BZ-C0805-G3-E1
BZ-C0805-G3-E1
    BAIZOU(百洲)
    翠绿
BZ-C0805-G3-E1 数据手册
深圳市百洲半导体光电科技有限公司 BAIZHOU SEMICONDUCTOR OPTOELECTRONIC TECHNOLOGY CO.,LTD. 产 品 规 格 书 SPECIFICATION FOR APPROVAL CUSTOMER/客户名称: MODEL NO./产品型号: DESCRIPTON./产品描述: DATE./日期: 版本 Edition: BZ-C0805-G3-E1 CHIP 0805 翠绿 2020/06/06 A.1 CUSTOMER AUTHORIZED SIGNATURE/客户承认签核 Pleas retun to us oen copy of “SPECIFICATION FOR APPROVAL”With you approved Signature./客户签字确认,盖章后请回传一份承认书我司。 Add:shenzhen baoan district rock street pond avenue macro hair trey Gao Xinyuan 12 5 floor of west side 地址:深圳市宝安区石岩街道塘头大道宏发佳特利高新园12栋5楼西侧 TEL/电话:0755-85255622 FAX/传真:0755-85255672 Http://www.cnbzic.com 深圳市百洲半导体光电科技有限公司 BAIZHOU SEMICONDUCTOR OPTOELECTRONIC TECHNOLOGY CO.,LTD. ■ Features: 1. 2.0mmx1.25mm SMT LED, 0.8mm THICKNESS. 2. WIDE VIEWING ANGLE. 3. IDEAL FOR BACKLIGHT AND INDICATOR. 4. Suitable for all SMT assembly 5. ROHS compliant 6. Lens Color:Water Clear ■ Applications: 1.Automotive: backlighting in dashboard and switch. 2.Telecommunication: indicator and back-lighting in telephone and fax. 3. Flat backlight for LCD switch and symbol. ■ Outline Dimension: C athode A node G reen m ark 建议焊盘尺寸 Notes: 1.All dimensions are in millimeters. 2.Tolerance is ±0.1 unless otherwise noted. 3.Specifications are subject to change without notice. 1 http://www.cnbzic.com SHENZHEN HUAHEDA ELECTRONISC CO.LTD 深圳华和达电子有限公司 SHENZHEN HUAHEDA ELECTRONISC CO.LTD 深圳华和达电子有限公司 深圳市百洲半导体光电科技有限公司 BAIZHOU SEMICONDUCTOR OPTOELECTRONIC TECHNOLOGY CO.,LTD. ■ Typical Electrical & Optical Characteristics(Ta=25°) Symbol Condition Min Typ Max Unit Forward Voltage VF IF =5mA 2.6 --- 3.2 V Reverse Current IR VR =5V 0 --- 1 μA Wave Length λd IF =5mA --- 522.5 --- nm Luminous Intensity Iv IF =5mA 160 250 331 mcd 2θ1/2 IF =5mA --- 120 --- Deg Items View Angle ■ Absolute Maximum Ratings (Ta = 25℃) Symbol Absolute maximum Rating Unit PD 80 mW Forward Current(DC) IF 25 mA Peak Forward Current IFP 100 mA Reverse Voltage VR 5 V Electrostatic Discharge ESD 2000(HBM) V Operation Temperature Topr ﹣40~﹢85 ℃ Storage Temperature Tstg ﹣40~﹢85 ℃ Items Power Dissipation Note :1/10 Duty Cycle,0.1 ms Pulse Width 2 http://www.cnbzic.com 深圳市百洲半导体光电科技有限公司 BAIZHOU SEMICONDUCTOR OPTOELECTRONIC TECHNOLOGY CO.,LTD. ■ Typical Electrical/Optical Characteristics Curves: 3 http://www.cnbzic.com 深圳市百洲半导体光电科技有限公司 BAIZHOU SEMICONDUCTOR OPTOELECTRONIC TECHNOLOGY CO.,LTD. ■ Reliability Test Number Test Item Test Conditions Sample size Acceptance/ Rejection 1 Reflow Solder Temperature:Max 260 ℃ Time:10S Cycles : 3times 22PCS 0/1 Life Test Temperature=25 ℃±5 ℃ Current=20mA±2mA Cycles:10000H 22PCS 0/1 3 85℃~25℃~-40℃~25℃ Temperature Cycling 30min 5min 30min 5min Cycles:100 22PCS 0/1 4 Hot/cold TemperatureShock 100 ℃±5 ℃ ~-40 ℃±5 ℃ 15 mins 15 mins Cycles:100 22PCS 0/1 5 Low Temperature Storage Temperature:-40 ℃±5 ℃ Cycles:1000H 22PCS 0/1 6 High Temperature Storage Temperature:100 ℃±5 ℃ Cycles:1000H 22PCS 0/1 2 Remarks: Specifications are subject to change without prior notice. 4 http://www.cnbzic.com 深圳市百洲半导体光电科技有限公司 BAIZHOU SEMICONDUCTOR OPTOELECTRONIC TECHNOLOGY CO.,LTD. ■ Reflow soldering instructions 1、Reflow soldering is recommended to the use of clean free flux, and in accordance to the reflow curve. Maximum number of soldering is limited 2、When soldering, do not exert pressure during heating process. ■Soldering 1、When manual soldering iron is used, it is recommended to use 20W anti-electro static soldering iron, soldering temperature must be kept below 360℃ / 3 seconds, 1Time soldering only 2、Do not mix different BIN materials on the same board, otherwise it will cause LED color Variation 5 http://www.cnbzic.com 深圳市百洲半导体光电科技有限公司 BAIZHOU ■ Taping Specifications SEMICONDUCTOR OPTOELECTRONIC TECHNOLOGY CO.,LTD. (Unit:mm) A U ser Feed D irection ■ Reel Size A A-A剖面图 (Unit:mm) 6 http://www.cnbzic.com 深圳市百洲半导体光电科技有限公司 BAIZHOU SEMICONDUCTOR OPTOELECTRONIC TECHNOLOGY CO.,LTD. ■ Humidity Proof packaging Note: 7 http://www.cnbzic.com SHENZHEN HUAHEDA ELECTRONISC CO.LTD 深圳华和达电子有限公司
BZ-C0805-G3-E1 价格&库存
很抱歉,暂时无法提供与“BZ-C0805-G3-E1”相匹配的价格&库存,您可以联系我们找货
