26DBM20B2U-L
26DBM20B2U-L
    PORTESCAP
26DBM20B2U-L 数据手册
Digital linear actuators 26DBM series DLA’s The 26DBM series comprise two versions. Both types are based on 4 phase permanent magnet stepper motor technology and utilise a rotor with an internal thread to provide linear motion via a leadscrew. The L series are provided with a leadscrew which may be attached to the driven mechanism. When the leadscrew is prevented from rotating the operation of the motor imparts linear motion to the screw. The maximum travel of the mechanism is 48 mm although optional 300 mm long leadscrews may be purchased for an increased travel distance of 260 mm. The K series incorporate a keyway in the actuator’s output slideway thereby providing the spindle with linear motion. This design is ideal for driving spring loaded mechanisms over a maximum travel distance of 13 mm. Dimensions mm: 26DBM-L series 15.18 26DBM-K Series 21.31 34 ( extended ) 9.58 ∅ 12.03 ∅ 26.16 New options ∅ 8.13 34.90 42.82 3.81 100% increased force compared with 92100 series 0.81 two point pointing ∅ 3.3 Stroke: 13.2 mm #2-56 UNC –2A thread 76.2 ( Max stroke: 48 mm) Leads 304.8 mm long Performance: 2 6 D B 2 0 M s e rie s 2 6 D B M 1 0 s e rie s 30 25 2 6D B M 20 -D se rie s 15 Force ( N ) Force ( N ) 20 10 26 D B M 20 -B se rie s 5 0 0 50 100 150 200 250 300 2 6 D B M 1 0 -D se ri e s 20 15 10 2 6 D B M 1 0 -B se ri e s 5 0 0 350 50 100 150 200 250 300 350 ste p s/se c ( 0 . 0 0 1 i n . / ste p ) ste p s/se c ( 0 .002 in / ste p ) Specification for uni-polar types Model 26DBM20B1U26DBM20B2U26DBM20D1U26DBM20D2U26DBM10B1U26DBM10B2U26DBM10D1U26DBM10D2U- Nominal Voltage Vdc 5 12 5 12 5 12 5 12 Linear travel per step ins. ( mm ) Maximum travel 0.002 ( 0.0508 ) 13.2 - K series 48 - L series 0.001 ( 0.0254 ) mm 13.2 - K series 48 - L series Maximum Force N 8.9 Min. de-energised holding Force N 2.8N 17.8 8.3 13.3 13.9 28.1 27.8 Nearest equivalent in 92100 series 92121-P1 92121-P2 92111-P1 92111-P2 Insert ‘K’ for keyway version Insert ‘L’ for leadscrew version Electrical Characteristic: Mclennan Servo Supplies Ltd. Coil Data: Resistance per phase Inductance per phase 1U ( 5V ) 14.6 Ohm 5.2 mH 2U ( 12V ) 84 Ohm 27.5 mH Tel: +44 (0)8707 700 700 www.mclennan.co.uk Issue: 001
26DBM20B2U-L 价格&库存
很抱歉,暂时无法提供与“26DBM20B2U-L”相匹配的价格&库存,您可以联系我们找货
