ASPL78L05DI-R
ASPL78L05DI-R
    ASCEND(安森德)
    SOT89
    输出类型:-;
ASPL78L05DI-R 数据手册
ASPL78L05 LINEAR INTEGRATED CIRCUIT 概述 General Description 特点 Features The 78L05 of three terminal positive regulators is designed to output 5V/100mA for a wide range of applications, such as on-card regulation for elimination of noise and distribution problems associated with single-point regulation. In addition, the chip can be used with power-pass elements to make high-current voltage regulators. The internal limiting and thermal-shutdown features of the regulatoressentially make 78L05 immune to overload. The 78L05 is available in the plastic TO-92,SOT-223,SOP-8,and SOT-89 packages. 78L05 是一种三端调整器,输出+5V/100mA 电流,应用广泛。例如可用作板卡调整器降低 噪声,和单点调整器结合起来解决分布式电源 问题。而且,这款芯片和功率调整元件组合可 以输出大电流。内置的限流和热关断保护 78L05 免于过载烧毁。78L05 提供三种塑料封 装:TO-92, SOT-223,SOP-8和 SOT-89。      全温度范围内输出电压精度:±3% Output voltage tolerance of over the temperature range ±3% 输出电流 100mA Output current of 100mA 内置过热保护 Internal thermal overload protection 内置过流保护 Internal over-current protection 无需外部元件 No external component 应用 Applications     高效率线性调整器 High Efficiency Linear Regulator 开关电源的后级调整器 Post Regulation for Switching Supply 为微处理器提供电源 Microprocessor Power Supply 主板的 I/O 端口电源 Mother Board I/O Power Supply Figure 1. Package Type of 78L05 FEB 2019 Version1.0 1/15 Ascend Semicondutor Co.,Ltd ASPL78L05 LINEAR INTEGRATED CIRCUIT 管脚说明 Pin Configuration Figure 2. Pin Configuration of 78L05 (Top view) FEB 2019 Version1.0 2/15 Ascend Semicondutor Co.,Ltd ASPL78L05 LINEAR INTEGRATED CIRCUIT 功能框图 Functional Block Diagram Figure 3. Functional Block Diagram of 78L05 绝对最大额定值 Absolute Maximum Rating (Note 1) 项目 Parameter 符号 Symbol 数值 Value 单位 Unit 输入电压 Input Voltage VIN 30 V 结温 Junction Temperature TJ 150 ℃ TLEAD 260 ℃ 焊接温度 Lead Temperature (Soldering, 10sec) PD 功耗 Power Dissipation(TA=25℃) 存储温度 Storage Temperature Range FEB 2019 Version1.0 TSTG 3/15 TO-92 0.65 SOT-223 0.7 SOT-89 0.65 SOP-8 0.83 -50 to 150 W ℃ Ascend Semicondutor Co.,Ltd ASPL78L05 LINEAR INTEGRATED CIRCUIT Note 1: Stresses greater than those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation of the device at these or any other conditions beyond those indicated under “Recommended Operating Conditions” is not implied. Exposure to “Absolute Maximum Ratings” for extended periods may affect device reliability. 备注 1:超过“绝对最大额定值”的应力可能会造成器件永久损坏。这些仅是应力额定值,器件 工作在上述条件以及超出“建议工作条件”的情况是不可取的。长期处于“绝对最大额定值”可 能影响器件的可靠性。 推荐工作条件 Recommended Operating Conditions 项目 Parameter 符号 Symbol 最小值 Min 最大值 Max 单位 Unit 输入电压 Input Voltage VIN 7 25 V 结温 Junction Temperature TJ -40 125 ℃ 电特性表 Electrical Characteristics 除非特指,典型字体表示 TJ=25℃,IOUT=40mA,VIN=10V, CIN=0.33μF, COUT=0.1μF,黑色字体的 温度范围-40℃到 125℃。 Limits in standard typeface are for TJ=25℃, Bold typeface applies over -40℃ to 125℃, IOUT=40mA, VIN=10V, CIN=0.33μF, COUT=0.1μF , unless otherwise specified. 