CT109AZ5U103M500VT
CT109AZ5U103M500VT
    YUYUE(新玉跃)
    插件,P=7.5mm
    10NF ±20% 500V
CT109AZ5U103M500VT 数据手册
圆片瓷介电容器 DISC CERAMIC CAPACITOR YUYUE 公司简介 南京新玉跃电子有限公司是成立于 1992 年的中外合资企业(原名南京玉跃电子有限公司),具有 10 多年专业制造陶瓷电容器的生产经验。公司主要产品为全系列陶瓷电容器,包括低、中、高压及交 流产品,广泛应用于家电、通讯、照明等整机并为仪表等装备产品配套,年生产能力达到 10 亿只以上, 出口占销售总额的 50%以上,遍及世界各个国家和地区。目前,公司形成了完整的管理体系,已通过 ISO9001 质量管理体系和 ISO14001 环境管理体系认证,产品满足 ROHS、REACH 要求,同时我们的安规 产品在中国、美国、德国、加拿大、挪威、芬兰、瑞典、丹麦均已获得认证。 严格、科学的管理体系,先进的生产设备,雄厚的技术力量以及良好的服务,使我们多年来享誉 中外。南京新玉跃电子有限公司是您最好的合作伙伴! Company Profile NanJing Yuyue Electronics Co., Ltd, a joint venture established in 1992,is a professional manufacturer of ceramic capacitors with over ten years’ history. The main products include full series of ceramic capacitors, ranging from low,mid & high voltage to AC safety standards capacitors. Our annual capacity is up to 1 billion pieces and the products are widely spread all over the world. The amounts for export accounts for over half of the all sales. Being an ISO9001 and ISO14001 certificated company, we have also obtained safety approvals in China (CQC), U.S.A (UL), Germany (VDE), Canada (CSA), Norway (NEMKO), Finland (FIMKO), Sweden (SEMKO), Denmark (DEMKO), and our product comply with ROHS 、REACH directive. We have been widely accepted for many years at home and abroad, with our scientific management system, advanced equipments, strong technical support and excellent services, NanJing YuYue Electronics Co., Ltd. is your best choice! 圆片瓷介电容器 DISC CERAMIC CAPACITOR YUYUE 目 录 CONTENT ■圆片瓷介电容器 DISC CERAMIC CAPACITOR 一、 品名的表示方法 Part Numbering System------------------------------------------- 1 1. 产品类别 CLASS----------------------------------------------------------------- 1 2. 直径代码 Diameter-------------------------------------------------------------- 1 3. 引出线形式 Lead Style---------------------------------------------------------- 2 4. 温度特性 Temperature Characteristics------------------------------------------- 2 5. 电容量 Capacitance------------------------------------------------------------- 2 6. 电容量公差 Capacitance Tolerance----------------------------------------------- 2 7. 额定电压(UR)Rated Voltage ---------------------------------------------------- 2 8. 包装形式 Package Type---------------------------------------------------------- 3 二、 温度特性 Temperature Characteristics------------------------------------------- 4 三、 CT7 安规认定瓷介电容器 CT7 Safety Standard recognized Ceramic Capacitor---------- 5 X1,Y2 型----------------------------------------------------------------------- 5 X1,Y1 型----------------------------------------------------------------------- 6 四、 HR 系列高压瓷介电容器 HR Series High Voltage Ceramic Capacitor------------------- 7 五、 CC1 温度补偿型圆片瓷介电容器 CC1 Temperature Compensating Ceramic Capacitor------ 8 六、 CT1 高介电常数型圆片瓷介电容器 CT1 High Dielectric Constant Ceramic Capacitor----- 9 七、 CS1 半导体瓷型圆片瓷介电容器 CS1 Semi-Conductive