A94B114FRN
A94B114FRN
    ABOV(现代)
    TSSOP-20
A94B114FRN 数据手册
A94B114 ABOV Semiconductor Co., Ltd. CMOS single-chip 8-bit MCU with 12-bit ADC, LDO and Comparator User’s manual Main features   A94B114 Enhanced 8051 microcontroller with reduced instruction cycle time (CM8051-S CPU) V 1.09 Basic MCU Function – 8 Kbytes Flash Code Memory – Code Area Protection – 512 bytes SRAM Data Memory  Built-in Analog Function – Power-On Reset and Low Voltage Detect Reset – Internal HFO (32MHz TYP ± 1.5%, TA= +25°C) – Internal LFO (256kHz ± 10%, TA= -40 ~ +85°C@Normal/IDLE Mode) – Internal LFO (168kHz ± 15%, TA= +25°C @STOP Mode) – Internal LFO (168kHz ± 20%, TA= -40 ~ +85°C@STOP Mode) – Watchdog Timer RC Oscillator (LFO/2 =128kHz)  Peripheral Features – 12-bit Analog to Digital Converter with 2.5V LDO – 16-bit PWM with inverters and dead-band control – USART 8-bit x 1-ch – I2C 8-bit x 1-ch  I/O and Packages – Up to 18 Programmable I/O lines with 20-SOP – 20-SOP, 20-TSSOP, 16-SOPN  Operating Conditions – 2.0V to 5.5V Wide Voltage Range – - 40°C to 85°C Temperature Range  Application – Small Home Appliance – Battery charge & discharge control Revised 17 July, 2018 1 A94B114 ABOV Semiconductor Co., Ltd. Revision history Version Date Revision list 1.00 2017.07.31 Primary Version. 1.01 2017.08.02 Added content of SYSCON_AR register. (11.1.5) Added note of CRC Polynomial. (11.11.4) 1.02 2017.08.15 Fixed typos. 1.03 2017.09.13 Sector 248~255 Endurance added. (7.15.1) Delete the LVIR reset function. (except LVR 1.75V) 1.04 2017.10.24 Added description of PUSH SP, POP SP, DA incompatible instruction. (17.1 APPENDIX) 1.05 2017.11.08 Update Table 7.4 Analog ADC Voltage Revised this book. Add Device Nomenclature Update Internal High Frequency Oscillator spec. Update Figure 10.8 & Page 193. Fuse_CFG1 Revised this book. Added Page 56 ILVL description 1.06 2018.01.22 1.07 2018.02.26 1.08 2018.05.11 Added Note of EINT0~2 operation (10.2), IRQ0~2 operation(10.12.3). 1.09 2018.07.17 The LFO Spec is separated from Normal / IDLE mode and STOP mode.(7.8) Added operation description in STOP mode of BIT. (11.2.1) Added WDT precautions when using LFO clock. (11.3.1) Fixed Peripheral Operation of STOP mode. (12.2) Version 1.09 Published by AE team 2018 ABOV Semiconductor Co. Ltd. all rights reserved. Additional information of this manual may be served by ABOV Semiconductor offices in Korea or distributors. ABOV Semiconductor reserves the right to make changes to any information here in at any time without notice. The information, diagrams and other data in this manual are correct and reliable. However, ABOV Semiconductor is in no way responsible for any violations of patents or other rights of the third party generated by the use of this manual. Contact information For more information, please visit : http://www.abov.co.kr E-mail : fae@abov.co.kr 2 A94B114 ABOV Semiconductor Co., Ltd. 1 Overview 1.1. Description The A94B114 is an advanced CMOS 8-bit microcontroller with 8 Kbytes of FLASH. This is powerful microcontroller which provides a highly flexible and cost effective solution to many embedded control applications. This provides the following features : 8 Kbytes of FLASH, 512 bytes of SRAM, 16-bit timer/counter, 16-bit PWM with inverters and deadband control, Watchdog timer, 12-bit ADC with LDO, On-chip POR, LVI and LVR, Internal High Frequency Oscillator, Internal Low Frequency Oscillator and clock circuitry. The A94B114 also supports Power saving modes to reduce Power Consumption. Device Name FLASH XRAM IRAM A94B114FR 8 Kbytes FLASH A94B114FD 256 bytes 256 bytes A94B114AE Table 1.1 ADC I/O PORT Package 10 inputs 18 20-TSSOP 10 inputs 18 20-SOP 8 inputs 14 16-SOPN Ordering Information of A94B114 Device Nomenclature A94B114 F R N (T) A94B114 Family Name Pin Count F 20 pin A 16 pin Package Type R TSSOP D SOP E SOPN Bonding Wire none Au wire N Pd-Cu wire Packing (T) Tape & Reel Figure 1.1 Device Nomenclature 3 A94B114 1.2  ABOV Semiconductor Co., Ltd. Features CPU  – 8-bit CISC CM8051-S core (8051 Compatible, 1 clocks per cycle)  – Reset release level (1.4V)  8 Kbytes On-Chip FLASH 256 bytes IRAM / 256 bytes XRAM  General Purpose I/O (GPIO)  Low Voltage Indicator  – 4 level detect (2.40/ 2.90/ 3.90/ 4.20V) Interrupt Sources – External Interrupts (EINT0~2, EINT10, EINT11, EINT12) (4) – Timer(0/1/2) (3) – WDT (1) – LVI (1) – USART (2) – I2C (1) – ADC (1) – BIT (1) – CRC (1) – Comparator (1) – Normal I/O : 18 Port ( P0[7:0], P1[5:0], P2[3:0] )  Timer/Counter – 8-bit Timer x 1-ch (T0) – 16-bit Timer x 2-ch (T1, T2)  Programmable Pulse Generation – Pulse generation (by T1/T2) – 16-bit PWM with inverters and Dead-band control x 1ch (by T1)   Comparator – Internal Low Frequency Oscillator : 256kHz ±10% (TA= -40~+85°C, Normal/IDLE) 168kHz ±15% (TA= +25°C, STOP) 168kHz ±20% (TA= -40~+85°C, STOP) Watch Timer (WDT)  – 8-bit x 1-ch – RCWDT with LFO  USART  Minimum Instruction Execution Time - 62.5ns (@16MHz main clock)  Operating Temperature - Power Down Mode – IDLE, STOP mode   12-bit A/D Converter – 10 Input channels  Oscillator Type – 0.4~16 MHz Crystal or Ceramic for main clock I2C – 8-bit× 1-ch  Operating Voltage and Frequency – 1MHz ~ 16MHz • Internal Clock : TA= -40~+85°C, VDD=2.0V ~ 5.5V • External Crystal : TA= -40~+85°C, VDD=2.7V ~ 5.5V – 8-bit× 1-ch  Internal Oscillator – Internal High Frequency Oscillator : 32MHz TYP ±1.5% (TA= 25°C) – Selectable internal reference Comparator. – External (CMN0, CMN1) – Internal (1.6V, 2.2V)  Low Voltage Reset – 1 level detect (1.75) – Endurance : 10,000 times (Sector 0~247) 50,000 timers (Sector 248~255) – Retention : 10 years – In-System Programming (ISP)  Power On Reset Sub-Active mode – System used by internal 128kHz Ring oscillator (LFO/2) -40~ +85℃  Operating Frequency - 1 / 4 / 8 / 16MHz (with HFO/2) - 128kHz (with LFO/2)  Package Type – 20-SOP – 20-TSSOP – 16-SOPN 4 A94B114 ABOV Semiconductor Co., Ltd. 1.3 Development tools 1.3.1 Compiler ABOV semiconductor does not provide any compiler for the A94B114. But the CPU core of A94B114 is CM8051-S core, you can use all kinds of third party's standard 8051 compiler like Keil C Compiler, Open Source SDCC (Small Device C Compiler). These compilers' output debug information can be integrated with our OCD2 emulator and debugger. Refer to OCD2 manual for more details. 1.3.2 OCD2 emulator and debugger The OCD2 emulator supports ABOV Semiconductor’s 8051 series MCU emulation. The OCD2 interface uses two wires interfacing between PC and MCU which is attached to user’s system. The OCD2 can read or change the value of MCU internal memory and I/O peripherals. And also the OCD2 controls MCU internal debugging logic, it means OCD2 controls emulation, step run, monitoring etc. The OCD2 Debugger program works on Microsoft-Windows NT, 2000, XP, Vista, 7, 8, 8.1, 10 (32-bit, 64-bit) operating system. If you want to see more details, please refer OCD2 debugger manual. You can download debugger S/W and manual from our web-site. There are OCD2 mode connection. - P01 (A94B114 DSCL pin) - P00 (A94B114 DSDA pin) 1 2 User VCC 3 4 User GND 5 6 DSCL 7 8 DSDA 9 10 Figure 1.2 On Chip Debugger 2 and Pin description (OCD2 mode) 5 A94B114 ABOV Semiconductor Co., Ltd. OCD2 (On Chip Debug) Emulator • MCU emulation control via 2pin OCD interface. • 2pin interface : OCD2 clock & data. • Higher interface speed than OCD dongle. • Support newly added debugging specifications. • Compact size. • Cost effective emulator. • Emulation & debugging on the target system directly. • Real time emulation. • PC interface : USB. Debugger • Operates with OCD2 emulator H/W. • Integrated Development Environment (IDE). Support docking windows and menus. • Support Free run, Step run, auto step run. • Support Symbolic debugging. • Support Source level debugging. Figure 1.3 OCD2 Debugger 6 A94B114 1.3.3 ABOV Semiconductor Co., Ltd. Programmer E-PGM + • Support ABOV / ADAM devices • 2~5 times faster than S-PGM+ • Main controller : 32-bit MCU @ 72MHz • Buffer memory : 1MB Figure 1.4 E-PGM+ component and connector 7 A94B114 ABOV Semiconductor Co., Ltd. PGMPlusLC2 Description PGMPlusLC2 is for ISP(In System Programming). It is used to write into the MCU Which is already mounted on target board using 10pin cable. Features • PGMplusLC2 is low cost writing Tool. • USB interface is supported. • Not need USB driver installation. • Connect the external power adaptor(5V@2A). • Supported high voltage Max 18V. • PGMplusLC2 is based on PC environment. • PGMplusLC2 is faster than PGMplusLC. • Transmission speed is 64KB/s Figure 1.5 PGMplusLC Writer 8 A94B114 ABOV Semiconductor Co., Ltd. E-PGM+ Gang4/6 • Product name : E-PGM+ GANG 4 • Dimension(x, y, h) : 33.5 x 22.5 x35mm • Weight : 2.0kg • Input Voltage : DC Adaptor 15V/2A • Operating Temp : -10 ~ 40℃ • Storage Temp : -30 ~ 80℃ • Water Proof : No • Product name : E-PGM+ GANG 6 • Dimension(x, y, h) : 148.2 x 22.5 x35mm • Weight : 2.8kg • Input Voltage : DC Adaptor 15V/2A • Operating Temp : -10 ~ 40℃ • Storage Temp : -30 ~ 80℃ • Water Proof : No Figure 1.6 Gang Programmer 9 A94B114 1.3.4 ABOV Semiconductor Co., Ltd. Circuit Design Guide At the FLASH programming, the programming tool needs 4 signal lines that are DSCL, DSDA, VDD, and VSS. When you design the PCB circuits, you should consider the usage of these signal lines for the on-board programming. Please be careful to design the related circuit of these signal pins because rising/falling timing of DSCL and DSDA is very important for proper programming. PGMpulsLC2, E-PGM+, E-PGM+ GANG 4 / 6 R1 (0 ~ 100 ) DSCL(I) To application circuit R2 (0 ~ 100 ) DSDA(I/O) To application circuit VDD VSS NOTE) 1. 2. 3. In on-board programming mode, very high-speed signal will be provided to pin DSCL and DSDA. And it will cause some damages to the application circuits connected to DSCL or DSDA port if the application circuit is designed as high speed response such as relay control circuit. If possible, the I/O configuration of DSDA, DSCL pins had better be set to input mode. The value of R1 and R2 is recommended value. It varies with circuit of system. When using LFO (Low Frequency Oscillator), it is recommended that the resistance value of R2 is 100 ohms. Because the internal De-bounce circuit does not operate normally at low clocks, this prevents Glitch from corrupting OCD communication. Figure 1.7 PCB design guide for on board programming 10 A94B114 2 ABOV Semiconductor Co., Ltd. Block diagram T0O(PWM0O) EINT10/EC0 Timer 0 (8-Bit) T2O/PWM2O EC2/EINT12 Timer 2 (16-Bit) T1O/PWM1O EC1/EINT11 PWM1OB OCD2 ( On-Chip debugger 2 ) CM8051-S CORE Timer 1 (16-Bit) FLASH (8K bytes) P1 PORT P10~P15 P2 PORT P20~P23 COMPARTOR CMO CMN0 CMN1 XRAM (256 bytes) EINT0 BIT TIMER (8-Bit) EINT1 EINT10 P00~P07 IRAM (256 bytes) Complementary PWM Control EINT2 P0 PORT 1.6V, 2.2V CMP 2.5V LDO Interrupt Controller Watch Dog Timer EINT11 AVDD EINT12 LFO 256kHz SCL (P14/P20) SDA (P15/P21) HFO 32MHz I2C ADC Ref. AN9/P23 AN8/P22 AN7/P07 RXD/P14 TXD/P15 SS/P00 XCK/P01 XIN/P11 XOUT/P10 RESETB/P13 AN6/P06 Power on Reset USART Low Voltage Indicator Low Voltage Reset System & Clock Control VDD Figure 2.1 VSS Block diagram of A94B114 NOTE) The P20, P21, P22 and P23 are not in the 16-Pin package. 11 AN5/P05 12 bit ADC AN4/P04 AN3/P03 AN2/P02 AN1/P01 AN0/P00 A94B114 3 ABOV Semiconductor Co., Ltd. Pin assignment 1 20 VDD 2 19 P00/AN0/SS/DSDA PWM1O/T1O/XIN/P11 3 18 P01/AN1/XCK/DSCL PWM2O/T2O/EC2/EINT12/P12 4 17 P02/AN2/EINT0 RESETB/P13 5 16 P22/AN8/EINT1 (SCL)/RXD/EINT10/P14 6 15 P23/AN9/EINT10/EC0/T0O/PWM1OB (SDA)/TXD/P15 7 14 P03/AN3/EINT11/EC1/T1O/PWM1O A94B114FR (20-TSSOP) VSS PWM2O/T2O/XO UT/P10 SCL/P20 8 13 P04/AN4/CMN1/EINT2/PWM1OB SDA/P21 9 12 P05/AN5/CMN0 10 11 P06/AN6/CMP CMO/AN7/P07 NOTE) 1. 2. 3. 4. Figure 3.1 The programmer (PGMplusLC, E-PGM+) uses P0[1:0] pin as DSCL, DSDA. The SDA/SCL lines for I2C can be configured on the P20/P21 (P14/P15) pins by software control. To use T1O/PWM1O as pin3(P11), set Sub-function and set it to Output High. To use T2O/PWM2O as pin2(P10), set Sub-function and set it to Output Low. A94B114FR 20-TSSOP Pin Assignment 1 20 VDD PWM2O/T2O/XO UT/P10 2 19 P00/AN0/SS/DSDA 18 P01/AN1/XCK/DSCL 17 P02/AN2/EINT0 16 P22/AN8/EINT1 15 P23/AN9/EINT10/EC0/T0O/PWM1OB 14 P03/AN3/EINT11/EC1/T1O/PWM1O 13 P04/AN4/CMN1/EINT2/PWM1OB 9 12 P05/AN5/CMN0 10 11 P06/AN6/CMP PWM1O/T1O/XIN/P11 3 PWM2O/T2O/EC2/EINT12/P12 4 RESETB/P13 5 (SCL)/RXD/EINT10/P14 6 (SDA)/TXD/P15 7 SCL/P20 8 SDA/P21 CMO/AN7/P07 A94B114FD (20-SOP) VSS NOTE) 1. 2. 3. 4. Figure 3.2 The programmer (PGMplusLC, E-PGM+) uses P0[1:0] pin as DSCL, DSDA. The SDA/SCL lines for I2C can be configured on the P20/P21 (P14/P15) pins by software control. To use T1O/PWM1O as pin3(P11), set Sub-function and set it to Output High. To use T2O/PWM2O as pin2(P10), set Sub-function and set it to Output Low. A94B114FD 20-SOP Pin Assignment 12 A94B114 ABOV Semiconductor Co., Ltd. 1 16 VDD PWM2O/T2O/XOUT/P10 2 15 P00/AN0/SS/DSDA 14 P01/AN1/AN1/XCK/DSCL 13 P02/AN2/EINT0 12 P03/AN3/EINT11/EC1/T1O/PWM1O 11 P04/AN4/CMN1/EINT2/PWM1OB PWM1O/T1O/XIN/P11 3 PWM2O/T2O/EC2/EINT12/P12 4 RESETB/P13 5 (SCL)/RXD/EINT10/P14 6 (SDA)/TXD/P15 7 CMO/AN7/P07 8 A94B114AE (16-SOPN) VSS 10 P05/AN5/CMN0 9 P06/AN6/CMP NOTE) 1. 2. 3. 4. 5. Figure 3.3 The programmer (PGMplusLC, E-PGM+) uses P0[1:0] pin as DSCL, DSDA. The P20, P21, P22 and P23 pins should be selected as a push-pull output or an input with pull-up resistor by software control when the 16-pin package is used. The SDA/SCL lines for I2C can be configured on the P20/P21 (P14/P15) pins by software control. To use T1O/PWM1O as pin3(P11), set Sub-function and set it to Output High. To use T2O/PWM2O as pin2(P10), set Sub-function and set it to Output Low. A94B114AE 16-SOPN Pin Assignment 13 A94B114 4 ABOV Semiconductor Co., Ltd. Package Diagram Figure 4.1 A94B114FR (20-TSSOP) Package Dimention 14 A94B114 ABOV Semiconductor Co., Ltd. Figure 4.2 A94B114FD (20-SOP) Package Dimention 15 A94B114 ABOV Semiconductor Co., Ltd. Figure 4.3 A94B114AE (16-SOPN) Package Dimention 16 A94B114 5 ABOV Semiconductor Co., Ltd. Pin Description PIN Name I/O Function @RESET Shared with P00 AN0/SS/DSDA P01 AN1/XCK/DSCL P02 P03 P04 I/O P05 Port 0 is a bit-programmable I/O port which can be configured as a schmitt-trigger input, a push-pull output, or an open-drain output. A pull-up resistor can be specified in 1-bit unit. AN2//EINT0 Input AN3/EINT11/EC1/T1O/PWM1O AN4/EINT2/CMN1/PWM1OB AN5/CMN0 P06 AN6/CMP P07 AN7/CMO P10 XOUT/T2O/PWM2O P11 P12 P13 I/O Port 1 is a bit-programmable I/O port which can be configured as a schmitt-trigger input, a push-pull output, or an open-drain output. A pull-up resistor can be specified in 1-bit unit. XIN/T1O/PWM1O Input EINT12/EC2/T2O/PWM2O RESETB P14 RXD/(SCL)/EINT10 P15 TXD/(SDA) P20 P21 P22 I/O P23 SCL Port 2 is a bit-programmable I/O port which can be configured as a schmitt-trigger input, a push-pull output, or an open-drain output. A pull-up resistor can be specified in 1-bit unit. The P20 - P23 are only in the 20-Pin package. Input External interrupt inputs Input P22/AN8 Input Input P04/AN4/CMN1/PWM1OB P14/RXD/(SCL) P23/AN9/EC0/T0O/PWM1OB P03/AN3/EC1/T1O/PWM1O Input P12/EC2/T2O/PWM2O AN8/EINT1 AN9/EINT10/EC0/ECO/T0O/PWM1OB EINT0 P02/AN2/SS EINT1 EINT2 EINT10 SDA I External interrupt inputs, Timer Capture and timer event counter inputs. (Timer 0, 1, 2) EINT11 EINT12 T0O Timer 0 interval output Input P23/AN9/EINT10 T1O Timer 1 interval output Input P03/AN3/EINT11/EC1/PWM1O T2O Timer 2 interval output Input P12/EINT12/ PWM2O PWM0O Timer 0 PWM output Input P23/AN9/EINT10/T0O PWM1O Timer 1 PWM output Input PWM1OB Timer 1 PWM Complementary output Input PWM2O Timer 2 PWM output Input P03/AN3/EINT11/EC1/T1O P04/AN4/EINT2/CMN1 P23/AN9/EINT10/EC0/T0O P12/EINT12/T2O O SS I/O USART external clock input/output Input P00/AN0/DSDA XCK I/O USART slave selection input/output input P01/AN1/DSCL TXD O USART data output Input P15/SDA (Second Select Pin) RXD I USART data input Input P14/SCL (Second Select Pin)/EINT10 SCL I/O I2C clock input/output Input P20, P14/(SCL) SDA I/O I2C data input/output Input P21, P15/(SDA) Table 5.1 Normal Pin Description 17 A94B114 ABOV Semiconductor Co., Ltd. PIN Name AN0 AN1 AN2 AN3 AN4 AN5 AN6 AN7 AN8 AN9 CMP CMN0 CMN1 CMO I/O Function @RESET I A/D converter input channels Input I I I O Input input input input RESETB I Input P13 DSDA DSCL XIN XOUT VDD, VSS I/O I Comparator input channel (+) Comparator input channel (-) Comparator input channel (-) Comparator output System reset pin with a pull-up resistor when it is selected as the RESETB by CONFIGURE OPTION Programmer data input/output (NOTE4,5) Programmer clock input (NOTE4,5) Shared with P00/SS/DSDA P01/XCK/DSCL P02//EINT0 P03/EINT11/EC1/T1O/PWM1O P04/EINT2/CMN1/PWM1OB P05/CMN0 P06/CMP P07/CMO P22/EINT1 P23/EIN10/EC0/T0O/PWM1OB P06/AN6 P05/AN5 P04/AN4/EINT2/PWM1OB P07/ AN7 Input Input I/O Main oscillator pins Input – Power input pins – P00/AN0/SS P01/AN1/XCK P11/T2O/PWM2O P10/T1O/PWM1O – Table 5.2 Normal Pin Description (Concluded) NOTE) 1. 2. 3. 4. The P20, P21, P22 and P23 are not in the 16-Pin package. The P13/RESETB pin is configured as one of the P13 and the RESETB pin by the “CONFIGURE OPTION”. If the P00 and P01 pins are connected to the programmer during power-on reset, the pins are automatically configured as In-System programming pins. The P00 and P01 pins are configured as inputs with internal pull-up resistor only during the reset or power-on reset. 18 A94B114 ABOV Semiconductor Co., Ltd. 6 Port Structures 6.1 General Purpose I/O Port Level Shift (1.8V to ExtVDD) Level Shift (ExtVDD to 1.8V) VDD PULL-UP REGISTER VDD VDD OPEN DRAIN REGISTER DATA REGISTER 0 MUX SUB-FUNC DATA OUTPUT PAD 1 SUB-FUNC ENABLE SUB-FUNC DIRECTION DIRECTION REGISTER 1 MUX 0 CMOS or Schmitt Level Input PORTx INPUT or SUB-FUNC DATA INPUT ANALOG CHANNEL ENABLE ANALOG INPUT Figure 6.1 General Purpose I/O Port 19 A94B114 6.2 ABOV Semiconductor Co., Ltd. External Interrupt I/O Port Level Shift (1.8V to ExtVDD) Level Shift (ExtVDD to 1.8V) VDD PULL-UP REGISTER VDD VDD OPEN DRAIN REGISTER DATA REGISTER 0 MUX SUB-FUNC DATA OUTPUT PAD 1 SUB-FUNC ENABLE SUB-FUNC DIRECTION 1 MUX DIRECTION REGISTER 0 VDD Q EXTERNAL INTERRUPT INTERRUPT ENABLE D POLARITY REG. CP r FLAG CLEAR CMOS or Schmitt Level Input 0 PORTx INPUT or SUB-FUNC DATA INPUT MUX 1 Q D CP r ANALOG CHANNEL ENABLE DEBOUNCE ENABLE ANALOG INPUT Figure 6.2 External Interrupt I/O Port 20 DEBOUNCE CLK A94B114 ABOV Semiconductor Co., Ltd. 7 Electrical Characteristics 7.1 Absolute Maximum Ratings Parameter Symbol Rating Unit Note Supply Voltage VDD -0.3~+6.5 V – VI -0.3~VDD+0.3 V VO -0.3~VDD+0.3 V IOH -15 mA Maximum current output sourced by (IOH per I/O pin) ∑IOH -80 mA Maximum current (∑IOH) IOL 30 mA Maximum current sunk by (IOL per I/O pin) Normal Voltage Pin Voltage on any pin with respect to VSS ∑IOL 160 mA Maximum current (∑IOL) Total Power Dissipation PT 400 mW – Storage Temperature TSTG -65~+150 °C – Table 7.1 Absolute Maximum Ratings NOTE) Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress rating only and functional operation of the device at any other conditions beyond those indicated in the operational sections of this specification is not implied. Exposure to absolute maximum rating conditions for extended periods may affect device reliability. 7.2 Recommended Operating Conditions (TA= -40°C ~ +85°C) Parameter Symbol Operating Voltage VDD Operating Temperature Table 7.2 7.3 TOPR Conditions fX= 1, 4, 8, 16MHz HFO fX= 256kHz LFO fX= 0.4 ~ 16MHz Crystal VDD=2.0~5.5V (Internal RC) VDD=2.7~5.5V (Crystal) MIN TYP 2.0 – 2.7 – -40 – MAX Unit 5.5 V 85 °C Recommended Operating Conditions Low Drop Out Characteristics (TA= -40 ~ +85oC, AVDD=2.7~5.5V, VSS=0V) Parameter Symbol LDO Output Voltage VLDO Quiescent Current Load Current Table 7.3 Condition MIN TYP MAX TA=-40~85℃ 2.450 2.5 2.550 TA=25℃ 2.470 2.5 2.530 IQ AVDD=5.5V - 300 400 uA IL Dropout Voltage=0.2V - - 1 mA Low Drop Out Characteristics 21 Unit A94B114 7.4 ABOV Semiconductor Co., Ltd. A/D Converter Characteristics (TA= -40℃ ~ +85℃, VDD= 2.5V ~ 5.5V, VSS=0V) Parameter Symbol Conditions MIN TYP MAX Unit Resolution Integral Non-Linearity Differential Non-Linearity Offset Error of Top Offset Error of Bottom – INL DNL EOT EOB – –– – – – 12 – – ±4 ±2 – ±5 ±3 ±8 ±4 bit Voltage = 1.25V (LDO ref) ADC Clock= 500kHz (LDO ref) – ±15 – Voltage = 2.50V (LDO ref) ADC Clock= 500kHz (LDO ref) – ±20 – – – – 20 30 60 VSS 2.2 – – – ±4 ±2 – – – – – 2.5 – 1 ±3 ±8 ±3 – – – VDD VDD 2 2 – – 0.1 LDO Ref. Integral Non-Linearity Analog Reference Voltage = 2.7V ~ 5.5V (VDD ref) ADC Clock= 2MHz (VDD ref) LDO_INL LDO Ref. Differential Non-Linearity LDO Ref. Offset Error of Top LDO Ref. Offset Error of Bottom LDO_DNL LDO_EOT LDO_EOB Conversion Time tCON Analog Input Voltage Analog Input Leakage Current VAN VDDREF LDOREF IAN ADC Operating Current IADC Analog Reference Voltage Table 7.4 NOTE Voltage = 2.5V ~ 5.5V (LDO ref) ADC Clock= 500kHz (LDO ref) AVREF = 3.0V ~ 5.5V AVREF = 2.7V ~ 5.5V AVREF = 2.4V ~ 5.5V – *NOTE – VDDREF=5.12V Enable VDD=5.12V Disable LSB LSB us V V uA mA uA A/D Converter Characteristics *NOTE) If the Analog reference voltage is lower than 2.7V and the ADC Clock is faster than 2MHz, ADC resolution will be degraded. (Analog Reference = VDDREF) If the Analog reference voltage is lower than 2.5V and the ADC Clock is faster than 500kHz, ADC resolution will be degraded. (Analog Reference = LDOREF) When LDO Reference is used, ADC gain can be affected by LDO output variation. 7.5 Low Voltage Reset and Low Voltage Indicator Characteristics (TA= -40°C ~ +85°C, VDD=2.0V ~ 5.5V, VSS=0V) Parameter Symbol Conditions VLVR VLVI Detection Level The LVR can select 1.75V but LVI can select other levels except 1.75V MIN TYP MAX – 1.75 1.90 2.2 2.4 2.6 2.7 2.9 3.1 3.6 3.9 4.2 3.9 4.2 4.5 Unit V Hysteresis △V – – 50 – mV Minimum Pulse Width tLW – – 500 – us LVR and LVI Current ILVR 1 – – 50 Table 7.5 7.6 LVR 1.75V VDD=5V LVI except 1.75V – – uA LVR and LVI Characteristics Power-On Reset Characteristics (TA=-40°C ~ +85°C, VDD=2.0V ~ 5.5V, VSS=0V) Parameter Symbol Conditions MIN TYP MAX Unit RESET Release Level VPOR – – 1.25 – V VDD Voltage Rising Time tR – 0.05 – 5.0 V/ms POR Current IPOR – – 0.1 – uA Table 7.6 Power-on Reset Characteristics 22 A94B114 7.7 ABOV Semiconductor Co., Ltd. Internal High Frequency Oscillator Characteristics (TA= -40°C ~ +85°C, VDD=2.0V ~ 5.5V, VSS=0V) Parameter Symbol Conditions MIN TYP MAX Unit Frequency fIRC VDD = 2.0 ~ 5.5V – 32 – MHz – ±1.5 – Tolerance – -2.5 – 2.5 -3.0 – 3.0 TA = 25°C TA = 0°C to +50°C TA = -40°C to +85°C With 0.1uF Bypass capacitor % Stabilization Time THFS – – 1 – ms Operating Current IHFO Enable – 0.4 – mA Table 7.7 7.8 High Internal RC Oscillator Characteristics Internal Low Frequency Oscillator Characteristics (TA= -40°C ~ +85°C, VDD=2.0V ~ 5.5V, VSS=0V) Parameter Symbol fLFON(Normal/IDLE) Frequency fLFOS(STOP) TLFON(Normal/IDLE) Tolerance TLFOS(STOP) Conditions MIN TYP – VDD = 2.0 ~ 5.5V With 0.1uF Bypass capacitor TA = 25°C Unit – kHz – kHz 256 – TA = -40°C to +85°C MAX 168 -10 – +10 % -15 – +15 % TA = -40°C to +85°C -20 – +20 % Stabilization Time TLFS – – 1 – ms Operating Current ILFO Enable – 1.5 – uA Table 7.8 7.9 Ring-Oscillator Characteristics Comparator Characteristics (TJ=-40℃ ~ +125℃, AVDD=2.2V ~ 5.5V) Parameter Symbol Operating Current IDD(RMS) Stop Current ISTOP(RMS) Comparator Input Offset Voltage VOS Propagation Delay tPD(tPHL) Hysteresis tHYS Internal VREF Stabilization Time tWKUP Table 7.9 Conditions MIN TYP MAX Unit - 100 200 uA nA 12 100 @Trim Comparator - ±10 - @Trim Comparator + LDO Internal Ref - ±25 - @Trim Comparator + AVDD Internal Ref - ±25 - No Trim, Comparator Only - ±40 - - 0.08 0.15 us - ±16 ±20 mV 4 - HYS_EN_I=’High’ (Except input offset) Comparator Characteristics 23 mV us A94B114 7.10 ABOV Semiconductor Co., Ltd. DC Characteristics (TA= -40°C ~ +85°C, VDD= 2.0V ~ 5.5V, VSS= 0V, fXIN= 16MHz) Parameter Symbol Conditions MIN TYP MAX Input High Voltage Input Low Voltage VIH1 VIL1 P0, P1, P2 P0, P1, P2 VDD=3.3V, IOH=-4mA, All output ports VDD=5V, IOH=-8mA, All output ports VDD=3.3V, IOL= 5mA, All output ports VDD=5V, IOL= 10mA, All output ports 0.7VDD – – – VDD 0.3VDD V V VDD-1.0 – – V VDD-1.0 – – V – – 1.0 V – – 1.0 V IIH All input ports - – 1 uA IIL All input ports -1 – - uA Pull-Up Resistor RPU1 VI=0V, TA= 25°C All Input ports 25 50 100 kΩ Run Mode, fX=16MHz (HFO/2) – 3 6 mA IDLE Mode, fX=16MHz – 0.8 1.6 mA Power Supply Current IDD1 (RUN) IIDD2 (IDLE) IDD3 (RUN_LFO) IDD4 (STOP1) IDD5 (STOP2) Run Mode, fX=128kHz (LFO/2) – 1 2.5 mA STOP1 Mode, LFO Enable – 5 20 uA STOP2 Mode, LFO Disable, LVR Disable – 2.5 5 uA VOH1 Output High Voltage VOH2 VOL1 Output Low Voltage VOL2 Input High Leakage Current Input Low Leakage Current Table 7.10 7.11 Unit DC Characteristics AC Characteristics (TA= -40°C ~ +85°C, VDD= 2.0V ~ 5.5V) Parameter Symbol Conditions MIN TYP MAX Unit RESETB input low width tRST Input, VDD= 5V – 500 – us All interrupt, VDD= 5V 125 – – ECn, VDD = 5V 125 – – ECn, VDD = 5V – – 20 External Counter Input High, Low Pulse Width tIWH, tIWL tECWH, tECWL External Counter Transition Time tREC, tFEC Interrupt input high, low width Table 7.11 AC Characteristics t RST RESETB 0.2 VDD tIWH t IWL External Interrupt 0.8 VDD 0.2 VDD t ECWH t ECWL ECn Figure 7.1 tREC t FEC AC Timing 24 ns A94B114 7.12 ABOV Semiconductor Co., Ltd. USART Characteristics (TA= -40°C ~ +85°C, VDD=2.0V ~ 5.5V, fXIN=16MHz) Parameter Symbol MIN TYP MAX Unit Serial port clock cycle time tSCK 1800 tCPU x 16 2200 ns Output data setup to clock rising edge tS1 8100 tCPU x 13 – ns Clock rising edge to input data valid tS2 – – 590 ns Output data hold after clock rising edge tH1 tCPU- 50 tCPU – ns Input data hold after clock rising edge tH2 0 – – ns Serial port clock High, Low level width tHIGH, tLOW 720 tCPU x 8 1280 ns Table 7.12 USART Characteristics t SCK t HIGH Figure 7.2 t LOW Waveform for USART Timing Characteristics tSCK Shift Clock tS1 Data Out tH1 D0 D1 D2 tS2 Data In Figure 7.3 Valid D3 D4 D5 D6 D7 tH2 Valid Valid Valid Timing Waveform for the USART Module 25 Valid Valid Valid Valid A94B114 7.13 ABOV Semiconductor Co., Ltd. I2C Characteristics (TA= -40°C ~ +85°C, VDD=2.0V ~ 5.5V) Parameter Symbol Clock frequency Clock High Pulse Width Standard Mode High-Speed Mode MIN MAX MIN MAX tSCL 0 100 0 400 tSCLH 4.0 – 0.6 – Clock Low Pulse Width tSCLL 4.7 – 1.3 – Bus Free Time tBF 4.7 – 1.3 – Start Condition Setup Time tSTSU 4.7 – 0.6 – Start Condition Hold Time tSTHD 4.0 – 0.6 – Stop Condition Setup Time tSPSU 4.0 – 0.6 – Stop Condition Hold Time tSPHD 4.0 – 0.6 – Output Valid from Clock tVD 0 – 0 – Data Input Hold Time tDIH 0 – 0 1.0 Data Input Setup Time tDIS 250 – 100 – Table 7.13 Unit kHz us ns I2C Characteristics tSCL tSCLH tSTSU tSCLL tDIH tSPSU SCL tSPHD SDA tSTHD tVD SDA Out tVD Figure 7.4 I2C Timing 26 tDIS tBF A94B114 7.14 ABOV Semiconductor Co., Ltd. Data Retention Voltage in Stop Mode (TA=-40°C ~ +85°C) Parameter Symbol Conditions MIN TYP MAX Unit Data retention supply voltage VDDDR – 1.8 – 5.5 V IDDDR VDDR= 1.8V, (TA= 25°C), Stop mode – – 1 uA Data retention supply current Table 7.14 Data Retention Voltage in Stop Mode Idle Mode (Watchdog Timer Active) ~ ~ Stop Mode Normal Operating Mode Data Retention ~ ~ V DD V DDDR Execution of STOP Instruction 0.8VDD INT Request t WAIT NOTE: tWAIT is the same as (the selected bit overflow of BIT) X 1/(BIT Clock) Figure 7.5 Stop Mode Release Timing when Initiated by an Interrupt RESET Occurs ~ ~ Oscillation Stabillization Time Stop Mode Normal Operating Mode Data Retention ~ ~ VDD V DDDR RESETB Execution of STOP Instruction 0.8 VDD 0.2 VDD TWAIT NOTE : tWAIT is the same as (4096 X 4 X 1/fx) (16.4ms @ 1MHz) Figure 7.6 Stop Mode Release Timing when Initiated by RESETB 27 A94B114 7.15 ABOV Semiconductor Co., Ltd. Internal Flash Rom Characteristics (TA=-40°C ~ +85°C, VDD=2.0V ~ 5.5V, VSS= 0V) Parameter Symbol Condition MIN TYP MAX Sector Write Time tFSW – – 2.5 2.7 Sector Erase Time tFSE – – 2.5 2.7 Code Write Protection Time tFHL – – 2.5 2.7 Page Buffer Reset Time tFBR – – – 5 us Flash Programming Frequency fPGM – 0.4 – – MHz Endurance of Write/Erase NFWE – – – 10,000 cycles Table 7.15 Unit ms Internal Flash Rom Characteristics 7.15.1 Internal Flash Rom Characteristics (Sector 248~255) (TA= 25°C, VDD=2.0V ~ 5.5V, VSS= 0V) Parameter Symbol Condition MIN TYP MAX Sector Write Time tFSW – – 2.5 2.7 Sector Erase Time tFSE – – 2.5 2.7 Code Write Protection Time tFHL – – 2.5 2.7 Page Buffer Reset Time tFBR – – – 5 us Flash Programming Frequency fPGM – 0.4 – – MHz Endurance of Write/Erase NFWE – – – 50,000 cycles Table 7.16 Unit ms Internal Flash Rom Characteristics NOTE) During a flash operation, SCLK[1:0] of SCCR must be set to “00” or “01” (HFO or Main Crystal for system clock). 7.16 Input / Output Capacitance (TA= -40°C ~ +85°C, VDD=0V) Parameter Symbol Input Capacitance CIN Output Capacitance COUT I/O Capacitance CIO Table 7.17 Condition MIN TYP MAX Unit fx= 1MHz Unmeasured pins are connected to VSS – – 10 pF Input / Output Capacitance 28 A94B114 7.17 ABOV Semiconductor Co., Ltd. Main Clock Oscillator Characteristics (TA=-40°C ~ +85°C, VDD=2.0V ~ 5.5V) Oscillator Parameter Crystal Main oscillation frequency Ceramic Oscillator Main oscillation frequency External Clock XIN input frequency Table 7.18 Condition MIN TYP MAX 2.0V – 5.5V 0.4 – 4.2 2.7V – 5.5V 0.4 – 16.0 2.0V – 5.5V 0.4 – 4.2 2.7V – 5.5V 0.4 – 16.0 2.0V – 5.5V 0.4 – 4.2 2.7V – 5.5V 0.4 – 16.0 Main Clock Oscillator Characteristics XIN XOUT C2 C1 Figure 7.7 Figure 7.8 Crystal/Ceramic Oscillator XIN XOUT External Clock Source Open External Clock 29 Unit MHz MHz MHz A94B114 7.18 ABOV Semiconductor Co., Ltd. Main Oscillation Stabilization Characteristics (TA=-40°C ~ +85°C, VDD=2.0V ~ 5.5V) Oscillator Parameter MIN TYP MAX Unit Crystal fx > 1MHz Oscillation stabilization occurs when VDD is equal to the minimum oscillator voltage range. fXIN = 0.4 to 16MHz XIN input high and low width (tXH, tXL) – – 60 ms – – 10 ms 42 – 1250 ns Ceramic External Clock Table 7.19 Main Oscillation Stabilization Characteristics 1/fXIN tXL tXH 0.8VDD XIN 0.2VDD Figure 7.9 7.19 Clock Timing Measurement at XIN Operating Voltage Range (fx in = 0.4 to 16MHz) 16.0MHz 4.2MHz 0.4MHz 2.0 2.7 Supply voltage(V) Figure 7.10 Operating Voltage Range 30 5.5 A94B114 7.20 ABOV Semiconductor Co., Ltd. Recommended Circuit and Layout { This 0.1uF capacitor should be within 0.5cm from the VDD pin of MCU on the PCB layout. VDD VSS } VDD + 0.1uF 0.1uF VCC { Storage Power Capacitor should be at least 10uF. } DC Power VCC A94B114 High-Current Part { { I/O 0.01uF { XIN This 0.01uF capacitor is alternatively for noise immunity. } X-tal The main crystal should be within 1cm from the pins of MCU on the PCB layout. XOUT Figure 7.11 } Infrared LED, FND(7-Segment), ,,,,, etc The MCU power line (VDD and VSS) should be separated from the highcurrent part at a DC power node on the PCB layout. Recommended Circuit and Layout 31 } A94B114 7.21 ABOV Semiconductor Co., Ltd. Typical Characteristics These graphs and tables provided in this section are only for design guidance and are not tested or guaranteed. In graphs or tables some data are out of specified operating range (e.g. out of specified VDD range). This is only for information and devices are guaranteed to operate properly only within the specified range. The data presented in this section is a statistical summary of data collected on units from different lots over a period of time. “Typical” represents the mean of the distribution while “max” or “min” represents (mean + 3σ) and (mean - 3σ) respectively where σ is standard deviation. RUN Current (mA) 4.5 4 3.5 fXIN=16MHz IRC=16MHz 3 2.5 2.0V IDLE Current (mA) Figure 7.12 5.5V 1.29 IRC=16MHz 1.27 1.25 2.7V VDD (V) 3.3V 5.5V IDLE (IDD2) Current 1.3 (uA) STOP2 (IDD5) Current 3.3V 1.31 LVR ON 0.8 LVR OFF 0.3 2.0V Figure 7.14 VDD (V) RUN (IDD1 ) Current 2.0V Figure 7.13 2.7V 2.7V VDD (V) STOP (IDD5) Current 32 3.3V 5.5V A94B114 8 ABOV Semiconductor Co., Ltd. Memory The A94B114 addresses two separate address memory stores: Program memory and Data memory. The logical separation of Program and Data memory allows Data memory to be accessed by 8-bit addresses, which makes the 8bit CPU access the data memory more rapidly. Nevertheless, 16-bit Data memory addresses can also be generated through the DPTR register. A94B114 provides on-chip 8 Kbytes of the ISP type flash program memory, which can be read and written to. Internal data memory (IRAM) is 256 bytes and it includes the stack area. External data memory (XRAM) is 256 bytes. 8.1 Program Memory A 16-bit program counter is capable of addressing up to 64 Kbytes, but this device has just 8 Kbytes program memory space. Figure 8-1 shows the map of the lower part of the program memory. After reset, the CPU begins execution from location 0000H. Each interrupt is assigned a fixed location in program memory. The interrupt causes the CPU to jump to that location, where it commences execution of the service routine. External interrupt 10, for example, is assigned to location 000BH. If external interrupt 10 is going to be used, its service routine must begin at location 000BH. If the interrupt is not going to be used, its service location is available as general purpose program memory. If an interrupt service routine is short enough (as is often the case in control applications), it can reside entirely within that 8 byte interval. Longer service routines can use a jump instruction to skip over subsequent interrupt locations, if other interrupts are in use. FFFFH 1FFFH 8K Bytes 0000H Figure 8.1 Program Memory NOTE) 1. 8k bytes Including Interrupt Vector Region 33 A94B114 8.2 ABOV Semiconductor Co., Ltd. Data Memory FFH FFH Upper 128bytes Internal RAM (Indirect Addressing) Special Function Registers 128bytes (Direct Addressing) 80H 80H 7FH Lower 128bytes Internal RAM (Direct or Indirect Addressing) 00H Figure 8.2 Data Memory Map The internal data memory space is divided into three blocks, which are generally referred to as the lower 128 bytes, upper 128 bytes, and SFR space. Internal data memory addresses are always one byte wide, which implies an address space of only 256 bytes. However, in fact the addressing modes for internal RAM can accommodate up to 384 bytes by using a simple trick. Direct addresses higher than 7FH access one memory space and indirect addresses higher than 7FH access a different memory space. Thus Figure 8-2 shows the upper 128 bytes and SFR space occupying the same block of addresses, 80H through FFH, although they are physically separate entities. The lower 128 bytes of RAM are present in all 8051 devices as mapped in Figure 8-3. The lowest 32 bytes are grouped into 4 banks of 8 registers. Program instructions call out these registers as R0 through R7. Two bits in the Program Status Word select which register bank is in use. This allows more efficient use of code space, since register instructions are shorter than instructions that use direct addressing. The next 16 bytes above the register banks form a block of bit-addressable memory space. The 8051 instruction set includes a wide selection of single-bit instructions, and the 128 bits in this area can be directly addressed by these instructions. The bit addresses in this area are 00H through 7FH. All of the bytes in the lower 128 bytes can be accessed by either direct or indirect addressing. The upper 128 bytes RAM can only be accessed by indirect addressing. These spaces are used for data RAM and stack. 34 A94B114 ABOV Semiconductor Co., Ltd. 7FH 7F 77 6F 67 5F 57 4F 47 3F 37 2F 27 1F 17 0F 07 General Purpose Register 80 Bytes 30H 2FH 16 Bytes (128bits) Bit Addressable 20H 1FH 8 Bytes 18H 17H 8 Bytes 10H 0FH 8 Bytes 08H 07H 8 Bytes 00H Figure 8.3 Register Bank 3 (8 Bytes) 7E 76 6E 66 5E 56 4E 46 3E 36 2E 26 1E 16 0E 06 7D 75 6D 65 5D 55 4D 45 3D 35 2D 25 1D 15 0D 05 7C 74 6C 64 5C 54 4C 44 3C 34 2C 24 1C 14 0C 04 Register Bank 2 (8 Bytes) R7 R6 R5 R4 R3 R2 R1 R0 Register Bank 1 (8 Bytes) Register Bank 0 (8 Bytes) Lower 128 bytes RAM 35 7B 73 6B 63 5B 53 4B 43 3B 33 2B 23 1B 13 0B 03 7A 72 6A 62 5A 52 4A 42 3A 32 2A 22 1A 12 0A 02 79 71 69 61 59 51 49 41 39 31 29 21 19 11 09 01 78 70 68 60 58 50 48 40 38 30 28 20 18 10 08 00 A94B114 8.3 ABOV Semiconductor Co., Ltd. External Data Memory A94B114 has 256 bytes XRAM and 32 byte XSFR. This area has no relation with RAM/FLASH. It can be read and written to through SFR with 8-bit unit. 20FFH Extended Special Function Registers (32 byte) 20E0H Not Used 00FFH 0000H Figure 8.4 External RAM 256 Bytes (Indirect Addressing) XDATA Memory Area NOTE) XSFR can be declared and used as follows. #define #define #define … CRC_CON CRC_H CRC_L *(volatile unsigned char xdata *) 0x20E0 *(volatile unsigned char xdata *) 0x20E3 *(volatile unsigned char xdata *) 0x20E4 36 A94B114 ABOV Semiconductor Co., Ltd. 8.4 SFR Map 8.4.1 SFR Map Summary - Reserved M8051 compatible 00H/8H(1) 01H/9H 02H/0AH 03H/0BH 04H/0CH 05H/0DH 06H/0EH 07H/0FH 0F8H I2CSR I2CMR I2CSCLLR I2CSCLH R I2CSDAH R I2CDR I2CSAR I2CSAR1 0F0H B FEMR FECR FESR FETCR FEARL FEARM FEARH 0E8H IP IP1 IP2 UCTRL4 FPCR - I2CMR1 - 0E0H ACC UCTRL1 UCTRL2 UCTRL3 USTAT UBAUD UDATA - 0D8H OSCCR SCCR - - - - CMPDBT - 0D0H PSW - - - - - CMPCR CMPTR 0C8H IE2 EIFLAG - - T1CDRL T1CDRH T1DDRL T1DDRH 0C0H IE1 - T2CRL T2CRH T2ADRL T2ADRH T2BDRL T2BDRH 0B8H IE - T1CRL T1CRH T1ADRL T1ADRH T1BDRL T1BDRH 0B0H IRQ2 - - P0FSR_L P0FSR_H P1FSR_L P1FSR_H P2FSR 0A8H IRQ1 - LDOCR P2IO P2PU P2OD P2DB - 0A0H IRQ0 - EO P1IO P1PU P1OD P1DB - 98H RSFR - ILVL P0IO P0PU P0OD P0DB - 90H P2 - T0CR T0CNT 88H P1 LVIR IOFFSET EIPOL0 80H P0 SP DPL/ DPH/ DPL1 DPH1 Table 8.1 NOTE) SFR Map Summary 00H/8H(1), These registers are bit-addressable. 