CWR-500(CSP)
CWR-500(CSP)
    CELFRAS(联智)
    WLCSP(2.6x3.9)
    QI兼容5W无线电源接收器IC
CWR-500(CSP) 数据手册
CWR500® Datasheet Qi Compliant 5W Wireless Power Receiver IC General Description CWR500 can deliver up to 5W as a highly-integrated single-chip wireless medium power receiver IC. As wireless power transfer systems are getting more popular, they require more fast charging and high efficiency solution. The CWR500 wireless power receiver IC is compliant with WPC 1.2.4 standard and supports the 5W baseband power profile (BPP) . The CWR500 power receiver integrates a synchronous rectifier, a low drop-out regulator, and communication controllers which use Amplitude Shift Keying (ASK) . The chip also supports the Foreign Object Detection (FOD) extension in WPC 1.2.4. For achieving chip stability, protection tools are implemented, such as over-current-protection, over-voltage-protection, thermal shutdown, and under voltage lock-out (UVLO). Configurable analog blocks can be used independently and co-operated with the control and communication unit. Features Overview       Single-chip dual mode 5W receiver for WPC 1.2.4 compliance Support 5W baseline power profile (BPP) FOD extension supports Integrated Synchronous Rectifier Receiver. - Support Output Power up to 5W. - High Rectifier Efficiency up to 95%. - High System Efficiency up to 90%. - Topology Auto Selection operation. Programmable Dynamic Rectifier Voltage Cont rol. Integrated Programmable Linear Regulator. - Output voltage range of 4.5~5.5V with 0.5V control step.         - Adaptive Coil Power loss/offset compensation. Programmable Temperature Control. Charger Complete and Enable control inputs End of Power Transfer (EPT) Packet manage ment. Over Current Limit Over Voltage Protection Thermal Shutdown WLCSP 50B 2.64mm x 3.94mm, 0.4mm pitch 384-bit One-Time-Programmable Device Applications - WPC Compliant Receivers. - Cell phones and smart phones.  - Output current limit up to 1A. Bi-directional channel communication - Digital Cameras. - Power Banks.   - ASK modulation for PRx to PTx 24-bit Power Calculation support Received Power Calculation for FOD function - Wireless Power Embedded Batteries - Bluetooth Headsets - Portable Media Players - Other Hand-held Device - 12-bit ADC for voltage/current measuremen t. 1. Description for Implementation Datasheet (REV. 1.0) Information furnished by CELFRAS is believed to be accurate and reliable. However, no responsibility is assumed by CELFRAS for its use, nor for any infringements of patents or other rights of third parties which may result from its use. No license is granted by implication or otherwise under any patent or patent rights of CELFRAS. World Wide Web Site: TBD Revised 2017-12-28 CWR500 Qi Compliant 5W Wireless Power Receiver IC Figure 1. CWR500 Block Diagram 1.1 Overview A wireless power charging system is composed of transmitter and receiver. In general, wireless power transmitter will transfer AC power using a power amplifier through a TX inductor coil. Then wireless power receiver will receive AC power through an RX inductor coil which is strongly coupled with the TX coil. In receiver part, rectifier will change the AC power to DC power and LDO will transfer the DC power to battery charger. Figure1 shows the block diagram of CWR500 wireless charging receiver IC. CWR500 receiver will support power