühlleistung Statischer Druck [Pa] [W ] Cooling capacity [W] 30 300 0 Temperature difference ∆T [K] Temperaturdifferenz ∆ T [K] PF 22.000 PFA 20.000 PF 22.000 IP54 /IP55 PF A/ 20.000 IP54 IP55 40 400 30 0 50 PF + 2 PFA FILTERFANS 4.0 5 PF 2 PF 22.000 IP 54 Kühlleistung Statischer Druck Kühlleistung 30 [W] Cooling capacity [W] 15 20 PF 22.000 PFA 20.000 pressure performance PFStatic 22.000 IP54 /IP55 PF A/ 20.000 IP54 IP55 curve 35 20 15 Luftfördermenge [m 3/h] PF 11.000 IP54 / PF A 10.000 IP54 25 10 Y PFA 30 20 X 2 PFA Z2 10 PF 0 0 X 20 40 55 60 69 80 Z2 Luftfördermenge [m 3/h] 100 120 140
11720001055 价格&库存
很抱歉,暂时无法提供与“11720001055”相匹配的价格&库存,您可以联系我们找货
  • 1+294.31587
  • 5+289.27557
  • 12+284.05824
  • 25+279.67401
  • 50+273.55068
库存:103
