CWT-1000
CWT-1000
    CELFRAS(联智)
    QFN40_5X5MM_EP
    QI兼容10W无线功率发射IC
CWT-1000 数据手册
CWT1000® Datasheet Qi Compliant 10W Wireless Power Transmitter IC General Description CWT1000 can deliver up to 10W as a highly-integrated single-chip wireless medium power transmitter IC. It can be configured to receive its input power from USB or AC adapter. Our chip integrates a power amp driver and communication controllers which use Amplitude Shift Keying (ASK) and Frequency Shift Keying (FSK). Our chip includes a 32-bit ARM Cortex M0 processor in order to offer high level of programmability according to its applications. Communication and control units (CCU) can accommodate WPC protocol including fault condition handling associated with power transfer. The CCU supports the foreign object detection (FOD) extension. Also, the chip includes over-temperature and voltage protection. Features Overview   WPC-1.2.4 compliant for A11 low power  I2C programmable interface specification  Foreign object detection High-efficiency power transfer system  Current sensing supporting baseline power profile (5V LDO50 maximum output current 20 Internal LDO33 output voltage range VIN>5V 3.3 LDO33 maximum output current V 20 Internal LDO18 output voltage range VIN>5V 1.8 LDO18 maximum output current mA mA V 10 mA BGR Internal BGR output voltage Register programmable VIN>3.3V 1.22 V fOSC50K Internal low speed oscillator frequency Register programmable VIN>3.3V 50 kHz fOSC60M Internal main oscillator frequency Register programmable VIN>3.3V 60 MHz ADC resolution VIN>3.3V 12 bit fOSC60M=60MHz 217 kSa/s VBGR Oscillator ADC NADC fSAMPLE ADC sampling rate NCH_ADC ADC channel 6 Protection IOCL IIN over current limit protection RSENSE=20mΩ TOTP Over temperature protection Thermal shutdown temperature 30℃ to 160℃ Temperature: Temperature: 2 A 150 ℃ 20 ℃ TOTP_HYS OTP hysteresis VTS_HOT EXT_TS hot temperature protection threshold voltage VEXT_TS: 0V to 0.5V 0.315 V VTS_HOT hysteresis VEXT_TS: 0.5V to 0V 20 mV EXT_TS cold temperature protection threshold voltage VEXT_TS: 0.5V to 1.5V 0.980 V VTS_COLD hysteresis VEXT_TS: 1.5V to 0.5V 80 mV VTS_HOT_HYS VTS_COLD VTS_COLD_HYS CELFRAS, Inc. 160℃ to 30℃ -11- CWT1000 Datasheet (Rev 1.1) CWT1000 Qi Compliant 10W Wireless Power Transmitter IC 6. I2C Signal Timing Figure 6. Timing Diagram for I2C interface Symbol Description Conditions VIL_SDA Input low threshold level SDA VPULLUP=VDD_IO=3.3V VIH_SDA Input high threshold level SDA VPULLUP=VDD_IO=3.3V VIL_SCL Input low threshold level SCL VPULLUP=VDD_IO=3.3V VIH_SCL Input high threshold level SCL VPULLUP=VDD_IO=3.3V Min. Typ. Max. Unit 0.7 V 2.6 V 0.7 2.6 V V fSCL SCL clock frequency 400 kHz tLOW SCL clock low time 1.3 us tHIGH SCL clock high time 0.6 us tr Rise time of both SDA and SCL 0.3 us tf Fall time of both SDA and SCL 0.3 us tSU,STA Setup time for START condition 0.6 us tHD,STA Hold time for START condition 0.6 us tSU,DAT Data setup time 0.1 us tHD,DAT Data hold time tSU,STO Setup time for STOP condition 0.6 us Bus free time between STOP and START condition 1.3 us tBF 0.9 us Table 2. I2C Characteristics CELFRAS, Inc. -12- CWT1000 Datasheet (Rev 1.1) CWT1000 Qi Compliant 10W Wireless Power Transmitter IC Revision History Date Version No. 2018/03/25 2018/07/26 1.0 1.1 CELFRAS, Inc. Description Initial Release Modify Pin definition -13- CWT1000 Datasheet (Rev 1.1) CWT1000 Qi Compliant 10W Wireless Power Transmitter IC Contact US  Headquarters CELFRAS Semiconductor Inc. 江西联智集成电路有限公司 59 Chuangxin No.1 Road, Nanchang Hi-tech Development Zone, Nanchang, Jiangxi, P.R.CHINA, Zip:330000  International CELFRAS Design Center Inc. 7F, 225-14, Pangyoyeok-ro, Bundang-gu, Seongnam-si, Gyeonggi-do, 13494, Korea Tel. +82-70-4055-6466 Fax +82-31-707-8825  Contact Website http://www.celfras.com/ Technical Support cts@celfras.com, june_yoo@celfras.com Sales Contact marketing@celfras.com Copyright © 2018 CELFRAS., Inc. All rights reserved. CELFRAS., Inc. CELFRAS, Inc. -14- CWT1000 Datasheet (Rev 1.1)
CWT-1000 价格&库存
很抱歉,暂时无法提供与“CWT-1000”相匹配的价格&库存,您可以联系我们找货