transfer up to 5W and it is compliant with WPC1.2.4 standards. It consists of rectifier, main LDO, internal LDOs, ADC, digital controller and etc. 1.2 Rectifier CWR500 employs a synchronous active rectifier in order to improve AC to DC power conversion efficiency. The rectifier power conversion efficiency is very important because it has a large influence on overall receiver efficiency. The rectifier in CWR500 will support full-wave, half-wave and passive mode according to the transferred power level. When the power transfer is started initially, the rectifier will operate in passive mode and supply the system power to overall receive IC. 1.3 Main LDO CELFRAS Semiconductor, Inc. -2- CWR500 Datasheet (Rev 1.0) CWR500 Qi Compliant 5W Wireless Power Receiver IC Main LDO regulator will transfer DC power from rectifier output to battery charger. LDO in CWR1000 is designed to transfer power up to 5W and its output voltage level can be changed by user. The LDO power transistor is designed to minimize its on-resistance because the LDO drop-out voltage is directly related to overall system efficiency. Especially, in case of large power transfer, the LDO drop-out voltage (VRECT-VOUT) should be controlled as small as possible. 1.4 ASK Modulator CWR1000 power receiver communicates with the power transmitter by ASK modulator. The ASK modulator make up the WPC standard 2kHz bi-phase signal by switching the capacitors between COMM1/2 and AC1/AC2. Switching the capacitance at AC1/AC2 nodes will change the impedance of transmitter coil. As a result, amplitude modulation is built up. 1.5 ADC CWR1000 power receiver employs 12-bit SAR ADC because it has low power, small area characteristics and moderate speed performance. ADC monitors important internal voltages and currents and gives the system information to the digital controller. 1.6 Protection CWR500 power receiver employs various protection schemes in order to prevent system damage. When the VRECT voltage is too high, the OVP (Over Voltage Protection) function will turn on the clamp path or send the EPT (End Power Transfer) packet to the transmitter. When the main LDO current is too large, the OCL (Over Current Limit) function will limit the output current. When the temperature inside or outside the chip is too high, the OTP (Over Temperature Protection) function will send the EPT packet to transmitter or shutdown the receiver system. 1.7 Digital Controller Digital controller in CWR500 controls all the analog blocks and entire system to perform power transfer operation according to the wireless power transfer standard, that is, WPC 1.2.4. It also supports I2C interface to communicate with external host. CELFRAS Semiconductor, Inc. -3- CWR500 Datasheet (Rev 1.0) CWR500 Qi Compliant 5W Wireless Power Receiver IC 2. Pin-out and description Figure 2. CWR500 Pin Configuration (WLCSP 50B 2.64mm x 3.94mm, 0.4mm pitch) 2.1 Pin Description (WLCSP 50B 2.64mm x 3.94mm, 0.4mm pitch) Pin Number Name Type A1 CMA O A6 CMB O A2 EXT_TS I External temperature sensor input. Connect this pin to external NTC thermistor. If not used, connect this pin to VDD_DIG. A3 VDD_DIG P Internal 3V LDO output for digital block and etc. 1uF capacitor connect to GND. Not for external use A4 VPP I 8V high voltage power for OTP programming. During the normal operation, connect this pin to VDD_DIG. A5 FOD