CP0605-19D2455ABT/LF
    ACX(璟德)
    SMD,0.5x0.7mm
CP0605-19D2455ABT/LF 数据手册
ACX Advanced Ceramic X CP0605 Series Multilayer Chip Couplers Features  Monolithic SMD with ultra-small, low-profiled, and light-weight type.  RoHS compliant  Automobile grade & AEC-Q200 compliant Applications 2.4 ~ 2.5、4.9~5.85 GHz dual-band wireless communication systems Specifications Frequency Insertion Loss Return Loss Part Number Coupling Directivity (dB) (dB) (dB) 15 min. 19.1  0.7 16 min. (dB) (MHz) 0.2 max. 2400 ~ 2500 @-40~85℃ 0.25 max. CP0605- @105℃ 19D2455AB_ 0.5 max. 4900 ~ 5950 @-40~85℃ 15 min. 0.55 max. @105℃ Q’ty/Reel (pcs) Operating Temperature Range Storage Temperature Range Storage Period Power Capacity 5150 ~ 5350 MHz 12.8  0.7 5500 ~ 5690 MHz 12.4  0.7 5700 ~ 5805 MHz 12.2  0.7 5825 ~ 5950 MHz 12.1  0.7 20 min. : 10,000 : -40 ~ +105 oC : -40 ~ +85 oC : 12 months max. : 4W max. Part Number CP  0605  - 19  D  2455  AB    /LF   Type CP : Coupler  Dimensions ( L × W ) 0.65 × 0.5 mm  LB Coupling 19 : 19 dB  HB Coupling D: 12.5dB  Specification code AB  Soldering /LF=lead-free  Central Frequency  Packaging 2455=2450MHz/ 5500MHz T: Tape & Reel B: Bulk CP0605-19D2455ABT/LF REV:3 PAGE:1/7 ACX Advanced Ceramic X Terminal Configuration    No. Terminal Name No. Terminal Name  Coupling  Out  Termination  IN  Dimensions and Recommended Land Pattern Unit: mm T L b < Bottom Vi T W a W L Mark Dimensions Recommended L W T a b 0.65  0.5  0.37  0.15 0.225 0.05 0.05 0.05 +0.1/-0.05 +0.1/-0.05 Land Pattern 0.2 0.15 0.2 Land 0.225 CP0605-19D2455ABT/LF REV:3 PAGE:2/7 ACX Advanced Ceramic X Measuring Diagram Attenuation Network analyzer Port 1 (50) Coupling Port 2 Port 1 (50) (50) Isolation Network analyzer Port 2 Port 1 (50) (50) Network analyzer Termination (50) Termination (50) (50) Termination (50) Termination (50) Termination (50) Port 2 Termination (50) 0 0 -10 -10 Directivity1 Coupling1 Insertion_Loss1 Return_Loss1 Electrical Characteristics (T=25oC) -20 -30 -40 -20 -30 -40 -50 -50 1 2 3 4 5 freq, GHz 6 7 1 2 3 4 5 6 7 freq, GHz Notes The contents of this data sheet are subject to change without notice. Please confirm the specifications and delivery conditions when placing your orde CP0605-19D2455ABT/LF REV:3 PAGE:3/7 ACX Advanced Ceramic X Taping Specifications Tape Dimensions (Unit: mm) & Quantity Type A A’ B C D E F T 2.0± 4.0± 0.58± 0.78± 2.0± 3.5± 8.0± 0.45± 0.05 0.1 0.03 0.03 0.05 0.05 0.2 0.03 0605 Quantity/reel Tape material 10,000pcs Paper Reel Dimensions (Unit: mm) 1.4 ± 0.2 Label 178± 1 60±1 Label: Customer’s Name, ACX P/N, Q’ty, Date, ACX Corp. 13.5±0.5 B A Type A B 0605 2.3±0.5 9.0±0.3 Leader and Trailer Tape Trailer End Trailer (160 mm min.) Empty Compartments with Cover Tape (500 mm min.) CP0605-19D2455ABT/LF REV:3 PAGE:4/7 ACX Advanced Ceramic X Peel-off Force Top Cover Tape Peeling Direction
CP0605-19D2455ABT/LF 价格&库存
很抱歉,暂时无法提供与“CP0605-19D2455ABT/LF”相匹配的价格&库存,您可以联系我们找货
