1415016026
1415016026
    TECSIS
1415016026 数据手册
pressure and vacuum gauges 40MM, ABS, BOTTOM AND REAR ENTRY Nominal Size • Ø40mm ABS housing • Copper alloy measuring system • Built to DIN 16063/EN837 • Ranges from -1… 15 bar to 0… 400 bar • Accuracy class 2.5 to DIN 16005 40mm Type 1410 1415 PART NUMBERS Range (Bar) -1 to 0 -1 to 0.6 -1 to 1.5 -1 to 3 -1 to 5 -1 to 9 -1 to 15 0 to 1 0 to 1.6 0 to 2.5 0 to 4 0 to 6 0 to 10 0 to 16 0 to 25 0 to 40 0 to 60 0 to 100 0 to 160 0 to 250 0 to 315 0 to 400 TECHNICAL SPECIFICATION 1410 1415 016001 042901 043001 044001 045001 046901 049901 069001 070001 072001 073001 074001 075001 076001 078001 079001 080901 081901 082901 084901 085901 086901 016001 042901 043001 044001 045001 046901 049901 069001 070001 072001 073001 074001 075001 076001 078001 079001 080001 081901 082901 084901 085901 086901 Type 1410 1415 Symbol Nominal size (mm) 40 Accuracy class 2.5 to Din 16005 (EN837) Operating range Constant Load: 3/4x full scale Alternating load: 2/3x full scale Case Plastic, black (ABS) Window Plexiglass, convex, clipped on Dial Plastic, white with stop pin, scale black to Din 16109 Pointer Plastic, black Movement Cu Zn alloy (Brass) Wetted parts Measuring element Cu alloy Pressure connection Cu Zn alloy 1 G /8 A (1/8" BSP) Connection thread OPTIONS Temperature ranges Media (see page 49) • Dual scale bar/psi • Connection threads • Panel mounting • G1/4 A(1/4"BSP) T max +60ºC Ambient T min: -40ºC to T max +60ºC Weight approx (Kg) 0.07 0.065 DIMENSIONS D b All Dimensions in mm b1 D G b h a AF AF G Type 1410 Type 1415 Type NG a± 0.5 b± 0.5 b1± 0.5 D± 0.5 G h± 1 AF 1410 40 8 24 - 41 G 1/8 A ( 1/8" BSP) 36 12 - 14 1415 30 40 - 26 44 41 1 1 G /8 A ( /8" BSP) 0800 731 3187 www.oem.co.uk
1415016026 价格&库存
很抱歉,暂时无法提供与“1415016026”相匹配的价格&库存,您可以联系我们找货