I FOD offset setting pin. Connect a resistor between this pin and GND. B1 COMM1 O B6 COMM2 O High voltage open drain output for ASK modulation. Connect 47nF capacitor from AC1/AC2 to COMM1/COMM2 separately B2 SDA I/O CELFRAS Semiconductor, Inc. Description NC I2C data input/output for internal register access. -4- CWR500 Datasheet (Rev 1.0) CWR500 Qi Compliant 5W Wireless Power Receiver IC B3 SCL I I2C clock input for internal register access. B4 DIG1 I Enable scan test mode. Connect to GND directly in normal application. B5 ILIM I Output current or over-current limit level programming pin. C1,D2,D5,D6 AVSS P Analog ground pin. C2 DIG3 I Scan clock for scan test mode. Connect to GND directly in normal application. C3 DIG2 I Scan enable for scan test mode. Connect to GND directly in normal application. C4 ENB I Active-low enable pin for the entire chip. C5 CHG_DONE I Active-high input from the external battery charger to terminate power transfer. C6 VDD_5V P Internal 5V LDO output pin for 1uF capacitor connection. Not for external use D1 CLAMP O High voltage open drain output for analog linear over-voltage protection. D3 DIG_TEST O Digital test output pin. Floating for normal application D4 ANA_TEST O Analog test output pin. Floating for normal application VOUT P Main LDO output pin for delivering power to the battery charger. 3.3uF capacitor connect to GND. VRECT P Internal synchronous rectifier output for 20uF capacitor connection. G1 BOOST1 O G6 BOOST2 O Bootstrap capacitor connection pin for driving the high-side FETs of synchronous rectifier. Connect 100nF capacitor to AC1/AC2 separately H1,H2,H3 AC1 I H4,H5,H6 AC2 I PGND P E1,E6,F2,F3 F4,F5 F1,F6,G2,G3 G4,G5 J1,J2,J3,J4 J5,J6 CELFRAS Semiconductor, Inc. AC power input of synchronous rectifier. Power ground for synchronous rectifier. -5- CWR500 Datasheet (Rev 1.0) CWR500 Qi Compliant 5W Wireless Power Receiver IC Application Guide Figure 4. CWR500 Typical Application Diagram 2.2 Receiver Coil and Resonant Capacitors The receiver coil design is related to the overall system application. The coil inductance, shape and material can be chosen according to the applications. The recommended receiver coil inductance for dual mode operation is between 5uH to 10uH. Series and parallel resonant capacitors CS and Cd are set according to WPC specification. The capacitance of the resonant capacitors can be calculated by the following equations. CS = Cd = 1 L'S ⅹ 2πfS 1 LS ⅹ 2πfD 2 2 − 1 CS In these equations, fS and fD are the dual resonant frequencies which cover the power transfer frequency range. Follow WPC Qi 1.2.4 specifications, fS is set to 100 kHz and fD is set to 1000kHz, respectively. L’S is coil self-inductance when placed on the transmitter, and LS is the self-inductance when placed away from the transmitter. 2.3 Boost and Communication Capacitors As shown in Figure 4, two external bootstrap capacitors CBOOST1 and CBOOST2 are needed to drive the highside FETs of synchronous rectifier. Bootstrap capacitors should have voltage rating of more than 25V and their recommended capacitances are 100nF. CELFRAS Semiconductor, Inc. -6- CWR500 Datasheet (Rev 1.0) CWR500 Qi Compliant 5W Wireless Power Receiver IC In order to communicate with transmitter, external capacitors should be connected between high voltage open drain output and AC1/AC2 input. CWR500 will be switching COMM1/COMM2 output in WPC mode. Typical recommended capacitance values are CCOMM1=CCOMM2=47nF. 2.4 Output Regulating Capacitors As shown in Figure 4, rectifier output VRECT and internal LDOs’ output VOUT, VDD_5V, VDD_DIG should be connected to external capacitor for voltage regulation. Typical recommended capacitance values are CVRECT=20uF, CVOUT=3.3uF, CVDD_5V=1uF, CVDD_DIG=1uF, respectively. 