Dielectric Ceramic Capacitor---- 10 八、 CC81 型高压瓷介电容器 CC81 Series High Voltage Ceramic Capacitor----------------- 11 九、 CT81 型高压瓷介电容器 CT81 Series High Voltage Ceramic Capacitor ----------------- 12 十、 CT81 型超高压瓷介电容器 CT81 Super High Voltage Ceramic Capacitor ---------------- 14 ■ 独石电容 MULTILAYER CERAMIC CAPACITOR 一、 品名的表示方法 Part Numbering System-------------------------------------------- 15 二、 常规性能 General Specification-------------------------------------------------- 15 圆片瓷介电容器 DISC CERAMIC CAPACITOR YUYUE 三、 温度特性 Temperature Characteristics (T.C.) 四、 尺寸、容量、额定电压的关系 Relationship with dimension, capacitance and rated voltage 15 五、 包装数量 Package quantity ------------------------------------------------------- 16 一、 品名的表示方法 Part Numbering System 包装形式 Package Type (8) 额定电压 Rated Voltage (7) 容量公差 Tolerance(6) 电容量 Capacitance (5) 温度特性 Temp.Characteristics (4) 引出线形式 Lead Style (3) 直径代码 Diameter (2) 产品类别 Class (1) 1. 产品类别 CLASS 1.1 温度补偿类型(I 类) Temperature Compensation 代码 Code CC1 CC81 额定电压 Rated Voltage 50V~500V ≥1KV 1.2 高介电常数型(Ⅱ类) High Dielectric Constant (ClassⅡ) 代码 Code CT1 CT81 CT7 额定电压 Rated Voltage 50V~500V ≥1KV X1Y1/X1Y2 1.3 半导体型(Ⅲ类) Semi-Conductive Dielectric 代码 Code 额定电压 Rated Voltage 2. (Class I) (ClassⅢ) CS1 16V~50V 直径代码 Diameter 代码 Code 片径 D±1(mm) 04 05 06 07 08 09 4.0 5.0 6.0 7.0 8.0 9.0 10 11 12 13 14 15 16 18 10.0 11.0 12.0 13.0 14.0 15.0 16.0 18.0 圆片瓷介电容器 DISC CERAMIC CAPACITOR 代码 Code YUYUE a b c d 3. 引出线形式 Lead Style 4. 温度特性 Temperature Characteristics 4.1 I 类 Class I NP0 N150 N220 N330 组别代码 Code (C) (P) (R) (S) 4.2 5. 6. N470 (T) e N750 (U) P350~N1000 (SL) Ⅱ、Ⅲ类 Class Ⅱ、ClassⅢ 组别代码 Y5P Y5R Y5U、 Z5U Y5V、Z5V Code (2B、BN) (2R) (2E) (2F) 电容量 Capacitance 代码 0R5 Code 容量 0.5pF Capacitance 1R0 100 101 102 103 104 1pF 10pF 100pF 1000pF 0.01uF 0.1uF 电容量公差 Capacitance Tolerance -1- 代码 Code C D J K M Z 容量公差 ±0.25pF±0.50pF ±5% ±10% ±20% +80%-20% Cap. Tolerance 适用容量范围 ≤5pF ≥5pF Applicable Capacitance Range 圆片瓷介电容器 DISC CERAMIC CAPACITOR 7. 额定电压(UR) Rated Voltage DC:从 16V 到 15KV From 16V to 15KV AC:X1Y1 X1Y2 8. 包装形式 Package Type 代码 Code 包装形式 Package Type B T 散件 Bulk 盒式编带 Taping Ammo Package ■编带 Taping Specification 直引线 straight leads YUYUE 内弯引线 inside crimped leads 表1 Item Value (mm) Code Pitch of component P 12.7±1.0 15.0±1.0 Pitch of sprocket hole P0 12.7±0.3 15.0±0.3 Lead spacing F 5.0-0.2 7.5-0.2 Length from hole center to component center P2 6.35±1.0 7.5±1.0 Length from hole center to lead P1 3.85±0.7 3.75±0.7 Body diameter D See the individual product specification Deviation along tape, left or right △S 0±1.0 Carrier tape width W 18.0±0.5 Position of sprocket hole W1 9.0±0.5 H 20-1.0 Lead distance between reference and bottom +0.8 +0.8 +1.5 l -2- 圆片瓷介电容器 DISC CERAMIC CAPACITOR YUYUE H0 16-0.5 ΦD0 4.0±0.2 Total tape thickness t1 0.5±0.2 Total thickness, tape and lead wire t2 1.5max Diameter of sprocket hole +1.0 +1.5 Hold down tape position W2 1.5-0 Deviation across tape △h 0±1.0 说明:我们将对产品进行持续的改进,因此技术规格参数若有变动或更改,以承认规格书为准。 