37 T0DR/ T0CDR ADCM EIPOL1 WDTMR DBTSR BITCNT ADCM1/ ADCRL WDTR/ ADCRH WDTCR SYSCON_ AR BITCR PCON A94B114 8.4.2 ABOV Semiconductor Co., Ltd. SFR Map Address Function Symbol R/W 80H P0 Data Register P0 81H Stack Pointer SP 82H Data Pointer Register Low 83H Data Pointer Register High 82H 83H @Reset 7 6 5 4 3 2 1 0 R/W 0 0 0 0 0 0 0 0 R/W 0 0 0 0 0 1 1 1 DPL R/W 0 0 0 0 0 0 0 0 DPH R/W 0 0 0 0 0 0 0 0 Data Pointer Register Low 1 DPL1 R/W 0 0 0 0 0 0 0 0 Data Pointer Register High 1 DPH1 R/W 0 0 0 0 0 0 0 0 84H De-bounce Time Selection Register DBTSR R/W 0 0 0 0 0 0 0 0 85H Basic Interval Timer Counter Register BITCNT R 0 0 0 0 0 0 0 0 86H Basic Interval Timer Control Register BITCR R/W 0 0 0 0 0 1 0 0 87H Power Control Register PCON R/W - – – – 0 0 0 0 88H P1 Data Register P1 R/W - - 0 0 0 0 0 0 89H Low Voltage Indicator Control Register LVIR R/W 0 0 0 0 0 0 0 0 8AH Interrupt Offset Register IOFFSET W 0 0 0 0 0 0 0 0 8BH External Interrupt Polarity Register 0 EIPOL0 R/W 0 0 0 0 0 0 0 0 8CH External Interrupt Polarity Register 1 EIPOL1 R/W 0 0 0 0 0 0 0 0 8DH Watch Dog Timer Mode Register WDTMR R/W 0 0 1 1 1 0 1 1 Watch Dog Timer Data Register WTDR W 1 1 1 1 1 1 1 1 Watch Dog Timer Counter Register WTCR R 0 0 0 0 0 0 0 0 8FH System Control Access Register SYSCON_AR R/W 0 0 0 0 0 0 0 0 90H P2 Data Register P2 R/W – – – – 0 0 0 0 91H Reserved – – 92H Timer 0 Control Register T0CR R/W 0 0 0 0 0 0 0 0 93H Timer 0 Counter Register T0CNT R 0 0 0 0 0 0 0 0 Timer 0 Data Register T0DR R/W 1 1 1 1 1 1 1 1 Timer 0 Capture Data Register T0CDR R 0 0 0 0 0 0 0 0 A/D Converter Mode Register ADCM R/W 1 0 0 0 1 1 1 1 A/D Converter Mode 1 Register ADCM1 W 0 0 0 0 0 0 0 1 A/D Converter Data Low Register ADCRL R 0 0 0 0 0 0 0 0 97H A/D Converter Data High Register ADCRH R 0 0 0 0 0 0 0 0 98H Reset Source Flag Register RSFR R/W 1 0 0 0 0 1 0 0 99H Reserved – – 9AH Interrupt nesting level Register ILVL R/W 0 0 0 0 0 0 0 0 9BH P0 Direction Register P0IO R/W 0 0 0 0 0 0 0 0 9CH P0 Pull-up Resistor Selection Register P0PU R/W 0 0 0 0 0 0 0 0 9DH P0 Open-drain Selection Register P0OD R/W 0 0 0 0 0 0 0 0 9EH P0 De-bounce Time Selection Register P0DB R/W 0 0 0 0 0 0 0 0 9FH Reserved – – A0H Interrupt Request Register 0 IRQ0 0 0 0 0 0 8EH 94H 95H 96H – – – 0 0 0 0 – A1H Reserved – – A2H Extended Operation Register EO R/W – – – – – – – 0 A3H P1 Direction Register P1IO R/W 0 0 0 0 0 0 0 0 A4H P1 Pull-up Resistor Selection Register P1PU R/W 0 0 0 0 0 0 0 0 Table 8.2 SFR Map 38 A94B114 ABOV Semiconductor Co., Ltd. Address Function Symbol R/W A5H P1 Open-drain Selection Register P1OD A6H P1 De-bounce Time Selection Register P1DB @Reset 7 6 5 4 3 2 1 0 R/W 0 0 0 0 0 0 0 0 R/W 0 0 0 0 0 0 0 0 – A7H Reserved – – A8H Interrupt Request Register 1 IRQ1 0 0 A9H Reserved – – – AAH LDO Control Register LDOCR R/W ABH P2 Direction Register P2IO R/W ACH P2 Pull-up Resistor Selection Register P2PU ADH P2 Open-drain Selection Register AEH P2 De-bounce Time Selection Register AFH 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 R/W 0 0 0 0 0 0 0 0 P2OD R/W 0 0 0 0 0 0 0 0 P2DB R/W 0 0 0 0 0 0 0 0 Reserved – – – B0H Interrupt Request Register 2 IRQ2 0 0 0 0 0 0 0 0 0 B1H Reserved – – – B2H Reserved – – – B3H P0 Function Selection Low Register P0FSRL R/W 0 0 0 0 0 0 0 0 B4H P0 Function Selection High Register P0FSRH R/W 0 0 0 0 0 0 0 0 B5H P1 Function Selection Low Register P1FSRL R/W 0 0 0 0 0 0 0 0 B6H P1 Function Selection High Register P1FSRH R/W 0 0 0 0 0 0 0 0 B7H P2 Function Selection Register P2FSR R/W 0 0 0 0 0 0 0 0 B8H Interrupt Enable Register IE R/W 0 – – 0 0 0 0 0 B9H Reserved – – – BAH Timer 1 Control Low Register T1CRL R/W 0 0 0 0 0 0 0 0 BBH Timer 1 Control High Register T1CRH R/W 0 0 0 0 0 0 0 0 BCH Timer 1 A Data Low Register T1ADRL R/W 1 1 1 1 1 1 1 1 BDH Timer 1 A Data High Register T1ADRH R/W 1 1 1 1 1 1 1 1 BEH Timer 1 B Data Low Register T1BDRL R/W 1 1 1 1 1 1 1 1 BFH Timer 1 B Data High Register T1BDRH R/W 1 1 1 1 1 1 1 1 C0H Interrupt Enable Register 1 IE1 R/W – 0 0 0 0 0 0 0 C1H Reserved – – – C2H Timer 2 Control Low Register T2CRL R/W 0 0 0 0 0 0 0 0 C3H Timer 2 Control High Register T2CRH R/W 0 0 0 0 0 0 0 0 C4H Timer 2 A Data Low Register T2ADRL R/W 1 1 1 1 1 1 1 1 C5H Timer 2 A Data High Register T2ADRH R/W 1 1 1 1 1 1 1 1 C6H Timer 2 B Data Low Register T2BDRL R/W 1 1 1 1 1 1 1 1 C7H Timer 2 B Data High Register T2BDRH R/W 1 1 1 1 1 1 1 1 C8H Interrupt Enable Register 2 IE2 R/W – – – – 0 0 0 0 C9H External Interrupt Flag Register EIFLAG CAH Reserved – – – CBH Reserved – – – CCH Timer 1 C Data Low Register T1CDRL R/W 1 1 1 1 1 1 1 1 CDH Timer 1 C Data High Register T1CDRH R/W 1 1 1 1 1 1 1 1 CEH Timer 1 D Data Low Register T1DDRL R/W 1 1 1 1 1 1 1 1 CFH Timer 1 D Data High Register T1DDRH R/W 1 1 1 1 1 1 1 1 Table 8.3 SFR Map (Continue) 39 R/W – – – – – 0 0 0 A94B114 Address ABOV Semiconductor Co., Ltd. R/W @Reset Function Symbol D0H Program Status Word Register PSW D1H Reserved – – – D2H Reserved – – – D3H Reserved – – – D4H Reserved – – – D5H Reserved – D6H Comparator Control Register CMPCR R/W 0 0 0 D7H Comparator Trigger Control Register CMPTR R/W 0 0 D8H Oscillator Control Register OSCCR R/W 0 D9H System Clock Control Register SCCR R/W 0 DAH Reserved – – – DBH Reserved – – – DCH Reserved – – – DDH Reserved – – – DEH Comparator De-bounce Time Register CMPDBT DFH Reserved – E0H Accumulator A Register ACC R/W 0 0 0 E1H USART Control Register 1 UCTRL1 R/W 0 0 0 E2H USART Control Register 2 UCTRL2 R/W 0 0 E3H USART Control Register 3 UCTRL3 R/W 0 E4H USART Status Register USTAT R/W 1 E5H USART Baud Rate Generation Register UBAUD R/W E6H USART Data Register UDATA R/W E7H Reserved – – E8H Interrupt Priority Register IP E9H Interrupt Priority Register 1 EAH EBH 0 4 3 0 2 1 0 0 0 0 0 0 0 1 0 0 0 0 0 0 0 0 0 0 1 0 0 1 0 0 0 0 0 0 1 1 1 1 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 0 – 0 0 0 0 0 0 0 0 0 0 1 1 1 1 1 1 1 1 0 0 0 0 0 0 0 0 R/W 0 0 0 0 0 0 0 0 IP1 R/W 0 0 0 0 0 0 0 0 Interrupt Priority Register 2 IP2 R/W 0 0 0 0 0 0 0 0 USART Control Register 4 UCTRL4 R/W 0 0 0 0 – 0 0 0 ECH USART Floating Point Counter FPCR R/W 0 0 0 0 0 0 0 0 EDH Reserved – EEH I2C Mode Register 1 I2CMR1 0 0 0 0 EFH Reserved – – F0H B Register B R/W 0 0 0 0 0 0 0 0 F1H Flash Mode Register FEMR R/W 0 0 0 0 0 0 0 0 F2H Flash Control Register FECR R/W 0 0 0 0 0 0 1 1 F3H Flash Status Register FESR R/W 1 0 0 0 0 0 0 0 F4H Flash Time Control Register FETCR R/W 0 0 0 0 0 0 0 0 F5H Flash Address Low Register FEARL R/W 0 0 0 0 0 0 0 0 F6H Flash Address Middle Register FEARM R/W 0 0 0 0 0 0 0 0 F7H Flash Address High Register FEARH R/W 0 0 0 0 0 0 0 0 40 0 5 0 SFR Map (Continue) 0 6 0 Table 8.4 R/W 7 – R/W – 0 0 0 0 – – – – R/W – 0 0 0 0 – A94B114 Address ABOV Semiconductor Co., Ltd. Function Symbol R/W @Reset 7 6 5 4 3 2 1 0 F8H I2C Status Register I2CSR R/W 0 0 0 0 0 0 0 0 F9H I2C Mode Register I2CMR R/W 0 0 0 0 0 0 0 0 FAH I2C SCL Low Period Register I2CSCLLR R/W 0 0 1 1 1 1 1 1 FBH I2C SCL High Period Register I2CSCLHR R/W 0 0 1 1 1 1 1 1 FCH I2C SDA Hold Time Register I2CSDAHR R/W 0 0 0 0 0 0 0 1 FDH I2C Data Register FEH I2C Slave Address Register FFH I2C Slave Address 1 Register Table 8.5 I2CDR R/W 1 1 1 1 1 1 1 1 I2CSAR R/W 0 0 0 0 0 0 0 0 I2CSAR1 R/W 0 0 0 0 0 0 0 0 SFR Map (Concluded) 41 A94B114 8.4.3 ABOV Semiconductor Co., Ltd. 8051 Compiler Compatible SFR ACC (Accumulator Register) : E0H 7 6 5 4 3 2 1 0 R/W R/W R/W R/W Initial value : 00H 3 2 1 0 R/W R/W R/W R/W R/W Initial value : 00H 4 3 2 1 0 R/W R/W R/W R/W R/W Initial value : 07H 4 3 2 1 0 R/W R/W R/W R/W Initial value : 00H 3 2 1 0 R/W R/W R/W R/W Initial value : 00H ACC R/W R/W ACC R/W R/W Accumulator B (B Register) : F0H 7 6 5 4 B R/W R/W B R/W B Register SP (Stack Pointer) : 81H 7 6 5 SP R/W R/W SP R/W Stack Pointer DPL (Data Pointer Register Low) : 82H 7 6 5 DPL R/W R/W DPL R/W R/W Data Pointer Low DPH (Data Pointer Register High) : 83H 7 6 5 4 DPH R/W R/W DPH R/W R/W Data Pointer High 42 A94B114 ABOV Semiconductor Co., Ltd. PSW (Program Status Word Register) : D0H 7 6 5 4 3 2 1 CY AC F0 RS1 RS0 OV F1 R/W R/W R/W R/W R/W R/W R/W 0 P R/W Initial value : 00H CY Carry Flag AC Auxiliary Carry Flag F0 General Purpose User-Definable Flag RS1 Register Bank Select bit 1 RS0 Register Bank Select bit 0 OV Overflow Flag F1 User-Definable Flag P Parity Flag. Set/Cleared by hardware each instruction cycle to indicate an odd/even number of ‘1’ bits in the accumulator EO (Extended Operation Register) : A2H 7 6 5 4 3 2 1 0 – – – – – – – DPSEL0 – – – – – – – DPSEL[2:0] Select Banked Data Pointer Register DPSEL0 Description 0 DPTR0 1 DPTR1 Reserved 43 R/W Initial value : 00H A94B114 9 I/O Ports 9.1 I/O Ports ABOV Semiconductor Co., Ltd. The A94B114 has four groups of I/O ports (P0 ~ P2). Each port can be easily configured by software as I/O pin, internal pull up and open-drain pin to meet various system configurations and design requirements. Also P0, P1 and P2 include function that can generate interrupt according to change of state of the pin. 9.2 Port Register 9.2.1 Data Register (Px) Data Register is a bidirectional I/O port. If ports are configured as output ports, data can be written to the corresponding bit of the Px. If ports are configured as input ports, the data can be read from the corresponding bit of the Px. 9.2.2 Direction Register (PxIO) Each I/O pin can be independently used as an input or an output through the PxIO register. Bits cleared in this register will make the corresponding pin of Px to input mode. Set bits of this register will make the pin to output mode. Almost bits are cleared by a system reset, but some bits are set by a system reset. 9.2.3 Pull-up Resistor Selection Register (PxPU) The on-chip pull-up resistor can be connected to I/O ports individually with a pull-up resistor selection register (PxPU). The pull-up register selection controls the pull-up resister enable/disable of each port. When the corresponding bit is 1, the pull-up resister of the pin is enabled. When 0, the pull-up resister is disabled. All bits are cleared by a system reset. 9.2.4 Open-drain Selection Register (PxOD) There are internally open-drain selection registers (PxOD) for P0 ~ P2. The open-drain selection register controls the open-drain enable/disable of each port. Almost ports become push-pull by a system reset, but some ports become opendrain by a system reset. 9.2.5 De-bounce Enable Register (PxDB) P0[6:2], P1[3:0], P2[3:0] support debounce function. Debounce clocks of each ports are fx/4, fx/8, fx/16 and fx/32. 9.2.6 Port Function Selection Register (PxFSR) These registers define alternative functions of ports. Please remember that these registers should be set properly for alternative port function. A reset clears the PxFSR register to ‘00H’, which makes all pins to normal I/O ports. 44 A94B114 9.2.7 ABOV Semiconductor Co., Ltd. De-bounce Time Selection Register (DBTSR) The de-bounce time selection register (DBTSR) select the de-bounce time of all ports and external reset. 9.2.8 Register Map Name Address Direction Default Description P0 80H R/W 00H P0 Data Register P0IO 9BH R/W 00H P0 Direction Register P0PU 9CH R/W 00H P0 Pull-up Resistor Selection Register P0OD 9DH R/W 00H P0 Open-drain Selection Register P0DB 9EH R/W 00H P0 De-bounce Enable Register P0FSRL B3H R/W 00H P0 Function Selection Low Register P0FSRH B4H R/W 00H P0 Function Selection High Register P1 88H R/W 00H P1 Data Register P1IO A3H R/W 00H P1 Direction Register P1PU A4H R/W 00H P1 Pull-up Resistor Selection Register P1OD A5H R/W 00H P1 Open-drain Selection Register P1DB A6H R/W 00H P1 De-bounce Enable Register P1FSRL B5H R/W 00H P1 Function Selection Low Register P1FSRH B6H R/W 00H P1 Function Selection High Register P2 90H R/W 00H P2 Data Register P2IO ABH R/W 00H P2 Direction Register P2PU ACH R/W 00H P2 Pull-up Resistor Selection Register P2OD ADH R/W 00H P2 Open-drain Selection Register P2DB AEH R/W 00H P2 De-bounce Enable Register P2FSR B7H R/W 00H P2 Function Selection Register DBTSR 84H R/W 00H De-bounce Time Selection Register Table 9.1 Port Register Map 45 A94B114 ABOV Semiconductor Co., Ltd. 9.3 P0 Port 9.3.1 P0 Port Description P0 is 8-bit I/O port. P0 control registers consist of P0 data register (P0), P0 direction register (P0IO), debounce enable register (P0DB), P0 pull-up resistor selection register (P0PU), and P0 open-drain selection register (P0OD). Refer to the port function selection registers for the P0 function selection. 9.3.2 Register description for P0 P0 (P0 Data Register) : 80H 7 6 5 4 3 2 1 0 P07 P06 P05 P04 P03 P02 P01 P00 R/W R/W R/W R/W R/W R/W R/W R/W Initial value : 00H P0[7:0] I/O Data P0IO (P0 Direction Register) : 9BH 7 6 5 4 3 2 1 0 P07IO P06IO P05IO P04IO P03IO P02IO P01IO P00IO R/W R/W R/W R/W R/W R/W R/W R/W Initial value : 00H P0IO[7:0] P0 Data I/O Direction. 0 Input 1 Output NOTE) EINT0, EINT2, EINT11 function possible when input P0PU (P0 Pull-up Resistor Selection Register) : 9CH 7 6 5 4 3 2 1 0 P07PU P06PU P05PU P04PU P03PU P02PU P01PU P00PU R/W R/W R/W R/W R/W R/W R/W P0PU[7:0] Configure Pull-up Resistor of P0 Port 0 Disable 1 Enable 46 R/W Initial value : 00H A94B114 ABOV Semiconductor Co., Ltd. P0OD (P0 Open-drain Selection Register) : 9DH 7 6 5 4 3 2 1 0 P07OD P06OD P05OD P04OD P03OD P02OD P01OD P00OD R/W R/W R/W R/W R/W R/W R/W P0OD[7:0] R/W Initial value : 00H Configure Open-drain of P0 Port 0 Push-pull output 1 Open-drain output P0DB (P0 De-bounce Enable Register) : 9EH 7 6 5 4 3 2 1 0 P07DB P06DB P05DB P04DB P03DB P02DB P01DB P00DB R/W R/W R/W R/W R/W R/W R/W P0DB[7:0] R/W Initial value : 00H Configure De-bounce of P0 Port 0 Disable 1 Enable NOTE) 1. 2. 3. 4. If the same level is not detected on enabled pin three or four times in a row at the sampling clock, the signal is eliminated as noise. A pulse level should be input for the duration of 3 clock or more to be actually detected as a valid edge. The port de-bounce is automatically disabled at stop mode and recovered after stop mode release. This can not work unless the system clock is HFO IRC. ( HFO : Internal High Frequency Oscillator ) 47 A94B114 ABOV Semiconductor Co., Ltd. P0FSR_L (Port 0 Function Selection Register Low) : B3H 7 6 5 4 3 2 1 0 P0FSR_L7 P0FSR_L6 P0FSR_L5 P0FSR_L4 P0FSR_L3 P0FSR_L2 P0FSR_L1 P0FSR_L0 R/W R/W R/W R/W R/W R/W R/W P0FSR_L[7:6] P0FSR_L[5:4] P0FSR_L[3:2] P0FSR_L[1:0] R/W Initial value : 00H P03 Function Select P0FSR_L7 P0FSR_L6 Description 0 0 I/O Port (EINT11 function possible when input) 0 1 EINT11 / EC1 1 0 T1O / PWM1O 1 1 AN3 P02 Function Select P0FSR_L5 P0FSR_L4 Description 0 0 I/O Port (EINT0 function possible when input) 0 1 EINT0 1 0 Not used 1 1 AN2 P01 Function Select P0FSR_L3 P0FSR_L2 Description 0 0 I/O Port 0 1 XCK 1 0 Not used 1 1 AN1 P00 Function Select P0FSR_L1 P0FSR_L0 Description 0 0 I/O Port 0 1 SS 1 0 Not used 1 1 AN0 48 A94B114 ABOV Semiconductor Co., Ltd. P0FSR_H (Port 0 Function Selection Register High) : B4H 7 6 5 4 3 2 1 0 P0FSR_H7 P0FSR_H6 P0FSR_H5 P0FSR_H4 P0FSR_H3 P0FSR_H2 P0FSR_H1 P0FSR_H0 R/W R/W R/W R/W R/W R/W R/W P0FSR_H[7:6] P0FSR_H[5:4] P0FSR_H[3:2] P0FSR_H[1:0] R/W Initial value : 00H P07 Function Select P0FSR_H7 P0FSR_H6 Description 0 0 I/O Port 0 1 Not used 1 0 CMO 1 1 AN7 P06 Function Select P0FSR_H5 P0FSR_H4 Description 0 0 I/O Port 0 1 Not used 1 0 CMP 1 1 AN6 P05 Function Select P0FSR_H3 P0FSR_H2 Description 0 0 I/O Port 0 1 Not used 1 0 CMN0 1 1 AN5 P04 Function Select P0FSR_H1 P0FSR_H0 Description 0 0 I/O Port (EINT2 function possible when input) 0 1 EINT2 1 0 PWM1OB/CMN1 1 1 AN4 NOTE) P0SFR_H[1:0] = 10’b Function requires caution. The PWM1OB function is the output, and the CMN1 Function is the input. This feature is not compatible at the same time and should not be used at the same time. Each function can be set using different pins. (PWM1OB P04/P23, CMN P04/P05) 49 A94B114 ABOV Semiconductor Co., Ltd. 9.4 P1 Port 9.4.1 P1 Port Description P1 is 6-bit I/O port. P1 control registers consist of P1 data register (P1), P1 direction register (P1IO), debounce enable register (P12DB), P1 pull-up resistor selection register (P1PU), and P1 open-drain selection register (P1OD) . Refer to the port function selection registers for the P1 function selection. 9.4.2 Register description for P1 P1 (P1 Data Register) : 88H 7 6 5 4 3 2 1 0 – – P15 P14 P13 P12 P11 P10 – – R/W R/W R/W R/W R/W R/W Initial value : 00H P1[5:0] I/O Data P1IO (P1 Direction Register) : A3H 7 6 5 4 3 2 1 0 – – P15IO P14IO P13IO P12IO P11IO P10IO – – R/W R/W R/W R/W R/W R/W Initial value : 00H P1IO[5:0] P1 Data I/O Direction 0 Input 1 Output NOTE) ENINT10/EINT12 function possible when input P1PU (P1 Pull-up Resistor Selection Register) : A4H 7 6 5 4 3 2 1 0 – – P15PU P14PU P13PU P12PU P11PU P10PU – – R/W R/W R/W R/W R/W P1PU[5:0] Configure Pull-up Resistor of P1 Port 0 Disable 1 Enable 50 R/W Initial value : 00H A94B114 ABOV Semiconductor Co., Ltd. P1OD (P1 Open-drain Selection Register) : A5H 7 6 5 4 3 2 1 0 – – P15OD P14OD P13OD P12OD P11OD P10OD – – R/W R/W R/W R/W R/W P1OD[5:0] R/W Initial value : 00H Configure Open-drain of P1 Port 0 Push-pull output 1 Open-drain output P1DB (P1 De-bounce Enable Register) : A6H 7 6 5 4 3 2 1 0 – – P15DB P14DB P13DB P12DB P11DB P10DB – – R/W R/W R/W R/W R/W P1DB[5:0] R/W Initial value : 00H Configure De-bounce of P1 Port 0 Disable 1 Enable NOTE) 1. 2. 3. 4. If the same level is not detected on enabled pin three or four times in a row at the sampling clock, the signal is eliminated as noise. A pulse level should be input for the duration of 3 clock or more to be actually detected as a valid edge. The port de-bounce is automatically disabled at stop mode and recovered after stop mode release. This can not work unless the system clock is HFO IRC. ( HFO : Internal High Frequency Oscillator ) 51 A94B114 ABOV Semiconductor Co., Ltd. P1FSR_L (Port 1 Function Selection Register Low) : B5H 7 6 5 4 3 2 1 0 P1FSR_L7 P1FSR_L6 P1FSR_L5 P1FSR_L4 P1FSR_L3 P1FSR_L2 P1FSR_L1 P1FSR_L0 R/W R/W R/W R/W R/W R/W R/W P1FSR_L[7:6] P1FSR_L[5:4] P1FSR_L[3:2] P1FSR_L[1:0] **NOTE) 1. 2. R/W Initial value : 00H P13 Function Select P1FSR_L7 P1FSR_L6 Description 0 0 I/O Port 0 1 Not used 1 0 Not used 1 1 Not used P12 Function Select P1FSR_L5 P1FSR_L4 Description 0 0 I/O Port (EINT12 function possible when input) 0 1 EINT12 / EC2 1 0 T2O / PWM2O 1 1 Not used P11 Function Select P1FSR_L3 P1FSR_L2 Description 0 0 I/O Port 0 1 Not used 1 0 T1O / PWM1O 1 1 Not used P10 Function Select P1FSR_L1 P1FSR_L0 Description 0 0 I/O Port 0 1 Not used 1 0 T2O / PWM2O 1 1 Not used To use T1O/PWM1O as pin3(P11), set Sub-function and set it to Output High. To use T2O/PWM2O as pin2(P10), set Sub-function and set it to Output Low. 52 A94B114 ABOV Semiconductor Co., Ltd. P1FSR_H (Port 1 Function Selection Register High) : B6H 7 6 5 4 3 2 1 0 – – P1FSR_H5 P1FSR_H4 P1FSR_H3 P1FSR_H2 P1FSR_H1 P1FSR_H0 – – R/W R/W R/W R/W R/W P1FSR_H[5:4] P1FSR_H[3:2] P1FSR_H[1:0] R/W Initial value : 00H I2C Port Select P1FSR_H5 P1FSR_H4 Description 0 0 Not used 0 1 Use P20, P21 for I2C 1 0 Use P14, P15 for I2C 1 1 Not used P15 Function Select P1FSR_H3 P1FSR_H2 Description 0 0 I/O Port 0 1 TXD 1 0 Not used 1 1 Not used P14 Function Select P1FSR_H1 P1FSR_H0 Description 0 0 I/O Port (EINT10 function possible when input) 0 1 RXD 1 0 Not used 1 1 EINT10 / EC0 53 A94B114 ABOV Semiconductor Co., Ltd. 9.5 P2 Port 9.5.1 P2 Port Description P2 is 4-bit I/O port. P2 control registers consist of P2 data register (P2), P2 direction register (P2IO), P2 pull-up resistor selection register (P2PU) and P2 open-drain selection register (P2OD). Refer to the port function selection registers for the P2 function selection. 9.5.2 Register description for P2 P2 (P2 Data Register) : 90H 7 6 5 4 3 2 1 0 – – – – P23 P22 P21 P20 – – – – R/W R/W R/W R/W Initial value : 00H P2[3:0] I/O Data P2IO (P2 Direction Register) : ABH 7 6 5 4 3 2 1 0 – – – – P23IO P22IO P21IO P20IO – – – – R/W R/W R/W R/W Initial value : 00H P2IO[3:0] P2 Data I/O Direction 0 Input 1 Output P2PU (P2 Pull-up Resistor Selection Register) : ACH 7 6 5 4 3 2 1 0 – – – – P23PU P22PU P21PU P20PU – – – – R/W R/W R/W R/W Initial value : 00H P2PU[3:0] Configure Pull-up Resistor of P2 Port 0 Disable 1 Enable P2OD (P2 Open-drain Selection Register) : ADH 7 6 5 4 3 2 1 0 – – – – P23OD P22OD P21OD P20OD – – – – R/W R/W R/W P2OD[3:0] Configure Open-drain of P2 Port 0 Push-pull output 1 Open-drain output 54 R/W Initial value : 00H A94B114 ABOV Semiconductor Co., Ltd. P2DB (P2 De-bounce Enable Register) : AEH 7 6 5 4 3 2 1 0 – – – – P23DB P22DB P21DB P20DB – – – – R/W R/W R/W P2DB R/W Initial value : 00H Configure De-bounce of P2 Port 0 Disable 1 Enable NOTE) 1. 2. 3. 4. If the same level is not detected on enabled pin three or four times in a row at the sampling clock, the signal is eliminated as noise. A pulse level should be input for the duration of 3 clock or more to be actually detected as a valid edge. The port de-bounce is automatically disabled at stop mode and recovered after stop mode release. This can not work unless the system clock is HFO IRC. ( HFO : Internal High Frequency Oscillator ) P2FSR (Port 2 Function Selection Register) : B7H 7 6 5 4 3 2 1 0 P2FSR7 P2FSR6 P2FSR5 P2FSR4 P2FSR3 P2FSR2 P2FSR1 P2FSR0 R/W R/W R/W R/W R/W R/W R/W P2FSR[7:6] P2FSR[5:4] P2FSR[3:2] P2FSR[1:0] R/W Initial value : 00H P23 Function Select P2FSR7 P2FSR6 Description 0 0 I/O Port (EINT10 function possible when input) 0 1 EINT10 / EC0 1 0 T0O / PWM1OB 1 1 AN9 P22 Function Select P2FSR5 P2FSR4 Description 0 0 I/O Port (EINT1 function possible when input) 0 1 EINT1 1 0 Not used 1 1 AN8 P21 Function Select P2FSR3 P2FSR2 Description 0 0 I/O Port 0 1 Not used 1 0 Not used 1 1 Not used P20 Function Select P2FSR1 P2FSR0 Description 0 0 I/O Port 0 1 Not used 1 0 Not used 1 1 Not used 55 A94B114 ABOV Semiconductor Co., Ltd. 10 Interrupt Controller 10.1 Overview The A94B114 supports up to 16 interrupt sources. The interrupts have separate enable register bits associated with them, allowing software control. They can also have two levels of priority assigned to them. The non-maskable interrupt source is always enabled with a higher priority than any other interrupt source, and is not controllable by software. The interrupt controller has following features: − Receive the request from 16 interrupt source − 2 priority levels − Multi Interrupt possibility − 4 interrrupt nesting levels − If the requests of different priority levels are received simultaneously, the request of higher priority level is served first. − Each interrupt source can be controlled by EA bit and each IEx bit − Interrupt latency: 3~9 machine cycles in single interrupt system The non-maskable interrupt is always enabled. The maskable interrupts are enabled through two pair of interrupt enable registers (IE, IE1, IE2). Each bit of IE, IE1, IE2 register individually enables/disables the corresponding interrupt source. Overall control is provided by bit 7 of IE (EA). When EA is set to ‘0’, all interrupts are disabled: when EA is set to ‘1’, interrupts are individually enabled or disabled through the other bits of the interrupt enable registers. The EA bit is always cleared to ‘0’ jumping to an interrupt service vector and set to ‘1’ executing the [RETI] instruction. The A94B114 supports a two-level priority scheme. Each maskable interrupt is individually assigned to one of four priority levels according to IP, IP1 and IP2. Figure 10.1 shows th the Interrupt Priority Level. Priority can be sets by writing to a bit of IP0, IP1 and IP2 regisgter. Each bit of IP0, IP1 and IP2 corresponds to each interrupt and desiges one of 2 priority levels of each interrupt. High level interrupt always has higher priority than low level interrupt. ( IP ) IPx 0 0 0 1 0 0 1 0 0 0 0 1 0 0 0 IP0.0 IP0.1 IP0.2 IP0.3 IP0.4 IP1.0 IP1.1 IP1.2 IP1.3 IP1.4 IP1.5 IP1.6 IP2.0 IP2.1 IP2.2 IP2.3 Priority level 1 Priority level 0 INT7 INT4 INT0 INT1 INT2 INT3 INT5 INT6 high Figure 10.1 ( IP2 ) ( IP1 ) 0 high INT12 INT8 INT9 INT10 INT11 INT13 INT14 INT15 low low Interrupt Priority Level This device support only 4 level interrupt nesting. Interrupt nesting level register (ILVL) has the current nesting level. If current nesting level is 4 and other interrupt having higher priority occur, it might cause a malfunction. 56 A94B114 10.2 ABOV Semiconductor Co., Ltd. External Interrupt The external interrupt on INT0, INT1, INT2, INT10, INT11 and INT12 pins receive various interrupt request depending on the external interrupt polarity 0 register (EIPOL0) and external interrupt polarity 1 register (EIPOL1) as shown in Figure 10.2. Also each external interrupt source has enable/disable bits. The external interrupt flag register (EIFLAG) and provides the status of external interrupts. EIPOL0 2 EINT10 Pin INT0 Interrupt 2 EINT11 Pin INT1 Interrupt 2 EINT12 Pin INT2 Interrupt EIPOL1 2 S/W Decisions EINT0 Pin EIFLAG0 2 EINT1 Pin INT4 Interrupt EIFLAG1 2 EIFLAG2 EINT2 Pin Figure 10.2 External Interrupt Description NOTE) EINT0~EINT2 can be ignored if interrupts are requested at the same time. If an interrupt request is requested and another interrupt is requested immediately before clearing (sysclk1-2), the later requested interrupt is ignored. 57 A94B114 10.3 ABOV Semiconductor Co., Ltd. Block Diagram IE Comparator IRQ0.0 IP EIPOL0 0 EI FLAG1.4 EINT10 IRQ0.1 1 EIFLAG1.5 EINT11 IRQ0.2 EINT12 IRQ0.3 IP1 2 EIFLAG1.6 3 EIPOL1 4 EINT0 EIFLAG.0 EINT1 EIFLAG.1 EINT2 EIFLAG.2 IRQ0.4 IP2 0 Priority High 1 2 3 4 IE1 I2C 5 USART RX 6 USART TX IRQ1.2 CRC IRQ1.3 Timer 0 IRQ1.4 Timer 1 IRQ1.5 Timer 2 IRQ1.6 7 8 9 10 11 5 6 Level 0 Level 1 Release Stop/Sleep 7 8 9 EA 10 11 IE2 ADC IRQ2.0 WDT IRQ2.1 BIT IRQ2.2 LVI IRQ2.3 12 13 14 15 Figure 10.3 12 13 14 Priority Low 15 Block Diagram of Interrupt NOTE) 1. 2. The release signal for stop/idle mode may be generated by all interrupt sources which are enabled without reference to the priority level. An interrupt request is delayed while data are written to IE, IE1, IE2, IP, IP1, IP2 and PCON register. 58 A94B114 10.4 ABOV Semiconductor Co., Ltd. Interrupt Vector Table The interrupt controller supports 16 interrupt sources as shown in the Table 10-1. When interrupt is served, long call instruction (LCALL) is executed and program counter jumps to the vector address. All interrupt requests have their own priority order. Interrupt Source Symbol Interrupt Enable Bit Polarity Mask Vector Address Hardware Reset RESETB - 0 Non-Maskable 0000H Comparator Interrupt INT0 IE.0 1 Maskable 0003H External Interrupt 10 INT1 IE.1 2 Maskable 000BH External Interrupt 11 INT2 IE.2 3 Maskable 0013H External Interrupt 12 INT3 IE.3 4 Maskable 001BH External Interrupt 0/1/2 INT4 IE.4 5 Maskable 0023H I2C Interrupt INT5 IE1.0 6 Maskable 002BH USART Rx Interrupt INT6 IE1.1 7 Maskable 0033H USART Tx Interrupt INT7 IE1.2 8 Maskable 003BH CRC Interrupt INT8 IE1.3 9 Maskable 0043H T0 Match Interrupt INT9 IE1.4 10 Maskable 004BH T1 Match Interrupt INT10 IE1.5 11 Maskable 0053H T2 Match Interrupt INT11 IE1.6 12 Maskable 005BH ADC Interrupt INT12 IE2.0 13 Maskable 0063H WDT Interrupt INT13 IE2.1 14 Maskable 006BH BIT Interrupt INT14 IE2.2 15 Maskable 0073H LVI Interrupt INT15 IE2.3 16 Maskable 007BH Table 10.1 Interrupt Vector Address Table For maskable interrupt execution, EA bit must set ‘1’ and specific interrupt must be enabled by writing ‘1’ to associated bit in the IEx. If an interrupt request is received, the specific interrupt request flag is set to ‘1’. And it remains ‘1’ until CPU accepts interrupt. If the interrupt is served, the interrupt request flag will be cleared automatically. 59 A94B114 10.5 ABOV Semiconductor Co., Ltd. Interrupt Sequence An interrupt request is held until the interrupt is accepted or the interrupt latch is cleared to ‘0’ by a reset or an instruction. Interrupt acceptance always generates at last cycle of the instruction. So instead of fetching the current instruction, CPU executes internally LCALL instruction and saves the PC at stack. For the interrupt service routine, the interrupt controller gives the address of LJMP instruction to CPU. Since the end of the execution of current instruction, it needs 3~9 machine cycles to go to the interrupt service routine. The interrupt service task is terminated by the interrupt return instruction [RETI]. Once an interrupt request is generated, the following process is performed. IE.EA Flag 0 1 2 Program Counter low Byte SP  SP + 1, M(SP)  (PCL) Saves PC value in order to continue 3 4 5 6 7 8 SP  SP + 1, M(SP)  (PCH) Interrupt Vector Address occurrence (Interrupt Vector Address) ISR(Interrupt Service Routine) move, execute Return from ISR RETI Program Counter high Byte recovery (PCH)  M(SP), SP  SP - 1 Program Counter low Byte recovery (PCL)  M(SP), SP  SP - 1 IE.EA Flag 1 9 10 Figure 10.4 process again after executing ISR Program Counter high Byte Main Program execution Interrupt Sequence Flow 60 A94B114 10.6 ABOV Semiconductor Co., Ltd. Effective Timing after Controlling Interrupt Bit Interrupt Enable Register command Next Instruction Setting both EA bit and individual interrupt enable bit IEx makes the pending interrupt active after executing the next instruction. Next Instruction Figure 10.5 10.7 Effective Timing of Interrupt Enable Register Multi Interrupt If two requests of different priority levels are received simultaneously, the request of higher priority level is served first. If more than one interrupt request are received, the interrupt polling sequence determines which request is served first by hardware. However, for special features, multi-interrupt processing can be executed by software. INT1 ISR Main Program Service INT0 ISR SETB EA Occur Occur INT1 Interrupt INT0 Interrupt Example) Software Multi Interrupt: INT1 : MOV SETB ... RETI Figure 10.6 IE, #03H EA RETI RETI ; Enable INT0 only ; Enable global interrupt (necessary for multi interrupt) Effective Timing of Multi-Interrupt Figure 10.6 shows an example of multi-interrupt processing. While INT1 is served, INT0 which has higher priority than INT1 is occurred. Then INT0 is served immediately and then the remain part of INT1 service routine is executed. If the priority level of INT0 is same or lower than INT1, INT0 will be served after the INT1 service has completed. An interrupt service routine may be only interrupted by an interrupt of higher priority and, if two interrupts of different priority occur at the same time, the higher level interrupt will be served first. An interrupt cannot be interrupted by another interrupt of the same or a lower priority level. If two interrupts of the same priority level occur simultaneously, the service order for those interrupts is determined by the scan order. 61 A94B114 10.8 ABOV Semiconductor Co., Ltd. Interrupt Enable Accept Timing Max. 4 Machine Cycle 4 Machine Cycle System Clock Interrupt goes Active Interrupt Interrupt Processing Latched : LCALL & LJMP Figure 10.7 10.9 Interrupt Routine Interrupt Response Timing Diagram Interrupt Service Routine Address Figure 10.8 Basic Interval Timer Basic Interval Timer Vector Table Address Service Routine Address 0073H 02H 0125H 0EH 0074H 01H 0126H 2EH 0075H 25H Correspondence between Vector Table Address and the Entry Address of ISR 10.10 Saving/Restore General-Purpose Registers INTxx : PUSH PUSH PUSH PUSH PUSH ∙ ∙ PSW DPL DPH B ACC Main Task Service Task Saving Register Interrupt_Processing: ∙ ∙ POP ACC POP B POP DPH POP DPL POP PSW RETI Figure 10.9 Interrupt Restoring Register Saving/Restore Process Diagram and Sample Source 62 A94B114 ABOV Semiconductor Co., Ltd. 10.11 Interrupt Timing Interrupt sampled here CLP2 CLP1 CLP2 C1P1 C1P2 C2P1 C2P2 SCLK INT_SRC INTR_ACK LAST_CYC INTR_LCALL INT_VEC 8-Bit interrupt Vector PROGA Figure 10.10 {8’h00, INT_VEC} Timing Chart of Interrupt Acceptance and Interrupt Return Instruction Interrupt sources are sampled at the last cycle of a command. When sampling interrupt source, it is decieded to low 8bit of interrupt vector. CM8051-S core makes interrupt acknowleadge at first cycle of command, executes long call to jump interrupt routine as INT_VEC. NOTE) command cycle CLPx: L=Last cycle, 1=1st cycle or 1st phase, 2=2nd cycle or 2nd phase 63 A94B114 ABOV Semiconductor Co., Ltd. 10.12 Interrupt Register Overview 10.12.1 Interrupt Enable Register (IE, IE1, IE2) Interrupt enable register consists of global interrupt control bit (EA) and peripheral interrupt control bits. Total 16 peripherals are able to control interrupt. 10.12.2 Interrupt Priority Register (IP, IP1, IP2) The 15 interrupts can decide 2 levels interrupt priority using interrupt priority register. Level 1 is the high priority, while level 0 is the lowest priority. After a reset IP, IP1 and IP2 are cleared to ‘00H’. At that initialization, low interrupt number has a higher priority than high interrupt number. If decided the priority, low interrupt number has a higher priority than high interrupt number in the same level. 10.12.3 Interrupt Request Register (IRQ0, IRQ1, IRQ2) Interrupt requeset register is set by ‘Peripherals’(H/W) when some event is occurred. The interrupt function is called when both interrupt enable and request bits are set. NOTE) In polling mode using IRQ, if there is another interrupt request after reading the IRQ and before writing it, the second requested IRQ may be cleared. 10.12.4 Interrupt Offset Register (IOFFSET) Interrupt Offset changing is possible using IOFFSET register. 10.12.5 Interrupt Nesting level Register (ILVL) Interrupt nesting level register has current interupt nesting level. 