2.5 Clamp Resistor When the VRECT voltage is too high, the OVP (Over Voltage Protection) function will turn on the clamp path or send the EPT (End Power Transfer) packet to the transmitter. The clamp path uses high voltage open drain output for analog linear OVP. The recommended resistance value of RCLAMP is between 10Ω to 50Ω according to the transfer power level of application. 2.6 Current Limit and FOD Setting Resistors When the main LDO current is too large, the OCL (Over Current Limit) function will limit the output current. The current limit level can be adjusted by external resistors and it is calculated as follows, ILIM = 45000 45000 = RILIM RIL1 + RIL2 In this equation, the RILIM is the total resistance from the ILIM pin to ground, that is, RIL1 + RIL2 as shown in Figure 4. It is recommended to use the resistors of good tolerance less than 1%, because the current estimation in wireless power receiver is very important. CWR500 adds an FOD offset proportional to output power level when it sends the received power packet to transmitter. The amount of the added FOD offset can be adjusted by the ratio of RIL1 to (RIL1 + RIL2). 2.7 External Temperature Sensor When the temperature inside or outside the chip is too high, the OTP (Over Temperature Protection) function will send the EPT packet to transmitter or shutdown the receiver system. In order to sense the temperature outside chip, connect EXT_TS pin to external NTC (Negative temperature Coefficient) thermistor as shown in Figure 4. The NTC thermistor should be placed close to the heat emission device. The EXT_TS voltage VEXT_TS can be calculated as follows, VEXT_TS RNTC + RTS1 × RTS3 RNTC + RTS1 + RTS3 = VDD_DIGⅹ RNTC + RTS1 × RTS3 + RTS2 RNTC + RTS1 + RTS3 In this equation, VDD_DIG is 3V from the internal LDO. CWR1000 compares VEXT_TS with internal reference voltages VTS_HOT and VTS_COLD. If VEXT_TSVTS_COLD, it means external temperature is too low and CWR500 also sends the EPT packet (value=0x03) to transmitter. Remind that VEXT_TS is negative slope curve vs temperature. The internal reference voltages VTS_HOT and VTS_COLD are fixed values as follows, Internal TS Reference Threshold Voltage [V] Hysteresis [mV] VTS_HOT 0.315 20 CELFRAS Semiconductor, Inc. -7- CWR500 Datasheet (Rev 1.0) CWR500 Qi Compliant 5W Wireless Power Receiver IC VTS_COLD 0.980 80 Recommended NTC resistance range is from hundreds of Ω to hundreds of kΩ vs temperature. After choosing the appropriate NTC thermistor, you can design RTS1, RTS2 and RTS3 according to your thermal protection specification. Table 1 shows an EXT_TS thermal protection design example. Temp VDD_DIG [V] RNTC RTS1 RTS2 RTS3 [℃] [kΩ] [kΩ] [kΩ] [kΩ] VEXT_TS [V] -40 3.0 188.5 3.9 47 68 1.550 -30 3.0 111.3 3.9 47 68 1.429 -20 3.0 67.8 3.9 47 68 1.278 -10 3.0 42.5 3.9 47 68 1.109 0 3.0 27.3 3.9 47 68 0.938 10 3.0 18.0 3.9 47 68 0.782 20 3.0 12.1 3.9 47 68 0.648 30 3.0 8.31 3.9 47 68 0.541 40 3.0 5.83 