Note: Dimensions and specifications are subject to changes in accordance with our continuous improvement and our specification for approval should be taken as the latest. 二、 温度特性 Temperature Characteristics 1.Ⅰ类瓷温度系数 ClassⅠTemperature Coefficient (T.C.) △C/C20(%) SL(P350-N1000) △C/C20(%) 6 8 6 4 4 P350 2 2 0 0 -2 -2 -4 NPO N150 N220 N330 N470 -4 -6 -6 -8 -10 N1000 -12 -55 -30 -5 20 45 70 Temperature(℃) 95 120 N750 -8 -10 -55 -30 -5 20 45 70 95 Temperature(℃) 120 温度系数、公差及色标 Temperature Coefficient (T.C.), Tolerance and Code Color 温系代码 T.C. Code NP0 温系色标 T.C.Color Code 黑 Black 温系及公差 T.C. TOL 温系代码 T.C.Code 0±30(CG) N470 兰 N750 紫 Violet ----------- 0±60(CH) N150 橙 Orange -150±60(PH) N220 黄 Yellow -220±60(RH) SL N330 绿 Green -330±60(SH) DL 温系色标 T.C.Color Code Blue 温系及公差 T.C. TOL. -470±60(TH) -750±120(UJ) -750±250(UK) +350 ~-1000 -3300±500 2.Ⅱ、Ⅲ类瓷温度特性 ClassⅡ、ClassⅢ Temperature Characteristics (T.C.) -3- 圆片瓷介电容器 DISC CERAMIC CAPACITOR △C/C20(%) YUYUE △C/C 20 (%) 15 10 40 Y5R 5 20 Y5U 0 0 -20 -5 Y5P -40 Y5V Z5U Z5V -60 -10 -80 -15 -30 -20 -10 0 10 -30 20 30 40 50 60 70 -20 -10 0 80 10 20 30 40 50 60 70 80 Temperature(℃ ) Temperature(℃) 温度特性 Temperature Characteristics EIA 代码 GB 代码 第一位字 The 1st letter 第二位字 The 2nd letter 第三位字 The 3rd letter X Y Z -55℃ -30℃ +10℃ 5 6 7 +85℃ +105℃ +125℃ P R S T U V ±10% ±15% ±22% +22%-33% +22%-56% +22%-82% 2B 2E 2F ±10% +22-56% +22-82% -25~+85℃ 三、 CT7 安规认定瓷介电容器 CT7 Safety Standard recognized Ceramic Capacitor 特性 Features 适合用在需安规认定、产品失效时可能导致电冲击危险的场合 These Ceramic Capacitors are specifically designed for AC applications and be used wherever they may be resulted in electronic shock when products are invalid. ■X1,Y2 型 X1,Y2 Series 常规性能 General Specification 工作温度范围 Operating Temp. Range -25℃ to +125℃ 电容量 Capacitance 在 1KHz±20% ,1.0±0.2Vrms 下测试,容量在允许偏差范围内 Within the Specified Tolerance at 1KHz±20% ,1.0±0.2Vrms 电容量公差 Capacitance Tolerance K:±10%, M:±20% 损耗 Dissipation Factor(DF) ≤2.5% at 1KHz±20% 1.0V±0.2Vrms 耐电压 Dielectric Withstanding Voltage 2600Vac for 2~5S 绝缘电阻(IR)Insulation Resistance 10000MΩ min at 500VDC and 1 minute electrification 标准 Applicable Standard 证书号码 Certificate No. UL UL1414 E237728 CSA CSA-C22.2 No.1-98 1515289 CQC GB/T14472 CQC03001008192 VDE EN60384-14 40008013 -4- 额定电压(UR) 标记 Rated Voltage Approved Monogram AC250V (r.m.s) DEMKO 312603-01 SEMKO 313019 FIMKO 20349 NEMKO P04201486 电容量规格 Capacitance Specification 2B(Y5P) 100~330 390~470 560~680 820~1000 电容量 Capacitance(pF) 温度特性 Temperature Characteristics 2E(Y5U) 外形尺寸 Diameter(mm) 2F(Y5V) 10~1500 1000~1500 2200 2200 3300 4700 3300 6800 4700 10000 D 06 07 08 09 10 11 12 13 14 Tmax F±1.0 d±0.05 6.0 7.5 圆片瓷介电容器 DISC CERAMIC CAPACITOR 0.60 YUYUE X1,Y1 型 X1,Y1 Series 特性 Features 适合用在需安规认定、产品失效时可能导致电冲击危险的场合 These Ceramic Capacitors are specifically designed for AC applications and be used wherever they may be resulted in electronic shock when products are invalid. 