10.12.6 External Interrupt Flag Register (EIFLAG) The external interrupt flag register (EIFLAG) is set to ‘1’ when the external interrupt0, 1 and 2 generating condition is satisfied. The external interrupt 0, 1, 2 share the same interrupt vector address and can check the interrupt source through the EIFLAG register. The flag can be cleared by writing ‘0’ to it. 10.12.7 External Interrupt Polarity Register (EIPOL0, EIPOL1) The external interrupt polarity 0 high/low register (EIPOL0), external interrupt polarity 1 register (EIPOL1) determines which type of rising/falling/both edge interrupt. Initially, default value is no interrupt at any edge. 64 A94B114 ABOV Semiconductor Co., Ltd. 10.12.8 Register Map Name Address Direction Default Description IE B8H R/W 00H Interrupt Enable Register IE1 C0H R/W 00H Interrupt Enable Register 1 IE2 C8H R/W 00H Interrupt Enable Register 2 IP E8H R/W 00H Interrupt Priority Register IP1 E9H R/W 00H Interrupt Priority Register 1 IP2 EAH R/W 00H Interrupt Priority Register 2 IRQ A0H R/W 00H Interrupt Request Register IRQ1 A8H R/W 00H Interrupt Request Register 1 IRQ2 B0H R/W 00H Interrupt Request Register 2 IOFFSET 8AH R/W 00H Interrupt Offset Register ILVL 9AH R/W 00H Interrupt Level Register EIFLAG C9H R/W 00H External Interrupt Flag Register EIPOL0 8BH R/W 00H External Interrupt Polarity 0 Register EIPOL1 8CH R/W 00H External Interrupt Polarity 1 Register Table 10.2 Interrupt Register Map 65 A94B114 ABOV Semiconductor Co., Ltd. 10.12.9 Interrupt Register Description The interrupt register is used for controlling interrupt functions. Also it has external interrupt control registers. The interrupt register consists of interrupt enable register (IE), interrupt enable register 1 (IE1) and interrupt enable register 2 (IE2). For external interrupt, it consists external interrupt polarity 0 register (EIPOL0) and external interrupt polarity 1 register (EIPOL1) . IE (Interrupt Enable Register) : B8H 7 6 5 4 3 2 1 0 EA – – INT4E INT3E INT2E INT1E INT0E R/W – – R/W R/W R/W R/W EA INT4E INT3E INT2E INT1E INT0E Enable or Disable All Interrupt bits 0 All Interrupt disable 1 All Interrupt enable Enable or Disable External Interrupt 0/1/2 (EINT0/EINT1/EINT2) 0 Disable 1 Enable Enable or Disable External Interrupt 12 (EINT12) 0 Disable 1 Enable Enable or Disable External Interrupt 11(EINT11) 0 Disable 1 Enable Enable or Disable External Interrupt 10(EINT10) 0 Disable 1 Enable Enable or Disable Comparator Interrupt 0 Disable 1 Enable 66 R/W Initial value : 00H A94B114 ABOV Semiconductor Co., Ltd. IE1 (Interrupt Enable Register 1): C0H 7 6 5 4 3 2 1 0 – INT11E INT10E INT9E INT8E INT7E INT6E INT5E – R/W R/W R/W R/W R/W R/W R/W Initial value: 00H INT11E INT10E INT9E INT8E INT7E INT6E INT5E Enable or Disable Timer2 Interrupt 0 Disable 1 Enable Enable or Disable Timer1 Interrupt 0 Disable 1 Enable Enable or Disable Timer 0 Interrupt 0 Disable 1 Enable Enable or Disable CRC Interrupt 0 Disable 1 Enable Enable or Disable USART Tx Interrupt 0 Disable 1 Enable Enable or Disable USART Rx Interrupt 0 Disable 1 Enable Enable or Disable I2C Interrupt 0 Disable 1 Enable IE2 (Interrupt Enable Register 2) : C8H 7 6 5 4 3 2 1 0 –- – – – INT15E INT14E INT13E INT12E – – – – R/W R/W R/W INT15E INT14E INT13E INT12E Enable or Disable LVI Interrupt 0 Disable 1 Enable Enable or Disable BIT Interrupt 0 Disable 1 Enable Enable or Disable WDT Interrupt 0 Disable 1 Enable Enable or Disable ADC Interrupt 0 Disable 1 Enable 67 R/W Initial value : 00H A94B114 ABOV Semiconductor Co., Ltd. IP (Interrupt Priority Register) : E8H 7 6 5 – – – IP4 IP3 IP2 IP1 – – – R/W R/W R/W R/W IP4 IP3 IP2 IP1 IP0 4 3 Select EINT0/1/2 Interrupt Priority 0 Level 0 1 Level 1 Select EINT12 Interrupt Priority 0 Level 0 1 Level 1 Select EINT11 Interrupt Priority 0 Level 0 1 Level 1 Select EINT10 Interrupt Priority 0 Level 0 1 Level 1 Select Comparator Interrupt Priority 0 Level 0 1 Level 1 68 2 1 0 IP0 R/W Initial value : 00H A94B114 ABOV Semiconductor Co., Ltd. IP1 (Interrupt Priority Register 1) : E9H 7 6 5 4 3 2 1 0 – IP16 IP15 IP14 IP13 IP12 IP11 IP10 – R/W R/W R/W R/W R/W R/W R/W Initial value : 00H IP16 IP15 IP14 IP13 IP12 IP11 IP10 Select Timer2 Interrupt Priority 0 Level 0 1 Level 1 Select Timer1 Interrupt Priority 0 Level 0 1 Level 1 Select Timer0 Interrupt Priority 0 Level 0 1 Level 1 Select CRC Interrupt Priority 0 Level 0 1 Level 1 Select USART Tx Interrupt Priority 0 Level 0 1 Level 1 Select USART Rx Interrupt Priority 0 Level 0 1 Level 1 Select I2C Interrupt Priority 0 Level 0 1 Level 1 IP2 (Interrupt Priority Register 2) : EAH 7 6 5 4 3 2 1 0 – – – – IP23 IP22 IP21 IP20 – – – – R/W R/W R/W IP23 IP22 IP21 IP20 Select LVI Interrupt Priority 0 Level 0 1 Level 1 Select BIT Interrupt Priority 0 Level 0 1 Level 1 Select WDT Interrupt Priority 0 Level 0 1 Level 1 Select ADC Interrupt Priority 0 Level 0 1 Level 1 69 R/W Initial value : 00H A94B114 ABOV Semiconductor Co., Ltd. IRQ (Interrupt Request Register) : A0H 7 6 5 4 3 2 1 0 – – – IRQ4 IRQ3 IRQ2 IRQ1 IRQ0 – – – R/W R/W R/W R/W IRQ4 IRQ3 IRQ2 IRQ1 IRQ0 If EINT0/1/2 interrupt occurs, the flag is set ‘1’ Flag is cleared when ISR occurs or by writing ‘0’ to bit. 0 EINT0/1/2 Interrupt doesn’t occur 1 EINT0/1/2 Interrupt occur If EINT12 interrupt occurs, the flag is set ‘1’ Flag is cleared when ISR occurs or by writing ‘0’ to bit. 0 EINT12 Interrupt doesn’t occur 1 EINT12 Interrupt occur If EINT11 interrupt occurs, the flag is set ‘1’ Flag is cleared when ISR occurs or by writing ‘0’ to bit. 0 EINT11 Interrupt doesn’t occur 1 EINT11 Interrupt occur If EINT10 interrupt occurs, the flag is set ‘1’ Flag is cleared when ISR occurs or by writing ‘0’ to bit. 0 EINT10 Interrupt doesn’t occur 1 EINT10 Interrupt occur If Comparator interrupt occurs, the flag is set ‘1’ Flag is cleared when ISR occurs or by writing ‘0’ to bit. 0 Comparator Interrupt doesn’t occur 1 Comparator Interrupt occur 70 R/W Initial value : 00H A94B114 ABOV Semiconductor Co., Ltd. IRQ1 (Interrupt Request Register 1) : A8H 7 6 5 4 3 2 1 0 – IRQ16 IRQ15 IRQ14 IRQ13 IRQ12 IRQ11 IRQ10 – R/W R/W R/W R/W R/W R/W IRQ16 IRQ15 IRQ14 IRQ13 IRQ12 IRQ11 IRQ10 If Timer2 interrupt occurs, the flag is set ‘1’ Flag is cleared when ISR occurs or by writing ‘0’ to bit. 0 Timer2 Interrupt doesn’t occur 1 Timer2 Interrupt occur If Timer1 interrupt occurs, the flag is set ‘1’ Flag is cleared when ISR occurs or by writing ‘0’ to bit. 0 Timer1 Interrupt doesn’t occur 1 Timer1 Interrupt occur If Timer0 interrupt occurs, the flag is set ‘1’ Flag is cleared when ISR occurs or by writing ‘0’ to bit. 0 Timer0 Interrupt doesn’t occur 1 Timer0 Interrupt occur If CRC interrupt occurs, the flag is set ‘1’ Flag is cleared when ISR occurs or by writing ‘0’ to bit. 0 CRC Interrupt doesn’t occur 1 CRC Interrupt occur If USART Tx interrupt occurs, the flag is set ‘1’ Flag is cleared when ISR occurs or by writing ‘0’ to bit. 0 USART Tx Interrupt doesn’t occur 1 USART Tx Interrupt occur If USART Rx interrupt occurs, the flag is set ‘1’ Flag is cleared when ISR occurs or by writing ‘0’ to bit. 0 USART Rx Interrupt doesn’t occur 1 USART Rx Interrupt occur If I2C interrupt occurs, the flag is set ‘1’ Flag is cleared when ISR occurs or by writing ‘0’ to bit. 0 I2C Interrupt doesn’t occur 1 I2C Interrupt occur 71 R/W Initial value : 00H A94B114 ABOV Semiconductor Co., Ltd. IRQ2 (Interrupt Request Register 2) : B0H 7 6 5 4 3 2 1 0 – – – – IRQ23 IRQ22 IRQ21 IRQ20 – – – – R/W R/W R/W IRQ23 IRQ22 IRQ21 IRQ20 If LVI interrupt occurs, the flag is set ‘1’ Flag is cleared when ISR occurs or by writing ‘0’ to bit. 0 LVI Interrupt doesn’t occur 1 LVI Interrupt occur If BIT interrupt occurs, the flag is set ‘1’ Flag is cleared when ISR occurs or by writing ‘0’ to bit. 0 BIT Interrupt doesn’t occur 1 BIT Interrupt occur If WDT interrupt occurs, the flag is set ‘1’ Flag is cleared when ISR occurs or by writing ‘0’ to bit. 0 WDT Interrupt doesn’t occur 1 WDT Interrupt occur If ADC interrupt occurs, the flag is set ‘1’ Flag is cleared when ISR occurs or by writing ‘0’ to bit. 0 ADC Interrupt doesn’t occur 1 ADC Interrupt occur 72 R/W Initial value : 00H A94B114 ABOV Semiconductor Co., Ltd. IOFFSET (Interrupt Offset Register) : 8AH 7 6 5 4 3 2 1 0 IOFFSET7 IOFFSET6 IOFFSET5 IOFFSET4 IOFFSET3 IOFFSET2 IOFFSET1 IOFFSET0 R/W R/W R/W R/W R/W R/W R/W IOFFSET[7:0] R/W Initial value : 00H Interrupt Offset Value Interrupt Vector Address = 256*INT_OFFSET Interrupt offset changing is possible when only the SYSCON_AR value is 5AH. So. User must set it with 5Ah before changing interrupt offset value and make sure set it with 00h after changing interrupt offset. ILVL (Interrupt Level Register) : 9AH 7 6 5 4 3 2 1 0 – – – – – ILVL2 ILVL1 ILVL0 – – – – – R R ILVL[7:0] R Initial value : 00H Interrupt Level Value Interrupt level is saved when using multi-interrupt. It has a value of 4level from 0H to 4H. EIFLAG (External Interrupt Flag Register) : C9H 7 6 5 4 3 2 1 0 – – – – – EIFLAG2 EIFLAG1 EIFLAG0 – – – – – R/W R/W EIFLAG2 EIFLAG1 EIFLAG0 R/W Initial value : 00H When an External Interrupt 2 is occurred, the flag becomes ‘1’. The flag is clear only by writing ‘0’ to the bit. The flag should clear by software. Writing “1” has no effect. 0 External Interrupt 2 not occurred 1 External Interrupt 2 occurred When an External Interrupt 1 is occurred, the flag becomes ‘1’. The flag is clear only by writing ‘0’ to the bit. The flag should clear by software. Writing “1” has no effect. 0 External Interrupt 1 not occurred 1 External Interrupt 1 occurred When an External Interrupt 0 is occurred, the flag becomes ‘1’. The flag is clear only by writing ‘0’ to the bit. The flag should clear by software. Writing “1” has no effect. 0 External Interrupt 0 not occurred 1 External Interrupt 0 occurred NOTE) EINT0~EINT2 can be ignored if interrupts are requested at the same time. If an interrupt request is requested and another interrupt is requested immediately before clearing (sysclk1-2), the later requested interrupt is ignored. 73 A94B114 ABOV Semiconductor Co., Ltd. EIPOL0 (External Interrupt Polarity High Register): 8BH 7 6 5 4 3 2 1 0 – – EIPOL05 EIPOL04 EIPOL03 EIPOL02 EIPOL01 EIPOL00 – – R/W R/W R/W R/W R/W R/W Initial value: 00H EIPOL0[5:4] EIPOL0[3:2] EIPOL0[1:0] External interrupt (EINT12) polarity selection EIPOL0[5:4] Description 0 0 No interrupt at any edge 0 1 Interrupt on rising edge 1 0 Interrupt on falling edge 1 1 Interrupt on both of rising and falling edge External interrupt (EINT11) polarity selection EIPOL0[3:2] Description 0 0 No interrupt at any edge 0 1 Interrupt on rising edge 1 0 Interrupt on falling edge 1 1 Interrupt on both of rising and falling edge External interrupt (EINT10) polarity selection EIPOL0[1:2] Description 0 0 No interrupt at any edge 0 1 Interrupt on rising edge 1 0 Interrupt on falling edge 1 1 Interrupt on both of rising and falling edge EIPOL1 (External Interrupt Polarity Register 1): 8CH 7 6 5 4 3 2 1 0 – – EIPOL15 EIPOL14 EIPOL13 EIPOL12 EIPOL11 EIPOL10 – – R/W R/W R/W R/W R/W R/W Initial value: 00H EIPOL1[5:4] EIPOL1[3:2] EIPOL1[1:0] External interrupt (EINT2) polarity selection EIPOL1[5:4] Description 0 0 No interrupt at any edge 0 1 Interrupt on rising edge 1 0 Interrupt on falling edge 1 1 Interrupt on both of rising and falling edge External interrupt (EINT1) polarity selection EIPOL1[3:2] Description 0 0 No interrupt at any edge 0 1 Interrupt on rising edge 1 0 Interrupt on falling edge 1 1 Interrupt on both of rising and falling edge External interrupt (EINT0) polarity selection EIPOL1[1:2] Description 0 0 No interrupt at any edge 0 1 Interrupt on rising edge 1 0 Interrupt on falling edge 1 1 Interrupt on both of rising and falling edge 74 A94B114 ABOV Semiconductor Co., Ltd. 11 Peripheral Hardware 11.1 Clock Generator 11.1.1 Overview As shown in Figure 11.1, the clock generator produces the basic clock pulses which provide the system clock to be supplied to the CPU and the peripheral hardware. It contains main-frequency clock oscillator. The main clock operation can be easily obtained by attaching a crystal between the XIN and XOUT pin, respectively. The main clock can be also obtained from the external oscillator. In this case, it is necessary to put the external clock signal into the XIN pin and open the XOUT pin. The default system clock is 32MHz INT-RC Oscillator and the default division rate is two. In order to stabilize system internally, it is used 32MHz INT-RC oscillator on POR. − Calibrated Internal RC Oscillator (HFO) : 32MHz • INT-RC OSC/2 (16 MHz, Default system clock) • INT-RC OSC/2 (8 MHz) • INT-RC OSC/4 (4 MHz) • INT-RC OSC/16 (1 MHz) − Main Crystal Oscillator (0.4~16 MHz) − Internal Ring Oscillator (LFO) : 256 kHz 11.1.2 Block Diagram XIN XOUT fXIN Main OSC STOP Mode XCLKEN TIMER1 TIMER2 SCLK (fx) (Core, System, Peripheral) HFOS[2:0] 3 Internal RC OSC (32MHz) DIV 1/2 1/4 1/8 MUX BITCK[1:0] 2 fHFO MUX 1/16 BCK[2:0] 3 1/16 BIT 1/128 clock DIV 1/1024 MUX BIT 1/4096 STOP Mode HFOEN LFOS[2:0] 3 Internal Ring OSC (256kHz) STOP Mode LFOSTEN DIV 1/2 1/4 1/8 MUX fLFO MUX 1/16 WDT clock 2 SCLK_SEL[1:0] LFOEN 2 WDT_CLK_SEL[1:0] Figure 11.1 Clock Generator Block Diagram 75 WDT BIT overflow A94B114 ABOV Semiconductor Co., Ltd. 11.1.3 Register Map Name Address Direction Default Description SCCR D9H R/W 40H System and Clock Control Register OSCCR D8H R/W 04H Oscillator Control Register SYSCON_AR 8FH R/W 00H System control access authorization register. Table 11.1 Clock Generator Register Map 11.1.4 Clock Generator Register Description The clock generator register uses clock control for system operation. The clock generation consists of System and clock control register and oscillator control register. 11.1.5 Register Description for Clock Generator SCCR (System and Clock Control Register) : D9H 7 6 5 4 3 2 1 0 – FWKTIME2 FWKTIME1 FWKTIME0 – LFOSTEN SCLK1 SCLK0 – R/W R/W R/W – R/W R/W FWKTIME[2:0] Select stop release time for fast wakeup (fx=16MHz) Release time varies depending on the system clock. FWKTIEM[2:0] LFOSTEN SCLK [1:0] Description 0 0 0 128us 0 0 1 256us 0 1 0 512us 0 1 1 4ms 1 0 0 8ms (Default) 1 0 1 16ms 1 1 0 32ms 1 1 1 64ms Internal Ring OSC (LFO) enable at STOP mode. 0 Disable at STOP mode. 1 Enable at STOP mode. System Clock Selection Bit SCLK1 SCLK0 Description 0 0 INT RC OSC (fHFO) for system clock 0 1 External Main OSC (fXIN) for system clock 1 0 INT Ring OSC (fLFO) for system clock 1 1 Not used 76 R/W Initial value : 40H A94B114 ABOV Semiconductor Co., Ltd. OSCCR (Oscillator Control Register) : D8H 7 6 5 4 3 2 1 0 LFOS1 LFOS0 HFOS1 HFOS0 – HFOEN XCLKEN LFOEN R/W R/W R/W R/W – R/W R/W LFOS[1:0] R/W Initial value : 04H Internal Ring OSC (LFO) Post-divider Selection LFOS1 LFOS0 Description HFOS[1:0] 0 0 fLFO / 2 (128kHz - Default) 0 1 fLFO / 4 (64kHz) 1 0 fLFO / 8 (32kHz) 1 1 fLFO / 16 (16kHz) Internal RC OSC (HFO) Post-divider Selection HFOS1 HFOS0 Description HFOEN XCLKE LFOEN 0 0 fHFO / 2 (16MHz - Default) 0 1 fHFO / 4 (8MHz) 1 0 fHFO / 8 (4MHz) 1 1 fHFO / 16 (1MHz) Control the Operation of the Internal RC Oscillator (HFO) 0 Disable operation of INT-RC OSC 1 Enable operation of INT-RC OSC Control the Operation of the External Main Oscillator 0 Disable operation of Crystal 1 Enable operation of Crystal Control the Operation of the Internal Ring Oscillator (LFO) 0 Disable operation of INT-Ring OSC 1 Enable operation of INT-Rring OSC SYSCON_AR (System control access authorization register) : 8FH 7 6 5 4 3 2 1 0 BIT7 BIT6 BIT5 BIT4 BIT3 BIT2 BIT1 BIT0 R/W R/W R/W R/W R/W R/W R/W R/W Initial value : 00H The following registers can be written only when authorized. The registers are SCCR, OSCCR, IOFFSET. These register changing are possible when only SYSCON_AR value is 5AH. So, User must set it with 5AH before changing value and make sure set it with 00h after changing value. 77 A94B114 11.2 ABOV Semiconductor Co., Ltd. Basic Interval Timer 11.2.1 Overview The A94B114 has one 8-bit basic interval timer that is free-run and can’t stop. Block diagram is shown in Figure 11.2. In addition, the basic interval timer generates the time base for watchdog timer counting. It also provides a basic interval timer interrupt. The A94B114 has these basic interval timer (BIT) features: − As timer function, timer interrupt occurrence NOTE) Since BIT Clock uses system clock, even if LFO (256kHz) is used as system clock, it can not be used in STOP Mode 11.2.2 Block Diagram BCK[2:0] 3 selected bit overflow 8-Bit Up Counter BITCNT BIT Clock IRQ2.2 clear clear INT_ACK RESET BCLR Figure 11.2 WDT Basic Interval Timer Block Diagram 11.2.3 Register Map Name Address Direction Default Description BITCNT 85H R 00H Basic Interval Timer Counter Register BITCR 86H R/W 04H Basic Interval Timer Control Register Table 11.2 Basic Interval Timer Register Map 78 To interrupt block A94B114 ABOV Semiconductor Co., Ltd. 11.2.4 Basic Interval Timer Register Description The basic interval timer register consists of basic interval timer counter register (BITCNT) and basic interval timer control register (BITCR). If BCLR bit is set to ‘1’, BITCNT becomes ‘0’ and then counts up. After 1 machine cycle, BCLR bit is cleared to ‘0’ automatically. 11.2.5 Register Description for Basic Interval Timer BITCNT (Basic Interval Timer Counter Register) : 8CH 7 6 5 4 3 2 1 0 BITCNT7 BITCNT6 BITCNT5 BITCNT4 BITCNT3 BITCNT2 BITCNT1 BITCNT0 R R R R R R R R Initial value : 00H BITCNT[7:0] BIT Counter BITCR (Basic Interval Timer Control Register) : 8BH 7 6 5 4 3 2 1 0 BITIFR BITCK1 BITCK0 – BCLR BCK2 BCK1 BCK0 R/W R/W R/W – R/W R/W R/W BITIFR BITCK[1:0] BCLR BCK[2:0] R/W Initial value : 04H When BIT Interrupt occurs, this bit becomes ‘1’. For clearing bit, write ‘0’ to this bit or auto clear by INT_ACK signal. Writing “1” has no effect. 0 BIT interrupt no generation 1 BIT interrupt generation Select BIT clock source BITCK1 BITCK0 Description 0 0 fx / 4096 0 1 fx / 1024 1 0 fx / 128 1 1 fx / 16 If this bit is written to ‘1’, BIT Counter is cleared to ‘0’ 0 Free Running 1 Clear Counter Select BIT overflow period BCK2 BCK1 BCK0 Description 0 0 0 Bit 0 overflow (BIT Clock * 2) 0 0 1 Bit 1 overflow (BIT Clock * 4) 0 1 0 Bit 2 overflow (BIT Clock * 8) 0 1 1 Bit 3 overflow (BIT Clock * 16) 1 0 0 Bit 4 overflow (BIT Clock * 32) (Default) 1 0 1 Bit 5 overflow (BIT Clock * 64) 1 1 0 Bit 6 overflow (BIT Clock * 128) 1 1 1 Bit 7 overflow (BIT Clock * 256) 79 A94B114 11.3 ABOV Semiconductor Co., Ltd. Watch Dog Timer 11.3.1 Overview The watchdog timer rapidly detects the CPU malfunction such as endless looping caused by noise or something like that, and resumes the CPU to the normal state. The watchdog timer signal for malfunction detection can be used as either a CPU reset or an interrupt request. When the watchdog timer is not being used for malfunction detection, it can be used as a timer to generate an interrupt at fixed intervals. It is possible to use free running 8-bit timer mode or watch dog timer mode as setting WDT_RESET_EN bit. If WDT_CLR is written to ‘1’, WDT counter value is cleared and counts up. After 1 machine cycle, this bit is cleared to ‘0’ automatically. The watchdog timer consists of 8-bit binary counter and the watchdog timer data register. When the value of 8-bit binary counter is equal to the 8 bits of WDTR, the interrupt request flag is generated. This can be used as Watchdog timer interrupt or reset of CPU in accordance with the bit WDT_RESET_EN. The clock source of the watchdog timer selects one of the system clock, ring oscillator, and bit overflow. The interval of watchdog timer interrupt is decided by WDT_CLK_DIV and WDTR set value. The equation can be described as 𝑊𝐷𝑇_𝑇𝐼𝑀𝐸[𝑠] = 𝑊𝐷𝑇_𝐶𝐿𝐾_𝐷𝐼𝑉 × (𝑊𝐷𝑇𝑅 𝑣𝑎𝑙𝑢𝑒 + 1) 𝑓𝑥 𝑜𝑟 𝑓𝐿𝐹𝑂 𝑜𝑟 𝑓𝐵𝐼𝑇 NOTE1) LFO Clock is different between Normal / IDLE mode and Stop mode. NOTE2) LFO Clock is 256kHz for Normal / IDLE mode and 168kHz for Stop Mode. (Typical) 11.3.2 Block Diagram fx WDT Clock Default 16MHz To RESET Circuit clear WDTCR WDTEN fLFO To interrupt block 256kHz IRQ2.1 fBIT Default 122Hz clear WDTR INT_ACK 5 WDT_CLR WDTMR {WDT_CLK_SEL[1:0], WDT_CLK_DIV[2:0]} Figure 11.3 WDT_REST_EN Watch Dog Timer Block Diagram 80 A94B114 ABOV Semiconductor Co., Ltd. 11.3.3 WDT Interrupt Timing Waveform WDT Clock Sourece WDT_CNT 0 1 2 3 0 1 2 3 WDTR 0 1 2 counter clear WDT_CLR occur n 3 WDTR  0000_0011b Match Detect WDT_flag WDT_RESETB Figure 11.4 RESET Watch Dog Timer Interrupt Timing Waveform 11.3.4 Register Map Name Address Direction Default Description WDTMR 8DH R/W 3BH Watch Dog Timer Control Register WDTR 8EH W FFH Watch Dog Timer Data Register WDTCR 8EH R 00H Watch Dog Timer Counter Register Table 11.3 Watch Dog Timer Register Map 11.3.5 Watch Dog Timer Register Description The watch dog timer register consists of watch dog timer counter register (WDTCR), watch dog timer data register (WDTR) and watch dog timer control register (WDTCR). 81 A94B114 ABOV Semiconductor Co., Ltd. 11.3.6 Register Description for Watch Dog Timer WDTMR (Watch Dog Timer Control Register) : 8DH 7 6 5 4 3 2 1 0 WDT_CLK_SE L1 WDT_CLK_SE L0 WDT_CLK_DIV 2 WDT_CLK_DIV 1 WDT_CLK_DIV 0 WDT_CLR WDT_RESET_ EN WDT_EN R/W R/W R/W R/W R/W R/W R/W WDT_CLK_SEL[1:0] WDT_CLK_DIV[2:0] R/W Initial value : 3BH WDT Clock Source Selection CLK_SEL1 CLK_SEL0 Description 0 0 Divide HFO clock (fx : Default 16MHz) 0 1 LFO clock (fLFO : 256kHz) 1 0 BIT overflow (fBIT : 122Hz) 1 1 Not used WDT Clock Source Selection fWDT : WDT Clock Source set by WDT_CLK_SEL[1:0] CLK_DIV2 CLK_DIV1 CLK_DIV0 Description WDT_CLR 0 0 0 fWDT / 2 0 0 1 fWDT / 4 0 1 0 fWDT / 8 0 1 1 fWDT / 16 1 0 0 fWDT / 256 1 0 1 fWDT / 512 1 1 0 fWDT / 1024 1 1 1 fWDT / 2048 Clear WDT Counter WDT_RESET_EN 0 Free Run 1 Clear WDT Counter (auto clear after 1 cycle) WDT Reset Enable bit WDT_EN 0 Disable 1 Enable WDT Enable bit 0 Disable 1 Enable WDTCR (Watch Dog Timer Counter Register: Read Case) : 8EH 7 6 5 4 3 2 1 0 WDTCR 7 WDTCR6 WDTCR5 WDTCR4 WDTCR3 WDTCR2 WDTCR1 WDTCR0 R R R R R R R R Initial value : 00H WDTCR[7:0] WDT Counter WDTR (Watch Dog Timer Data Register: Write Case) : 8EH 7 6 5 4 3 2 1 0 WDTR7 WDTR 6 WDTR 5 WDTR 4 WDTR 3 WDTR 2 WDTR 1 WDTR 0 W W W W W W W WDTR[7:0] Set a period WDT Interrupt Interval = WDT_CLK_DIV x (WDTDR Value+1) / (WDT Clock Source Period) NOTE) To guarantee proper operation, the data should be greater than 01H. 82 W Initial value : FFH A94B114 11.4 ABOV Semiconductor Co., Ltd. Timer 0 11.4.1 Overview The 8-bit timer 0 consists of multiplexer, timer 0 counter register, timer 0 data register, timer 0 capture data register and timer 0 control register (T0CNT, T0DR, T0CDR, T0CR). It has three operating modes: − 8-bit timer/counter mode − 8-bit PWM output mode − 8-bit capture mode The timer/counter 0 can be clocked by an internal or an external clock source (EC0). The clock source is selected by clock selection logic which is controlled by the clock selection bits (T0CK[2:0]). − TIMER 0 clock source: fX/2, 4, 8, 32, 128, 512, 2048 and EC0 In the capture mode, by EINT10, the data is captured into input capture data register (T0CDR). In timer/counter mode, whenever counter value is equal to T0DR, T0O port toggles. Also the timer 0 outputs PWM waveform through PWM0O port in the PWM mode. T0EN T0MS[1:0] T0CK[2:0] Timer 0 1 00 XXX 8 Bit Timer/Counter Mode 1 01 XXX 8 Bit PWM Mode 1 1X XXX 8 Bit Capture Mode Table 11.4 Timer 0 Operating Modes 83 A94B114 ABOV Semiconductor Co., Ltd. 11.4.2 8-bit Timer/Counter Mode The 8-bit timer/counter mode is selected by control register as shown in Figure 11.5. The 8-bit timer have counter and data register. The counter register is increased by internal. Timer 0 can use the input clock with one of 2, 4, 8, 32, 128, 512 and 2048 prescaler division rates (T0CK[2:0]). When the value of T0CNT and T0DR is identical in timer 0, a match signal is generated and the interrupt of Timer 0 occurs. T0CNT value is automatically cleared by match signal. It can be also cleared by software (T0CC). The external clock (EC0) counts up the time at the rising edge. If the EC0 is selected as a clock source by T0CK[2:0], EC0 port should be set to the input port by P2FSR[7:6]. T0CR T0EN T0PE T0MS1 T0MS0 T0CK2 T0CK1 T0CK0 T0CC 1 x 0 0 x x x x ADDRESS : 92H INITIAL VALUE: 0000_0000B EC0 fx P r e s c a l e r fx/2 fx/4 fx/8 fx/32 Match signal Clear M U X T0CC 8-bit Timer 0 Counter INT_ACK T0CNT(8Bit) fx/128 Clear fx/512 fx/2048 Match T0EN MUX IRQ1.4 To interrupt block Comparator 3 2 T0DR(8Bit) T0CK[2:0] T0PE T0MS[1:0] 8-bit Timer 0 Data Register T0O/PWM0O Figure 11.5 8-bit Timer/Counter Mode for Timer 0 Match with T0DR n T0CNT n-1 Value Count Pulse n-2 Period Up- PCP 6 count 5 4 3 2 1 0 TIME Interrupt Period = PCP x (n+1) Timer 0 (T0IFR) Interrupt Figure 11.6 Occur Occur Occur Interrupt Interrupt Interrupt 8-bit Timer/Counter 0 Example 84 A94B114 ABOV Semiconductor Co., Ltd. 11.4.3 8-bit PWM Mode The timer 0 has a high speed PWM (Pulse Width Modulation) function. In PWM mode, T0O/PWM0O pin outputs up to 8-bit resolution PWM output. This pin should be configured as a PWM output by setting the T0O/PWM0O function by P2FSR[7:6] to ’10’. In the 8-bit timer/counter mode, a match signal is generated when the counter value is identical to the value of T0DR. When the value of T0CNT and T0DR is identical in timer 0, a match signal is generated and the interrupt of timer 0 occurs. In PWM mode, the match signal does not clear the counter. Instead, it runs continuously, overflowing at “FFH”, and then continues incrementing from “00H”. The timer 0 overflow interrupt is generated whenever a counter overflow occurs. T0CNT value is cleared by software (T0CC) bit. T0CR T0EN T0PE T0MS1 T0MS0 T0CK2 T0CK1 T0CK0 T0CC 1 x 0 1 x x x x ADDRESS : 92H INITIAL VALUE: 0000_0000B EC0 fx P r e s c a l e r fx/2 fx/4 fx/8 fx/32 Match signal Clear M U X T0CC 8-bit Timer 0 Counter INT_ACK T0CNT(8Bit) fx/128 Clear fx/512 fx/2048 Match T0EN IRQ1.4 To interrupt block Comparator 3 T0CK[2:0] MUX 2 T0DR(8Bit) T0MS[1:0] T0PE 8-bit Timer 0 Data Register T0O/PWM0O Figure 11.7 8-bit PWM Mode for Timer 0 85 A94B114 ABOV Semiconductor Co., Ltd. PWM Mode(T0MS = 01b) Set T0EN Timer 0 clock T0CNT XX 00H 01H 02H 4AH T0DR T0 Overflow Interrupt 1. T0DR = 4AH T0PWM T0 Match Interrupt 2. T0DR = 00H T0PWM T0 Match Interrupt 3. T0DR = FFH T0PWM T0 Match Interrupt Figure 11.8 PWM Output Waveforms in PWM Mode for Timer 0 86 FEH FFH 00H A94B114 ABOV Semiconductor Co., Ltd. 11.4.4 8-bit Capture Mode The timer 0 capture mode is set by T0MS[1:0] as ‘1x’. The clock source can use the internal/external clock. Basically, it has the same function as the 8-bit timer/counter mode and the interrupt occurs when T0CNT is equal to T0DR. T0CNT value is automatically cleared by match signal and it can be also cleared by software (T0CC). This timer interrupt in capture mode is very useful when the pulse width of captured signal is wider than the maximum period of timer. The capture result is loaded into T0CDR. In the timer 0 capture mode, timer 0 output (T0O) waveform is not available. According to EIPOL0 registers setting, the external interrupt EINT10 function is chosen. Of course, the EINT10 pin must be set to an input port. T0CDR and T0DR are in the same address. In the capture mode, reading operation reads T0CDR, not T0DR and writing operation will update T0DR. T0CR T0EN T0PE T0MS1 T0MS0 T0CK2 T0CK1 T0CK0 T0CC 1 x 1 x x x x x ADDRESS : 92H INITIAL VALUE: 0000_0000B EC0 P r e s c a l e r fx fx/2 Match signal Clear fx/4 M U X fx/8 fx/32 T0CC 8-bit Timer 0 Counter INT_ACK T0CNT(8Bit) fx/128 Clear Clear fx/512 fx/2048 Match T0EN MUX IRQ1.4 Comparator 3 2 T0DR(8Bit) T0CK[2:0] T0MS[1:0] 8-bit Timer 0 Data Register EIPOL0[1:0] 2 T0CDR(8Bit) EINT10 INT_ACK 2 Clear T0MS[1:0] IRQ.1 Figure 11.9 8-bit Capture Mode for Timer 0 87 To interrupt block To interrupt block A94B114 ABOV Semiconductor Co., Ltd. T0CDR Load n T0CNT Value nn2 Up-count 1 Count Pulse Period PCP 6 5 4 3 2 1 0 TIME Ext. EINT10 PIN Interrupt Request (FLAG10) Figure 11.10 Interrupt Interval Period Input Capture Mode Operation for Timer 0 FFH FFH XXH T0CNT YYH 00H 00H 00H 00H Interrupt Request (T0IFR) Ext. EINT10 PIN Interrupt Request (FLAG10) Figure 11.11 Interrupt Interval Period = FFH+01H+FFH +01H+YYH+01H Express Timer Overflow in Capture Mode 88 00H A94B114 ABOV Semiconductor Co., Ltd. 11.4.5 Block Diagram EC0 P r e s c a l e r fx fx/2 fx/4 8-bit Timer 0 Counter M U X fx/8 fx/32 T0CC Clear T0CNT (8Bit) INT_ACK Match signal fx/128 Clear Clear fx/512 Match T0EN fx/2048 MUX IRQ1.4 To interrupt block Comparator 3 T0CK[2:0] T0DR (8Bit) To other block 2 T0MS[1:0] 8-bit Timer 0 Data Register EIPOL0[1:0] T0O/PWM0O 2 T0CDR (8Bit) T0PE EINT10 INT_ACK 2 Clear T0MS[1:0] IRQ.1 Figure 11.12 To interrupt block 8-bit Timer 0 Block Diagram 11.4.6 Register Map Name Address Direction Default Description T0CR 92H R/W 00H Timer 0 Control Register T0CNT 93H R 00H Timer 0 Counter Register T0DR 94H R/W FFH Timer 0 Data Register T0CDR 94H R 00H Timer 0 Capture Data Register Table 11.5 Timer 0 Register Map 11.4.7 Timer/Counter 0 Register Description The timer/counter 0 register consists of timer 0 counter register (T0CNT), timer 0 data register (T0DR), timer 0 capture data register (T0CDR), and timer 0 control register (T0CR). 89 A94B114 ABOV Semiconductor Co., Ltd. 11.4.8 Register Description for Timer/Counter 0 T0CR (Timer 0 Control Register) : 92H 7 6 5 4 3 2 1 0 T0EN T0PE T0MS1 T0MS0 T0CK2 T0CK1 T0CK0 T0CC R/W R/W R/W R/W R/W R/W R/W T0EN T0PE T0MS[1:0] T0CK[2:0] T0CC R/W Initial value : 00H Control Timer 0 0 Timer 0 disable 1 Timer 0 enable Port output Control Timer0 0 Port output disable 1 Port output enable Control Timer 0 Operation Mode T0MS1 T0MS0 Description 0 0 Timer/counter mode (T0O: toggle at match) 0 1 PWM mode (The overflow interrupt can occur) 1 x Capture mode (The match interrupt can occur) Select Timer 0 clock source. fx is a system clock frequency T0CK2 T0CK1 T0CK0 Description 0 0 0 fx/2 0 0 1 fx/4 0 1 0 fx/8 0 1 1 fx/32 1 0 0 fx/128 1 0 1 fx/512 1 1 0 fx/2048 1 1 1 External clock (EC0) Clear timer 0 Counter 0 No effect 1 Clear the Timer 0 counter (When write, automatically cleared “0” after being cleared counter) 90 A94B114 ABOV Semiconductor Co., Ltd. T0CNT (Timer 0 Counter Register) : 93H 7 6 5 4 3 2 1 0 T0CNT7 T0CNT6 T0CNT5 T0CNT4 T0CNT3 T0CNT2 T0CNT1 T0CNT0 R R R R R R R R Initial value : 00H T0CNT[7:0] T0 Counter T0DR (Timer 0 Data Register) : 94H 7 6 5 4 3 2 1 0 T0DR7 T0DR6 T0DR5 T0DR4 T0DR3 T0DR2 T0DR1 T0DR0 R/W R/W R/W R/W R/W R/W R/W T0DR[7:0] R/W Initial value : FFH T0 Data T0CDR (Timer 0 Capture Data Register: Read Case, Capture mode only) : 94H 7 6 5 4 3 2 1 0 T0CDR7 T0CDR6 T0CDR5 T0CDR4 T0CDR3 T0CDR2 T0CDR1 T0CDR0 R R R R R R R T0CDR[7:0] T0 Capture Data 91 R Initial value : 00H A94B114 11.5 ABOV Semiconductor Co., Ltd. Timer 1 11.5.1 Overview The 16-bit timer 1 consists of multiplexer, timer 1 A data register high/low, timer 1 B data register high/low, timer1 C data register high/low timer1 D data register high/low and timer 1 control register high/low (T1ADRH, T1ADRL, T1BDRH, T1BDRL, T1CRH, T1CRL, T1DRH, T1DRL). It has four operating modes: − 16-bit timer/counter mode − 16-bit capture mode − 16-bit PPG output mode (one-shot mode) − 16-bit PPG output mode (repeat mode) The timer/counter 1 can be clocked by an internal or an external clock source (EC1). The clock source is selected by clock selection logic which is controlled by the clock selection bits (T1CK[2:0]). − TIMER 1 clock source: fX/1, 2, 4, 8, 64, 2048, HFO and EC1 In the capture mode, by EINT11, the data is captured into input capture data register (T1BDRH/T1BDRL). Timer 1 outputs the comparison result between counter and data register through T1O port in timer/counter mode. Also Timer 1 outputs PWM wave form through PWM1O port in the PPG mode. T1EN P1FSRL[4:3] T1MS[1:0] T1CK[2:0] Timer 1 1 01 00 XXX 16 Bit Timer/Counter Mode 1 00 01 XXX 16 Bit Capture Mode 1 01 10 XXX 16 Bit PPG Mode(one-shot mode) 1 01 11 XXX 16 Bit PPG Mode(repeat mode) Table 11.6 Timer 1 Operating Modes 11.5.2 16-bit Timer/Counter Mode The 16-bit timer/counter mode is selected by control register as shown in Figure 11.13. The 16-bit timer have counter and data register. The counter register is increased by internal or external clock input. Timer 1 can use the input clock with one of 1, 2, 4, 8, 64, 2048 and Internal High Frequency Oscillator (HFO) prescaler division rates (T1CK[2:0]). When the value of T1CNTH, T1CNTL and the value of T1ADRH, T1ADRL are identical in Timer 1 respectively, a match signal is generated and the interrupt of Timer 1 occurs. The T1CNTH, T1CNTL value is automatically cleared by match signal. It can be also cleared by software (T1CC). The external clock (EC1) counts up the timer at the rising edge. If the EC1 is selected as a clock source by T1CK[2:0], EC1 port should be set to the input port by P0FSR_L[7:6] to ‘01’. 92 A94B114 ABOV Semiconductor Co., Ltd. T1CRH T1CRL T1EN T1BEN T1MS1 T1MS0 – – T1PE T1CC 1 X 0 0 – – X X T1CK2 T1CK1 T1CK0 T1IFR T1BPOL T1POL X X X X X X ADDRESS:BBH INITIAL VALUE : 0000_0000B T1ECE T1CNTR X ADDRESS:BAH INITIAL VALUE : 0000_0000B X 16-bit A Data Register T1ADRH/T1ADRL A Match T1CC T1EN Reload T1CK[2:0] T1ECE Clear Edge Detector EC1 A Match P r e s c a l e r fx INT_ACK Buffer Register A 3 T1EN fx/1 Comparator fx/2 fx/4 fx/8 fx/64 To interrupt block IRQ1.5 16-bit Counter T1CNTH/T1CNTL M U X R A Match T1CC T1EN Clear Pulse Generator fx/2048 T1O 2 HFO T1MS[1:0] Figure 11.13 T1PE T1POL 16-bit Timer/Counter Mode for Timer 1 Match with T1ADRH/L n T1CNTH/L n- Value n- 1 Count Pulse Period PCP 2 Up-count 6 5 4 3 2 1 0 TIME Interrupt Period = PCP x (n+1) Timer 1 Interrupt Figure 11.14 Occur Occur Occur Interrupt Interrupt Interrupt 16-bit Timer/Counter 1 Example 93 A94B114 ABOV Semiconductor Co., Ltd. 11.5.3 16-bit Capture Mode The 16-bit timer 1 capture mode is set by T1MS[1:0] as ‘01’. The clock source can use the internal/external clock. Basically, it has the same function as the 16-bit timer/counter mode and the interrupt occurs when T1CNTH/T1CNTL is equal to T1ADRH/T1ADRL. The T1CNTH, T1CNTL values are automatically cleared by match signal. It can be also cleared by software (T1CC). This timer interrupt in capture mode is very useful when the pulse width of captured signal is wider than the maximum period of timer. The capture result is loaded into T1BDRH/T1BDRL. According to EIPOL0 registers setting, the external interrupt EINT11 function is chosen. Of course, the EINT11 pin must be set as an input port. T1EN T1BEN T1MS1 T1MS0 – – T1PE T1CC 1 X 0 1 – – X X T1CK2 T1CK1 T1CK0 T1IFR X X X X T1CRH T1CRL T1BPOL T1POL X X ADDRESS:BBH INITIAL VALUE : 0000_0000B ADDRESS:BAH INITIAL VALUE : 0000_0000B T1ECE T1CNTR X X 16-bit A Data Register T1ADRH/T1ADRL A Match T1CC T1EN Reload T1CK[2:0] T1ECE Edge Detector EC1 Clear A Match P r e s c a l e r fx INT_ACK Buffer Register A 3 T1EN fx/1 fx/8 fx/64 To interrupt block Comparator fx/2 fx/4 IRQ1.5 M U X 16-bit Counter T1CNTH/T1CNTL R Clear A Match T1CC T1EN Clear fx/2048 HFO EIPOL0[3:2] 2 T1CNTR 16-bit B Data Register T1BDRH/T1BDRL EINT11 2 INT_ACK Clear T1MS[1:0] IRQ.2 Figure 11.15 16-bit Capture Mode for Timer 1 94 To interrupt block A94B114 ABOV Semiconductor Co., Ltd. T1BDRH/L Load n T1CNTH/L n- Value n2 Up-count 1 Count Pulse Period PCP 6 5 4 3 2 1 0 TIME Ext. EINT11 PIN Interrupt Request Interrupt Interval Period (FLAG11) Figure 11.16 Input Capture Mode Operation for Timer 1 FFFFH FFFFH XXH T1CNTH/L YYH 00H 00H 00H 00H Interrupt Request (T1IFR) Ext. EINT11 PIN Interrupt Request (FLAG11) Figure 11.17 Interrupt Interval Period = FFFFH+01H+FFFFH +01H+YYH+01H Express Timer Overflow in Capture Mode 95 00H A94B114 ABOV Semiconductor Co., Ltd. 11.5.4 16-bit PPG Mode The timer 1 has a PPG (Programmable Pulse Generation) function. In PPG mode, T1O/PWM1O pin outputs up to 16bit resolution PWM output. This pin should be configured as a PWM output by setting P1FSRL_L[3:2] or P0FSRL_L[7:6] to ‘10’. The period of the PWM output is determined by the T1ADRH/T1ADRL. And the duty of the PWM output is determined by the T1BDRH/T1BDRL. T1CRH T1CRL T1EN T1BEN T1MS1 T1MS0 – – T1PE T1CC 1 X 1 1 – – X X T1CK2 T1CK1 T1CK0 T1IFR X X X X T1BPOL T1POL X X ADDRESS:BBH INITIAL VALUE : 0000_0000B ADDRESS:BAH INITIAL VALUE : 0000_0000B T1ECE T1CNTR X X 16-bit A Data Register T1ADRH/T1ADRL A Match T1CC T1EN Reload T1CK[2:0] T1ECE EC1 fx Edge Detector INT_ACK Buffer Register A 3 Clear A Match P r e s c a l e r T1EN fx/1 Comparator fx/2 fx/4 fx/8 fx/64 To interrupt block IRQ1.5 M U X 16-bit Counter T1CNTH/T1CNTL HFO T1EN B Match fx/2048 Comparator Buffer Register B Reload A Match T1CC Clear R Pulse Generator 2 T1O/ PWM1O T1PE T1MS[1:0] T1POL A Match T1CC T1EN 16-bit B Data Register T1BDRH/T1BDRL NOTE) The T1EN is automatically cleared to logic “0” after one pulse is generated at a PPG one-shot mode. Figure 11.18 16-bit PPG Mode for Timer 1 96 A94B114 ABOV Semiconductor Co., Ltd. Repeat Mode(T1MS = 11b) and "Start High"(T1POL = 0b). Clear and Start Set T1EN Timer 1 clock Counter X T1ADRH/L M 0 1 2 3 4 5 6 7 8 M-1 0 1 2 T1 Interrupt 1. T1BDRH/L(5) < T1ADRH/L PWM1O B Match A Match 2. T1BDRH/L >= T1ADRH/L PWM1O A Match 3. T1BDRH/L = "0000H" PWM1O A Match Low Level One-shot Mode(T1MS = 10b) and "Start High"(T1POL = 0b). Clear and Start Set T1EN Timer 1 clock Counter X T1ADRH/L M 0 1 2 3 4 5 6 7 8 M-1 0 T1 Interrupt 1. T1BDRH/L(5) < T1ADRH/L PWM1O B Match A Match 2. T1BDRH/L >= T1ADRH/L PWM1O A Match 3. T1BDRH/L = "0000H" PWM1O Figure 11.19 A Match Low Level 16-bit PPG Mode Timming chart for Timer 1 97 3 4 A94B114 ABOV Semiconductor Co., Ltd. 11.5.5 16-bit Complementary PWM mode (Dead Time) The timer 1 has a Complementary PWM function. The complementary PWM output function operates when T1BEN is set. In PPG mode, PWM1O/PWM1OB pin outputs up to 16-bit resolution complementary PWM output. This pin should be configured as a PWM output by setting P1FSRL_L[3:2] or P0FSRL_L[7:6] to ‘10’. The period of the PWM output is determined by the T1ADRH/T1ADRL. And the duty of the PWM output is determined by the T1BDRH/T1BDRL. The delay (dead time) of the complementary pwm output is determined by T1CDRH / T1CDRL. And the duty of the complementary pwm output is determined by T1DDRH / T1DDRL. T1CRH T1CRL T1EN T1BEN T1MS1 T1MS0 – – T1PE T1CC 1 1 1 1 – – 1 X T1CK2 T1CK1 T1CK0 T1IFR X X X X T1BPOL T1POL X 16-bit A Data Register T1ADRH/T1ADRL Reload ADDRESS:BBH INITIAL VALUE : 0000_0000B ADDRESS:BAH INITIAL VALUE : 0000_0000B T1ECE T1CNTR X X X 16-bit D Data Register T1DDRH/T1DDRL Reload Buffer Register A Buffer Register D INT_ACK D Match EC1 Edge Detector T1ECE fx A Match P r e s c a l e r IRQ1.5 T1EN fx/1 Clear To interrupt block Comparator fx/2 M U X fx/4 fx/8 fx/64 16-bit Counter T1CNTH/T1CNTL R Clear R 16-bit Counter TZCNTH/TZCNT Pulse Generator B Match fx/2048 PWM1O Comparator 2 HFO T1POL 3 T1PE Pulse Generator C Match T1CK[2:0] PWM1OB 2 Buffer Register B A Match T1CC T1EN Reload 16-bit B Data Register T1BDRH/T1BDRL Buffer Register C T1MS[1:0] T1BPOL T1BEN Reload 16-bit C Data Register T1CDRH/T1CDRL NOTE) The T1EN is automatically cleared to logic “0” after one pulse is generated at a PPG one-shot mode. Figure 11.20 16-bit Complementary PWM Mode for Timer 1 98 A94B114 ABOV Semiconductor Co., Ltd. Repeat Mode(T1MS = 11b) and "Start High"(T1POL = 0b). Clear and Start Set T1EN Timer 1 clock T1_Counter TZ_Counter T1ADRH/L X X 0 1 2 3 4 5 6 7 8 X X 0 1 2 3 4 5 6 7 M-1 0 1 2 3 4 ···· ···· ···· 0 1 2 M T1 Interrupt 1. T1BDRH/L(5) < T1ADRH/L, T1CDRH/L(2), T1DDRH/L(5), PWM1O B Match A Match C Match PWM1OB C Match T1BPOL = 0b D Match T1CDR * T1 Clock T1DDR * T1 Clock T1CDR * T1 Clock T1DDR * T1 Clock T1CDR * T1 Clock T1BPOL = 1b PWM1OB T1CDR * T1 Clock 1st PERIOD 2nd PERIOD 1. T1BDRH/L(5) < T1ADRH/L, T1CDRH/L(2), T1DDRH/L(5), - one shot mode PWM1O PWM1OB T1BPOL = 0b C Match T1CDR * T1 Clock D Match T1DDR * T1 Clock T1BPOL = 1b PWM1OB T1CDR * T1 Clock T1DDR * T1 Clock 1st PERIOD Figure 11.21 16-bit Complementary PWM Mode Timming chart for Timer 1 99 A94B114 ABOV Semiconductor Co., Ltd. 11.5.6 Block Diagram 16-bit D Data Register T1DDRH/T1DDRL 16-bit A Data Register T1ADRH/T1ADRL Reload Reload Buffer Register D Buffer Register A INT_ACK D Match Edge Detector EC1 A Match P r e s c a l e r T1ECE fx IRQ1.5 T1EN fx/1 Clear To interrupt block Comparator fx/2 fx/4 16-bit Counter T1CNTH/T1CNTL M U X fx/8 fx/64 R R 16-bit Counter TZCNTH/TZCNT Clear Pulse Generator B Match fx/2048 Comparator 2 HFO T1POL 3 T1O/ PWM1O T1PE Pulse Generator C Match T1CK[2:0] 2 Buffer Register B A Match T1CC T1EN Reload Buffer Register C T1MS[1:0] Reload 16-bit B Data Register T1BDRH/T1BDRL 16-bit C Data Register T1CDRH/T1CDRL EIPOL0[3:2] 2 T1CNTR EINT11 INT_ACK 2 Clear T1MS[1:0] To interrupt block IRQ.2 Figure 11.22 16-bit Timer 1 Block Diagram 11.5.7 Register Map Name Address Direction Default Description T1CRL BAH R/W 00H Timer 1 Control Low Register T1CRH BBH R/W 00H Timer 1 Control High Register T1ADRL BCH R/W FFH Timer 1 A Data Low Register T1ADRH BDH R/W FFH Timer 1 A Data High Register T1BDRL BEH R/W FFH Timer 1 B Data Low Register T1BDRH BFH R/W FFH Timer 1 B Data High Register T1CDRL CCH R/W FFH Timer 1 C Data Low Register T1CDRH CDH R/W FFH Timer 1 C Data High Register T1DDRL CEH R/W FFH Timer 1 D Data Low Register T1DDRH CFH R/W FFH Timer 1 D Data High Register Table 11.7 Timer 1 Register Map 100 T1BPOL T1BEN PWM1OB A94B114 ABOV Semiconductor Co., Ltd. 11.5.8 Timer/Counter 1 Register Description The timer/counter 1 register consists of timer 1 A data high register (T1ADRH), timer 1 A data low register (T1ADRL), timer 1 B data high register (T1BDRH), timer 1 B data low register (T1BDRL), timer 1 C data high register (T1CDRH), timer 1 C data low register (T1CDRL), timer 1 D data high register (T1DDRH), timer 1 D data log register (T1DDRL), timer 1 control high register (T1CRH) and timer 1 control low register (T1CRL). 