3.9 47 68 0.460 50 3.0 4.16 3.9 47 68 0.399 60 3.0 3.02 3.9 47 68 0.354 70 3.0 2.23 3.9 47 68 0.321 80 3.0 1.67 3.9 47 68 0.296 90 3.0 1.27 3.9 47 68 0.278 100 3.0 0.98 3.9 47 68 0.265 110 3.0 0.76 3.9 47 68 0.255 120 3.0 0.60 3.9 47 68 0.247 Status VEXT_TS > VTS_COLD Send EPT packet VTS_HOT < VEXT_TS < VTS_COLD Normal charging operation VEXT_TS < VTS_HOT Send EPT packet Table 1. EXT_TS Thermal Protection Design Example In this example, the hot temperature threshold TTS_HOT and the cold temperature threshold TTS_COLD are designed to be 80℃ and -10℃ respectively. You can change the hot and cold temperature threshold according to your application by changing the related resistors. 2.8 CHG_DOWN When CHG_DOWN is from low to high, CWR500 send “charging complete” EPT (0x01) to TX to inform TX that battery is charging complete. 2.9 ENB When applying logic high to ENB, CWR500 is suspended and IC leakage current will be smaller than 10uA. When ENB is logic low level, CWR500 is enabled for wireless charging. 2.10 PCB Layout Guide  Keep the trace resistance as low as possible on large current nets as shown in Table 2. CELFRAS Semiconductor, Inc. -8- CWR500 Datasheet (Rev 1.0) CWR500 Qi Compliant 5W Wireless Power Receiver IC  Resonant capacitors CS and Cd need to be as close to the device as possible.  Clamp, boost and communication capacitors (CCLAMP, CBOOST1, CBOOST2, CCOMM1, CCOMM2, CCMA and CCMB) need to be as close to the device as possible.  Output regulating capacitors CVRECT and CVOUT need to be as close to the device as possible.  LDO capacitors C Net (Ball) Type Maximum Current [A] AC1, AC2 AC 1.5 VRECT AC 1.5 VOUT DC 1.5 PGND AC 1.5 COMM1, COMM2, CMA, CMB AC 1 CLAMP AC 1.5 Table 2. Large Current Nets 2.11 Register Map 7bit Address: 0x24H. Register index (hex) 27h 2Eh 2Fh 41h 42h 5Ch 5Dh 5Eh 62h 63h 64h 68h 69h Bit Number B7 B6 B5 B4 B3 SET_VOUT_EXTENDED[3:0] COLD_UTP[1:0] OCL_ON_ PEN_PROT MASK B2 B1 B0 SET_VOUT_BASE_LINE[3:0] OVP[1:0] HOT_OTP[1:0] OTP_COLD_ TSD_OUT_ OVP_OU OTP_HOT RELEASE_TIME[1:0] MASK T_MASK _ MASK MASK REF_Q_FACTOR PTC_GUARANTEED_PWR ADC_CODE Reserved ADC_OUT[11:8] ADC_OUT[7:0] 8bit RP 24bit RP[15:8] 24bit RP[7:0] POWER_CLASS GUARANTEED_POWER_VALUE Reserved POTENTIAL_POWER_VALUE CELFRAS Semiconductor, Inc. TSD[1:0] -9- W/R W/R W/R W/R W/R R W/R R R R R R R R CWR500 Datasheet (Rev 1.0) CWR500 Qi Compliant 5W Wireless Power Receiver IC DETAILED REGISTER INFORMATION REG 27H REG Bit REG 2FH Type Default Description 7 VOUT_EPP[3] R/W 1 6 VOUT_EPP[2] R/W 0 5 VOUT_EPP[1] R/W 0 4 VOUT_EPP[0] R/W 1 3 VOUT_BPP[3] R/W 0 Setup bits of VOUT voltage for base line profile 2 VOUT_BPP[2] R/W 0 Offset: 4.5 V, Range 4.5 V – 9.5 V; Unit=0.5V 1 VOUT_BPP[1] R/W 0 Default: 5 V (0001). 0 VOUT_BPP[0] R/W 1 Normal case, VOUT=5V in BPP mode Type Default Bit Field 7 COLD_UTP[1] R/W 1 6 COLD_UTP[0] R/W 0 5 2EH Field 4 TSD[1] R/W TSD[0] R/W Default: Description 00 1.163V / 1.073V (Detection / Release) 01 1.069V / 0.984V (Detection / Release) 10 0.980V / 0.898V (Detection / Release) 11 0.894V / 0.820V (Detection / Release) 00 130 ℃ / 110 ℃ (Die OTP Detection / Releas e) 01 140 ℃ / 120 ℃ (Die OTP Detection / Releas e) 10 150 ℃ / 130 ℃ (Die OTP Detection / Releas e) 11 160 ℃ / 140 ℃ (Die OTP Detection / Releas e) 00 14.0 V / 12.5 V (Detection / Release) 01 14.5 V / 13.0 V (Detection / Release) 10 15.0 V / 13.5 V (Detection / Release) 11 15.5 V / 14.0 V (Detection / Release) 0 OVP[1] R/W 1 2 OVP[0] R/W 0 1 HOT_OTP[1] R/W 1 0 HOT_OTP[0] R/W 0 Type Default Field Offset: 4.5 V, Range 4.5 V – 9.5 V; Unit=0.5V 1 3 Bit Setup bits of VOUT voltage for extended profile , 00 0.339V / 0.367V (Detection / Release) 01 0.326V / 0.351V (Detection / Release) 10 0.314V / 0.335V (Detection / Release) 11 0.306V / 0.322V (Detection / Release) Description 0:disable protection function, 1:enable protection function 7 PEN_PROT R/W 1 6 OCL_ON_MASK R/W 1 5 RELEASE_TIME[1] R/W 0 RELEASE_TIME[0] R/W 3 TSD_OUT_MASK R/W 1 0: No mask; 1: mask Initially all signals are masked and release masks after a time delay. 00:No release; 01: Release after 5s; 10: Release after 10s; 11:Release after 20s; 0: No mask; 1: mask 2 OVP_OUT_MASK R/W 1 0: No mask; 1: mask 1 OTP_HOT_MASK R/W 1 0: No mask; 1: mask 4 CELFRAS Semiconductor, Inc. 0 -10- CWR500 Datasheet (Rev 1.0) CWR500 Qi Compliant 5W Wireless Power Receiver IC 0 REG 41H REG Bit Default 6 REF_Q_FACTOR[6] R/W 0 5 REF_Q_FACTOR[5] R/W 0 4 REF_Q_FACTOR[4] R/W 1 3 REF_Q_FACTOR[3] R/W 0 2 REF_Q_FACTOR[2] R/W 1 1 REF_Q_FACTOR[1] R/W 0 0 REF_Q_FACTOR[0] R/W 0 Type Default Bit Field 7 Reserved - - 6 Reserved - - R 0 R 0 R 1 R 0 R 1 R 0 Bit PTC_GUARANTEED_PO WER[5] PTC_GUARANTEED_PO WER[4] PTC_GUARANTEED_PO WER[3] PTC_GUARANTEED_PO WER[2] PTC_GUARANTEED_PO WER[1] PTC_GUARANTEED_PO WER[0] Field Type Default 7 Reserved - - 6 Reserved - - 5 - - 4 Reserved Reserved - - 3 ADC_CODE[3] R/W 0 2 ADC_CODE[2] R/W 0 1 ADC_CODE[1] R/W 0 0 ADC_CODE[0] R/W 0 Bit Field Type Default 7 Reserved - - 6 Reserved - - 5 Reserved - - 4 Reserved - - 3 ADC_OUT[11] R 0 3 0 5DH Type 0 1 REG 0: No mask; 1: mask R/W 2 5CH Field 1 REF_Q_FACTOR[7] 4 REG R/W 7 5 42H OTP_COLD_MASK CELFRAS Semiconductor, Inc. -11- Description Quality factor reference value Description Reserved Guaranteed Power Value in Power Transfer Contract. Unit=0.5W Description Reserved The related ADC_OUT value is loaded to Reg: 0x5D and Reg 0x5E. 4'b0000:VRECT; 4’0001:VOUT 4’b0010:IOUT; 4’b0011:ILIM 4’b0100:FOD; 4’b0101:EXT_TS 4’b0110:VCTAT Description Reserved ADC value with Reg 5EH according to CWR500 Datasheet (Rev 1.0) CWR500 Qi Compliant 5W Wireless Power Receiver IC REG 5EH REG 62H REG 63H REG 64H 2 ADC_OUT[10] R 0 1 ADC_OUT[9] R 0 0 ADC_OUT[8] R 0 ADC_CODE register select ADC channel ADC MSB 4bits Bit Field Type Default 7 ADC_OUT[7] R 0 6 ADC_OUT[6] R 0 5 ADC_OUT[5] R 0 4 ADC_OUT[4] R 0 3 ADC_OUT[3] R 0 2 ADC_OUT[2] R 0 1 ADC_OUT[1] R 0 0 ADC_OUT[0] R 0 Bit Field Type Default 7 8bit RP[7] R 0 6 8bit RP[6] R 0 5 8bit RP[5] R 0 4 8bit RP[4] R 0 3 8bit RP[3] R 0 2 8bit RP[2] R 0 1 8bit RP[1] R 0 0 8bit RP[0] R 0 Bit Field Type Default 7 24bit RP[15] R 0 6 24bit RP[14] R 0 5 24bit RP[13] R 0 4 24bit RP[12] R 0 3 24bit RP[11] R 0 2 24bit RP[10] R 0 1 24bit RP[9] R 0 0 24bit RP[8] R 0 Bit Field Type Default 7 24bit RP[7] R 0 6 24bit RP[6] R 0 5 24bit RP[5] R 0 4 24bit RP[4] R 0 3 24bit RP[3] R 0 CELFRAS Semiconductor, Inc. -12- Description ADC value with Reg5DH according to ADC_COUD register select ADC channel ADC LSB 8bits Description 8bits Receiver Power Package ValueBPP only Description 24bits Receiver Power Package Value High 8bits-EPP only Description 24bits Receiver Power Package Value Low 8bits-EPP only CWR500 Datasheet (Rev 1.0) CWR500 Qi Compliant 5W Wireless