Demo kit(Hardware+Software)
    UNEO(利永环球)
    8 PORTS DEMO KIT 硬件+软件 (HARDWARE+SOFTWARE)
Demo kit(Hardware+Software) 数据手册
8-Channel Resistive Force Sensor Demo Kit Demo Kit Software Download link: http://files.uneotech.com:8080/share.cgi?ssid=05hPvnh Hardware spec:58mm x 155mm 4-Channel VR100K Resistor ( Sensor A / Sensor B / Sensor C / Sensor D ) 4-Channel Fixed 10K Resistor ( Sensor E / Sensor F / Sensor G / Sensor H ) Software interface: Frequency option Data type for the line chart Current saved path Record Chang saved path There are five different data types for the line chart (mmHg; Force(g); g/cm2; R(ohm); Conductivity) and the line chart image on the software interface can be saved. Since the value of each data types (mmHg; Force(g); g/cm2; R(ohm); Conductivity) should be computed through the value of ADC to find out their relationship, so setting in advance is required when first time use the demo kit and software. Software setting function: Step 1: click "Setting", then enter the operation interface . Step 2: Choose the quantity of weight that needs to be calibrated. Step 3: click channel to do calibration (only can calibrate one channel each time) Channel you chose will display red. Calibrated information: Sensor sensing area Force (unit: g) ; ADC value Resistance of reference resistor 解析資料: ADC can measure voltage from voltage divider circuit. In order to get the resistance of sensor, please refer to below formula: Rsensor = Ref.Res *{[(ADC full level)-ADC]/ADC} Uneo sensor have linear relationship between Conductivity and Force, so need to get the conductivity first, then calculate the force. There are 8 channels in one demo kit. 4 Ref.Res for Variable resistance+Fixed resistance and 4 RefRes for only Fixed resistance. For example, Ref.Res is 100K and ADC value is 256, so Rsensor = 100K * (1023-256)/256 ==> Rsensor is 300K Resistance / Conductivity: Use ADC value and RefRes to find out Pressure: Use Force(g) to construct a linear equation with one variable, and find the pressure value by current Conductivity. mmHg / g/cm2: Use Sensor Sensing Area and Force(g) to find out pressure. Step 4: Update “Sensor Area/ Ref. resistance/ Force/ ADC value” Update Sensor area size: Click "Update": Update above area size to below channel which was selected. Update Ref. resistance: Click "Update": Update above resistance value to below channel which was selected. Update force and ADC: Click "Update": Update force value and ADC value. Step 5: check current parameter and save, then re-start software. Circuit:
Demo kit(Hardware+Software) 价格&库存
很抱歉,暂时无法提供与“Demo kit(Hardware+Software)”相匹配的价格&库存,您可以联系我们找货