常规性能 General Specification 工作温度范围 Operating Temp. Range -25℃ to +125℃ 电容量 Capacitance 在 1KHz±20% ,1.0±0.2Vrms 下测试,容量在允许偏差范围内 Within the Specified Tolerance at 1KHz±20% ,1.0±0.2Vrms 电容量公差 Capacitance Tolerance K:±10%, M:±20% 损耗 Dissipation Factor(DF) ≤2.5% at 1KHz±20% 1.0V±0.2Vrms 耐电压 Dielectric Withstanding Voltage 4000Vac for 2~5 S 绝缘电阻(IR)Insulation Resistance 10000MΩ min at 500VDC and 1 minute electrification 标准 Related Standard 证书号码 Certificate No. UL UL1414 E237728 CSA CSA-C22.2 NO.1-98 1515289 CQC GB/T14472 CQC03001008193 -5- 额定电压(UR) 标记 Rated Voltage Approved Monogram AC250V (r.m.s) 圆片瓷介电容器 DISC CERAMIC CAPACITOR YUYUE VDE 40008010 DEMKO 315034-01 AC400V (r.m.s) 906443 EN60384-14 SEMKO FIMKO 25150 NEMKO P09210990 电容量规格 Capacitance Specification 2B(Y5P) 100~220 270~330 390~470 560~680 电容量 Capacitance(pF) 温度特性 Temperature Characteristics 2E(Y5U) 470 1000 外形尺寸 Diameter(mm) 2F(Y5V) 1000 1500 2200 3300 D 06 07 08 Tmax F±1.0 d±0.05 09 7.0 10.0 0.60 10 11 3300 12 4700 4700 15 ※ 超出本规范的圆片瓷介电容器产品,可按顾客要求提供。For units beyond above specification, please consult us. 820 1000 1500~2200 四、 HR 系列高压瓷介电容器 HR Series High Voltage Ceramic Capacitor 特性 Features 低损耗,用于开关电源缓冲器 Low Loss for Switching Power Supply Snubber Circuit 常规性能 General Specification 工作温度范围 Operating Temp. Range -25℃ to +85℃ 电容量 Capacitance 在 1KHz±20% ,1.0±0.2Vrms 下测试,容量在允许偏差范围内 Within the Specified Tolerance at 1KHz±20% ,1.0±0.2Vrms 电容量公差 Capacitance Tolerance K:±10%, M:±20% 损耗 Dissipation Factor(DF) DF≤0.2% 额定电压 Rated Voltage(UR) 1KV、2KV 耐电压 Dielectric Withstanding Voltage 2UR for 2 to 5 S(Charge /Discharge current≤50mA) 绝缘电阻(IR)Insulation Resistance 10000MΩ min at 500VDC and 1 minute electrification at 1KHz±20% ,1.0±0.2Vrms 电容量规格 Capacitance Specification 额定电压 Rated 电容量 Capacitance(pF) -6- 外形尺寸 Diameter(mm) 圆片瓷介电容器 DISC CERAMIC CAPACITOR YUYUE 温度特性 Temperature Characteristics DC 1KV 2KV SL Y5R (R) D 10~68 150~330 05 82~100 470~560 06 150~180 680 07 220 820~1000 08 270 1200 09 330~390 1500~1800 10 470 2200 12 10~47 100~330 06 56~100 390~560 07 120~150 680 08 180 820 09 1000 10 220~270 1500 12 330 1800~2200 14 470~560 3300 16 Tmax F±1.0 d±0.05 4.0 5.0 or 7.5 0.6 5.0 五、 CC1 温度补偿型圆片瓷介电容器(ClassⅠ) CC1 Temperature Compensating Ceramic Capacitor(ClassⅠ) 特性 Features 电容量变化与温度呈线性 Linear Capacitance Change over Temperature 容量稳定性高 High Stability of Capacitance 低损耗 Low Loss at Wide Range of Frequency 多种温度系数,适用于谐振回路及温度补偿效应的回路。 Various T.C. available Suits for Oscillation and Temperature Compensating Circuit. 