Power Receiver IC REG 68H REG 69H 2 24bit RP[2] R 0 1 24bit RP[1] R 0 0 24bit RP[0] R 0 Bit Field Type Default 7 TX POWER CLASS[1] R 0 6 TX POWER CLASS[0] R 0 5 TX_GUARANTEED_POWER[5] R 0 4 TX_GUARANTEED_POWER[4] R 0 3 TX_GUARANTEED_POWER[3] R 0 2 TX_GUARANTEED_POWER[2] R 0 1 TX_GUARANTEED_POWER[1] R 0 0 TX_GUARANTEED_POWER[0] R 0 Bit Field Type Default 7 Reserved - - 6 Reserved - - 5 TX_POTENTIAL_POWER[5] R 0 4 TX_POTENTIAL_POWER[4] R 0 3 TX_POTENTIAL_POWER[3] R 0 2 TX_POTENTIAL_POWER[2] R 0 1 TX_POTENTIAL_POWER[1] R 0 0 TX_POTENTIAL_POWER[0] R 0 CELFRAS Semiconductor, Inc. -13- Description TX Power Class Value by FSK TX Guaranteed Power Value by FSK Description Reserved TX Potential Power Value by FSK CWR500 Datasheet (Rev 1.0) CWR500 Qi Compliant 5W Wireless Power Receiver IC 3. Package Outline Figure 5. WLCSP 50B Package Outline, 2.64mm x 3.94mm, 0.4mm pitch CELFRAS Semiconductor, Inc. -14- CWR500 Datasheet (Rev 1.0) CWR500 Qi Compliant 5W Wireless Power Receiver IC 4. Electrical Characteristics 4.1 4.2 4.3 Absolute Maximum Rating PIN Parameter Rating Unit AC1, AC2, COMM1, COMM2, CMA, CMB VRECT, CLAMP Voltage -0.3 to 20 V BOOST1, BOOST2 Voltage -0.3 to 26 V VOUT Voltage -0.3 to 9.5 V VPP Voltage -0.3 to 8 V VDD_5V, VDD_DIG, ENB, CHG_DONE ILIM, FOD, EXT_TS, SCL, SDA Voltage -0.3 to 6 V PGND Voltage -0.3 to 0.3 V AC1, AC2, VRECT, VOUT, CLAMP, PGND Current 1.5 A COMM1, COMM2, CMA, CMB RMS Current 1 A Recommended Operating Condition Symbol Description Min. VRECT Rectifier voltage range 4 IOUT Typ. Max. Unit 15 V Main LDO output current 1.5 A ICOMM COMM1, COMM2 sink current 500 mA ICM CMA, CMB sink current 500 mA TJ Junction temperature -30 125 ℃ TA Ambient temperature -30 85 ℃ Thermal Information CWR500 WLCSP 50B 2. 64mm x 3.94mm Parameters UNITS Junction-to-ambient thermal resistance ℃/W Junction-to-case thermal resistance ℃/W Junction-to-board thermal resistance ℃/W Junction temperature,TJ ℃ Ambient operation temperature ℃ Storage temperature,Tstg ℃ Lead soldering temperature,TL(10s) ℃ CELFRAS Semiconductor, Inc. -15- CWR500 Datasheet (Rev 1.0) CWR500 Qi Compliant 5W Wireless Power Receiver IC 4.4 ESD Test Model RATINGS UNITS HBM: all pins CDM: all pins 4.5 V V ELECTRICAL Characteristics Unless otherwise specified: TA = -20°C to 70°C. Typical values are for TA = 25°C Symbol Description Conditions Min. Typ. Max. Unit Synchronous Active Rectifier VIN_RECT AC1, AC2 input voltage range 4.0 20 V fIN_RECT AC1, AC2 input frequency range 80 500 kHz Eff_RECT AC to DC power conversion efficiency VUVLO VUVLO_HYS 92 Under voltage lockout VRECT: 0V to 4V 3.2 Under voltage lockout hysteresis VRECT: 4V to 0V 400 % 3.3 V mV Main LDO VIN_MLDO VOUT_MLDO VOUT_MLDO_STEP Main LDO input voltage range Main LDO output voltage range Register programmable VRECT>5V 4.0 15 V 4.5 12 V Main LDO output voltage control step 0.5 IOUT_MLDO Main LDO output current range PSRR_MLDO Main LDO power supply rejection ratio V 1.7 CVOUT=3.3uF DC to 100MHz 20 A dB Internal LDO VOUT_VDD_5V VOUT_VDD_DIG Internal VDD_5V LDO output voltage range Internal VDD_DIG LDO output voltage range VRECT>5V, CVDD_5V=1uF, External load3V, CVDD_DIG=1uF External load3V 1.22 V Internal oscillator frequency Register programmable VRECT>3V 15 MHz ADC resolution VRECT>3V 12 bit fOSC=15MHz 217 kSa/s Oscillator fOSC ADC NADC fSAMPLE ADC sampling rate NCH_ADC ADC channel 