BF8629-5R7-360T/LF
BF8629-5R7-360T/LF
    ACX(璟德)
    SMD,2.9x8.6mm
    5700MHZ带通滤波器
BF8629-5R7-360T/LF 数据手册
ACX Advanced Ceramic X BF8629 Series Band-pass filters Features  SMD type with low loss at pass-band and high attenuation at stop-band.  RoHS compliant Applications Wireless communication systems. Specifications Frequency Range (MHz) Insertion Loss @ BW (dB) Ripple @ BW (dB) Return Loss @ BW (dB) Frequency (MHz) Attenuation (dB) 5490 ~ 5850 2.5 max. 1.3 max. 10 min. 5150 ~ 5330 50 min. Part Number BF86295R7-360 Q’ty/Reel (pcs) Operating Temperature Range Storage Temperature Range Storage Period Power Capacity : 1,000 : -40 ~ +100 oC : -40 ~ +100 oC : 12 months max. : 1W max. Part Number BF  8629  - 5R7  - 360    /LF   Type BF : Band-Pass Filter  Dimensions ( L × W )  Frequency Range 5R7=5700MHz  Specification Code 360  Packaging T: Tape & Reel B: Bulk  Soldering /LF=lead-free BF8629-5R7360T/LF REV:6 PAGE:1/6 8.6 × 2.9 mm ACX Advanced Ceramic X Terminal Configuration Dimensions and Recommended PC Board Pattern Unit: mm BF8629-5R7360T/LF REV:6 PAGE:2/6 ACX Advanced Ceramic X . . Electrical Characteristics (T=25oC) 0 -10 -20 IL RL -30 -40 -50 -60 -70 4.2 5.2 6.2 7.0 freq, GHz Notes The contents of this data sheet are subject to change without notice. Please confirm the specifications and delivery conditions when placing your order. BF8629-5R7360T/LF REV:6 PAGE:3/6 ACX Advanced Ceramic X Taping Specifications Tape Dimensions (Unit: mm) & Quantity Reel Dimensions (Unit: mm) Storage Conditions (1)Temperature: 0 ~40℃, humidity : 80%RH or less (2)Storage Period: 12 months max.* *12 months in vacuum sealed bag and 1 month after opened. Please keep unused parts in vacuum sealed bags. BF8629-5R7360T/LF REV:6 PAGE:4/6 ACX Advanced Ceramic X Mechanical & Environmental Characteristics Item Low Temperature Hold Test High Temperature Hold Test Humidity Resistance Test Requirements 1. No apparent damage 2. Fulfill the electrical specification after test 1. No apparent damage 2. Fulfill the electrical specification after test Test Method Unit shall be subjected to -40℃ for 10 hours and then be left for more than 2 hours at room temperature. Unit shall be subjected to +100℃ for 10 hours and then be left for more than 2 hours at room temperature. 1. No apparent damage Unit shall be subjected to the 60±2℃, 95% relative humidity 2. Fulfill the electrical for 24 hours and then be left for more than 2 hours at 25±5℃ specification after test in less than 65% relative humidity. After the unit is applied to thermal shock -40℃ Thermal Shock Resistance Test 1. No apparent damage 2. Fulfill the electrical specification after test +100℃ for 2 hours soak at each temperature with transition time less than 10 seconds for 5 cycles and then be left for more than 1 hour at 25±5℃ in less than 65% relative humidity. The device is subjected to be soldered on test PCB. Then apply 0.5Kg(5N) of force for 10±1 seconds in the direction of arrow. (the soldering should be done by reflow and be conducted with care so that the soldering is uniform and free Adhesion Test 1. No apparent damage of defect by stress such as heat shock.) Weld the product to the center part of the PCB with the thickness 1.6±0.2mm as the illustration shows, and keep exerting force arrow-ward on it as speed off 1mm/S, and hold for 5±1S at the position of 1.5mm. Bending Resist Test 1. No apparent damage BF8629-5R7360T/LF REV:6 PAGE:5/6 ACX Advanced Ceramic X Soldering Conditions  Recommended Reflow Soldering Profile for Pb-free Process Note: All the temperature measure point is on top surface of the component. If temperature over recommend, it will make component surface peeling or damage.  Soldering With Iron Soldering iron temperature: 270±10℃ Apply preheating at 120℃ for 2-3 minutes. Finish soldering for each terminal within 3 seconds, if soldering iron over temperature 270±10℃ or Soldering iron can not leakage of electricity. Notes The contents of this data sheet are subject to change without notice. Please confirm the specifications and delivery conditions when placing your order. Advanced Ceramic X Corp. 16 Tzu Chiang Road, Hsinchu Industrial District Hsinchu Hsien 303, Taiwan TEL:886-3-5987008 FAX:886-3-5987001 E-mail: acx@acxc.com.tw http://www.acxc.com.tw BF8629-5R7360T/LF REV:6 PAGE:6/6
BF8629-5R7-360T/LF 价格&库存
很抱歉,暂时无法提供与“BF8629-5R7-360T/LF”相匹配的价格&库存,您可以联系我们找货