常规性能 General Specification -7- 工作温度范围 Operating Temp. Range -25℃ to +85℃ 电容量 Capacitance 在 1MHz±20% ,1.0±0.2Vrms 下测试,容量在允许偏差范围内 Within the Specified Tolerance at 1MHz±20% ,1.0±0.2Vrms 电容量公差 Capacitance Tolerance C:±0.25pF,D:±0.5pF,J:±5%,K:±10% 损耗 Dissipation Factor(DF) C<50pF, DF≤1.5(150/CR+7) ×10-4 C≥50pF, DF≤15×10-4 at 1MHz±20% ,1.0±0.2Vrms 额定电压 Rated Voltage(UR) 50V to 耐电压 Dielectric Withstanding Voltage 2.5UR for 2 to 5 S (Charge /Discharge current≤50mA) 绝缘电阻(IR)Insulation Resistance 10000MΩ min at rated voltage and 1 minute electrification 500V 圆片瓷介电容器 DISC CERAMIC CAPACITOR 电容量规格 Capacitance Specification 额定电压 Rated voltage DC 50V 160V 250V YUYUE 外形尺寸 Diameter (mm) 电容量 Capacitance(pF) 温度系数 Temperature Coefficient. NP0 (C) N150 (P) N220 (R) N330 (S) N470 (T) N750 (U) SL 0.5~47 1~47 15~39 15~39 15~39 20~56 24~220 51~82 51~62 43~56 62~82 240~270 06 100 680~100 62~100 91~120 300~430 07 110~150 110~150 110~150 121~150 470~550 08 180~260 180~260 180~260 180~200 560~680 09 220~270 750~820 10 1000 12 270~330 360~390 470 500V D 04 05 14 1~39 20~120 05 47 150~180 06 51~68 200~220 07 82~100 270 08 300~330 09 六、 CT1 高介电常数型圆片瓷介电容器(ClassⅡ) CT1 High Dielectric Constant Ceramic Capacitor(ClassⅡ) 特性 Features 电容量变化与温度呈非线性关系 Nonlinear Capacitance change over temperature 适用于旁路、耦合电路中 Suits for By-pass, Coupling Circuit 常规性能 General Specification -8- F±1.0 2.5 Or 5.0 工作温度范围 Operating Temp. Range Y5P、Y5U、Y5V:-25℃ to +85℃,Z5U、Z5V:+10℃ to +85℃ 电容量 Capacitance 在 1KHz±20% ,1.0±0.2Vrms 下测试,容量在允许偏差范围内 Within the Specified Tolerance at 1KHz±20% ,1.0±0.2Vrms 电容量公差 Capacitance Tolerance K:±10%, M:±20%, Z:+80-20% 损耗 Dissipation Factor(DF) Y5P,:DF≤2.5%,BN≤0.5% Y5U,Z5U ,Y5V,Z5V:DF≤3.5% at 1KHz±20% ,1.0±0.2Vrms 额定电压 Rated Voltage(UR) 50V to 耐电压 Dielectric Withstanding Voltage 2.5UR for 2 to 5 S (Charge /Discharge current≤50mA) 绝缘电阻(IR)Insulation Resistance 4000MΩ min at rated voltage and 1 minute electrification 500V 圆片瓷介电容器 DISC CERAMIC CAPACITOR YUYUE 电容量规格 Capacitance Specification DC 50V 160V 250V 500V 外形尺寸 Diameter (mm) 电容量 Capacitance(pF) 额定电压 Rated Voltage 温度特性 Temperature Characteristics Y5P (B、BN) Y5U (E) Z5U (E) Y5V (F) Z5V (F) D 100~2200 1000~5000 1000~6800 4700~6800 5600~10000 05 2400~3300 5600~6800 8200~10000 8200~10000 15000 06 3600~4700 8200~10000 15000 22000 07 5000~6800 22000 22000 08 8200 09 10000 10 100~1000 1000~2200 1000~2200 2200~3300 1200~1500 2700~3300 2700~3300 3900~5600 4700~5000 06 1800~2200 3900~4700 3900~5000 6800~8200 6800 07 2700 5000~6800 5600~6800 10000 8200~10000 08 3000~3900 8200~10000 8200~10000 15000 09 22000 10 4700 5600~6800 05 22000 22000 8200~10000 33000 12 47000 14 100000 七、 CS1 半导体型圆片瓷介电容器 (ClassⅢ) CS1 Semi-Conductive Dielectric Ceramic Capacitor (ClassⅢ) 特性 Features 大容量、小体积 Large Capacitance in Small Size 适用于绝缘电阻低的低阻抗电路 Used in Low Impedance Circuit of Low IR -9- F±1.0 18 2.5 or 5.0 常规性能 General Specification 工作温度范围 Operating Temp. Range -25℃ to +85℃ 电容量 Capacitance 在 1KHz±20% ,0.1±0.01Vrms 下测试,容量在允许偏差范围内 Within the Specified Tolerance at 1KHz±20% ,0.1±0.01Vrms 电容量公差 Capacitance Tolerance