11.5.9 Register Description for Timer/Counter 1 T1ADRH (Timer 1 A data High Register) : BDH 7 6 5 4 3 2 1 0 T1ADRH7 T1ADRH6 T1ADRH5 T1ADRH4 T1ADRH3 T1ADRH2 T1ADRH1 T1ADRH0 R/W R/W R/W R/W R/W R/W R/W T1ADRH[7:0] R/W Initial value : FFH T1 A Data High Byte T1ADRL (Timer 1 A Data Low Register) : BCH 7 6 5 4 3 2 1 0 T1ADRL7 T1ADRL6 T1ADRL5 T1ADRL4 T1ADRL3 T1ADRL2 T1ADRL1 T1ADRL0 R/W R/W R/W R/W R/W R/W R/W T1ADRL[7:0] R/W Initial value : FFH T1 A Data Low Byte NOTE) Do not write “0000H” in the T1ADRH/T1ADRL register when PPG mode T1BDRH (Timer 1 B Data High Register) : BFH 7 6 5 4 3 2 1 0 T1BDRH7 T1BDRH6 T1BDRH5 T1BDRH4 T1BDRH3 T1BDRH2 T1BDRH1 T1BDRH0 R/W R/W R/W R/W R/W R/W R/W T1BDRH[7:0] R/W Initial value : FFH T1 B Data High Byte T1BDRL (Timer 1 B Data Low Register) : BEH 7 6 5 4 3 2 1 0 T1BDRL7 T1BDRL6 T1BDRL5 T1BDRL4 T1BDRL3 T1BDRL2 T1BDRL1 T1BDRL0 R/W R/W R/W R/W R/W R/W R/W T1BDRL[7:0] T1 B Data Low Byte 101 R/W Initial value : FFH A94B114 ABOV Semiconductor Co., Ltd. T1CDRH (Timer 1 C data High Register) : CDH 7 6 5 4 3 2 1 0 T1CDRH7 T1CDRH6 T1CDRH5 T1CDRH4 T1CDRH3 T1CDRH2 T1CDRH1 T1CDRH0 R/W R/W R/W R/W R/W R/W R/W T1CDRH[7:0] R/W Initial value : FFH T1 C Data High Byte T1CDRL (Timer 1 C Data Low Register) : CCH 7 6 5 4 3 2 1 0 T1CDRL7 T1CDRL6 T1CDRL5 T1CDRL4 T1CDRL3 T1CDRL2 T1CDRL1 T1CDRL0 R/W R/W R/W R/W R/W R/W R/W T1CDRL[7:0] R/W Initial value : FFH T1 C Data Low Byte T1DDRH (Timer 1 D Data High Register) : CFH 7 6 5 4 3 2 1 0 T1DDRH7 T1DDRH6 T1DDRH5 T1DDRH4 T1DDRH3 T1DDRH2 T1DDRH1 T1DDRH0 R/W R/W R/W R/W R/W R/W R/W T1DDRH[7:0] R/W Initial value : FFH T1 D Data High Byte T1DDRL (Timer 1 D Data Low Register) : CEH 7 6 5 4 3 2 1 0 T1DDRL7 T1DDRL6 T1DDRL5 T1DDRL4 T1DDRL3 T1DDRL2 T1DDRL1 T1DDRL0 R/W R/W R/W R/W R/W R/W R/W T1DDRL[7:0] T1 D Data Low Byte 102 R/W Initial value : FFH A94B114 ABOV Semiconductor Co., Ltd. T1CRH (Timer 1 Control High Register) : BBH 7 6 5 4 3 2 1 0 T1EN T1BEN T1MS1 T1MS0 – – T1PE T1CC R/W R/W R/W R/W – – R/W T1EN T1BEN T1MS[1:0] T1PE T1CC Control Timer 1 0 Timer 1 disable 1 Timer 1 enable (Counter clear and start) Control Complementary PWM 0 Complementary PWM disable 1 Complementary PWM enable Control Timer 1 Operation Mode T1MS1 T1MS0 Description 0 0 Timer/counter mode (T1O: toggle at A match) 0 1 Capture mode (The A match interrupt can occur) 1 0 PPG one-shot mode (PWM1O) 1 1 PPG repeat mode (PWM1O) Control Timer 1 port output 0 Timer 1 output disable 1 Timer 1 output enable Clear Timer 1 Counter 0 No effect 1 Clear the Timer 1 counter (When write, automatically cleared “0” after being cleared counter) *NOTE) To use T1O/PWM1O as pin3(P11), set Sub-function and set it to Output High. 103 R/W Initial value : 00H A94B114 ABOV Semiconductor Co., Ltd. T1CRL (Timer 1 Control Low Register) : BAH 7 6 5 4 3 2 1 0 T1CK2 T1CK1 T1CK0 T1IFR T1BPOL T1POL T1ECE T1CNTR R/W R/W R/W R/W R/W R/W R/W T1CK[2:0] T1IFR T1BPOL T1POL T1ECE T1CNTR R/W Initial value : 00H Select Timer 1 clock source. fx is main system clock frequency T1CK2 T1CK1 T1CK0 Description 0 0 0 fx / 2048 0 0 1 fx / 64 0 1 0 fx / 8 0 1 1 fx / 4 1 0 0 fx / 2 1 0 1 fx / 1 1 1 0 HFO Direct (32MHz) 1 1 1 External clock (EC1) When T1 Interrupt occurs, this bit becomes ‘1’. For clearing bit, write ‘0’ to this bit or auto clear by INT_ACK signal. Writing “1” has no effect. 0 T1 Interrupt no generation 1 T1 Interrupt generation PWM1OB Polarity Selection 0 Start High (PWM1OB is low level at disable) 1 Start Low (PWM1OB is high level at disable) T1O/PWM1O Polarity Selection 0 Start High (T1O/PWM1O is low level at disable) 1 Start Low (T1O/PWM1O is high level at disable) Timer 1 External Clock Edge Selection 0 External clock falling edge 1 External clock rising edge Timer 1 Counter Read Control 0 No effect 1 Load the counter value to the B data register (When write, automatically cleared “0” after being loaded) 104 A94B114 11.6 ABOV Semiconductor Co., Ltd. Timer 2 11.6.1 Overview The 16-bit timer 2 consists of multiplexer, timer 2 A data high/low register, timer 2 B data high/low register and timer 2 control high/low register (T2ADRH, T2ADRL, T2BDRH, T2BDRL, T2CRH, T2CRL). It has four operating modes: − 16-bit timer/counter mode − 16-bit capture mode − 16-bit PPG output mode (one-shot mode) − 16-bit PPG output mode (repeat mode) The timer/counter 2 can be clocked by an internal or an external clock source (EC2). The clock source is selected by clock selection logic which is controlled by the clock selection bits (T2CK[2:0]). − TIMER 2 clock source: fX/1, 2, 4, 8, 64, 2048, HFO and EC2 In the capture mode, by EINT12, the data is captured into input capture data register (T2BDRH/T2BDRL). In timer/counter mode, whenever counter value is equal to T2ADRH/L, T2O port toggles. Also the timer 2 outputs PWM wave form to PWM2O port in the PPG mode. T2EN P1FSRL[6:5] T2MS[1:0] T2CK[2:0] Timer 2 1 01 00 XXX 16 Bit Timer/Counter Mode 1 00 01 XXX 16 Bit Capture Mode 1 01 10 XXX 16 Bit PPG Mode(one-shot mode) 1 01 11 XXX 16 Bit PPG Mode(repeat mode) Table 11.8 Timer 2 Operating Modes 105 A94B114 ABOV Semiconductor Co., Ltd. 11.6.2 16-bit Timer/Counter Mode The 16-bit timer/counter mode is selected by control register as shown in Figure 11.23. The 16-bit timer have counter and data register. The counter register is increased by internal or timer 1 A match clock input. Timer 2 can use the input clock with one of 1, 2, 4, 8, 64, 2048 and Internal High Frequency Oscillator (HFO) prescaler division rates(T2CK[2:0]). When the values of T2CNTH/T2CNTL and T2ADRH/T2ADRL are identical in timer 2, a match signal is generated and the interrupt of Timer 2 occurs. The T2CNTH/T2CNTL values are automatically cleared by match signal. It can be also cleared by software (T2CC). The external clock (EC2) counts up the timer at the rising edge. If the EC2 is seledted as a clock source by T1CK[2:0], EC2 port should be set to the input port by P1FSR_L[5:4] to ‘01’. T2CRH T2CRL T2EN – T2MS1 T2MS0 – – T2PE T2CC 1 – 0 0 – – X X T2CK2 T2CK1 T2CK0 T2IFR - T2POL X X X X - X ADDRESS:C3H INITIAL VALUE : 0000_0000B T2ECE T2CNTR X ADDRESS:C2H INITIAL VALUE : 0000_0000B X 16-bit A Data Register T2ADRH/T2ADRL A Match T2CC T2EN Reload T2CK[2:0] T2ECE EC2 Edge Detector fx INT_ACK Buffer Register A 3 Clear A Match P r e s c a l e r T2EN fx/1 Comparator fx/2 fx/4 fx/8 fx/64 M U X 16-bit Counter T2CNTH/T2CNTL R A Match T2CC T2EN Clear Pulse Generator fx/2048 2 HFO T2MS[1:0] Figure 11.23 To interrupt block IRQ1.6 16-bit Timer/Counter Mode for Timer 2 106 T2POL T2O A94B114 ABOV Semiconductor Co., Ltd. Match with T2ADRH/L n T2CNTH/L n- Value n- 1 Count Pulse Period 2 Up-count PCP 6 5 4 3 2 1 0 TIME Interrupt Period = PCP x (n+1) Timer 2 (T2IFR) Interrupt Figure 11.24 Occur Occur Occur Interrupt Interrupt Interrupt 16-bit Timer/Counter 2 Example 107 A94B114 ABOV Semiconductor Co., Ltd. 11.6.3 16-bit Capture Mode The timer 2 capture mode is set by T2MS[1:0] as ‘01’. The clock source can use the internal clock. Basically, it has the same function as the 16-bit timer/counter mode and the interrupt occurs when T2CNTH/T2CNTL is equal to T2ADRH/T2ADRL. T2CNTH/T2CNTL values are automatically cleared by match signal and it can be also cleared by software (T2CC). This timer interrupt in capture mode is very useful when the pulse width of captured signal is wider than the maximum period of timer. The capture result is loaded into T2BDRH/T2BDRL. In the timer 2 capture mode, timer 2 output(T2O) waveform is not available. According to EIPOL0 registers setting, the external interrupt EINT12 function is chosen. Of course, the EINT12 pin must be set to an input port. T2CRH T2CRL T2EN – T2MS1 T2MS0 – – T2PE T2CC 1 – 0 1 – – X X T2CK2 T2CK1 T2CK0 T2IFR – T2POL X X X X – X ADDRESS:C3H INITIAL VALUE : 0000_0000B T2ECE T2CNTR X ADDRESS:C2H INITIAL VALUE : 0000_0000B X 16-bit A Data Register T2ADRH/T2ADRL A Match T2CC T2EN Reload T2CK[2:0] T2ECS EC2 Edge Detector Clear A Match T2EN P r e s c a l e r fx INT_ACK Buffer Register A 3 fx/1 fx/2 fx/4 fx/8 IRQ1.6 To interrupt block Comparator 16-bit Counter T2CNTH/T2CNTL M U X R Clear A Match T2CC T2EN Clear fx/64 fx/2048 HFO EIPOL0[5:4] 2 T2CNTR 16-bit B Data Register T2BDRH/T2BDRL EINT12 2 INT_ACK Clear T2MS[1:0] IRQ.3 Figure 11.25 16-bit Capture Mode for Timer 2 108 To interrupt block A94B114 ABOV Semiconductor Co., Ltd. T2BDRH/L Load n T2CNTH/L n- Value n2 Up-count 1 Count Pulse Period PCP 6 5 4 3 2 1 0 TIME Ext. EINT12 PIN Interrupt Request Interrupt Interval Period (FLAG12) Figure 11.26 Input Capture Mode Operation for Timer 2 FFFFH FFFFH XXH T2CNTH/L YYH 00H 00H 00H 00H Interrupt Request (T2IFR) Ext. EINT12 PIN Interrupt Request (FLAG12) Figure 11.27 Interrupt Interval Period = FFFFH+01H+FFFFH +01H+YYH+01H Express Timer Overflow in Capture Mode 109 00H A94B114 ABOV Semiconductor Co., Ltd. 11.6.4 16-bit PPG Mode The timer 2 has a PPG (Programmable Pulse Generation) function. In PPG mode, the T2O/PWM2O pin outputs up to 16-bit resolution PWM output. This pin should be configured as a PWM output by set P1FSR_L[5:4] or P1FSR_L[1:0] to ‘10’. The period of the PWM output is determined by the T2ADRH/T2ADRL. And the duty of the PWM output is determined by the T2BDRH/T2BDRL. T2EN – T2MS1 T2MS0 – – T2PE T2CC 1 – 1 1 – – 1 X T2CK2 T2CK1 T2CK0 T2IFR – T2POL X X X X – X T2CRH T2CRL ADDRESS:C3H INITIAL VALUE : 0000_0000B ADDRESS:C2H INITIAL VALUE : 0000_0000B T2ECE T2CNTR X X 16-bit A Data Register T2ADRH/T2ADRL A Match T2CC T2EN Reload T2CK[2:0] T2ECS EC2 fx INT_ACK Buffer Register A 3 Clear Edge Detector A Match P r e s c a l e r T2EN fx/1 Comparator fx/2 fx/4 fx/8 To interrupt block T2IFR M U X 16-bit Counter T2CNTH/T2CNTL fx/64 B Match fx/2048 HFO Comparator Buffer Register B Reload A Match T2CC T2EN Clear R Pulse Generator T2O/ PWM2O 2 T2MS[1:0] T2POL T2PE A Match T2CC T2EN 16-bit B Data Register T2BDRH/T2BDRL NOTE) The T2EN is automatically cleared to logic “0” after one pulse is generated at a PPG one-shot mode. Figure 11.28 16-bit PPG Mode for Timer 2 110 A94B114 ABOV Semiconductor Co., Ltd. Repeat Mode(T2MS = 11b) and "Start High"(T2POL = 0b). Clear and Start Set T2EN Timer 2 clock Counter X T2ADRH/L M 0 1 2 3 4 5 6 7 8 M-1 0 1 2 T2 Interrupt 1. T2BDRH/L(5) < T2ADRH/L PWM2O B Match A Match 2. T2BDRH/L >= T2ADRH/L PWM2O A Match 3. T2BDRH/L = "0000H" PWM2O A Match Low Level One-shot Mode(T2MS = 10b) and "Start High"(T2POL = 0b). Clear and Start Set T2EN Timer 2 clock Counter X T2ADRH/L M 0 1 2 3 4 5 6 7 8 M-1 0 T2 Interrupt 1. T2BDRH/L(5) < T2ADRH/L PWM2O B Match A Match 2. T2BDRH/L >= T2ADRH/L PWM2O A Match 3. T2BDRH/L = "0000H" PWM2O Figure 11.29 A Match Low Level 16-bit PPG Mode Timming chart for Timer 2 111 3 4 A94B114 ABOV Semiconductor Co., Ltd. 11.6.5 Block Diagram 16-bit A Data Register T2ADRH/T2ADRL A Match T2CC T2EN Reload T2CK[2:0] T2ECS Buffer Register A 3 EC2 Clear Edge Detector A Match P r e s c a l e r fx T2EN fx/1 To interrupt block IRQ1.6 Comparator fx/2 M U X fx/4 fx/8 fx/64 16-bit Counter T2CNTH/T2CNTL Clear B Match Comparator HFO Buffer Register B EIPOL1[5:4] 2 Reload T2CNTR EINT12 A Match T2CC T2EN Clear R fx/2048 2 16-bit B Data Register T2BDRH/T2BDRL Pulse Generator T2POL INT_ACK Clear T2MS[1:0] 16-bit Timer 2 Block Diagram Name Address Direction Default Description T2CRL C2H R/W 00H Timer 2 Control Low Register T2CRH C3H R/W 00H Timer 2 Control High Register T2ADRL C4H R/W FFH Timer 2 A Data Low Register T2ADRH C5H R/W FFH Timer 2 A Data High Register T2BDRL C6H R/W FFH Timer 2 B Data Low Register T2BDRH C7H R/W FFH Timer 2 B Data High Register Timer 2 Register Map 112 T2PE A Match T2CC T2EN 11.6.6 Register Map Table 11.9 T2O/ PWM2O 2 T2MS[1:0] IRQ.3 Figure 11.30 To other block INT_ACK To interrupt block A94B114 ABOV Semiconductor Co., Ltd. 11.6.7 Timer/Counter 2 Register Description The timer/counter 2 register consists of timer 2 A data high register (T2ADRH), timer 2 A data low register (T2ADRL), timer 2 B data high register (T2BDRH), timer 2 B data low register (T2BDRL), timer 2 control high register (T2CRH) and timer 2 control low register (T2CRL). 11.6.8 Register Description for Timer/Counter 2 T2ADRH (Timer 2 A data High Register) : C5H 7 6 5 4 3 2 1 0 T2ADRH7 T2ADRH6 T2ADRH5 T2ADRH4 T2ADRH3 T2ADRH2 T2ADRH1 T2ADRH0 R/W R/W R/W R/W R/W R/W R/W T2ADRH[7:0] R/W Initial value : FFH T2 A Data High Byte T2ADRL (Timer 2 A Data Low Register) : C4H 7 6 5 4 3 2 1 0 T2ADRL7 T2ADRL6 T2ADRL5 T2ADRL4 T2ADRL3 T2ADRL2 T2ADRL1 T2ADRL0 R/W R/W R/W R/W R/W R/W R/W T2ADRL[7:0] R/W Initial value : FFH T2 A Data Low Byte NOTE) Do not write “0000H” in the T2ADRH/T2ADRL register when PPG mode. T2BDRH (Timer 2 B Data High Register) : C7H 7 6 5 4 3 2 1 0 T2BDRH7 T2BDRH6 T2BDRH5 T2BDRH4 T2BDRH3 T2BDRH2 T2BDRH1 T2BDRH0 R/W R/W R/W R/W R/W R/W R/W T2BDRH[7:0] R/W Initial value : FFH T2 B Data High Byte T2BDRL (Timer 2 B Data Low Register) : C6H 7 6 5 4 3 2 1 0 T2BDRL7 T2BDRL6 T2BDRL5 T2BDRL4 T2BDRL3 T2BDRL2 T2BDRL1 T2BDRL0 R/W R/W R/W R/W R/W R/W R/W T2BDRL[7:0] T2 B Data Low 113 R/W Initial value : FFH A94B114 ABOV Semiconductor Co., Ltd. T2CRH (Timer 2 Control High Register) : C3H 7 6 5 4 3 2 1 0 T2EN – T2MS1 T2MS0 – – T2PE T2CC R/W – R/W R/W – – R/W T2EN T2MS[1:0] T2PE T2CC Control Timer 2 0 Timer 2 disable 1 Timer 2 enable (Counter clear and start) Control Timer 2 Operation Mode T2MS1 T2MS0 Description 0 0 Timer/counter mode (T2O: toggle at A match) 0 1 Capture mode (The A match interrupt can occur) 1 0 PPG one-shot mode (PWM2O) 1 1 PPG repeat mode (PWM2O) Control Timer 2 port output 0 Timer 2 output disable 1 Timer 2 output enable Clear Timer 2 Counter 0 No effect 1 Clear the Timer 2 counter (When write, automatically cleared “0” after being cleared counter) *NOTE) To use T2O/PWM2O as pin2(P10), set Sub-function and set it to Output Low. 114 R/W Initial value : 00H A94B114 ABOV Semiconductor Co., Ltd. T2CRL (Timer 2 Control Low Register) : C2H 7 6 5 4 3 2 1 0 T2CK2 T2CK1 T2CK0 T2IFR – T2POL T2ECE T2CNTR R/W R/W R/W R/W – R/W R/W T2CK[2:0] T2IFR T2POL T2ECE T2CNTR R/W Initial value : 00H Select Timer 2 clock source. fx is main system clock frequency T2CK2 T2CK1 T2CK0 Description 0 0 0 fx/2048 0 0 1 fx/64 0 1 0 fx/8 0 1 1 fx/4 1 0 0 fx/2 1 0 1 fx/1 1 1 0 HFO Direct (32MHz) 1 1 1 External clock (EC1) When T2 Match Interrupt occurs, this bit becomes ‘1’. For clearing bit, write ‘0’ to this bit or auto clear by INT_ACK signal. Writing “1” has no effect. 0 T2 interrupt no generation 1 T2 interrupt generation T2O/PWM2O Polarity Selection 0 Start High (T2O/PWM2O is low level at disable) 1 Start Low (T2O/PWM2O is high level at disable) Timer 2 External Clock Edge Selection 0 External clock falling edge 1 External clock rising edge Timer 2 Counter Read Control 0 No effect 1 Load the counter value to the B data register (When write, automatically cleared “0” after being loaded) 115 A94B114 11.7 ABOV Semiconductor Co., Ltd. 12-bit A/D Converter 11.7.1 Overview The analog-to-digital converter (A/D) allows conversion of an analog input signal to a corresponding 12-bit digital value. The A/D module has tenth analog inputs. The output of the multiplex is the input into the converter, which generates the result via successive approximation. The A/D module has four registers which are the control register ADCM (A/D Converter Mode Register), ADCM1 (A/D Converter Mode Register 1) and A/D result register ADCHR (A/D Converter Result High Register) and ADCLR (A/D Converter Result Low Register). It is selected for the corresponding channel to be converted by setting ADSEL[3:0]. To executing A/D conversion, ADST bit sets to ‘1’. The register ADCHR and ADCLR contains the results of the A/D conversion. When the conversion is completed, the result is loaded into the ADCHR and ADCLR, the A/D conversion status bit AFLAG is set to ‘1’, and the A/D interrupt is set. For processing A/D conversion, AFLAG bit is read as ‘0’. If using STBY (power down) bit, the ADC is disabled. After STBY bit is reset (ADC power enable) and it is restarted, during some cycle, ADC conversion value may have an inaccurate value. Also internal timer, external generating event, comparator and the timer can start ADC. At this time, interrupt enable of trigger sources is not required. If only the interrupt generation condition of each trigger source is satisfied, start adc. ADC Conversion Time = ADCLK * 60 cycles The A/D converter needs at least 20 μs for conversion time. So you must set the conversion time more than 20 μs. If the ADC conversion time is set short, the resolution is degraded. 11.7.2 Block Diagram Pre scaler SCLK ÷4 ÷8 ÷16 ÷32 Mux 12-bit A/D Converter Data Register ADCRH[7:0] (8bit) ADC Input Channel MUX AIN9 9 AIN8 8 . . . CKSEL[1:0] ADCLK [97 H] Comparator 2 1 AIN0 0 4 ADSEL[3:0] AVDD Mux ADST or Trigger Resistor Ladder Circuit LDO 2.5V Figure 11.31 Clear [96 H] Successive Approximation Circuit AIN1 ADST or EXTRG AFLAG . . . AIN2 LDOEN ADCRL[7:4] (4bit) 2 REFSEL ADC Block Diagram 116 ADIF ADC Interrupt A94B114 ABOV Semiconductor Co., Ltd. AN0 ~ AN9 Analog Input 0~1000pF Figure 11.32 A/D Analog Input Pin Connecting Capacitor 11.7.3 ADC Operation Align bit set "0" ADCO11 ADCO10 ADCO9 ADCO8 ADCO7 ADCO6 ADCO5 ADCO4 ADCRH7 ADCRH6 ADCRH5 ADCRH4 ADCRH3 ADCRH2 ADCRH1 ADCRH0 ADCO3 ADCO2 ADCO1 ADCO0 ADCRL7 ADCRL6 ADCRL5 ADCRL4 ADCRH[7:0] ADCRL[7:4] ADCRL[3:0] bit are "0" Align bit set "1" ADCO11 ADCO10 ADCO9 ADCO8 ADCRH3 ADCRH2 ADCRH1 ADCRH0 ADCO7 ADCO6 ADCO5 ADCO4 ADCO3 ADCO2 ADCO1 ADCO0 ADCRL7 ADCRL6 ADCRL5 ADCRL4 ADCRL3 ADCRL2 ADCRL1 ADCRL0 ADCRH[3:0] ADCRH[7:4] bit are "0" Figure 11.33 ADCRL[7:0] ADC Operation for Align bit 117 A94B114 ABOV Semiconductor Co., Ltd. SET ADCM1 SET ADCM Converting START N AFLAG = 1? Select ADC Clock & Data Align bit. ADC enable & Select AN Input Channel. Start ADC Conversion. (ADST=1 or External Trigger Matching) If Conversion is completed, AFLG is set “1” and ADC interrupt is occurred. Y READ ADCRH/L After Conversion is completed, read ADCRH and ADCRL. ADC END Figure 11.34 Converter Operation Flow 118 A94B114 ABOV Semiconductor Co., Ltd. 11.7.4 Register Map Name Address Direction Default Description ADCM 95H R/W 8FH A/D Converter Mode Register ADCM1 96H R/W 01H A/D Converter Mode 1 Register ADCRL 96H R xxH A/D Converter Result Low Register ADCRH 97H R xxH A/D Converter Result High Register Table 11.10 Register Map 11.7.5 Register Description for ADC The ADC Register consists of A/D Converter Mode Register (ADCM), A/D Converter Result High Register (ADCRH), A/D Converter Result Low Register (ADCRL), A/D Converter Mode 1 Register (ADCM1).. NOTE) When STBY bit is set to ‘1’, ADCM1 is read. If ADC enables, it is possible only to write ADCM1. When reading, ADCRL is read. 119 A94B114 ABOV Semiconductor Co., Ltd. ADCM (A/D Converter Mode Register) : 95H 7 6 5 4 3 2 1 0 STBY ADST REFSEL AFLAG ADSEL3 ADSEL2 ADSEL1 ADSEL0 R/W R/W R/W R R/W R/W R/W STBY ADST REFSEL AFLAG ADSEL[3:0] R/W Initial value : 8FH Control operation of A/D standby (power down) 0 ADC module enable 1 ADC module disable (power down) Control A/D Conversion stop/start. 0 ADC Conversion Stop 1 ADC Conversion Start A/D Converter reference selection 0 Internal Reference (VDD) 1 Internal LDO Reference (VLDO = 2.5V) A/D Converter operation state 0 During A/D Conversion 1 A/D Conversion finished A/D Converter input selection ADSEL3 ADSEL2 ADSEL1 ADSEL0 Description 0 0 0 0 Channel0(AN0) 0 0 0 1 Channel1(AN1) 0 0 1 0 Channel2(AN2) 0 0 1 1 Channel3(AN3) 0 1 0 0 Channel4(AN4) 0 1 0 1 Channel5(AN5) 0 1 1 0 Channel6(AN6) 0 1 1 1 Channel7(AN7) 1 0 0 0 Channel8(AN8) 1 0 0 1 Channel9(AN9) 1 0 1 0 reserved 1 0 1 1 reserved 1 1 0 0 reserved 1 1 0 1 reserved 1 1 1 0 reserved 1 1 1 1 reserved NOTE) 1. 2. When using ports as ADC input port, set corresponding PxFSRH, PxFSRL register to ADC input mode in order to open analog input switch and to prevent digital input. LDO : Low Drop Out 120 A94B114 ABOV Semiconductor Co., Ltd. ADCM1 (A/D Converter Mode Register) : 96H 7 6 5 4 3 2 1 0 EXTRG TSEL2 TSEL1 TSEL0 AMUXEN ALIGN CKSEL1 CKSEL0 R/W R/W R/W R/W R/W R/W R/W EXTRG TSEL[2:0] AMUXEN ALIGN CKSEL[1:0] NOTE) A/D external Trigger 0 External Trigger disable 1 External Trigger enable A/D Trigger Source selection TSEL2 TSEL1 TSEL0 Description 0 0 0 Ext. Interrupt 10 (P23) 0 0 1 Ext. Interrupt 11 (P03) 0 1 0 Ext. Interrupt 12 (P12) 0 1 1 - 1 0 0 Timer0 interrupt 1 0 1 Timer1 interrupt 1 1 0 Timer2 interrupt A/D analog input mux enable 0 AIN[15:0] channel disable(Floating) 1 AIN[15:0] channel enable A/D Converter data align selection. 0 MSB align (ADCRH[7:0], ADCRL[7:4]) 1 LSB align (ADCRH[3:0], ADCRL[7:0]) A/D Converter Clock selection CKSEL1 CKSEL0 ADC Clock 0 0 fx/4 0 1 fx/8 1 0 fx/16 1 1 fx/32 fx : system clock ADC clock should use below 3MHz 121 R/W Initial value : 01H A94B114 ABOV Semiconductor Co., Ltd. ADCRH (A/D Converter Result High Register) : 97H 7 6 5 4 3 2 1 0 ADDM11 ADDM10 ADDM9 ADDM8 ADDM7 ADDL11 ADDM6 ADDL10 ADDM5 ADDL9 ADDM4 ADDL8 R R R R R R R R Initial value : xxH ADDM[11:4] MSB align, A/D Converter High result (8-bit), default ADDL[11:8] LSB align, A/D Converter High result (4-bit) ADCRL (A/D Converter Result Low Register) : 96H 7 6 5 4 3 2 1 0 ADDM3 ADDL7 ADDM2 ADDL6 ADDM1 ADDL5 ADDM0 ADDL4 ADDL3 ADDL2 ADDL1 ADDL0 R R R R R R R R Initial value : xxH ADDM[3:0] MSB align, A/D Converter Low result (4-bit), default ADDL[7:0] LSB align, A/D Converter Low result (8-bit) 122 A94B114 11.8 ABOV Semiconductor Co., Ltd. Comparator 11.8.1 Overview The A9B114 contains analog comparators which can be easily used to compare the external input voltage with internally reference or externally reference voltage. ADC and Comparator have the same input. When the comparator input voltage is larger than the reference voltage comparator output status is ‘1’ and interrupt flag is generated. The Comparator interrupt flag is assigned to one interrupt vector. Comparator output debounce clock and length can be set. The internal reference of the comparator is the resistor distribution method. When AVDD is selected, the reference value is 5V. At this time, 1.6V and 2.2V can be selected as the internal reference voltage of the comparator. If AVDD is below 5V, the internal reference value is reduced at a constant rate. However, when Low Drop Out(LDO) is selected, 1.6V and 2.2V are normally selected as 2.5V reference. 11.8.2 Block Diagram CMP(P06) Ext. LDOEN CMPRE FE N LDO 2.5V Internal Reference 2.2V 1.6V Timer1 Complementary output Con tro l 2 AVDD CMPREFS[1:0] CMPPWRSEL COMPEN IRQ.0 + Debounce CMN1(P04) fx LFO (256kHz) CMPHY SEN CMP_DB_EN CMP_DB_CLK_SEL CMNS Comparator Block Diagram 11.8.3 Register map Name Address Direction Default Description CMPCR D6H R/W 01H Comparator Control Register CMPTR D7H R/W 00H Comparator Option Register CMPDBT DEH R/W 0FH Comparator Output de-bounce time Register LDOCR AAH R/W 00H LDO Control Register Table 11.11 Interrupt Request CMO(P07) CMPOUT CMN0(P05) Figure 11.35 PWM Output Register Map 123 A94B114 ABOV Semiconductor Co., Ltd. 11.8.4 Register Description for Comparator CMPCR (Comparator Control Register) : D6H 7 6 5 4 3 2 1 0 CMPEN CMPPWRSEL CMPREFS1 CMPREFS0 CMPREFEN CMNS CMPOF CMPF R/W R/W R/W R/W R/W R/W R/W CMPEN CMPPWRSEL CMPREFS[1:0] CMPREFEN CMNS CMPOF CMPF R Initial value : 01H Comparator block operation control 0 Comparator disable 1 Comparator enable Comparator reference power selection 0 LDO 2.5V 1 AVDD Comparator reference selection CMPREFS1 CMPREFS0 Description 0 0 Internal 1.6V 0 1 External PIN (P06) 1 0 Internal 2.2V 1 1 External PIN (P06) Comparator internal reference control 0 Internal reference disable 1 Internal reference enable Comparator input pin selection 0 CMN1 (P04) 1 CMN0 (P05) Comparator output selection 0 Output ‘H’ when CMP > CMN and Output ‘L’ when CMP < CMN 1 Output ‘H’ when CMP < CMN and Output ‘L’ when CMP > CMN Comparator output flag 0 Output ‘L’ 1 Output ‘H’ 124 A94B114 ABOV Semiconductor Co., Ltd. CMPTR (Comparator Option Register) : D7H 7 6 5 4 3 2 1 0 CMPHYSEN CMP_DB_EN – CMP_DB_CLK_SEL CMPEDGE1 CMPEDGE0 CMPPWMC1 CMPPWMC0 R/W R/W – R/W R/W R/W R/W CMPHYSEN CMP_DB_EN CMP_DB_CLK_SEL CMPEDGE[1:0] CMPPWMC[1:0] R/W Initial value : 00H Comparator block hysteresis operation control 0 Comparator hysteresis disable 1 Comparator hysteresis enable Comparator output de-bounce control 0 Output de-bounce disable 1 Output de-bounce enable Comparator output de-bounce clock source 0 fx (16MHz) 1 LFO (256kHz) Comparator interrupt trigger selection CMPEDGE1 CMPEDGE0 Description 0 0 Reserve 0 1 Rising edge trigger 1 0 Falling edge trigger 1 1 Both edge trigger Timer1 PWM output Control by comparator CMPPWMC1 CMPPWMC0 Description 0 0 Not controlled 0 1 PWM stop when comparator out ‘H’ 1 0 PWM stop when CMP > CMN 1 1 PWM stop when CMP < CMN 125 A94B114 ABOV Semiconductor Co., Ltd. CMPDBT (Comparator De-bounce Time Register) : DEH 7 6 5 4 3 2 1 0 – – – – CMPDBT3 CMPDBT2 CMPDBT1 CMPDBT0 – – – – R/W R/W R/W CMPDBT[3:0] R/W Initial value : 0FH Comparator output de-bounce time Select comparator output de-bounce length De-bounce length = CMPDBT x 2 x 1/fdbclk2 LDOCR (LDO Control Register) : AAH 7 6 5 4 3 2 1 0 – – – – – – DSCHGEN LDOEN – – – – – – R/W DSCHGEN LDOEN Note) LDO by pass mode 0 Disable 1 Enable LDO control 0 LDO disable 1 LDO enable LDO operating mode DSCHGEN_I LDOEN Description 0 0 LDO disable 0 1 Normal mode LDO output 2.5V 1 0 Bypass mode LDO output is bypass to AVDD 126 R/W Initial value : 00H A94B114 11.9 ABOV Semiconductor Co., Ltd. USART 11.9.1 Overview The Universal Synchronous and Asynchronous serial Receiver and Transmitter (USART) is a highly flexible serial communication device. The main features are listed below. - Full Duplex Operation (Independent Serial Receive and Transmit Registers) - Asynchronous or Synchronous Operation - Master or Slave Clocked Synchronous and SPI Operation - Supports all four SPI Modes of Operation (Mode 0, 1, 2, 3) - LSB First or MSB First Data Transfer @SPI mode - High Resolution Baud Rate Generator - Supports Serial Frames with 5,6,7,8, or 9 Data bits and 1 or 2 Stop bits - Odd or Even Parity Generation and Parity Check Supported by Hardware - Data OverRun Detection - Framing Error Detection - Digital Low Pass Filter - Three Separate Interrupts on TX Complete, TX Data Register Empty and RX Complete - Double Speed Asynchronous Communication Mode USART has three main parts of Clock Generator, Transmitter and Receiver. The Clock Generation logic consists of synchronization logic for external clock input used by synchronous or SPI slave operation, and the baud rate generator for asynchronous or master (synchronous or SPI) operation. The Transmitter consists of a single write buffer, a serial shift register, parity generator and control logic for handling different serial frame formats. The write buffer allows a continuous transfer of data without any delay between frames. The receiver is the most complex part of the USART module due to its clock and data recovery units. The recovery unit is used for asynchronous data reception. In addition to the recovery unit, the Receiver includes a parity checker, a shift register, a two level receive FIFO (UDATA) and control logic. The Receiver supports the same frame formats as the Transmitter and can detect Frame Error, Data OverRun and Parity Errors. 127 A94B114 ABOV Semiconductor Co., Ltd. 11.9.2 Block Diagram UBAUD SCLK Baud Rate Generator Master Clock Sync Logic XCK Control XCK UMSEL[1:0] RXD/ MISO M U X M U X Rx Interrupt RXC Rx Control Clock Recovery Data Recovery Receive Shift Register (RXSR) DOR/PE/FE Checker UDATA[0] (Rx) M U X UMSEL1&UMSEL0 Master Stop bit Generator D E P TXD/ MOSI D E P Parity Generator M U X Tx Control UDATA[1] (Rx) UPM0 Transmit Shift Register (TXSR) UMSEL0 M U X UPM1 UDATA(Tx) SS Control SS UMSEL1 UMSEL0 UPM1 UPM0 UCTRL2 UDRIE RXCIE WAKEIE TXE RXE USARTEN U2X ADDRESS : E2H INITIAL VALUE : 0000_0000B UCTRL3 MASTER LOOPS DISXCK SPISS - USBS TX8 RX8 ADDRESS : E3H INITIAL VALUE : 0000_-000B WAKE SOFTRST DOR FE PE ADDRESS : E4H INITIAL VALUE : 1000_0000B UDRE TXCIE TXC RXC USIZE2 USIZE1 USIZE0 UCPOL ADDRESS : E1H INITIAL VALUE : 0000_0000B UCTRL1 USTAT Figure 11.36 Tx Interrupt TXC USART Block Diagram 128 I n t e r n a l B u s L i n e A94B114 ABOV Semiconductor Co., Ltd. 11.9.3 Clock Generation UBAUD U2X fSCLK (UBAUD+1) Prescaling Up-Counter /8 /2 SCLK M U X txclk MASTER Sync Register Edge Detector UCPOL XCK Figure 11.37 M U X M U X /2 UMSEL0 M U X rxclk Clock Generation Block Diagram The Clock generation logic generates the base clock for the Transmitter and Receiver. The USART supports four modes of clock operation and those are Normal Asynchronous, Double Speed Asynchronous, Master Synchronous and Slave Synchronous. The clock generation scheme for Master SPI and Slave SPI mode is the same as Master Synchronous and Slave Synchronous operation mode. The UMSELn bit in UCTRL1 register selects between asynchronous and synchronous operation. Asynchronous Double Speed mode is controlled by the U2X bit in the UCTRL2 register. The MASTER bit in UCTRL2 register controls whether the clock source is internal (Master mode, output port) or external (Slave mode, input port). The XCK pin is only active when the USART operates in Synchronous or SPI mode. Table below contains equations for calculating the baud rate (in bps). Operating Mode Equation for Calculating Baud Rate Asynchronous Normal Mode (U2X=0) Baud Rate = fSCLK 16(UBAUDx + 1) Asynchronous Double Speed Mode (U2X=1) Baud Rate = fSCLK 8(UBAUDx + 1) Synchronous or SPI Master Mode Baud Rate = fSCLK 2(UBAUDx + 1) Table 11.12 Equations for Calculating Baud Rate Register Setting 129 A94B114 ABOV Semiconductor Co., Ltd. 11.9.4 External Clock (XCK) External clocking is used by the synchronous or SPI slave modes of operation. External clock input from the XCK pin is sampled by a synchronization logic to remove meta-stability. The output from the synchronization logic must then pass through an edge detector before it can be used by the Transmitter and Receiver. This process introduces a two CPU clock period delay and the maximum frequency of the external XCK pin is limited by the following equation. fXCK = fSCLK 4 Where fXCK is the frequency of XCK and fSCLK is the frequency of main system clock (SCLK). 11.9.5 Synchronous mode Operation When synchronous or SPI mode is used, the XCK pin will be used as either clock input (slave) or clock output (master). The dependency between the clock edges and data sampling or data change is the same. The basic principle is that data input on RXD (MISO in SPI mode) pin is sampled at the opposite XCK clock edge of the edge in the data output on TXD (MOSI in SPI mode) pin is changed. The UCPOL bit in UCTRL1 register selects which XCK clock edge is used for data sampling and which is used for data change. As shown in the figure below, when UCPOL is zero the data will be changed at XCK rising edge and sampled at XCK falling edge. UCPOL = 1 XCK TXD/RXD Sample UCPOL = 0 XCK TXD/RXD Sample Figure 11.38 Synchronous Mode XCKn Timing 130 A94B114 ABOV Semiconductor Co., Ltd. 11.9.6 Data format A serial frame is defined to be one character of data bits with synchronization bits (start and stop bits), and optionally a parity bit for error checking. The USART supports all 30 combinations of the following as valid frame formats. - 1 start bit - 5, 6, 7, 8 or 9 data bits - no, even or odd parity bit - 1 or 2 stop bits A frame starts with the start bit followed by the least significant data bit (LSB). Then the next data bits, up to a total of nine, are succeeding, ending with the most significant bit (MSB). If enabled the parity bit is inserted after the data bits, before the stop bits. A high to low transition on data pin is considered as start bit. When a complete frame is transmitted, it can be directly followed by a new frame, or the communication line can be set to an idle state. The idle means high state of data pin. The next figure shows the possible combinations of the frame formats. Bits inside brackets are optional. 1 data frame St Idle D0 D1 D2 D3 D4 [D5] [D6] [D7] [D8] [P] Sp1 [Sp2] Idle / St Character bits Figure 11.39 frame format 1 data frame consists of the following bits • Idle No communication on communication line (TxD/RxD) • St Start bit (Low) • Dn • Parity bit ------------ Even parity, Odd parity, No parity • Stop bit(s) ---------- 1 bit or 2 bits Data bits (0~8) The frame format used by the USART is set by the USIZE[2:0], UPM[1:0] and USBS bits in UCTRL1 register. The Transmitter and Receiver use the same setting. 11.9.7 Parity bit The parity bit is calculated by doing an exclusive-or of all the data bits. If odd parity is used, the result of the exclusiveor is inverted. The parity bit is located between St + bits and first stop bit of a serial frame. Peven = Dn-1 ^ … ^ D3 ^ D2 ^ D1 ^ D0 ^ 0 Podd = Dn-1 ^ … ^ D3 ^ D2 ^ D1 ^ D0 ^ 1 Peven : Parity bit using even parity Podd : Parity bit using odd parity Dn : Data bit n of the character 131 A94B114 ABOV Semiconductor Co., Ltd. 11.9.8 USART Transmitter The USART Transmitter is enabled by setting the TXE bit in UCTRL1 register. When the Transmitter is enabled, the normal port operation of the TXD pin is overridden by the serial output pin of USART. The baud-rate, operation mode and frame format must be setup once before doing any transmissions. If synchronous or SPI operation is used, the clock on the XCK pin will be overridden and used as transmission clock. If USART operates in SPI mode, SS pin is used as SS input pin in slave mode or can be configured as SS output pin in master mode. This can be done by setting SPISS bit in UCTRL3 register. 11.9.8.1 Sending Tx data A data transmission is initiated by loading the transmit buffer (UDATA register I/O location) with the data to be transmitted. The data written in transmit buffer is moved to the shift register when the shift register is ready to send a new frame. The shift register is loaded with the new data if it is in idle state or immediately after the last stop bit of the previous frame is transmitted. When the shift register is loaded with new data, it will transfer one complete frame at the settings of control registers. If the 9-bit characters are used in asynchronous or synchronous operation mode (USIZE[2:0]=7), the ninth bit must be written to the TX8 bit in UCTRL3 register before loading transmit buffer (UDATA register). 