项目 Parameter 输出电压 Output Voltage 符号 Symbol 测试条件 Conditions VOUT 7.0V≤VIN≤20V 数值 Value 最小 Min 典型 Typ 最大 Max 4.85 5 5.15 4.85 单位 Unit V 5.15 1.0mA≤IOUT≤40mA 线性调整率 Line Regulation VRLINE 负载调整率 Load Regulation VRLOAD 压差 Dropout Voltage 短路电流 Short Current FEB 2019 Version1.0 30 70 mV 1.0mA≤IOUT≤100mA 20 40 mV 1.0mA≤IOUT≤40mA 10 30 VDROP 1.7 2 Ios 100 7.0V≤VIN≤20V IOUT=40mA 4/15 V mA Ascend Semicondutor Co.,Ltd ASPL78L05 LINEAR INTEGRATED CIRCUIT 静态电流 Quiescent Current IQ IOUT=0 2.3 4 mA 静态电流的变化 Quiescent Current Change △IQ 8.0V≦VIN≦20V 0.1 0.3 mA 1.0mA≦IOUT≦40mA 0.2 输出噪声电压 Output Noise Voltage NO 10Hz ≤f≤100KHz 40 μV 电源抑制比 Ripple Rejection PSRR f=120Hz, 75 dB 峰值输出电流 Peak Output Current IPK 160 mA 输出电压平均温度系数 Average Temperature Coefficient of Output Voltage △VOUT/△T -0.35 mV/℃ 最小输入电压 Minimum Value of Input Voltage Required to Maintain Line Regulation VIN(min) 热阻 Thermal Resistance θJC 47 8.0V≦VIN≦20V IOUT=5.0mA 6.7 TO-92 81 SOT-89 84 SOT-223 71 7 V ℃/W 典型性能 Typical Performance Characteristics Figure 4. Output Voltage vs. Junction Temperature FEB 2019 Version1.0 5/15 Figure 5. Output Voltage vs. Input Voltage Ascend Semicondutor Co.,Ltd ASPL78L05 LINEAR INTEGRATED CIRCUIT Figure 6. Output Voltage vs. Load Current Figure 8. Quiescent Current vs. Junction Temperature Figure 7. Thermal Shutdown Figure 9. Quiescent Current vs. Input voltage Figure 10. Dropout Voltage vs. Junction Temperature FEB 2019 Version1.0 6/15 Figure 11. Ripple Rejection Ascend Semicondutor Co.,Ltd ASPL78L05 LINEAR INTEGRATED CIRCUIT 典型应用 Typical Application Figure 14. Fixed Output Regulator VOUT = 5V + (5V/R1 + IQ)R2 5V/R1 > 3IQ, load regulation(Lr) ≈ [(R1 + R2)/R1](Lr of 78L05) Figure 15. Adjustable Output Regulator IOUT = (VOUT/R1)+IQ > IQ over line and load change Figure 16. Current Regulator FEB 2019 Version1.0 7/15 Ascend Semicondutor Co.,Ltd ASPL78L05 LINEAR INTEGRATED CIRCUIT 典型应用 Typical Application(Continued) Optional: Improves ripple rejection and transient response. Load Regulation: 0.6% 0 ≤IL ≤250mA pulsed with tON = 50ms Figure 17. 5V 500mA Regulator with Short Circuit Protection *Solid tantalum VOUT = VG + 5V R1 = -VIN/IQ VOUT = 5V(R2/R4) for (R2+R3) = (R4+R5) A 0.5V output will correspond to (R2/R4) = 0.1(R3/R4)=0.9 Figure 18. Variable Output Regulator 0.5V to 18V Note2: Senichip are responsible for consistency of product. The devices should be working in recommended condition. Before new design product being bulk production, pilot production should be done. Senichip assumes no liability for applications assistance or customer design product. 备注 2:西安晟芯半导体公司负责提供器件的一致性,客户应在推荐工作条件下使用器件。客户 设计新产品量产前应进行小批量试产,西安晟芯半导体公司不对客户设计产品及其应用支持负 责。 