DP1608-A2455BLT/LF
DP1608-A2455BLT/LF
    ACX(璟德)
    DP1608-A2455BLT/LF
DP1608-A2455BLT/LF 数据手册
ACX DP 1608 Series Advanced Ceramic X Multilayer Chip Diplexers Features  Monolithic structure including one low-pass and one band-pass filters with loss pole at adjacent passband. RoHS complaint Applications  Dual-band / dual-mode 2.4GHz/5GHz WLAN Specifications Part Number Passband (MHz) Insertion Loss (dB) Passband VSWR Attenuation (dB) 10 min. @ 3.6 ~ 3.75 GHz 0.68 max. @ 25°C 2400~2500 0.88 max. @-40~105°C 2.0 max. 20 min. @ 4.8 ~ 5.0 GHz 10 min. @ 7.2 ~ 7.5GHz 10 min. @ 9.6 ~ 10GHz 25 min. @ 0.86 ~ 0.96 GHz DP1608A2455BL_ 25 min. @ 1.545 ~ 1.605GHz 25 min. @ 1.71 ~ 1.99GHz 0.78 max. @ 25°C 4900~5950 0.98 max. @-40~105°C 2.0 max. 30 min. @ 2.17 GHz 10 min. @ 8.1 ~ 8.8GHz 15 min. @ 8.82 ~ 9.8GHz 25 min. @ 9.8 ~ 11.8GHz Q’ty/Reel (pcs) Operating Temperature Range Storage Temperature Range Storage Period Power Capacity : 4000 : -40 ~ +105 oC : -40 ~ +105 oC : 12 months max. : 3W max. Part Number DP  1608  - A  2455  BL    /LF   Dimensions  Type DP : Diplexer  Material Code A  Frequency Range 2455=2400MHz /5500MHz  Specification Code BL  Packaging T: Tape & Reel B: Bulk  Soldering /LF=lead-free (L×W) DP1608-A2455BLT/LF REV:3 PAGE:1/7 1.6 × 0.8 mm ACX Advanced Ceramic X Terminal Configuration       No. Terminal Name No. Terminal Name  Higher Freq. Port  GND  GND  Common Port  Lower Freq. Port  GND Dimensions and Recommended PC Board Pattern a p Unit : mm W T c g L < Top View> < Bottom View> Mark L W T a Dimensions 1.6±0.1 0.8±0.1 0.6±0.1 0.2±0.1 b < Side View > b c g p 0.2+0.1 0.15±0.1 0.3±0.1 0.5±0.05 /-0.15 0.25 Solder Resist 0.55 * * 0.25 Land Through-hole ( 0.35) * 0.25 * Line width should be designed to match 50ohm characteristic impedance, depending on PCB material and thickness. DP1608-A2455BLT/LF REV:3 PAGE:2/7 ACX Advanced Ceramic X Measuring Diagram Network Port 1 (50) Port 3 (50) analyzer Port 2 (50) GND GND GND Electrical Characteristics (T=25oC) Return Loss 0 0 -10 -10 -20 dB(S(3,3)) dB(S(2,2)) dB(S(1,1)) dB(S(1,2)) dB(S(3,2)) Attenuation -30 -40 -20 -30 -40 -50 -50 0 2 4 6 8 10 12 0 2 freq, GHz 4 6 8 10 12 freq, GHz Notes The contents of this data sheet are subject to change without notice. Please confirm the specifications and delivery conditions when placing your order. DP1608-A2455BLT/LF REV:3 PAGE:3/7 ACX Advanced Ceramic X Taping Specifications Tape Dimensions (Unit: mm) & Quantity A’ T 1.75 ± 0.1 D E F C PAPER B TAPE Type A A A’ B C D E F T 4.0± 4.0± 1.10± 1.92± 2.0± 3.5± 8.0± 0.75± 0.1 0.1 0.1 0.1 0.1 0.1 0.1 0.05 1608 Quantity/reel Tape material 4,000pcs Paper Reel Dimensions (Unit: mm) 1.4 ± 0.2 Label 178± 1 60±1 Label: Customer’s Name, ACX P/N, Q’ty, Date, ACX Corp. 13.5±0.5 B A Type A B 1608 2.3±0.5 9.0±0.3 Leader and Trailer Tape Trailer End Trailer (160 mm min.) Empty Compartments with Cover Tape (500 mm min.) DP1608-A2455BLT/LF REV:3 PAGE:4/7 ACX Advanced Ceramic X Peel-off Force Top Cover Tape Peeling Direction
DP1608-A2455BLT/LF 价格&库存
很抱歉,暂时无法提供与“DP1608-A2455BLT/LF”相匹配的价格&库存,您可以联系我们找货