11.9.8.2 Transmitter flag and interrupt The USART Transmitter has 2 flags which indicate its state. One is USART Data Register Empty (UDRE) and the other is Transmit Complete (TXC). Both flags can be used as interrupt sources. UDRE flag indicates whether the transmit buffer is ready to be loaded with new data. This bit is set when the transmit buffer is empty and cleared when the transmit buffer contains transmittion data which has not yet been moved into the shift register. And also this flag can be cleared by writing ‘0’ to this bit position. Writing ‘1’ to this bit position is not valid. When the Data Register Empty Interrupt Enable (UDRIE) bit in UCTRL2 register is set and the Global Interrupt is enabled, USART Data Register Empty Interrupt is generated while UDRE flag is set. The Transmit Complete (TXC) flag bit is set when the entire frame in the transmit shift register has been shifted out and there are no more data in the transmit buffer. The TXC flag is automatically cleared when the Transmit Complete Interrupt service routine is executed, or it can be cleared by writing ‘0’ to TXC bit in USTAT register. When the Transmit Complete Interrupt Enable (TXCIE) bit in UCTRL2 register is set and the Global Interrupt is enabled, USART Transmit Complete Interrupt is generated while TXC flag is set. 11.9.8.3 Parity Generator The Parity Generator calculates the parity bit for the sending serial frame data. When parity bit is enabled (UPM[1]=1), the transmitter control logic inserts the parity bit between the bits and the first stop bit of the sending frame. 132 A94B114 11.9.8.4 ABOV Semiconductor Co., Ltd. Disabling Transmitter Disabling the Transmitter by clearing the TXE bit will not become effective until ongoing transmission is completed. When the Transmitter is disabled, the TXD pin is used as normal General Purpose I/O (GPIO) or primary function pin. 11.9.9 USART Receiver The USART Receiver is enabled by setting the RXE bit in the UCTRL1 register. When the Receiver is enabled, the normal pin operation of the RXD pin is overridden by the USART as the serial input pin of the Receiver. The baud-rate, mode of operation and frame format must be set before serial reception. If synchronous or SPI operation is used, the clock on the XCK pin will be used as transfer clock. If USART operates in SPI mode, SS pin is used as SS input pin in slave mode or can be configured as SS output pin in master mode. This can be done by setting SPISS bit in UCTRL3 register. 11.9.9.1 Receiving Rx data When USART is in synchronous or asynchronous operation mode, the Receiver starts data reception when it detects a valid start bit (LOW) on RXD pin. Each bit after start bit is sampled at pre-defined baud-rate (asynchronous) or sampling edge of XCK (synchronous), and shifted into the receive shift register until the first stop bit of a frame is received. Even if there’s 2nd stop bit in the frame, the 2nd stop bit is ignored by the Receiver. That is, receiving the first stop bit means that a complete serial frame is present in the receiver shift register and contents of the shift register are to be moved into the receive buffer. The receive buffer is read by reading the UDATA register. If 9-bit characters are used (USIZE[2:0] = 7), the ninth bit is stored in the RX8 bit position in the UCTRL3 register. The 9th bit must be read from the RX8 bit before reading the low 8 bits from the UDATA register. Likewise, the error flags FE, DOR, PE must be read before reading the data from UDATA register. This is because the error flags are stored in the same FIFO position of the receive buffer. 11.9.9.2 Receiver flag and interrupt The USART Receiver has one flag that indicates the Receiver state. The Receive Complete (RXC) flag indicates whether there are unread data present in the receive buffer. This flag is set when there are unread data in the receive buffer and cleared when the receive buffer is empty. If the Receiver is disabled (RXE=0), the receiver buffer is flushed and the RXC flag is cleared. When the Receive Complete Interrupt Enable (RXCIE) bit in the UCTRL2 register is set and Global Interrupt is enabled, the USART Receiver Complete Interrupt is generated while RXC flag is set. The USART Receiver has three error flags which are Frame Error (FE), Data OverRun (DOR) and Parity Error (PE). These error flags can be read from the USTAT register. As data received are stored in the 2-level receive buffer, these error flags are also stored in the same position of receive buffer. So, before reading received data from UDATA register, read the USTAT register first which contains error flags. 133 A94B114 ABOV Semiconductor Co., Ltd. The Frame Error (FE) flag indicates the state of the first stop bit. The FE flag is set when the stop bit was correctly detected as “1”, and the FE flag is cleared when the stop bit was incorrect, ie detected as “0”. This flag can be used for detecting out-of-sync conditions between data frames. The Data OverRun (DOR) flag indicates data loss due to a receive buffer full condition. A DOR occurs when the receive buffer is full, and another new data is present in the receive shift register which are to be stored into the receive buffer. After the DOR flag is set, all the incoming data are lost. To prevent data loss or clear this flag, read the receive buffer. The Parity Error (PE) flag indicates that the frame in the receive buffer had a Parity Error when received. If Parity Check function is not enabled (UPM[1]=0), the PE bit is always read “0”. NOTE) The error flags related to receive operation are not used when USART is in SPI mode. 11.9.9.3 Parity Checker If Parity bit is enabled (UPM[1]=1), the Parity Checker calculates the parity of the data bits in incoming frame and compares the result with the parity bit from the received serial frame. 11.9.9.4 Disabling Receiver In contrast to Transmitter, disabling the Receiver by clearing RXE bit makes the Receiver inactive immediately. When the Receiver is disabled the Receiver flushes the receive buffer and the remaining data in the buffer is all reset. The RXD pin is not overridden the function of USART, so RXD pin becomes normal GPIO or primary function pin. 11.9.9.5 Asynchronous Data Reception To receive asynchronous data frame, the USART includes a clock and data recovery unit. The Clock Recovery logic is used for synchronizing the internally generated baud-rate clock to the incoming asynchronous serial frame on the RXD pin. The Data recovery logic samples incoming bits and low pass filters them, and this removes the noise of RXD pin. The next figure illustrates the sampling process of the start bit of an incoming frame. The sampling rate is 16 times the baud-rate for normal mode, and 8 times the baud rate for Double Speed mode (U2X=1). The horizontal arrows show the synchronization variation due to the asynchronous sampling process. Note that larger time variation is shown when using the Double Speed mode. RxD START IDLE BIT0 Sample (U2X = 0) 0 0 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 1 2 3 Sample (U2X = 1) 0 Figure 11.40 1 2 3 4 5 6 Start bit Sampling 134 7 8 1 2 A94B114 ABOV Semiconductor Co., Ltd. When the Receiver is enabled (RXE=1), the clock recovery logic tries to find a high to low transition on the RXD line, the start bit condition. After detecting high to low transition on RXD line, the clock recovery logic uses samples 8,9, and 10 for Normal mode, and samples 4, 5, and 6 for Double Speed mode to decide if a valid start bit is received. If more than 2 samples have logical low level, it is considered that a valid start bit is detected and the internally generated clock is synchronized to the incoming data frame. And the data recovery can begin. The synchronization process is repeated for each start bit. As described above, when the Receiver clock is synchronized to the start bit, the data recovery can begin. Data recovery process is almost similar to the clock recovery process. The data recovery logic samples 16 times for each incoming bits for Normal mode and 8 times for Double Speed mode. And uses sample 8, 9, and 10 to decide data value for Normal mode, samples 4, 5, and 6 for Double Speed mode. If more than 2 samples have low levels, the received bit is considered to a logic 0 and more than 2 samples have high levels, the received bit is considered to a logic 1. The data recovery process is then repeated until a complete frame is received including the first stop bit. The decided bit value is stored in the receive shift register in order. Note that the Receiver only uses the first stop bit of a frame. Internally, after receiving the first stop bit, the Receiver is in idle state and waiting to find start bit. BIT n RxD Sample (U2X = 0) 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 1 Sample (U2X = 1) 1 Figure 11.41 2 3 4 5 6 7 8 1 Sampling of Data and Parity bit The process for detecting stop bit is like clock and data recovery process. That is, if 2 or more samples of 3 center values have high level, correct stop bit is detected, else a Frame Error flag is set. After deciding first stop bit whether a valid stop bit is received or not, the Receiver enters into idle state and monitors the RXD line to check a valid high to low transition is detected (start bit detection). STOP 1 RxD (A) (B) Sample (U2X = 0) 1 2 3 4 5 6 7 8 9 10 11 12 13 Sample (U2X = 1) 1 Figure 11.42 2 3 4 5 6 Stop bit Sampling and Next Start bit Sampling 135 7 (C) A94B114 ABOV Semiconductor Co., Ltd. 11.9.10 SPI Mode The USART can be set to operate in industrial standard SPI compliant mode. The SPI mode has the following features. - Full duplex, three-wire synchronous data transfer - Master or Slave operation - Supports all four SPI modes of operation (mode0, 1, 2, and 3) - Selectable LSB first or MSB first data transfer - Double buffered transmit and receive - Programmable transmit bit rate When SPI mode is enabled (UMSEL[1:0]=3), the Slave Select (SS) pin becomes active low input in slave mode operation, or can be output in master mode operation if SPISS bit is set. Note that during SPI mode of operation, the pin RXD is renamed as MISO and TXD is renamed as MOSI for compatibility to other SPI devices. 11.9.10.1 SPI Clock formats and timing To accommodate a wide variety of synchronous serial peripherals from different manufacturers, the USART has a clock polarity bit (UCPOL) and a clock phase control bit (UCPHA) to select one of four clock formats for data transfers. UCPOL selectively insert an inverter in series with the clock. UCPHA selects one of two different clock phase relationships between the clock and data. Note that UCPHA and UCPOL bits in UCTRL1 register have different meanings according to the UMSEL[1:0] bits which decides the operating mode of USART. Table below shows four combinations of UCPOL and UCPHA for SPI mode 0, 1, 2, and 3. SPI Mode UCPOL UCPHA Leading Edge Trailing Edge 0 0 0 Sample (Rising) Setup (Falling) 1 0 1 Setup (Rising) Sample (Falling) 2 1 0 Sample (Falling) Setup (Rising) 3 1 1 Setup (Falling) Sample (Rising) Table 11.13 CPOL Functionality 136 A94B114 ABOV Semiconductor Co., Ltd. XCK (UCPOL=0) XCK (UCPOL=1) SAMPLE MOSI MSB First LSB First BIT7 BIT0 BIT6 BIT1 … … BIT2 BIT5 BIT1 BIT6 BIT0 BIT7 MISO /SS OUT (MASTER) /SS IN (SLAVE) Figure 11.43 SPI Clock Formats when UCPHA=0 When UCPHA=0, the slave begins to drive its MISO output with the first data bit value when SS goes to active low. The first XCK edge causes both the master and the slave to sample the data bit value on their MISO and MOSI inputs, respectively. At the second XCK edge, the USART shifts the second data bit value out to the MOSI and MISO outputs of the master and slave, respectively. Unlike the case of UCPHA=1, when UCPHA=0, the slave’s SS input must go to its inactive high level between transfers. This is because the slave can prepare the first data bit when it detects falling edge of SS input. XCK (UCPOL=0) XCK (UCPOL=1) SAMPLE MOSI MSB First LSB First BIT7 BIT0 BIT6 BIT1 … … MISO /SS OUT (MASTER) /SS IN (SLAVE) Figure 11.44 SPI Clock Formats when UCPHA=1 137 BIT2 BIT5 BIT1 BIT6 BIT0 BIT7 A94B114 ABOV Semiconductor Co., Ltd. When UCPHA=1, the slave begins to drive its MISO output when SS goes active low, but the data is not defined until the first XCK edge. The first XCK edge shifts the first bit of data from the shifter onto the MOSI output of the master and the MISO output of the slave. The next XCK edge causes both the master and slave to sample the data bit value on their MISO and MOSI inputs, respectively. At the third XCK edge, the USART shifts the second data bit value out to the MOSI and MISO output of the master and slave respectively. When UCPHA=1, the slave’s SS input is not required to go to its inactive high level between transfers. Because the SPI logic reuses the USART resources, SPI mode of operation is similar to that of synchronous or asynchronous operation. An SPI transfer is initiated by checking for the USART Data Register Empty flag (UDRE=1) and then writing a byte of data to the UDATA Register. In master mode of operation, even if transmission is not enabled (TXE=0), writing data to the UDATA register is necessary because the clock XCK is generated from transmitter block. 11.9.11 Register Map Name Address Direction Default Description UCTRL1 E1H R/W 00H USART Control 1 Register UCTRL2 E2H R/W 00H USART Control 2 Register UCTRL3 E3H R/W 00H USART Control 3 Register UCTRL4 EBH R/W 00H USART Control 4 Register USTAT E4H R 80H USART Status Register UBAUD E5H R/W FFH USART Baud Rate Generation Register UDATA E6H R/W 00H USART Data Register FPCR ECH R/W 00H USART Floating Point Counter Register Table 11.14 USART Register Map 11.9.12 USART Register Description USART module consists of USART Control 1 Register (UCTRL1), USART Control 2 Register (UCTRL2), USART Control 3 Register (UCTRL3), USART Control 4 Register (UCTRL4), USART Floaint Point Counter (FPCR), USART Status Register (USTAT), USART Data Register (UDATA), and USART Baud Rate Generation Register (UBAUD). 138 A94B114 ABOV Semiconductor Co., Ltd. 11.9.13 Register Description for USART UCTRL1 (USART Control 1 Register) E1H 7 6 5 4 3 2 1 0 UMSEL1 UMSEL0 UPM1 UPM0 USIZE2 USIZE1 UDORD USIZE0 UCPHA UCPOL R/W R/W R/W R/W R/W R/W R/W UMSEL[1:0] Selects operation mode of USART UPM[1:0] USIZE[2:0] UDORD UCPOL UCPHA UMSEL1 UMSEL0 Operating Mode 0 0 Asynchronous Mode (Normal Uart) 0 1 Synchronous Mode (Synchronous Uart) 1 0 Reserved 1 1 SPI Mode R/W Initial value : 00H Selects Parity Generation and Check methods UPM1 UPM0 Parity mode 0 0 No Parity 0 1 Reserved 1 0 Even Parity 1 1 Odd Parity When in asynchronous or synchronous mode of operation, selects the length of data bits in frame. USIZE2 USIZE1 USIZE0 Data length 0 0 0 5-bit 0 0 1 6-bit 0 1 0 7-bit 0 1 1 8-bit 1 0 0 Reserved 1 0 1 Reserved 1 1 0 Reserved 1 1 1 9-bit This bit is in the same bit position with USIZE1. In SPI mode, when set to one the MSB of the data byte is transmitted first. When set to zero the LSB of the data byte is transmitted first. 0 LSB First 1 MSB First Selects polarity of XCK in synchronous or SPI mode 0 TXD change @Rising Edge, RXD change @Falling Edge 1 TXD change @ Falling Edge, RXD change @ Rising Edge This bit is in the same bit position with USIZE0. In SPI mode, along with UCPOL bit, selects one of two clock formats for different kinds of synchronous serial peripherals. Leading edge means first XCK edge and trailing edge means 2nd or last clock edge of XCK in one XCK pulse. And Sample means detecting of incoming receive bit, Setup means preparing transmit data. UCPOL UCPHA Leading Edge Trailing Edge 0 0 Sample (Rising) Setup (Falling) 0 1 Setup (Rising) Sample (Falling) 1 0 Sample (Falling) Setup (Rising) 1 1 Setup (Falling) Sample (Rising) 139 A94B114 ABOV Semiconductor Co., Ltd. UCTRL2 (USART Control 2 Register) E2H 7 6 5 4 3 2 1 0 UDRIE TXCIE RXCIE WAKEIE TXE RXE USARTEN U2X R/W R/W R/W R/W R/W R/W R/W R/W Initial value : 00H UDRIE TXCIE RXCIE WAKEIE TXE RXE USARTEN U2X Interrupt enable bit for USART Data Register Empty. 0 Interrupt from UDRE is inhibited (use polling) 1 When UDRE is set, request an interrupt Interrupt enable bit for Transmit Complete. 0 Interrupt from TXC is inhibited (use polling) 1 When TXC is set, request an interrupt Interrupt enable bit for Receive Complete 0 Interrupt from RXC is inhibited (use polling) 1 When RXC is set, request an interrupt Interrupt enable bit for Asynchronous Wake in STOP mode. When device is in stop mode, if RXD goes to LOW level an interrupt can be requested to wake-up system. 0 Interrupt from Wake is inhibited 1 When WAKE is set, request an interrupt Enables the transmitter unit. 0 Transmitter is disabled 1 Transmitter is enabled Enables the receiver unit. 0 Receiver is disabled 1 Receiver is enabled Activate USART module by supplying clock. 0 USART is disabled (clock is halted) 1 USART is enabled This bit only has effect for the asynchronous operation and selects receiver sampling rate. 0 Normal asynchronous operation 1 Double Speed asynchronous operation 140 A94B114 ABOV Semiconductor Co., Ltd. UCTRL3 (USART Control 3 Register) E3H 7 6 5 4 3 2 MASTER LOOPS DISXCK SPISS - R/W R/W R/W R/W - MASTER LOOPS DISXCK SPISS USBS TX8 RX8 1 0 USBS TX8 RX8 R/W R/W R/W Initial value : 00H Selects master or slave in SPI or Synchronous mode operation and controls the direction of XCK pin. 0 Slave mode operation and XCK is input pin. 1 Master mode operation and XCK is output pin Controls the Loop Back mode of USART, for test mode 0 Normal operation 1 Loop Back mode In Synchronous mode of operation, selects the waveform of XCK output. 0 XCK is free-running while USART is enabled in synchronous master mode. 1 XCK is active while any frame is on transferring. Controls the functionality of SS pin in master SPI mode. 0 SS pin is normal GPIO or other primary function 1 SS output to other slave device Selects the length of stop bit in Asynchronous or Synchronous mode of operation. 0 1 Stop bit 1 2 Stop bit The ninth bit of data frame in Asynchronous or Synchronous mode of operation. Write this bit first before loading the UDATA register. 0 MSB (9th bit) to be transmitted is ‘0’ 1 MSB (9th bit) to be transmitted is ‘1’ The ninth bit of data frame in Asynchronous or Synchronous mode of operation. Read this bit first before reading the receive buffer. 0 MSB (9th bit) received is ‘0’ 1 MSB (9th bit) received is ‘1’ UCTRL4 (USART Control 4 Register) EBH 7 6 5 4 3 2 1 0 - - - - - FPCREN AOVSSEL AOVSEN - - - - - R/W R/W R/W Initial value : 00H FPCREN AOVSEN AOVSSEL Enable baud rate compensation 0 Disable 1 Enable Enable additional oversampling rates selection 0 Disable 1 Enable Select additional oversampling rates 0 Select X13 1 Select X4 141 A94B114 ABOV Semiconductor Co., Ltd. USTAT (USART Status Register) E4H 7 6 5 4 3 2 1 0 UDRE TXC RXC WAKE SOFTRST DOR FE PE R/W R/W R/W R/W R/W R R R Initial value : 80H UDRE TXC RXC WAKE SOFTRST DOR FE PE The UDRE flag indicates if the transmit buffer (UDATA) is ready to be loaded with new data. If UDRE is ‘1’, it means the transmit buffer is empty and can hold one or two new data. This flag can generate an UDRE interrupt. Writing ‘0’ to this bit position will clear UDRE flag. 0 Transmit buffer is not empty. 1 Transmit buffer is empty. This flag is set when the entire frame in the transmit shift register has been shifted out and there is no new data currently present in the transmit buffer. This flag is automatically cleared when the interrupt service routine of a TXC interrupt is executed. It is also cleared by writing ‘0’ to this bit position. This flag can generate a TXC interrupt. 0 Transmission is ongoing. 1 Transmit buffer is empty and the data in transmit shift register are shifted out completely. This flag is set when there are unread data in the receive buffer and cleared when all the data in the receive buffer are read. The RXC flag can be used to generate a RXC interrupt. 0 There is no data unread in the receive buffer 1 There are more than 1 data in the receive buffer This flag is set when the RX pin is detected low while the CPU is in stop mode. This flag can be used to generate a WAKE interrupt. This bit is set only when in asynchronous mode of operation. NOTE 0 No WAKE interrupt is generated. 1 WAKE interrupt is generated. This is an internal reset and only has effect on USART. Writing ‘1’ to this bit initializes the internal logic of USART and is auto cleared. 0 No operation 1 Reset USART This bit is set if a Data OverRun occurs. While this bit is set, the incoming data frame is ignored. This flag is valid until the receive buffer is read. 0 No Data OverRun 1 Data OverRun detected This bit is set if the first stop bit of next character in the receive buffer is detected as ‘0’. This bit is valid until the receive buffer is read. 0 No Frame Error 1 Frame Error detected This bit is set if the next character in the receive buffer has a Parity Error when received while Parity Checking is enabled. This bit is valid until the receive buffer is read. 0 No Parity Error 1 Parity Error detected NOTE) When the WAKE function of USART is used as a release source from STOP mode, it is required to clear this bit in the RX interrupt service routine. Else the device will not wake-up from STOP mode again by the change of RX pin. 142 A94B114 ABOV Semiconductor Co., Ltd. UBAUD (USART Baud-Rate Generation Register) E5H 7 6 5 4 3 2 1 0 UBAUD7 UBAUD6 UBAUD5 UBAUD4 UBAUD3 UBAUD2 UBAUD1 UBAUD0 R/W R/W R/W R/W R/W R/W R/W R/W Initial value : FFH UBAUD [7:0] The value in this register is used to generate internal baud rate in asynchronous mode or to generate XCK clock in synchronous or SPI mode. To prevent malfunction, do not write ‘0’ in asynchronous mode, and do not write ‘0’ or ‘1’ in synchronous or SPI mode. UDATA (USART Data Register) E6H 7 6 5 4 3 2 1 0 UDATA7 UDATA6 UDATA 5 UDATA 4 UDATA 3 UDATA 2 UDATA 1 UDATA 0 R/W R/W R/W R/W R/W R/W R/W R/W Initial value : 00H UDATA [7:0] The USART Transmit Buffer and Receive Buffer share the same I/O address with this DATA register. The Transmit Data Buffer is the destination for data written to the UDATA register. Reading the UDATA register returns the contents of the Receive Buffer. Write this register only when the UDRE flag is set. In SPI or synchronous master mode, write this register even if TX is not enabled to generate clock, XCK. FPCR (USART Floating Point Register) ECH 7 6 5 4 3 2 1 0 FPCR7 FPCR6 FPCR5 FPCR4 FPCR3 FPCR2 FPCR1 FPCR0 R/W R/W R/W R/W R/W R/W R/W R/W Initial value : 00H FPCR [7:0] USART Floating Point Counter 8-bit floating point counter NOTE) BAUD RATE compensation can be used in the following ways: Example1) Condition : sysclk = 16MHz, Baud rate = 9600 bps, Asynchronous Normal Mode (U2X = 0) Baud rate = sysclk / 16 x (UBAUD + 1) Calculated UBAUD = (1000000 / Target Baud rate) – 1 = 103.17, Error rate = 0.17 ⇒ UBAUD = 104 UCTRL4 = 0x04, Enable baudrate Compensation Calculated FPCR = (UBAUD - Calculated UBAUD ) x 256 = (104 – 103.17) x 256 = 212.48 ⇒ FPCR = 213 Example2) Condition : sysclk = 16MHz, Baud rate = 115,200 bps, Asynchronous Normal Mode (U2X = 0) Baud rate = sysclk / 16 x (UBAUD + 1) Calculated UBAUD = (1000000 / Target Baud rate) – 1 = 7.68, Error rate = 0.68 ⇒ UBAUD = 8 UCTRL4 = 0x04, Enable baudrate Compensation Calculated FPCR = (UBAUD - Calculated UBAUD ) x 256 = (8 – 7.68) x 256 = 81.92 ⇒ FPCR = 82 143 A94B114 ABOV Semiconductor Co., Ltd. 11.9.14 Baud Rate setting (example) fOSC=1.00MHz Baud Rate U2X=0 fOSC=1.8432MHz U2X=1 U2X=0 fOSC=2.00MHz U2X=1 U2X=0 U2X=1 UBAUD ERROR UBAUD ERROR UBAUD ERROR UBAUD ERROR UBAUD ERROR UBAUD ERROR 2400 25 0.2% 51 0.2% 47 0.0% 95 0.0% 51 0.2% 103 0.2% 4800 12 0.2% 25 0.2% 23 0.0% 47 0.0% 25 0.2% 51 0.2% 9600 6 -7.0% 12 0.2% 11 0.0% 23 0.0% 12 0.2% 25 0.2% 14.4K 3 8.5% 8 -3.5% 7 0.0% 15 0.0% 8 -3.5% 16 2.1% 19.2K 2 8.5% 6 -7.0% 5 0.0% 11 0.0% 6 -7.0% 12 0.2% 28.8K 1 8.5% 3 8.5% 3 0.0% 7 0.0% 3 8.5% 8 -3.5% 38.4K 1 -18.6% 2 8.5% 2 0.0% 5 0.0% 2 8.5% 6 -7.0% 57.6K - - 1 8.5% 1 -25.0% 3 0.0% 1 8.5% 3 8.5% 76.8K - - 1 -18.6% 1 0.0% 2 0.0% 1 -18.6% 2 8.5% 115.2K - - - - - - 1 0.0% - - 1 8.5% 230.4K - - - - - - - - - - - - fOSC=3.6864MHz Baud Rate U2X=0 fOSC=4.00MHz U2X=1 U2X=0 fOSC=7.3728MHz U2X=1 U2X=0 U2X=1 UBAUD ERROR UBAUD ERROR UBAUD ERROR UBAUD ERROR UBAUD ERROR UBAUD 2400 95 0.0% 191 0.0% 103 0.2% 207 0.2% 191 0.0% - ERROR - 4800 47 0.0% 95 0.0% 51 0.2% 103 0.2% 95 0.0% 191 0.0% 9600 23 0.0% 47 0.0% 25 0.2% 51 0.2% 47 0.0% 95 0.0% 14.4K 15 0.0% 31 0.0% 16 2.1% 34 -0.8% 31 0.0% 63 0.0% 19.2K 11 0.0% 23 0.0% 12 0.2% 25 0.2% 23 0.0% 47 0.0% 28.8K 7 0.0% 15 0.0% 8 -3.5% 16 2.1% 15 0.0% 31 0.0% 38.4K 5 0.0% 11 0.0% 6 -7.0% 12 0.2% 11 0.0% 23 0.0% 57.6K 3 0.0% 7 0.0% 3 8.5% 8 -3.5% 7 0.0% 15 0.0% 76.8K 2 0.0% 5 0.0% 2 8.5% 6 -7.0% 5 0.0% 11 0.0% 115.2K 1 0.0% 3 0.0% 1 8.5% 3 8.5% 3 0.0% 7 0.0% 230.4K - - 1 0.0% - - 1 8.5% 1 0.0% 3 0.0% 250K - - 1 -7.8% - - 1 0.0% 1 -7.8% 3 -7.8% 0.5M - - - - - - - - - - 1 -7.8% fOSC=8.00MHz Baud Rate U2X=0 fOSC=11.0592MHz U2X=1 U2X=0 fOSC=14.7456MHz U2X=1 U2X=0 U2X=1 UBAUD ERROR UBAUD ERROR UBAUD ERROR UBAUD ERROR UBAUD ERROR UBAUD ERROR 2400 207 0.2% - - - - - - - - - - 4800 103 0.2% 207 0.2% 143 0.0% - - 191 0.0% - - 9600 51 0.2% 103 0.2% 71 0.0% 143 0.0% 95 0.0% 191 0.0% 14.4K 34 -0.8% 68 0.6% 47 0.0% 95 0.0% 63 0.0% 127 0.0% 19.2K 25 0.2% 51 0.2% 35 0.0% 71 0.0% 47 0.0% 95 0.0% 28.8K 16 2.1% 34 -0.8% 23 0.0% 47 0.0% 31 0.0% 63 0.0% 38.4K 12 0.2% 25 0.2% 17 0.0% 35 0.0% 23 0.0% 47 0.0% 57.6K 8 -3.5% 16 2.1% 11 0.0% 23 0.0% 15 0.0% 31 0.0% 76.8K 6 -7.0% 12 0.2% 8 0.0% 17 0.0% 11 0.0% 23 0.0% 115.2K 3 8.5% 8 -3.5% 5 0.0% 11 0.0% 7 0.0% 15 0.0% 230.4K 1 8.5% 3 8.5% 2 0.0% 5 0.0% 3 0.0% 7 0.0% 250K 1 0.0% 3 0.0% 2 -7.8% 5 -7.8% 3 -7.8% 6 5.3% 0.5M - - 1 0.0% - - 2 -7.8% 1 -7.8% 3 -7.8% 1M - - - - - - - - - - 1 -7.8% Table 11.15 Examples of UBAUD Settings for Commonly Used Oscillator Frequencies 144 A94B114 ABOV Semiconductor Co., Ltd. 11.9.15 0% Error Baud Rate This USART system supports the floating point counter logic for the 0% error of baud rate. By using the 8bits floating point counter logic, the cumulative error to below the decimal point can be removed. The floating point counter value is defined by baud rate error. In the baud rate formula, BAUD is presented the integer count value. For example, If you want to use the 57600 baud rate (fXIN = 16MHz), integer count value must be 16.36 value (BAUD+1 = 16000000/(16×57600) = 17.36). Here, the accurate BAUD value is 16.36. To realize 0% error of baud rate, floating point counter value must be 164 ((17-16.36) x 256 ≒ 164) and BAUD value must be 17. Namely you have to write the 164(decimal number) in USART_FPCR and 17(decimal number) in USART_BAUD. Integer count value Integer count value - 1 0 1 8bit Max floating point count value 8bit floating point counter Figure 11.45 0% Error Baud Rate Block Diagram 145 TXD clock 0% Error generator Baud rate A94B114 ABOV Semiconductor Co., Ltd. 11.10 I2C 11.10.1 Overview The I2C is one of industrial standard serial communication protocols, and which uses 2 bus lines Serial Data Line (SDA) and Serial Clock Line (SCL) to exchange data. Because both SDA and SCL lines are open-drain output, each line needs pull-up resistor. The features are as shown below. - Compatible with I2C bus standard - Multi-master operation - Up to 400kHz data transfer speed - 7-bit address - Support two slave addresses - Both master and slave operation - Bus busy detection 11.10.2 Block Diagram Slave Addr. Register (I2CSAR) Debounce enable SDA Noise Canceller (debounce) 1 Slave Addr. Register1 (I2CSAR1) SDAIN 0 SDAOUT F/F 8-bit Shift Register (SHFTR) SDA Out Controller Data Out Register (I2CDR) Debounce enable SCL High Period Register (I2CSCLHR) SCLIN SCL Noise Canceller (debounce) 1 SCL Out Controller 0 SDA Hold Time Register (I2CDAHR) SCLOUT Figure 11.46 SCL Low Period Register (I2CSCLLR) I2C Block Diagram 146 I n t e r n a l B u s L i n e A94B114 ABOV Semiconductor Co., Ltd. 11.10.3 I2C bit Transfer The data on the SDA line must be stable during HIGH period of the clock, SCL. The HIGH or LOW state of the data line can only change when the clock signal on the SCL line is LOW. The exceptions are START(S), repeated START(Sr) and STOP(P) condition where data line changes when clock line is high. SDA SCL Data line Stable: Data valid except S, Sr, P Figure 11.47 Change of Data allowed Bit Transfer on the I2C-Bus 11.10.4 Start / Repeated Start / Stop One master can issue a START (S) condition to notice other devices connected to the SCL, SDA lines that it will use the bus. A STOP (P) condition is generated by the master to release the bus lines so that other devices can use it. A high to low transition on the SDA line while SCL is high defines a START (S) condition. A low to high transition on the SDA line while SCL is high defines a STOP (P) condition. START and STOP conditions are always generated by the master. The bus is considered to be busy after START condition. The bus is considered to be free again after STOP condition, ie, the bus is busy between START and STOP condition. If a repeated START condition (Sr) is generated instead of STOP condition, the bus stays busy. So, the START and repeated START conditions are functionally identical. SDA SCL Figure 11.48 S P START Condition STOP Condition START and STOP Condition 147 A94B114 ABOV Semiconductor Co., Ltd. 11.10.5 Data Transfer Every byte put on the SDA line must be 8-bit long. The number of bytes that can be transmitted per transfer is unlimited. Each byte has to be followed by an acknowledge bit. Data is transferred with the most significant bit (MSB) first. If a slave can’t receive or transmit another complete byte of data until it has performed some other function, it can hold the clock line SCL LOW to force the master into a wait state. Data transfer then continues when the slave is ready for another byte of data and releases clock line SCL. P SDA MSB Acknowledgement Signal form Slave Byte Complete, Interrupt within Device SCL S or Sr 1 Acknowledgement Signal form Slave Sr Clock line held low while interrupts are served. 9 1 ACK 9 Sr or P ACK START or Repeated START Condition Figure 11.49 STOP or Repeated START Condition STOP or Repeated START Condition 11.10.6 Acknowledge The acknowledge related clock pulse is generated by the master. The transmitter releases the SDA line (HIGH) during the acknowledge clock pulse. The receiver must pull down the SDA line during the acknowledge clock pulse so that it remains stable LOW during the HIGH period of this clock pulse. When a slave is addressed by a master (Address Packet), and if it is unable to receive or transmit because it’s performing some real time function, the data line must be left HIGH by the slave. And also, when a slave addressed by a master is unable to receive more data bits, the slave receiver must release the SDA line (Data Packet). The master can then generate either a STOP condition to abort the transfer, or a repeated START condition to start a new transfer. If a master receiver is involved in a transfer, it must signal the end of data to the slave transmitter by not generating an acknowledge on the last byte that was clocked out of the slave. The slave transmitter must release the data line to allow the master to generate a STOP or repeated START condition. Data Output By Transmitter NACK Data Output By Receiver ACK SCL From MASTER 1 2 8 9 Clock pulse for ACK Figure 11.50 Acknowledge on the I2C-Bus 148 A94B114 ABOV Semiconductor Co., Ltd. 11.10.7 Synchronization / Arbitration Clock synchronization is performed by using the wired-AND connection of I2C interfaces to the SCL line. This means that a HIGH to LOW transition on the SCL line will cause the devices concerned to start counting off their LOW period and it will hold the SCL line in that state until the clock HIGH state is reached. However the LOW to HIGH transition of this clock may not change the state of the SCL line if another clock is still within its LOW period. In this way, a synchronized SCL clock is generated with its LOW period determined by the device with the longest clock LOW period, and its HIGH period determined by the one with the shortest clock HIGH period. A master may start a transfer only if the bus is free. Two or more masters may generate a START condition. Arbitration takes place on the SDA line, while the SCL line is at the HIGH level, in such a way that the master which transmits a HIGH level, while another master is transmitting a LOW level will switch off its DATA output state because the level on the bus doesn’t correspond to its own level. Arbitration continues for many bits until a winning master gets the ownership of I2C bus. Its first stage is comparison of the address bits. Wait High Counting Start High Counting Fast Device SCLOUT High Counter Reset Slow Device SCLOUT SCL Figure 11.51 Clock Synchronization during Arbitration Procedure Arbitration Process not adapted Device 1 loses Arbitration Device1 DataOut Device2 DataOut SDA on BUS SCL on BUS S Figure 11.52 Arbitration Procedure of Two Masters 149 Device1 outputs High A94B114 ABOV Semiconductor Co., Ltd. 11.10.8 Operation The I2C is byte-oriented and interrupt based. Interrupts are issued after all bus events except for a transmission of a START condition. Because the I2C is interrupt based, the application software is free to execute other operations during a I2C byte transfer. Note that when a I2C interrupt is generated, IIF flag in I2CMR register is set, it is cleared by writing an arbitrary value to I2CSR. When I2C interrupt occurs, the SCL line is hold LOW until writing any value to I2CSR. When the IIF flag is set, the I2CSR contains a value indicating the current state of the I2C bus. According to the value in I2CSR, software can decide what to do next. I2C can operate in 4 modes by configuring master/slave, transmitter/receiver. The operating mode is configured by a winning master. A more detailed explanation follows below. 11.10.8.1 Master Transmitter To operate I2C in master transmitter, follow the recommended steps below. 1. Enable I2C by setting IICEN bit in I2CMR. This provides main clock to the peripheral. 2. Load SLA+W into the I2CDR where SLA is address of slave device and W is transfer direction from the viewpoint of the master. For master transmitter, W is ‘0’. Note that I2CDR is used for both address and data. 3. Configure baud rate by writing desired value to both I2CSCLLR and I2CSCLHR for the Low and High period of SCL line. 4. Configure the I2CSDAHR to decide when SDA changes value from falling edge of SCL. If SDA should change in the middle of SCL LOW period, load half the value of I2CSCLLR to the I2CSDAHR. 5. Set the START bit in I2CMR. This transmits a START condition. And also configure how to handle interrupt and ACK signal. When the START bit is set, 8-bit data in I2CDR is transmitted out according to the baud-rate. 6. This is ACK signal processing stage for address packet transmitted by master. When 7-bit address and 1-bit transfer direction is transmitted to target slave device, the master can know whether the slave acknowledged or not in the 9th high period of SCL. If the master gains bus mastership, I2C generates GCALL interrupt regardless of the reception of ACK from the slave device. When I2C loses bus mastership during arbitration process, the MLOST bit in I2CSR is set, and I2C waits in idle state or can be operate as an addressed slave. To operate as a slave when the MLSOT bit in I2CSR is set, the ACKEN bit in I2CMR must be set and the received 7-bit address must equal to the SLA bits in I2CSAR. In this case I2C operates as a slave transmitter or a slave receiver (go to appropriate section). In this stage, I2C holds the SCL LOW. This is because to decide whether I2C continues serial transfer or stops communication. The following steps continue assuming that I2C does not lose mastership during first data transfer. I2C (Master) can choose one of the following cases regardless of the reception of ACK signal from slave. 1) Master receives ACK signal from slave, so continues data transfer because slave can receive more data from master. In this case, load data to transmit to I2CDR. 2) Master stops data transfer even if it receives ACK signal from slave. In this case, set the STOP bit in I2CMR. 3) Master transmits repeated START condition with not checking ACK signal. In this case, load SLA+R/W into the I2CDR and set START bit in I2CMR. 150 A94B114 ABOV Semiconductor Co., Ltd. After doing one of the actions above, write arbitrary value to I2CSR to release SCL line. In case of 1), move to step 7. In case of 2), move to step 9 to handle STOP interrupt. In case of 3), move to step 6 after transmitting the data in I2CDR and if transfer direction bit is ‘1’ go to master receiver section. 7. 1-byte of data is being transmitted. During data transfer, bus arbitration continues. 8. This is ACK signal processing stage for data packet transmitted by master. I2C holds the SCL as Low. When I2C loses bus mastership while transmitting data arbitrating other masters, the MLOST bit in I2CSR is set. If then, I2C waits in idle state. When the data in I2CDR is transmitted completely, I2C generates TEND interrupt. I2C can choose one of the following cases regardless of the reception of ACK signal from slave. 1) Master continues receiving data from slave. To do this, set ACKEN bit in I2CMR to ACKnowledge and the next data to be received. 