K:±10%, M:±20%, Z:+80-20% 损耗 Dissipation Factor(DF) Y5P:DF≤3.5%, Y5U:DF≤5.0%, Y5V:DF≤7.5% at 1KHz±20% ,0.1±0.01Vrms 额定电压 Rated Voltage(UR) 16V,25V,50V 耐电压 Dielectric Withstanding Voltage 1.5UR for 2 to 5 S (Charge /Discharge current≤50mA) 绝缘电阻(IR)Insulation Resistance 16V:100MΩ or 10 MΩuF 1 minute electrification 25V、50V:1000MΩ or 20 MΩuF 1 minute electrification 圆片瓷介电容器 DISC CERAMIC CAPACITOR YUYUE 电容量规格 Capacitance Specification 额定电压 Rated Voltage DC 温度特性 Temperature Characteristics Y5P(B) 16V 10000 Y5U(E) Y5V(F) 100000 100000 40000~47000 15000~27000 25V 外形尺寸 Diameter (mm) 电容量 Capacitance(pF) 33000~47000 82000~100000 47000~68000 150000 06 08 40000~47000 04 50000~68000 05 100000 06 07 220000 08 09 82000~100000 10 10000~15000 10000~33000 18000~27000 40000~47000 82000~100000 33000~68000 10000~22000 04 33000~47000 05 68000~100000 220000 100000 F±1.0 05 220000 220000 50V D 2.5 or 5.0 06 07 08 11 注:100V 以上产品可根据顾客要求提供 Units of 100v and over are available upon request. 八、 CC81 型高压瓷介电容器 CC81 Series High Voltage Ceramic Capacitor 特性 Features 环氧树脂包封,可提供无卤素环氧树脂包封 Epoxy Coating for all Parts,HF Epoxy Coating be provided 容量稳定性高 High Stability of Capacitance 常规性能 General Specification - 10--11 工作温度范围 Operating Temp. Range -25℃ to +85℃ 电容量 Capacitance 在 1MHz±20% ,1.0±0.2Vrms 下测试,容量在允许偏差范围内 Within the Specified Tolerance at 1MHz±20% ,1.0±0.2Vrms 电容量公差 Capacitance Tolerance C:±0.25pF,D:±0.5pF,J:±5%,K:±10% 损耗 Dissipation Factor(DF) C<50pF, DF≤1.5(150/CR+7) ×10-4 C≥50pF, DF≤15×10-4 at 1MHz±20% ,1.0±0.2Vrms 额定电压 Rated Voltage(UR) 1KV to 耐电压 Dielectric Withstanding Voltage 1.5UR +500V for 2 to 5 S (Charge /Discharge current≤50mA) 绝缘电阻(IR)Insulation Resistance 10000MΩ min at 500VDC and 1 minute electrification 3KV 圆片瓷介电容器 DISC CERAMIC CAPACITOR 电容量规格 Capacitance Specification 额定电压 Rated Voltage DC YUYUE 电容量 Capacitance(pF) 外形尺寸 Diameter(mm) 温度特性 Temperature Characteristics NP0 SL D 1~33 20~120 05 36~39 1KV 150~180 07 82 220 08 100~120 270 09 150 330~470 10 180~220 2KV 3KV F±1.0 d±0.05 06 47~68 1~18 Tmax 4.0 12 10~47 06 56~100 07 20~39 120~150 08 47~56 180 09 68 10 82 220~270 12 100~120 330 14 470~560 16 2~15 10~33 06 18~22 39~47 07 56~68 08 82~150 09 5.0 or 7.5 0.5 or 0.6 7.5 or 10.0 0.6 5.0 6.0 九、 CT81 型高压瓷介电容器 CT81 Series High Voltage Ceramic Capacitor 特性 Features 环氧树脂包封, 可提供无卤素环氧树脂包封,应用范围广泛 Coating be provided, Wide Range of General Purpose Applications 常规性能 General Specification Epoxy Coating for all Parts,HF Epoxy 工作温度范围 Operating Temp. Range Y5P、Y5U、Y5V:-25℃ to +85℃,Z5U、Z5V:+10℃ to +85℃ 电容量 Capacitance 在 1KHz±20% ,1.0±0.2Vrms 下测试,容量在允许偏差范围内 Within the Specified Tolerance at 1KHz±20% ,1.0±0.2Vrms 电容量公差 Capacitance Tolerance K:±10%, M:±20%, Z:+80-20% 损耗 Dissipation Factor(DF) Y5P、Y5U、Z5U:DF≤2.0%,BN:DF≤0.5%, Y5V、Z5V:DF≤3.5% at 1KHz±20% ,1.0±0.2Vrms 额定电压 Rated Voltage(UR) 1KV to 耐电压 Dielectric Withstanding Voltage 1.5UR +500V