ASDM3050KQ
30V N-Channel MOSFET
Product Summary
Features
High density cell design for ultra low Rdson
V DS
30
V
Good stability and uniformity with high EAS
R DS(on),TYP@ VGS=10 V
9
mΩ
Excellent package for good heat dissipation
ID
50
A
Fully characterized Avalanche voltage and current
Special process technology for high ESD capability
Application
Power switching application
Hard switched and high frequency circuits
Uninterruptible Power Supply
1
TO-252
N-Channel MOSFET
Absolute Maximum Ratings (TC=25℃unless otherwise noted)
Parameter
Symbol
Drain-Source Voltage
VDS
Gate-Source Voltage
VGS
Limit
Unit
30
V
±20
V
ID
50
A
ID (100℃)
35
A
Pulsed Drain Current
IDM
140
A
Maximum Power Dissipation
PD
60
W
0.4
W/℃
EAS
70
mJ
TJ,TSTG
-55 To 175
RθJC
2.5
℃/W
Drain Current-Continuous
Drain Current-Continuous(TC=100℃)
Derating factor
Single pulse avalanche energy
(Note 5)
Operating Junction and Storage Temperature Range
Thermal Characteristic
Thermal Resistance,Junction-to-Case(Note 2)
NOV 2018 Version1.0
1/8
Ascend Semicondutor Co.,Ltd
ASDM3050KQ
Electrical Characteristics (TC=25℃unless otherwise noted)
Parameter
Symbol
Condition
Min
Typ
Max
Unit
Off Characteristics
Drain-Source Breakdown Voltage
BVDSS
VGS=0V ID=250μA
30
33
V
Zero Gate Voltage Drain Current
IDSS
VDS=30V,VGS=0V
1
μA
Gate-Body Leakage Current
IGSS
VGS=±20V,VDS=0V
±100
nA
Gate Threshold Voltage
VGS(th)
VDS=VGS,ID=250μA
1
1.4
2
V
Drain-Source On-State Resistance
RDS(ON)
VGS=10V, ID=25A
9
11
VGS=5V, ID=20A
11.3
14
VDS=5V,ID=20A
15
S
2000
PF
280
PF
160
PF
10
nS
On Characteristics
(Note 3)
Forward Transconductance
Dynamic Characteristics
gFS
mΩ
(Note4)
Input Capacitance
Clss
Output Capacitance
Coss
Reverse Transfer Capacitance
Switching Characteristics
VDS=15V,VGS=0V,
F=1.0MHz
Crss
(Note 4)
Turn-on Delay Time
td(on)
Turn-on Rise Time
tr
VDD=15V,ID=20A
8
nS
td(off)
VGS=10V,RGEN=1.8Ω
30
nS
5
nS
23
nC
7
nC
4.5
nC
0.85
1.2
V
50
A
TJ = 25°C, IF = 50A
22
35
nS
(Note3)
11
18
nC
Turn-Off Delay Time
Turn-Off Fall Time
tf
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
VDS=10V,ID=25A,
VGS=10V
Drain-Source Diode Characteristics
Diode Forward Voltage (Note 3)
Diode Forward Current
(Note 2)
Reverse Recovery Time
VSD
VGS=0V,IS=25A
IS
trr
Reverse Recovery Charge
Qrr
Forward Turn-On Time
ton
di/dt = 100A/μs
Intrinsic turn-on time is negligible (turn-on is dominated by LS+LD)
Notes:
1. Repetitive Rating: Pulse width limited by maximum junction temperature.
2. Surface Mounted on FR4 Board, t ≤ 10 sec.
3. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%.
4. Guaranteed by design, not subject to production
5. EAS condition:Tj=25℃, VDD=15V,VG=10V,L=1mH, Rg=25Ω
NOV 2018 Version1.0
2/8
ASDM3050KQ
Test circuit
1)EAS test Circuits
2)Gate charge test Circuit:
Tc, Case Temperature (°C)
3)Switch Time Test Circuit:
NOV 2018 Version1.0
3/8
ASDM3050KQ
ID- Drain Current (A)
Normalized On-Resistance
Typical Electrical and Thermal Characteristics (Curves)
TJ-Junction Temperature(℃)
Vds Drain-Source Voltage (V)
Figure 4 Rdson-JunctionTemperature
Vgs Gate-Source Voltage (V)
Figure 1 Output Characteristics
Qg Gate Charge (nC)
Figure 2 Transfer Characteristics
Figure 5 Gate Charge
Is- Reverse Drain Current (A)
Rdson On-Resistance Normalized
Vsd Source-Drain Voltage (V)
Figure 3 Rdson- Drain Current
NOV 2018 Version1.0
Figure 6 Source- Drain Diode Forward
4/8
ASDM3050KQ
Normalized BVdss
C Capacitance (pF)
Figure 7 Capacitance vs Vds
Figure 9 BVDSS vs Junction Temperature
Figure 8 Safe Operation Area
Figure 10 VGS(th) vs Junction Temperature
r(t),Normalized Effective
Transient Thermal Impedance
Square Wave Pluse Duration(sec)
Figure 11 Normalized Maximum Transient Thermal Impedance
NOV 2018 Version1.0
5/8
ASDM3050KQ
Ordering and Marking Information
Ordering Device No.
ASDM3050KQ-R
Marking
Package
Packing
3050
TO-252
Tape&Reel
2500
MARKING
PACKAGE
TO-252
NOV 2018 Version1.0
Quantity
3050
6/8
ASDM3050KQ
6\PERO
'LPHQVLRQVLQ0LOOLPHWHUV
'LPHQVLRQVLQ,QFKHV
0LQ
0D[
0LQ
0D[
E
E
F
F
7
很抱歉,暂时无法提供与“ASDM3050KQ-R”相匹配的价格&库存,您可以联系我们找货