2) Master wants to terminate data transfer when it receives next data by not generating ACK signal. This can be done by clearing ACKEN bit in I2CMR. 3) Because no ACK signal is detected, master terminates data transfer. In this case, set the STOP bit in I2CMR. 4) No ACK signal is detected, and master transmits repeated START condition. In this case, load SLA+R/W into the I2CDR and set the START bit in I2CMR. After doing one of the actions above, write arbitrary value to I2CSR to release SCL line. In case of 1), move to step 7. In case of 2), move to step 9 to handle STOP interrupt. In case of 3), move to step 6 after transmitting the data in I2CDR, and if transfer direction bit is ‘1’ go to master receiver section. 9. This is the final step for master transmitter function of I2C, handling STOP interrupt. The STOP bit indicates that data transfer between master and slave is over. To clear I2CSR, write arbitrary value to I2CSR. After this, I2C enters idle state. 11.10.8.2 Master Receiver To operate I2C in master receiver, follow the recommended steps below. 1. Enable I2C by setting IICEN bit in I2CMR. This provides main clock to the peripheral. 2. Load SLA+R into the I2CDR where SLA is address of slave device and R is transfer direction from the viewpoint of the master. For master receiver, R is ‘1’. Note that I2CDR is used for both address and data. 3. Configure baud rate by writing desired value to both I2CSCLLR and I2CSCLHR for the Low and High period of SCL line. 4. Configure the I2CSDAHR to decide when SDA changes value from falling edge of SCL. If SDA should change in the middle of SCL LOW period, load half the value of I2CSCLLR to the I2CSDAHR. 5. Set the START bit in I2CMR. This transmits a START condition. And also configure how to handle interrupt and ACK signal. When the START bit is set, 8-bit data in I2CDR is transmitted out according to the baud-rate. 6. This is ACK signal processing stage for address packet transmitted by master. When 7-bit address and 1-bit transfer direction is transmitted to target slave device, the master can know whether the slave acknowledged or not in the 9th high period of SCL. If the master gains bus mastership, I2C generates GCALL interrupt regardless of the reception of ACK from the slave device. When I2C loses bus mastership during arbitration process, the MLOST bit in I2CSR is set, and I2C waits in idle state or can be operate as an addressed slave. To operate as a slave when the MLSOT bit in I2CSR is set, the ACKEN bit in I2CMR must be set and the received 7-bit address must equal to the SLA bits in I2CSAR. In this case I2C operates as a slave transmitter or a slave receiver (go to 151 A94B114 ABOV Semiconductor Co., Ltd. appropriate section). In this stage, I2C holds the SCL LOW. This is because to decide whether I2C continues serial transfer or stops communication. The following steps continue assuming that I2C does not lose mastership during first data transfer. I2C (Master) can choose one of the following cases according to the reception of ACK signal from slave. 1) Master receives ACK signal from slave, so continues data transfer because slave can prepare and transmit more data to master. Configure ACKEN bit in I2CMR to decide whether I2C ACKnowledges the next data to be received or not. 2) Master stops data transfer because it receives no ACK signal from slave. In this case, set the STOP bit in I2CMR. 3) Master transmits repeated START condition due to no ACK signal from slave. In this case, load SLA+R/W into the I2CDR and set START bit in I2CMR. After doing one of the actions above, write arbitrary value to I2CSR to release SCL line. In case of 1), move to step 7. In case of 2), move to step 9 to handle STOP interrupt. In case of 3), move to step 6 after transmitting the data in I2CDR and if transfer direction bit is ‘0’ go to master transmitter section. 7. 1-byte of data is being received. 8. This is ACK signal processing stage for data packet transmitted by slave. I2C holds the SCL LOW. When 1-byte of data is received completely, I2C generates TEND interrupt. I2C can choose one of the following cases according to the RXACK flag in I2CSR. 4) Master continues receiving data from slave. To do this, set ACKEN bit in I2CMR to ACKnowledge and the next data to be received. 5) Master wants to terminate data transfer when it receives next data by not generating ACK signal. This can be done by clearing ACKEN bit in I2CMR. 6) Because no ACK signal is detected, master terminates data transfer. In this case, set the STOP bit in I2CMR. 7) No ACK signal is detected, and master transmits repeated START condition. In this case, load SLA+R/W into the I2CDR and set the START bit in I2CMR. After doing one of the actions above, write arbitrary value to I2CSR to release SCL line. In case of 1) and 2), move to step 7. In case of 3), move to step 9 to handle STOP interrupt. In case of 4), move to step 6 after transmitting the data in I2CDR, and if transfer direction bit is ‘0’ go to master transmitter section. 9. This is the final step for master receiver function of I2C, handling STOP interrupt. The STOP bit indicates that data transfer between master and slave is over. To clear I2CSR, write arbitrary value to I2CSR. After this, I2C enters idle state. 152 A94B114 11.10.8.3 ABOV Semiconductor Co., Ltd. Slave Transmitter To operate I2C in slave transmitter, follow the recommended steps below. 1. If the main operating clock (SCLK) of the system is slower than that of SCL, load value 0x00 into I2CSDAHR to make SDA change within one system clock period from the falling edge of SCL. Note that the hold time of SDA is calculated by SDAH x period of SCLK where SDAH is multiple of number of SCLK coming from I2CSDAHR. When the hold time of SDA is longer than the period of SCLK, I2C (slave) cannot transmit serial data properly. 2. Enable I2C by setting IICEN bit and INTEN bit in I2CMR. This provides main clock to the peripheral. 3. When a START condition is detected, I2C receives one byte of data and compares it with SLA bits in I2CSAR. If the GCALLEN bit in I2CSAR is enabled, I2C compares the received data with value 0x00, the general call address. 4. If the received address does not equal to SLA bits in I2CSAR, I2C enters idle state ie, waits for another START condition. Else if the address equals to SLA bits and the ACKEN bit is enabled, I2C generates SSEL interrupt and the SCL line is held LOW. Note that even if the address equals to SLA bits, when the ACKEN bit is disabled, I2C enters idle state. When SSEL interrupt occurs, load transmit data to I2CDR and write arbitrary value to I2CSR to release SCL line. 5. 1-byte of data is being transmitted. 6. In this step, I2C generates TEND interrupt and holds the SCL line as Low regardless of the reception of ACK signal from master. Slave can select one of the following cases. 1) No ACK signal is detected and I2C waits STOP or repeated START condition. 2) ACK signal from master is detected. Load data to transmit into I2CDR. After doing one of the actions above, write arbitrary value to I2CSR to release SCL line. In case of 1) move to step 7 to terminate communication. In case of 2) move to step 5. In either case, a repeated START condition can be detected. For that case, move step 4. 7. This is the final step for slave transmitter function of I2C, handling STOP interrupt. The STOP bit indicates that data transfer between master and slave is over. To clear I2CSR, write arbitrary value to I2CSR. After this, I2C enters idle state. 11.10.8.4 Slave Receiver To operate I2C in slave receiver, follow the recommended steps below. 1. If the main operating clock (SCLK) of the system is slower than that of SCL, load value 0x00 into I2CSDAHR to make SDA change within one system clock period from the falling edge of SCL. Note that the hold time of SDA is calculated by SDAH x period of SCLK where SDAH is multiple of number of SCLK coming from I2CSDAHR. When the hold time of SDA is longer than the period of SCLK, I2C (slave) cannot transmit serial data properly. 2. Enable I2C by setting IICEN bit and INTEN bit in I2CMR. This provides main clock to the peripheral. 3. When a START condition is detected, I2C receives one byte of data and compares it with SLA bits in I2CSAR. If the GCALLEN bit in I2CSAR is enabled, I2C compares the received data with value 0x00, the general call address. 4. If the received address does not equal to SLA bits in I2CSAR, I2C enters idle state ie, waits for another START condition. Else if the address equals to SLA bits and the ACKEN bit is enabled, I2C generates SSEL interrupt and 153 A94B114 ABOV Semiconductor Co., Ltd. the SCL line is held LOW. Note that even if the address equals to SLA bits, when the ACKEN bit is disabled, I2C enters idle state. When SSEL interrupt occurs and I2C is ready to receive data, write arbitrary value to I2CSR to release SCL line. 5. 1-byte of data is being received. 6. In this step, I2C generates TEND interrupt and holds the SCL line LOW regardless of the reception of ACK signal from master. Slave can select one of the following cases. 1) No ACK signal is detected (ACKEN=0) and I2C waits STOP or repeated START condition. 2) ACK signal is detected (ACKEN=1) and I2C can continue to receive data from master. After doing one of the actions above, write arbitrary value to I2CSR to release SCL line. In case of 1) move to step 7 to terminate communication. In case of 2) move to step 5. In either case, a repeated START condition can be detected. For that case, move step 4. 7. This is the final step for slave receiver function of I2C, handling STOP interrupt. The STOP bit indicates that data transfer between master and slave is over. To clear I2CSR, write arbitrary value to I2CSR. After this, I2C enters idle state. 11.10.9 Register Map Name Address Dir Default Description I2CSR F8H R 00H I2C Status Register 0 I2CMR F9H R/W 00H I2C Mode Control Register I2CMR1 EEH R/W 00H I2C Mode Control Register 1 I2CSCLLR FAH R/W 3FH SCL Low Period Register I2CSCLHR FBH R/W 3FH SCL High Period Register I2CSDAHR FCH R/W 01H SDA Hold Time Register I2CDR0 FDH R/W FFH I2C Data Register I2CSAR FEH R/W 00H I2C Slave Address 0 Register I2CSAR1 FFH R/W 00H I2C Slave Address 1 Register Table 11.16 11.10.10 I2C Register Map I2C Register Description I2C Registers are composed of I2C Mode Control Register (I2CMR), I2C Mode Control Register 1 (ICMR1), I2C Status Register (I2CSR), SCL Low Period Register (I2CSCLLR), SCL High Period Register (I2CSCLHR), SDA Hold Time Register (I2CSDAHR), I2C Data Register (I2CDR), I2C Slave Address 0 Register (I2CSAR1) and I2C Slave Address 1 Register (I2CSAR1). 154 A94B114 11.10.11 ABOV Semiconductor Co., Ltd. Register Description for I2C I2CMR (I2C Mode Control Register) : F9H 7 6 5 4 3 2 1 0 IIF IICEN RESET INTEN ACKEN MASTER STOP START R/W R/W R/W R/W R/W R R/W IIF This is interrupt flag bit. 0 1 IICEN RESET INTEN ACKEN MASTER STOP START R/W Initial value : 00H Enable No interrupt is generated or interrupt is cleared An interrupt is generated I 2C Function Block (by providing clock) 0 I2C is inactive 1 I2C is active Initialize internal registers of I2C. 0 No operation 1 Initialize I2C, auto cleared Enable interrupt generation of I2C. 0 Disable interrupt, operates in polling mode 1 Enable interrupt Controls ACK signal generation at ninth SCL period. NOTE) ACK signal is output (SDA=0) for the following 3 cases. When received address packet equals to SLA bits in I2CSAR When received address packet equals to value 0x00 with GCALL enabled When I2C operates as a receiver (master or slave) 0 No ACK signal is generated (SDA=1) 1 ACK signal is generated (SDA=0) Represent operating mode of I2C 0 I2C is in slave mode 1 I2C is in master mode When I2C is master, generates STOP condition. 0 No operation 1 STOP condition is to be generated When I2C is master, generates START condition. 0 No operation 1 START or repeated START condition is to be generated I2CMR1 (I2C Mode Control Register 1) : EEH 7 6 5 4 3 2 1 0 - - - - - - - DIS_SDAH - - - - - - - DIS_SDAH Disable SDA hold time 0 Enable SDA hold time 1 Disable SDA hold time 155 R/W Initial value : 00H A94B114 ABOV Semiconductor Co., Ltd. I2CSR (I2C Status Register) : F8H 7 6 5 4 3 2 1 0 GCALL TEND STOP SSEL MLOST BUSY TMODE RXACK R R R R R R R GCALL TEND STOP SSEL MLOST BUSY TMODE RXACK R Initial value : 00H This bit has different meaning depending on whether I 2C is master or slave. NOTE 1) When I2C is a master, this bit represents whether it received AACK (Address ACK) from slave. When I2C is a slave, this bit is used to indicate general call. 0 No AACK is received (Master mode) 1 AACK is received (Master mode) 0 Received address is not general call address 1 General call address is detected (Slave mode) (Slave mode) This bit is set when 1-Byte of data is transferred completely. NOTE 1) 0 1 byte of data is not completely transferred 1 1 byte of data is completely transferred This bit is set when STOP condition is detected. NOTE 1) 0 No STOP condition is detected 1 STOP condition is detected This bit is set when I2C is addressed by other master. NOTE 1) 0 I2C is not selected as slave 1 I2C is addressed by other master and acts as a slave This bit represents the result of bus arbitration in master mode. NOTE 1) 0 I2C maintains bus mastership 1 I2C has lost bus mastership during arbitration process This bit reflects bus status. 0 I2C bus is idle, so any master can issue a START condition 1 I2C bus is busy This bit is used to indicate whether I2C is transmitter or receiver. 0 I2C is a receiver 1 I2C is a transmitter This bit shows the state of ACK signal. 0 No ACK is received 1 ACK is generated at ninth SCL period NOTE 1) These bits can be source of interrupt. When an I2C interrupt occurs except for STOP interrupt, the SCL line is hold LOW. To release SCL, write arbitrary value to I2CSR. When I2CSR is written, the TEND, STOP, SSEL, LOST, RXACK bits are cleared. 156 A94B114 ABOV Semiconductor Co., Ltd. I2CSCLLR (SCL Low Period Register) : FAH 7 6 5 4 3 2 1 0 SCLL7 SCLL6 SCLL5 SCLL4 SCLL3 SCLL2 SCLL1 SCLL0 R/W R/W R/W R/W R/W R/W R/W SCLL[7:0] R/W Initial value : 3FH This register defines the LOW period of SCL when I2C operates in master mode. The base clock is SCLK, the system clock, and the period is calculated by the formula : tSCLK × (4 × SCLL + 1) where tSCLK is the period of SCLK. I2CSCLHR (SCL High Period Register) : FBH 7 6 5 4 3 2 1 0 SCLH7 SCLH6 SCLH5 SCLH4 SCLH3 SCLH2 SCLH1 SCLH0 R/W R/W R/W R/W R/W R/W R/W SCLH[7:0] R/W Initial value : 3FH This register defines the HIGH period of SCL when I2C operates in master mode. The base clock is SCLK, the system clock, and the period is calculated by the formula : tSCLK × (4 × SCLH + 3) where tSCLK is the period of SCLK. So, the operating frequency of I2C in master mode (fI2C) is calculated by the following equation. 1 fI2C = tSCLK × (4 (SCLL + SCLH) + 4) I2CSDAHR (SDA Hold Time Register) : FCH 7 6 5 4 3 2 1 0 SDAH7 SDAH6 SDAH5 SDAH4 SDAH3 SDAH2 SDAH1 SDAH0 R/W R/W R/W R/W R/W R/W R/W SDAH[7:0] R/W Initial value : 01H This register is used to control SDA output timing from the falling edge of SCL. Note that SDA is changed after tSCLK × SDAH. In master mode, load half the value of SCLL to this register to make SDA change in the middle of SCL. In slave mode, configure this register regarding the frequency of SCL from master. The SDA is changed after tSCLK × (SDAH + 1). So, to insure normal operation in slave mode, the value t SCLK × (SDAH + 1) must be smaller than the period of SCL. I2CDR (I2C Data Register) : FDH 7 6 5 4 3 2 1 0 ICD7 ICD6 ICD5 ICD4 ICD3 ICD2 ICD1 ICD0 R/W R/W R/W R/W R/W R/W R/W ICD[7:0] R/W Initial value : FFH When I2C is configured as a transmitter, load this register with data to be transmitted. When I2C is a receiver, the received data is stored into this register. 157 A94B114 ABOV Semiconductor Co., Ltd. I2CSAR0 (I2C Slave Address Register 0) : FEH 7 6 5 4 3 2 1 0 SLA7 SLA6 SLA5 SLA4 SLA3 SLA2 SLA1 GCALLEN R/W R/W R/W R/W R/W R/W R/W R/W Initial value : 00H SLA[7:1] These bits configure the slave address of this I2C module when I2C operates in slave mode. GCALLEN This bit decides whether I2C allows general call address or not when I 2C operates in slave mode. 0 Ignore general call address 1 Allow general call address I2CSAR1 (I2C Slave Address Register 1) : FFH 7 6 5 4 3 2 1 0 SLA7 SLA6 SLA5 SLA4 SLA3 SLA2 SLA1 GCALLEN R/W R/W R/W R/W R/W R/W R/W R/W Initial value : 00H SLA[7:1] These bits configure the slave address of this I2C module when I2C operates in slave mode. GCALLEN This bit decides whether I2C allows general call address or not when I2C operates in slave mode. 0 Ignore general call address 1 Allow general call address 158 A94B114 ABOV Semiconductor Co., Ltd. 11.11 CRC 11.11.1 Overview Using the CRC, it can be monitor the memory of the specified area. This is a one-time operation, and reset is required for continuous operation. In CRC MNT mode, when the CRC read is finished, CRC_FLAG occurs. In CRC validate mode, if the CRC validate fail after the CRC reading is finished, CRC_FLAG occurs. CRC_FAIL indicates the status of validate results when the CRC read is finished. If the CRC_FLAG is generated and the interrupt is enabled, interrupt service routine is served. CRC-FLAG is not cleared by hardware. CRC-TYPE 0~3 are not supported. Validate is done by comparing the CRC_MNT register and the CRC register value. CRC are not automatically initialized, you need to calculate a new CRC after CRC_H,CRC_L Clear. CRC TYPE CRC mode Input Condition of CRC_FLAG Condition of CRC reset CRC_TYPE = 4 MNT FLASH After CRC reading Validate fail CRC_TYPE = 5 MNT IXRAM After CRC reading Validate fail CRC_TYPE = 6 Validate FLASH After CRC reading & Validate fail Validate fail CRC_TYPE = 7 validate IXRAM After CRC reading & Validate fail Validate fail Table 11.17 CRC mode 11.11.2 Block Diagram < FLAGH > ADDR_MNT_START ADDR_MNT ADDR_MNT_END FLASH IRQ1.3 ADDR_MNT_END CRC calculator CRC CRC_TYPE[1] CRC Interrupt ADDR_MNT_START ADDR_MNT_END CRC_TYPE[2:0] IXRAM INT_EN CRC_MNT < IXRAM > CRC_FAIL Figure 11.53 CRC block diagram 11.11.3 Register Map Name Address Direction Default Description CRC_CON 20E0H R/W 00H CRC Control Register CRC_H 20E3H R/W 00H CRC High Register CRC_L 20E4H R/W 00H CRC Low Register CRC_MNT_H 20E5H R/W 00H CRC Monitor High Register CRC_MNT_L 20E6H R/W 00H CRC Monitor Low Register CRC_ADDR_START_M 20EBH R/W 00H CRC Start Address Middle Register CRC_ADDR_START_L 20ECH R/W 00H CRC Start Address Low Register CRC_ADDR_END_M 20EDH R/W 00H CRC End Address Middle Register CRC_ADDR_END_L 20EEH R/W 00H CRC End Address Low Register Table 11.18 CRC Register Map 159 A94B114 ABOV Semiconductor Co., Ltd. 11.11.4 CRC Register description CRC_CON (CRC Control Register) : 20E0H 7 6 5 4 3 2 1 0 CRC_FLAG CRC_INTEN – CRC_EN CRC_FAIL CRC_TYPE[2] CRC_TYPE[1] CRC_TYPE[0] R/W R/W – R/W R/W R/W R/W CRC_FLAG R/W Initial value : 00H CRC flag. The flag is cleared only by writing a ‘0’ to the bit. So, the flag should be cleared by software. Writing “1” has no effect. * When go to interrupt service routine, CRC_FLAG is not cleared. 0 CRC flag not occur 1 CRC_INTEN CRC flag occur Enable CRC interrupt CRC_EN 0 CRC interrupt disable 1 CRC interrupt enable Enable CRC operation, it is cleared automatically after the CRC reading is finished CRC_FAIL 0 CRC disable 1 CRC enable Status of CRC validate. CRC_TYPE[2:0] 0 Validate pass 1 Validate fail Select the CRC input data type. 0xx Not used 100 Specified flash data 101 Specified IXRAM data For XRAM data CRC, add 256 to the corresponding address. (Physical Address : IRAM (0~0xFF), XRAM (0x100~0x1FF) 110 Specified flash data, validate CRC value 111 Specified IXRAM data, validate CRC value For XRAM data CRC, add 256 to the corresponding address. (Physical Address : IRAM (0~0xFF), XRAM (0x100~0x1FF) CRC_H (CRC High Register) : 20E3H 7 6 5 4 3 2 1 0 CRC[15] CRC[14] CRC[13] CRC[12] CRC[11] CRC[10] CRC[9] CRC[8] R/W R/W R/W R/W R/W R/W R/W R/W Initial value : 00H CRC_L (CRC Low Register) : 20E4H 7 6 5 4 3 2 1 0 CRC[7] CRC[6] CRC[5] CRC[4] CRC[3] CRC[2] CRC[1] CRC[0] R/W R/W R/W R/W R/W R/W R/W R/W Initial value : 00H CRC[15:0] CRC result CRC_MNT_H (CRC Monitor High Register) : 20E5H 7 6 5 4 3 160 2 1 0 A94B114 ABOV Semiconductor Co., Ltd. CRC_MNT[15] CRC_MNT[14] CRC_MNT[13] CRC_MNT[12] CRC_MNT[11] CRC_MNT[10] CRC_MNT[9] CRC_MNT[8] R/W R/W R/W R/W R/W R/W R/W R/W Initial value : 00H CRC_MNT_L (CRC Monitor Low Register) : 20E6H 7 6 5 4 3 2 1 0 CRC_MNT[7] CRC_MNT[6] CRC_MNT[5] CRC_MNT[4] CRC_MNT[3] CRC_MNT[2] CRC_MNT[1] CRC_MNT[0] R/W R/W R/W R/W R/W R/W R/W R/W Initial value : 00H CRC_MNT[15:0] CRC compare register, when performing a validate CRC_ADDR_START_M (CRC Start Address Middle Register) : 20EBH 7 6 5 4 3 2 1 0 CRC_ADDR_ START[15] CRC_ADDR_ START[14] CRC_ADDR_ START[13] CRC_ADDR_ START[12] CRC_ADDR_ START[11] CRC_ADDR_ START[10] CRC_ADDR_ START[9] CRC_ADDR_ START[8] R/W R/W R/W R/W R/W R/W R/W R/W Initial value : 00H CRC_ADDR_START_L (CRC Start Address Low Register) : 20ECH 7 6 5 4 3 2 1 0 CRC_ADDR_ START[7] CRC_ADDR_ START[6] CRC_ADDR_ START[5] CRC_ADDR_ START[4] CRC_ADDR_ START[3] CRC_ADDR_ START[2] CRC_ADDR_ START[1] CRC_ADDR_ START[0] R/W R/W R/W R/W R/W R/W R/W R/W Initial value : 00H CRC_ADDR_START[16:0] CRC start address CRC_ADDR_END_M (CRC End Address Middle Register) : 20EDH 7 6 5 4 3 2 1 0 CRC_ADDR_ END[15] CRC_ADDR_ END[14] CRC_ADDR_ END[13] CRC_ADDR_ END[12] CRC_ADDR_ END[11] CRC_ADDR_ END[10] CRC_ADDR_ END[9] CRC_ADDR_ END[8] R/W R/W R/W R/W R/W R/W R/W R/W Initial value : 00H CRC_ADDR_END_L (CRC End Address Low Register) : 20EEH 7 6 5 4 3 2 1 0 CRC_ADDR_ END[7] CRC_ADDR_ END[6] CRC_ADDR_ END[5] CRC_ADDR_ END[4] CRC_ADDR_ END[3] CRC_ADDR_ END[2] CRC_ADDR_ END[1] CRC_ADDR_ END[0] R/W R/W R/W R/W R/W R/W R/W CRC_ADDR_END[16:0] NOTE) CRC end address CRC Polynomial f(x) = 1+x^7+x^10+x^11+x^15+x^16 CRC16, Polynomial representations Normal : 0x8C81 161 R/W Initial value : 00H A94B114 ABOV Semiconductor Co., Ltd. 12 Power Down Operation 12.1 Overview The A94B114 has two power-down modes to minimize the power consumption of the device. In power down mode, power consumption is reduced considerably. The device provides two kinds of power saving functions, IDLE and STOP mode. In two modes, program is stopped. 12.2 Peripheral Operation in IDLE/STOP Mode Peripheral IDLE Mode STOP Mode CPU ALL CPU Operation are Disable ALL CPU Operation are Disable RAM Retain Retain Basic Interval Timer Operates Continuously Stop Watch Dog Timer Operates Continuously Stop (Can be operated with Ring OSC) Timer0~2 Operates Continuously Halted (Only when the Event Counter Mode is Enabled, Timer operates Normally) ADC Operates Continuously Stop Comparator Operates Continuously Stop (Can be operated with Ring OSC) USART Operates Continuously Stop I2C Operates Continuously Stop Internal RC OSC (16MHz) Oscillation Stop when the system clock (fx) is fIRC Internal Ring OSC (256kHz) Can be operated with setting value Can be operated with setting value Main OSC (0.4~12MHz) Oscillation Stop when fx = fXIN I/O Port Retain Retain Control Register Retain Retain Address Data Bus Retain Retain Release Method By RESET, all Interrupts By RESET, Timer Interrupt(EC), External Interrupt, I2C Interrupt, Comparator Interrupt, USART by RX, WDT, LVI Table 12.1 Peripheral Operation during Power Down Mode 162 A94B114 12.3 ABOV Semiconductor Co., Ltd. IDLE Mode The power control register is set to ‘01h’ to enter the IDLE Mode. In this mode, the internal oscillation circuits remain active. Oscillation continues and peripherals are operated normally but CPU stops. It is released by reset or interrupt. To be released by interrupt, interrupt should be enabled before IDLE mode. If using reset, because the device becomes initialized state, the registers have reset value. OSC ... CPU Clock ... External Interrupt Normal Operation Figure 12.1 Stand-by Mode IDLE Mode Release Timing by External Interrupt 163 Normal Operation A94B114 12.4 ABOV Semiconductor Co., Ltd. STOP Mode The power control register is set to ‘03H’ to enter the STOP Mode. In the stop mode, the selected oscillator, system clock and peripheral clock is stopped, but watch timer can be continued to operate with sub clock. With the clock frozen, all functions are stopped, but the on-chip RAM and control registers are held. For example, If the internal RC oscillator (fIRC) is selected for the system clock and the sub clock (fSUB) is oscillated, the internal RC oscillator stops oscillation and the sub clock is continuously oscillated in stop mode. At that time, the watch timer can be operated with the sub clock. The source for exit from STOP mode is hardware reset and interrupts. The reset re-defines all the control registers. When exit from STOP mode, enough oscillation stabilization time is required to normal operation. Figure 12.2 shows the timing diagram. When released from STOP mode, the Basic interval timer is activated on wake-up. Therefore, before STOP instruction, user must be set its relevant prescale divide ratio to have long enough time. This guarantees that oscillator has started and stabilized. OSC ... CPU Clock External Interrupt Release configure option Read CFG Read Oscillation stabilization time = 8ms @ 16MHz system clock STOP command Nornal Operation Figure 12.2 STOP MODE Stand-by Mode STOP Mode Release Timing by External Interrupt 164 Nornal Operation A94B114 12.5 ABOV Semiconductor Co., Ltd. Release Operation of STOP Mode After STOP mode is released, the operation begins according to content of related interrupt register just before STOP mode start (Figure 12.3). If the global interrupt Enable Flag (IE.EA) is set to `1`, the STOP mode is released by the interrupt which each interrupt enable flag = `1` and the CPU jumps to the relevant interrupt service routine. Even if the IE.EA bit is cleared to ‘0’, the STOP mode is released by the interrupt of which the interrupt enable flag is set to ‘1’. SET PCON[7:0] SET IEx.b STOP Mode Interrupt Request Corresponding Interrupt Enable Bit(IE, IE1, IE2, IE3) IEx.b==1 ? Y STOP Mode Release Interrupt Service Routine Next Instruction Figure 12.3 STOP Mode Release Flow 165 N A94B114 12.6 ABOV Semiconductor Co., Ltd. Register Map Name Address Direction Default Description PCON 87H R/W 00H Power Control Register Table 12.2 12.7 Power Down Operation Register Map Power Down Operation Register Description The power down operation register consists of the power control register (PCON). 12.8 Register Description for Power Down Operation PCON (Power Control Register): 87H 7 6 5 4 3 2 1 0 – – – – PCON3 PCON2 PCON1 PCON0 – – – – R/W R/W R/W R/W Initial value: 00H PCON[7:0] Power Control 01H IDLE mode enable 03H STOP mode enable Other Values Normal operation NOTE) 1. 2. 3. 4. To enter IDLE mode, PCON must be set to ‘01H’. To enter STOP mode, PCON must be set to ‘03H’. The PCON register is automatically cleared by a release signal in STOP/IDLE mode. Three or more NOP instructions must immediately follow the instruction that make the device enter STOP/IDLE mode. Refer to the following examples. Ex1) MOV PCON, #01H ; IDLE mode Ex2) MOV NOP NOP NOP NOP NOP NOP • • • • • • 166 PCON, #03H ; STOP mode A94B114 ABOV Semiconductor Co., Ltd. 13 RESET 13.1 Overview The following is the hardware setting value. On Chip Hardware Initial Value Program Counter (PC) 0000h Accumulator 00h Stack Pointer (SP) 07h Peripheral Clock On Control Register Refer to the Peripheral Registers Table 13.1 13.2 Reset State Reset Source The A94B114 has four types of reset sources. The following is the reset sources. 13.3 − External RESETB − Power ON RESET (POR) − WDT Overflow Reset (In the case of WDTEN = `1`) − Low Voltage Reset (In the case of LVREN = `0 `) Block Diagram Ext RESET Disable by FUSE RESET Noise Canceller RESETB POR RST WDT RST WDT RSTEN LVR RST LVROFF Figure 13.1 RESET Block Diagram 167 A94B114 13.4 ABOV Semiconductor Co., Ltd. RESET Noise Canceller The Figure 13.2 is the noise canceller diagram for noise cancellation of RESET. It has the noise cancellation value of about 2us(@VDD=5V) to the low input of system reset. t < TRNC t < TRNC A t > TRNC t > TRNC t > TRNC A’ Figure 13.2 13.5 Reset noise canceller timer diagram Power on RESET When rising device power, the POR (Power On Reset) has a function to reset the device. If POR is used, it executes the device RESET function instead of the RESET IC or the RESET circuits. And the external RESET PIN is able to use as normal I/O pin. VPO R = 1.25V (Typ) VDD nPOR (Internal Signal) Internal RESETb Oscillation ... Oscillation Stabilization time Figure 13.3 Internal RESET Release Timing On Power-Up 168 A94B114 ABOV Semiconductor Co., Ltd. Counting for configure option read start after RESET is released VDD Internal nPOR Internal Counter for RESET release 00 01 02 00 01 02 03 Internal RESETb 6.4ms~9.6ms (8ms+-20%) @ 16Mhz system clock (HFO) Configure Read 6.4ms~9.6ms (8ms+-20%) @ 16MHz system clock(HFO) Program Counter Figure 13.4 0000 0001 0002 Configuration Timing when Power-on :VDD Input :Internal OSC ④ Configure option Read & Reset Release ② POR ① Figure 13.5 Process Boot Process WaveForm Description Remarks ① -No Operation ② - 1st POR level Detection - Internal OSC (32MHz) ON - Delay section (=8ms) - VDD input voltage must rise over than flash operating voltage for Configure option read - Configure option read point - Reset Release section ③ ④ ⑤ Table 13.2 ⑤ ③ -Normal operation Boot Process Description 169 -about 1.07V ~ 1.55V -Slew Rate >= 0.05V/ms -Configure Value is determined by Writing Option A94B114 13.6 ABOV Semiconductor Co., Ltd. External RESETB Input The External RESETB is the input to a Schmitt trigger. If RESETB pin is held with low for at least 10us over within the operating voltage range and stable oscillation, it is applied and the internal state is initialized. Its debounce clock is only Internal High Frequency Oscillator (HFO) IRC. So do not turn off the HFO IRC to use it. After reset state becomes ‘1’, it needs the stabilization time with 16ms and after the stable state, the internal RESET becomes ‘1’. The Reset process step needs 5 oscillator clocks. And the program execution starts at the vector address stored at address 0000H. OSC ... External RESETb LVI RESETb LVD RESETb WDT RESETb Internal Counter for RESET release Internal RESETb Configure Read 00 01 02 03 6.4ms~9.6ms @ 16MHz system clock(HFO) 6.4ms~9.6ms @ 16MHz system clock(HFO) Program Counter Figure 13.6 0000 0001 0002 Timing Diagram after RESET PRESCALER COUNT START VDD OSC START TIMING Figure 13.7 Oscillator generating waveform example NOTE) 1. 2. As shown Figure 13.7, the stable generating time is not included in the start-up time. The RESETB pin has a Pull-up register by hardware 170 A94B114 13.7 ABOV Semiconductor Co., Ltd. Low Voltage Reset and Low Voltage Indicator Processor The A94B114 has an On-chip Low Voltage Rest (LVR) and On-chip Low Voltage Indicator circuit (LVI) for monitoring the VDD level during operation by comparing it to a fixed trigger level. The LVR terriger level is 1.75V and it is enabled by default. The LVR can be disable by register setting. The trigger level for the LVI can be selected by LVIS[2:0] bit to be 2.4V, 2.9V, 3.9V, 4.2V. In the STOP mode, this will contribute significantly to the total current consumption. So to minimize the current consumption, LVR is set to off by software. LVI is not operation in STOP mode. External VDD LVI_DB Disable 2.4V Low Voltage Indicator (LVI) 2.8V 3.8V 4.2V D De-bounce Clock (HFO IRC Only) LVILS[2:0] LVROFF STOP_SYSB 1 Q CP Interrupt Reset External VDD Low Voltage Reset (LVR) Figure 13.8 13.8 LVI Interrupt 0 LVRRF Block Diagram of LVR and LVI Register Map Name Address Direction Default Description RSFR 98H R/W 84H Reset Flag Register LVIR 89H R/W 00H Low Voltage Indicator Control Register DBTSR 84H R/W 00H De-bounce Time Selection Register Table 13.3 13.9 Reset Operation Register Map Reset Operation Register Description The reset control register consists of the reset flag register (RSFR), low voltage indicator control register (LVIR) and debounce time selection register (DBTSR). 171 A94B114 ABOV Semiconductor Co., Ltd. 13.10 Register Description for Reset Operation RSFR (Reset Flag Register) : 98H 7 6 5 4 3 2 1 0 PORF EXTRF WDTRF OCDRF - LVRF – – R/W R/W R/W R/W R/W R/W – PORF EXTRF WDTRF OCDRF LVRF – Initial value : 84H Power-On Reset flag bit. The bit reset by writing ‘0’ to this bit. 0 No detection 1 Detection External Reset (RESETB) flag bit. The bit is reset by writing ‘0’ to this bit or by PowerOn Reset. 0 No detection 1 Detection Watch Dog Reset flag bit. The bit reset by writing ‘0’ to this bit or by Power-On Reset. 0 No detection 1 Detection On-chip debugger reset flag bit. The bit reset by writing ‘0’ to this bit or by Power-On Reset. 0 No detection 1 Detection Low Voltage Reset flag bit. The bit reset by writing ‘0’ to this bit. 0 No detection 1 Detection NOTE) 1. 2. When the Power-On Reset occurs, the PORF bit is only set to “1”, EXTRF, WDTRF, OCDRF bits are all cleared to “0”. When a reset except the POR occurs, the corresponding flag bit is only set to “1”, the other flag bits are kept in the previous values. 172 A94B114 ABOV Semiconductor Co., Ltd. LVIR (Low Voltage Indicator Control Register) : 89H 7 6 5 4 3 2 1 0 LVROFF LVI_INT_ON LVI_DB – – LVILS2 LVILS1 LVILS0 R/W R/W R/W – – R/W R/W R/W Initial value : 00H LVROFF LVI_INT_ON LVI_DB LVILS[2:0] LVR ON/OFF selection 0 LVR ON 1 LVR OFF LVI Interrupt selection 0 Interrupt 1 Do not select. LVI Reset de-bounce control 0 Disable 1 Enable ( 4us De-bounce, HFO IRC only) LVI level Voltage LVILS2 LVILS1 LVILS0 Description 0 0 0 LVI disable 0 0 1 2.4V 0 1 0 2.9V 0 1 1 3.9V 1 0 0 4.2V 1 0 1 Not used 1 1 0 Not used 1 1 1 Not used DBTSR (De-bounce Time Selection Register) : 84H 7 6 5 4 3 2 1 0 – – – – RDB1 RDB0 PDB1 PDB0 – – – – R/W R/W R/W R/W Initial value : 00H RDB[1:0] PDB[1:0] External Reset De-bounce selection register RDB1 RDB0 Description 0 0 10us 0 1 20us 1 0 40us 1 1 80us Port De-bounce selection register PDB1 PDB0 Description 0 0 1.2us 0 1 2.5us 1 0 5us 1 1 10us NOTE) If RESETB pin is held with low for at least 10us over within the operating voltage range and stable oscillation, it is applied and the internal state is initialized. Its de-bounce clock is only HFO IRC. So do not turn off the HFO IRC to use it. 173 A94B114 ABOV Semiconductor Co., Ltd. 14 On-chip Debug System 14.1 Overview 14.1.1 Description A94B114 can use On-chip debug(OCD). On-chip debug system (OCD) of A94B114 can be used for programming the non-volatile memories and on-chip debugging. Detail descriptions for programming via the OCD interface can be found in the following chapter. Figure 14.1 shows a block diagram of the OCD interface and the On-chip Debug system. 14.1.2 Feature − Two-wire external interface: 1-wire serial clock input, 1-wire bi-directional serial data bus − Debugger Access to: − − • All Internal Peripheral Units • Internal data RAM • Program Counter • Flash and Data EEPROM Memories Extensive On-chip Debug Support for Break Conditions, Including • Break Instruction • Single Step Break • Program Memory Break Points on Single Address • Programming of Flash, EEPROM, Fuses, and Lock Bits through the two-wire Interface Operating frequency • Supports the maximum frequency of the target MCU Target MCU internal circuit Format converter DSCL USB BDC DBG Control CPU DBGRegister DSDA Address bus Internal data bus Code memory - SRAM - Flash - EEPROM User I/O Figure 14.1 Block Diagram of On-Chip Debug System 174 Data memory Peripheral A94B114 14.2 ABOV Semiconductor Co., Ltd. Two-Pin External Interface 14.2.1 Basic Transmission Packet • 10-bit packet transmission using two-pin interface. • 1-packet consists of 8-bit data, 1-bit parity and 1-bit acknowledge. • Parity is even of ‘1’ for 8-bit data in transmitter. • Receiver generates acknowledge bit as ‘0’ when transmission for 8-bit data and its parity has no error. • When transmitter has no acknowledge(Acknowledge bit is ‘1’ at tenth clock), error process is executed in transmitter. • When acknowledge error is generated, host PC makes stop condition and transmits command which has error again. • Background debugger command is composed of a bundle of packet. • Start condition and stop condition notify the start and the stop of background debugger command respectively. Figure 14.2 10-bit Transmission Packet 175 A94B114 ABOV Semiconductor Co., Ltd. 14.2.2 Packet Transmission Timing 14.2.2.1 Data Transfer DSDA LSB Acknowledgement Signal from receiver LSB Acknowledgement Signal from receiver DSCL St 1 10 1 ACK START Figure 14.3 Data Transfer on the Twin Bus 14.2.2.2 Bit Transfer DSDA DSCL Data line stable data valid except Start and Stop Figure 14.4 Change of data allowed Bit Transfer on the Serial Bus 176 10 Sp STOP A94B114 ABOV Semiconductor Co., Ltd. 14.2.2.3 Start and Stop Condition DSDA DSCL St Sp START Condition STOP Condition Figure 14.5 Start and Stop Condition 14.2.2.4 Acknowledge Bit Data output By transmitter no acknowledge Data output By receiver acknowledge DSCL from master 1 9 2 10 Clock pulse for acknowledgement Figure 14.6 Acknowledge on the Serial Bus Acknowledge bit transmission Acknowledge bit transmission Minimum 500ns wait HIGH Start HIGH Host PC DSCL OUT Target Device DSCL OUT Start wait Maximum 5TSCLK DSCL Internal Operation Figure 14.7 Clock Synchronization during Wait Procedure 177 Minimum 1TSCLK for next byte transmission A94B114 ABOV Semiconductor Co., Ltd. 14.2.3 Connection of Transmission Two-pin interface connection uses open-drain(wire-AND bidirectional I/O). VDD pull - up resistors Rp Rp DSDA(Debugger Serial Data Line) DSCL(Debugger Serial Clock Line) VDD DSCL OUT DSCL IN VDD DSDA OUT DSCL OUT DSDA IN DSDA OUT DSDA IN DSCL IN Target Device(Slave) Host Machine(Master) Current source for DSCL to fast 0 to 1 transition in high speed mode Figure 14.8 Connection of Transmission 178 A94B114 ABOV Semiconductor Co., Ltd. 15 Memory Programming 15.1 Overview 15.1.1 Description A94B114 has flash memory to which a program can be written, erased, and overwritten while mounted on the board. This device support the self program/erase mode in user soft mode in sram-jump. Serial ISP mode is supported. 