for 2 to 5 S (Charge /Discharge current≤50mA) 绝缘电阻(IR)Insulation Resistance 10000MΩ min at 500VDC and 1 minute electrification 6.3KV(6KV) 圆片瓷介电容器 DISC CERAMIC CAPACITOR 电容量规格 Capacitance Specification 额定电压 Rated Voltage DC 1KV YUYUE 电容量 Capacitance(pF) 外形尺寸 Diameter(mm) 温度特性 Temperature Characteristics Y5P (2B) BN(Y5P) Y5U (2E) Z5U (2E) Y5V (2F) Z5V (2F) D 100~680 100~680 1000~2200 05 820~1000 820~1000 3300 06 07 1000~2200 1000~2200 1200~1500 1200~1500 3300 3300 4700 1800~2000 1800~2000 4700 4700 6800 10000 08 2700~3300 2700~3300 6800 6800 10000 15000 09 3900 3900 4700 4700 10 10000 10000 22000 Tmax F±1.0 d±0.05 4.0 11 12 5600 5600 6800 6800 13 8200~10000 8200~10000 2KV 14 Or 0.5 47000 15 7.5 Or or 10.0 0.6 100~470 100~470 470~1000 470~1000 1000~2200 06 560~820 560~820 1500 1500 3300 07 2200 2200 4700 08 3300 3300 6800 1000~1500 1000~1500 1800 1800 2200 2200 2700 2700 3300 3300 6800 6800 3900 3900 10000 10000 4700 4700 3900~4700 3900~4700 5.0 33000 6800 09 10000 10 10000 11 5.0 12 15000 13 14 22000 15 To be continued 续 CT81 型高压瓷介电容器 额定电压 电容量 Capacitance(pF) -12 - 外形尺寸 圆片瓷介电容器 DISC CERAMIC CAPACITOR YUYUE 温度特性 Temperature Characteristics DC 3KV Y5P (2B) BN(Y5P) Y5U (2E) Z5U (2E) Y5V (2F) Z5V (2F) D 100~220 100~220 1000 06 330~470 330~470 2200 07 560~680 560~680 820~1000 820~1000 1000 1000 Tmax 08 2200 3300 2200 3300 09 4700 10 3300 F±1.0 7.5 6.0 or d±0.05 0.6 10.0 11 12 6.3KV(6KV) 100~220 100~220 470 470 1000 06 330 330 1000 1000 1500 07 470 470 680 680 1000 08 1500~2200 1500~2200 1000 3300 1500 2200 09 3300 10 4700 11 3300 12 1500 6800 13 14 4700 4700 10000 注:4KV,5KV 按订货资料生产。Note: 4KV,5KV can be made on customer’s demands. 十、 CT81 型超高压瓷介电容器 CT81 Super High Voltage Ceramic Capacitor 特性 Features - 13 - 16 6.0 10.0 0.6 独石电容 MULTILAYER CHIP CERAMIC CAPACITOR YUYUE 工作温度范围 Operating Temp. Range. -25℃ to +85℃ 电容量 Capacitance 在 1KHz±20% ,1.0±0.2Vrms 下测试,容量在允许偏差范围内 Within the Specified Tolerance at 1KHz±20% ,1.0±0.2Vrms 电容量公差 Capacitance Tolerance K:±10%, M:±20%, Z:+80-20% 损耗 Dissipation Factor(DF) DF≤2.0% 额定电压 Rated Voltage(UR) ≥7.5KV 耐电压 Dielectric Withstanding Voltage 1.5UR for 2 to 5 S (Charge /Discharge current≤50mA) 绝缘电阻(IR)Insulation Resistance 10000MΩ min at 500VDC and 1 minute electrification at 1KHz±20% ,1.0±0.2Vrms 阻燃绝缘包封 Flame-resistant insulation coating applied 高压电源、整流电路的应用 For High voltage DC power supply application 常规性能 General Specification 电容量规格 Capacitance Specification 额定电压 Rated Voltage DC 电容量 Capacitance(pF) 外形尺寸 Diameter (mm) 温度特性 Temperature Characteristics Y5P (B) Y5U(E) Y5V(F) D Tmax 100~220 07 330 08 470 10 7.5KV 8.0 680 1000 12 (8KV) 1000 1500 14 1500 2200 16 2200 18 100~220 08 330~470 10 10KV 9.0 680 1000 12 1000 2200 14 1500 16 100~220 09 330 10 470 12 15KV 10.0 680 1000 2200 14 820 1500 3300 16 1000 2200 4700 18 注:也可按顾客要求提供其他超高压陶瓷电容器(7.5KV,10KV,15KV 以外) NOTE:More CT81 super high voltage capacitors are available upon request except for those list above. 