FEB 2019 Version1.0 8/15 Ascend Semicondutor Co.,Ltd ASPL78L05 LINEAR INTEGRATED CIRCUIT Ordering and Marking Information Device Marking Package Packaging Quantity AS3//6/ SOP8 Tape&Reel 3000/Reel AS3//'7/ SO7 Tape&Reel 3000/Reel AS3//', / SO7 Tape&Reel 1000/Reel AS3///3/ 72  %$* MARKING PACKAGE SOP-8 SO7 Lot Number 56J.3 SO7 Date Code 72 NOV 2018 Version1.0 9/15 Ascend Semicondutor Co.,Ltd ASPL78L05 LINEAR INTEGRATED CIRCUIT 外观尺寸 Mechanical Dimensions TO-92 (Bulk Packing) FEB 2019 Version1.0 10/15 Unit: mm (inch) Ascend Semicondutor Co.,Ltd ASPL78L05 LINEAR INTEGRATED CIRCUIT 外观尺寸 Mechanical Dimensions (Continued) TO-92 (Ammo Packing) FEB 2019 Version1.0 11/15 Unit: mm (inch) Ascend Semicondutor Co.,Ltd ASPL78L05 LINEAR INTEGRATED CIRCUIT 外观尺寸 Mechanical Dimensions (Continued) SOT-223 FEB 2019 Version1.0 Unit: mm (inch) 12/15 Ascend Semicondutor Co.,Ltd ASPL78L05 LINEAR INTEGRATED CIRCUIT 外观尺寸 Mechanical Dimensions (Continued) SOT-89 FEB 2019 Version1.0 Unit: mm (inch) 13/15 Ascend Semicondutor Co.,Ltd ASPL78L05 LINEAR INTEGRATED CIRCUIT SOP-8 PACKAGE IN FORMATION FEB 2019 Version1.0 14/15 Ascend Semicondutor Co.,Ltd ASPL78LXX LINEAR INTEGRATED CIRCUIT IMPORTANT NOTICE Xi‘an Ascend Semiconductor incorporated MAKES NO WARRANTY OF ANY KIND, EXPRESS OR IMPLIED, WITH REGARDS TO THIS DOCUMENT, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE (AND THEIR EQUIVALENTS UNDER THE LAWS OF ANY JURISDICTION). Xi‘an Ascend Semiconductor Incorporated and its subsidiaries reserve the right to make modifications, enhancements, improvements, corrections or other changes without further notice to this document and any product described herein. Xi‘an Ascend Semiconductor Incorporated does not assume any liability arising out of the application or use of this document or any product described herein; neither does Xi‘an Ascend Semiconductor Incorporated convey any license under its patent or trademark rights, nor the rights of others. Any Customer or user of this document or products described herein in such applications shall assume . all risks of such use and will agree to hold Ascendsemi Incorporated and all the companies whose products are represented on Xi‘an Ascend Semiconductor Incorporated website, harmless against all damages. Xi‘an Ascend Semiconductor Incorporated does not warrant or accept any liability whatsoever in respect of any products purchased through unauthorized sales channel. Should Customers purchase or use Xi‘an Ascend Semiconductor Incorporated products for any unintended or unauthorized application, Customers shall indemnify and hold Xi‘an Ascend Semiconductor Incorporated and its representatives harmless against all claims, damages, expenses, and attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized application. www.ascendsemi.com NOV 2018 Version1.0 15/15 Ascend Semicondutor Co.,Ltd
ASPL78L05DI-R 价格&库存
很抱歉,暂时无法提供与“ASPL78L05DI-R”相匹配的价格&库存,您可以联系我们找货
ASPL78L05DI-R
    • 1+0.42830
    库存:10