15.1.2 Features • Flash Size : 8 Kbytes • Single power supply program and erase • Command interface for fast program and erase operation • Up to 10,000 program/erase cycles at typical voltage and temperature for flash memory • Security feature 15.2 Flash Control and status register Registers to control Flash are Mode Register (FEMR), Control Register (FECR), Status Register (FESR), Time Control Register (FETCR), Address Low Register (FEARL), Address Middle Register (FEARM) and address High Register (FEARH). They are mapped to SFR area and can be accessed only in programming mode. 15.2.1 Register Map Name Address Dir Default Description FEMR F1H R/W 00H Flash Mode Register FECR F2H R/W 03H Flash Control Register FESR F3H R/W 80H Flash Status Register FETCR F4H R/W 00H Flash Time Control Register FEARL F5H R/W 00H Flash Address Low Register FEARM F6H R/W 00H Flash Address Middle Register FEARH F7H R/W 00H Flash Address High Register ENTRY_0 10D8H (XRAM) R/W 00H 0xAA ENTRY_1 10DAH (XRAM) R/W 00H 0x55 ENTRY_2 10DDH (XRAM) R/W 00H 0xA5 PAGE_BUF 10E0H ~ 10FFH R/W 00H Flash Data Buffer Table 15.1 Register MAP 179 A94B114 ABOV Semiconductor Co., Ltd. 15.2.2 Register Description for Flash FEMR (Flash Mode Register) : F1H 7 6 5 4 3 2 1 0 FSEL - PGM ERASE PBUFF OTPE VFY FEEN R/W - R/W R/W R/W R/W R/W FSEL PGM ERASE PBUFF OTPE VFY R/W Initial value : 00H Select flash memory. 0 Deselect flash memory 1 Select flash memory Enable program or program verify mode with VFY 0 Disable program or program verify mode 1 Enable program or program verify mode Enable erase or erase verify mode with VFY 0 Disable erase or erase verify mode 1 Enable erase or erase verify mode Select page buffer 0 Deselect page buffer 1 Select page buffer Select OTP area instead of program memory 0 Deselect OTP area 1 Select OTP area Set program or erase verify mode with PGM or ERASE Program Verify: PGM=1, VFY=1 Erase Verify: ERASE=1, VFY=1 FEEN Enable program and erase of Flash. When inactive, it is possible to read as normal mode 0 Disable program and erase 1 Enable program and erase 180 A94B114 ABOV Semiconductor Co., Ltd. FECR (Flash Control Register) : F2H 7 6 5 4 3 2 1 0 AEF - EXIT1 EXIT0 WRITE READ nFERST nPBRST R/W - R/W R/W R/W R/W R/W AEF EXIT[1:0] WRITE READ R/W Initial value : 03H Enable flash bulk erase mode 0 Disable bulk erase mode of Flash memory 1 Enable bulk erase mode of Flash memory Exit from program mode. It is cleared automatically after 1 clock EXIT1 EXIT0 Description 0 0 Don’t exit from program mode 0 1 Don’t exit from program mode 1 0 Don’t exit from program mode 1 1 Exit from program mode Start to program or erase of Flash. It is cleared automatically after 1 clock 0 No operation 1 Start to program or erase of Flash Start auto-verify of Flash. It is cleared automatically after 1 clock 0 No operation 1 Start auto-verify of Flash nFERST Reset Flash control logic. It is cleared automatically after 1 clock 0 No operation 1 Reset Flash control logic. nPBRST Reset page buffer with PBUFF. It is cleared automatically after 1 clock PBUFF nPBRST Description 0 0 Page buffer reset 1 0 Write checksum reset WRITE and READ bits can be used in program, erase and verify mode with FEAR registers. Read or writes for memory cell or page buffer uses read and write enable signals from memory controller. Indirect address mode with FEAR is only allowed to program, erase and verify 181 A94B114 ABOV Semiconductor Co., Ltd. FESR (Flash Status Register) : F3H 7 6 PEVBSY VFYGOOD R R/W PEVBSY Operation status flag. It is clear automatically when operation starts. Operations are program, erase or verification VFYGOOD ROMINT 5 4 3 2 1 0 - - ROMINT WMODE EMODE VMODE R R R/W R R 0 Busy (Operation processing) 1 Complete Operation R Initial value : 80H Auto-verification result flag. 0 Auto-verification fails 1 Auto-verification successes Flash interrupt request flag. Auto-cleared when program/erase/verify starts. Active in program/erase/verify completion 0 Not interrupt request. 1 Interrupt request. WMODE Write mode flag EMODE Erase mode flag VMODE Verify mode flag FEARL (Flash address low Register) : F5H 7 6 5 4 3 2 1 0 ARL7 ARL6 ARL5 ARL4 ARL3 ARL2 ARL1 ARL0 W W W W W W W W Initial value : 00H ARL[7:0] Flash address low FEARM (Flash address middle Register) : F6H 7 6 5 4 3 2 1 0 ARM7 ARM6 ARM5 ARM4 ARM3 ARM2 ARM1 ARM0 W W W W W W W W Initial value : 00H ARM[7:0] Flash address middle FEARH (Flash address high Register) : F7H 7 6 5 4 3 2 1 0 ARH7 ARH6 ARH5 ARH4 ARH3 ARH2 ARH1 ARH0 W W W W W W W ARH[7:0] W Initial value : 00H Flash address high FEAR registers are used for program, erase and auto-verify. In program and erase mode, it is page address and ignored the same least significant bits as the number of bits of page address. In auto-verify mode, address increases automatically by one. FEARs are write-only register. Reading these registers returns 24-bit checksum result 182 A94B114 ABOV Semiconductor Co., Ltd. FETCR (Flash Time control Register) : F4H 7 6 5 4 3 2 1 0 TCR7 TCR6 TCR5 TCR4 TCR3 TCR2 TCR1 TCR0 R/W R/W R/W R/W R/W R/W R/W TCR[7:0] R/W Initial value : 00H Flash Time control Program and erase time is controlled by setting FETCR register. Program and erase timer uses 10-bit counter. It increases by internal RC oscillator clock frequency (HFO IRC). It is cleared when program or erase starts. Timer stops when 10-bit counter is same to FETCR. PEVBSY is cleared when program, erase or verify starts and set when program, erase or verify stops. Max program/erase time : (255+1) * 2 * (31.25ns * 256) = 4.096ms In the case of 10% of error rate of counter source clock, program or erase time is 3.6~4.5ms * * Program/erase time calculation for page write or erase, Tpe = (TCON+1) * 2 * (31.25ns * 256 ) for bulk erase, Tbe = (TCON+1) * 4 * (31.25ns * 256) Min Typ Max Unit program/erase Time 2.4 2.5 2.6 ms Bulk erase Time - 5.0 - ms Table 15.2 Program/erase Time ※ Recommended program/erase time (FETCR = A0h) 183 A94B114 15.3 ABOV Semiconductor Co., Ltd. Memory map 15.3.1 Flash Memory Map Program memory uses 8-Kbyte of Flash memory. It is read by byte and written by page. One page is 32-byte FFFFh P R O G R A M F E A R pgm/ers/vfy Flash MUX C O U N T E R 1FFFh 8 Kbytes 0000h Figure 15.1 15 Flash Memory Map 14 13 12 11 10 9 8 7 6 PAGE ADDRESS 5 4 3 2 1 WORD ADDRESS Program Memory 0xFF Page 255 0x1F Page 254 0x00 Page 1 0x000 Figure 15.2 Page 0 * Page buffer size: 32Bytes Address configuration of Flash memory 184 0 A94B114 15.4 ABOV Semiconductor Co., Ltd. Serial In-System Program Mode Serial in-system program uses the interface of debugger which uses two wires. Refer to chapter 14 in details about debugger. 15.4.1 Flash operation Configuration (This Configuration is just used for follow description) 7 6 5 4 3 2 1 0 - FEMR[4] & [1] FEMR[5] & [1] - - FEMR[2] FECR[6] FECR[7] - ERASE&VFY PGM&VFY - - OTPE AEE AEF Master Reset Page Buffer Reset Page Buffer Load(0X00H) Page Buffer Reset Page Buffer Load In the case of OTP OTPE flag Set In the case of OTP OTPE flag Set Erase Erase Latency(500us) Program Page Buffer Reset Pgm Latency(500us) Configuration Reg. setting Page Buffer Reset Cell Read Configuration Reg. setting No Pass/Fail? Cell Read Yes Configuration Reg. Clear Figure 15.3 Pass/Fail? The sequence of page program and erase of Flash memory 185 A94B114 ABOV Semiconductor Co., Ltd. Master Reset Page Buffer Reset Page Buffer Load Configuration Reg. Set Erase Erase Latency(500us) Page Buffer Reset Configuration Reg. clear Reg. setting Cell Read Pass/Fail? Figure 15.4 15.4.1.1 The sequence of bulk erase of Flash memory Flash Read Step 1. Enter OCD(=ISP) mode. Step 2. Set ENBDM bit of BCR. Step 3. Enable debug and Request debug mode. Step 4. Read data from Flash. 15.4.1.2 Enable program mode Step 1. Enter OCD(=ISP) mode.1 Step 2. Set ENBDM bit of BCR. Step 3. Enable debug and Request debug mode. Step 4. Enter program/erase mode entry sequence.2 (1) Write 0xAA to 0x10D8 (XRAM). (2) Write 0x55 to 0x10DA (XRAM). (3) Write 0xA5 to 0x10DD (XRAM). 1 Refer to how to enter ISP mode.. 2 Command sequence to activate Flash write/erase mode. It is composed of sequentially writing data of Flash memory. 186 A94B114 15.4.1.3 ABOV Semiconductor Co., Ltd. Flash write mode Step 1. Enable program mode. Step 2. Reset page buffer. FEMR: 1000_0001 FECR:0000_0010 Step 3. Select page buffer. FEMR:1000_1001 Step 4. Write data to page buffer.(Address automatically increases by twin.) Step 5. Set write mode. FEMR:1010_0001 Step 6. Set page address. FEARH:FEARM:FEARL=20’hx_xxxx Step 7. Set FETCR. Step 8. Start program. FECR:0000_1011 Step 9. Insert one NOP operation Step 10. Read FESR until PEVBSY is 1. Step 11. Repeat step2 to step 8 until all pages are written. 15.4.1.4 Flash page erase mode Step 1. Enable program mode. Step 2. Reset page buffer. FEMR: 1000_0001 FECR:0000_0010 Step 3. Select page buffer. FEMR:1000_1001 Step 4. Write ‘h00 to page buffer. (Data value is not important.) Step 5. Set erase mode. FEMR:1001_0001 Step 6. Set page address. FEARH:FEARM:FEARL=20’hx_xxxx Step 7. Set FETCR. Step 8. Start erase. FECR:0000_1011 Step 9. Insert one NOP operation Step 10. Read FESR until PEVBSY is 1. Step 11. Repeat step2 to step 8 until all pages are erased. 15.4.1.5 Flash bulk erase mode Step 1. Enable program mode. Step 2. Reset page buffer. FEMR: 1000_0001 FECR:0000_0010 Step 3. Select page buffer. FEMR:1000_1001 Step 4. Write ‘h00 to page buffer. (Data value is not important.) Step 5. Set erase mode. FEMR:1001_0001. (Only main cell area is erased. For bulk erase including OTP area, select OTP area.(set FEMR to 1000_1101.) Step 6. Set FETCR Step 7. Start bulk erase. FECR:1000_1011 Step 8. Insert one NOP operation Step 9. Read FESR until PEVBSY is 1. 187 A94B114 15.4.1.6 ABOV Semiconductor Co., Ltd. Flash OTP area read mode Step 1. Enter OCD(=ISP) mode. Step 2. Set ENBDM bit of BCR. Step 3. Enable debug and Request debug mode. Step 4. Select OTP area. FEMR:1000_0101 Step 5. Read data from Flash. 15.4.1.7 Flash OTP area write mode Step 1. Enable program mode. Step 2. Reset page buffer. FEMR: 1000_0001 FECR:0000_0010 Step 3. Select page buffer. FEMR:1000_1001 Step 4. Write data to page buffer.(Address automatically increases by twin.) Step 5. Set write mode and select OTP area. FEMR:1010_0101 Step 6. Set page address. FEARH:FEARM:FEARL=20’hx_xxxx Step 7. Set FETCR. Step 8. Start program. FECR:0000_1011 Step 9. Insert one NOP operation Step 10. Read FESR until PEVBSY is 1. 15.4.1.8 Flash OTP area erase mode Step 1. Enable program mode. Step 2. Reset page buffer. FEMR: 1000_0001 FECR:0000_0010 Step 3. Select page buffer. FEMR:1000_1001 Step 4. Write ‘h00 to page buffer. (Data value is not important.) Step 5. Set erase mode and select OTP area. FEMR:1001_0101 Step 6. Set page address. FEARH:FEARM:FEARL=20’hx_xxxx Step 7. Set FETCR. Step 8. Start erase. FECR:0000_1011 Step 9. Insert one NOP operation Step 10. Read FESR until PEVBSY is 1. 15.4.1.9 Flash program verify mode Step 1. Enable program mode. Step 2. Set program verify mode. FEMR:1010_0011 Step 3. Read data from Flash. 188 A94B114 ABOV Semiconductor Co., Ltd. 15.4.1.10 OTP program verify mode Step 1. Enable program mode. Step 2. Set program verify mode. FEMR:1010_0111 Step 3. Read data from Flash. 15.4.1.11 Flash erase verify mode Step 1. Enable program mode. Step 2. Set erase verify mode. FEMR:1001_0011 Step 3. Read data from Flash. 15.4.1.12 Flash page buffer read Step 1. Enable program mode. Step 2. Select page buffer. FEMR:1000_1001 Step 3. Read data from Flash. 15.4.2 Summary of Flash Program/Erase Mode Operation mode F L A S H Description Flash read Read cell by byte. Flash write Write cell by page. Flash page erase Erase cell by page. Flash bulk erase Erase the whole cells. Flash program verify Read cell in verify mode after programming. Flash erase verify Read cell in verify mode after erase. Flash page buffer load Load data to page buffer. Table 15.3 Operation Mode 189 A94B114 15.5 ABOV Semiconductor Co., Ltd. Mode entrance method of ISP mode TARGET MODE DSDA DSCL DSDA OCD(ISP) ‘hC ‘hC ‘hC Release from worst 1.7V Power on reset Low period required during more 10us RESET DSCL DSDA RESET_SYSB Figure 15.5 ISP mode 190 A94B114 15.6 ABOV Semiconductor Co., Ltd. SRAM-Jump Program mode In this device SRAM-jump program is used to self programing in user mode. When writing the flash data memory, cpu should operate in sram not flash. SRAM address 0x00 is assigned to program address 0x8000. Refer to the following example. main() { .... // 1. Flash mode entry with movx instruction *(unsigned char xdata *)0x10D8 = 0xAA; *(unsigned char xdata *)0x10DA = 0x55; *(unsigned char xdata *)0x10DD = 0xA5; FETCR = 0x9D; // 2.5ms PGM time FEMR = 0x81; FECR = 0x02; // 3. Reset page buffer write_page_buffer(); // 4. Write page buffer void write_page_buffer() { #pragma asm mov dptr,#write_page_buffer_src mov r0,#0x30 mov r2,#0x12 ;sram write_page_buffer_loop: clr a movc a,@a+dptr mov @r0,a inc dptr inc r0 djnz r2,write_page_buffer_loop ljmp 0x8030 ; jump sram region #pragma endasm } do_flash_at_sram(); // 5. Write flash FECR = 0x33; // 6. Flash mode exit .... Return ; } void write_page_buffer_src() { FEMR = 0x81; #pragma asm mov r0,#32 mov dptr,#0x10E0 ; page buffer address write_page_buffer_src_loop: mov a, @r1 // write data is written in the SRAM // previosly and r1 has the address movx @dptr,a inc r1 inc dptr djnz r0,write_page_buffer_src_loop #pragma endasm void do_flash_at_sram_src() { FEMR = 0xA1; // FECR = 0x0B; // Enable program while( !(FESR & 0x80) ); FEMR = 0; } void do_flash_at_sram() { #pragma asm mov dptr,#do_flash_at_sram_src mov r0,#0x30 mov r1,#0x13 do_flash_at_sram_loop: clr a movc a,@a+dptr mov @r0,a inc dptr inc r0 djnz r1,do_flash_at_sram_loop ljmp 0x8030 #pragma endasm } Figure 15.6 FEMR = 0; } Code example of flash write by SRAM-jump mode 191 A94B114 ABOV Semiconductor Co., Ltd. main FLASH MEMORY ... Flash mode entry SRAM MEMORY Set PGM time (code size : 0x13) Reset page buffer 0x30 write_page_buffer_src() write_page_buffer_src() 0x42 function call (write_page_buffer()) write_page_buffer() jump 0x8030 (code size : 0x14) 0x30 do_flash_at_sram_src() do_flash_at_sram_src() 0x43 function call (do_flash_at_sram()) Flash mode exit ... Figure 15.7 do_flash_at_sram() jump 0x8030 The A94B114 uses the following method to prevent malfunction during Flash write operation. Instead of the code memory, the execution code is copied to the SRAM to perform the flash write operation. When SRAM code is executed, the start address is 0x8000 and this address is used to jump to IRAM 0x00 address. In this diagram, the Write_page_buffer_src () function is the code for the Flash write operation, which indicates that function is copied to the SRAM and the corresponding part is executed. Memory diagram and flow of flash write by SRAM-jump mode 192 A94B114 ABOV Semiconductor Co., Ltd. 16 Configure Option 16.1 Configure Option Control FUSE_CFG0 (Pseudo-Configure Data) 7 6 5 4 3 2 1 0 RSTEN – XOENA XIENA – LOCKVA LOCKHL LOCKF R – R R – R R RSTEN XOENA Select RESETB pin 0 Disable RESETB pin (default) 1 Enable RESETB pin Enable Main OSC output 0 XIENA Disable 1 Enable Enable Main OSC input 0 LCKVA R Initial value : 00H Disable 1 Enable Vector Area(00~FF) Protection selection 0 Enable protection (Not erasable by instruction) 1 LOCKHL Disable protection (Erasable by instruction) Code Write Protection 0 LOCKF Enable protection 1 Disable protection Code Read Protection 0 Disable protection 1 Enable protection FUSE_CFG1 (Pseudo-Configure Data) 7 6 5 4 3 2 1 0 – – – – PASEL PASS2 PASS1 PASS0 – – – – R R R PASEL PASS[2:0] R Initial value : 00H Specific Area Write Protection Selection 0 Enable protection (Not erasable by instruction) 1 Disable protection (Erasable by instruction) When PASEL is 0 (Enable protection), Code write protection is possible in the set address area. 0 0 0 0100H ~ 1BFFH 0 0 1 0100H ~ 1DFFH 0 1 0 0100H ~ 1EFFH 0 1 1 0100H ~ 1F7FH 1 0 1 0100H ~ 17FFH 1 1 0 0100H ~ 0FFFH 1 1 1 0100H ~ 07FFH 193 A94B114 ABOV Semiconductor Co., Ltd. 17 APPENDIX 17.1 Instruction Table Instructions are either 1, 2 or 3 bytes long as listed in the ‘Bytes’ column below. Each instruction takes either 1, 2, 3, 4 or 5 machine cycles to execute as listed in the following table. 1 machine cycle comprises 1 system clock cycles. ARITHMETIC Mnemonic Description Bytes Clocks Hex code ADD A,Rn ADD A,dir ADD A,@Ri ADD A,#data ADDC A,Rn ADDC A,dir ADDC A,@Ri ADDC A,#data SUBB A,Rn SUBB A,dir SUBB A,@Ri SUBB A,#data INC A INC Rn INC dir INC @Ri DEC A DEC Rn DEC dir DEC @Ri INC DPTR MUL AB DIV AB DA A NOTE1 Add register to A Add direct byte to A Add indirect memory to A Add immediate to A Add register to A with carry Add direct byte to A with carry Add indirect memory to A with carry Add immediate to A with carry Subtract register from A with borrow Subtract direct byte from A with borrow Subtract indirect memory from A with borrow Subtract immediate from A with borrow Increment A Increment register Increment direct byte Increment indirect memory Decrement A Decrement register Decrement direct byte Decrement indirect memory Increment data pointer Multiply A by B Divide A by B Decimal Adjust A 1 2 1 2 1 2 1 2 1 2 1 2 1 1 2 1 1 1 2 1 1 1 1 1 2 3 3 2 2 3 3 2 2 3 3 2 1 2 3 3 1 2 3 3 1 8 8 1 28-2F 25 26-27 24 38-3F 35 36-37 34 98-9F 95 96-97 94 04 08-0F 05 06-07 14 18-1F 15 16-17 A3 A4 84 D4 LOGICAL Mnemonic Description Bytes Clocks Hex code ANL A,Rn ANL A,dir ANL A,@Ri ANL A,#data ANL dir,A ANL dir,#data ORL A,Rn ORL A,dir ORL A,@Ri ORL A,#data ORL dir,A ORL dir,#data XRL A,Rn XRL A,dir XRL A, @Ri XRL A,#data XRL dir,A XRL dir,#data CLR A CPL A SWAP A AND register to A AND direct byte to A AND indirect memory to A AND immediate to A AND A to direct byte AND immediate to direct byte OR register to A OR direct byte to A OR indirect memory to A OR immediate to A OR A to direct byte OR immediate to direct byte Exclusive-OR register to A Exclusive-OR direct byte to A Exclusive-OR indirect memory to A Exclusive-OR immediate to A Exclusive-OR A to direct byte Exclusive-OR immediate to direct byte Clear A Complement A Swap Nibbles of A 1 2 1 2 2 3 1 2 1 2 2 3 1 2 1 2 2 3 1 1 1 2 3 3 2 3 3 2 3 3 2 3 3 2 3 3 2 3 3 1 1 1 58-5F 55 56-57 54 52 53 48-4F 45 46-47 44 42 43 68-6F 65 66-67 64 62 63 E4 F4 C4 194 A94B114 RL A RLC A RR A RRC A ABOV Semiconductor Co., Ltd. Rotate A left Rotate A left through carry Rotate A right Rotate A right through carry 1 1 1 1 1 1 1 1 23 33 03 13 DATA TRANSFER Mnemonic Description Bytes Clocks Hex code MOV A,Rn MOV A,dir MOV A,@Ri MOV A,#data MOV Rn,A MOV Rn,dir MOV Rn,#data MOV dir,A MOV dir,Rn MOV dir,dir MOV dir,@Ri MOV dir,#data MOV @Ri,A MOV @Ri,dir MOV @Ri,#data MOV DPTR,#data MOVC A,@A+DPTR MOVC A,@A+PC MOVX A,@Ri MOVX A,@DPTR MOVX @Ri,A MOVX @DPTR,A PUSH dir POP dir XCH A,Rn XCH A,dir XCH A,@Ri XCHD A,@Ri Move register to A Move direct byte to A Move indirect memory to A Move immediate to A Move A to register Move direct byte to register Move immediate to register Move A to direct byte Move register to direct byte Move direct byte to direct byte Move indirect memory to direct byte Move immediate to direct byte Move A to indirect memory Move direct byte to indirect memory Move immediate to indirect memory Move immediate to data pointer Move code byte relative DPTR to A Move code byte relative PC to A Move external data(A8) to A Move external data(A16) to A Move A to external data(A8) Move A to external data(A16) Push direct byte onto stack (except PUSH SP)NOTE1 Pop direct byte from stack (except POP SP)NOTE1 Exchange A and register Exchange A and direct byte Exchange A and indirect memory Exchange A and indirect memory nibble 1 2 1 2 1 2 2 2 2 3 2 3 1 2 2 3 1 1 1 1 1 1 2 2 1 2 1 1 2 3 3 2 2 3 2 2 2 3 3 3 2 3 3 3 2 2 2 2 1 1 3 3 2 4 3 3 E8-EF E5 E6-E7 74 F8-FF A8-AF 78-7F F5 88-8F 85 86-87 75 F6-F7 A6-A7 76-77 90 93 83 E2-E3 E0 F2-F3 F0 C0 D0 C8-CF C5 C6-C7 D6-D7 BOOLEAN Mnemonic Description Bytes Clocks Hex code CLR C CLR bit SETB C SETB bit CPL C CPL bit ANL C,bit ANL C,/bit ORL C,bit ORL C,/bit MOV C,bit MOV bit,C Clear carry Clear direct bit Set carry Set direct bit Complement carry Complement direct bit AND direct bit to carry AND direct bit inverse to carry OR direct bit to carry OR direct bit inverse to carry Move direct bit to carry Move carry to direct bit 1 2 1 2 1 2 2 2 2 2 2 2 1 3 1 3 1 3 3 3 3 3 3 3 C3 C2 D3 D2 B3 B2 82 B0 72 A0 A2 92 195 A94B114 ABOV Semiconductor Co., Ltd. BRANCHING Mnemonic Description Bytes Clocks Hex code ACALL addr 11 LCALL addr 16 RET RETI AJMP addr 11 LJMP addr 16 SJMP rel JC rel JNC rel JB bit,rel JNB bit,rel JBC bit,rel JMP @A+DPTR JZ rel JNZ rel CJNE A,dir,rel CJNE A,#d,rel CJNE Rn,#d,rel CJNE @Ri,#d,rel DJNZ Rn,rel DJNZ dir,rel Absolute jump to subroutine Long jump to subroutine Return from subroutine Return from interrupt Absolute jump unconditional Long jump unconditional Short jump (relative address) Jump on carry = 1 Jump on carry = 0 Jump on direct bit = 1 Jump on direct bit = 0 Jump on direct bit = 1 and clear Jump indirect relative DPTR Jump on accumulator = 0 Jump on accumulator ≠0 Compare A,direct jne relative Compare A,immediate jne relative Compare register, immediate jne relative Compare indirect, immediate jne relative Decrement register, jnz relative Decrement direct byte, jnz relative 2 3 1 1 2 3 2 2 2 3 3 3 1 2 2 3 3 3 3 2 3 4 2 4 4 3 4 3 3 3 5 5 5 2 3 3 5 4 4 5 4 5 11→F1 12 22 32 01→E1 02 80 40 50 20 30 10 73 60 70 B5 B4 B8-BF B6-B7 D8-DF D5 MISCELLANEOUS Mnemonic Description Bytes Clocks Hex code NOP No operation 1 1 00 In the above table, an entry such as E8-EF indicates a continuous block of hex opcodes used for 8 different registers, the register numbers of which are defined by the lowest three bits of the corresponding code. Non-continuous blocks of codes, shown as 11→F1 (for example), are used for absolute jumps and calls, with the top 3 bits of the code being used to store the top three bits of the destination address. The CJNE instructions use the abbreviation #d for immediate data; other instructions use #data. NOTE1) PUSH SP, POP SP, and DA instruction behave differently from 8051 operations. The use of this instruction only occurs when using the assembly language, and its use is very limited. Refer to "ERRATA_ABOV_94 CPU(CM8051) Incompatible Instruction" for more details. 17.2 Package relation A94B114FR (20-Pin) A94B114FD (20-Pin) A94B114AE (13-Pin) Pin count 20 16 Max I/O 18 14 Difference (removed functions on standard A94B114) - AN8, AN9, EINT1, EINT10 EC0, T0O, PWM1OB 196 A94B114 ABOV Semiconductor Co., Ltd. Table of contents Revision history ............................................................................................................................................................................ 2 1 Overview ................................................................................................................................................................................. 3 1.1. Description ..................................................................................................................................................................................................3 1.2 Features.........................................................................................................................................................................................................4 1.3 Development tools ..................................................................................................................................................................................5 1.3.1 Compiler ..............................................................................................................................................................................................5 1.3.2 OCD2 emulator and debugger ................................................................................................................................................5 1.3.3 Programmer .......................................................................................................................................................................................7 1.3.4 Circuit Design Guide................................................................................................................................................................... 10 2 Block diagram ...................................................................................................................................................................... 11 3 Pin assignment .................................................................................................................................................................... 12 4 Package Diagram ................................................................................................................................................................ 14 5 Pin Description .................................................................................................................................................................... 17 6 Port Structures .................................................................................................................................................................... 19 7 6.1 General Purpose I/O Port .................................................................................................................................................................. 19 6.2 External Interrupt I/O Port ................................................................................................................................................................ 20 Electrical Characteristics ................................................................................................................................................... 21 7.1 Absolute Maximum Ratings ............................................................................................................................................................. 21 7.2 Recommended Operating Conditions ......................................................................................................................................... 21 7.3 Low Drop Out Characteristics ......................................................................................................................................................... 21 7.4 A/D Converter Characteristics ......................................................................................................................................................... 22 7.5 Low Voltage Reset and Low Voltage Indicator Characteristics ........................................................................................ 22 7.6 Power-On Reset Characteristics ...................................................................................................................................................... 22 7.7 Internal High Frequency Oscillator Characteristics ................................................................................................................ 23 7.8 Internal Low Frequency Oscillator Characteristics ................................................................................................................. 23 7.9 Comparator Characteristics .............................................................................................................................................................. 23 7.10 DC Characteristics ................................................................................................................................................................................. 24 7.11 AC Characteristics ................................................................................................................................................................................. 24 7.12 USART Characteristics ......................................................................................................................................................................... 25 7.13 I2C Characteristics ................................................................................................................................................................................. 26 7.14 Data Retention Voltage in Stop Mode ........................................................................................................................................ 27 7.15 Internal Flash Rom Characteristics ................................................................................................................................................ 28 7.15.1 Internal Flash Rom Characteristics (Sector 248~255) ................................................................................................. 28 7.16 Input / Output Capacitance ............................................................................................................................................................. 28 7.17 Main Clock Oscillator Characteristics ........................................................................................................................................... 29 7.18 Main Oscillation Stabilization Characteristics ........................................................................................................................... 30 7.19 Operating Voltage Range .................................................................................................................................................................. 30 197 A94B114 ABOV Semiconductor Co., Ltd. 7.20 Recommended Circuit and Layout ................................................................................................................................................ 31 7.21 Typical Characteristics ......................................................................................................................................................................... 32 8 Memory ................................................................................................................................................................................. 33 8.1 Program Memory .................................................................................................................................................................................. 33 8.2 Data Memory .......................................................................................................................................................................................... 34 8.3 External Data Memory ........................................................................................................................................................................ 36 8.4 SFR Map .................................................................................................................................................................................................... 37 9 8.4.1 SFR Map Summary...................................................................................................................................................................... 37 8.4.2 SFR Map ........................................................................................................................................................................................... 38 8.4.3 8051 Compiler Compatible SFR ............................................................................................................................................ 42 I/O Ports ................................................................................................................................................................................ 44 9.1 I/O Ports .................................................................................................................................................................................................... 44 9.2 Port Register ............................................................................................................................................................................................ 44 9.2.1 Data Register (Px) ........................................................................................................................................................................ 44 9.2.2 Direction Register (PxIO) .......................................................................................................................................................... 44 9.2.3 Pull-up Resistor Selection Register (PxPU) ....................................................................................................................... 44 9.2.4 Open-drain Selection Register (PxOD)............................................................................................................................... 44 9.2.5 De-bounce Enable Register (PxDB) ..................................................................................................................................... 44 9.2.6 Port Function Selection Register (PxFSR) .......................................................................................................................... 44 9.2.7 De-bounce Time Selection Register (DBTSR) .................................................................................................................. 45 9.2.8 Register Map .................................................................................................................................................................................. 45 9.3 P0 Port ........................................................................................................................................................................................................ 46 9.3.1 P0 Port Description ..................................................................................................................................................................... 46 9.3.2 Register description for P0 ...................................................................................................................................................... 46 9.4 P1 Port ........................................................................................................................................................................................................ 50 9.4.1 P1 Port Description ..................................................................................................................................................................... 50 9.4.2 Register description for P1 ...................................................................................................................................................... 50 9.5 P2 Port ........................................................................................................................................................................................................ 54 9.5.1 P2 Port Description ..................................................................................................................................................................... 54 9.5.2 Register description for P2 ...................................................................................................................................................... 54 10 Interrupt Controller ......................................................................................................................................................... 56 10.1 Overview .................................................................................................................................................................................................... 56 10.2 External Interrupt ................................................................................................................................................................................... 