7 ENB/CHG_DOWN VIH ENB/CHG_DOWN input threshold high CELFRAS Semiconductor, Inc. 1.5 -16- V CWR500 Datasheet (Rev 1.0) CWR500 Qi Compliant 5W Wireless Power Receiver IC VIL ENB/CHG_DOWN input threshold low 0.5 V 15.2 V Protection VOVP VOVP_HYS IOCL IOCL_HYS TOTP VRECT over voltage protection Register programmable VRECT: 5V to 16V OVP hysteresis VRECT: 16V to 5V IOUT over current limit protection Programmable by RILIM IOUT: 0A to 2A OCL hysteresis IOUT: 2A to 0A Over temperature protection Thermal shutdown temperature Temperature: 14.8 RILIM=24kΩ 30℃ to 160℃ Temperature: 15 1.5 V 1.875 A 50 mA 150 ℃ 20 ℃ TOTP_HYS OTP hysteresis VTS_HOT EXT_TS hot temperature protection threshold voltage VEXT_TS: 0V to 0.5V 0.315 V VTS_HOT hysteresis VEXT_TS: 0.5V to 0V 20 mV EXT_TS cold temperature protection threshold voltage VEXT_TS: 0.5V to 1.5V 0.980 V VTS_COLD hysteresis VEXT_TS: 1.5V to 0.5V 80 mV VTS_HOT_HYS VTS_COLD VTS_COLD_HYS 160℃ to 30℃ 5. I2C Signal Timing Figure 7. Timing Diagram for I2C interface Symbol Description Conditions VIL_SDA Input low threshold level SDA VPULLUP=VDD_DIG=3V VIH_SDA Input high threshold level SDA VPULLUP=VDD_DIG=3V VIL_SCL Input low threshold level SCL VPULLUP=VDD_DIG=3V VIH_SCL Input high threshold level SCL VPULLUP=VDD_DIG=3V Min. Typ. Max. Unit 0.7 V 2.3 V 0.7 2.3 V V fSCL SCL clock frequency tLOW SCL clock low time 1.3 us tHIGH SCL clock high time 0.6 us tr 400 Rise time of both SDA and SCL CELFRAS Semiconductor, Inc. 0.3 -17- kHz us CWR500 Datasheet (Rev 1.0) CWR500 Qi Compliant 5W Wireless Power Receiver IC tf Fall time of both SDA and SCL 0.3 us tSU,STA Setup time for START condition 0.6 us tHD,STA Hold time for START condition 0.6 us tSU,DAT Data setup time 0.1 us tHD,DAT Data hold time tSU,STO Setup time for STOP condition 0.6 us Bus free time between STOP and START condition 1.3 us tBF 0.9 us Table 3. I2C Characteristics CELFRAS Semiconductor, Inc. -18- CWR500 Datasheet (Rev 1.0) CWR500 Qi Compliant 5W Wireless Power Receiver IC Revision History Date Version No. 2017/07/27 1.0 Description Preliminary Release Ordering Information Part Number CWR500-W5 CWR500-W9 CWR500-WC Shipping Carrier Package Type WLCSP 50, 2.6 4mm x 3.94m m WLCSP 50, 2.6 4mm x 3.94m m WLCSP 50, 2.6 4mm x 3.94m m Tape and Reel Eco Plan Package Qty Green (RoHS&noSb/Br) MSL Peak Temp Description Level-1-260C-UNLIM VOUT=5V(BPP), 5V(EPP) Tape and Reel Green (RoHS& no Sb/Br) Level-1-260C-UNLIM VOUT=5V(BPP), 9V(EPP) Tape and Reel Green (RoHS& no Sb/Br) Level-1-260C-UNLIM VOUT=5V(BPP), 12V(EPP) CELFRAS Semiconductor, Inc. -19- Device M arking CWR500 Datasheet (Rev 1.0) CWR500 Qi Compliant 5W Wireless Power Receiver IC Contact US  Headquarters CELFRAS Semiconductor Inc. 江西联智集成电路有限公司 59 Chuangxin No.1 Road, Nanchang Hi-tech Development Zone, Nanchang, Jiangxi, P.R.CHINA, Zip:33000 0  International CELFRAS Design Center Inc. 7F, 225-14, Pangyoyeok-ro, Bundang-gu, Seongnam-si, Gyeonggi-do, 13494, Korea Tel. +82-70-4055-6466 Fax +82-31-707-8825  Contact Website Technical Support cts@celfras.com, ken_zhang@celfras.com Sales Contact marketing@celfras.com Copyright © 2018 CELFRAS., Inc. All rights reserved. CELFRAS., Inc. CELFRAS Semiconductor, Inc. -20- CWR500 Datasheet (Rev 1.0)
CWR-500(CSP) 价格&库存
很抱歉,暂时无法提供与“CWR-500(CSP)”相匹配的价格&库存,您可以联系我们找货
CWR-500(CSP)
    • 1+10.49760
    • 10+8.84520
    • 30+7.80840
    库存:6