独石电容 Multiplayer ceramic capacitor - 14 - F±1.0 d±0.05 0.65 10.0 0.8 0.65 12.7 0.8 0.65 12.7 0.8 特性 Features 容量大、体积小、可靠性高、电容量稳定,耐高温耐湿性好等。广泛应用于电子精密仪器,以及各种小型电子设备作谐振、耦 合、滤波、旁路用。 With special constructive, small volume, and high reliability. The products are applied to Computers and various kinds of electronic equipments. 一、 品名的表示方法 Part Numbering System 0805 X7R 104 K 50V T CT4 尺寸规格 (长×宽(英寸) ) 0805 0.08×0.05 1206 0.12×0.06 1210 0.12×0.10 1812 0.18×0.12 2225 0.22×0.35 3035 0.30×0.35 CC4:1 类径向引线电容器 Class 1 radial leads MLC CT4:2 类径向引线电容器 Class 2 radial leads MLC 二、 介质种类 Dielectric NP0 X7R 误差 Tolerance C ±0.25pF D ±0.50pF 标称电容(pF) Nominal Capacitance 102 1000 5R0 5.0 Y5V J ±5% K ±10% M ±20% S +50-20% Z +80-20% 额定电压(V) Rated voltage 包装方式 package stype 25 盒式编带 Aammo Tape 散件 BULK T 50 B 100 常规性能 General Specification 工作温度范围 Operating Temp. Range. NP0 X7R :-55℃ to +125℃ Y5V: -30℃ to +85℃ NP0:Within the Specified Tolerance at 电容量 Capacitance 1MHz±20% ,1.0±0.2Vrms X7R:1KHz±20% ,1.0±0.2Vrms Y5V:1KHz±20% ,0.3±0.2Vrms 损耗 Dissipation Factor(DF) 耐电压 Dielectric Withstanding Voltage NP0:DF≤0.15% at 1MHz±20% ,1.0±0.2Vrms X7R:DF≤2.5% at 1KHz±20% ,1.0±0.2Vrms Y5V:DF≤3.5% at 1KHz±20% ,0.3±0.2Vrms 2.5UR for 2 to 5 S (Charge /Discharge current≤50mA) NP0:10000MΩ min at rated voltage and 1 minute electrification 绝缘电阻(IR)Insulation Resistance X7R:4000MΩ min or R*C≥100S at rated voltage and 1 minute electrification Y5V:4000MΩ min or R*C≥100S at rated voltage and 1 minute electrification 三、 温度特性 Temperature Characteristics (T.C.) △C/C 20 (%) △C/C20(10-3) NP0(0±30PPM) 5 3 1 -1 -3 -5 -55 -30 -5 20 45 70 Temperature(℃) 95 120 20 10 0 -10 -20 -30 -40 -50 -60 -70 -80 -75 - 15 - X7R Y5V -50 -25 0 25 50 Temperature(℃) 75 100 125 独石电容 MULTILAYER CHIP CERAMIC CAPACITOR 四、 尺寸、容量、额定电压的关系 Relationship with dimension, capacitance and rated voltage 尺寸代码 Size code 尺寸 Dimensions(mm) F±0.5 H±1 Lmax YUYUE 额定电压 Wmax Tmax 2.5 容量范围 Capacitance(pF) Rated Voltage (v) NP0 X7R Y5V 25 0R5-332 221-105 103-105 50 0R5-222 221-105 103-684 100 0R5-102 221-683 25 0R5-682 221-105 103-125 50 0R5-472 221-105 103-105 100 0R5-392 221-683 25 561-103 102-334 104-155 50 561-682 102-105 104-155 100 561-472 102-104 25 102-153 103-474 154-335 50 102-153 103-334 154-325 100 102-682 103-224 25 102-223 103-105 684-475 50 102-223 103-105 684-335 100 102-103 103-474 25 102-104 103-225 105-106 50 102-473 103-225 105-685 100 102-332 103-105 5.0 0805 4.2 5.0 3.8 3.8 10.0 7.5 5.0 1206 10.0 5.0 4.5 3.8 7.5 5.0 1210 10.0 7.6 5.5 3.8 7.5 1812 2225 3035 五、 5.0 7.5 7.5 10.0 10.0 10.0 8.5 10.0 12.5 8.5 9.5 10.5 包装数量 Packaging quantity 盒式包装 Ammo package 散件 Bulk 2000pcs 1000 或 500pcs ※可根据用户需要包装。Can be made on customer’s demands. - 16 - 3.8 4.2 4.2
CT109AZ5U103M500VT 价格&库存
很抱歉,暂时无法提供与“CT109AZ5U103M500VT”相匹配的价格&库存,您可以联系我们找货