57 10.3 Block Diagram ........................................................................................................................................................................................ 58 10.4 Interrupt Vector Table ......................................................................................................................................................................... 59 10.5 Interrupt Sequence ............................................................................................................................................................................... 60 10.6 Effective Timing after Controlling Interrupt Bit ....................................................................................................................... 61 10.7 Multi Interrupt ........................................................................................................................................................................................ 61 10.8 Interrupt Enable Accept Timing ..................................................................................................................................................... 62 198 A94B114 10.9 ABOV Semiconductor Co., Ltd. Interrupt Service Routine Address ................................................................................................................................................ 62 10.10 Saving/Restore General-Purpose Registers .......................................................................................................................... 62 10.11 Interrupt Timing ................................................................................................................................................................................ 63 10.12 Interrupt Register Overview ......................................................................................................................................................... 64 10.12.1 Interrupt Enable Register (IE, IE1, IE2) ........................................................................................................................... 64 10.12.2 Interrupt Priority Register (IP, IP1, IP2) .......................................................................................................................... 64 10.12.3 Interrupt Request Register (IRQ0, IRQ1, IRQ2) .......................................................................................................... 64 10.12.4 Interrupt Offset Register (IOFFSET) ................................................................................................................................. 64 10.12.5 Interrupt Nesting level Register (ILVL) ........................................................................................................................... 64 10.12.6 External Interrupt Flag Register (EIFLAG) ..................................................................................................................... 64 10.12.7 External Interrupt Polarity Register (EIPOL0, EIPOL1) ............................................................................................. 64 10.12.8 Register Map ............................................................................................................................................................................. 65 10.12.9 Interrupt Register Description ........................................................................................................................................... 66 11 Peripheral Hardware ....................................................................................................................................................... 75 11.1 Clock Generator ..................................................................................................................................................................................... 75 11.1.1 Overview .......................................................................................................................................................................................... 75 11.1.2 Block Diagram ............................................................................................................................................................................... 75 11.1.3 Register Map .................................................................................................................................................................................. 76 11.1.4 Clock Generator Register Description ................................................................................................................................ 76 11.1.5 Register Description for Clock Generator ......................................................................................................................... 76 11.2 Basic Interval Timer .............................................................................................................................................................................. 78 11.2.1 Overview .......................................................................................................................................................................................... 78 11.2.2 Block Diagram ............................................................................................................................................................................... 78 11.2.3 Register Map .................................................................................................................................................................................. 78 11.2.4 Basic Interval Timer Register Description ......................................................................................................................... 79 11.2.5 Register Description for Basic Interval Timer ................................................................................................................. 79 11.3 Watch Dog Timer .................................................................................................................................................................................. 80 11.3.1 Overview .......................................................................................................................................................................................... 80 11.3.2 Block Diagram ............................................................................................................................................................................... 80 11.3.3 WDT Interrupt Timing Waveform ......................................................................................................................................... 81 11.3.4 Register Map .................................................................................................................................................................................. 81 11.3.5 Watch Dog Timer Register Description ............................................................................................................................. 81 11.3.6 Register Description for Watch Dog Timer...................................................................................................................... 82 11.4 Timer 0 ....................................................................................................................................................................................................... 83 11.4.1 Overview .......................................................................................................................................................................................... 83 11.4.2 8-bit Timer/Counter Mode ...................................................................................................................................................... 84 11.4.3 8-bit PWM Mode ......................................................................................................................................................................... 85 11.4.4 8-bit Capture Mode .................................................................................................................................................................... 87 11.4.5 Block Diagram ............................................................................................................................................................................... 89 11.4.6 Register Map .................................................................................................................................................................................. 89 199 A94B114 ABOV Semiconductor Co., Ltd. 11.4.7 Timer/Counter 0 Register Description ............................................................................................................................... 89 11.4.8 Register Description for Timer/Counter 0 ........................................................................................................................ 90 11.5 Timer 1 ....................................................................................................................................................................................................... 92 11.5.1 Overview .......................................................................................................................................................................................... 92 11.5.2 16-bit Timer/Counter Mode ................................................................................................................................................... 92 11.5.3 16-bit Capture Mode ................................................................................................................................................................. 94 11.5.4 16-bit PPG Mode ......................................................................................................................................................................... 96 11.5.5 16-bit Complementary PWM mode (Dead Time) ........................................................................................................ 98 11.5.6 Block Diagram ............................................................................................................................................................................ 100 11.5.7 Register Map ............................................................................................................................................................................... 100 11.5.8 Timer/Counter 1 Register Description ............................................................................................................................ 101 11.5.9 Register Description for Timer/Counter 1 ..................................................................................................................... 101 11.6 Timer 2 .................................................................................................................................................................................................... 105 11.6.1 Overview ....................................................................................................................................................................................... 105 11.6.2 16-bit Timer/Counter Mode ................................................................................................................................................ 106 11.6.3 16-bit Capture Mode .............................................................................................................................................................. 108 11.6.4 16-bit PPG Mode ...................................................................................................................................................................... 110 11.6.5 Block Diagram ............................................................................................................................................................................ 112 11.6.6 Register Map ............................................................................................................................................................................... 112 11.6.7 Timer/Counter 2 Register Description ............................................................................................................................ 113 11.6.8 Register Description for Timer/Counter 2 ..................................................................................................................... 113 11.7 12-bit A/D Converter........................................................................................................................................................................ 116 11.7.1 Overview ....................................................................................................................................................................................... 116 11.7.2 Block Diagram ............................................................................................................................................................................ 116 11.7.3 ADC Operation ........................................................................................................................................................................... 117 11.7.4 Register Map ............................................................................................................................................................................... 119 11.7.5 Register Description for ADC .............................................................................................................................................. 119 11.8 Comparator ........................................................................................................................................................................................... 123 11.8.1 Overview ....................................................................................................................................................................................... 123 11.8.2 Block Diagram ............................................................................................................................................................................ 123 11.8.3 Register map ............................................................................................................................................................................... 123 11.8.4 Register Description for Comparator............................................................................................................................... 124 11.9 USART ...................................................................................................................................................................................................... 127 11.9.1 Overview ....................................................................................................................................................................................... 127 11.9.2 Block Diagram ............................................................................................................................................................................ 128 11.9.3 Clock Generation ....................................................................................................................................................................... 129 11.9.4 External Clock (XCK) ................................................................................................................................................................ 130 11.9.5 Synchronous mode Operation ............................................................................................................................................ 130 11.9.6 Data format ................................................................................................................................................................................. 131 11.9.7 Parity bit ........................................................................................................................................................................................ 131 200 A94B114 ABOV Semiconductor Co., Ltd. 11.9.8 USART Transmitter .................................................................................................................................................................... 132 11.9.8.1 Sending Tx data .........................................................................................................................................................................................132 11.9.8.2 Transmitter flag and interrupt .............................................................................................................................................................132 11.9.8.3 Parity Generator .........................................................................................................................................................................................132 11.9.8.4 Disabling Transmitter ...............................................................................................................................................................................133 11.9.9 USART Receiver .......................................................................................................................................................................... 133 11.9.9.1 Receiving Rx data ......................................................................................................................................................................................133 11.9.9.2 Receiver flag and interrupt ...................................................................................................................................................................133 11.9.9.3 Parity Checker .............................................................................................................................................................................................134 11.9.9.4 Disabling Receiver .....................................................................................................................................................................................134 11.9.9.5 Asynchronous Data Reception ............................................................................................................................................................134 11.9.10 11.9.10.1 SPI Mode .................................................................................................................................................................................. 136 SPI Clock formats and timing .............................................................................................................................................................136 11.9.11 Register Map .......................................................................................................................................................................... 138 11.9.12 USART Register Description ............................................................................................................................................ 138 11.9.13 Register Description for USART ..................................................................................................................................... 139 11.9.14 Baud Rate setting (example) ........................................................................................................................................... 144 11.9.15 0% Error Baud Rate ............................................................................................................................................................. 145 11.10 I2C......................................................................................................................................................................................................... 146 11.10.1 Overview ................................................................................................................................................................................... 146 11.10.2 Block Diagram........................................................................................................................................................................ 146 11.10.3 I2C bit Transfer ...................................................................................................................................................................... 147 11.10.4 Start / Repeated Start / Stop .......................................................................................................................................... 147 11.10.5 Data Transfer .......................................................................................................................................................................... 148 11.10.6 Acknowledge .......................................................................................................................................................................... 148 11.10.7 Synchronization / Arbitration.......................................................................................................................................... 149 11.10.8 Operation ................................................................................................................................................................................. 150 11.10.8.1 Master Transmitter ....................................................................................................................................................................................150 11.10.8.2 Master Receiver ..........................................................................................................................................................................................151 11.10.8.3 Slave Transmitter........................................................................................................................................................................................153 11.10.8.4 Slave Receiver..............................................................................................................................................................................................153 11.10.9 Register Map .......................................................................................................................................................................... 154 11.10.10 I2C Register Description .................................................................................................................................................... 154 11.10.11 Register Description for I2C ............................................................................................................................................ 155 11.11 CRC ....................................................................................................................................................................................................... 159 11.11.1 Overview ................................................................................................................................................................................... 159 11.11.2 Block Diagram........................................................................................................................................................................ 159 11.11.3 Register Map .......................................................................................................................................................................... 159 11.11.4 CRC Register description .................................................................................................................................................. 160 12 12.1 Power Down Operation ................................................................................................................................................ 162 Overview ................................................................................................................................................................................................. 162 201 A94B114 ABOV Semiconductor Co., Ltd. 12.2 Peripheral Operation in IDLE/STOP Mode.............................................................................................................................. 162 12.3 IDLE Mode ............................................................................................................................................................................................. 163 12.4 STOP Mode ........................................................................................................................................................................................... 164 12.5 Release Operation of STOP Mode ............................................................................................................................................. 165 12.6 Register Map ........................................................................................................................................................................................ 166 12.7 Power Down Operation Register Description ....................................................................................................................... 166 12.8 Register Description for Power Down Operation................................................................................................................ 166 13 RESET ............................................................................................................................................................................. 167 13.1 Overview ................................................................................................................................................................................................. 167 13.2 Reset Source ......................................................................................................................................................................................... 167 13.3 Block Diagram ..................................................................................................................................................................................... 167 13.4 RESET Noise Canceller ..................................................................................................................................................................... 168 13.5 Power on RESET .................................................................................................................................................................................. 168 13.6 External RESETB Input ...................................................................................................................................................................... 170 13.7 Low Voltage Reset and Low Voltage Indicator Processor ............................................................................................... 171 13.8 Register Map ........................................................................................................................................................................................ 171 13.9 Reset Operation Register Description ...................................................................................................................................... 171 13.10 14 Register Description for Reset Operation .......................................................................................................................... 172 On-chip Debug System ................................................................................................................................................ 174 14.1 Overview ................................................................................................................................................................................................. 174 14.1.1 Description ................................................................................................................................................................................... 174 14.1.2 Feature ........................................................................................................................................................................................... 174 14.2 Two-Pin External Interface ............................................................................................................................................................. 175 14.2.1 Basic Transmission Packet ..................................................................................................................................................... 175 14.2.2 Packet Transmission Timing ................................................................................................................................................. 176 14.2.2.1 Data Transfer................................................................................................................................................................................................176 14.2.2.2 Bit Transfer ....................................................................................................................................................................................................176 14.2.2.3 Start and Stop Condition ......................................................................................................................................................................177 14.2.2.4 Acknowledge Bit ........................................................................................................................................................................................177 14.2.3 15 Connection of Transmission ................................................................................................................................................. 178 Memory Programming ................................................................................................................................................. 179 15.1 Overview ................................................................................................................................................................................................. 179 15.1.1 Description ................................................................................................................................................................................... 179 15.1.2 Features ......................................................................................................................................................................................... 179 15.2 Flash Control and status register ................................................................................................................................................ 179 15.2.1 Register Map ............................................................................................................................................................................... 179 15.2.2 Register Description for Flash ............................................................................................................................................. 180 15.3 Memory map ....................................................................................................................................................................................... 184 15.3.1 Flash Memory Map .................................................................................................................................................................. 184 202 A94B114 15.4 ABOV Semiconductor Co., Ltd. Serial In-System Program Mode ................................................................................................................................................. 185 15.4.1 Flash operation .......................................................................................................................................................................... 185 15.4.1.1 Flash Read .....................................................................................................................................................................................................186 15.4.1.2 Enable program mode ............................................................................................................................................................................186 15.4.1.3 Flash write mode .......................................................................................................................................................................................187 15.4.1.4 Flash page erase mode ..........................................................................................................................................................................187 15.4.1.5 Flash bulk erase mode............................................................................................................................................................................187 15.4.1.6 Flash OTP area read mode ...................................................................................................................................................................188 15.4.1.7 Flash OTP area write mode ..................................................................................................................................................................188 15.4.1.8 Flash OTP area erase mode .................................................................................................................................................................188 15.4.1.9 Flash program verify mode ..................................................................................................................................................................188 15.4.1.10 OTP program verify mode ....................................................................................................................................................................189 15.4.1.11 Flash erase verify mode .........................................................................................................................................................................189 15.4.1.12 Flash page buffer read ...........................................................................................................................................................................189 15.4.2 Summary of Flash Program/Erase Mode ....................................................................................................................... 189 15.5 Mode entrance method of ISP mode ...................................................................................................................................... 190 15.6 SRAM-Jump Program mode ......................................................................................................................................................... 191 16 16.1 17 Configure Option ........................................................................................................................................................... 193 Configure Option Control .............................................................................................................................................................. 193 APPENDIX....................................................................................................................................................................... 194 17.1 Instruction Table ................................................................................................................................................................................. 194 17.2 Package relation.................................................................................................................................................................................. 196 Table of contents ....................................................................................................................................................................... 197 203
A94B114FRN 价格&库存
很抱歉,暂时无法提供与“A94B114FRN”相匹配的价格&库存,您可以联系我们找货
